[GRASS-SVN] r45460 -
grass-addons/grass7/raster/r.stream/r.stream.snap
svn_grass at osgeo.org
Sat Feb 26 02:58:05 EST 2011
Author: hamish
Date: 2011-02-25 23:58:05 -0800 (Fri, 25 Feb 2011)
New Revision: 45460
grass-addons/grass7/raster/r.stream/r.stream.snap/io.c
grass-addons/grass7/raster/r.stream/r.stream.snap/io.h
grass-addons/grass7/raster/r.stream/r.stream.snap/local_proto.h
grass-addons/grass7/raster/r.stream/r.stream.snap/local_vars.h
grass-addons/grass7/raster/r.stream/r.stream.snap/main.c
grass-addons/grass7/raster/r.stream/r.stream.snap/points_io.c
grass-addons/grass7/raster/r.stream/r.stream.snap/snap.c
run trunk/tools/grass_indent.sh *.[ch]
Modified: grass-addons/grass7/raster/r.stream/r.stream.snap/io.c
--- grass-addons/grass7/raster/r.stream/r.stream.snap/io.c 2011-02-26 07:53:29 UTC (rev 45459)
+++ grass-addons/grass7/raster/r.stream/r.stream.snap/io.c 2011-02-26 07:58:05 UTC (rev 45460)
@@ -1,523 +1,562 @@
#include "io.h"
/* all in ram functions section */
-int ram_create_map(MAP* map, RASTER_MAP_TYPE data_type) {
- * allocates 0 filled nrows*ncols map of type void;
- * map parameters are stored in structure;
- * map: map to be created;
- * map type to be created must be CELL, FCELL, DCELL;
- int r, c;
- if(data_type < 0 || data_type > 2)
+int ram_create_map(MAP * map, RASTER_MAP_TYPE data_type)
+ * allocates 0 filled nrows*ncols map of type void;
+ * map parameters are stored in structure;
+ * map: map to be created;
+ * map type to be created must be CELL, FCELL, DCELL;
+ int r, c;
+ if (data_type < 0 || data_type > 2)
G_fatal_error(_("ram_creat: Cannot create map of unrecognised type"));
- map->data_type=data_type;
- map->map_name=NULL;
- map->nrows = Rast_window_rows();
- map->ncols = Rast_window_cols();
- map->data_size=Rast_cell_size(data_type);
-/* preparing internal map */
- switch (map->data_type) {
- case CELL_TYPE:
- map->map = G_calloc(map->nrows,sizeof(CELL *));
- break;
+ map->data_type = data_type;
+ map->map_name = NULL;
+ map->nrows = Rast_window_rows();
+ map->ncols = Rast_window_cols();
+ map->data_size = Rast_cell_size(data_type);
- case FCELL_TYPE:
- map->map = G_calloc(map->nrows,sizeof(FCELL *));
- break;
- case DCELL_TYPE:
- map->map = G_calloc(map->nrows,sizeof(DCELL *));
- break;
+ /* preparing internal map */
+ switch (map->data_type) {
+ case CELL_TYPE:
+ map->map = G_calloc(map->nrows, sizeof(CELL *));
+ break;
- for (r = 0; r < map->nrows; ++r)
- (map->map)[r] = G_calloc(map->ncols,map->data_size);
- return 0;
+ case FCELL_TYPE:
+ map->map = G_calloc(map->nrows, sizeof(FCELL *));
+ break;
+ case DCELL_TYPE:
+ map->map = G_calloc(map->nrows, sizeof(DCELL *));
+ break;
+ for (r = 0; r < map->nrows; ++r)
+ (map->map)[r] = G_calloc(map->ncols, map->data_size);
+ return 0;
-int ram_read_map(MAP* map, char* input_map_name, int check_res, RASTER_MAP_TYPE check_data_type) {
- * Funciton read external map and put it in MAP structure (created with create_map)
- * map: map to be read can be of any data type, read map is converted to target map if neccesary.
- * input_map_name: name of the map to be read;
- * map pointer to map stucture (created with create_map);
- * check_res: [1]: check res correspondence between region and map [0 no check];
- * check_data_type [CELL, FCELL, DCELL] check if reading map is of particular type, [-1] no check;
+int ram_read_map(MAP * map, char *input_map_name, int check_res,
+ RASTER_MAP_TYPE check_data_type)
+ * Funciton read external map and put it in MAP structure (created with create_map)
+ * map: map to be read can be of any data type, read map is converted to target map if neccesary.
