[GRASS-SVN] r45384 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sat Feb 12 04:54:41 EST 2011
Author: martinl
Date: 2011-02-12 01:54:41 -0800 (Sat, 12 Feb 2011)
New Revision: 45384
Added:
grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_vdigit.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm_dialogs.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/vclean.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/wxnviz.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/wxvdigit.py
wxGUI/vdigit: vdigit related code moved from mapdisp_window to
mapdisp_vdigit
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm_dialogs.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm_dialogs.py 2011-02-11 22:07:34 UTC (rev 45383)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm_dialogs.py 2011-02-12 09:54:41 UTC (rev 45384)
@@ -1,4 +1,4 @@
@package dbm_dialogs.py
@brief DBM-related dialogs
@@ -7,7 +7,7 @@
- DisplayAttributesDialog
- ModifyTableRecord
-(C) 2007-2010 by the GRASS Development Team
+(C) 2007-2011 by the GRASS Development Team
This program is free software under the GNU General Public
License (>=v2). Read the file COPYING that comes with GRASS
@@ -31,27 +31,26 @@
from dbm_base import VectorDBInfo
class DisplayAttributesDialog(wx.Dialog):
- Standard dialog used to add/update/display attributes linked
- to the vector map.
- Attribute data can be selected based on layer and category number
- or coordinates.
- @param parent
- @param map vector map
- @param query query coordinates and distance (used for v.edit)
- @param cats {layer: cats}
- @param line feature id (requested for cats)
- @param style
- @param pos
- @param action (add, update, display)
def __init__(self, parent, map,
query=None, cats=None, line=None,
style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER,
pos=wx.DefaultPosition,
action="add"):
+ """!Standard dialog used to add/update/display attributes linked
+ to the vector map.
+ Attribute data can be selected based on layer and category number
+ or coordinates.
+ @param parent
+ @param map vector map
+ @param query query coordinates and distance (used for v.edit)
+ @param cats {layer: cats}
+ @param line feature id (requested for cats)
+ @param style
+ @param pos
+ @param action (add, update, display)
self.parent = parent # mapdisplay.BufferedWindow
self.map = map
self.action = action
@@ -268,14 +267,15 @@
self.FindWindowById(id).SetValue(str(value))
def OnCancel(self, event):
- """!Cancel button pressed"""
+ """!Cancel button pressed
self.parent.parent.dialogs['attributes'] = None
- if self.parent.parent.digit:
- self.parent.parent.digit.GetDisplay().SetSelected([])
+ if self.parent.digit:
+ self.parent.digit.GetDisplay().SetSelected([])
self.parent.UpdateMap(render = False)
else:
self.parent.parent.OnRender(None)
self.Close()
def OnSubmit(self, event):
@@ -501,15 +501,16 @@
break
class ModifyTableRecord(wx.Dialog):
- """!Dialog for inserting/updating table record"""
def __init__(self, parent, id, title, data, keyEditable=(-1, True),
style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
+ """!Dialog for inserting/updating table record
Notes:
- 'Data' is a list: [(column, value)]
- 'KeyEditable' (id, editable?) indicates if textarea for key column
- is editable(True) or not.
+ 'Data' is a list: [(column, value)]
+ 'KeyEditable' (id, editable?) indicates if textarea for key column
+ is editable(True) or not.
+ # parent -> VDigitWindow
wx.Dialog.__init__(self, parent, id, title, style=style)
self.CenterOnParent()
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py 2011-02-11 22:07:34 UTC (rev 45383)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py 2011-02-12 09:54:41 UTC (rev 45384)
@@ -245,6 +245,8 @@
# default is 2D display mode
self.MapWindow = self.MapWindow2D
self.MapWindow.SetCursor(self.cursors["default"])
+ # used by vector digitizer
+ self.MapWindowVDigit = None
# used by Nviz (3D display mode)
self.MapWindow3D = None
@@ -275,11 +277,6 @@
self.printopt = disp_print.PrintOptions(self, self.MapWindow)
- # Initialization of digitization tool
- self.digit = None
# Init zoom history
self.MapWindow.ZoomHistory(self.Map.region['n'],
@@ -311,7 +308,7 @@
# default toolbar
if name == "map":
self.toolbars['map'] = toolbars.MapToolbar(self, self.Map)
self._mgr.AddPane(self.toolbars['map'],
wx.aui.AuiPaneInfo().
Name("maptoolbar").Caption(_("Map toolbar")).
@@ -324,6 +321,7 @@
# vector digitizer
elif name == "vdigit":
from vdigit import haveVDigit
if not haveVDigit:
from vdigit import errorMsg
msg = _("Unable to start wxGUI vector digitizer.\nDo you want to start "
@@ -347,10 +345,28 @@
log = self._layerManager.goutput
else:
log = None
+ if not self.MapWindowVDigit:
+ from mapdisp_vdigit import VDigitWindow
+ self.MapWindowVDigit = VDigitWindow(self, id = wx.ID_ANY,
+ Map = self.Map, tree = self.tree,
+ lmgr = self._layerManager)
+ self.MapWindowVDigit.Show()
+ self.MapWindow = self.MapWindowVDigit
+ self._mgr.DetachPane(self.MapWindow2D)
+ self.MapWindow2D.Hide()
self.toolbars['vdigit'] = toolbars.VDigitToolbar(parent = self, mapcontent = self.Map,
layerTree = self.tree,
log = log)
+ self.MapWindowVDigit.SetToolbar(self.toolbars['vdigit'])
+ self._mgr.AddPane(self.MapWindowVDigit, wx.aui.AuiPaneInfo().CentrePane().
+ Dockable(False).BestSize((-1,-1)).
+ CloseButton(False).DestroyOnClose(True).
+ Layer(0))
self._mgr.AddPane(self.toolbars['vdigit'],
Name("vdigittoolbar").Caption(_("Vector digitizer toolbar")).
@@ -359,12 +375,12 @@
BottomDockable(False).TopDockable(True).
CloseButton(False).Layer(2).
BestSize((self.toolbars['vdigit'].GetSize())))
# change mouse to draw digitized line
self.MapWindow.mouse['box'] = "point"
- self.MapWindow.zoomtype = 0
- self.MapWindow.pen = wx.Pen(colour = 'red', width = 2, style = wx.SOLID)
- self.MapWindow.polypen = wx.Pen(colour = 'green', width = 2, style = wx.SOLID)
+ self.MapWindow.zoomtype = 0
+ self.MapWindow.pen = wx.Pen(colour = 'red', width = 2, style = wx.SOLID)
+ self.MapWindow.polypen = wx.Pen(colour = 'green', width = 2, style = wx.SOLID)
# georectifier
elif name == "georect":
self.toolbars['georect'] = toolbars.GRToolbar(self, self.Map)
@@ -397,7 +413,7 @@
# update status bar
self.statusbarWin['toggle'].Enable(False)
# erase map window
self.MapWindow.EraseMap()
@@ -541,8 +557,8 @@
self.MapWindow.ClearLines()
# deselect features in vdigit
- if self.toolbars['vdigit'] and self.digit:
- self.digit.GetDisplay().SetSelected([])
+ if self.toolbars['vdigit']:
+ self.MapWindow.display.SetSelected([])
self.MapWindow.UpdateMap(render = True, renderVector = True)
else:
self.MapWindow.UpdateMap(render = True)
Added: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_vdigit.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_vdigit.py (rev 0)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_vdigit.py 2011-02-12 09:54:41 UTC (rev 45384)
@@ -0,0 +1,1064 @@
+ at package mapdisp_vdigit.py
+ at brief Map display canvas extended for vector digitizer
+See also vdigit.py, wxvdriver.py and wxvdigit.py
+Classes:
+ - VDigitWindow
+(C) 2011 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Martin Landa <landa.martin gmail.com>
+import wx
+import dbm_dialogs
+from debug import Debug
+from mapdisp_window import BufferedWindow
+from preferences import globalSettings as UserSettings
+from vdigit import VDigitCategoryDialog
+from vdigit import VDigitZBulkDialog
+from vdigit import VDigitDuplicatesDialog
+class VDigitWindow(BufferedWindow):
+ """!A Buffered window extended for vector digitizer.
+ def __init__(self, parent, id = wx.ID_ANY,
+ Map = None, tree = None, lmgr = None,
+ style = wx.NO_FULL_REPAINT_ON_RESIZE, **kwargs):
+ BufferedWindow.__init__(self, parent, id, Map, tree, lmgr,
+ style, **kwargs)
+ self.pdcVector = wx.PseudoDC()
+ self.toolbar = self.parent.toolbars['vdigit']
+ self.digit = None
+ self.Bind(wx.EVT_KEY_DOWN, self.OnKeyDown)
+ def SetToolbar(self, toolbar):
+ """!Set up related toolbar
+ self.toolbar = toolbar
+ def _onMotion(self, coord, precision):
+ """!Track mouse motion and update statusbar (see self.Motion)
+ @parem coord easting, northing
+ @param precision formatting precision
+ e, n = coord
+ if self.toolbar.GetAction() != 'addLine' or \
+ self.toolbar.GetAction('type') not in ('line', 'boundary') or \
+ len(self.polycoords) == 0:
+ return False
+ # for linear feature show segment and total length
+ distance_seg = self.Distance(self.polycoords[-1],
+ (e, n), screen = False)[0]
+ distance_tot = distance_seg
+ for idx in range(1, len(self.polycoords)):
+ distance_tot += self.Distance(self.polycoords[idx-1],
+ self.polycoords[idx],
+ screen = False)[0]
+ self.parent.statusbar.SetStatusText("%.*f, %.*f (seg: %.*f; tot: %.*f)" % \
+ (precision, e, precision, n,
+ precision, distance_seg,
+ precision, distance_tot), 0)
+ return True
+ def OnKeyDown(self, event):
+ """!Key pressed"""
+ shift = event.ShiftDown()
+ kc = event.GetKeyCode()
+ event = None
+ if not shift:
+ if kc == ord('P'):
+ event = wx.CommandEvent(winid = self.toolbar.addPoint)
+ tool = self.toolbar.OnAddPoint
+ elif kc == ord('L'):
+ event = wx.CommandEvent(winid = self.toolbar.addLine)
+ tool = self.toolbar.OnAddLine
+ if event:
+ self.toolbar.OnTool(event)
+ tool(event)
+ def _updateMap(self):
+ if not self.toolbar or \
+ not self.toolbar.GetLayer():
+ return
+ # set region
+ self.digit.GetDisplay().UpdateRegion()
+ # re-calculate threshold for digitization tool
+ # self.parent.digit.GetDisplay().GetThreshold()
+ # draw map
+ # self.pdcVector.Clear()
+ self.pdcVector.RemoveAll()
+ try:
+ item = self.tree.FindItemByData('maplayer', self.toolbar.GetLayer())
+ except TypeError:
+ item = None
+ if item and self.tree.IsItemChecked(item):
+ self.redrawAll = True
+ self.digit.GetDisplay().DrawMap()
+ # translate tmp objects (pointer position)
+ if self.toolbar.GetAction() == 'moveLine':
+ if self.moveInfo.has_key('beginDiff'):
+ # move line
+ for id in self.moveInfo['id']:
+ self.pdcTmp.TranslateId(id,
+ self.moveInfo['beginDiff'][0],
+ self.moveInfo['beginDiff'][1])
+ del self.moveInfo['beginDiff']
+ def OnLeftDownAddLine(self, event):
+ """!Left mouse button pressed - add new feature
+ try:
+ mapLayer = self.toolbar.GetLayer().GetName()
+ except:
+ return
+ if self.toolbar.GetAction('type') in ['point', 'centroid']:
+ # add new point / centroiud
+ east, north = self.Pixel2Cell(self.mouse['begin'])
+ nfeat, fids = self.digit.AddFeature(self.toolbar.GetAction('type'), [(east, north)])
+ if nfeat < 1:
+ return
+ self.UpdateMap(render = False) # redraw map
+ # add new record into atribute table
+ if UserSettings.Get(group = 'vdigit', key = "addRecord", subkey = 'enabled'):
+ # select attributes based on layer and category
+ cats = { fids[0] : {
+ UserSettings.Get(group = 'vdigit', key = "layer", subkey = 'value') :
+ (UserSettings.Get(group = 'vdigit', key = "category", subkey = 'value'), )
+ posWindow = self.ClientToScreen((self.mouse['end'][0] + self.dialogOffset,
+ self.mouse['end'][1] + self.dialogOffset))
+ addRecordDlg = dbm_dialogs.DisplayAttributesDialog(parent = self, map = mapLayer,
+ cats = cats,
+ pos = posWindow,
+ action = "add")
+ if self.toolbar.GetAction('type') == 'centroid':
+ for fid in fids:
+ self._geomAttrb(fid, addRecordDlg, 'area')
+ self._geomAttrb(fid, addRecordDlg, 'perimeter')
+ if addRecordDlg.mapDBInfo and \
+ addRecordDlg.ShowModal() == wx.ID_OK:
+ sqlfile = tempfile.NamedTemporaryFile(mode = "w")
+ for sql in addRecordDlg.GetSQLString():
+ sqlfile.file.write(sql + ";\n")
+ sqlfile.file.flush()
+ gcmd.RunCommand('db.execute',
+ parent = self,
+ quiet = True,
+ input = sqlfile.name)
+ if addRecordDlg.mapDBInfo:
+ self._updateATM()
+ elif self.toolbar.GetAction('type') in ["line", "boundary", "area"]:
+ # add new point to the line
+ self.polycoords.append(self.Pixel2Cell(event.GetPositionTuple()[:]))
+ self.DrawLines(pdc = self.pdcTmp)
+ def _geomAttrb(self, fid, dialog, attrb):
+ """!Define geometry attributes
+ item = self.tree.FindItemByData('maplayer', mapLayer)
+ vdigit = self.tree.GetPyData(item)[0]['vdigit']
+ if not vdigit or \
+ not vdigit.has_key('geomAttr') or \
+ not vdigit['geomAttr'].has_key(attrb):
+ return
+ val = -1
+ if attrb == 'length':
+ val = self.digit.GetLineLength(fid)
+ type = attrb
+ elif attrb == 'area':
+ val = self.digit.GetAreaSize(fid)
+ type = attrb
+ elif attrb == 'perimeter':
+ val = self.digit.GetAreaPerimeter(fid)
+ type = 'length'
+ if val > 0:
+ layer = int(UserSettings.Get(group = 'vdigit', key = "layer", subkey = 'value'))
+ column = vdigit['geomAttr'][attrb]['column']
+ val = UnitsConvertValue(val, type, vdigit['geomAttr'][attrb]['units'])
+ dialog.SetColumnValue(layer, column, val)
+ dialog.OnReset()
+ def _geomAttrbUpdate(self, fids):
+ """!Update geometry atrributes of currently selected features
+ @param fid list feature id
+ mapLayer = self.parent.toolbars['vdigit'].GetLayer()
+ vectorName = mapLayer.GetName()
+ if vdigit is None or not vdigit.has_key('geomAttr'):
+ return
+ dbInfo = gselect.VectorDBInfo(vectorName)
+ for fid in fids:
+ for layer, cats in self.digit.GetLineCats(fid).iteritems():
+ table = dbInfo.GetTable(layer)
+ for attrb, item in vdigit['geomAttr'].iteritems():
+ val = -1
+ type = attrb
+ type = attrb
+ type = 'length'
+ if val < 0:
+ continue
+ val = UnitsConvertValue(val, type, item['units'])
+ for cat in cats:
+ sqlfile.write('UPDATE %s SET %s = %f WHERE %s = %d;\n' % \
+ (table, item['column'], val,
+ dbInfo.GetKeyColumn(layer), cat))
+ parent = True,
+ quiet = True,
+ def _updateATM(self):
+ """!Update open Attribute Table Manager
+ @todo: use AddDataRow() instead
+ # update ATM
+ digitVector = self.toolbar.GetLayer().GetName()
+ for atm in self.lmgr.dialogs['atm']:
+ atmVector = atm.GetVectorName()
+ if atmVector == digitVector:
+ layer = UserSettings.Get(group = 'vdigit', key = "layer", subkey = 'value')
+ # TODO: use AddDataRow instead
+ atm.LoadData(layer)
+ def OnLeftDownEditLine(self, event):
+ """!Left mouse button pressed - edit linear feature - add new
+ vertex.
