[GRASS-SVN] r45388 - in grass/trunk: . include include/Make lib/init
svn_grass at osgeo.org
Sat Feb 12 08:10:10 EST 2011
Author: martinl
Date: 2011-02-12 05:10:10 -0800 (Sat, 12 Feb 2011)
New Revision: 45388
grass/trunk/configure
grass/trunk/configure.in
grass/trunk/include/Make/Platform.make.in
grass/trunk/include/Make/Python.make
grass/trunk/include/gisdefs.h
grass/trunk/lib/init/variables.html
there is no need for python switch (wxGUI vdigit and nviz were
pythonized)
Modified: grass/trunk/configure
--- grass/trunk/configure 2011-02-12 13:01:43 UTC (rev 45387)
+++ grass/trunk/configure 2011-02-12 13:10:10 UTC (rev 45388)
@@ -73,12 +73,6 @@
enable GDAL/OGR support (gdal-config with path,
e.g. '--with-gdal=/usr/local/bin/gdal-config')"
ac_help="$ac_help
- --with-python[=path/python-config]
- enable support for Python SWIG bindings and wxGUI
- Python extensions (python-config with path, e.g.
- '--with-python=/usr/bin/python2.5-config',
- default: no)"
-ac_help="$ac_help
--with-wxwidgets[=path/wx-config]
enable wxWidgets support (wx-config with path,
e.g. '--with-wxwidgets=/usr/local/bin/wx-config',
@@ -746,7 +740,7 @@
fi
echo $ac_n "checking host system type""... $ac_c" 1>&6
-echo "configure:750: checking host system type" >&5
+echo "configure:744: checking host system type" >&5
host_alias=$host
case "$host_alias" in
@@ -769,7 +763,7 @@
# Extract the first word of "gcc", so it can be a program name with args.
set dummy gcc; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:773: checking for $ac_word" >&5
+echo "configure:767: checking for $ac_word" >&5
if test -n "$CC"; then
ac_cv_prog_CC="$CC" # Let the user override the test.
@@ -796,7 +790,7 @@
# Extract the first word of "cc", so it can be a program name with args.
set dummy cc; ac_word=$2
-echo "configure:800: checking for $ac_word" >&5
+echo "configure:794: checking for $ac_word" >&5
@@ -844,7 +838,7 @@
# Extract the first word of "cl", so it can be a program name with args.
set dummy cl; ac_word=$2
-echo "configure:848: checking for $ac_word" >&5
+echo "configure:842: checking for $ac_word" >&5
@@ -873,7 +867,7 @@
fi
echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:877: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
+echo "configure:871: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
ac_ext=c
# CFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -884,12 +878,12 @@
cat > conftest.$ac_ext << EOF
-#line 888 "configure"
+#line 882 "configure"
#include "confdefs.h"
main(){return(0);}
EOF
-if { (eval echo configure:893: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:887: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cc_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -915,19 +909,19 @@
{ echo "configure: error: installation or configuration problem: C compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:919: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:913: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cc_cross" 1>&6
cross_compiling=$ac_cv_prog_cc_cross
echo $ac_n "checking whether we are using GNU C""... $ac_c" 1>&6
-echo "configure:924: checking whether we are using GNU C" >&5
+echo "configure:918: checking whether we are using GNU C" >&5
cat > conftest.c <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:931: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:925: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gcc=yes
else
ac_cv_prog_gcc=no
@@ -945,7 +939,7 @@
ac_save_CFLAGS="$CFLAGS"
CFLAGS=
echo $ac_n "checking whether ${CC-cc} accepts -g""... $ac_c" 1>&6
-echo "configure:949: checking whether ${CC-cc} accepts -g" >&5
+echo "configure:943: checking whether ${CC-cc} accepts -g" >&5
echo 'void f(){}' > conftest.c
if test -z "`${CC-cc} -g -c conftest.c 2>&1`"; then
@@ -974,10 +968,10 @@
fi
echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:978: checking for Cygwin environment" >&5
+echo "configure:972: checking for Cygwin environment" >&5
cat > conftest.$ac_ext <<EOF
-#line 981 "configure"
+#line 975 "configure"
int main() {
@@ -988,7 +982,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:992: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:986: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -1004,17 +998,17 @@
CYGWIN=
test "$ac_cv_cygwin" = yes && CYGWIN=yes
echo $ac_n "checking for mingw32 environment""... $ac_c" 1>&6
-echo "configure:1008: checking for mingw32 environment" >&5
+echo "configure:1002: checking for mingw32 environment" >&5
-#line 1011 "configure"
+#line 1005 "configure"
int main() {
return __MINGW32__;
; return 0; }
EOF
-if { (eval echo configure:1018: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1012: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_mingw32=yes
else
@@ -1032,7 +1026,7 @@
echo $ac_n "checking for executable suffix""... $ac_c" 1>&6
-echo "configure:1036: checking for executable suffix" >&5
+echo "configure:1030: checking for executable suffix" >&5
if test "$CYGWIN" = yes || test "$MINGW32" = yes; then
ac_cv_exeext=.exe
@@ -1051,23 +1045,23 @@
IEEEFLAG=
echo $ac_n "checking for full floating-point support""... $ac_c" 1>&6
-echo "configure:1055: checking for full floating-point support" >&5
+echo "configure:1049: checking for full floating-point support" >&5
if test "$cross_compiling" = yes; then
echo "$ac_t""unknown (cross-compiling)" 1>&6
echo $ac_n "checking whether "cc -mieee" works""... $ac_c" 1>&6
-echo "configure:1060: checking whether "cc -mieee" works" >&5
+echo "configure:1054: checking whether "cc -mieee" works" >&5
ac_save_cflags=${CFLAGS}
CFLAGS="$CFLAGS -mieee"
-#line 1064 "configure"
+#line 1058 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:1071: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1065: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
echo "$ac_t""yes" 1>&6
IEEEFLAG="-mieee"
@@ -1083,7 +1077,7 @@
else
-#line 1087 "configure"
+#line 1081 "configure"
#include <float.h>
@@ -1097,7 +1091,7 @@
EOF
-if { (eval echo configure:1101: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1095: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
@@ -1110,14 +1104,14 @@
CFLAGS=-mieee
echo $ac_n "checking for full floating-point support with -mieee""... $ac_c" 1>&6
-echo "configure:1114: checking for full floating-point support with -mieee" >&5
+echo "configure:1108: checking for full floating-point support with -mieee" >&5
{ echo "configure: error: *** INTERNAL CONFIGURE ERROR" 1>&2; exit 1; }
else
-#line 1121 "configure"
+#line 1115 "configure"
#include <float.h>
@@ -1131,7 +1125,7 @@
EOF
-if { (eval echo configure:1135: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1129: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
IEEEFLAG="-mieee"
@@ -1168,7 +1162,7 @@
# Extract the first word of "pwd", so it can be a program name with args.
set dummy pwd; ac_word=$2
-echo "configure:1172: checking for $ac_word" >&5
+echo "configure:1166: checking for $ac_word" >&5
case "$pwd" in
@@ -1206,7 +1200,7 @@
fi
echo $ac_n "checking for source directory""... $ac_c" 1>&6
-echo "configure:1210: checking for source directory" >&5
+echo "configure:1204: checking for source directory" >&5
if test -z "$srcdir" ; then
SRCDIR=`$pwd`
@@ -1217,7 +1211,7 @@
echo "$ac_t"""$SRCDIR"" 1>&6
echo $ac_n "checking for build directory""... $ac_c" 1>&6
-echo "configure:1221: checking for build directory" >&5
+echo "configure:1215: checking for build directory" >&5
DSTDIR=`$pwd`
WINDSTDIR=`$winpwd`
@@ -1285,7 +1279,7 @@
# Extract the first word of "svnversion", so it can be a program name with args.
set dummy svnversion; ac_word=$2
-echo "configure:1289: checking for $ac_word" >&5
+echo "configure:1283: checking for $ac_word" >&5
case "$SVN_VERSION" in
@@ -1341,7 +1335,7 @@
echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1345: checking for MacOSX App" >&5
+echo "configure:1339: checking for MacOSX App" >&5
case "$enable_macosx_app" in
yes) MACOSX_APP=1 ;;
no) MACOSX_APP= ;;
@@ -1353,7 +1347,7 @@
# Check for MacOSX archs
echo $ac_n "checking for MacOSX architectures""... $ac_c" 1>&6
-echo "configure:1357: checking for MacOSX architectures" >&5
+echo "configure:1351: checking for MacOSX architectures" >&5
MACOSX_ARCHS=
@@ -1382,7 +1376,7 @@
# Check for MacOSX SDK
echo $ac_n "checking for MacOSX SDK""... $ac_c" 1>&6
-echo "configure:1386: checking for MacOSX SDK" >&5
+echo "configure:1380: checking for MacOSX SDK" >&5
MACOSX_SDK=
@@ -1392,7 +1386,7 @@
ac_safe=`echo "$with_macosx_sdk/SDKSettings.plist" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $with_macosx_sdk/SDKSettings.plist""... $ac_c" 1>&6
-echo "configure:1396: checking for $with_macosx_sdk/SDKSettings.plist" >&5
+echo "configure:1390: checking for $with_macosx_sdk/SDKSettings.plist" >&5
{ echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -1436,7 +1430,7 @@
echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1440: checking how to build libraries" >&5
+echo "configure:1434: checking how to build libraries" >&5
# Check whether --enable-shared or --disable-shared was given.
if test "${enable_shared+set}" = set; then
enableval="$enable_shared"
@@ -1821,15 +1815,6 @@
fi
-# Check whether --with-python or --without-python was given.
-if test "${with_python+set}" = set; then
- withval="$with_python"
-else
- with_python="no"
-fi
# Check whether --with-wxwidgets or --without-wxwidgets was given.
if test "${with_wxwidgets+set}" = set; then
withval="$with_wxwidgets"
@@ -2254,7 +2239,7 @@
# Done checking fortran
echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:2258: checking for additional include dirs" >&5
+echo "configure:2243: checking for additional include dirs" >&5
case "$with_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -2277,7 +2262,7 @@
# With libs option
echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:2281: checking for additional library dirs" >&5
+echo "configure:2266: checking for additional library dirs" >&5
case "$with_libs" in
{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -2311,7 +2296,7 @@
# SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
# ./install, which can be erroneously created by make from ./install.sh.
echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:2315: checking for a BSD compatible install" >&5
+echo "configure:2300: checking for a BSD compatible install" >&5
if test -z "$INSTALL"; then
IFS="${IFS= }"; ac_save_IFS="$IFS"; IFS=":"
@@ -2364,7 +2349,7 @@
# Extract the first word of "flex", so it can be a program name with args.
set dummy flex; ac_word=$2
-echo "configure:2368: checking for $ac_word" >&5
+echo "configure:2353: checking for $ac_word" >&5
if test -n "$LEX"; then
ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -2395,13 +2380,13 @@
*) ac_lib=l ;;
esac
echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:2399: checking for yywrap in -l$ac_lib" >&5
+echo "configure:2384: checking for yywrap in -l$ac_lib" >&5
ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-l$ac_lib $LIBS"
-#line 2405 "configure"
+#line 2390 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -2412,7 +2397,7 @@
yywrap()
; return 0; }
EOF
-if { (eval echo configure:2416: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2401: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -2437,7 +2422,7 @@
# Extract the first word of "lex", so it can be a program name with args.
set dummy lex; ac_word=$2
-echo "configure:2441: checking for $ac_word" >&5
+echo "configure:2426: checking for $ac_word" >&5
case "$LEXPATH" in
@@ -2477,7 +2462,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:2481: checking for $ac_word" >&5
+echo "configure:2466: checking for $ac_word" >&5
if test -n "$YACC"; then
ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -2508,7 +2493,7 @@
# Extract the first word of "yacc", so it can be a program name with args.
set dummy yacc; ac_word=$2
-echo "configure:2512: checking for $ac_word" >&5
+echo "configure:2497: checking for $ac_word" >&5
case "$YACCPATH" in
@@ -2546,7 +2531,7 @@
# Extract the first word of "ranlib", so it can be a program name with args.
set dummy ranlib; ac_word=$2
-echo "configure:2550: checking for $ac_word" >&5
+echo "configure:2535: checking for $ac_word" >&5
if test -n "$RANLIB"; then
ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -2575,7 +2560,7 @@
-echo "configure:2579: checking for $ac_word" >&5
+echo "configure:2564: checking for $ac_word" >&5
if test -n "$AR"; then
ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -2606,7 +2591,7 @@
-echo "configure:2610: checking for $ac_word" >&5
+echo "configure:2595: checking for $ac_word" >&5
if test -n "$ENV"; then
ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -2635,7 +2620,7 @@
# Extract the first word of "perl", so it can be a program name with args.
set dummy perl; ac_word=$2
-echo "configure:2639: checking for $ac_word" >&5
+echo "configure:2624: checking for $ac_word" >&5
case "$PERL" in
@@ -2666,7 +2651,7 @@
fi
echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:2670: checking how to run the C preprocessor" >&5
