[GRASS-SVN] r45288 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Feb 2 07:56:11 EST 2011
Author: martinl
Date: 2011-02-02 04:56:11 -0800 (Wed, 02 Feb 2011)
New Revision: 45288
grass/trunk/gui/wxpython/gui_modules/dbm.py
grass/trunk/gui/wxpython/gui_modules/layertree.py
grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
grass/trunk/gui/wxpython/gui_modules/vdigit.py
grass/trunk/gui/wxpython/gui_modules/wxvdigit.py
grass/trunk/gui/wxpython/gui_modules/wxvdriver.py
wxGUI/vdigit: geometry attributes reimplemented in Python
Modified: grass/trunk/gui/wxpython/gui_modules/dbm.py
--- grass/trunk/gui/wxpython/gui_modules/dbm.py 2011-02-01 23:21:26 UTC (rev 45287)
+++ grass/trunk/gui/wxpython/gui_modules/dbm.py 2011-02-02 12:56:11 UTC (rev 45288)
@@ -2568,10 +2568,10 @@
def __createDeletePage(self):
"""!Delete layer"""
self.deletePanel = wx.Panel(parent=self, id=wx.ID_ANY)
- self.AddPage(page=self.deletePanel, text=_("Delete layer"))
+ self.AddPage(page=self.deletePanel, text=_("Remove layer"))
label = wx.StaticText(parent=self.deletePanel, id=wx.ID_ANY,
- label='%s:' % _("Layer to detele"))
+ label='%s:' % _("Layer to remove"))
self.deleteLayer = wx.ComboBox(parent=self.deletePanel, id=wx.ID_ANY, size=(100, -1),
style=wx.CB_SIMPLE | wx.CB_READONLY,
@@ -2592,7 +2592,7 @@
self.deleteLayer.Enable(False)
self.deleteTable.Enable(False)
- btnDelete = wx.Button(self.deletePanel, wx.ID_DELETE, _("&Delete layer"),
+ btnDelete = wx.Button(self.deletePanel, wx.ID_DELETE, _("&Remove layer"),
size=(125,-1))
btnDelete.Bind(wx.EVT_BUTTON, self.OnDeleteLayer)
Modified: grass/trunk/gui/wxpython/gui_modules/layertree.py
--- grass/trunk/gui/wxpython/gui_modules/layertree.py 2011-02-01 23:21:26 UTC (rev 45287)
+++ grass/trunk/gui/wxpython/gui_modules/layertree.py 2011-02-02 12:56:11 UTC (rev 45288)
@@ -961,13 +961,12 @@
menuform.GUI().ParseCommand(['d.rast.num'], completed = (self.GetOptData,layer,params),
parentframe = self, centreOnParent = False)
elif ltype == 'vector':
- types = ''
- for type in UserSettings.Get(group = 'cmd', key = 'showType').keys():
+ types = list()
+ for ftype in ['point', 'line', 'boundary', 'centroid', 'area', 'face']:
if UserSettings.Get(group = 'cmd', key = 'showType', subkey = [type, 'enabled']):
- types += type + ','
- types = types.rstrip(',')
+ types.append(ftype)
- menuform.GUI().ParseCommand(['d.vect', 'type=%s' % types],
+ menuform.GUI().ParseCommand(['d.vect', 'type=%s' % ','.join(types)],
elif ltype == 'thememap':
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py 2011-02-01 23:21:26 UTC (rev 45287)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py 2011-02-02 12:56:11 UTC (rev 45288)
@@ -1251,8 +1251,8 @@
if digitToolbar.GetAction('type') in ['point', 'centroid']:
# add new point / centroiud
east, north = self.Pixel2Cell(self.mouse['begin'])
- fid = digitClass.AddFeature(digitToolbar.GetAction('type'), [(east, north)])
- if fid < 0:
+ nfeat, fids = digitClass.AddFeature(digitToolbar.GetAction('type'), [(east, north)])
+ if nfeat < 1:
return
self.UpdateMap(render = False) # redraw map
@@ -1260,7 +1260,7 @@
# add new record into atribute table
if UserSettings.Get(group = 'vdigit', key = "addRecord", subkey = 'enabled'):
# select attributes based on layer and category
- cats = { fid : {