+ * input_map_name: name of the map to be read;
+ * map pointer to map stucture (created with create_map);
+ * check_res: [1]: check res correspondence between region and map [0 no check];
+ * check_data_type [CELL, FCELL, DCELL] check if reading map is of particular type, [-1] no check;
- int r, c;
- char *mapset;
- struct Cell_head cellhd, this_window;
- char* maptypes[]= { "CELL", "FCELL", "DCELL" };
- int input_map_fd;
- RASTER_MAP_TYPE input_data_type;
- size_t input_data_size;
- void* input_buffer=NULL;
- void* input_pointer;
+ int r, c;
+ char *mapset;
+ struct Cell_head cellhd, this_window;
+ char *maptypes[] = { "CELL", "FCELL", "DCELL" };
+ int input_map_fd;
+ RASTER_MAP_TYPE input_data_type;
+ size_t input_data_size;
+ void *input_buffer = NULL;
+ void *input_pointer;
- /* checking if map exist */
- mapset = (char*)G_find_raster2(input_map_name, "");
- if (mapset == NULL)
+ /* checking if map exist */
+ mapset = (char *)G_find_raster2(input_map_name, "");
+ if (mapset == NULL)
G_fatal_error(_("Raster map <%s> not found"), input_map_name);
- /* checking if region and input are the same */
- G_get_window(&this_window);
- Rast_get_cellhd(input_map_name, mapset, &cellhd);
- if(check_res)
- if (this_window.ew_res != cellhd.ew_res ||
- this_window.ns_res != cellhd.ns_res)
- G_fatal_error(_("Region resolution and map %s resolution differs. \
+ /* checking if region and input are the same */
+ G_get_window(&this_window);
+ Rast_get_cellhd(input_map_name, mapset, &cellhd);
+ if (check_res)
+ if (this_window.ew_res != cellhd.ew_res ||
+ this_window.ns_res != cellhd.ns_res)
+ G_fatal_error(_("Region resolution and map %s resolution differs. \
Run g.region rast=%s to set proper region resolution"),
- input_map_name, input_map_name);
+ input_map_name, input_map_name);
- /* checking if input map is of required type */
- if(check_data_type != map->data_type)
- G_debug(1,"ram_open:required map type and internal map type differs: conversion forced!");
- input_data_type = Rast_map_type(input_map_name,mapset);
- if(check_data_type !=-1)
- if (input_data_type != check_data_type)
- G_fatal_error(_("<%s> is not of type %s"),
- input_map_name, maptypes[check_data_type]);
+ /* checking if input map is of required type */
+ if (check_data_type != map->data_type)
+ G_debug(1,
+ "ram_open:required map type and internal map type differs: conversion forced!");
+ input_data_type = Rast_map_type(input_map_name, mapset);
+ if (check_data_type != -1)
+ if (input_data_type != check_data_type)
+ G_fatal_error(_("<%s> is not of type %s"),
+ input_map_name, maptypes[check_data_type]);
- input_map_fd = Rast_open_old(input_map_name, mapset);
- input_data_size = Rast_cell_size(input_data_type);
-{/* reading range */
+ input_map_fd = Rast_open_old(input_map_name, mapset);
+ input_data_size = Rast_cell_size(input_data_type);
+ { /* reading range */
struct Range map_range;
struct FPRange map_fp_range;
int min, max;
- if(input_data_type==CELL_TYPE) {
- Rast_init_range(&map_range);
- Rast_read_range(input_map_name,mapset,&map_range);
- Rast_get_range_min_max(&map_range, &min, &max);
- map->min=(double)min;
- map->max=(double)max;
- else {
- Rast_init_fp_range(&map_fp_range);
- Rast_read_fp_range(input_map_name,mapset,&map_fp_range);
- Rast_get_fp_range_min_max(&map_fp_range, &(map->min), &(map->max));
-/* end opening and checking */
+ if (input_data_type == CELL_TYPE) {
+ Rast_init_range(&map_range);
+ Rast_read_range(input_map_name, mapset, &map_range);
+ Rast_get_range_min_max(&map_range, &min, &max);
+ map->min = (double)min;
+ map->max = (double)max;
+ else {
+ Rast_init_fp_range(&map_fp_range);
+ Rast_read_fp_range(input_map_name, mapset, &map_fp_range);
+ Rast_get_fp_range_min_max(&map_fp_range, &(map->min),
+ &(map->max));
+ /* end opening and checking */
- input_buffer=Rast_allocate_buf(input_data_type);
- /* start reading */
- G_message(_("Reading map <%s>"),input_map_name);
+ input_buffer = Rast_allocate_buf(input_data_type);
- for (r = 0; r < map->nrows; ++r) {
- G_percent(r, map->nrows, 2);
+ /* start reading */
+ G_message(_("Reading map <%s>"), input_map_name);
- Rast_get_row(input_map_fd, input_buffer, r,input_data_type);
- input_pointer=input_buffer;
+ for (r = 0; r < map->nrows; ++r) {
+ G_percent(r, map->nrows, 2);
- for (c = 0; c < map->ncols; ++c)
- if(!Rast_is_null_value(input_pointer+c*input_data_size,input_data_type))
- case CELL_TYPE:
- ((CELL**)map->map)[r][c] =