+echo "configure:2655: checking how to run the C preprocessor" >&5
# On Suns, sometimes $CPP names a directory.
if test -n "$CPP" && test -d "$CPP"; then
CPP=
@@ -2679,13 +2664,13 @@
# On the NeXT, cc -E runs the code through the compiler's parser,
# not just through cpp.
-#line 2683 "configure"
+#line 2668 "configure"
#include <assert.h>
Syntax Error
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:2689: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2674: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
@@ -2696,13 +2681,13 @@
rm -rf conftest*
CPP="${CC-cc} -E -traditional-cpp"
-#line 2700 "configure"
+#line 2685 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:2706: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2691: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2713,13 +2698,13 @@
rm -rf conftest*
CPP="${CC-cc} -nologo -E"
-#line 2717 "configure"
+#line 2702 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:2723: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2708: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2743,10 +2728,10 @@
echo "$ac_t""$CPP" 1>&6
echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:2747: checking for ANSI C header files" >&5
+echo "configure:2732: checking for ANSI C header files" >&5
-#line 2750 "configure"
+#line 2735 "configure"
#include <stdlib.h>
#include <stdarg.h>
@@ -2754,7 +2739,7 @@
#include <float.h>
EOF
-{ (eval echo configure:2758: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2743: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2771,7 +2756,7 @@
if test $ac_cv_header_stdc = yes; then
# SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 2775 "configure"
+#line 2760 "configure"
#include <string.h>
EOF
@@ -2789,7 +2774,7 @@
# ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 2793 "configure"
+#line 2778 "configure"
#include <stdlib.h>
EOF
@@ -2810,7 +2795,7 @@
else
-#line 2814 "configure"
+#line 2799 "configure"
#include <ctype.h>
#define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -2821,7 +2806,7 @@
exit (0); }
EOF
-if { (eval echo configure:2825: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:2810: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
else
@@ -2848,15 +2833,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:2852: checking for $ac_hdr" >&5
+echo "configure:2837: checking for $ac_hdr" >&5
-#line 2855 "configure"
+#line 2840 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2860: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2845: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2885,15 +2870,15 @@
do
-echo "configure:2889: checking for $ac_hdr" >&5
+echo "configure:2874: checking for $ac_hdr" >&5
-#line 2892 "configure"
+#line 2877 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2897: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2882: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2922,15 +2907,15 @@
do
-echo "configure:2926: checking for $ac_hdr" >&5
+echo "configure:2911: checking for $ac_hdr" >&5
-#line 2929 "configure"
+#line 2914 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2934: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2919: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2959,15 +2944,15 @@
do
-echo "configure:2963: checking for $ac_hdr" >&5
+echo "configure:2948: checking for $ac_hdr" >&5
-#line 2966 "configure"
+#line 2951 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2971: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2956: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2996,15 +2981,15 @@
do
-echo "configure:3000: checking for $ac_hdr" >&5
+echo "configure:2985: checking for $ac_hdr" >&5
-#line 3003 "configure"
+#line 2988 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3008: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2993: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3030,10 +3015,10 @@
done
echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:3034: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:3019: checking whether time.h and sys/time.h may both be included" >&5
-#line 3037 "configure"
+#line 3022 "configure"
#include <sys/types.h>
#include <sys/time.h>
@@ -3042,7 +3027,7 @@
struct tm *tp;
; return 0; }
EOF
-if { (eval echo configure:3046: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3031: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_header_time=yes
else
@@ -3062,10 +3047,10 @@
fi
echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:3066: checking for off_t" >&5
+echo "configure:3051: checking for off_t" >&5
-#line 3069 "configure"
+#line 3054 "configure"
#if STDC_HEADERS
@@ -3092,10 +3077,10 @@
fi
echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:3096: checking for uid_t in sys/types.h" >&5
+echo "configure:3081: checking for uid_t in sys/types.h" >&5
-#line 3099 "configure"
+#line 3084 "configure"
EOF
@@ -3123,10 +3108,10 @@
fi
echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:3127: checking return type of signal handlers" >&5
+echo "configure:3112: checking return type of signal handlers" >&5
-#line 3130 "configure"
+#line 3115 "configure"
#include <signal.h>
@@ -3143,7 +3128,7 @@
int i;
; return 0; }
EOF
-if { (eval echo configure:3147: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3132: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_type_signal=void
else
@@ -3161,10 +3146,10 @@
-echo "configure:3165: checking for Cygwin environment" >&5
+echo "configure:3150: checking for Cygwin environment" >&5
-#line 3168 "configure"
+#line 3153 "configure"
int main() {
@@ -3175,7 +3160,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:3179: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3164: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -3193,10 +3178,10 @@
for ac_func in ftime gethostname gettimeofday lseek nice time uname
do
echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:3197: checking for $ac_func" >&5
+echo "configure:3182: checking for $ac_func" >&5
-#line 3200 "configure"
+#line 3185 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char $ac_func(); below. */
@@ -3219,7 +3204,7 @@
; return 0; }
EOF
-if { (eval echo configure:3223: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3208: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_$ac_func=yes"
else
@@ -3245,10 +3230,10 @@
for ac_func in seteuid setpriority setreuid setruid
do
-echo "configure:3249: checking for $ac_func" >&5
+echo "configure:3234: checking for $ac_func" >&5
-#line 3252 "configure"
+#line 3237 "configure"
@@ -3271,7 +3256,7 @@
; return 0; }
EOF
-if { (eval echo configure:3275: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3260: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3297,10 +3282,10 @@
for ac_func in drand48
do
-echo "configure:3301: checking for $ac_func" >&5
+echo "configure:3286: checking for $ac_func" >&5
-#line 3304 "configure"
+#line 3289 "configure"
@@ -3323,7 +3308,7 @@
; return 0; }
EOF
-if { (eval echo configure:3327: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3312: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3349,10 +3334,10 @@
for ac_func in putenv setenv
do
-echo "configure:3353: checking for $ac_func" >&5
+echo "configure:3338: checking for $ac_func" >&5
-#line 3356 "configure"
+#line 3341 "configure"
@@ -3375,7 +3360,7 @@
; return 0; }
EOF
-if { (eval echo configure:3379: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3364: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3401,10 +3386,10 @@
for ac_func in nanosleep
do
-echo "configure:3405: checking for $ac_func" >&5
+echo "configure:3390: checking for $ac_func" >&5
-#line 3408 "configure"
+#line 3393 "configure"
@@ -3427,7 +3412,7 @@
; return 0; }
EOF
-if { (eval echo configure:3431: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3416: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3452,13 +3437,13 @@
if test "$cross_compiling" != "yes" ; then
echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:3456: checking whether setpgrp takes no argument" >&5
+echo "configure:3441: checking whether setpgrp takes no argument" >&5
{ echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
else
-#line 3462 "configure"
+#line 3447 "configure"
#ifdef HAVE_UNISTD_H
@@ -3478,7 +3463,7 @@
EOF
-if { (eval echo configure:3482: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3467: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
ac_cv_func_setpgrp_void=no
else
@@ -3506,16 +3491,16 @@
fi
echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:3510: checking for long long int" >&5
+echo "configure:3495: checking for long long int" >&5
-#line 3512 "configure"
+#line 3497 "configure"
int main() {
long long int x;
; return 0; }
EOF
-if { (eval echo configure:3519: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3504: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
@@ -3535,7 +3520,7 @@
rm -f conftest*
echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:3539: checking for W11" >&5
+echo "configure:3524: checking for W11" >&5
case "$enable_w11" in
yes|no) echo "$ac_t"""$enable_w11"" 1>&6 ;;
*) { echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; } ;;
@@ -3563,7 +3548,7 @@
# Uses ac_ vars as temps to allow command line to override cache and checks.
# --without-x overrides everything else, but does not touch the cache.
echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:3567: checking for X" >&5
+echo "configure:3552: checking for X" >&5
# Check whether --with-x or --without-x was given.
if test "${with_x+set}" = set; then
@@ -3623,12 +3608,12 @@
# First, try using that file with no special directory specified.
-#line 3627 "configure"
+#line 3612 "configure"
#include <$x_direct_test_include>
EOF
-{ (eval echo configure:3632: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3617: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3697,14 +3682,14 @@
LIBS="-l$x_direct_test_library $LIBS"
-#line 3701 "configure"
+#line 3686 "configure"
int main() {
${x_direct_test_function}()
; return 0; }
EOF
-if { (eval echo configure:3708: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3693: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LIBS="$ac_save_LIBS"
# We can link X programs with no special library path.
@@ -3809,17 +3794,17 @@
case "`(uname -sr) 2>/dev/null`" in
"SunOS 5"*)
echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:3813: checking whether -R must be followed by a space" >&5
+echo "configure:3798: checking whether -R must be followed by a space" >&5
ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 3816 "configure"
+#line 3801 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:3823: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3808: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_nospace=yes
else
@@ -3835,14 +3820,14 @@
else
LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 3839 "configure"
+#line 3824 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:3846: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3831: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_space=yes
else
@@ -3874,13 +3859,13 @@
# libraries were built with DECnet support. And karl at cs.umb.edu says
# the Alpha needs dnet_stub (dnet does not exist).
echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:3878: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:3863: checking for dnet_ntoa in -ldnet" >&5
ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet $LIBS"
-#line 3884 "configure"
+#line 3869 "configure"
@@ -3891,7 +3876,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:3895: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3880: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3912,13 +3897,13 @@
if test $ac_cv_lib_dnet_dnet_ntoa = no; then
echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:3916: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:3901: checking for dnet_ntoa in -ldnet_stub" >&5
ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet_stub $LIBS"
-#line 3922 "configure"
+#line 3907 "configure"
@@ -3929,7 +3914,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:3933: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3918: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3957,10 +3942,10 @@
# The nsl library prevents programs from opening the X display
# on Irix 5.2, according to dickey at clark.net.
echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:3961: checking for gethostbyname" >&5
+echo "configure:3946: checking for gethostbyname" >&5
-#line 3964 "configure"
+#line 3949 "configure"
which can conflict with char gethostbyname(); below. */
@@ -3983,7 +3968,7 @@
; return 0; }
EOF
-if { (eval echo configure:3987: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3972: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gethostbyname=yes"
else
@@ -4003,13 +3988,13 @@
if test $ac_cv_func_gethostbyname = no; then
echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:4007: checking for gethostbyname in -lnsl" >&5
+echo "configure:3992: checking for gethostbyname in -lnsl" >&5
ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 4013 "configure"
+#line 3998 "configure"
@@ -4020,7 +4005,7 @@
gethostbyname()
; return 0; }
EOF
-if { (eval echo configure:4024: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4009: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4049,10 +4034,10 @@
# -lsocket must be given before -lnsl if both are needed.
# We assume that if connect needs -lnsl, so does gethostbyname.
echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:4053: checking for connect" >&5
+echo "configure:4038: checking for connect" >&5
-#line 4056 "configure"
+#line 4041 "configure"
which can conflict with char connect(); below. */
@@ -4075,7 +4060,7 @@
; return 0; }
EOF
-if { (eval echo configure:4079: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4064: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_connect=yes"
else
@@ -4095,13 +4080,13 @@
if test $ac_cv_func_connect = no; then
echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:4099: checking for connect in -lsocket" >&5
+echo "configure:4084: checking for connect in -lsocket" >&5
ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 4105 "configure"
+#line 4090 "configure"
@@ -4112,7 +4097,7 @@
connect()
; return 0; }
EOF
-if { (eval echo configure:4116: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4101: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4135,10 +4120,10 @@
# gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:4139: checking for remove" >&5
+echo "configure:4124: checking for remove" >&5
-#line 4142 "configure"
+#line 4127 "configure"
which can conflict with char remove(); below. */
@@ -4161,7 +4146,7 @@
; return 0; }
EOF
-if { (eval echo configure:4165: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4150: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_remove=yes"
else
@@ -4181,13 +4166,13 @@
if test $ac_cv_func_remove = no; then
echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:4185: checking for remove in -lposix" >&5
+echo "configure:4170: checking for remove in -lposix" >&5
ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
LIBS="-lposix $LIBS"
-#line 4191 "configure"
+#line 4176 "configure"
@@ -4198,7 +4183,7 @@
remove()
; return 0; }
EOF
-if { (eval echo configure:4202: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4187: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4221,10 +4206,10 @@
# BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:4225: checking for shmat" >&5
+echo "configure:4210: checking for shmat" >&5
-#line 4228 "configure"
+#line 4213 "configure"
which can conflict with char shmat(); below. */
@@ -4247,7 +4232,7 @@
; return 0; }
EOF
-if { (eval echo configure:4251: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4236: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_shmat=yes"
else
@@ -4267,13 +4252,13 @@
if test $ac_cv_func_shmat = no; then
echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:4271: checking for shmat in -lipc" >&5
+echo "configure:4256: checking for shmat in -lipc" >&5
ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
LIBS="-lipc $LIBS"
-#line 4277 "configure"
+#line 4262 "configure"
@@ -4284,7 +4269,7 @@
shmat()
; return 0; }
EOF
-if { (eval echo configure:4288: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4273: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4316,13 +4301,13 @@
