[GRASS-SVN] r45345 -
grass/branches/releasebranch_6_4/vector/v.overlay
svn_grass at osgeo.org
Wed Feb 9 09:42:51 EST 2011
Author: neteler
Date: 2011-02-09 06:42:51 -0800 (Wed, 09 Feb 2011)
New Revision: 45345
grass/branches/releasebranch_6_4/vector/v.overlay/main.c
patch from Martin Landa to catch wrong atype parameter (user error)
Modified: grass/branches/releasebranch_6_4/vector/v.overlay/main.c
--- grass/branches/releasebranch_6_4/vector/v.overlay/main.c 2011-02-09 12:42:22 UTC (rev 45344)
+++ grass/branches/releasebranch_6_4/vector/v.overlay/main.c 2011-02-09 14:42:51 UTC (rev 45345)
@@ -194,7 +194,7 @@
/* Copy lines to output */
for (input = 0; input < 2; input++) {
- int ncats, index;
+ int ncats, index, nlines_out;
G_message(_("Copying vector objects from vector map <%s>..."),
in_opt[input]->answer);
@@ -210,6 +210,7 @@
nlines = Vect_get_num_lines(&(In[input]));
+ nlines_out = 0;
for (line = 1; line <= nlines; line++) {
int ltype;
@@ -227,8 +228,15 @@
Vect_write_line(&Out, ltype, Points, Cats);
+ nlines_out++;
+ if (nlines_out == 0) {
+ Vect_delete(out_opt->answer);
+ G_fatal_error(_("No %s features found in vector map <%s>. Verify '%s' parameter."),
+ type_opt[input]->answer, Vect_get_full_name(&(In[input])),
+ type_opt[input]->key);
/* Allocate attributes */
attr[input].n = 0;
/* this may be more than necessary */