+ cats = { fids[0] : {
UserSettings.Get(group = 'vdigit', key = "layer", subkey = 'value') :
(UserSettings.Get(group = 'vdigit', key = "category", subkey = 'value'), )
@@ -1273,12 +1273,13 @@
pos = posWindow,
action = "add")
- if not point:
- self.__geomAttrb(fid, addRecordDlg, 'area', digitClass,
- digitToolbar.GetLayer())
- self.__geomAttrb(fid, addRecordDlg, 'perimeter', digitClass,
+ if digitToolbar.GetAction('type') == 'centroid':
+ for fid in fids:
+ self._geomAttrb(fid, addRecordDlg, 'area', digitClass,
+ digitToolbar.GetLayer())
+ self._geomAttrb(fid, addRecordDlg, 'perimeter', digitClass,
if addRecordDlg.mapDBInfo and \
addRecordDlg.ShowModal() == wx.ID_OK:
sqlfile = tempfile.NamedTemporaryFile(mode = "w")
@@ -1299,7 +1300,7 @@
self.polycoords.append(self.Pixel2Cell(event.GetPositionTuple()[:]))
self.DrawLines(pdc = self.pdcTmp)
- def __geomAttrb(self, fid, dialog, attrb, digit, mapLayer):
+ def _geomAttrb(self, fid, dialog, attrb, digit, mapLayer):
"""!Trac geometry attributes?"""
item = self.tree.FindItemByData('maplayer', mapLayer)
vdigit = self.tree.GetPyData(item)[0]['vdigit']
@@ -1324,7 +1325,7 @@
dialog.SetColumnValue(layer, column, val)
dialog.OnReset()
- def __geomAttrbUpdate(self, fids):
+ def _geomAttrbUpdate(self, fids):
"""!Update geometry atrributes of currently selected features
@param fid list feature id
@@ -2158,7 +2159,7 @@
if fid < 0:
return
- self.__geomAttrbUpdate([fid,])
+ self._geomAttrbUpdate([fid,])
del self.vdigitMove
@@ -2178,19 +2179,24 @@
digitToolbar.GetAction('type') in ["line", "boundary", "area"]:
# -> add new line / boundary
try:
- map = digitToolbar.GetLayer().GetName()
+ mapName = digitToolbar.GetLayer().GetName()
except:
- map = None
+ mapName = None
wx.MessageBox(parent = self,
message = _("No vector map selected for editing."),
caption = _("Error"), style = wx.OK | wx.ICON_ERROR | wx.CENTRE)
- if map:
+ if mapName:
+ if digitToolbar.GetAction('type') == 'line':
+ line = True
+ else:
+ line = False
if len(self.polycoords) < 2: # ignore 'one-point' lines
return
- fid = digitClass.AddFeature(digitToolbar.GetAction('type'), self.polycoords)
- if fid < 0:
+ nfeat, fids = digitClass.AddFeature(digitToolbar.GetAction('type'), self.polycoords)
+ if nfeat < 0:
return
position = self.Cell2Pixel(self.polycoords[-1])
@@ -2202,29 +2208,30 @@
if UserSettings.Get(group = 'vdigit', key = "addRecord", subkey = 'enabled') and \
(line is True or \
- (not line and fid > 0)):
+ (not line and nfeat > 0)):
posWindow = self.ClientToScreen((position[0] + self.dialogOffset,
position[1] + self.dialogOffset))
- cats = { fid : {
- addRecordDlg = dbm_dialogs.DisplayAttributesDialog(parent = self, map = map,
+ addRecordDlg = dbm_dialogs.DisplayAttributesDialog(parent = self, map = mapName,
cats = cats,
pos = posWindow,
action = "add")
- self.__geomAttrb(fid, addRecordDlg, 'length', digitClass,
- # auto-placing centroid
+ for fid in fids:
+ self._geomAttrb(fid, addRecordDlg, 'length', digitClass,
+ # auto-placing centroid
@@ -2258,7 +2265,7 @@
fid = digitClass.RemoveVertex(self.Pixel2Cell(self.mouse['begin']))
if fid < 0:
return
elif digitToolbar.GetAction() in ("copyCats", "copyAttrs"):
try:
if digitToolbar.GetAction() == 'copyCats':
Modified: grass/trunk/gui/wxpython/gui_modules/vdigit.py