# libraries we check for below, so use a different variable.
# --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:4320: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:4305: checking for IceConnectionNumber in -lICE" >&5
ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 4326 "configure"
+#line 4311 "configure"
@@ -4333,7 +4318,7 @@
IceConnectionNumber()
; return 0; }
EOF
-if { (eval echo configure:4337: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4322: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4373,12 +4358,12 @@
LIBS=""
echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:4377: checking for library containing cuserid" >&5
+echo "configure:4362: checking for library containing cuserid" >&5
ac_func_search_save_LIBS="$LIBS"
ac_cv_search_cuserid="no"
-#line 4382 "configure"
+#line 4367 "configure"
@@ -4389,7 +4374,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:4393: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4378: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="none required"
else
@@ -4400,7 +4385,7 @@
test "$ac_cv_search_cuserid" = "no" && for i in compat; do
LIBS="-l$i $ac_func_search_save_LIBS"
-#line 4404 "configure"
+#line 4389 "configure"
@@ -4411,7 +4396,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:4415: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4400: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="-l$i"
break
@@ -4437,10 +4422,10 @@
# Note: -lxdr -liberty -lws2_32 is for MinGW
echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:4441: checking for xdrmem_create" >&5
+echo "configure:4426: checking for xdrmem_create" >&5
-#line 4444 "configure"
+#line 4429 "configure"
which can conflict with char xdrmem_create(); below. */
@@ -4463,7 +4448,7 @@
; return 0; }
EOF
-if { (eval echo configure:4467: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4452: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_xdrmem_create=yes"
else
@@ -4481,13 +4466,13 @@
echo "$ac_t""no" 1>&6
echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:4485: checking for xdrmem_create in -lsun" >&5
+echo "configure:4470: checking for xdrmem_create in -lsun" >&5
ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lsun $LIBS"
-#line 4491 "configure"
+#line 4476 "configure"
@@ -4498,7 +4483,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:4502: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4487: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4517,13 +4502,13 @@
echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:4521: checking for xdrmem_create in -lnsl" >&5
+echo "configure:4506: checking for xdrmem_create in -lnsl" >&5
ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 4527 "configure"
+#line 4512 "configure"
@@ -4534,7 +4519,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:4538: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4523: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4553,13 +4538,13 @@
echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:4557: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:4542: checking for xdrmem_create in -lrpclib" >&5
ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lrpclib $LIBS"
-#line 4563 "configure"
+#line 4548 "configure"
@@ -4570,7 +4555,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:4574: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4559: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4589,13 +4574,13 @@
echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:4593: checking for xdrmem_create in -lxdr" >&5
+echo "configure:4578: checking for xdrmem_create in -lxdr" >&5
ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lxdr -liberty -lws2_32 $LIBS"
-#line 4599 "configure"
+#line 4584 "configure"
@@ -4606,7 +4591,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:4610: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4595: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4640,10 +4625,10 @@
for ac_func in asprintf
do
-echo "configure:4644: checking for $ac_func" >&5
+echo "configure:4629: checking for $ac_func" >&5
-#line 4647 "configure"
+#line 4632 "configure"
@@ -4666,7 +4651,7 @@
; return 0; }
EOF
-if { (eval echo configure:4670: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4655: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4693,10 +4678,10 @@
# Test if mathlib needs -lm flag or is included with libc
echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:4697: checking for atan" >&5
+echo "configure:4682: checking for atan" >&5
-#line 4700 "configure"
+#line 4685 "configure"
which can conflict with char atan(); below. */
@@ -4719,7 +4704,7 @@
; return 0; }
EOF
-if { (eval echo configure:4723: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4708: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_atan=yes"
else
@@ -4737,13 +4722,13 @@
echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:4741: checking for atan in -lm" >&5
+echo "configure:4726: checking for atan in -lm" >&5
ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
LIBS="-lm $LIBS"
-#line 4747 "configure"
+#line 4732 "configure"
@@ -4754,7 +4739,7 @@
atan()
; return 0; }
EOF
-if { (eval echo configure:4758: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4743: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4781,10 +4766,10 @@
echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:4785: checking for dlsym" >&5
+echo "configure:4770: checking for dlsym" >&5
-#line 4788 "configure"
+#line 4773 "configure"
which can conflict with char dlsym(); below. */
@@ -4807,7 +4792,7 @@
; return 0; }
EOF
-if { (eval echo configure:4811: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4796: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dlsym=yes"
else
@@ -4825,13 +4810,13 @@
echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:4829: checking for dlsym in -ldl" >&5
+echo "configure:4814: checking for dlsym in -ldl" >&5
ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
LIBS="-ldl $LIBS"
-#line 4835 "configure"
+#line 4820 "configure"
@@ -4842,7 +4827,7 @@
dlsym()
; return 0; }
EOF
-if { (eval echo configure:4846: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4831: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4869,10 +4854,10 @@
echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:4873: checking for iconv" >&5
+echo "configure:4858: checking for iconv" >&5
-#line 4876 "configure"
+#line 4861 "configure"
which can conflict with char iconv(); below. */
@@ -4895,7 +4880,7 @@
; return 0; }
EOF
-if { (eval echo configure:4899: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4884: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_iconv=yes"
else
@@ -4913,13 +4898,13 @@
echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:4917: checking for iconv in -liconv" >&5
+echo "configure:4902: checking for iconv in -liconv" >&5
ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-liconv $LIBS"
-#line 4923 "configure"
+#line 4908 "configure"
@@ -4930,7 +4915,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:4934: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4919: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4949,13 +4934,13 @@
echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:4953: checking for iconv in -lgiconv" >&5
+echo "configure:4938: checking for iconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-lgiconv $LIBS"
-#line 4959 "configure"
+#line 4944 "configure"
@@ -4966,7 +4951,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:4970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4955: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4985,10 +4970,10 @@
echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:4989: checking for libiconv" >&5
+echo "configure:4974: checking for libiconv" >&5
-#line 4992 "configure"
+#line 4977 "configure"
which can conflict with char libiconv(); below. */
@@ -5011,7 +4996,7 @@
; return 0; }
EOF
-if { (eval echo configure:5015: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5000: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_libiconv=yes"
else
@@ -5029,13 +5014,13 @@
echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:5033: checking for libiconv in -liconv" >&5
+echo "configure:5018: checking for libiconv in -liconv" >&5
ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 5039 "configure"
+#line 5024 "configure"
@@ -5046,7 +5031,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:5050: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5035: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5065,13 +5050,13 @@
echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:5069: checking for libiconv in -lgiconv" >&5
+echo "configure:5054: checking for libiconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 5075 "configure"
+#line 5060 "configure"
@@ -5082,7 +5067,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:5086: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5071: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5119,10 +5104,10 @@
have_socket=1
echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:5123: checking for socket" >&5
+echo "configure:5108: checking for socket" >&5
-#line 5126 "configure"
+#line 5111 "configure"
which can conflict with char socket(); below. */
@@ -5145,7 +5130,7 @@
; return 0; }
EOF
-if { (eval echo configure:5149: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5134: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_socket=yes"
else
@@ -5163,13 +5148,13 @@
echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:5167: checking for socket in -lsocket" >&5
+echo "configure:5152: checking for socket in -lsocket" >&5
ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
LIBS="-lsocket $LIBS"
-#line 5173 "configure"
+#line 5158 "configure"
@@ -5180,7 +5165,7 @@
socket()
; return 0; }
EOF
-if { (eval echo configure:5184: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5169: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5228,7 +5213,7 @@
echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:5232: checking for location of zlib includes" >&5
+echo "configure:5217: checking for location of zlib includes" >&5
case "$with_zlib_includes" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -5254,15 +5239,15 @@
do
-echo "configure:5258: checking for $ac_hdr" >&5
+echo "configure:5243: checking for $ac_hdr" >&5
-#line 5261 "configure"
+#line 5246 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5266: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5251: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5296,7 +5281,7 @@
echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:5300: checking for location of zlib library" >&5
+echo "configure:5285: checking for location of zlib library" >&5
case "$with_zlib_libs" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -5321,13 +5306,13 @@
echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:5325: checking for deflate in -lz" >&5
+echo "configure:5310: checking for deflate in -lz" >&5
ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
LIBS="-lz $LIBS"
-#line 5331 "configure"
+#line 5316 "configure"
@@ -5338,7 +5323,7 @@
deflate()
; return 0; }
EOF
-if { (eval echo configure:5342: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5327: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5386,7 +5371,7 @@
echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:5390: checking for location of External PROJ.4 includes" >&5
+echo "configure:5375: checking for location of External PROJ.4 includes" >&5
case "$with_proj_includes" in
{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -5412,15 +5397,15 @@
do
-echo "configure:5416: checking for $ac_hdr" >&5
+echo "configure:5401: checking for $ac_hdr" >&5
-#line 5419 "configure"
+#line 5404 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5424: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5409: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5457,7 +5442,7 @@
else
echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:5461: checking External PROJ.4 version" >&5
+echo "configure:5446: checking External PROJ.4 version" >&5
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -5465,7 +5450,7 @@
else
-#line 5469 "configure"
+#line 5454 "configure"
#include <stdio.h>
@@ -5477,7 +5462,7 @@
EOF
-if { (eval echo configure:5481: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:5466: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
proj_ver=`cat conftestdata`
echo "$ac_t""$proj_ver" 1>&6
@@ -5502,7 +5487,7 @@
echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:5506: checking for location of External PROJ.4 library" >&5
+echo "configure:5491: checking for location of External PROJ.4 library" >&5
case "$with_proj_libs" in
{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -5527,13 +5512,13 @@
echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:5531: checking for pj_get_def in -lproj" >&5
+echo "configure:5516: checking for pj_get_def in -lproj" >&5
ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
LIBS="-lproj $LIBS"
-#line 5537 "configure"
+#line 5522 "configure"
@@ -5544,7 +5529,7 @@
pj_get_def()
; return 0; }
EOF
-if { (eval echo configure:5548: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5533: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5578,7 +5563,7 @@
echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:5582: checking for location of External PROJ.4 data files" >&5
+echo "configure:5567: checking for location of External PROJ.4 data files" >&5
case "$with_proj_share" in
{ echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -5602,14 +5587,14 @@
# LOC_CHECK_SHARE does not work when cross compiling
if test "$cross_compiling" = "yes" ; then
echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:5606: checking for epsg" >&5
+echo "configure:5591: checking for epsg" >&5
else
ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:5613: checking for $PROJSHARE/epsg" >&5
