[GRASS-SVN] r45305 - grass/trunk/ps/ps.map
svn_grass at osgeo.org
Fri Feb 4 03:38:55 EST 2011
Author: hamish
Date: 2011-02-04 00:38:55 -0800 (Fri, 04 Feb 2011)
New Revision: 45305
grass/trunk/ps/ps.map/main.c
grass/trunk/ps/ps.map/ps.map.html
remove command line scale option (use map instruction instead)
Modified: grass/trunk/ps/ps.map/main.c
--- grass/trunk/ps/ps.map/main.c 2011-02-04 07:18:16 UTC (rev 45304)
+++ grass/trunk/ps/ps.map/main.c 2011-02-04 08:38:55 UTC (rev 45305)
@@ -95,7 +95,6 @@
int iflag;
int can_reset_scale;
int copies_set;
- struct Option *map_scale;
struct Option *input_file;
struct Option *output_file;
struct Option *copies;
@@ -148,13 +147,6 @@
output_file->description = _("PostScript output file");
/* output_file->required = YES; Can omit for -p list page size & exit mode */
- map_scale = G_define_option();
- map_scale->key = "scale";
- map_scale->key_desc = "mapscale";
- map_scale->type = TYPE_STRING;
- map_scale->description =
- _("Scale of the output map, e.g. 1:25000 (default: Auto-sized to fit page)");
copies = G_define_option();
copies->key = "copies";
copies->type = TYPE_INTEGER;
@@ -251,17 +243,6 @@
G_fatal_error("%s - %s: %s", G_program_name(),
input_file->answer, strerror(errno));
- if (map_scale->answer) {
- G_warning(_("Using <%s> from the command line is depreciated. "
- "Please use the <%s> mapping instruction instead. "
- "The parameter <%s> will be removed in future versions of GRASS."),
- "scale", "scale", "scale");
- can_reset_scale = isatty(0);
- if (check_scale(map_scale->answer))
- strcpy(PS.scaletext, map_scale->answer);
- else
- error(map_scale->answer, "", "illegal scale request");
if (copies->answer) {
if (sscanf(copies->answer, "%d", &ps_copies) != 1) {
Modified: grass/trunk/ps/ps.map/ps.map.html
--- grass/trunk/ps/ps.map/ps.map.html 2011-02-04 07:18:16 UTC (rev 45304)
+++ grass/trunk/ps/ps.map/ps.map.html 2011-02-04 08:38:55 UTC (rev 45305)
@@ -1087,12 +1087,6 @@
<B>scale</B> 1:25000
</PRE>
<P>
-This instruction is identical to the <EM>scale</EM> command line parameter.
-<BR>
-<em>NOTE: Using "scale" from the command line is depreciated and while
-still provided for compatibility reasons it will be removed in the future.
-Please use the "scale" mapping instruction instead.</em>
-<P>
<a name="scalebar"></a>