- Rast_get_c_value(input_pointer+c*input_data_size, input_data_type);
- break;
- case FCELL_TYPE:
- ((FCELL**)map->map)[r][c] =
- Rast_get_f_value(input_pointer+c*input_data_size, input_data_type);
- break;
- case DCELL_TYPE:
- ((DCELL**)map->map)[r][c] =
- Rast_get_d_value(input_pointer+c*input_data_size, input_data_type);
- break;
- default:
- G_fatal_error(_("ram_open:Wrong internal data type"));
- break;
- } /*end for r */
+ Rast_get_row(input_map_fd, input_buffer, r, input_data_type);
+ input_pointer = input_buffer;
- G_free(input_buffer);
- Rast_close(input_map_fd);
- return 0;
+ for (c = 0; c < map->ncols; ++c)
+ if (!Rast_is_null_value
+ (input_pointer + c * input_data_size, input_data_type))
+ case CELL_TYPE:
+ ((CELL **) map->map)[r][c] =
+ Rast_get_c_value(input_pointer + c * input_data_size,
+ input_data_type);
+ break;
+ case FCELL_TYPE:
+ ((FCELL **) map->map)[r][c] =
+ Rast_get_f_value(input_pointer + c * input_data_size,
+ input_data_type);
+ break;
+ case DCELL_TYPE:
+ ((DCELL **) map->map)[r][c] =
+ Rast_get_d_value(input_pointer + c * input_data_size,
+ input_data_type);
+ break;
+ default:
+ G_fatal_error(_("ram_open:Wrong internal data type"));
+ break;
+ } /*end for r */
+ G_free(input_buffer);
+ Rast_close(input_map_fd);
+ return 0;
} /* end create floating point map */
-int ram_reset_map(MAP* map, int value) {
- * set all cells in the map to value
- int r;
+int ram_reset_map(MAP * map, int value)
+ * set all cells in the map to value
+ int r;
- for (r=0;r<map->nrows;++r)
- memset((map->map)[r],value,map->ncols*map->data_size);
- return 0;
+ memset((map->map)[r], value, map->ncols * map->data_size);
+ return 0;
-int ram_write_map(MAP* map, char* output_map_name, RASTER_MAP_TYPE output_data_type, int convert_to_null, double value) {
- * write map to disk with output_map_name and output_data_type [CELL, FCELL, DCELL];
- * if output_data_type = -1 than internal map type is used for output;
- * if output map != -1 and types differ data_type, conversion is forced
- * convert to null: check if convert to null a particular value in dataset;
- int r, c;
- int output_fd = 0;
- struct History history;
- void* row;
+int ram_write_map(MAP * map, char *output_map_name,
+ RASTER_MAP_TYPE output_data_type, int convert_to_null,
+ double value)
+ * write map to disk with output_map_name and output_data_type [CELL, FCELL, DCELL];
+ * if output_data_type = -1 than internal map type is used for output;
+ * if output map != -1 and types differ data_type, conversion is forced
+ * convert to null: check if convert to null a particular value in dataset;
- /* check for output format */
- if(output_data_type == -1)
+ int r, c;
+ int output_fd = 0;
+ struct History history;
+ void *row;
+ /* check for output format */
+ if (output_data_type == -1)
output_data_type = map->data_type;
- if(output_data_type != map->data_type)
- G_debug(1,"ram_write:required map type and internal map type differs: conversion forced!");
- G_message(_("Writing map <%s>"),output_map_name);
- output_fd = Rast_open_new(output_map_name, output_data_type);
- /* writing */
- if(convert_to_null) {
- row = map->map[r];
- case CELL_TYPE:
- if (((CELL*)row)[c] == (CELL)value)
- Rast_set_c_null_value(row+c*(map->data_size), 1);
- break;
- case FCELL_TYPE:
- if (((FCELL*)row)[c] == (FCELL)value)
- Rast_set_f_null_value(row+c*(map->data_size), 1);
- break;
- case DCELL_TYPE:
- if (((DCELL*)row)[c] == (DCELL)value)
- Rast_set_d_null_value(row+c*(map->data_size), 1);
- break;
- default:
- G_debug(1,"ram_null:Cannot convert to null at: %d %d",r,c);
+ if (output_data_type != map->data_type)
+ G_debug(1,
+ "ram_write:required map type and internal map type differs: conversion forced!");
+ G_message(_("Writing map <%s>"), output_map_name);
+ output_fd = Rast_open_new(output_map_name, output_data_type);
+ /* writing */
+ if (convert_to_null) {
+ row = map->map[r];
+ case CELL_TYPE:
+ if (((CELL *) row)[c] == (CELL) value)
+ Rast_set_c_null_value(row + c * (map->data_size), 1);
+ break;
+ case FCELL_TYPE:
+ if (((FCELL *) row)[c] == (FCELL) value)
+ Rast_set_f_null_value(row + c * (map->data_size), 1);
+ break;
+ case DCELL_TYPE:
+ if (((DCELL *) row)[c] == (DCELL) value)
+ Rast_set_d_null_value(row + c * (map->data_size), 1);
+ break;
+ default:
+ G_debug(1, "ram_null:Cannot convert to null at: %d %d", r, c);
Rast_put_row(output_fd, (map->map)[r], output_data_type);
- Rast_close(output_fd);
- Rast_short_history(output_map_name, "raster", &history);