--- grass/trunk/gui/wxpython/gui_modules/vdigit.py 2011-02-01 23:21:26 UTC (rev 45287)
+++ grass/trunk/gui/wxpython/gui_modules/vdigit.py 2011-02-02 12:56:11 UTC (rev 45288)
@@ -514,7 +514,7 @@
row += 1
note = '\n'.join(textwrap.wrap(_("Note: These settings are stored "
- " in the workspace not in the vector digitizer "
+ "in the workspace not in the vector digitizer "
"preferences."), 55))
gridSizer.Add(item = wx.StaticText(parent = panel, id = wx.ID_ANY,
label = note),
@@ -704,6 +704,7 @@
def UpdateSettings(self):
"""!Update digitizer settings
+ self.parent.GetLayerManager().WorkspaceChanged() # geometry attributes
# symbology
for key, (enabled, color) in self.symbology.iteritems():
if enabled:
Modified: grass/trunk/gui/wxpython/gui_modules/wxvdigit.py
--- grass/trunk/gui/wxpython/gui_modules/wxvdigit.py 2011-02-01 23:21:26 UTC (rev 45287)
+++ grass/trunk/gui/wxpython/gui_modules/wxvdigit.py 2011-02-02 12:56:11 UTC (rev 45288)
@@ -431,7 +431,7 @@
@param ftype feature type (point, line, centroid, boundary)
@param points tuple of points ((x, y), (x, y), ...)
- @return new feature id
+ @return tuple (number of added features, feature ids)
if UserSettings.Get(group = 'vdigit', key = "categoryMode", subkey = 'selection') == 2:
layer = -1 # -> no category
@@ -453,12 +453,12 @@
else:
GError(parent = self.mapWindow,
message = _("Unknown feature type '%s'") % ftype)
- return
+ return (-1, None)
if vtype & GV_LINES and len(points) < 2:
message = _("Not enough points for line"))
- return
+ return (-1, None)
self.toolbar.EnableUndo()
@@ -1007,7 +1007,22 @@
@return line length
@return -1 on error
- return self.digit.GetLineLength(line)
+ if not self._checkMap():
+ return -1
+ if not Vect_line_alive(self.poMapInfo, line):
+ return -1
+ ltype = Vect_read_line(self.poMapInfo, self.poPoints, None, line)
+ if ltype < 0:
+ self._error.ReadLine(line)
+ return ret
+ length = -1
+ if ltype & GV_LINES: # lines & boundaries
+ length = Vect_line_length(self.poPoints)
+ return length
def GetAreaSize(self, centroid):
"""!Get area size
@@ -1017,18 +1032,57 @@
@return area size
@return -1 on error
- return self.digit.GetAreaSize(centroid)
+ return -1
+ ltype = Vect_read_line(self.poMapInfo, None, None, centroid)
+ if ltype < 0:
+ return ret
+ if ltype != GV_CENTROID:
+ return -1
+ area = Vect_get_centroid_area(self.poMapInfo, centroid)
+ size = -1
+ if area > 0:
+ if not Vect_area_alive(self.poMapInfo, area):
+ return size
+ size = Vect_get_area_area(self.poMapInfo, area)
+ return size
def GetAreaPerimeter(self, centroid):
"""!Get area perimeter
@param centroid centroid id
@return area size
@return -1 on error
- return self.digit.GetAreaPerimeter(centroid)
+ return -1
+ if ltype < 0:
+ return ret
+ return -1
+ perimeter = -1
+ if area > 0:
+ if not Vect_area_alive(self,poMapInfo, area):
+ return -1
+ Vect_get_area_points(self.poMapInfo, area, self.poPoints)
+ perimeter = Vect_area_perimeter(self.poPoints)
+ return perimeter
def SetLineCats(self, line, layer, cats, add=True):
"""!Set categories for given line and layer
@@ -1246,7 +1300,7 @@
return True
def _addFeature(self, ftype, coords, layer, cat, snap, threshold):
- """!Add new feature to the vector map
+ """!Add new feature(s) to the vector map
@param ftype feature type (GV_POINT, GV_LINE, GV_BOUNDARY, ...)
