[GRASS-SVN] r45362 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Thu Feb 10 14:55:35 EST 2011
Author: mmetz
Date: 2011-02-10 11:55:35 -0800 (Thu, 10 Feb 2011)
New Revision: 45362
grass/trunk/lib/vector/Vlib/break_polygons.c
fix debug level
Modified: grass/trunk/lib/vector/Vlib/break_polygons.c
--- grass/trunk/lib/vector/Vlib/break_polygons.c 2011-02-10 19:16:15 UTC (rev 45361)
+++ grass/trunk/lib/vector/Vlib/break_polygons.c 2011-02-10 19:55:35 UTC (rev 45362)
@@ -121,7 +121,7 @@
int fd, xpntfd;
char *filename;
- G_debug(0, "File-based version of Vect_break_polygons()");
+ G_debug(1, "File-based version of Vect_break_polygons()");
filename = G_tempfile();
fd = open(filename, O_RDWR | O_CREAT | O_EXCL, 0600);
@@ -409,7 +409,7 @@
double dx, dy, a1 = 0, a2 = 0;
int closed, last_point, cross;
- G_debug(0, "Memory-based version of Vect_break_polygons()");
+ G_debug(1, "Memory-based version of Vect_break_polygons()");
RBTree = rbtree_create(compare_xpnts, sizeof(XPNT));
