[GRASS-SVN] r45431 - grass/branches/develbranch_6/mswindows/osgeo4w
svn_grass at osgeo.org
Fri Feb 18 10:11:11 EST 2011
Author: martinl
Date: 2011-02-18 07:11:11 -0800 (Fri, 18 Feb 2011)
New Revision: 45431
Removed:
grass/branches/develbranch_6/mswindows/osgeo4w/gdal-1.6.diff
remove unused file
Deleted: grass/branches/develbranch_6/mswindows/osgeo4w/gdal-1.6.diff
--- grass/branches/develbranch_6/mswindows/osgeo4w/gdal-1.6.diff 2011-02-18 15:07:17 UTC (rev 45430)
+++ grass/branches/develbranch_6/mswindows/osgeo4w/gdal-1.6.diff 2011-02-18 15:11:11 UTC (rev 45431)
@@ -1,261 +0,0 @@
-Index: nmake.opt
---- nmake.opt (revision 17458)
-+++ nmake.opt (working copy)
-@@ -22,8 +22,8 @@
- # 1200 = 6.0
- !IFNDEF MSVC_VER
--#assume msvc 7.1
--MSVC_VER=1310
-+#assume msvc 9.0
-+MSVC_VER=1500
- !ENDIF
-@@ -39,11 +39,11 @@
- # But the paths *should* be absolute (relative paths mess up in submakefiles).
- !IFNDEF GDAL_HOME
--GDAL_HOME = "C:\warmerda\bld"
-+GDAL_HOME = $(OSGEO4W_ROOT)
- !ENDIF
- BINDIR = $(GDAL_HOME)\bin
- PLUGINDIR = $(BINDIR)\gdalplugins
--PY_INST_DIR = $(GDAL_HOME)\pymod
-+PY_INST_DIR = $(GDAL_HOME)\apps\Python25\lib\site-packages
- LIBDIR = $(GDAL_HOME)\lib
- INCDIR = $(GDAL_HOME)\include
- DATADIR = $(GDAL_HOME)\data
-@@ -52,7 +52,7 @@
- # Set this to the installed directory containing python. If you don't
- # have python just let it point to a directory that does not exist (as now).
- !IFNDEF PYDIR
--PYDIR = "C:\Software\Python24"
-+PYDIR = $(OSGEO4W_ROOT)\apps\Python25
- !ENDIF
- # Set the location of your SWIG installation
-@@ -77,7 +77,7 @@
- !IFNDEF OPTFLAGS
- !IF $(MSVC_VER) >= 1400
- !IFNDEF DEBUG
--OPTFLAGS= /nologo /MD /EHsc /Ox /W3 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /DNDEBUG
-+OPTFLAGS= /nologo /MD /EHsc /Zi /Ox /W3 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /DNDEBUG /Fd$(GDAL_ROOT)\gdal$(VERSION).pdb
- !ELSE
- OPTFLAGS= /nologo /MD /EHsc /Zi /W4 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Fd$(GDAL_ROOT)\gdal$(VERSION).pdb
- !ENDIF
-Index: ogr/ogrsf_frmts/grass/ogrgrassdatasource.cpp
---- ogr/ogrsf_frmts/grass/ogrgrassdatasource.cpp (revision 17458)
-+++ ogr/ogrsf_frmts/grass/ogrgrassdatasource.cpp (working copy)
-@@ -31,6 +31,10 @@
- #include "cpl_conv.h"
- #include "cpl_string.h"
-+#ifdef WIN32
-+#include <fcntl.h>
-+#endif
- CPL_CVSID("$Id$");
-@@ -187,6 +191,9 @@
- Vect_set_fatal_error ( GV_FATAL_PRINT ); // Print error and continue
- Vect_set_open_level (2);
-+#ifdef WIN32
-+ _set_fmode(_O_BINARY);
-+#endif
- int level = Vect_open_old ( &map, pszMap, pszMapset);
- if ( level < 2 ) {
-Index: ogr/ogrsf_frmts/grass/makefile.vc