+echo "configure:5598: checking for $PROJSHARE/epsg" >&5
@@ -5641,7 +5626,7 @@
# Extract the first word of "nad2bin", so it can be a program name with args.
set dummy nad2bin; ac_word=$2
-echo "configure:5645: checking for $ac_word" >&5
+echo "configure:5630: checking for $ac_word" >&5
case "$NAD2BIN" in
@@ -5681,7 +5666,7 @@
echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:5685: checking whether to use regex" >&5
+echo "configure:5670: checking whether to use regex" >&5
echo "$ac_t"""$with_regex"" 1>&6
case "$with_regex" in
"no") USE_REGEX= ;;
@@ -5701,7 +5686,7 @@
echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:5705: checking for location of regex includes" >&5
+echo "configure:5690: checking for location of regex includes" >&5
case "$with_regex_includes" in
{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -5727,15 +5712,15 @@
do
-echo "configure:5731: checking for $ac_hdr" >&5
+echo "configure:5716: checking for $ac_hdr" >&5
-#line 5734 "configure"
+#line 5719 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5739: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5724: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5769,7 +5754,7 @@
echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:5773: checking for location of regex library" >&5
+echo "configure:5758: checking for location of regex library" >&5
case "$with_regex_libs" in
{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -5794,10 +5779,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:5798: checking for regcomp" >&5
+echo "configure:5783: checking for regcomp" >&5
-#line 5801 "configure"
+#line 5786 "configure"
which can conflict with char regcomp(); below. */
@@ -5820,7 +5805,7 @@
; return 0; }
EOF
-if { (eval echo configure:5824: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5809: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_regcomp=yes"
else
@@ -5847,13 +5832,13 @@
echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:5851: checking for regcomp in -lregex" >&5
+echo "configure:5836: checking for regcomp in -lregex" >&5
ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
LIBS="-lregex $LIBS"
-#line 5857 "configure"
+#line 5842 "configure"
@@ -5864,7 +5849,7 @@
regcomp()
; return 0; }
EOF
-if { (eval echo configure:5868: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5853: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5914,7 +5899,7 @@
echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:5918: checking whether to use Readline" >&5
+echo "configure:5903: checking whether to use Readline" >&5
echo "$ac_t"""$with_readline"" 1>&6
case "$with_readline" in
"no") USE_READLINE= ;;
@@ -5935,7 +5920,7 @@
echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:5939: checking for location of Readline includes" >&5
+echo "configure:5924: checking for location of Readline includes" >&5
case "$with_readline_includes" in
{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -5961,15 +5946,15 @@
do
-echo "configure:5965: checking for $ac_hdr" >&5
+echo "configure:5950: checking for $ac_hdr" >&5
-#line 5968 "configure"
+#line 5953 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5973: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5958: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6005,15 +5990,15 @@
do
-echo "configure:6009: checking for $ac_hdr" >&5
+echo "configure:5994: checking for $ac_hdr" >&5
-#line 6012 "configure"
+#line 5997 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6017: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6002: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6047,7 +6032,7 @@
echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:6051: checking for location of Readline library" >&5
+echo "configure:6036: checking for location of Readline library" >&5
case "$with_readline_libs" in
{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -6072,13 +6057,13 @@
echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:6076: checking for readline in -lreadline" >&5
+echo "configure:6061: checking for readline in -lreadline" >&5
ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
LIBS="-lreadline $LIBS"
-#line 6082 "configure"
+#line 6067 "configure"
@@ -6089,7 +6074,7 @@
readline()
; return 0; }
EOF
-if { (eval echo configure:6093: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6078: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6124,13 +6109,13 @@
echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:6128: checking for add_history in -lhistory" >&5
+echo "configure:6113: checking for add_history in -lhistory" >&5
ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
LIBS="-lhistory $LIBS"
-#line 6134 "configure"
+#line 6119 "configure"
@@ -6141,7 +6126,7 @@
add_history()
; return 0; }
EOF
-if { (eval echo configure:6145: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6130: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6184,7 +6169,7 @@
echo $ac_n "checking whether to use JPEG""... $ac_c" 1>&6
-echo "configure:6188: checking whether to use JPEG" >&5
+echo "configure:6173: checking whether to use JPEG" >&5
echo "$ac_t"""$with_jpeg"" 1>&6
case "$with_jpeg" in
"no") USE_JPEG= ;;
@@ -6204,7 +6189,7 @@
echo $ac_n "checking for location of JPEG includes""... $ac_c" 1>&6
-echo "configure:6208: checking for location of JPEG includes" >&5
+echo "configure:6193: checking for location of JPEG includes" >&5
case "$with_jpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-jpeg-includes." 1>&2; exit 1; }
@@ -6230,15 +6215,15 @@
do
-echo "configure:6234: checking for $ac_hdr" >&5
+echo "configure:6219: checking for $ac_hdr" >&5
-#line 6237 "configure"
+#line 6222 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6242: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6227: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6272,7 +6257,7 @@
echo $ac_n "checking for location of JPEG library""... $ac_c" 1>&6
-echo "configure:6276: checking for location of JPEG library" >&5
+echo "configure:6261: checking for location of JPEG library" >&5
case "$with_jpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-jpeg-libs." 1>&2; exit 1; }
@@ -6299,13 +6284,13 @@
echo $ac_n "checking for jpeg_start_compress in -ljpeg""... $ac_c" 1>&6
-echo "configure:6303: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:6288: checking for jpeg_start_compress in -ljpeg" >&5
ac_lib_var=`echo jpeg'_'jpeg_start_compress | sed 'y%./+-%__p_%'`
LIBS="-ljpeg $LIBS"
-#line 6309 "configure"
+#line 6294 "configure"
@@ -6316,7 +6301,7 @@
jpeg_start_compress()
; return 0; }
EOF
-if { (eval echo configure:6320: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6305: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6335,13 +6320,13 @@
-echo "configure:6339: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:6324: checking for jpeg_start_compress in -ljpeg" >&5
LIBS="-ljpeg $ZLIB $LIBS"
-#line 6345 "configure"
+#line 6330 "configure"
@@ -6352,7 +6337,7 @@
; return 0; }
EOF
-if { (eval echo configure:6356: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6341: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6401,7 +6386,7 @@
# GDAL option
echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:6405: checking whether to use GDAL" >&5
+echo "configure:6390: checking whether to use GDAL" >&5
GDAL_LIBS=
GDAL_CFLAGS=
@@ -6419,7 +6404,7 @@
# Extract the first word of "gdal-config", so it can be a program name with args.
set dummy gdal-config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:6423: checking for $ac_word" >&5
+echo "configure:6408: checking for $ac_word" >&5
case "$GDAL_CONFIG" in
@@ -6474,14 +6459,14 @@
LIBS="$LIBS $GDAL_LIBS"
CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 6478 "configure"
+#line 6463 "configure"
#include <gdal.h>
int main() {
GDALOpen("foo", GA_ReadOnly);
; return 0; }
EOF
-if { (eval echo configure:6485: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6470: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
echo "configure: failed program was:" >&5
@@ -6490,14 +6475,14 @@
LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 6494 "configure"
+#line 6479 "configure"
#include "confdefs.h"
#include <gdal.h>
int main() {
; return 0; }
EOF
-if { (eval echo configure:6501: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6486: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
else
@@ -6529,7 +6514,7 @@
# GEOS option
echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:6533: checking whether to use GEOS" >&5
+echo "configure:6518: checking whether to use GEOS" >&5
GEOS_LIBS=
GGEOS_CFLAGS=
@@ -6547,7 +6532,7 @@
# Extract the first word of "geos-config", so it can be a program name with args.
set dummy geos-config; ac_word=$2
-echo "configure:6551: checking for $ac_word" >&5
+echo "configure:6536: checking for $ac_word" >&5
case "$GEOS_CONFIG" in
@@ -6595,15 +6580,15 @@
do
-echo "configure:6599: checking for $ac_hdr" >&5
+echo "configure:6584: checking for $ac_hdr" >&5
-#line 6602 "configure"
+#line 6587 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6607: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6592: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6638,13 +6623,13 @@
echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:6642: checking for initGEOS in -lgeos_c" >&5
+echo "configure:6627: checking for initGEOS in -lgeos_c" >&5
ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
LIBS="-lgeos_c $LIBS"
-#line 6648 "configure"
+#line 6633 "configure"
@@ -6655,7 +6640,7 @@
initGEOS()
; return 0; }
EOF
-if { (eval echo configure:6659: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6644: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6698,7 +6683,7 @@
echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:6702: checking whether to use TIFF" >&5
+echo "configure:6687: checking whether to use TIFF" >&5
echo "$ac_t"""$with_tiff"" 1>&6
case "$with_tiff" in
"no") USE_TIFF= ;;
@@ -6718,7 +6703,7 @@
echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:6722: checking for location of TIFF includes" >&5
+echo "configure:6707: checking for location of TIFF includes" >&5
case "$with_tiff_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -6744,15 +6729,15 @@
do
-echo "configure:6748: checking for $ac_hdr" >&5
+echo "configure:6733: checking for $ac_hdr" >&5
cat > conftest.$ac_ext <<EOF
-#line 6751 "configure"
+#line 6736 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6756: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6741: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6786,7 +6771,7 @@
echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:6790: checking for location of TIFF library" >&5
+echo "configure:6775: checking for location of TIFF library" >&5
case "$with_tiff_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -6817,13 +6802,13 @@
echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:6821: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6806: checking for TIFFOpen in -ltiff" >&5
ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
LIBS="-ltiff $LIBS"
-#line 6827 "configure"
+#line 6812 "configure"
@@ -6834,7 +6819,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6838: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6823: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6853,13 +6838,13 @@
-echo "configure:6857: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6842: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $MATHLIB $LIBS"
-#line 6863 "configure"
+#line 6848 "configure"
@@ -6870,7 +6855,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6874: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6859: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6889,13 +6874,13 @@
-echo "configure:6893: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6878: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $LIBS"
-#line 6899 "configure"
+#line 6884 "configure"
@@ -6906,7 +6891,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6910: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6895: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6925,13 +6910,13 @@
-echo "configure:6929: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6914: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 6935 "configure"
+#line 6920 "configure"
@@ -6942,7 +6927,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6946: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6931: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6961,13 +6946,13 @@
-echo "configure:6965: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6950: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 6971 "configure"
+#line 6956 "configure"
@@ -6978,7 +6963,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6982: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6967: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6997,13 +6982,13 @@
-echo "configure:7001: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6986: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 7007 "configure"
+#line 6992 "configure"
@@ -7014,7 +6999,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7018: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7003: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7033,13 +7018,13 @@
-echo "configure:7037: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7022: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 7043 "configure"
+#line 7028 "configure"
@@ -7050,7 +7035,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7054: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7039: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7069,13 +7054,13 @@
-echo "configure:7073: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7058: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 7079 "configure"
+#line 7064 "configure"
@@ -7086,7 +7071,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7090: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7184,7 +7169,7 @@
echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:7188: checking whether to use PNG" >&5
+echo "configure:7173: checking whether to use PNG" >&5
echo "$ac_t"""$with_png"" 1>&6
case "$with_png" in
"no") USE_PNG= ;;
@@ -7203,7 +7188,7 @@
echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:7207: checking for location of PNG includes" >&5
+echo "configure:7192: checking for location of PNG includes" >&5
case "$with_png_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -7229,15 +7214,15 @@
do
-echo "configure:7233: checking for $ac_hdr" >&5
+echo "configure:7218: checking for $ac_hdr" >&5
-#line 7236 "configure"
+#line 7221 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7241: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7226: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7271,7 +7256,7 @@
echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:7275: checking for location of PNG library" >&5
+echo "configure:7260: checking for location of PNG library" >&5
case "$with_png_libs" in
{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -7296,13 +7281,13 @@
echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:7300: checking for png_read_image in -lpng" >&5
+echo "configure:7285: checking for png_read_image in -lpng" >&5
ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 7306 "configure"
+#line 7291 "configure"
@@ -7313,7 +7298,7 @@
png_read_image()
; return 0; }
EOF
-if { (eval echo configure:7317: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7302: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7355,7 +7340,7 @@
echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:7359: checking whether to use PostgreSQL" >&5
+echo "configure:7344: checking whether to use PostgreSQL" >&5
echo "$ac_t"""$with_postgres"" 1>&6
case "$with_postgres" in
"no") USE_POSTGRES= ;;
@@ -7382,7 +7367,7 @@
echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:7386: checking for location of PostgreSQL includes" >&5
+echo "configure:7371: checking for location of PostgreSQL includes" >&5
case "$with_postgres_includes" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -7408,15 +7393,15 @@
do
-echo "configure:7412: checking for $ac_hdr" >&5
+echo "configure:7397: checking for $ac_hdr" >&5
-#line 7415 "configure"
+#line 7400 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7420: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7405: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7454,7 +7439,7 @@
echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:7458: checking for location of PostgreSQL library" >&5
+echo "configure:7443: checking for location of PostgreSQL library" >&5
case "$with_postgres_libs" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -7483,13 +7468,13 @@
echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:7487: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7472: checking for PQsetdbLogin in -lpq" >&5
ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lpq $LIBS"
-#line 7493 "configure"
+#line 7478 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -7500,7 +7485,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7504: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7489: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -7519,13 +7504,13 @@
-echo "configure:7523: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7508: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 7529 "configure"
+#line 7514 "configure"
@@ -7536,7 +7521,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7540: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7525: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7555,13 +7540,13 @@
-echo "configure:7559: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7544: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt $LIBS"
-#line 7565 "configure"
+#line 7550 "configure"
@@ -7572,7 +7557,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7576: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7561: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7591,13 +7576,13 @@
-echo "configure:7595: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7580: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 7601 "configure"
+#line 7586 "configure"
@@ -7608,7 +7593,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7612: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7597: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7665,13 +7650,13 @@
ac_save_ldflags="$LDFLAGS"
LDFLAGS="$LDFLAGS $PQLIBPATH"
echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:7669: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7654: checking for PQcmdTuples in -lpq" >&5
ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 7675 "configure"
+#line 7660 "configure"
@@ -7682,7 +7667,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:7686: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7671: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7704,13 +7689,13 @@
-echo "configure:7708: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7693: checking for PQcmdTuples in -lpq" >&5
-#line 7714 "configure"
+#line 7699 "configure"
@@ -7721,7 +7706,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:7725: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7710: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7764,7 +7749,7 @@
echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:7768: checking whether to use MySQL" >&5
+echo "configure:7753: checking whether to use MySQL" >&5
echo "$ac_t"""$with_mysql"" 1>&6
case "$with_mysql" in
"no") USE_MYSQL= ;;
@@ -7784,7 +7769,7 @@
echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:7788: checking for location of MySQL includes" >&5
+echo "configure:7773: checking for location of MySQL includes" >&5
case "$with_mysql_includes" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -7810,15 +7795,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:7814: checking for $ac_hdr" >&5
+echo "configure:7799: checking for $ac_hdr" >&5
-#line 7817 "configure"
+#line 7802 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7822: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7807: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -7855,7 +7840,7 @@
echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:7859: checking for location of MySQL library" >&5
+echo "configure:7844: checking for location of MySQL library" >&5
case "$with_mysql_libs" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -7886,13 +7871,13 @@
echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:7890: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7875: checking for mysql_query in -lmysqlclient" >&5
ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
LIBS="-lmysqlclient $LIBS"
-#line 7896 "configure"
+#line 7881 "configure"
@@ -7903,7 +7888,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7907: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7892: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7922,13 +7907,13 @@
-echo "configure:7926: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7911: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 7932 "configure"
+#line 7917 "configure"
@@ -7939,7 +7924,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7943: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7928: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7958,13 +7943,13 @@
-echo "configure:7962: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7947: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 7968 "configure"
+#line 7953 "configure"
@@ -7975,7 +7960,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7979: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7964: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7994,13 +7979,13 @@
-echo "configure:7998: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7983: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 8004 "configure"
+#line 7989 "configure"
@@ -8011,7 +7996,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8015: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8000: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8030,13 +8015,13 @@
-echo "configure:8034: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8019: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 8040 "configure"
+#line 8025 "configure"
@@ -8047,7 +8032,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8051: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8036: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8066,13 +8051,13 @@
-echo "configure:8070: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8055: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 8076 "configure"
+#line 8061 "configure"
@@ -8083,7 +8068,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8087: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8072: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8102,13 +8087,13 @@
-echo "configure:8106: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8091: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 8112 "configure"
+#line 8097 "configure"
@@ -8119,7 +8104,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8123: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8108: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8138,13 +8123,13 @@
-echo "configure:8142: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8127: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 8148 "configure"
+#line 8133 "configure"
@@ -8155,7 +8140,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8159: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8144: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8245,7 +8230,7 @@
