[GRASS-SVN] r45404 - grass/trunk/vector/v.build.polylines
Mon Feb 14 12:25:31 EST 2011
Author: mmetz
Date: 2011-02-14 09:25:31 -0800 (Mon, 14 Feb 2011)
New Revision: 45404
   grass/trunk/vector/v.build.polylines/main.c
process only lines
Modified: grass/trunk/vector/v.build.polylines/main.c
--- grass/trunk/vector/v.build.polylines/main.c	2011-02-14 15:21:52 UTC (rev 45403)
+++ grass/trunk/vector/v.build.polylines/main.c	2011-02-14 17:25:31 UTC (rev 45404)
@@ -178,9 +178,8 @@
 	if (type & GV_LINES)
 	    nlines++;
-	/* copy points to output as they are, with cats */
-	if (type & GV_POINTS) {
+	else {
+	    /* copy points to output as they are, with cats */
 	    Vect_read_line(&map, points, Cats, line);
 	    Vect_write_line(&Out, type, points, Cats);
 	    continue;