- Rast_command_history(&history);
- Rast_write_history(output_map_name, &history);
- G_message(_("<%s> Done"), output_map_name);
- return 0;
+ Rast_close(output_fd);
+ Rast_short_history(output_map_name, "raster", &history);
+ Rast_command_history(&history);
+ Rast_write_history(output_map_name, &history);
+ G_message(_("<%s> Done"), output_map_name);
+ return 0;
-int ram_release_map (MAP* map) {
- * free memory allocated for map, set pointer to null;
- int r;
+int ram_release_map(MAP * map)
+ * free memory allocated for map, set pointer to null;
+ int r;
- G_free((map->map)[r]);
- G_free(map->map);
- map=NULL;
- return 0;
+ G_free((map->map)[r]);
+ G_free(map->map);
+ map = NULL;
+ return 0;
/* memory swap functions section */
-int seg_create_map(SEG * seg, int srows, int scols, int number_of_segs, RASTER_MAP_TYPE data_type) {
- /* create segment and returns pointer to it;
- * seg must be declared first;
- * parameters are stored in structure;
- * seg: segment to be created;
- * srows, scols segment size
- * number of segs max number of segs stored in memory
- * data_type to be created must be CELL, FCELL, DCELL;
+int seg_create_map(SEG * seg, int srows, int scols, int number_of_segs,
+ RASTER_MAP_TYPE data_type)
+ /* create segment and returns pointer to it;
+ * seg must be declared first;
+ * parameters are stored in structure;
+ * seg: segment to be created;
+ * srows, scols segment size
+ * number of segs max number of segs stored in memory
+ * data_type to be created must be CELL, FCELL, DCELL;
- char* filename;
- int fd;
- int local_number_of_segs;
+ char *filename;
+ int fd;
+ int local_number_of_segs;
- seg->fd=-1;
- seg->filename = NULL;
- seg->map_name = NULL;
- seg->mapset = NULL;
- seg->data_type = data_type;
- seg->nrows = Rast_window_rows();
- seg->ncols = Rast_window_cols();
+ seg->fd = -1;
+ seg->filename = NULL;
+ seg->map_name = NULL;
+ seg->mapset = NULL;
+ seg->data_type = data_type;
+ seg->nrows = Rast_window_rows();
+ seg->ncols = Rast_window_cols();
- local_number_of_segs=(seg->nrows/srows+1)*(seg->ncols/scols+1);
- number_of_segs=(number_of_segs>local_number_of_segs) ?
- local_number_of_segs : number_of_segs;
- G_debug(3,"seg_creat:number of segments %d",number_of_segs);
- switch (seg->data_type) {
- case CELL_TYPE:
- seg->data_size=sizeof(CELL);
- break;
- case FCELL_TYPE:
- seg->data_size=sizeof(FCELL);
- break;
- case DCELL_TYPE:
- seg->data_size=sizeof(DCELL);
- break;
- default:
- G_fatal_error(_("seg_create: unrecognisabe data type"));
- filename=G_tempfile();
- fd=creat(filename,0666);
- if(0 > segment_format(fd,seg->nrows,seg->ncols,srows,scols,seg->data_size)) {
- close(fd);
- unlink(filename);
- G_fatal_error(_("seg_create: cannot format segment"));
+ local_number_of_segs =
+ (seg->nrows / srows + 1) * (seg->ncols / scols + 1);
+ number_of_segs =
+ (number_of_segs >
+ local_number_of_segs) ? local_number_of_segs : number_of_segs;
+ G_debug(3, "seg_creat:number of segments %d", number_of_segs);
+ switch (seg->data_type) {
+ case CELL_TYPE:
+ seg->data_size = sizeof(CELL);
+ break;
+ case FCELL_TYPE:
+ seg->data_size = sizeof(FCELL);
+ break;
+ case DCELL_TYPE:
+ seg->data_size = sizeof(DCELL);
+ break;
+ default:
+ G_fatal_error(_("seg_create: unrecognisabe data type"));
+ filename = G_tempfile();
+ fd = creat(filename, 0666);
+ if (0 >
+ segment_format(fd, seg->nrows, seg->ncols, srows, scols,
+ seg->data_size)) {
close(fd);
- if(0 > (fd = open(filename,2))) {
- unlink(filename);
- G_fatal_error(_("seg_create: cannot re-open file"));
- if(0>(fd = segment_init(&(seg->seg),fd,number_of_segs))) {
- unlink(filename);
- G_fatal_error(_("seg_create: cannot init segment file or out of memory"));
- seg->filename = G_store(filename);
- seg->fd = fd;
- return 0;
+ unlink(filename);
+ G_fatal_error(_("seg_create: cannot format segment"));
+ close(fd);
+ if (0 > (fd = open(filename, 2))) {
+ unlink(filename);
+ G_fatal_error(_("seg_create: cannot re-open file"));
+ if (0 > (fd = segment_init(&(seg->seg), fd, number_of_segs))) {
+ unlink(filename);
+ G_fatal_error(_("seg_create: cannot init segment file or out of memory"));
+ seg->filename = G_store(filename);
+ seg->fd = fd;
+ return 0;
-int seg_read_map(SEG* seg, char* input_map_name, int check_res, RASTER_MAP_TYPE check_data_type) {
- * Funciton read external map and put it in SEG structure (created with seg_create_map)
- * map to be read can be of any data type, read map is converted if neccesary.