# Extract the first word of "mysql_config", so it can be a program name with args.
set dummy mysql_config; ac_word=$2
-echo "configure:8249: checking for $ac_word" >&5
+echo "configure:8234: checking for $ac_word" >&5
case "$MYSQLD_CONFIG" in
@@ -8294,10 +8279,10 @@
LIBS="$MYSQLDLIB $LIBS"
echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:8298: checking for mysql_server_init" >&5
+echo "configure:8283: checking for mysql_server_init" >&5
-#line 8301 "configure"
+#line 8286 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char mysql_server_init(); below. */
@@ -8323,7 +8308,7 @@
; return 0; }
EOF
-if { (eval echo configure:8327: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8312: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_mysql_server_init=yes"
else
@@ -8375,7 +8360,7 @@
echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:8379: checking whether to use SQLite" >&5
+echo "configure:8364: checking whether to use SQLite" >&5
echo "$ac_t"""$with_sqlite"" 1>&6
case "$with_sqlite" in
"no") USE_SQLITE= ;;
@@ -8395,7 +8380,7 @@
echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:8399: checking for location of SQLite includes" >&5
+echo "configure:8384: checking for location of SQLite includes" >&5
case "$with_sqlite_includes" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -8421,15 +8406,15 @@
do
-echo "configure:8425: checking for $ac_hdr" >&5
+echo "configure:8410: checking for $ac_hdr" >&5
-#line 8428 "configure"
+#line 8413 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8433: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8418: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8472,7 +8457,7 @@
echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:8476: checking for location of SQLite library" >&5
+echo "configure:8461: checking for location of SQLite library" >&5
case "$with_sqlite_libs" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -8501,13 +8486,13 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:8505: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8490: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
LIBS="-lsqlite3 $LIBS"
-#line 8511 "configure"
+#line 8496 "configure"
@@ -8518,7 +8503,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8522: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8507: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8537,13 +8522,13 @@
-echo "configure:8541: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8526: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 8547 "configure"
+#line 8532 "configure"
@@ -8554,7 +8539,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8558: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8543: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8573,13 +8558,13 @@
-echo "configure:8577: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8562: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 8583 "configure"
+#line 8568 "configure"
@@ -8590,7 +8575,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8594: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8579: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8609,13 +8594,13 @@
-echo "configure:8613: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8598: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 8619 "configure"
+#line 8604 "configure"
@@ -8626,7 +8611,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8630: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8615: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8695,7 +8680,7 @@
echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:8699: checking whether to use FFMPEG" >&5
+echo "configure:8684: checking whether to use FFMPEG" >&5
echo "$ac_t"""$with_ffmpeg"" 1>&6
case "$with_ffmpeg" in
"no") USE_FFMPEG= ;;
@@ -8715,7 +8700,7 @@
echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:8719: checking for location of FFMPEG includes" >&5
+echo "configure:8704: checking for location of FFMPEG includes" >&5
case "$with_ffmpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -8741,15 +8726,15 @@
do
-echo "configure:8745: checking for $ac_hdr" >&5
+echo "configure:8730: checking for $ac_hdr" >&5
-#line 8748 "configure"
+#line 8733 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8753: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8738: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8785,15 +8770,15 @@
do
-echo "configure:8789: checking for $ac_hdr" >&5
+echo "configure:8774: checking for $ac_hdr" >&5
-#line 8792 "configure"
+#line 8777 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8797: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8782: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8829,15 +8814,15 @@
do
-echo "configure:8833: checking for $ac_hdr" >&5
+echo "configure:8818: checking for $ac_hdr" >&5
-#line 8836 "configure"
+#line 8821 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8841: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8826: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8880,7 +8865,7 @@
echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:8884: checking for location of FFMPEG library" >&5
+echo "configure:8869: checking for location of FFMPEG library" >&5
case "$with_ffmpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -8907,13 +8892,13 @@
echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:8911: checking for av_free in -lavutil" >&5
+echo "configure:8896: checking for av_free in -lavutil" >&5
ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
LIBS="-lavutil $LIBS"
-#line 8917 "configure"
+#line 8902 "configure"
@@ -8924,7 +8909,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:8928: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8913: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8943,13 +8928,13 @@
-echo "configure:8947: checking for av_free in -lavutil" >&5
+echo "configure:8932: checking for av_free in -lavutil" >&5
LIBS="-lavutil $MATHLIB $LIBS"
-#line 8953 "configure"
+#line 8938 "configure"
@@ -8960,7 +8945,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:8964: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8949: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9005,13 +8990,13 @@
echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:9009: checking for avcodec_init in -lavcodec" >&5
+echo "configure:8994: checking for avcodec_init in -lavcodec" >&5
ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
LIBS="-lavcodec $FFMPEGLIB $LIBS"
-#line 9015 "configure"
+#line 9000 "configure"
@@ -9022,7 +9007,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:9026: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9011: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9041,13 +9026,13 @@
-echo "configure:9045: checking for avcodec_init in -lavcodec" >&5
+echo "configure:9030: checking for avcodec_init in -lavcodec" >&5
LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 9051 "configure"
+#line 9036 "configure"
@@ -9058,7 +9043,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:9062: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9047: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9103,13 +9088,13 @@
echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:9107: checking for av_set_parameters in -lavformat" >&5
+echo "configure:9092: checking for av_set_parameters in -lavformat" >&5
ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
LIBS="-lavformat $FFMPEGLIB $LIBS"
-#line 9113 "configure"
+#line 9098 "configure"
@@ -9120,7 +9105,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:9124: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9109: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9139,13 +9124,13 @@
-echo "configure:9143: checking for av_set_parameters in -lavformat" >&5
+echo "configure:9128: checking for av_set_parameters in -lavformat" >&5
LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 9149 "configure"
+#line 9134 "configure"
@@ -9156,7 +9141,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:9160: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9145: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9215,7 +9200,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:9219: checking whether to use OpenGL" >&5
+echo "configure:9204: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -9249,7 +9234,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:9253: checking for location of OpenGL includes" >&5
+echo "configure:9238: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -9275,15 +9260,15 @@
do
-echo "configure:9279: checking for $ac_hdr" >&5
+echo "configure:9264: checking for $ac_hdr" >&5
-#line 9282 "configure"
+#line 9267 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9287: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9272: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9317,7 +9302,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:9321: checking for location of OpenGL library" >&5
+echo "configure:9306: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -9346,13 +9331,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:9350: checking for glBegin in -lGL" >&5
+echo "configure:9335: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 9356 "configure"
+#line 9341 "configure"
@@ -9363,7 +9348,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9367: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9352: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9382,13 +9367,13 @@
-echo "configure:9386: checking for glBegin in -lGL" >&5
+echo "configure:9371: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 9392 "configure"
+#line 9377 "configure"
@@ -9399,7 +9384,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9403: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9388: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9418,13 +9403,13 @@
-echo "configure:9422: checking for glBegin in -lGL" >&5
+echo "configure:9407: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 9428 "configure"
+#line 9413 "configure"
@@ -9435,7 +9420,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9439: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9424: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9454,13 +9439,13 @@
-echo "configure:9458: checking for glBegin in -lGL" >&5
+echo "configure:9443: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 9464 "configure"
+#line 9449 "configure"
@@ -9471,7 +9456,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9475: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9460: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9533,13 +9518,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:9537: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9522: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 9543 "configure"
+#line 9528 "configure"
@@ -9550,7 +9535,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:9554: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9539: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9569,13 +9554,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:9573: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9558: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 9579 "configure"
+#line 9564 "configure"
@@ -9586,7 +9571,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:9590: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9575: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9633,10 +9618,10 @@
LIBS=" $OPENGLLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:9637: checking for glXCreatePbuffer" >&5
+echo "configure:9622: checking for glXCreatePbuffer" >&5
-#line 9640 "configure"
+#line 9625 "configure"
which can conflict with char glXCreatePbuffer(); below. */
@@ -9659,7 +9644,7 @@
; return 0; }
EOF
-if { (eval echo configure:9663: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9648: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -9696,10 +9681,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:9700: checking for glXCreateGLXPixmap" >&5
+echo "configure:9685: checking for glXCreateGLXPixmap" >&5
-#line 9703 "configure"
+#line 9688 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -9722,7 +9707,7 @@
; return 0; }
EOF
-if { (eval echo configure:9726: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9711: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -9765,7 +9750,7 @@
echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:9769: checking for location of OpenGL framework" >&5
+echo "configure:9754: checking for location of OpenGL framework" >&5
case "$with_opengl_framework" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -9789,15 +9774,15 @@
do
-echo "configure:9793: checking for $ac_hdr" >&5
+echo "configure:9778: checking for $ac_hdr" >&5
-#line 9796 "configure"
+#line 9781 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9801: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9786: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9833,10 +9818,10 @@
LIBS="-framework OpenGL -framework AGL -framework ApplicationServices $LIBS"
LDFLAGS="$OPENGLPATH $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:9837: checking for glBegin" >&5
+echo "configure:9822: checking for glBegin" >&5
-#line 9840 "configure"
+#line 9825 "configure"
which can conflict with char glBegin(); below. */
@@ -9859,7 +9844,7 @@
; return 0; }
EOF
-if { (eval echo configure:9863: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9848: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -9896,10 +9881,10 @@
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:9900: checking for gluBeginCurve" >&5
+echo "configure:9885: checking for gluBeginCurve" >&5
-#line 9903 "configure"
+#line 9888 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -9922,7 +9907,7 @@
; return 0; }
EOF
-if { (eval echo configure:9926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9911: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -9970,7 +9955,7 @@
-echo "configure:9974: checking for location of OpenGL includes" >&5
+echo "configure:9959: checking for location of OpenGL includes" >&5
@@ -9996,15 +9981,15 @@
do
-echo "configure:10000: checking for $ac_hdr" >&5
+echo "configure:9985: checking for $ac_hdr" >&5
-#line 10003 "configure"
+#line 9988 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10008: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9993: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10038,7 +10023,7 @@
-echo "configure:10042: checking for location of OpenGL library" >&5
+echo "configure:10027: checking for location of OpenGL library" >&5
@@ -10063,18 +10048,18 @@
ac_save_libs="$LIBS"
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:10067: checking for OpenGL library" >&5
+echo "configure:10052: checking for OpenGL library" >&5
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
LIBS="-lopengl32 "
-#line 10071 "configure"
+#line 10056 "configure"
#include <GL/gl.h>
int main() {
glEnd();
; return 0; }
EOF
-if { (eval echo configure:10078: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10063: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
@@ -10098,18 +10083,18 @@
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:10102: checking for GLU library" >&5
+echo "configure:10087: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB "
-#line 10106 "configure"
+#line 10091 "configure"
#include <GL/glu.h>
int main() {
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:10113: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10098: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -10158,7 +10143,7 @@
echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:10162: checking whether to use Tcl/Tk" >&5
+echo "configure:10147: checking whether to use Tcl/Tk" >&5
echo "$ac_t"""$with_tcltk"" 1>&6
case "$with_tcltk" in
"no") USE_TCLTK= ;;
@@ -10178,7 +10163,7 @@
echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:10182: checking for location of Tcl/Tk includes" >&5
+echo "configure:10167: checking for location of Tcl/Tk includes" >&5
case "$with_tcltk_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -10204,15 +10189,15 @@
do
-echo "configure:10208: checking for $ac_hdr" >&5
+echo "configure:10193: checking for $ac_hdr" >&5
-#line 10211 "configure"
+#line 10196 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10216: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10201: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10249,15 +10234,15 @@
do
-echo "configure:10253: checking for $ac_hdr" >&5
+echo "configure:10238: checking for $ac_hdr" >&5
-#line 10256 "configure"
+#line 10241 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10261: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10246: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10291,7 +10276,7 @@
echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:10295: checking Tcl version" >&5
+echo "configure:10280: checking Tcl version" >&5
CPPFLAGS="$TCLINCDIR $CPPFLAGS"
if test "$cross_compiling" = yes; then
@@ -10299,7 +10284,7 @@
echo "$ac_t""unknown (cross-compiling)" 1>&6
else
-#line 10303 "configure"
+#line 10288 "configure"
#include <stdio.h>
@@ -10311,7 +10296,7 @@
EOF
-if { (eval echo configure:10315: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:10300: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tcl_ver=`cat conftestdata`
echo "$ac_t""$tcl_ver" 1>&6
@@ -10329,7 +10314,7 @@
echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:10333: checking Tk version" >&5
+echo "configure:10318: checking Tk version" >&5
CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -10337,7 +10322,7 @@
else
-#line 10341 "configure"
+#line 10326 "configure"
#include <stdio.h>
@@ -10349,7 +10334,7 @@
EOF
-if { (eval echo configure:10353: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:10338: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tk_ver=`cat conftestdata`