+ self.polycoords.append(self.Pixel2Cell(self.mouse['begin']))
+ self.moveInfo['id'].append(wx.NewId())
+ def OnLeftDownMoveLine(self, event):
+ """!Left mouse button pressed - vector digitizer move
+ feature/vertex, edit linear feature
+ self.moveInfo = {}
+ # geographic coordinates of initial position (left-down)
+ self.moveInfo['begin'] = None
+ # list of ids to modify
+ self.moveInfo['id'] = []
+ if self.toolbar.GetAction() in ["moveVertex", "editLine"]:
+ # set pen
+ pcolor = UserSettings.Get(group = 'vdigit', key = "symbol",
+ subkey = ["highlight", "color"])
+ self.pen = self.polypen = wx.Pen(colour = pcolor,
+ width = 2, style = wx.SHORT_DASH)
+ self.pdcTmp.SetPen(self.polypen)
+ def OnLeftDownDisplayCA(self, event):
+ """!Left mouse button pressed - vector digitizer display categories
+ or attributes action
+ try:
+ except:
+ return
+ coords = self.Pixel2Cell(self.mouse['begin'])
+ # unselect
+ self.digit.GetDisplay().SetSelected([])
+ # select feature by point
+ cats = {}
+ if self.digit.GetDisplay().SelectLineByPoint(coords) is None:
+ return
+ if UserSettings.Get(group = 'vdigit', key = 'checkForDupl',
+ subkey = 'enabled'):
+ lines = self.digit.GetDisplay().GetSelected()
+ else:
+ lines = (self.digit.GetDisplay().GetSelected()[0],) # only first found
+ for line in lines:
+ cats[line] = self.digit.GetLineCats(line)
+ if self.toolbar.GetAction() == "displayAttrs":
+ # select attributes based on coordinates (all layers)
+ if self.parent.dialogs['attributes'] is None:
+ self.parent.dialogs['attributes'] = \
+ dbm_dialogs.DisplayAttributesDialog(parent = self, map = mapLayer,
+ cats = cats,
+ action = "update")
+ else:
+ # upgrade dialog
+ self.parent.dialogs['attributes'].UpdateDialog(cats = cats)
+ if self.parent.dialogs['attributes']:
+ if len(cats.keys()) > 0:
+ # highlight feature & re-draw map
+ if not self.parent.dialogs['attributes'].IsShown():
+ self.parent.dialogs['attributes'].Show()
+ else:
+ if self.parent.dialogs['attributes'] and \
+ self.parent.dialogs['attributes'].IsShown():
+ self.parent.dialogs['attributes'].Hide()
+ else: # displayCats
+ if self.parent.dialogs['category'] is None:
+ # open new dialog
+ dlg = VDigitCategoryDialog(parent = self,
+ map = mapLayer,
+ cats = cats,
+ pos = posWindow,
+ title = _("Update categories"))
+ self.parent.dialogs['category'] = dlg
+ else:
+ # update currently open dialog
+ self.parent.dialogs['category'].UpdateDialog(cats = cats)
+ if self.parent.dialogs['category']:
+ if not self.parent.dialogs['category'].IsShown():
+ self.parent.dialogs['category'].Show()
+ else:
+ if self.parent.dialogs['category'].IsShown():
+ self.parent.dialogs['category'].Hide()
+ self.UpdateMap(render = False, renderVector = True)
+ def OnLeftDownCopyCA(self, event):
+ """!Left mouse button pressed - vector digitizer copy
+ categories or attributes action
+ if not hasattr(self, "copyCatsList"):
+ self.copyCatsList = []
+ else:
+ self.copyCatsIds = []
+ self.mouse['box'] = 'box'
+ def OnLeftDownCopyLine(self, event):
+ """!Left mouse button pressed - vector digitizer copy lines
+ action
+ if not hasattr(self, "copyIds"):
+ self.copyIds = []
+ self.layerTmp = None
+ def OnLeftDownBulkLine(self, event):
+ """!Left mouse button pressed - vector digitizer label 3D
+ vector lines
+ if len(self.polycoords) > 1: # start new line
+ self.polycoords = []
+ self.ClearLines(pdc = self.pdcTmp)
+ if len(self.polycoords) == 1:
+ begin = self.Pixel2Cell(self.polycoords[-1])
+ end = self.Pixel2Cell(self.mouse['end'])
+ else:
+ end = self.Pixel2Cell(self.polycoords[-1])
+ begin = self.Pixel2Cell(self.mouse['begin'])
+ self.DrawLines(self.pdcTmp, polycoords = (begin, end))
+ def OnLeftDownUndo(self, event):
+ """!Left mouse button pressed with control key - vector
+ digitizer undo functionality
+ if self.mouse["use"] != "pointer" or not self.toolbar:
+ return
+ digitClass = self.parent.digit
+ if (self.toolbar.GetAction() == "addLine" and \
+ self.toolbar.GetAction('type') in ["line", "boundary", "area"]) or \
+ self.toolbar.GetAction() == "editLine":
+ # add line or boundary -> remove last point from the line
+ try:
+ removed = self.polycoords.pop()
+ Debug.msg(4, "BufferedWindow.OnMiddleDown(): polycoords_poped=%s" % \
+ [removed,])
+ # self.mouse['begin'] = self.Cell2Pixel(self.polycoords[-1])
+ except:
+ pass
+ if self.toolbar.GetAction() == "editLine":
+ # remove last vertex & line
+ if len(self.moveInfo['id']) > 1:
+ self.moveInfo['id'].pop()
+ self.UpdateMap(render = False, renderVector = False)
+ elif self.toolbar.GetAction() in ["deleteLine", "moveLine", "splitLine",
+ "addVertex", "removeVertex", "moveVertex",
+ "copyCats", "flipLine", "mergeLine",
+ "snapLine", "connectLine", "copyLine",
+ "queryLine", "breakLine", "typeConv"]:
+ # varios tools -> unselected selected features
+ if self.toolbar.GetAction() in ["moveLine", "moveVertex", "editLine"] and \
+ hasattr(self, "moveInfo"):
+ del self.moveInfo
+ elif self.toolbar.GetAction() == "copyCats":
+ try:
+ del self.copyCatsList
+ del self.copyCatsIds
+ except AttributeError:
+ pass
+ elif self.toolbar.GetAction() == "copyLine":
+ del self.copyIds
+ if self.layerTmp:
+ self.Map.DeleteLayer(self.layerTmp)
+ self.UpdateMap(render = True, renderVector = False)
+ del self.layerTmp
+ self.UpdateMap(render = False) # render vector
+ elif self.toolbar.GetAction() == "zbulkLine":
+ # reset polyline
+ def _onLeftDown(self, event):
+ """!Left mouse button donw - vector digitizer various actions
+ try:
+ except:
+ wx.MessageBox(parent = self,
+ message = _("No vector map selected for editing."),
+ caption = _("Vector digitizer"),
+ style = wx.OK | wx.ICON_INFORMATION | wx.CENTRE)
+ event.Skip()
+ return
+ if self.toolbar.GetAction() not in ("moveVertex",
+ "addVertex",
+ "removeVertex",
+ "editLine"):
+ # set pen
+ self.pen = wx.Pen(colour = 'Red', width = 2, style = wx.SHORT_DASH)
+ self.polypen = wx.Pen(colour = 'dark green', width = 2, style = wx.SOLID)
+ if self.toolbar.GetAction() in ("addVertex",
+ "removeVertex",
+ "splitLines"):
+ # unselect
+ if self.toolbar.GetAction() == "addLine":
+ self.OnLeftDownAddLine(event)
+ elif self.toolbar.GetAction() == "editLine" and \
+ self.OnLeftDownEditLine(event)
+ elif self.toolbar.GetAction() in ("moveLine",
+ "moveVertex",
+ "editLine") and \
+ not hasattr(self, "moveInfo"):
+ self.OnLeftDownVDigitMoveLine(event)
+ elif self.toolbar.GetAction() in ("displayAttrs"
+ "displayCats"):
+ self.OnLeftDownDisplayCA(event)
+ elif self.toolbar.GetAction() in ("copyCats",
+ "copyAttrs"):
+ self.OnLeftDownCopyCA(event)
+ self.OnLeftDownCopyLine(event)
+ self.OnLeftDownBulkLine(event)
+ def _onLeftUp(self, event):
+ """!Left mouse button released - vector digitizer various
+ actions
+ pos1 = self.Pixel2Cell(self.mouse['begin'])
+ pos2 = self.Pixel2Cell(self.mouse['end'])
+ nselected = 0
+ # -> delete line || move line || move vertex
+ if self.toolbar.GetAction() in ("moveVertex",
+ "editLine"):
+ if len(self.digit.GetDisplay().GetSelected()) == 0:
+ nselected = self.digit.GetDisplay().SelectLineByPoint(pos1)['point']
+ try:
+ selVertex = self.digit.GetDisplay().GetSelectedVertex(pos1)[0]
+ except IndexError:
+ selVertex = None
+ if selVertex:
+ # self.UpdateMap(render=False)
+ ids = self.digit.GetDisplay().GetSelected(grassId = False)
+ # move this line to tmp layer
+ for id in ids:
+ if id % 2: # register only vertices
+ e, n = self.Pixel2Cell(self.pdcVector.GetIdBounds(id)[0:2])
+ self.polycoords.append((e, n))
+ self.digit.GetDisplay().DrawSelected(False)
+ if selVertex < ids[-1] / 2:
+ # choose first or last node of line
+ self.moveInfo['id'].reverse()
+ self.polycoords.reverse()
+ else:
+ # unselect
+ del self.moveInfo
+ "copyAttrs"):
+ if not hasattr(self, "copyCatsIds"):
+ # 'from' -> select by point
+ if nselected:
+ self.copyCatsList = self.digit.GetDisplay().GetSelected()
+ else:
+ # -> 'to' -> select by bbox
+ # return number of selected features (by box/point)
+ nselected = self.digit.GetDisplay().SelectLinesByBox((pos1, pos2))
+ if nselected == 0:
+ if self.digit.GetDisplay().SelectLineByPoint(pos1) is not None:
+ nselected = 1
+ if nselected > 0:
+ self.copyCatsIds = self.digit.GetDisplay().GetSelected()
+ elif self.toolbar.GetAction() == "queryLine":
+ selected = digitClass.SelectLinesByQuery(bbox = (pos1, pos2))
+ nselected = len(selected)
+ if nselected > 0:
+ self.digit.GetDisplay().SetSelected(selected)
+ else:
+ # -> moveLine || deleteLine, etc. (select by point/box)
+ if self.toolbar.GetAction() == 'moveLine' and \
+ len(self.digit.GetDisplay().GetSelected()) > 0:
+ nselected = 0
+ else:
+ drawSeg = True
+ else:
+ drawSeg = False
+ nselected = self.digit.GetDisplay().SelectLinesByBox(bbox = (pos1, pos2),
+ drawSeg = drawSeg)
+ nselected = 1
+ if nselected > 0:
+ if self.toolbar.GetAction() in ("moveLine",
+ "moveVertex"):
+ # get pseudoDC id of objects which should be redrawn
+ if self.toolbar.GetAction() == "moveLine":
+ # -> move line
+ self.moveInfo['id'] = self.digit.GetDisplay().GetSelected(grassId = False)
+ else: # moveVertex
+ self.moveInfo['id'] = self.digit.GetDisplay().GetSelectedVertex(pos1)
+ if len(self.moveInfo['id']) == 0: # no vertex found
+ # check for duplicates
+ if UserSettings.Get(group = 'vdigit', key = 'checkForDupl', subkey = 'enabled'):
+ dupl = self.digit.GetDisplay().GetDuplicates()
+ if dupl:
+ dlg = VDigitDuplicatesDialog(parent = self, data = dupl, pos = posWindow)
+ if dlg.ShowModal() == wx.ID_OK:
+ self.digit.GetDisplay().UnSelect(dlg.GetUnSelected())
+ # update selected
+ if self.toolbar.GetAction() != "editLine":
+ # -> move line || move vertex
+ else: # no vector object found
+ if not (self.toolbar.GetAction() in ("moveLine",
+ "moveVertex") and \
+ hasattr(self, "moveInfo") and \
+ len(self.moveInfo['id']) > 0):
+ # avoid left-click when features are already selected
+ def OnLeftUpModifyLine(self, event):
+ """!Left mouse button released - vector digitizer split line,
+ add/remove vertex action
+ pointOnLine = self.digit.GetDisplay().SelectLineByPoint(pos1)['point']