- * seg: pointer to map stucture (created with create_map);
- int input_fd;
- int r,c;
- char* mapset;
- void* target_buffer=NULL;
- void* input_pointer=NULL;
+int seg_read_map(SEG * seg, char *input_map_name, int check_res,
+ * Funciton read external map and put it in SEG structure (created with seg_create_map)
+ * map to be read can be of any data type, read map is converted if neccesary.
+ * seg: pointer to map stucture (created with create_map);
+ int input_fd;
+ int r, c;
+ char *mapset;
+ void *target_buffer = NULL;
+ void *input_pointer = NULL;
if (mapset == NULL)
- G_fatal_error(_("seg_read:Raster map <%s> not found"), input_map_name);
- seg->mapset=mapset;
- /* check resolution equal anyinteger check; equal 0 no check*/
- if(check_res)
- if (this_window.ew_res != cellhd.ew_res || this_window.ns_res != cellhd.ns_res)
+ G_fatal_error(_("seg_read:Raster map <%s> not found"),
+ input_map_name);
+ seg->mapset = mapset;
+ /* check resolution equal anyinteger check; equal 0 no check */
+ if (check_res)
- if(check_data_type != seg->data_type)
- input_fd = Rast_open_old(input_map_name,mapset);
+ if (check_data_type != seg->data_type)
+ G_debug(1,
+ input_fd = Rast_open_old(input_map_name, mapset);
int min, max;
- seg->min=(double)min;
- seg->max=(double)max;
- else {
- Rast_get_fp_range_min_max(&map_fp_range, &(seg->min), &(seg->max));
+ seg->min = (double)min;
+ seg->max = (double)max;
+ else {
+ Rast_get_fp_range_min_max(&map_fp_range, &(seg->min),
+ &(seg->max));
+ target_buffer = Rast_allocate_buf(seg->data_type);
+ for (r = 0; r < seg->nrows; ++r) {
+ G_percent(r, seg->nrows, 2);
+ Rast_get_row(input_fd, input_buffer, r, input_data_type);
+ memset(target_buffer, 0, seg->ncols * seg->data_size);
+ for (c = 0; c < seg->ncols; ++c)
+ (input_pointer + c * input_data_size, input_data_type)) {
+ case CELL_TYPE:
+ ((CELL *) target_buffer)[c] =
+ input_data_type);
+ break;
+ case FCELL_TYPE:
+ ((FCELL *) target_buffer)[c] =
+ input_data_type);
+ break;
+ case DCELL_TYPE:
+ ((DCELL *) target_buffer)[c] =
+ input_data_type);
+ break;
+ default:
+ G_fatal_error(_("Wrong internal data type"));
+ break;
- /* end opening and checking */
- target_buffer=Rast_allocate_buf(seg->data_type);
+ if (0 > segment_put_row(&(seg->seg), target_buffer, r)) {
+ G_free(target_buffer);
+ Rast_close(input_fd);
+ G_fatal_error(_("seg_read: Cannot segment put row %d for map %s"),
+ r, input_map_name);
+ } /* end for row */
- for (r=0; r<seg->nrows; ++r) {
- G_percent(r, seg->nrows, 2);
- Rast_get_row(input_fd,input_buffer,r,input_data_type);
- memset(target_buffer,0,seg->ncols*seg->data_size);
- for (c = 0; c < seg->ncols; ++c)
- if(!Rast_is_null_value(input_pointer+c*input_data_size,input_data_type)) {
- case CELL_TYPE:
- ((CELL*)target_buffer)[c] =
- break;
- case FCELL_TYPE:
- ((FCELL*)target_buffer)[c] =
- break;
- case DCELL_TYPE:
- ((DCELL*)target_buffer)[c] =
- break;
- default:
- G_fatal_error(_("Wrong internal data type"));
- break;
+ seg->map_name = G_store(input_map_name);
+ seg->mapset = G_store(mapset);
- if(0>segment_put_row(&(seg->seg),target_buffer,r)) {
- G_free(target_buffer);
- Rast_close(input_fd);
- G_fatal_error(_("seg_read: Cannot segment put row %d for map %s"),
- r,input_map_name);
- } /* end for row */
- seg->map_name=G_store(input_map_name);
- seg->mapset=G_store(mapset);
- return 0;
+ return 0;
-int seg_reset_map (SEG* seg, int value) {
-int r,c;
- for (r=0;r<seg->nrows;++r)
- for (c=0;c<seg->ncols;++c)
-segment_put(&(seg->seg),&value,r,c);
+int seg_reset_map(SEG * seg, int value)
+ int r, c;
-int seg_write_map(SEG* seg, char* output_map_name, RASTER_MAP_TYPE output_data_type, int convert_to_null, double value) {
- * write seg to disk with output_map_name and output_data_type [CELL, FCELL, DCELL];
- int output_fd;
- int r, c;
- void* output_buffer;
- void* row;
+ segment_put(&(seg->seg), &value, r, c);
+int seg_write_map(SEG * seg, char *output_map_name,
+ double value)
+ * write seg to disk with output_map_name and output_data_type [CELL, FCELL, DCELL];
+ int output_fd;
+ int r, c;
