[GRASS-SVN] r45347 - grass/trunk/vector/v.overlay
svn_grass at osgeo.org
Wed Feb 9 09:43:22 EST 2011
Author: neteler
Date: 2011-02-09 06:43:21 -0800 (Wed, 09 Feb 2011)
New Revision: 45347
grass/trunk/vector/v.overlay/main.c
patch from Martin Landa to catch wrong atype parameter (user error)
Modified: grass/trunk/vector/v.overlay/main.c
--- grass/trunk/vector/v.overlay/main.c 2011-02-09 14:43:06 UTC (rev 45346)
+++ grass/trunk/vector/v.overlay/main.c 2011-02-09 14:43:21 UTC (rev 45347)
@@ -196,7 +196,7 @@
/* Copy lines to output */
for (input = 0; input < 2; input++) {
- int ncats, index;
+ int ncats, index, nlines_out;
Vect_set_open_level(2);
Vect_open_old2(&(In[input]), in_opt[input]->answer, "", field_opt[input]->answer);
@@ -207,6 +207,7 @@
nlines = Vect_get_num_lines(&(In[input]));
+ nlines_out = 0;
for (line = 1; line <= nlines; line++) {
int ltype;
@@ -224,8 +225,15 @@
Vect_write_line(&Out, ltype, Points, Cats);
+ nlines_out++;
+ if (nlines_out == 0) {
+ Vect_delete(out_opt->answer);
+ G_fatal_error(_("No %s features found in vector map <%s>. Verify '%s' parameter."),
+ type_opt[input]->answer, Vect_get_full_name(&(In[input])),
+ type_opt[input]->key);
/* Allocate attributes */
attr[input].n = 0;
/* this may be more than necessary */