---- ogr/ogrsf_frmts/grass/makefile.vc (revision 0)
-+++ ogr/ogrsf_frmts/grass/makefile.vc (revision 0)
-@@ -0,0 +1,33 @@
-+GRASS_BASE = $(OSGEO4W_ROOT)\apps\grass\grass-$(GRASS_VERSION)
-+SRC = ogrgrassdriver.cpp ogrgrassdatasource.cpp ogrgrasslayer.obj
-+OBJ = ogrgrassdriver.obj ogrgrassdatasource.obj ogrgrasslayer.obj
-+PLUGIN_DLL = ogr_GRASS.dll
-+CFLAGS = /nologo /MD /EHsc /Od /Zi /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /DNDEBUG \
-+ -I $(OSGEO4W_ROOT)/apps/gdal-16/include \
-+ -I $(OSGEO4W_ROOT)/include -I $(GRASS_BASE)/include \
-+ -D GRASS_GISBASE=\"$(OSGEO4W_ROOT)\\apps\\grass\\grass-$(GRASS_VERSION)\"
-+GRASS_LIBS = /LIBPATH:$(GRASS_BASE)/lib $(OSGEO4W_ROOT)/apps/gdal-16/lib/gdal_i.lib grass_gis.lib grass_vect.lib grass_dbmibase.lib grass_dbmiclient.lib grass_gproj.lib
-+PLUGIN_DIR = $(OSGEO4W_ROOT)\apps\gdal-16\bin\gdalplugins
-+#GRASS_LIBS = /LIBPATH:$(GRASS_BASE)/lib /LIBPATH:$(OSGEO4W_ROOT)/lib gdal_i.lib grass_gis.lib grass_vect.lib grass_dbmibase.lib grass_dbmiclient.lib grass_gproj.lib
-+#PLUGIN_DIR = $(OSGEO4W_ROOT)\bin\gdalplugins
-+plugin: $(PLUGIN_DLL)
-+$(PLUGIN_DLL): $(OBJ)
-+ link /debug /dll $(LDEBUG) /out:$(PLUGIN_DLL) $(OBJ) $(GDALLIB) $(GRASS_LIBS)
-+ if exist $(PLUGIN_DLL).manifest mt -manifest $(PLUGIN_DLL).manifest -outputresource:$(PLUGIN_DLL);2
-+ xcopy $(PLUGIN_DLL) $(PLUGIN_DIR) /y
-+.cpp.obj:
-+ $(CC) $(CFLAGS) /c $*.cpp
-+default: $(OBJ)
-+ xcopy /D /Y *.obj ..\o
-+clean:
-+ -del *.obj
-+plugin-install: $(PLUGIN_DLL)
-+ -mkdir $(PLUGINDIR)
-+ $(INSTALL) $(PLUGIN_DLL) $(PLUGINDIR)
-Index: ogr/ogrfeature.cpp
---- ogr/ogrfeature.cpp (revision 17458)
-+++ ogr/ogrfeature.cpp (working copy)
-@@ -976,8 +976,7 @@
- const char *OGRFeature::GetFieldAsString( int iField )
--#define TEMP_BUFFER_SIZE 80
-- char szTempBuffer[TEMP_BUFFER_SIZE];
-+ char szTempBufferSize[80];
- CPLFree(m_pszTmpFieldValue);
- m_pszTmpFieldValue = NULL;
-@@ -989,7 +988,7 @@
- switch (iSpecialField)
- case SPF_FID:
-- snprintf( szTempBuffer, TEMP_BUFFER_SIZE, "%ld", GetFID() );
-+ snprintf( szTempBuffer, sizeof szTempBufferSize, "%ld", GetFID() );
- return m_pszTmpFieldValue = CPLStrdup( szTempBuffer );
- case SPF_OGR_GEOMETRY:
-@@ -1038,7 +1037,7 @@
- else if( poFDefn->GetType() == OFTInteger )
- "%d", pauFields[iField].Integer );
-@@ -1054,14 +1053,14 @@
- else
- strcpy( szFormat, "%.15g" );
- szFormat, pauFields[iField].Real );
- else if( poFDefn->GetType() == OFTDateTime )
- "%04d/%02d/%02d %2d:%02d:%02d",
- pauFields[iField].Date.Year,
- pauFields[iField].Date.Month,
-@@ -1086,17 +1085,17 @@
- if( nMinutes == 0 )
- snprintf( szTempBuffer+strlen(szTempBuffer),
