[GRASS-SVN] r45328 - grass/branches/develbranch_6/db/drivers/dbf
Mon Feb 7 12:50:38 EST 2011
Author: neteler
Date: 2011-02-07 09:50:38 -0800 (Mon, 07 Feb 2011)
New Revision: 45328
   grass/branches/develbranch_6/db/drivers/dbf/dbfexe.c
revert bad formatting
Modified: grass/branches/develbranch_6/db/drivers/dbf/dbfexe.c
--- grass/branches/develbranch_6/db/drivers/dbf/dbfexe.c	2011-02-07 13:08:54 UTC (rev 45327)
+++ grass/branches/develbranch_6/db/drivers/dbf/dbfexe.c	2011-02-07 17:50:38 UTC (rev 45328)
@@ -33,41 +33,27 @@
 #define NODE_ERROR  4
 int yyparse(void);
 void get_col_def(SQLPSTMT * st, int col, int *type, int *width,
 		 int *decimals);
 int sel(SQLPSTMT * st, int tab, int **set);
 void eval_val(int tab, int row, int col, SQLPVALUE * inval,
 	      SQLPVALUE * result);
 int set_val(int tab, int row, int col, SQLPVALUE * val);
 double eval_node(SQLPNODE *, int, int, SQLPVALUE *);
 int eval_node_type(SQLPNODE *, int);
 int execute(char *sql, cursor * c)
     int i, j, tab, ret;
     SQLPSTMT *st;
     ROW *dbrows;
     VALUE *dbval;
     int row, nrows;
     int *cols, ncols, col;
     int *selset;
     int dtype, stype;
     int width, decimals;
     char *tmpsql, name[500];
     SQLPVALUE *calctmp;		/* store for calculated values in UPDATE, if any */
     /* parse sql statement */
@@ -486,15 +472,10 @@
 static int cmp_row_asc(const void *pa, const void *pb)
     int *row1 = (int *)pa;
     int *row2 = (int *)pb;
     char *c1, *c2;
     int i1, i2;
     double d1, d2;
     TABLE *tbl;
     tbl = &(db.tables[cur_cmp_table]);
@@ -554,9 +535,7 @@
 int sel(SQLPSTMT * st, int tab, int **selset)
     int i, ret, condition;
     int *set;			/* pointer to array of indexes to rows */
     int aset, nset;
     G_debug(2, "sel(): tab = %d", tab);
@@ -683,17 +662,11 @@
 double eval_node(SQLPNODE * nptr, int tab, int row, SQLPVALUE * value)
     int left, right;
     SQLPVALUE left_value, right_value;
     int ccol;
     COLUMN *col;
     VALUE *val;
     double left_dval, right_dval, dval;
     char *rightbuf;
     /* Note: node types were previously checked by eval_node_type */
@@ -1033,9 +1006,7 @@
 int eval_node_type(SQLPNODE * nptr, int tab)
     int left, right;
     int ccol;
     COLUMN *col = NULL;
     switch (nptr->node_type) {
