[GRASS-SVN] r45311 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Fri Feb 4 10:02:32 EST 2011
Author: martinl
Date: 2011-02-04 07:02:32 -0800 (Fri, 04 Feb 2011)
New Revision: 45311
grass/branches/develbranch_6/gui/wxpython/gui_modules/wxvdriver.py
wxGUI/vdigit: fix adding new vertex (line not found)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/wxvdriver.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/wxvdriver.py 2011-02-04 09:23:38 UTC (rev 45310)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/wxvdriver.py 2011-02-04 15:02:32 UTC (rev 45311)
@@ -565,14 +565,13 @@
@param poMapInfo use external Map_info, None for self.poMapInfo
@return dict {'line' : feature id, 'point' : point on line}
- @return None nothing found
thisMapInfo = poMapInfo is None
if not poMapInfo:
poMapInfo = self.poMapInfo
if not poMapInfo:
- return None
+ return { 'line' : -1, 'point': None }
if thisMapInfo:
self._drawSelected = True
@@ -601,7 +600,7 @@
py = c_double()
pz = c_double()
if not self._validLine(lineNearest):
- return None
ftype = Vect_read_line(poMapInfo, self.poPoints, self.poCats, lineNearest)
Vect_line_distance (self.poPoints, point[0], point[1], 0.0, self.is3D,
byref(px), byref(py), byref(pz),