echo "$ac_t""$tk_ver" 1>&6
@@ -10378,7 +10363,7 @@
echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:10382: checking for location of Tcl/Tk library" >&5
+echo "configure:10367: checking for location of Tcl/Tk library" >&5
case "$with_tcltk_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -10418,13 +10403,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:10422: checking for Tcl_Init in -ltcl" >&5
+echo "configure:10407: checking for Tcl_Init in -ltcl" >&5
ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl $MATHLIB $LIBS"
-#line 10428 "configure"
+#line 10413 "configure"
@@ -10435,7 +10420,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:10439: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10424: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10454,13 +10439,13 @@
-echo "configure:10458: checking for Tcl_Init in -ltcl" >&5
+echo "configure:10443: checking for Tcl_Init in -ltcl" >&5
LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 10464 "configure"
+#line 10449 "configure"
@@ -10471,7 +10456,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:10475: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10460: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10498,13 +10483,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:10502: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:10487: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 10508 "configure"
+#line 10493 "configure"
@@ -10515,7 +10500,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:10519: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10504: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10534,13 +10519,13 @@
-echo "configure:10538: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:10523: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 10544 "configure"
+#line 10529 "configure"
@@ -10551,7 +10536,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:10555: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10540: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10578,13 +10563,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:10582: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:10567: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 10588 "configure"
+#line 10573 "configure"
@@ -10595,7 +10580,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:10599: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10584: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10614,13 +10599,13 @@
-echo "configure:10618: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:10603: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 10624 "configure"
+#line 10609 "configure"
@@ -10631,7 +10616,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:10635: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10620: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10709,13 +10694,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:10713: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:10698: checking for Tk_MainWindow in -ltk" >&5
ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 10719 "configure"
+#line 10704 "configure"
@@ -10726,7 +10711,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:10730: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10715: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10745,13 +10730,13 @@
-echo "configure:10749: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:10734: checking for Tk_MainWindow in -ltk" >&5
LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 10755 "configure"
+#line 10740 "configure"
@@ -10762,7 +10747,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:10766: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10751: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10789,13 +10774,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:10793: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:10778: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 10799 "configure"
+#line 10784 "configure"
@@ -10806,7 +10791,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:10810: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10795: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10825,13 +10810,13 @@
-echo "configure:10829: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:10814: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 10835 "configure"
+#line 10820 "configure"
@@ -10842,7 +10827,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:10846: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10831: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10869,13 +10854,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:10873: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:10858: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 10879 "configure"
+#line 10864 "configure"
@@ -10886,7 +10871,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:10890: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10875: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10905,13 +10890,13 @@
-echo "configure:10909: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:10894: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 10915 "configure"
+#line 10900 "configure"
@@ -10922,7 +10907,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:10926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10911: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11012,13 +10997,13 @@
do
# add only if in MACOSX_ARCHS
echo $ac_n "checking for Tcl_Init in -l$tlib""... $ac_c" 1>&6
-echo "configure:11016: checking for Tcl_Init in -l$tlib" >&5
+echo "configure:11001: checking for Tcl_Init in -l$tlib" >&5
ac_lib_var=`echo $tlib'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-l$tlib -arch $a $MACOSX_SDK $TCLTKLIBPATH $LIBS"
-#line 11022 "configure"
+#line 11007 "configure"
@@ -11029,7 +11014,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11018: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11079,7 +11064,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:11083: checking whether to use ODBC" >&5
+echo "configure:11068: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -11098,7 +11083,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:11102: checking for location of ODBC includes" >&5
+echo "configure:11087: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -11124,15 +11109,15 @@
do
-echo "configure:11128: checking for $ac_hdr" >&5
+echo "configure:11113: checking for $ac_hdr" >&5
-#line 11131 "configure"
+#line 11116 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11136: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11121: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11166,7 +11151,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:11170: checking for location of ODBC library" >&5
+echo "configure:11155: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -11191,13 +11176,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:11195: checking for SQLConnect in -lodbc" >&5
+echo "configure:11180: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 11201 "configure"
+#line 11186 "configure"
@@ -11208,7 +11193,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:11212: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11197: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11233,13 +11218,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:11237: checking for SQLConnect in -liodbc" >&5
+echo "configure:11222: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 11243 "configure"
+#line 11228 "configure"
@@ -11250,7 +11235,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:11254: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11239: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11275,11 +11260,11 @@
echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:11279: checking for ODBC library" >&5
+echo "configure:11264: checking for ODBC library" >&5
LDFLAGS="$ODBCLIB $LDFLAGS"
LIBS="-lodbc32 "
-#line 11283 "configure"
+#line 11268 "configure"
#include <windows.h>
#include <sql.h>
@@ -11287,7 +11272,7 @@
SQLAllocEnv((SQLHENV *)0);
; return 0; }
EOF
-if { (eval echo configure:11291: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11276: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -11336,7 +11321,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:11340: checking whether to use FFTW" >&5
+echo "configure:11325: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -11355,7 +11340,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:11359: checking for location of FFTW includes" >&5
+echo "configure:11344: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -11381,15 +11366,15 @@
do
-echo "configure:11385: checking for $ac_hdr" >&5
+echo "configure:11370: checking for $ac_hdr" >&5
-#line 11388 "configure"
+#line 11373 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11393: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11378: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11417,15 +11402,15 @@
do
-echo "configure:11421: checking for $ac_hdr" >&5
+echo "configure:11406: checking for $ac_hdr" >&5
-#line 11424 "configure"
+#line 11409 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11429: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11414: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11453,15 +11438,15 @@
do
-echo "configure:11457: checking for $ac_hdr" >&5
+echo "configure:11442: checking for $ac_hdr" >&5
-#line 11460 "configure"
+#line 11445 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11465: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11450: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11507,7 +11492,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:11511: checking for location of FFTW library" >&5
+echo "configure:11496: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -11532,13 +11517,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:11536: checking for fftw_execute in -lfftw3" >&5
+echo "configure:11521: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 11542 "configure"
+#line 11527 "configure"
@@ -11549,7 +11534,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:11553: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11538: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11574,13 +11559,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:11578: checking for fftwnd_one in -lfftw" >&5
+echo "configure:11563: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-lfftw $MATHLIB $LIBS"
-#line 11584 "configure"
+#line 11569 "configure"
@@ -11591,7 +11576,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:11595: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11580: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11616,13 +11601,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:11620: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:11605: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 11626 "configure"
+#line 11611 "configure"
#include "confdefs.h"
@@ -11633,7 +11618,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:11637: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11622: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11690,7 +11675,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:11694: checking whether to use BLAS" >&5
+echo "configure:11679: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -11711,7 +11696,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:11715: checking for location of BLAS includes" >&5
+echo "configure:11700: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -11731,7 +11716,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:11735: checking for location of BLAS library" >&5
+echo "configure:11720: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -11757,15 +11742,15 @@
do
-echo "configure:11761: checking for $ac_hdr" >&5
+echo "configure:11746: checking for $ac_hdr" >&5
-#line 11764 "configure"
+#line 11749 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11769: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11754: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11800,13 +11785,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:11804: checking for dnrm2_ in -lblas" >&5
+echo "configure:11789: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $MATHLIB $LIBS"
-#line 11810 "configure"
+#line 11795 "configure"
@@ -11817,7 +11802,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:11821: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11806: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11836,13 +11821,13 @@
-echo "configure:11840: checking for dnrm2_ in -lblas" >&5
+echo "configure:11825: checking for dnrm2_ in -lblas" >&5
LIBS="-lblas $MATHLIB -lg2c $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 11846 "configure"
+#line 11831 "configure"
@@ -11853,7 +11838,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:11857: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11842: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11897,13 +11882,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:11901: checking for ATL_xerbla in -latlas" >&5
+echo "configure:11886: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 11907 "configure"
+#line 11892 "configure"
@@ -11914,7 +11899,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:11918: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11903: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11929,13 +11914,13 @@
if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
echo "$ac_t""yes" 1>&6
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:11933: checking for sgemm_ in -lf77blas" >&5
+echo "configure:11918: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 11939 "configure"
+#line 11924 "configure"
@@ -11946,7 +11931,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11950: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11935: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11961,13 +11946,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:11965: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:11950: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 11971 "configure"
+#line 11956 "configure"
@@ -11978,7 +11963,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:11982: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11967: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12024,16 +12009,16 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:12028: checking for sgemm in $vlib_flags" >&5
+echo "configure:12013: checking for sgemm in $vlib_flags" >&5
-#line 12030 "configure"
+#line 12015 "configure"
int main() {
sgemm
; return 0; }
EOF
-if { (eval echo configure:12037: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12022: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -12051,13 +12036,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:12055: checking for sgemm_ in -lblas" >&5
+echo "configure:12040: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $LIBS"
-#line 12061 "configure"
+#line 12046 "configure"
@@ -12068,7 +12053,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12072: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12057: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12083,13 +12068,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:12087: checking for dgemm_ in -ldgemm" >&5
+echo "configure:12072: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 12093 "configure"
+#line 12078 "configure"
@@ -12100,7 +12085,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:12104: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12089: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12115,13 +12100,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:12119: checking for sgemm_ in -lsgemm" >&5
+echo "configure:12104: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
-#line 12125 "configure"
+#line 12110 "configure"
@@ -12132,7 +12117,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12136: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12121: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12166,13 +12151,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:12170: checking for acosp in -lsunmath" >&5
+echo "configure:12155: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
LIBS="-lsunmath $LIBS"
-#line 12176 "configure"
+#line 12161 "configure"
@@ -12183,7 +12168,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:12187: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12172: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12198,13 +12183,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:12202: checking for sgemm_ in -lsunperf" >&5
+echo "configure:12187: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
-#line 12208 "configure"
+#line 12193 "configure"
@@ -12215,7 +12200,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12219: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12204: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12245,13 +12230,13 @@
# Generic BLAS library
-echo "configure:12249: checking for sgemm_ in -lblas" >&5
+echo "configure:12234: checking for sgemm_ in -lblas" >&5
LIBS="-lblas $LIBS"
-#line 12255 "configure"
+#line 12240 "configure"
@@ -12262,7 +12247,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12266: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12251: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12301,7 +12286,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:12305: checking whether to use LAPACK" >&5
+echo "configure:12290: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -12326,7 +12311,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:12330: checking for location of LAPACK includes" >&5