+ void *output_buffer;
+ void *row;
output_data_type = seg->data_type;
- if(output_data_type != seg->data_type)
- output_fd=Rast_open_new(output_map_name,output_data_type);
- output_buffer=Rast_allocate_buf(output_data_type);
- segment_flush(&(seg->seg));
- /* writing */
- for(r=0;r<seg->nrows;++r) {
+ if (output_data_type != seg->data_type)
+ G_debug(1,
+ output_buffer = Rast_allocate_buf(output_data_type);
+ segment_flush(&(seg->seg));
+ /* writing */
- if(0>segment_get_row(&(seg->seg),output_buffer,r))
- G_warning(_("seg_write: Cannot segment read row %d for map %s"),
- r,output_map_name);
+ if (0 > segment_get_row(&(seg->seg), output_buffer, r))
+ G_warning(_("seg_write: Cannot segment read row %d for map %s"),
+ r, output_map_name);
- row = output_buffer;
- case CELL_TYPE:
- if (((CELL*)output_buffer)[c] == (CELL)value)
- Rast_set_c_null_value(row+c*(seg->data_size), 1);
- break;
- case FCELL_TYPE:
- if (((FCELL*)output_buffer)[c] == (FCELL)value)
- Rast_set_f_null_value(row+c*(seg->data_size), 1);
- break;
- case DCELL_TYPE:
- if (((DCELL*)output_buffer)[c] == (DCELL)value)
- Rast_set_d_null_value(row+c*(seg->data_size), 1);
- break;
- default:
- G_warning(_("ram_null:Cannot convert to null at: %d %d"),r,c);
+ row = output_buffer;
+ case CELL_TYPE:
+ if (((CELL *) output_buffer)[c] == (CELL) value)
+ Rast_set_c_null_value(row + c * (seg->data_size), 1);
+ break;
+ case FCELL_TYPE:
+ if (((FCELL *) output_buffer)[c] == (FCELL) value)
+ Rast_set_f_null_value(row + c * (seg->data_size), 1);
+ break;
+ case DCELL_TYPE:
+ if (((DCELL *) output_buffer)[c] == (DCELL) value)
+ Rast_set_d_null_value(row + c * (seg->data_size), 1);
+ break;
+ default:
+ G_warning(_("ram_null:Cannot convert to null at: %d %d"), r,
+ c);
Rast_put_row(output_fd, output_buffer, output_data_type);
- G_free(output_buffer);
- G_message(_("%s Done"), output_map_name);
- return 0;
+ G_free(output_buffer);
+ G_message(_("%s Done"), output_map_name);
+ return 0;
-int seg_release_map(SEG* seg) {
- * release segment close files, set pointers to null;
- segment_release(&(seg->seg));
- close(seg->fd);
- unlink(seg->filename);
+int seg_release_map(SEG * seg)
+ * release segment close files, set pointers to null;
+ segment_release(&(seg->seg));
+ close(seg->fd);
+ unlink(seg->filename);
- if(seg->map_name)
+ if (seg->map_name)
G_free(seg->map_name);
- if(seg->mapset)
+ if (seg->mapset)
G_free(seg->mapset);
-return 0;
+ return 0;
Modified: grass-addons/grass7/raster/r.stream/r.stream.snap/io.h
--- grass-addons/grass7/raster/r.stream/r.stream.snap/io.h 2011-02-26 07:53:29 UTC (rev 45459)
+++ grass-addons/grass7/raster/r.stream/r.stream.snap/io.h 2011-02-26 07:58:05 UTC (rev 45460)
@@ -16,39 +16,40 @@
#define SROWS 256
#define SCOLS 256
-typedef struct {
- void** map; /* matrix of data */
- double min, max; /* data range : may requre casting */
- int nrows, ncols;
- char* map_name; /* map name, unused */
- RASTER_MAP_TYPE data_type; /* type of data */
- size_t data_size; /* type of data */
+typedef struct
+ void **map; /* matrix of data */
+ double min, max; /* data range : may requre casting */
+ int nrows, ncols;
+ char *map_name; /* map name, unused */
+ RASTER_MAP_TYPE data_type; /* type of data */
+ size_t data_size; /* type of data */
} MAP;
-typedef struct {
- SEGMENT seg; /* segmented data store */
- int fd; /* segment temporary file name descriptor */
- char* filename; /* segment temporary file name */
- char* map_name; /* map name converted to segment */
- char* mapset;
- int nrows, ncols; /* store nrows and rcols */
- RASTER_MAP_TYPE data_type; /* data type of the map */
- size_t data_size; /* size of cell returned by sizeof */
- double min, max; /* data range */
+typedef struct
+ SEGMENT seg; /* segmented data store */
+ int fd; /* segment temporary file name descriptor */
+ char *filename; /* segment temporary file name */
+ char *map_name; /* map name converted to segment */
+ char *mapset;
+ int nrows, ncols; /* store nrows and rcols */
+ RASTER_MAP_TYPE data_type; /* data type of the map */