+ if not pointOnLine:
+ return
+ if self.toolbar.GetAction() in ["splitLine", "addVertex"]:
+ self.UpdateMap(render = False) # highlight object
+ self.DrawCross(pdc = self.pdcTmp, coords = self.Cell2Pixel((pointOnLine[0], pointOnLine[1])),
+ size = 5)
+ else: # removeVertex
+ # get only id of vertex
+ try:
+ id = self.digit.GetDisplay().GetSelectedVertex(pos1)[0]
+ id = None
+ if id:
+ x, y = self.pdcVector.GetIdBounds(id)[0:2]
+ self.pdcVector.RemoveId(id)
+ self.DrawCross(pdc = self.pdcTmp, coords = (x, y),
+ size = 5)
+ else:
+ # unselect
+ def OnLeftUpCopyLine(self, event):
+ """!Left mouse button released - vector digitizer copy feature
+ action
+ if UserSettings.Get(group = 'vdigit', key = 'bgmap',
+ subkey = 'value', internal = True) == '':
+ # no background map -> copy from current vector map layer
+ if nselected > 0:
+ # highlight selected features
+ else:
+ else:
+ # copy features from background map
+ self.copyIds += self.digit.SelectLinesFromBackgroundMap(bbox = (pos1, pos2))
+ if len(self.copyIds) > 0:
+ color = UserSettings.Get(group = 'vdigit', key = 'symbol',
+ subkey = ['highlight', 'color'])
+ colorStr = str(color[0]) + ":" + \
+ str(color[1]) + ":" + \
+ str(color[2])
+ dVectTmp = ['d.vect',
+ 'map=%s' % UserSettings.Get(group = 'vdigit', key = 'bgmap',
+ subkey = 'value', internal = True),
+ 'cats=%s' % utils.ListOfCatsToRange(self.copyIds),
+ '-i',
+ 'color=%s' % colorStr,
+ 'fcolor=%s' % colorStr,
+ 'type=point,line,boundary,centroid',
+ 'width=2']
+ if not self.layerTmp:
+ self.layerTmp = self.Map.AddLayer(type = 'vector',
+ name = globalvar.QUERYLAYER,
+ command = dVectTmp)
+ else:
+ self.layerTmp.SetCmd(dVectTmp)
+ else:
+ self.redrawAll = None
+ def OnLeftUpBulkLine(self, event):
+ """!Left mouse button released - vector digitizer z-bulk line
+ action
+ # select lines to be labeled
+ pos1 = self.polycoords[0]
+ pos2 = self.polycoords[1]
+ if nselected > 0:
+ self.DrawLines(pdc = self.pdcTmp) # redraw temp line
+ else:
+ def OnLeftUpConnectLine(self, event):
+ """!Left mouse button released - vector digitizer connect line
+ action
+ if len(self.digit.GetDisplay().GetSelected()) > 0:
+ def OnLeftUp(self, event):
+ if hasattr(self, "infoMove"):
+ if len(digitClass.GetDisplay().GetSelected()) == 0:
+ self.moveInfo['begin'] = self.Pixel2Cell(self.mouse['begin']) # left down
+ # eliminate initial mouse moving efect
+ self.mouse['begin'] = self.mouse['end']
+ if self.toolbar.GetAction() in ("deleteLine",
+ "moveLine",
+ "moveVertex",
+ "copyCats",
+ "copyAttrs",
+ "editLine",
+ "flipLine",
+ "mergeLine",
+ "snapLine",
+ "queryLine",
+ "breakLine",
+ "typeConv",
+ "connectLine"):
+ self._onLeftUp(event)
+ elif self.toolbar.GetAction() in ("splitLine",
+ "addVertex",
+ "removeVertex"):
+ self.OnLeftUpModifyLine(event)
+ self.OnLeftUpCopyLine(event)
+ elif self.toolbar.GetAction() == "zbulkLine" and \
+ len(self.polycoords) == 2:
+ self.OnLeftUpBulkLine(event)
+ elif self.toolbar.GetAction() == "connectLine":
+ self.OnLeftUpConnectLine(event)
+ def _onRightDown(self, event):
+ # digitization tool (confirm action)
+ if self.toolbar.GetAction() in ("moveLine", "moveVertex") and \
+ pFrom = self.moveInfo['begin']
+ pTo = self.Pixel2Cell(event.GetPositionTuple())
+ move = (pTo[0] - pFrom[0],
+ pTo[1] - pFrom[1])
+ # move line
+ if self.digit.MoveSelectedLines(move) < 0:
+ return
+ elif self.toolbar.GetAction() == "moveVertex":
+ # move vertex
+ fid = self.digit.MoveSelectedVertex(pFrom, move)
+ if fid < 0:
+ return
+ self._geomAttrbUpdate([fid,])
+ del self.moveInfo
+ def _onRightUp(self, event):
+ """!Right mouse button released
+ if self.toolbar.GetAction() == "addLine" and \
+ self.toolbar.GetAction('type') in ["line", "boundary", "area"]:
+ # -> add new line / boundary
+ try:
+ mapName = self.toolbar.GetLayer().GetName()
+ except:
+ mapName = None
+ gcmd.GError(parent = self,
+ message = _("No vector map selected for editing."))
+ if mapName:
+ if self.toolbar.GetAction('type') == 'line':
+ line = True
+ else:
+ line = False
+ if len(self.polycoords) < 2: # ignore 'one-point' lines
+ return
+ nfeat, fids = self.digit.AddFeature(self.toolbar.GetAction('type'), self.polycoords)
+ if nfeat < 0:
+ return
+ position = self.Cell2Pixel(self.polycoords[-1])
+ self.Refresh()
+ if UserSettings.Get(group = 'vdigit', key = "addRecord", subkey = 'enabled') and \
+ (line is True or \
+ (not line and nfeat > 0)):
+ posWindow = self.ClientToScreen((position[0] + self.dialogOffset,
+ position[1] + self.dialogOffset))
+ addRecordDlg = dbm_dialogs.DisplayAttributesDialog(parent = self, map = mapName,
+ cats = cats,
+ pos = posWindow,
+ action = "add")
+ for fid in fids:
+ self._geomAttrb(fid, addRecordDlg, 'length')
+ # auto-placing centroid
+ parent = True,
+ quiet = True,
+ self._updateATM()
+ elif self.toolbar.GetAction() == "deleteLine":
+ # -> delete selected vector features
+ if self.digit.DeleteSelectedLines() < 0:
+ return
+ self._updateATM()
+ elif self.toolbar.GetAction() == "splitLine":
+ # split line
+ if self.digit.SplitLine(self.Pixel2Cell(self.mouse['begin'])) < 0:
+ return
+ elif self.toolbar.GetAction() == "addVertex":
+ # add vertex
+ fid = self.digit.AddVertex(self.Pixel2Cell(self.mouse['begin']))
+ if fid < 0:
+ return
+ elif self.toolbar.GetAction() == "removeVertex":
+ # remove vertex
+ fid = self.digit.RemoveVertex(self.Pixel2Cell(self.mouse['begin']))
+ if fid < 0:
+ return
+ elif self.toolbar.GetAction() in ("copyCats", "copyAttrs"):
+ try:
+ if self.toolbar.GetAction() == 'copyCats':
+ if self.digit.CopyCats(self.copyCatsList,
+ self.copyCatsIds, copyAttrb = False) < 0:
+ return
+ else:
+ self.copyCatsIds, copyAttrb = True) < 0:
+ return
+ pass
+ self._updateATM()
+ line = self.digit.GetDisplay().GetSelected()
+ if self.digit.EditLine(line, self.polycoords) < 0:
+ return
+ del self.moveInfo
+ elif self.toolbar.GetAction() == "flipLine":
+ if self.digit.FlipLine() < 0:
+ return
+ elif self.toolbar.GetAction() == "mergeLine":
+ if self.digit.MergeLine() < 0:
+ return
+ elif self.toolbar.GetAction() == "breakLine":
+ if self.digit.BreakLine() < 0:
+ return
+ elif self.toolbar.GetAction() == "snapLine":
+ if self.digit.SnapLine() < 0:
+ return
+ if len(self.digit.GetDisplay().GetSelected()) > 1:
+ if self.digit.ConnectLine() < 0:
+ return
+ if self.digit.CopyLine(self.copyIds) < 0:
+ return
+ del self.copyIds
+ if self.layerTmp:
+ del self.layerTmp
+ elif self.toolbar.GetAction() == "zbulkLine" and len(self.polycoords) == 2:
+ selected = self.digit.GetDisplay().GetSelected()
+ dlg = VDigitZBulkDialog(parent = self, title = _("Z bulk-labeling dialog"),
+ nselected = len(selected))
+ if self.digit.ZBulkLines(pos1, pos2, dlg.value.GetValue(),
+ dlg.step.GetValue()) < 0:
+ return
+ elif self.toolbar.GetAction() == "typeConv":
+ # -> feature type conversion
+ # - point <-> centroid
+ # - line <-> boundary
+ if self.digit.TypeConvForSelectedLines() < 0:
+ return
+ if self.toolbar.GetAction() != "addLine":
+ # unselect and re-render
+ def _onMouseMoving(self, event):
+ self.mouse['end'] = event.GetPositionTuple()[:]
+ Debug.msg (5, "BufferedWindow.OnMouseMoving(): coords=%f,%f" % \
+ (self.mouse['end'][0], self.mouse['end'][1]))
+ if len(self.polycoords) > 0:
+ self.MouseDraw(pdc = self.pdcTmp, begin = self.Cell2Pixel(self.polycoords[-1]))
+ elif self.toolbar.GetAction() in ["moveLine", "moveVertex", "editLine"] \
+ and hasattr(self, "moveInfo"):
+ dx = self.mouse['end'][0] - self.mouse['begin'][0]
+ dy = self.mouse['end'][1] - self.mouse['begin'][1]
+ if len(self.moveInfo['id']) > 0:
+ # draw lines on new position
+ # move line
+ self.pdcTmp.TranslateId(id, dx, dy)
+ elif self.toolbar.GetAction() in ["moveVertex", "editLine"]:
+ # move vertex ->
+ # (vertex, left vertex, left line,
+ # right vertex, right line)
+ # do not draw static lines
+ if self.toolbar.GetAction() == "moveVertex":
+ ### self.pdcTmp.TranslateId(self.moveInfo['id'][0], dx, dy)
+ self.pdcTmp.RemoveId(self.moveInfo['id'][0])
+ if self.moveInfo['id'][1] > 0: # previous vertex
+ x, y = self.Pixel2Cell(self.pdcTmp.GetIdBounds(self.moveInfo['id'][1])[0:2])
+ self.pdcTmp.RemoveId(self.moveInfo['id'][1] + 1)
+ self.polycoords.append((x, y))
+ ### x, y = self.Pixel2Cell(self.pdcTmp.GetIdBounds(self.moveInfo['id'][0])[0:2])
+ self.polycoords.append(self.Pixel2Cell(self.mouse['end']))
+ if self.moveInfo['id'][2] > 0: # next vertex
+ x, y = self.Pixel2Cell(self.pdcTmp.GetIdBounds(self.moveInfo['id'][2])[0:2])
+ self.pdcTmp.RemoveId(self.moveInfo['id'][2]-1)
+ else: # edit line
+ try:
+ if self.moveInfo['id'][-1] > 0: # previous vertex
+ begin = self.Cell2Pixel(self.polycoords[-1]))
+ except: # no line
+ self.Refresh() # TODO: use RefreshRect()
+ # draw mouse moving
+ self.MouseDraw(self.pdcTmp)
+ def _zoom(self, event):
+ tmp1 = self.mouse['end']
+ tmp2 = self.Cell2Pixel(self.moveInfo['begin'])
+ dx = tmp1[0] - tmp2[0]
+ dy = tmp1[1] - tmp2[1]
+ self.moveInfo['beginDiff'] = (dx, dy)
+ self.pdcTmp.RemoveId(id)
Property changes on: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_vdigit.py
___________________________________________________________________
Added: svn:mime-type
+ text/x-python
Added: svn:eol-style
+ native
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py 2011-02-11 22:07:34 UTC (rev 45383)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py 2011-02-12 09:54:41 UTC (rev 45384)
@@ -29,7 +29,6 @@
import grass.script as grass
import dbm
-import dbm_dialogs
import gdialogs
import gcmd
import utils
@@ -38,16 +37,12 @@
from units import ConvertValue as UnitsConvertValue
-from vdigit import GV_LINES as VDigit_Lines_Type
-from vdigit import VDigitCategoryDialog
-from vdigit import VDigitZBulkDialog
-from vdigit import VDigitDuplicatesDialog
class MapWindow(object):
- """!Abstract map window class
- Parent for BufferedWindow class (2D display mode) and
- GLWindow (3D display mode)
+ """!Abstract map display window class
+ Superclass for BufferedWindow class (2D display mode), and GLWindow
+ (3D display mode).