+echo "configure:12315: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -12346,7 +12331,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:12350: checking for location of LAPACK library" >&5
+echo "configure:12335: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -12372,15 +12357,15 @@
do
-echo "configure:12376: checking for $ac_hdr" >&5
+echo "configure:12361: checking for $ac_hdr" >&5
-#line 12379 "configure"
+#line 12364 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12384: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12369: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12412,10 +12397,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:12416: checking for dsegv_" >&5
+echo "configure:12401: checking for dsegv_" >&5
-#line 12419 "configure"
+#line 12404 "configure"
which can conflict with char dsegv_(); below. */
@@ -12438,7 +12423,7 @@
; return 0; }
EOF
-if { (eval echo configure:12442: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12427: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -12465,13 +12450,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:12469: checking for desgv_ in -llapack" >&5
+echo "configure:12454: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-llapack $FLIBS $LIBS"
-#line 12475 "configure"
+#line 12460 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -12482,7 +12467,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:12486: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12471: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -12514,13 +12499,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:12518: checking for dgesv_ in -llapack" >&5
+echo "configure:12503: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 12524 "configure"
+#line 12509 "configure"
@@ -12531,7 +12516,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:12535: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12520: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12550,13 +12535,13 @@
-echo "configure:12554: checking for dgesv_ in -llapack" >&5
+echo "configure:12539: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 12560 "configure"
+#line 12545 "configure"
@@ -12567,7 +12552,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:12571: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12556: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12623,7 +12608,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:12627: checking whether to use Cairo" >&5
+echo "configure:12612: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -12649,7 +12634,7 @@
echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:12653: checking for location of cairo includes" >&5
+echo "configure:12638: checking for location of cairo includes" >&5
case "$with_cairo_includes" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -12675,15 +12660,15 @@
do
-echo "configure:12679: checking for $ac_hdr" >&5
+echo "configure:12664: checking for $ac_hdr" >&5
-#line 12682 "configure"
+#line 12667 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12687: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12672: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12719,7 +12704,7 @@
echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:12723: checking for location of cairo library" >&5
+echo "configure:12708: checking for location of cairo library" >&5
case "$with_cairo_libs" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -12739,7 +12724,7 @@
echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:12743: checking for cairo linking flags" >&5
+echo "configure:12728: checking for cairo linking flags" >&5
case "$with_cairo_ldflags" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -12755,10 +12740,10 @@
LIBS=" $CAIROLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:12759: checking for cairo_create" >&5
+echo "configure:12744: checking for cairo_create" >&5
-#line 12762 "configure"
+#line 12747 "configure"
which can conflict with char cairo_create(); below. */
@@ -12781,7 +12766,7 @@
; return 0; }
EOF
-if { (eval echo configure:12785: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12770: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -12815,10 +12800,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:12819: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:12804: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 12822 "configure"
+#line 12807 "configure"
which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below. */
@@ -12841,7 +12826,7 @@
; return 0; }
EOF
-if { (eval echo configure:12845: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12830: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
else
@@ -12874,10 +12859,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:12878: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:12863: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 12881 "configure"
+#line 12866 "configure"
which can conflict with char cairo_xlib_surface_get_xrender_format(); below. */
@@ -12900,7 +12885,7 @@
; return 0; }
EOF
-if { (eval echo configure:12904: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12889: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
else
@@ -12942,7 +12927,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:12946: checking whether to use FreeType" >&5
+echo "configure:12931: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -12961,7 +12946,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:12965: checking for location of FreeType includes" >&5
+echo "configure:12950: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -12987,15 +12972,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:12991: checking for $ac_hdr" >&5
+echo "configure:12976: checking for $ac_hdr" >&5
-#line 12994 "configure"
+#line 12979 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:12999: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12984: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -13029,7 +13014,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:13033: checking for location of FreeType library" >&5
+echo "configure:13018: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -13054,13 +13039,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:13058: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:13043: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 13064 "configure"
+#line 13049 "configure"
@@ -13071,7 +13056,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:13075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13060: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13112,7 +13097,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:13116: checking whether to use NLS" >&5
+echo "configure:13101: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -13132,10 +13117,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:13136: checking for gettext" >&5
+echo "configure:13121: checking for gettext" >&5
-#line 13139 "configure"
+#line 13124 "configure"
which can conflict with char gettext(); below. */
@@ -13158,7 +13143,7 @@
; return 0; }
EOF
-if { (eval echo configure:13162: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13147: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -13176,13 +13161,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:13180: checking for gettext in -lintl" >&5
+echo "configure:13165: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 13186 "configure"
+#line 13171 "configure"
@@ -13193,7 +13178,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:13197: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13182: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13228,7 +13213,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:13232: checking whether to use C++" >&5
+echo "configure:13217: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -13244,7 +13229,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:13248: checking for $ac_word" >&5
+echo "configure:13233: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -13273,7 +13258,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:13277: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:13262: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -13284,12 +13269,12 @@
cat > conftest.$ac_ext << EOF
-#line 13288 "configure"
+#line 13273 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:13293: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13278: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -13315,19 +13300,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:13319: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:13304: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:13324: checking whether we are using GNU C++" >&5
+echo "configure:13309: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:13331: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:13316: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -13345,7 +13330,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:13349: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:13334: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -13386,7 +13371,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:13390: checking whether to use openDWG" >&5
+echo "configure:13375: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -13406,7 +13391,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:13410: checking for location of openDGW includes" >&5
+echo "configure:13395: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -13432,15 +13417,15 @@
do
-echo "configure:13436: checking for $ac_hdr" >&5
+echo "configure:13421: checking for $ac_hdr" >&5
-#line 13439 "configure"
+#line 13424 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13444: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13429: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13474,7 +13459,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:13478: checking for location of openDWG library" >&5
+echo "configure:13463: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -13515,7 +13500,7 @@
echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:13519: checking whether to use POSIX threads" >&5
+echo "configure:13504: checking whether to use POSIX threads" >&5
echo "$ac_t"""$with_pthread"" 1>&6
case "$with_pthread" in
"no") USE_PTHREAD= ;;
@@ -13535,7 +13520,7 @@
echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:13539: checking for location of POSIX threads includes" >&5
+echo "configure:13524: checking for location of POSIX threads includes" >&5
case "$with_pthread_includes" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -13561,15 +13546,15 @@
do
-echo "configure:13565: checking for $ac_hdr" >&5
+echo "configure:13550: checking for $ac_hdr" >&5
-#line 13568 "configure"
+#line 13553 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13573: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13558: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13603,7 +13588,7 @@
echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:13607: checking for location of POSIX threads library" >&5
+echo "configure:13592: checking for location of POSIX threads library" >&5
case "$with_pthread_libs" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -13628,10 +13613,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:13632: checking for pthread_create" >&5
+echo "configure:13617: checking for pthread_create" >&5
-#line 13635 "configure"
+#line 13620 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char pthread_create(); below. */
@@ -13654,7 +13639,7 @@
; return 0; }
EOF
-if { (eval echo configure:13658: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13643: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_pthread_create=yes"
else
@@ -13681,13 +13666,13 @@
echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:13685: checking for pthread_create in -lpthread" >&5
+echo "configure:13670: checking for pthread_create in -lpthread" >&5
ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
LIBS="-lpthread $LIBS"
-#line 13691 "configure"
+#line 13676 "configure"
@@ -13698,7 +13683,7 @@
pthread_create()
; return 0; }
EOF
-if { (eval echo configure:13702: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13687: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13754,7 +13739,7 @@
if test "$enable_largefile" = yes; then
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:13758: checking for special C compiler options needed for large files" >&5
+echo "configure:13743: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -13762,7 +13747,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 13766 "configure"
+#line 13751 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -13778,7 +13763,7 @@
; return 0; }
EOF
-if { (eval echo configure:13782: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13767: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
echo "configure: failed program was:" >&5
@@ -13787,7 +13772,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 13791 "configure"
+#line 13776 "configure"
@@ -13803,7 +13788,7 @@
; return 0; }
EOF
-if { (eval echo configure:13807: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13792: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -13823,11 +13808,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:13827: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:13812: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 13831 "configure"
+#line 13816 "configure"
@@ -13843,14 +13828,14 @@
; return 0; }
EOF
-if { (eval echo configure:13847: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13832: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
cat conftest.$ac_ext >&5
rm -rf conftest*
-#line 13854 "configure"
+#line 13839 "configure"
#define _FILE_OFFSET_BITS 64
@@ -13868,7 +13853,7 @@
; return 0; }
EOF
-if { (eval echo configure:13872: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13857: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -13887,11 +13872,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:13891: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:13876: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 13895 "configure"
+#line 13880 "configure"
@@ -13907,14 +13892,14 @@
; return 0; }
EOF
-if { (eval echo configure:13911: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13896: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13918 "configure"
+#line 13903 "configure"
#define _LARGE_FILES 1
@@ -13932,7 +13917,7 @@
; return 0; }
EOF
-if { (eval echo configure:13936: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13921: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -13951,25 +13936,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:13955: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13940: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 13959 "configure"
+#line 13944 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13966: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13951: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13973 "configure"
+#line 13958 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -13978,7 +13963,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13982: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13967: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -13999,25 +13984,25 @@
fi
-echo "configure:14003: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13988: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 14007 "configure"
+#line 13992 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:14014: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13999: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 14021 "configure"
+#line 14006 "configure"
#include <stdio.h>
@@ -14026,7 +14011,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:14030: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14015: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
else
@@ -14049,18 +14034,18 @@
# If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:14053: checking for fseeko" >&5
+echo "configure:14038: checking for fseeko" >&5
ac_cv_func_fseeko=no
-#line 14057 "configure"
+#line 14042 "configure"
#include <stdio.h>
int main() {
return fseeko && fseeko (stdin, 0, 0);
; return 0; }
EOF
-if { (eval echo configure:14064: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14049: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_func_fseeko=yes
else
@@ -14077,10 +14062,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:14081: checking if system supports Large Files at all" >&5
+echo "configure:14066: checking if system supports Large Files at all" >&5
-#line 14084 "configure"
+#line 14069 "configure"
#include <stdio.h>
@@ -14112,7 +14097,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:14116: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14101: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -14138,191 +14123,10 @@
# Done large file support
-# Python check
-echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:14145: checking whether to use Python" >&5
-PYTHONINC=
-PYTHONCFLAGS=
-PYTHONLDFLAGS=
-SWIG=
-USE_PYTHON=
-MACOSX_ARCHS_PYTHON=
-if test "$with_python" = "no" ; then
- echo "$ac_t""no" 1>&6
-else
- echo "$ac_t""yes" 1>&6
- USE_PYTHON="1"
- if test "$with_python" != "yes" ; then
- PY_CONFIG="$with_python"
- fi
- # Extract the first word of "python-config", so it can be a program name with args.
-set dummy python-config; ac_word=$2
-echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:14166: checking for $ac_word" >&5
-case "$PY_CONFIG" in
- ac_cv_path_PY_CONFIG="$PY_CONFIG" # Let the user override the test with a path.
- ac_cv_path_PY_CONFIG="$PY_CONFIG" # Let the user override the test with a dos path.
- IFS="${IFS= }"; ac_save_ifs="$IFS"; IFS=":"
- ac_dummy="$PATH"
- for ac_dir in $ac_dummy; do
- test -z "$ac_dir" && ac_dir=.
