[GRASS-SVN] r45371 - grass/branches/develbranch_6/gui/wxpython/docs
svn_grass at osgeo.org
Fri Feb 11 11:35:47 EST 2011
Author: neteler
Date: 2011-02-11 08:35:47 -0800 (Fri, 11 Feb 2011)
New Revision: 45371
grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Vector_Digitizer.html
cosmetics
Modified: grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Vector_Digitizer.html
--- grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Vector_Digitizer.html 2011-02-11 16:35:19 UTC (rev 45370)
+++ grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Vector_Digitizer.html 2011-02-11 16:35:47 UTC (rev 45371)
@@ -162,13 +162,13 @@
supported.</li>
<li>Connect two selected lines/boundaries<br> Connect selected
lines or boundaries, the first given line is connected to the
- second one. The second line is broken if necessary. The lines
- are connected only if distance between them is not greater
+ second one. The second line is broken if necessary on each intersection.
+ The lines are connected only if distance between them is not greater
than snapping threshold value.</li>
- <li>Query tool<br>Select vector features by min/max length value
- (linear features or dangles).</li>
- <li>Z-bulk labeling of 3D lines<br> Assign z coordinate to 3D
- vector lines in bounding box.</li>
+ <li>Query tool<br>Select vector features by defining a threshold for
+ min/max length value (linear features or dangles).</li>
+ <li>Z-bulk labeling of 3D lines<br> Assign z coordinate values to 3D
+ vector lines in bounding box. This is useful for labeling contour lines.</li>
<li>Feature type conversion<br> Change feature type of selected
geometry features. Points are converted to centroids,
centroids to points, lines to boundaries and boundaries to