+ size_t data_size; /* size of cell returned by sizeof */
+ double min, max; /* data range */
} SEG;
/* all in ram functions */
-int ram_create_map(MAP*, RASTER_MAP_TYPE);
-int ram_read_map (MAP* , char*, int, RASTER_MAP_TYPE);
-int ram_reset_map (MAP*, int);
-int ram_write_map (MAP*, char*, RASTER_MAP_TYPE, int, double);
-int ram_destory_map(MAP*);
+int ram_create_map(MAP *, RASTER_MAP_TYPE);
+int ram_read_map(MAP *, char *, int, RASTER_MAP_TYPE);
+int ram_reset_map(MAP *, int);
+int ram_write_map(MAP *, char *, RASTER_MAP_TYPE, int, double);
+int ram_destory_map(MAP *);
/* memory swap functions */
-int seg_create_map(SEG*, int, int, int, RASTER_MAP_TYPE);
-int seg_read_map (SEG*, char*, int, RASTER_MAP_TYPE);
-int seg_reset_map (SEG*, int);
-int seg_write_map (SEG*, char*, RASTER_MAP_TYPE, int, double);
-int seg_release_map(SEG*);
+int seg_create_map(SEG *, int, int, int, RASTER_MAP_TYPE);
+int seg_read_map(SEG *, char *, int, RASTER_MAP_TYPE);
+int seg_reset_map(SEG *, int);
+int seg_write_map(SEG *, char *, RASTER_MAP_TYPE, int, double);
+int seg_release_map(SEG *);
Modified: grass-addons/grass7/raster/r.stream/r.stream.snap/local_proto.h
--- grass-addons/grass7/raster/r.stream/r.stream.snap/local_proto.h 2011-02-26 07:53:29 UTC (rev 45459)
+++ grass-addons/grass7/raster/r.stream/r.stream.snap/local_proto.h 2011-02-26 07:58:05 UTC (rev 45460)
@@ -1,3 +1,2 @@
#include "io.h"
#include "local_vars.h"
Modified: grass-addons/grass7/raster/r.stream/r.stream.snap/local_vars.h
--- grass-addons/grass7/raster/r.stream/r.stream.snap/local_vars.h 2011-02-26 07:53:29 UTC (rev 45459)
+++ grass-addons/grass7/raster/r.stream/r.stream.snap/local_vars.h 2011-02-26 07:58:05 UTC (rev 45460)
@@ -16,25 +16,19 @@
#define SQR(x) ((x) * (x))
-typedef struct {
- int r,c;
- int di,dj; /* shift */
- int cat;
- double accum;
- int stream;
- int status; /* 1=skipped,2=unresolved,3=snapped,4=correct */
+typedef struct
+ int r, c;
+ int di, dj; /* shift */
+ int cat;
+ double accum;
+ int stream;
+ int status; /* 1=skipped,2=unresolved,3=snapped,4=correct */
} OUTLET;
GLOBAL int nextr[9];
GLOBAL int nextc[9];
-GLOBAL OUTLET* points;
+GLOBAL OUTLET *points;
GLOBAL int nrows, ncols;
-GLOBAL float** distance_mask;
+GLOBAL float **distance_mask;
Modified: grass-addons/grass7/raster/r.stream/r.stream.snap/main.c
--- grass-addons/grass7/raster/r.stream/r.stream.snap/main.c 2011-02-26 07:53:29 UTC (rev 45459)
+++ grass-addons/grass7/raster/r.stream/r.stream.snap/main.c 2011-02-26 07:58:05 UTC (rev 45460)
@@ -1,3 +1,4 @@
* MODULE: r.stream.snap
@@ -24,123 +25,124 @@
int main(int argc, char *argv[])
- struct GModule *module;
- struct Option *in_points_opt,
- *in_points_cat_opt,
- *out_points_opt,
- *in_stream_opt,
- *in_accum_opt,
- *opt_accum_treshold,
- *opt_distance_treshold,
- *opt_swapsize;
- int snap_to_streams;
- int i;
- SEG map_dirs, map_streams, map_accum;
- SEGMENT *streams=NULL, *accum=NULL;
- int number_of_segs;
- int number_of_points;
- int radius;
- double accum_treshold;
- G_gisinit(argv[0]);
+ struct GModule *module;
+ struct Option *in_points_opt,
+ *in_points_cat_opt,
+ *out_points_opt,
+ *in_stream_opt,
+ *in_accum_opt,
+ *opt_accum_treshold, *opt_distance_treshold, *opt_swapsize;
- module = G_define_module();
- module->description = _("Delineate basins according user' input. \
+ int snap_to_streams;
+ int i;
+ SEG map_dirs, map_streams, map_accum;
+ SEGMENT *streams = NULL, *accum = NULL;
+ int number_of_segs;
+ int number_of_points;
+ int radius;
+ double accum_treshold;
+ G_gisinit(argv[0]);
+ module = G_define_module();
+ module->description = _("Delineate basins according user' input. \
Input can be stream network, point file with outlets or outlet coordinates");
- G_add_keyword("basins creation");
- in_points_opt = G_define_standard_option(G_OPT_V_INPUT);
- in_points_opt->description = _("Name of input vector points map");
- out_points_opt = G_define_standard_option(G_OPT_V_OUTPUT);
- out_points_opt->description = _("Name of output vector points map");
+ G_add_keyword("basins creation");