Map = None, tree = None, lmgr = None, **kwargs):
@@ -64,30 +59,9 @@
'use' : "pointer",
'box' : "point"
- def EraseMap(self):
- """!Erase the canvas (virtual method)
- pass
- def UpdateMap(self):
- """!Updates the canvas anytime there is a change to the
- underlaying images or to the geometry of the canvas.
- pass
- def OnLeftDown(self, event):
- pass
- def OnLeftUp(self, event):
- pass
- def OnKeyDown(self, event):
- pass
def OnMotion(self, event):
- """!Mouse moved
- Track mouse motion and update status bar
if self.parent.statusbarWin['toggle'].GetSelection() == 0: # Coordinates
precision = int(UserSettings.Get(group = 'projection', key = 'format',
@@ -100,23 +74,11 @@
self.parent.statusbar.SetStatusText("", 0)
return
- if self.parent.toolbars['vdigit'] and \
- self.parent.toolbars['vdigit'].GetAction() == 'addLine' and \
- self.parent.toolbars['vdigit'].GetAction('type') in ('line', 'boundary') and \
- len(self.polycoords) > 0:
- # for linear feature show segment and total length
- distance_seg = self.Distance(self.polycoords[-1],
- (e, n), screen = False)[0]
- distance_tot = distance_seg
- for idx in range(1, len(self.polycoords)):
- distance_tot += self.Distance(self.polycoords[idx-1],
- self.polycoords[idx],
- screen = False)[0]
- self.parent.statusbar.SetStatusText("%.*f, %.*f (seg: %.*f; tot: %.*f)" % \
- (precision, e, precision, n,
- precision, distance_seg,
- precision, distance_tot), 0)
- else:
+ updated = False
+ if hasattr(self, "digit"):
+ updated = self._onMotion((e, n), precision)
+ if not updated:
if self.parent.statusbarWin['projection'].IsChecked():
if not UserSettings.Get(group = 'projection', key = 'statusbar', subkey = 'proj4'):
self.parent.statusbar.SetStatusText(_("Projection not defined (check the settings)"), 0)
@@ -144,14 +106,9 @@
else:
self.parent.statusbar.SetStatusText("%.*f; %.*f" % \
(precision, e, precision, n), 0)
event.Skip()
- def OnZoomToMap(self, event):
- pass
- def OnZoomToRaster(self, event):
- pass
def GetLayerByName(self, name, mapType, dataType = 'layer'):
"""!Get layer from layer tree by nam
@@ -181,7 +138,7 @@
def GetSelectedLayer(self, type = 'layer', multi = False):
"""!Get selected layer from layer tree
@param type 'item' / 'layer' / 'nviz'
@param multi return first selected layer or all
@@ -226,12 +183,14 @@
return ret
class BufferedWindow(MapWindow, wx.Window):
- """!A Buffered window class.
+ """!A Buffered window class (2D view mode)
+ Superclass for VDigitWindow (vector digitizer).
When the drawing needs to change, you app needs to call the
UpdateMap() method. Since the drawing is stored in a bitmap, you
can also save the drawing to file by calling the
- SaveToFile(self,file_name,file_type) method.
+ SaveToFile() method.
@@ -242,7 +201,7 @@
# flags
self.resize = False # indicates whether or not a resize event has taken place
self.dragimg = None # initialize variable for map panning
# variables for drawing on DC
self.pen = None # pen for drawing zoom boxes, etc.
self.polypen = None # pen for drawing polylines (measurements, profiles, etc)
@@ -257,7 +216,6 @@
self.Bind(wx.EVT_PAINT, self.OnPaint)
self.Bind(wx.EVT_SIZE, self.OnSize)
self.Bind(wx.EVT_IDLE, self.OnIdle)
- ### self.Bind(wx.EVT_MOTION, self.MouseActions)
self.Bind(wx.EVT_MOUSE_EVENTS, self.MouseActions)
self.Bind(wx.EVT_MOTION, self.OnMotion)
@@ -273,34 +231,33 @@
self.select = {} # selecting/unselecting decorations for dragging
self.textdict = {} # text, font, and color indexed by id
self.currtxtid = None # PseudoDC id for currently selected text
# zoom objects
self.zoomhistory = [] # list of past zoom extents
self.currzoom = 0 # current set of extents in zoom history being used
self.zoomtype = 1 # 1 zoom in, 0 no zoom, -1 zoom out
self.hitradius = 10 # distance for selecting map decorations
self.dialogOffset = 5 # offset for dialog (e.g. DisplayAttributesDialog)
# OnSize called to make sure the buffer is initialized.
# This might result in OnSize getting called twice on some
# platforms at initialization, but little harm done.
### self.OnSize(None)
- self.DefinePseudoDC()
+ self._definePseudoDC()
# redraw all pdc's, pdcTmp layer is redrawn always (speed issue)
# will store an off screen empty bitmap for saving to file
- self._buffer = ''
+ self._buffer = None
self.Bind(wx.EVT_ERASE_BACKGROUND, lambda x:None)
- self.Bind(wx.EVT_KEY_DOWN , self.OnKeyDown)
# vars for handling mouse clicks
self.dragid = -1
self.lastpos = (0, 0)
- def DefinePseudoDC(self):
+ def _definePseudoDC(self):
"""!Define PseudoDC objects to use
# create PseudoDC used for background map, map decorations like scales and legends
@@ -311,7 +268,7 @@
self.pdcDec = wx.PseudoDC()
# pseudoDC for temporal objects (select box, measurement tool, etc.)
self.pdcTmp = wx.PseudoDC()
def Draw(self, pdc, img = None, drawid = None, pdctype = 'image', coords = [0, 0, 0, 0]):
"""!Draws map and overlay decorations
@@ -326,25 +283,23 @@
if img and pdctype == 'image':
# self.imagedict[img]['coords'] = coords
self.select[self.imagedict[img]['id']] = False # ?
pdc.BeginDrawing()
if drawid != 99:
bg = wx.TRANSPARENT_BRUSH
else:
bg = wx.Brush(self.GetBackgroundColour())
pdc.SetBackground(bg)
- ### pdc.Clear()
Debug.msg (5, "BufferedWindow.Draw(): id=%s, pdctype = %s, coord=%s" % \
(drawid, pdctype, coords))
# set PseudoDC id
if drawid is not None:
pdc.SetId(drawid)
if pdctype == 'clear': # erase the display
bg = wx.WHITE_BRUSH
# bg = wx.Brush(self.GetBackgroundColour())
@@ -355,13 +310,13 @@
self.Refresh()
return
if pdctype == 'image': # draw selected image
bitmap = wx.BitmapFromImage(img)
w,h = bitmap.GetSize()
pdc.DrawBitmap(bitmap, coords[0], coords[1], True) # draw the composite map
pdc.SetIdBounds(drawid, wx.Rect(coords[0],coords[1], w, h))
elif pdctype == 'box': # draw a box on top of the map
if self.pen:
pdc.SetBrush(wx.Brush(wx.CYAN, wx.TRANSPARENT))
@@ -382,13 +337,11 @@
pdc.SetPen(self.pen)
pdc.DrawLinePoint(wx.Point(coords[0], coords[1]),wx.Point(coords[2], coords[3]))
pdc.SetIdBounds(drawid, wx.Rect(coords[0], coords[1], coords[2], coords[3]))
- # self.ovlcoords[drawid] = coords
elif pdctype == 'polyline': # draw a polyline on top of the map
if self.polypen:
pdc.SetPen(self.polypen)
- ### pdc.DrawLines(coords)
if (len(coords) < 2):
return
i = 1
@@ -396,7 +349,7 @@
pdc.DrawLinePoint(wx.Point(coords[i-1][0], coords[i-1][1]),
wx.Point(coords[i][0], coords[i][1]))
i += 1
# get bounding rectangle for polyline
xlist = []
ylist = []
@@ -411,7 +364,7 @@
y2 = max(ylist)
pdc.SetIdBounds(drawid, wx.Rect(x1,y1,x2,y2))
# self.ovlcoords[drawid] = [x1,y1,x2,y2]
elif pdctype == 'point': # draw point
if self.pen:
@@ -421,11 +374,10 @@
coords[0] + 5,
coords[1] + 5)
pdc.SetIdBounds(drawid, wx.Rect(coordsBound))
elif pdctype == 'text': # draw text on top of map
if not img['active']:
- return #only draw active text
+ return # only draw active text
if img.has_key('rotation'):
rotation = float(img['rotation'])
else:
@@ -439,16 +391,16 @@
else:
pdc.DrawRotatedText(img['text'], coords[0], coords[1], rotation)
pdc.SetIdBounds(drawid, wx.Rect(coords[0], coords[1], w, h))
pdc.EndDrawing()
self.Refresh()
return drawid
def TextBounds(self, textinfo):
"""!Return text boundary data
@param textinfo text metadata (text, font, color, rotation)
@param coords reference point
@@ -461,18 +413,17 @@
Debug.msg (4, "BufferedWindow.TextBounds(): text=%s, rotation=%f" % \
(textinfo['text'], rotation))
self.Update()
- ### self.Refresh()
self.SetFont(textinfo['font'])
w, h = self.GetTextExtent(textinfo['text'])
if rotation == 0:
coords[2], coords[3] = coords[0] + w, coords[1] + h
return coords, w, h
boxh = math.fabs(math.sin(math.radians(rotation)) * w) + h
boxw = math.fabs(math.cos(math.radians(rotation)) * w) + h
coords[2] = coords[0] + boxw
@@ -480,40 +431,14 @@
return coords, boxw, boxh
- """!Key pressed"""
- shift = event.ShiftDown()
- kc = event.GetKeyCode()
- vdigitToolbar = self.parent.toolbars['vdigit']
- ### vdigit
- if vdigitToolbar:
- event = None
- if not shift:
- if kc == ord('P'):
- event = wx.CommandEvent(winid = vdigitToolbar.addPoint)
- tool = vdigitToolbar.OnAddPoint
- elif kc == ord('L'):
- event = wx.CommandEvent(winid = vdigitToolbar.addLine)
- tool = vdigitToolbar.OnAddLine
- if event:
- vdigitToolbar.OnTool(event)
- tool(event)
def OnPaint(self, event):
"""!Draw PseudoDC's to buffered paint DC
- self.pdc for background and decorations
- self.pdcVector for vector map which is edited
- self.pdcTmp for temporaly drawn objects (self.polycoords)
If self.redrawAll is False on self.pdcTmp content is re-drawn
Debug.msg(4, "BufferedWindow.OnPaint(): redrawAll=%s" % self.redrawAll)
dc = wx.BufferedPaintDC(self, self.buffer)
- ### dc.SetBackground(wx.Brush("White"))
dc.Clear()
# use PrepareDC to set position correctly
@@ -534,7 +459,7 @@
self.pdc.DrawToDCClipped(dc, rgn)
# draw vector map layer
- if self.pdcVector:
# decorate with GDDC (transparency)
try:
gcdc = wx.GCDC(dc)
@@ -549,7 +474,7 @@
# draw to the dc
self.pdc.DrawToDC(dc)
+ if isinstace(self, VDigitWindow):
try:
gcdc = wx.GCDC(dc)
@@ -557,7 +482,7 @@
except NotImplementedError, e:
print >> sys.stderr, e
self.pdcVector.DrawToDC(dc)
# store buffered image
# self.bufferLast = wx.BitmapFromImage(self.buffer.ConvertToImage())
self.bufferLast = dc.GetAsBitmap(wx.Rect(0, 0, self.Map.width, self.Map.height))
@@ -604,23 +529,23 @@
self.img = self.img.Scale(self.Map.width, self.Map.height)
if len(self.Map.GetListOfLayers()) > 0:
self.UpdateMap()
# re-render image on idle
self.resize = True
# reposition checkbox in statusbar
self.parent.StatusbarReposition()
# update statusbar
self.parent.StatusbarUpdate()
def OnIdle(self, event):
"""!Only re-render a composite map image from GRASS during
idle time instead of multiple times during resizing.