-- TEMP_BUFFER_SIZE-strlen(szTempBuffer), "%02d", nHours );
-+ sizeof szTempBufferSize-strlen(szTempBuffer), "%02d", nHours );
- else
-- TEMP_BUFFER_SIZE-strlen(szTempBuffer), "%02d%02d", nHours, nMinutes );
-+ sizeof szTempBufferSize-strlen(szTempBuffer), "%02d%02d", nHours, nMinutes );
- else if( poFDefn->GetType() == OFTDate )
-- snprintf( szTempBuffer, TEMP_BUFFER_SIZE, "%04d/%02d/%02d",
-+ snprintf( szTempBuffer, sizeof szTempBufferSize, "%04d/%02d/%02d",
- pauFields[iField].Date.Day );
-@@ -1105,7 +1104,7 @@
- else if( poFDefn->GetType() == OFTTime )
-- snprintf( szTempBuffer, TEMP_BUFFER_SIZE, "%2d:%02d:%02d",
-+ snprintf( szTempBuffer, sizeof szTempBufferSize, "%2d:%02d:%02d",
- pauFields[iField].Date.Hour,
- pauFields[iField].Date.Minute,
- pauFields[iField].Date.Second );
-@@ -1117,7 +1116,7 @@
- char szItem[32];
- int i, nCount = pauFields[iField].IntegerList.nCount;
-- snprintf( szTempBuffer, TEMP_BUFFER_SIZE, "(%d:", nCount );
-+ snprintf( szTempBuffer, sizeof szTempBufferSize, "(%d:", nCount );
- for( i = 0; i < nCount; i++ )
- snprintf( szItem, sizeof(szItem), "%d",
-@@ -1155,7 +1154,7 @@
- else
- strcpy( szFormat, "%.16g" );
- snprintf( szItem, sizeof(szItem), szFormat,
-@@ -1183,7 +1182,7 @@
- int i, nCount = pauFields[iField].StringList.nCount;
- const char *pszItem = pauFields[iField].StringList.paList[i];
-@@ -1228,7 +1227,6 @@
- else
- return "";
--#undef TEMP_BUFFER_SIZE
-Index: frmts/grass/makefile.vc
---- frmts/grass/makefile.vc (revision 0)
-+++ frmts/grass/makefile.vc (revision 0)
-@@ -0,0 +1,32 @@
-+SRC = grass57dataset.cpp
-+OBJ = grass57dataset.obj
-+PLUGIN_DLL = gdal_GRASS.dll
-+LDEBUG = /debug
-+CFLAGS = -I $(OSGEO4W_ROOT)\apps\grass\grass-$(GRASS_VERSION)\include -I $(OSGEO4W_ROOT)\apps\gdal-16\include -I $(OSGEO4W_ROOT)\include /MD /EHsc
-+GRASS_LIBS = /LIBPATH:$(OSGEO4W_ROOT)\apps\grass\grass-$(GRASS_VERSION)\lib $(OSGEO4W_ROOT)\apps\gdal-16\lib\gdal_i.lib grass_gis.lib grass_i.lib grass_gproj.lib
-+PLUGINDIR = $(OSGEO4W_ROOT)\apps\gdal-16\bin\gdalplugins
-+#CFLAGS = -I $(OSGEO4W_ROOT)\include -I $(OSGEO4W_ROOT)\apps\grass\grass-$(GRASS_VERSION)\include /MD /EHsc /Od /Zi /DNDEBUG /Fdgdal_GRASS.pdb
-+#GRASS_LIBS = /LIBPATH:c:/OSGeo4W/apps/grass/grass-$(GRASS_VERSION)/lib /LIBPATH:C:/OSGeo4W/lib gdal_i.lib grass_gis.lib grass_i.lib grass_gproj.lib
-+#PLUGINDIR = $(OSGEO4W_ROOT)\bin\gdalplugins
-+ link /dll $(LDEBUG) /out:$(PLUGIN_DLL) $(OBJ) $(GDALLIB) $(GRASS_LIBS)
-+ xcopy $(PLUGIN_DLL) $(PLUGINDIR) /y
-+$(OBJ): $(SRC)
-+ $(CC) $(CFLAGS) /c $(SRC)
-+default: $(OBJ)
-+clean:
-+ -del *.obj *.manifest *.dll *.lib *.exp *.pdb