- if test -f $ac_dir/$ac_word; then
- ac_cv_path_PY_CONFIG="$ac_dir/$ac_word"
- break
- fi
- done
- IFS="$ac_save_ifs"
- test -z "$ac_cv_path_PY_CONFIG" && ac_cv_path_PY_CONFIG="no"
-esac
-PY_CONFIG="$ac_cv_path_PY_CONFIG"
-if test -n "$PY_CONFIG"; then
- echo "$ac_t""$PY_CONFIG" 1>&6
-else
-fi
- if test "$PY_CONFIG" != "no" ; then
- # With Python includes directory
- PYTHONINC=`"$PY_CONFIG" --includes`
-ac_save_cppflags="$CPPFLAGS"
-CPPFLAGS="$PYTHONINC $CPPFLAGS"
-for ac_hdr in Python.h
-do
-ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
-echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:14208: checking for $ac_hdr" >&5
-cat > conftest.$ac_ext <<EOF
-#line 14211 "configure"
-#include "confdefs.h"
-#include <$ac_hdr>
-EOF
-ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:14216: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
-ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
-if test -z "$ac_err"; then
- rm -rf conftest*
- eval "ac_cv_header_$ac_safe=yes"
-else
- echo "$ac_err" >&5
- echo "configure: failed program was:" >&5
- cat conftest.$ac_ext >&5
- rm -rf conftest*
- eval "ac_cv_header_$ac_safe=no"
-fi
-rm -f conftest*
-if eval "test \"`echo '$ac_cv_header_'$ac_safe`\" = yes"; then
- ac_tr_hdr=HAVE_`echo $ac_hdr | sed 'y%abcdefghijklmnopqrstuvwxyz./-%ABCDEFGHIJKLMNOPQRSTUVWXYZ___%'`
- cat >> confdefs.h <<EOF
-#define $ac_tr_hdr 1
-EOF
-else
-{ echo "configure: error: *** Unable to locate Python includes." 1>&2; exit 1; }
-fi
-done
-CPPFLAGS=$ac_save_cppflags
- PYTHONCFLAGS=`"$PY_CONFIG" --cflags`
- # With Python library directory
- PYTHONLDFLAGS=`"$PY_CONFIG" --ldflags`
- # shouldn't have arch flags in C/LD flags on OSX
- for a in i386 ppc x86_64 ppc64
- do
- PYTHONCFLAGS=`echo "$PYTHONCFLAGS" | sed "s/-arch *$a//g"`
- PYTHONLDFLAGS=`echo "$PYTHONLDFLAGS" | sed "s/-arch *$a//g"`
- done
- fi
- # look for the swig program
- # Extract the first word of "swig", so it can be a program name with args.
-set dummy swig; ac_word=$2
-echo "configure:14264: checking for $ac_word" >&5
-case "$SWIG" in
- ac_cv_path_SWIG="$SWIG" # Let the user override the test with a path.
- ac_cv_path_SWIG="$SWIG" # Let the user override the test with a dos path.
- ac_dummy="$PATH"
- ac_cv_path_SWIG="$ac_dir/$ac_word"
- break
- fi
- done
- test -z "$ac_cv_path_SWIG" && ac_cv_path_SWIG="no"
-esac
-SWIG="$ac_cv_path_SWIG"
-if test -n "$SWIG"; then
- echo "$ac_t""$SWIG" 1>&6
-else
-fi
- # if test "$SWIG" = "no" ; then
- # AC_MSG_ERROR([*** couldn't find swig])
- # fi
- # check for available OSX archs in Python, assume framework
- if test -n "$MACOSX_ARCHS" ; then
- pylib=`"$PY_CONFIG" --prefix`/Python
- pylibinfo=`file -L "$pylib"`
- do
- # add only if in MACOSX_ARCHS
- if test -n "`echo \"$pylibinfo\" | grep \"library $a\"`" ; then
- if test -n "`echo "$MACOSX_ARCHS" | grep $a`" ; then
- MACOSX_ARCHS_PYTHON="$MACOSX_ARCHS_PYTHON -arch $a"
- fi
- fi
- done
- fi
-fi # Done checking Python
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:14326: checking whether to use wxWidgets" >&5
+echo "configure:14130: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -14343,7 +14147,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
-echo "configure:14347: checking for $ac_word" >&5
+echo "configure:14151: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -14391,7 +14195,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:14395: checking wxWidgets version" >&5
+echo "configure:14199: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -14414,15 +14218,15 @@
do
-echo "configure:14418: checking for $ac_hdr" >&5
+echo "configure:14222: checking for $ac_hdr" >&5
-#line 14421 "configure"
+#line 14225 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14426: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14230: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14751,13 +14555,6 @@
s%@PTHREADLIB@%$PTHREADLIB%g
s%@USE_PTHREAD@%$USE_PTHREAD%g
s%@USE_LARGEFILES@%$USE_LARGEFILES%g
-s%@PY_CONFIG@%$PY_CONFIG%g
-s%@SWIG@%$SWIG%g
-s%@PYTHONINC@%$PYTHONINC%g
-s%@PYTHONCFLAGS@%$PYTHONCFLAGS%g
-s%@PYTHONLDFLAGS@%$PYTHONLDFLAGS%g
-s%@USE_PYTHON@%$USE_PYTHON%g
-s%@MACOSX_ARCHS_PYTHON@%$MACOSX_ARCHS_PYTHON%g
s%@WX_CONFIG@%$WX_CONFIG%g
s%@WXVERSION@%$WXVERSION%g
s%@WXWIDGETSCXXFLAGS@%$WXWIDGETSCXXFLAGS%g
@@ -15095,8 +14892,6 @@
echo " PostgreSQL support: `if test -n "${USE_POSTGRES}" ; then echo yes ; else echo no ; fi`"
-echo " Python support: `if test -n "${USE_PYTHON}" ; then echo yes ; else echo no ; fi`"
echo " Readline support: `if test -n "${USE_READLINE}" ; then echo yes ; else echo no ; fi`"
echo " SQLite support: `if test -n "${USE_SQLITE}" ; then echo yes ; else echo no ; fi`"
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in 2011-02-12 13:01:43 UTC (rev 45387)
+++ grass/trunk/configure.in 2011-02-12 13:10:10 UTC (rev 45388)
@@ -8,11 +8,11 @@
# PURPOSE: This configure runs all the tests to determine what components
# are installed on the current system. It also defines certain
# configuration variables for compilation and installation.
-# COPYRIGHT: (C) 2000-2009 by the GRASS Development Team
+# COPYRIGHT: (C) 2000-2009, 2011 by the GRASS Development Team
-# This program is free software under the GNU General Public
-# License (>=v2). Read the file COPYING that comes with GRASS
-# for details.
+# This program is free software under the GNU General
+# Public License (>=v2). Read the file COPYING that
+# comes with GRASS for details.
# MANUAL: http://www.gnu.org/software/autoconf/manual/autoconf.html
# Website for config.guess, config.sub:
@@ -267,13 +267,6 @@
enable GDAL/OGR support (gdal-config with path,
e.g. '--with-gdal=/usr/local/bin/gdal-config')])
-AC_ARG_WITH(python,
-[ --with-python[=path/python-config]
- enable support for Python SWIG bindings and wxGUI
- Python extensions (python-config with path, e.g.
- '--with-python=/usr/bin/python2.5-config',
- default: no)],, with_python="no")
AC_ARG_WITH(wxwidgets,
[ --with-wxwidgets[=path/wx-config]
enable wxWidgets support (wx-config with path,
@@ -1740,79 +1733,6 @@
AC_SUBST(USE_LARGEFILES)
-# Python check
-AC_MSG_CHECKING(whether to use Python)
-PYTHONINC=
-PYTHONCFLAGS=
-PYTHONLDFLAGS=
-SWIG=
-USE_PYTHON=
- AC_MSG_RESULT(no)
-else
- AC_MSG_RESULT(yes)
- USE_PYTHON="1"
- fi
- AC_PATH_PROG(PY_CONFIG, python-config, no)
- LOC_CHECK_INCLUDES(Python.h,Python,$PYTHONINC)
- do
- done
- fi
- AC_PATH_PROG(SWIG, swig, no)
- # fi
- do
- fi
- fi
- done
- fi
-AC_SUBST(PYTHONINC)
-AC_SUBST(PYTHONCFLAGS)
-AC_SUBST(PYTHONLDFLAGS)
-AC_SUBST(SWIG)
-AC_SUBST(USE_PYTHON)
-AC_SUBST(MACOSX_ARCHS_PYTHON)
AC_MSG_CHECKING(whether to use wxWidgets)
@@ -1967,7 +1887,6 @@
LOC_MSG_USE(OpenGL support,USE_OPENGL)
LOC_MSG_USE(PNG support,USE_PNG)
LOC_MSG_USE(PostgreSQL support,USE_POSTGRES)
-LOC_MSG_USE(Python support,USE_PYTHON)
LOC_MSG_USE(Readline support,USE_READLINE)
LOC_MSG_USE(SQLite support,USE_SQLITE)
LOC_MSG_USE(Tcl/Tk support,USE_TCLTK)
Modified: grass/trunk/include/Make/Platform.make.in
--- grass/trunk/include/Make/Platform.make.in 2011-02-12 13:01:43 UTC (rev 45387)
+++ grass/trunk/include/Make/Platform.make.in 2011-02-12 13:10:10 UTC (rev 45388)
@@ -216,12 +216,6 @@
#Python
PYTHON = python
-PYTHONINC = @PYTHONINC@
-PYTHONCFLAGS = @PYTHONCFLAGS@
-PYTHONLDFLAGS = @PYTHONLDFLAGS@
-SWIG = @SWIG@
-USE_PYTHON = @USE_PYTHON@
-MACOSX_ARCHS_PYTHON = @MACOSX_ARCHS_PYTHON@
#wxWidgets
WXVERSION = @WXVERSION@
Modified: grass/trunk/include/Make/Python.make
--- grass/trunk/include/Make/Python.make 2011-02-12 13:01:43 UTC (rev 45387)
+++ grass/trunk/include/Make/Python.make 2011-02-12 13:10:10 UTC (rev 45388)
@@ -1,20 +1,5 @@
-ifeq ($(findstring darwin,$(ARCH)),darwin)
-PYMOD_LD = $(CXX) -bundle -undefined dynamic_lookup
-PYMOD_LDFLAGS := $(SHLIB_LDFLAGS) -L$(ARCH_LIBDIR)
-else
-PYMOD_LD = $(CXX) -shared
-PYMOD_LDFLAGS := $(SHLIB_LDFLAGS) -L$(ARCH_LIBDIR) $(PYTHONLDFLAGS)
-endif
-PYMOD_CFLAGS = $(SHLIB_CFLAGS) $(PYTHONINC) $(PYTHON_CFLAGS)
PY_SOURCES := $(wildcard *.py)
%.pyc: %.py
$(PYTHON) -m py_compile $<
-%_wrap.c %.py: %.i $(EXTRA_SWIG)
- $(SWIG) $(INC) -python -module $* -shadow $<
-_%.so: $(OBJDIR)/%_wrap.o $(_%_so_FILES)
- $(PYMOD_LD) -o $@ $(LDFLAGS) $(EXTRA_LDFLAGS) $(PYMOD_LDFLAGS) $(filter %.o,$^) $($*_LIBS) $(LIBES) $(EXTRA_LIBS)
Modified: grass/trunk/include/gisdefs.h
--- grass/trunk/include/gisdefs.h 2011-02-12 13:01:43 UTC (rev 45387)
+++ grass/trunk/include/gisdefs.h 2011-02-12 13:10:10 UTC (rev 45388)
@@ -112,9 +112,7 @@
* the G_asprintf macro is disabled until a stable version of GDAL
* with a different function becomes widely used
-#ifndef SWIG
int G_vasprintf(char **, const char *, va_list);
-#endif
int G_asprintf(char **, const char *, ...)
__attribute__ ((format(printf, 2, 3)));
Modified: grass/trunk/lib/init/variables.html
--- grass/trunk/lib/init/variables.html 2011-02-12 13:01:43 UTC (rev 45387)
+++ grass/trunk/lib/init/variables.html 2011-02-12 13:10:10 UTC (rev 45388)
@@ -236,7 +236,7 @@
to trace the source of the error.</dd>
<dt>GRASS_PYTHON</dt>
- <dd>[wxGUI, Python SWIG]<br>
+ <dd>[wxGUI, Python Ctypes]<br>
set to override Python executable.<br>
On Mac OS X this should be the pythonw executable for the wxGUI to work.</dd>