if self.resize:
self.UpdateMap(render = True)
event.Skip()
def SaveToFile(self, FileName, FileType, width, height):
@@ -655,11 +580,10 @@
self.Refresh()
def GetOverlay(self):
- Converts rendered overlay files to wx.Image
+ """!Converts rendered overlay files to wx.Image
Updates self.imagedict
@return list of images
imgs = []
@@ -671,12 +595,12 @@
imgs.append(img)
return imgs
def GetImage(self):
"""!Converts redered map files to wx.Image
Updates self.imagedict (id=99)
@return wx.Image instance (map composition)
imgId = 99
@@ -691,8 +615,7 @@
return img
def UpdateMap(self, render = True, renderVector = True):
- Updates the canvas anytime there is a change to the
+ """!Updates the canvas anytime there is a change to the
@param render re-render map composition
@@ -702,9 +625,6 @@
self.resize = False
- # if len(self.Map.GetListOfLayers()) == 0:
- # return False
if self.img is None:
render = True
@@ -771,38 +691,8 @@
# render vector map layer
- digitToolbar = self.parent.toolbars['vdigit']
- if renderVector and digitToolbar and \
- digitToolbar.GetLayer():
- # set region
- self.parent.digit.GetDisplay().UpdateRegion()
- # re-calculate threshold for digitization tool
- # self.parent.digit.GetDisplay().GetThreshold()
- # draw map
- # self.pdcVector.Clear()
- self.pdcVector.RemoveAll()
- try:
- item = self.tree.FindItemByData('maplayer', digitToolbar.GetLayer())
- except TypeError:
- item = None
- if item and self.tree.IsItemChecked(item):
- self.redrawAll = True
- self.parent.digit.GetDisplay().DrawMap()
- # translate tmp objects (pointer position)
- if digitToolbar.GetAction() == 'moveLine':
- if hasattr(self, "vdigitMove") and \
- self.vdigitMove.has_key('beginDiff'):
- # move line
- for id in self.vdigitMove['id']:
- self.pdcTmp.TranslateId(id,
- self.vdigitMove['beginDiff'][0],
- self.vdigitMove['beginDiff'][1])
- del self.vdigitMove['beginDiff']
+ if renderVector and hasattr(self, "digit"):
+ self._updateMap()
# render overlays
@@ -922,25 +812,23 @@
region['w'] >= refRegion['w'] and \
region['e'] <= refRegion['e']:
return True
return False
def EraseMap(self):
- Erase the canvas
+ """!Erase map canvas
self.Draw(self.pdc, pdctype = 'clear')
self.Draw(self.pdcVector, pdctype = 'clear')
self.Draw(self.pdcDec, pdctype = 'clear')
self.Draw(self.pdcTmp, pdctype = 'clear')
def DragMap(self, moveto):
- Drag the entire map image for panning.
+ """!Drag the entire map image for panning.
@param moveto dx,dy
dc = wx.BufferedDC(wx.ClientDC(self))
@@ -956,8 +844,7 @@
self.dragimg.EndDrag()
def DragItem(self, id, event):
- Drag an overlay decoration item
+ """!Drag an overlay decoration item
if id == 99 or id == '' or id == None: return
Debug.msg (5, "BufferedWindow.DragItem(): id=%d" % id)
@@ -966,7 +853,6 @@
dy = event.GetY() - y
self.pdc.SetBackground(wx.Brush(self.GetBackgroundColour()))
r = self.pdc.GetIdBounds(id)
- ### FIXME in vdigit/pseudodc.i
if type(r) is list:
r = wx.Rect(r[0], r[1], r[2], r[3])
if id > 100: # text dragging
@@ -975,7 +861,7 @@
rleft = (r[0]-r[2],r[1],r[2],r[3])
r = r.Union(rleft)
self.pdc.TranslateId(id, dx, dy)
r2 = self.pdc.GetIdBounds(id)
if type(r2) is list:
r2 = wx.Rect(r[0], r[1], r[2], r[3])
@@ -987,26 +873,22 @@
self.lastpos = (event.GetX(), event.GetY())
def MouseDraw(self, pdc = None, begin = None, end = None):
- Mouse box or line from 'begin' to 'end'
+ """!Mouse box or line from 'begin' to 'end'
If not given from self.mouse['begin'] to self.mouse['end'].
-# self.redrawAll = False
if not pdc:
return
if begin is None:
begin = self.mouse['begin']
if end is None:
end = self.mouse['end']
Debug.msg (5, "BufferedWindow.MouseDraw(): use=%s, box=%s, begin=%f,%f, end=%f,%f" % \
(self.mouse['use'], self.mouse['box'],
begin[0], begin[1], end[0], end[1]))
if self.mouse['box'] == "box":
boxid = wx.ID_NEW
mousecoords = [begin[0], begin[1],
@@ -1022,6 +904,7 @@
self.RefreshRect(r, False)
pdc.SetId(boxid)
self.Draw(pdc, drawid = boxid, pdctype = 'box', coords = mousecoords)
elif self.mouse['box'] == "line" or self.mouse['box'] == 'point':
self.lineid = wx.ID_NEW
mousecoords = [begin[0], begin[1], \
@@ -1041,18 +924,16 @@
self.Draw(pdc, drawid = self.lineid, pdctype = 'line', coords = mousecoords)
def DrawLines(self, pdc = None, polycoords = None):
- Draw polyline in PseudoDC
+ """!Draw polyline in PseudoDC
Set self.pline to wx.NEW_ID + 1
polycoords - list of polyline vertices, geographical coordinates
(if not given, self.polycoords is used)
if not pdc:
pdc = self.pdcTmp
if not polycoords:
polycoords = self.polycoords
@@ -1067,9 +948,9 @@
Debug.msg (4, "BufferedWindow.DrawLines(): coords=%s, id=%s" % \
(coords, self.plineid))
return self.plineid
return -1
def DrawCross(self, pdc, coords, size, rotation = 0,
@@ -1093,10 +974,10 @@
self.lineid = wx.NewId()
for lineCoords in coordsCross:
self.Draw(pdc, drawid = self.lineid, pdctype = 'line', coords = lineCoords)
if not text:
return self.lineid
if textAlign == 'ul':
coord = [coords[0] - textOffset[0], coords[1] - textOffset[1], 0, 0]
elif textAlign == 'ur':
@@ -1108,19 +989,15 @@
self.Draw(pdc, img = text,
pdctype = 'text', coords = coord)
return self.lineid
def MouseActions(self, event):
- Mouse motion and button click notifier
+ """!Mouse motion and button click notifier
if not self.processMouse:
return
- ### if self.redrawAll is False:
- ### self.redrawAll = True
# zoom with mouse wheel
if event.GetWheelRotation() != 0:
self.OnMouseWheel(event)
@@ -1128,23 +1005,23 @@
# left mouse button pressed
elif event.LeftDown():
self.OnLeftDown(event)
# left mouse button released
elif event.LeftUp():
self.OnLeftUp(event)
# dragging
elif event.Dragging():
self.OnDragging(event)
# double click
elif event.ButtonDClick():
self.OnButtonDClick(event)
# middle mouse button pressed
elif event.MiddleDown():
self.OnMiddleDown(event)
# middle mouse button relesed
elif event.MiddleUp():
self.OnMiddleUp(event)
@@ -1152,22 +1029,19 @@
# right mouse button pressed
elif event.RightDown():
self.OnRightDown(event)
# right mouse button released
elif event.RightUp():
self.OnRightUp(event)
elif event.Entering():
self.OnMouseEnter(event)
elif event.Moving():
self.OnMouseMoving(event)
- # event.Skip()
def OnMouseWheel(self, event):
- Mouse wheel moved
+ """!Mouse wheel moved
self.processMouse = False
current = event.GetPositionTuple()[:]
@@ -1183,22 +1057,19 @@
zoomtype = 1
else:
zoomtype = -1
# zoom
self.Zoom(begin, end, zoomtype)
# redraw map
self.UpdateMap()
- ### self.OnPaint(None)
# update statusbar
self.Refresh()
self.processMouse = True
-# event.Skip()
def OnDragging(self, event):
"""!Mouse dragging
@@ -1208,7 +1079,10 @@
move = (current[0] - previous[0],
current[1] - previous[1])
+ digitToolbar = self.toolbar
+ else:
+ digitToolbar = None
# dragging or drawing box with left button
if self.mouse['use'] == 'pan' or \
@@ -1224,326 +1098,16 @@
# dragging anything else - rubber band box or line
else:
if (self.mouse['use'] == 'pointer' and
- not digitToolbar): return
+ not digitToolbar):
+ return
- digitClass = self.parent.digit
if (event.LeftIsDown() and
not (digitToolbar and
digitToolbar.GetAction() in ("moveLine",) and
- digitClass.GetDisplay().GetSelected() > 0)):
+ self.display.GetSelected() > 0)):
# draw box only when left mouse button is pressed
self.MouseDraw(pdc = self.pdcTmp)
- # event.Skip()
- def OnLeftDownVDigitAddLine(self, event):
- """!Left mouse button down - vector digitizer add new line
- action
- try:
- mapLayer = digitToolbar.GetLayer().GetName()
- except:
- return
- if digitToolbar.GetAction('type') in ['point', 'centroid']:
- # add new point / centroiud
- east, north = self.Pixel2Cell(self.mouse['begin'])
- nfeat, fids = digitClass.AddFeature(digitToolbar.GetAction('type'), [(east, north)])
- if nfeat < 1:
- return
- self.UpdateMap(render = False) # redraw map
- # add new record into atribute table
- if UserSettings.Get(group = 'vdigit', key = "addRecord", subkey = 'enabled'):
- # select attributes based on layer and category
- cats = { fids[0] : {
- UserSettings.Get(group = 'vdigit', key = "layer", subkey = 'value') :
- (UserSettings.Get(group = 'vdigit', key = "category", subkey = 'value'), )
- posWindow = self.ClientToScreen((self.mouse['end'][0] + self.dialogOffset,
- self.mouse['end'][1] + self.dialogOffset))
- addRecordDlg = dbm_dialogs.DisplayAttributesDialog(parent = self, map = mapLayer,
- cats = cats,
- pos = posWindow,
- action = "add")
- if digitToolbar.GetAction('type') == 'centroid':
- for fid in fids:
- self._geomAttrb(fid, addRecordDlg, 'area', digitClass,
- digitToolbar.GetLayer())
- self._geomAttrb(fid, addRecordDlg, 'perimeter', digitClass,
- if addRecordDlg.mapDBInfo and \
- addRecordDlg.ShowModal() == wx.ID_OK:
- sqlfile = tempfile.NamedTemporaryFile(mode = "w")
- for sql in addRecordDlg.GetSQLString():
- sqlfile.file.write(sql + ";\n")
- sqlfile.file.flush()
- gcmd.RunCommand('db.execute',
- parent = self,
- quiet = True,
- input = sqlfile.name)
- if addRecordDlg.mapDBInfo:
- self.__updateATM()
- elif digitToolbar.GetAction('type') in ["line", "boundary", "area"]:
- # add new point to the line
- self.polycoords.append(self.Pixel2Cell(event.GetPositionTuple()[:]))
- self.DrawLines(pdc = self.pdcTmp)
- def _geomAttrb(self, fid, dialog, attrb, digit, mapLayer):
- """!Trac geometry attributes?"""