@coords tuple of coordinates ((x, y), (x, y), ...)
@@ -1255,11 +1309,12 @@
@param snap snap to node/vertex
@param threshold threshold for snapping
- @return -1 on error
- @return feature id of new feature
+ @return tuple (number of added features, list of fids)
+ @return number of features -1 on error
+ fids = list()
- return -1
+ return (-1, None)
is3D = bool(Vect_is_3d(self.poMapInfo))
@@ -1268,7 +1323,7 @@
if not (ftype & (GV_POINTS | GV_LINES | GV_AREA)): # TODO: 3D
self._error.FeatureType(ftype)
- return -1
+ return (-1, None)
# set category
Vect_reset_cats(self.poCats)
@@ -1305,7 +1360,9 @@
newline = Vect_write_line(self.poMapInfo, ltype, self.poPoints, self.poCats)
if newline < 0:
self._error.WriteLine()
- return -1
+ return (-1, None)
+ else:
+ fids.append(newline)
left = right = -1
if ftype & GV_AREA:
@@ -1332,21 +1389,28 @@
Vect_find_poly_centroid(bpoints, byref(x), byref(y)) == 0:
Vect_reset_line(bpoints)
Vect_append_point(bpoints, x.value, y.value, 0.0)
- if Vect_write_line(self.poMapInfo, GV_CENTROID,
- bpoints, self.poCats) < 0:
+ newline = Vect_write_line(self.poMapInfo, GV_CENTROID,
+ bpoints, self.poCats)
+ if newline < 0:
- return -1
+ return (len(fids), fids)
+ else:
if right > 0 and \
Vect_get_area_centroid(self.poMapInfo, right) == 0:
if Vect_get_area_points(byref(self.poMapInfo), right, bpoints) > 0 and \
- if Vect_write_line(byref(self.poMapInfo), GV_CENTROID,
+ newline = Vect_write_line(byref(self.poMapInfo), GV_CENTROID,
+ if newline < 0:
- return -1
+ return (len(fids, fids))
+ else:
Vect_destroy_line_struct(bpoints)
# register changeset
@@ -1357,7 +1421,7 @@
if self._settings['breakLines']:
self._breakLineAtIntersection(newline, self.poPoints, changeset)
- return newline
def _ModifyLineVertex(self, coords, add = True):
"""!Add or remove vertex
Modified: grass/trunk/gui/wxpython/gui_modules/wxvdriver.py
--- grass/trunk/gui/wxpython/gui_modules/wxvdriver.py 2011-02-01 23:21:26 UTC (rev 45287)
+++ grass/trunk/gui/wxpython/gui_modules/wxvdriver.py 2011-02-02 12:56:11 UTC (rev 45288)
@@ -390,10 +390,10 @@
def _isDuplicated(self, line):
"""!Check for already marked duplicates
- \param line feature id
+ @param line feature id
- \return True line already marked as duplicated
- \return False not duplicated
+ @return True line already marked as duplicated
+ @return False not duplicated
return line in self.selected['idsDupl']
