[GRASS-SVN] r45398 - grass/trunk/vector/v.kernel
Mon Feb 14 05:33:25 EST 2011
Author: mmetz
Date: 2011-02-14 02:33:25 -0800 (Mon, 14 Feb 2011)
New Revision: 45398
   grass/trunk/vector/v.kernel/v.kernel.html
update manual: explain equal split
Modified: grass/trunk/vector/v.kernel/v.kernel.html
--- grass/trunk/vector/v.kernel/v.kernel.html	2011-02-14 08:31:59 UTC (rev 45397)
+++ grass/trunk/vector/v.kernel/v.kernel.html	2011-02-14 10:33:25 UTC (rev 45398)
@@ -5,8 +5,11 @@
 triangular, epanechnikov, quartic, triweight, gaussian, cosine</em>,
 default is <em>gaussian</em>.
 <p>
-The module can also generate a vector density map on a vector network,
-optionally using the equal split algorithm of Okabe et al. 2009.
+The module can also generate a vector density map on a vector network.
+Conventional kernel functions produce biased estimates by overestimating
+the densities around network nodes, whereas the equal split kernel
+function of Okabe et al. (2009) produces unbiased density estimates.
+The equal split kernel function can be enabled with <em>node=split</em>.
 <H2>NOTES</H2>