- item = self.tree.FindItemByData('maplayer', mapLayer)
- vdigit = self.tree.GetPyData(item)[0]['vdigit']
- if vdigit and \
- vdigit.has_key('geomAttr') and \
- vdigit['geomAttr'].has_key(attrb):
- val = -1
- if attrb == 'length':
- val = digit.GetLineLength(fid)
- type = attrb
- elif attrb == 'area':
- val = digit.GetAreaSize(fid)
- type = attrb
- elif attrb == 'perimeter':
- val = digit.GetAreaPerimeter(fid)
- type = 'length'
- if val > 0:
- layer = int(UserSettings.Get(group = 'vdigit', key = "layer", subkey = 'value'))
- column = vdigit['geomAttr'][attrb]['column']
- val = UnitsConvertValue(val, type, vdigit['geomAttr'][attrb]['units'])
- dialog.SetColumnValue(layer, column, val)
- dialog.OnReset()
- def _geomAttrbUpdate(self, fids):
- """!Update geometry atrributes of currently selected features
- @param fid list feature id
- mapLayer = self.parent.toolbars['vdigit'].GetLayer()
- vectorName = mapLayer.GetName()
- digit = self.parent.digit
- if vdigit is None or not vdigit.has_key('geomAttr'):
- return
- dbInfo = gselect.VectorDBInfo(vectorName)
- for fid in fids:
- for layer, cats in digit.GetLineCats(fid).iteritems():
- table = dbInfo.GetTable(layer)
- for attrb, item in vdigit['geomAttr'].iteritems():
- val = -1
- type = attrb
- type = attrb
- type = 'length'
- if val < 0:
- continue
- val = UnitsConvertValue(val, type, item['units'])
- for cat in cats:
- sqlfile.write('UPDATE %s SET %s = %f WHERE %s = %d;\n' % \
- (table, item['column'], val,
- dbInfo.GetKeyColumn(layer), cat))
- parent = True,
- quiet = True,
- def __updateATM(self):
- """!Update open Attribute Table Manager
- @todo: use AddDataRow() instead
- # update ATM
- digitVector = digitToolbar.GetLayer().GetName()
- for atm in self.lmgr.dialogs['atm']:
- atmVector = atm.GetVectorName()
- if atmVector == digitVector:
- layer = UserSettings.Get(group = 'vdigit', key = "layer", subkey = 'value')
- # TODO: use AddDataRow instead
- atm.LoadData(layer)
- def OnLeftDownVDigitEditLine(self, event):
- Left mouse button down - vector digitizer edit linear feature
- - add new vertex.
- self.polycoords.append(self.Pixel2Cell(self.mouse['begin']))
- self.vdigitMove['id'].append(wx.NewId())
- def OnLeftDownVDigitMoveLine(self, event):
- Left mouse button down - vector digitizer move feature/vertex,
- self.vdigitMove = {}
- # geographic coordinates of initial position (left-down)
- self.vdigitMove['begin'] = None
- # list of ids to modify
- self.vdigitMove['id'] = []
- if digitToolbar.GetAction() in ["moveVertex", "editLine"]:
- # set pen
- pcolor = UserSettings.Get(group = 'vdigit', key = "symbol",
- subkey = ["highlight", "color"])
- self.pen = self.polypen = wx.Pen(colour = pcolor,
- width = 2, style = wx.SHORT_DASH)
- self.pdcTmp.SetPen(self.polypen)
- def OnLeftDownVDigitDisplayCA(self, event):
- """!Left mouse button down - vector digitizer display categories
- or attributes action
- try:
- except:
- return
- coords = self.Pixel2Cell(self.mouse['begin'])
- # unselect
- digitClass.GetDisplay().SetSelected([])
- # select feature by point
- cats = {}
- if digitClass.GetDisplay().SelectLineByPoint(coords) is None:
- return
- if UserSettings.Get(group = 'vdigit', key = 'checkForDupl',
- subkey = 'enabled'):
- lines = digitClass.GetDisplay().GetSelected()
- else:
- lines = (digitClass.GetDisplay().GetSelected()[0],) # only first found
- for line in lines:
- cats[line] = digitClass.GetLineCats(line)
- if digitToolbar.GetAction() == "displayAttrs":
- # select attributes based on coordinates (all layers)
- if self.parent.dialogs['attributes'] is None:
- self.parent.dialogs['attributes'] = \
- dbm_dialogs.DisplayAttributesDialog(parent = self, map = mapLayer,
- cats = cats,
- action = "update")
- else:
- # upgrade dialog
- self.parent.dialogs['attributes'].UpdateDialog(cats = cats)
- if self.parent.dialogs['attributes']:
- if len(cats.keys()) > 0:
- # highlight feature & re-draw map
- if not self.parent.dialogs['attributes'].IsShown():
- self.parent.dialogs['attributes'].Show()
- else:
- if self.parent.dialogs['attributes'] and \
- self.parent.dialogs['attributes'].IsShown():
- self.parent.dialogs['attributes'].Hide()
- else: # displayCats
- if self.parent.dialogs['category'] is None:
- # open new dialog
- dlg = VDigitCategoryDialog(parent = self,
- map = mapLayer,
- cats = cats,
- pos = posWindow,
- title = _("Update categories"))
- self.parent.dialogs['category'] = dlg
- else:
- # update currently open dialog
- self.parent.dialogs['category'].UpdateDialog(cats = cats)
- if self.parent.dialogs['category']:
- if not self.parent.dialogs['category'].IsShown():
- self.parent.dialogs['category'].Show()
- else:
- if self.parent.dialogs['category'].IsShown():
- self.parent.dialogs['category'].Hide()
- self.UpdateMap(render = False, renderVector = True)
- def OnLeftDownVDigitCopyCA(self, event):
- Left mouse button down - vector digitizer copy categories
- if not hasattr(self, "copyCatsList"):
- self.copyCatsList = []
- else:
- self.copyCatsIds = []
- self.mouse['box'] = 'box'
- def OnLeftDownVDigitCopyLine(self, event):
- Left mouse button down - vector digitizer copy lines action
- if not hasattr(self, "copyIds"):
- self.copyIds = []
- self.layerTmp = None
- def OnLeftDownVDigitBulkLine(self, event):
- """!Left mouse button down - vector digitizer label 3d vector
- lines
- if len(self.polycoords) > 1: # start new line
- self.polycoords = []
- self.ClearLines(pdc = self.pdcTmp)
- if len(self.polycoords) == 1:
- begin = self.Pixel2Cell(self.polycoords[-1])
- end = self.Pixel2Cell(self.mouse['end'])
- else:
- end = self.Pixel2Cell(self.polycoords[-1])
- begin = self.Pixel2Cell(self.mouse['begin'])
- self.DrawLines(self.pdcTmp, polycoords = (begin, end))
@@ -1566,11 +1130,11 @@
# vector digizer
elif self.mouse["use"] == "pointer" and \
- self.parent.toolbars['vdigit']:
+ hasattr(self, "digit"):
if event.ControlDown():
- self.OnLeftDownVDigitUndo(event)
+ self.OnLeftDownUndo(event)
else:
- self.OnLeftDownVDigit(event)
+ self._onLeftDown(event)
elif self.mouse['use'] == 'pointer':
# get decoration or text id
@@ -1585,375 +1149,9 @@
self.dragid = idlist[0] #drag whatever is on top
else:
pass
event.Skip()
- def OnLeftDownVDigitUndo(self, event):
- """!Left mouse button down with control key pressed - vector
- digitizer undo functionality
- if self.mouse["use"] != "pointer" or not digitToolbar:
- return
- if (digitToolbar.GetAction() == "addLine" and \
- digitToolbar.GetAction('type') in ["line", "boundary", "area"]) or \
- digitToolbar.GetAction() == "editLine":
- # add line or boundary -> remove last point from the line
- try:
- removed = self.polycoords.pop()
- Debug.msg(4, "BufferedWindow.OnMiddleDown(): polycoords_poped=%s" % \
- [removed,])
- # self.mouse['begin'] = self.Cell2Pixel(self.polycoords[-1])
- except:
- pass
- if digitToolbar.GetAction() == "editLine":
- # remove last vertex & line
- if len(self.vdigitMove['id']) > 1:
- self.vdigitMove['id'].pop()
- self.UpdateMap(render = False, renderVector = False)
- elif digitToolbar.GetAction() in ["deleteLine", "moveLine", "splitLine",
- "addVertex", "removeVertex", "moveVertex",
- "copyCats", "flipLine", "mergeLine",
- "snapLine", "connectLine", "copyLine",
- "queryLine", "breakLine", "typeConv"]:
- # varios tools -> unselected selected features
- if digitToolbar.GetAction() in ["moveLine", "moveVertex", "editLine"] and \
- hasattr(self, "vdigitMove"):
- elif digitToolbar.GetAction() == "copyCats":
- try:
- del self.copyCatsList
- del self.copyCatsIds
- except AttributeError:
- pass
- elif digitToolbar.GetAction() == "copyLine":
- del self.copyIds
- if self.layerTmp:
- self.Map.DeleteLayer(self.layerTmp)
- self.UpdateMap(render = True, renderVector = False)
- del self.layerTmp
- self.UpdateMap(render = False) # render vector
- elif digitToolbar.GetAction() == "zbulkLine":
- # reset polyline
- def OnLeftDownVDigit(self, event):
- """!Left mouse button donw - vector digitizer various actions
- try:
- except:
- wx.MessageBox(parent = self,
- message = _("No vector map selected for editing."),
- caption = _("Vector digitizer"),
- style = wx.OK | wx.ICON_INFORMATION | wx.CENTRE)
- event.Skip()
- return
- if digitToolbar.GetAction() not in ("moveVertex",
- "addVertex",
- "removeVertex",
- "editLine"):
- # set pen
- self.pen = wx.Pen(colour = 'Red', width = 2, style = wx.SHORT_DASH)
- self.polypen = wx.Pen(colour = 'dark green', width = 2, style = wx.SOLID)
- if digitToolbar.GetAction() in ("addVertex",
- "removeVertex",
- "splitLines"):
- # unselect
- if digitToolbar.GetAction() == "addLine":
- self.OnLeftDownVDigitAddLine(event)
- elif digitToolbar.GetAction() == "editLine" and \
- self.OnLeftDownVDigitEditLine(event)
- elif digitToolbar.GetAction() in ("moveLine",
- "moveVertex",
- "editLine") and \
- not hasattr(self, "vdigitMove"):
- self.OnLeftDownVDigitMoveLine(event)
- elif digitToolbar.GetAction() in ("displayAttrs"
- "displayCats"):
- self.OnLeftDownVDigitDisplayCA(event)
- elif digitToolbar.GetAction() in ("copyCats",
- "copyAttrs"):
- self.OnLeftDownVDigitCopyCA(event)
- self.OnLeftDownVDigitCopyLine(event)
- self.OnLeftDownVDigitBulkLine(event)
- def OnLeftUpVDigit(self, event):
- """!Left mouse button up - vector digitizer various actions
- pos1 = self.Pixel2Cell(self.mouse['begin'])
- pos2 = self.Pixel2Cell(self.mouse['end'])
- nselected = 0
- # -> delete line || move line || move vertex
- if digitToolbar.GetAction() in ("moveVertex",
- "editLine"):
- if len(digitClass.GetDisplay().GetSelected()) == 0:
- nselected = digitClass.GetDisplay().SelectLineByPoint(pos1)['point']
- try:
- selVertex = digitClass.GetDisplay().GetSelectedVertex(pos1)[0]
- except IndexError:
- selVertex = None
- if selVertex:
- # self.UpdateMap(render=False)
- ids = digitClass.GetDisplay().GetSelected(grassId = False)
- # move this line to tmp layer
- for id in ids:
- if id % 2: # register only vertices
- e, n = self.Pixel2Cell(self.pdcVector.GetIdBounds(id)[0:2])
- self.polycoords.append((e, n))
- digitClass.GetDisplay().DrawSelected(False)
- if selVertex < ids[-1] / 2:
- # choose first or last node of line
- self.vdigitMove['id'].reverse()
- self.polycoords.reverse()
- else:
- # unselect
- "copyAttrs"):
- if not hasattr(self, "copyCatsIds"):
- # 'from' -> select by point
- if nselected:
- self.copyCatsList = digitClass.GetDisplay().GetSelected()
- else:
- # -> 'to' -> select by bbox
- # return number of selected features (by box/point)
- nselected = digitClass.GetDisplay().SelectLinesByBox((pos1, pos2))
- if nselected == 0:
- if digitClass.GetDisplay().SelectLineByPoint(pos1) is not None:
- nselected = 1
- if nselected > 0:
- self.copyCatsIds = digitClass.GetDisplay().GetSelected()
- elif digitToolbar.GetAction() == "queryLine":
- selected = digitClass.SelectLinesByQuery(bbox = (pos1, pos2))
- nselected = len(selected)
- if nselected > 0:
- digitClass.GetDisplay().SetSelected(selected)
- else:
- # -> moveLine || deleteLine, etc. (select by point/box)
- if digitToolbar.GetAction() == 'moveLine' and \
- len(digitClass.GetDisplay().GetSelected()) > 0:
- nselected = 0
- else:
- drawSeg = True
- else:
- drawSeg = False
- nselected = digitClass.GetDisplay().SelectLinesByBox(bbox = (pos1, pos2),
- drawSeg = drawSeg)
- nselected = 1
- if nselected > 0:
- if digitToolbar.GetAction() in ("moveLine",
- "moveVertex"):
- # get pseudoDC id of objects which should be redrawn
- if digitToolbar.GetAction() == "moveLine":
- # -> move line
- self.vdigitMove['id'] = digitClass.GetDisplay().GetSelected(grassId = False)
- else: # moveVertex
- self.vdigitMove['id'] = digitClass.GetDisplay().GetSelectedVertex(pos1)
- if len(self.vdigitMove['id']) == 0: # no vertex found
- # check for duplicates
- if UserSettings.Get(group = 'vdigit', key = 'checkForDupl', subkey = 'enabled'):
- dupl = digitClass.GetDisplay().GetDuplicates()
- if dupl:
- dlg = VDigitDuplicatesDialog(parent = self, data = dupl, pos = posWindow)
- if dlg.ShowModal() == wx.ID_OK:
- digitClass.GetDisplay().UnSelect(dlg.GetUnSelected())
- # update selected
- if digitToolbar.GetAction() != "editLine":
- # -> move line || move vertex
- else: # no vector object found
- if not (digitToolbar.GetAction() in ("moveLine",
- "moveVertex") and \
- hasattr(self, "vdigitMove") and \
- len(self.vdigitMove['id']) > 0):
- # avoid left-click when features are already selected
- def OnLeftUpVDigitModifyLine(self, event):
- """!Left mouse button up - vector digitizer split line, add/remove
- vertex action
- pointOnLine = digitClass.GetDisplay().SelectLineByPoint(pos1)['point']
- if not pointOnLine:
- return
- if digitToolbar.GetAction() in ["splitLine", "addVertex"]:
- self.UpdateMap(render = False) # highlight object
- self.DrawCross(pdc = self.pdcTmp, coords = self.Cell2Pixel((pointOnLine[0], pointOnLine[1])),
- size = 5)
- else: # removeVertex
- # get only id of vertex
- try:
- id = digitClass.GetDisplay().GetSelectedVertex(pos1)[0]
- id = None
- if id:
- x, y = self.pdcVector.GetIdBounds(id)[0:2]
- self.pdcVector.RemoveId(id)
- self.DrawCross(pdc = self.pdcTmp, coords = (x, y),
- size = 5)
- else:
- # unselect
- def OnLeftUpVDigitCopyLine(self, event):
- Left mouse button up - vector digitizer copy feature action
- if UserSettings.Get(group = 'vdigit', key = 'bgmap',
- subkey = 'value', internal = True) == '':
- # no background map -> copy from current vector map layer
- if nselected > 0:
- # highlight selected features
- else:
- else:
- # copy features from background map
- self.copyIds += digitClass.SelectLinesFromBackgroundMap(bbox = (pos1, pos2))
- if len(self.copyIds) > 0:
- color = UserSettings.Get(group = 'vdigit', key = 'symbol',
- subkey = ['highlight', 'color'])
- colorStr = str(color[0]) + ":" + \
- str(color[1]) + ":" + \
- str(color[2])
- dVectTmp = ['d.vect',
- 'map=%s' % UserSettings.Get(group = 'vdigit', key = 'bgmap',
- subkey = 'value', internal = True),
- 'cats=%s' % utils.ListOfCatsToRange(self.copyIds),
- '-i',
- 'color=%s' % colorStr,
- 'fcolor=%s' % colorStr,
- 'type=point,line,boundary,centroid',
- 'width=2']
- if not self.layerTmp:
- self.layerTmp = self.Map.AddLayer(type = 'vector',
- name = globalvar.QUERYLAYER,
- command = dVectTmp)
- else:
- self.layerTmp.SetCmd(dVectTmp)
- else:
- self.redrawAll = None
- def OnLeftUpVDigitBulkLine(self, event):
- Left mouse button up - vector digitizer z-bulk line action
- # select lines to be labeled
- pos1 = self.polycoords[0]
- pos2 = self.polycoords[1]
- if nselected > 0:
- self.DrawLines(pdc = self.pdcTmp) # redraw temp line
- else:
- def OnLeftUpVDigitConnectLine(self, event):
- Left mouse button up - vector digitizer connect line action
- if len(digitClass.GetDisplay().GetSelected()) > 0:
@@ -1981,26 +1179,26 @@
# redraw map
# update statusbar
elif self.mouse["use"] == "query":
# querying
self.parent.QueryMap(self.mouse['begin'][0],self.mouse['begin'][1])
elif self.mouse["use"] == "queryVector":
# editable mode for vector map layers
self.parent.QueryVector(self.mouse['begin'][0], self.mouse['begin'][1])
# clear temp canvas
elif self.mouse["use"] in ["measure", "profile"]:
# measure or profile
if self.mouse["use"] == "measure":
self.parent.MeasureDist(self.mouse['begin'], self.mouse['end'])
@@ -2014,10 +1212,10 @@
coordtype = 'source'
else:
coordtype = 'target'
self.parent.GetLayerManager().gcpmanagement.SetGCPData(coordtype, coord, self, confirm = True)
self.parent.GetLayerManager().georectifying:
# -> georectifying
@@ -2026,55 +1224,14 @@
coordtype = 'gcpcoord'
else:
coordtype = 'mapcoord'
self.parent.GetLayerManager().georectifying.SetGCPData(coordtype, coord, self)
- elif self.mouse["use"] == "pointer" and self.parent.toolbars['vdigit']:
- # digitization tool active
- if hasattr(self, "vdigitMove"):
- self.vdigitMove['begin'] = self.Pixel2Cell(self.mouse['begin']) # left down
- # eliminate initial mouse moving efect
- self.mouse['begin'] = self.mouse['end']
- if digitToolbar.GetAction() in ("deleteLine",
- "moveLine",
- "moveVertex",
- "copyCats",
- "copyAttrs",
- "editLine",
- "flipLine",
- "mergeLine",
- "snapLine",
- "queryLine",
- "breakLine",
- "typeConv",
- "connectLine"):
- self.OnLeftUpVDigit(event)
- elif digitToolbar.GetAction() in ("splitLine",
- "addVertex",
- "removeVertex"):
- self.OnLeftUpVDigitModifyLine(event)
- self.OnLeftUpVDigitCopyLine(event)
+ elif self.mouse["use"] == "pointer" and \
- elif digitToolbar.GetAction() == "zbulkLine" and \
- len(self.polycoords) == 2:
- self.OnLeftUpVDigitBulkLine(event)
- elif digitToolbar.GetAction() == "connectLine":
- self.OnLeftUpConnectLine(event)
elif (self.mouse['use'] == 'pointer' and
self.dragid >= 0):
# end drag of overlay decoration
@@ -2089,12 +1246,11 @@
def OnButtonDClick(self, event):
- Mouse button double click
+ """!Mouse button double click
Debug.msg (5, "BufferedWindow.OnButtonDClick(): use=%s" % \
self.mouse["use"])
# measure
self.ClearLines(pdc=self.pdcTmp)
@@ -2104,17 +1260,11 @@
self.mouse['end'] = [0, 0]
self.Refresh()
self.SetCursor(self.parent.cursors["default"])
- elif self.mouse["use"] == "profile":
- pass
- elif self.mouse['use'] == 'pointer' and \
- # vector digitizer
- pass
- else:
- # select overlay decoration options dialog
+ elif self.mouse["use"] != "profile" or \
+ (self.mouse['use'] != 'pointer' and \
+ hasattr(self, "digit")):
+ # select overlay decoration options dialog
clickposition = event.GetPositionTuple()[:]
idlist = self.pdc.FindObjects(clickposition[0], clickposition[1], self.hitradius)
if idlist == []:
@@ -2135,238 +1285,37 @@
Debug.msg (5, "BufferedWindow.OnRightDown(): use=%s" % \
self.mouse["use"])
- if digitToolbar:
- # digitization tool (confirm action)
- pFrom = self.vdigitMove['begin']
- pTo = self.Pixel2Cell(event.GetPositionTuple())
- move = (pTo[0] - pFrom[0],
- pTo[1] - pFrom[1])
- # move line
- if digitClass.MoveSelectedLines(move) < 0:
- return
- elif digitToolbar.GetAction() == "moveVertex":
- # move vertex
- fid = digitClass.MoveSelectedVertex(pFrom, move)
- if fid < 0:
- return
- self._geomAttrbUpdate([fid,])
+ self._onRightDown(event)
event.Skip()
def OnRightUp(self, event):
Debug.msg (5, "BufferedWindow.OnRightUp(): use=%s" % \
self.mouse["use"])
- self.OnRightUpVDigit(event)
+ self._onRightUp(event)
self.Refresh()
event.Skip()
- def OnRightUpVDigit(self, event):
- """!Right mouse button release (vector digitizer)
- if not digitToolbar:
- return
- if digitToolbar.GetAction() == "addLine" and \
- digitToolbar.GetAction('type') in ["line", "boundary", "area"]:
- # -> add new line / boundary
- try:
- mapName = digitToolbar.GetLayer().GetName()
- except:
- mapName = None
- gcmd.GError(parent = self,
- message = _("No vector map selected for editing."))
- if mapName:
- if digitToolbar.GetAction('type') == 'line':
- line = True
- else:
- line = False
- if len(self.polycoords) < 2: # ignore 'one-point' lines
- return
- nfeat, fids = digitClass.AddFeature(digitToolbar.GetAction('type'), self.polycoords)
- if nfeat < 0:
- return
- position = self.Cell2Pixel(self.polycoords[-1])
- self.Refresh()
- if UserSettings.Get(group = 'vdigit', key = "addRecord", subkey = 'enabled') and \
- (line is True or \
- (not line and nfeat > 0)):
- posWindow = self.ClientToScreen((position[0] + self.dialogOffset,
- position[1] + self.dialogOffset))
- addRecordDlg = dbm_dialogs.DisplayAttributesDialog(parent = self, map = mapName,
- cats = cats,
- pos = posWindow,
- action = "add")
- for fid in fids:
- self._geomAttrb(fid, addRecordDlg, 'length', digitClass,
- # auto-placing centroid
- parent = True,
- quiet = True,
- elif digitToolbar.GetAction() == "deleteLine":
- # -> delete selected vector features
- if digitClass.DeleteSelectedLines() < 0:
- return
- elif digitToolbar.GetAction() == "splitLine":
- # split line
- if digitClass.SplitLine(self.Pixel2Cell(self.mouse['begin'])) < 0:
- return
- elif digitToolbar.GetAction() == "addVertex":
- # add vertex
- fid = digitClass.AddVertex(self.Pixel2Cell(self.mouse['begin']))
- if fid < 0:
- return
- elif digitToolbar.GetAction() == "removeVertex":
- # remove vertex
- fid = digitClass.RemoveVertex(self.Pixel2Cell(self.mouse['begin']))
- if fid < 0:
- return
- elif digitToolbar.GetAction() in ("copyCats", "copyAttrs"):
- try:
- if digitToolbar.GetAction() == 'copyCats':
- if digitClass.CopyCats(self.copyCatsList,
- self.copyCatsIds, copyAttrb = False) < 0:
- return
- else:
- self.copyCatsIds, copyAttrb = True) < 0:
- return
- pass
- line = digitClass.GetDisplay().GetSelected()
- if digitClass.EditLine(line, self.polycoords) < 0:
- return
- elif digitToolbar.GetAction() == "flipLine":
- if digitClass.FlipLine() < 0:
- return
- elif digitToolbar.GetAction() == "mergeLine":
- if digitClass.MergeLine() < 0:
- return
- elif digitToolbar.GetAction() == "breakLine":
- if digitClass.BreakLine() < 0:
- return
- elif digitToolbar.GetAction() == "snapLine":
- if digitClass.SnapLine() < 0:
- return
- if len(digitClass.GetDisplay().GetSelected()) > 1:
- if digitClass.ConnectLine() < 0:
- return
- if digitClass.CopyLine(self.copyIds) < 0:
- return
- del self.copyIds
- if self.layerTmp:
- del self.layerTmp
- elif digitToolbar.GetAction() == "zbulkLine" and len(self.polycoords) == 2:
- selected = digitClass.GetDisplay().GetSelected()
- dlg = VDigitZBulkDialog(parent = self, title = _("Z bulk-labeling dialog"),
- nselected = len(selected))
- if digitClass.ZBulkLines(pos1, pos2, dlg.value.GetValue(),
- dlg.step.GetValue()) < 0:
- return
- elif digitToolbar.GetAction() == "typeConv":
- # -> feature type conversion
- # - point <-> centroid
- # - line <-> boundary
- if digitClass.TypeConvForSelectedLines() < 0:
- return
- if digitToolbar.GetAction() != "addLine":
- # unselect and re-render
def OnMiddleDown(self, event):
"""!Middle mouse button pressed
- if event:
- self.mouse['begin'] = event.GetPositionTuple()[:]
+ if not event:
+ return
+ self.mouse['begin'] = event.GetPositionTuple()[:]
def OnMiddleUp(self, event):
"""!Middle mouse button released
- # if self.parent.toolbars['vdigit']:
- # event.Skip()
- # return
# set region in zoom or pan
@@ -2394,74 +1343,16 @@
self.SetFocus()
else:
event.Skip()
def OnMouseMoving(self, event):
"""!Motion event and no mouse buttons were pressed
- if self.mouse["use"] == "pointer" and digitToolbar:
- self.mouse['end'] = event.GetPositionTuple()[:]
- Debug.msg (5, "BufferedWindow.OnMouseMoving(): coords=%f,%f" % \
- (self.mouse['end'][0], self.mouse['end'][1]))
- if len(self.polycoords) > 0:
- self.MouseDraw(pdc = self.pdcTmp, begin = self.Cell2Pixel(self.polycoords[-1]))
- elif digitToolbar.GetAction() in ["moveLine", "moveVertex", "editLine"] \
- and hasattr(self, "vdigitMove"):
- dx = self.mouse['end'][0] - self.mouse['begin'][0]
- dy = self.mouse['end'][1] - self.mouse['begin'][1]
- if len(self.vdigitMove['id']) > 0:
- # draw lines on new position
- # move line
- self.pdcTmp.TranslateId(id, dx, dy)
- elif digitToolbar.GetAction() in ["moveVertex", "editLine"]:
- # move vertex ->
- # (vertex, left vertex, left line,
- # right vertex, right line)
- # do not draw static lines
- if digitToolbar.GetAction() == "moveVertex":
- ### self.pdcTmp.TranslateId(self.vdigitMove['id'][0], dx, dy)
- self.pdcTmp.RemoveId(self.vdigitMove['id'][0])
- if self.vdigitMove['id'][1] > 0: # previous vertex
- x, y = self.Pixel2Cell(self.pdcTmp.GetIdBounds(self.vdigitMove['id'][1])[0:2])
- self.pdcTmp.RemoveId(self.vdigitMove['id'][1] + 1)
- self.polycoords.append((x, y))
- ### x, y = self.Pixel2Cell(self.pdcTmp.GetIdBounds(self.vdigitMove['id'][0])[0:2])
- self.polycoords.append(self.Pixel2Cell(self.mouse['end']))
- if self.vdigitMove['id'][2] > 0: # next vertex
- x, y = self.Pixel2Cell(self.pdcTmp.GetIdBounds(self.vdigitMove['id'][2])[0:2])
- self.pdcTmp.RemoveId(self.vdigitMove['id'][2]-1)
- else: # edit line
- try:
- if self.vdigitMove['id'][-1] > 0: # previous vertex
- begin = self.Cell2Pixel(self.polycoords[-1]))
- except: # no line
- self.Refresh() # TODO: use RefreshRect()
- # draw mouse moving
- self.MouseDraw(self.pdcTmp)
+ if self.mouse["use"] == "pointer" and \
+ self._onMouseMoving(event)
event.Skip()
def ClearLines(self, pdc = None):
"""!Clears temporary drawn lines from PseudoDC
@@ -2472,23 +1363,21 @@
pdc.RemoveId(self.lineid)
except:
pass
try:
pdc.ClearId(self.plineid)
pdc.RemoveId(self.plineid)
except:
pass
Debug.msg(4, "BufferedWindow.ClearLines(): lineid=%s, plineid=%s" %
(self.lineid, self.plineid))
return True
def Pixel2Cell(self, (x, y)):
"""!Convert image coordinates to real word coordinates
@param x, y image coordinates
@return easting, northing
@@ -2512,7 +1401,7 @@
north = n - y * res
return (east, north)
def Cell2Pixel(self, (east, north)):
"""!Convert real word coordinates to image coordinates
@@ -2534,7 +1423,7 @@
y = (n - north) / res
return (x, y)
def Zoom(self, begin, end, zoomtype):
Calculates new region while (un)zoom/pan-ing
@@ -2542,21 +1431,20 @@
x1, y1 = begin
x2, y2 = end
newreg = {}
# threshold - too small squares do not make sense
# can only zoom to windows of > 5x5 screen pixels
if abs(x2-x1) > 5 and abs(y2-y1) > 5 and zoomtype != 0:
if x1 > x2:
x1, x2 = x2, x1
if y1 > y2:
y1, y2 = y2, y1
# zoom in
if zoomtype > 0:
newreg['w'], newreg['n'] = self.Pixel2Cell((x1, y1))
newreg['e'], newreg['s'] = self.Pixel2Cell((x2, y2))
# zoom out
elif zoomtype < 0:
newreg['w'], newreg['n'] = self.Pixel2Cell((-x1 * 2, -y1 * 2))
@@ -2574,7 +1462,7 @@
newreg['w'], newreg['n'] = self.Pixel2Cell((dx, dy))
newreg['e'], newreg['s'] = self.Pixel2Cell((self.Map.width + dx,
self.Map.height + dy))
# if new region has been calculated, set the values
if newreg != {}:
# LL locations
@@ -2587,33 +1475,23 @@
ce = newreg['w'] + (newreg['e'] - newreg['w']) / 2
cn = newreg['s'] + (newreg['n'] - newreg['s']) / 2
- # xo = self.Cell2Pixel((self.Map.region['center_easting'], self.Map.region['center_northing']))
- # xn = self.Cell2Pixel(ce, cn))
- tmp = self.Pixel2Cell(self.mouse['end'])
# calculate new center point and display resolution
self.Map.region['center_easting'] = ce
self.Map.region['center_northing'] = cn
self.Map.region["ewres"] = (newreg['e'] - newreg['w']) / self.Map.width
self.Map.region["nsres"] = (newreg['n'] - newreg['s']) / self.Map.height
self.Map.AlignExtentFromDisplay()
- tmp1 = self.mouse['end']
- tmp2 = self.Cell2Pixel(self.vdigitMove['begin'])
- dx = tmp1[0] - tmp2[0]
- dy = tmp1[1] - tmp2[1]
- self.vdigitMove['beginDiff'] = (dx, dy)
- self.pdcTmp.RemoveId(id)
+ if hasattr(self, "digit") and \
+ hasattr(self, "moveInfo"):
+ self._zoom(event)
self.ZoomHistory(self.Map.region['n'], self.Map.region['s'],
self.Map.region['e'], self.Map.region['w'])
def ZoomBack(self):
"""!Zoom to previous extents in zoomhistory list
@@ -2645,8 +1523,7 @@
def ZoomHistory(self, n, s, e, w):
- Manages a list of last 10 zoom extents
+ """!Manages a list of last 10 zoom extents
@param n,s,e,w north, south, east, west
@@ -2685,8 +1562,7 @@
def ResetZoomHistory(self):
"""!Reset zoom history"""
self.zoomhistory = list()
def ZoomToMap(self, layers = None, ignoreNulls = False, render = True):
"""!Set display extents to match selected raster
or vector map(s).
@@ -2711,9 +1587,9 @@
if l.type == 'raster':
rast.append(l.GetName())
elif l.type == 'vector':
- if digitToolbar and digitToolbar.GetLayer() == l:
- w, s, b, e, n, t = self.parent.digit.GetDisplay().GetMapBoundingBox()
+ self.toolbar.GetLayer() == l:
+ w, s, b, e, n, t = self.display.GetMapBoundingBox()
self.Map.GetRegion(n = n, s = s, w = w, e = e,
update = True)
updated = True
@@ -2733,7 +1609,7 @@
if render:
self.UpdateMap()
def ZoomToWind(self):
@@ -2741,13 +1617,12 @@
settings (set with g.region)
self.Map.region = self.Map.GetRegion()
- ### self.Map.SetRegion(windres=True)
self.UpdateMap()
def ZoomToDefault(self):
@@ -2758,9 +1633,9 @@
self.UpdateMap()
def DisplayToWind(self):
@@ -2770,7 +1645,7 @@
tmpreg = os.getenv("GRASS_REGION")
if tmpreg:
del os.environ["GRASS_REGION"]
# We ONLY want to set extents here. Don't mess with resolution. Leave that
# for user to set explicitly with g.region
new = self.Map.AlignResolution()
@@ -2786,7 +1661,7 @@
if tmpreg:
os.environ["GRASS_REGION"] = tmpreg
def ZoomToSaved(self):
"""!Set display geometry to match extents in
saved region file
@@ -2828,7 +1703,7 @@
if dlg.ShowModal() == wx.ID_CANCEL or not dlg.wind:
dlg.Destroy()
return
# test to see if it already exists and ask permission to overwrite
if grass.find_file(name = dlg.wind, element = 'windows')['name']:
overwrite = wx.MessageBox(parent = self,
@@ -2841,14 +1716,14 @@
self.SaveRegion(dlg.wind)
dlg.Destroy()
def SaveRegion(self, wind):
"""!Save region settings
@param wind region name
new = self.Map.GetCurrentRegion()
if tmpreg:
@@ -2867,14 +1742,14 @@
if tmpreg:
def Distance(self, beginpt, endpt, screen=True):
"""!Calculete distance
LL-locations not supported
@todo Use m.distance
@param beginpt first point
@param endpt second point
@param screen True for screen coordinates otherwise EN
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py 2011-02-11 22:07:34 UTC (rev 45383)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py 2011-02-12 09:54:41 UTC (rev 45384)
@@ -637,7 +637,8 @@
self.layerTree = layerTree # reference to layer tree associated to map display
self.log = log # log area
AbstractToolbar.__init__(self, parent)
+ self.digit = self.parent.MapWindow.digit
# currently selected map layer for editing (reference to MapLayer instance)
self.mapLayer = None
# list of vector layers from Layer Manager (only in the current mapset)
@@ -794,8 +795,8 @@
# clear tmp canvas
if self.action['id'] != id:
self.parent.MapWindow.ClearLines(pdc = self.parent.MapWindow.pdcTmp)
- if self.parent.digit and \
- len(self.parent.digit.GetDisplay().GetSelected()) > 0:
+ if self.parent.MapWindow.digit and \
+ len(self.parent.MapWindow.digit.GetDisplay().GetSelected()) > 0:
# cancel action
self.parent.MapWindow.OnMiddleDown(None)
@@ -983,7 +984,7 @@
def OnUndo(self, event):
"""!Undo previous changes"""
- self.parent.digit.Undo()
+ self.digit.Undo()
event.Skip()
@@ -1001,11 +1002,11 @@
def OnSettings(self, event):
"""!Show settings dialog"""
- if self.parent.digit is None:
+ if self.digit is None:
try:
- self.parent.digit = VDigit(mapwindow = self.parent.MapWindow)
+ self.digit = self.parent.MapWindow.digit = VDigit(mapwindow = self.parent.MapWindow)
except SystemExit:
- self.parent.digit = None
+ self.digit = self.parent.MapWindow.digit = None
if not self.settingsDialog:
self.settingsDialog = VDigitSettingsDialog(parent = self.parent, title = _("Digitization settings"),
@@ -1191,7 +1192,7 @@
def OnZBulk(self, event):
"""!Z bulk-labeling selected lines/boundaries"""
- if not self.parent.digit.IsVector3D():
+ if not self.digit.IsVector3D():
gcmd.GError(parent = self.parent,
message = _("Vector map is not 3D. Operation canceled."))
return
@@ -1301,12 +1302,12 @@
0)
self.parent.MapWindow.pdcVector = wx.PseudoDC()
self.mapLayer = mapLayer
# open vector map
- if self.parent.digit.OpenMap(mapLayer.GetName()) is None:
+ if self.digit.OpenMap(mapLayer.GetName()) is None:
self.StopEditing()
return False
@@ -1330,7 +1331,7 @@
opacity = mapLayer.GetOpacity(float = True)
if opacity < 1.0:
alpha = int(opacity * 255)
- self.parent.digit.driver.UpdateSettings(alpha)
+ self.digit.UpdateSettings(alpha)
return True
@@ -1346,7 +1347,7 @@
if self.mapLayer:
Debug.msg (4, "VDigitToolbar.StopEditing(): layer=%s" % self.mapLayer.GetName())
if UserSettings.Get(group = 'vdigit', key = 'saveOnExit', subkey = 'enabled') is False:
- if self.parent.digit.GetUndoLevel() > -1:
+ if self.digit.GetUndoLevel() > -1:
dlg = wx.MessageDialog(parent = self.parent,
message = _("Do you want to save changes "
"in vector map <%s>?") % self.mapLayer.GetName(),
@@ -1354,7 +1355,7 @@
style = wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
if dlg.ShowModal() == wx.ID_NO:
# revert changes
- self.parent.digit.Undo(0)
+ self.digit.Undo(0)
dlg.Destroy()
self.parent.statusbar.SetStatusText(_("Please wait, "
@@ -1365,7 +1366,7 @@
if lmgr:
lmgr.toolbar.Enable('vdigit', enable = True)
lmgr.notebook.SetSelection(1)
- self.parent.digit.CloseMap()
+ self.digit.CloseMap()
if lmgr:
lmgr.GetLogWindow().GetProgressBar().SetValue(0)
lmgr.GetLogWindow().WriteCmdLog(_("Editing of vector map <%s> successfully finished") % \
@@ -1385,8 +1386,8 @@
self.parent.dialogs[dialog].Close()
self.parent.dialogs[dialog] = None
- self.parent.digit.__del__() # FIXME: destructor is not called here (del)
+ self.digit.__del__() # FIXME: destructor is not called here (del)
Property changes on: grass/branches/develbranch_6/gui/wxpython/gui_modules/vclean.py
+ text/x-python
+ native
Property changes on: grass/branches/develbranch_6/gui/wxpython/gui_modules/wxnviz.py
+ text/x-python
+ native
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/wxvdigit.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/wxvdigit.py 2011-02-11 22:07:34 UTC (rev 45383)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/wxvdigit.py 2011-02-12 09:54:41 UTC (rev 45384)
@@ -1075,7 +1075,7 @@
area = Vect_get_centroid_area(self.poMapInfo, centroid)
perimeter = -1
if area > 0:
- if not Vect_area_alive(self,poMapInfo, area):
+ if not Vect_area_alive(self.poMapInfo, area):
return -1
Vect_get_area_points(self.poMapInfo, area, self.poPoints)