- in_stream_opt = G_define_standard_option(G_OPT_R_INPUT);
- in_stream_opt->key = "streams";
- in_stream_opt->required = NO;
- in_stream_opt->description = _("Name of stream map");
+ in_points_opt = G_define_standard_option(G_OPT_V_INPUT);
+ in_points_opt->description = _("Name of input vector points map");
- in_accum_opt = G_define_standard_option(G_OPT_R_INPUT);
- in_accum_opt->key = "accum";
- in_accum_opt->required = NO;
- in_accum_opt->description = _("Name of accumulation map");
+ out_points_opt = G_define_standard_option(G_OPT_V_OUTPUT);
+ out_points_opt->description = _("Name of output vector points map");
- opt_accum_treshold = G_define_option();
- opt_accum_treshold->key="accumtres";
- opt_accum_treshold->type = TYPE_DOUBLE;
- opt_accum_treshold->answer="-1";
- opt_accum_treshold->description =_("Minimum accumulation streshold to snap");
- opt_distance_treshold = G_define_option();
- opt_distance_treshold->key="radius";
- opt_distance_treshold->answer="1";
- opt_distance_treshold->type = TYPE_INTEGER;
- opt_distance_treshold->description =_("Maximum distance to snap (in cells)");
- opt_swapsize = G_define_option();
- opt_swapsize->key="memory";
- opt_swapsize->type = TYPE_INTEGER;
- opt_swapsize->answer = "300";
- opt_swapsize->required = NO;
- opt_swapsize->description =_("Max memory used (MB)");
+ in_stream_opt = G_define_standard_option(G_OPT_R_INPUT);
+ in_stream_opt->key = "streams";
+ in_stream_opt->required = NO;
+ in_stream_opt->description = _("Name of stream map");
+ in_accum_opt = G_define_standard_option(G_OPT_R_INPUT);
+ in_accum_opt->key = "accum";
+ in_accum_opt->required = NO;
+ in_accum_opt->description = _("Name of accumulation map");
+ opt_accum_treshold = G_define_option();
+ opt_accum_treshold->key = "accumtres";
+ opt_accum_treshold->type = TYPE_DOUBLE;
+ opt_accum_treshold->answer = "-1";
+ opt_accum_treshold->description =
+ _("Minimum accumulation streshold to snap");
+ opt_distance_treshold = G_define_option();
+ opt_distance_treshold->key = "radius";
+ opt_distance_treshold->answer = "1";
+ opt_distance_treshold->type = TYPE_INTEGER;
+ opt_distance_treshold->description =
+ _("Maximum distance to snap (in cells)");
+ opt_swapsize = G_define_option();
+ opt_swapsize->key = "memory";
+ opt_swapsize->type = TYPE_INTEGER;
+ opt_swapsize->answer = "300";
+ opt_swapsize->required = NO;
+ opt_swapsize->description = _("Max memory used (MB)");
if (G_parser(argc, argv)) /* parser */
exit(EXIT_FAILURE);
- number_of_segs = (int)atof(opt_swapsize->answer);
- number_of_segs < 32 ? (int)(32/0.12) : number_of_segs/0.12;
- radius=atoi(opt_distance_treshold->answer);
- accum_treshold=atof(opt_accum_treshold->answer);
+ number_of_segs = (int)atof(opt_swapsize->answer);
+ number_of_segs < 32 ? (int)(32 / 0.12) : number_of_segs / 0.12;
- nrows = Rast_window_rows();
- ncols = Rast_window_cols();
- if (G_legal_filename(out_points_opt->answer) < 0)
- G_fatal_error(_("<%s> is an illegal basin name"), out_points_opt->answer);
- if(!in_stream_opt->answer && !in_accum_opt->answer)
- G_fatal_error(_("At least one map of accumulation or streams is required"));
+ radius = atoi(opt_distance_treshold->answer);
+ accum_treshold = atof(opt_accum_treshold->answer);
- if(!in_accum_opt->answer)
- accum_treshold=-1;
- /* SEGMENT VERSION ONLY*/
- if(in_stream_opt->answer) {
- seg_create_map(&map_streams,SROWS, SCOLS, number_of_segs, CELL_TYPE);
- seg_read_map(&map_streams,in_stream_opt->answer,1,CELL_TYPE);
+ nrows = Rast_window_rows();
+ ncols = Rast_window_cols();
+ if (G_legal_filename(out_points_opt->answer) < 0)
+ G_fatal_error(_("<%s> is an illegal basin name"),
+ out_points_opt->answer);
+ if (!in_stream_opt->answer && !in_accum_opt->answer)
+ G_fatal_error(_("At least one map of accumulation or streams is required"));
+ if (!in_accum_opt->answer)
+ accum_treshold = -1;
+ /* SEGMENT VERSION ONLY */
+ if (in_stream_opt->answer) {
+ seg_create_map(&map_streams, SROWS, SCOLS, number_of_segs, CELL_TYPE);
+ seg_read_map(&map_streams, in_stream_opt->answer, 1, CELL_TYPE);
streams = &map_streams.seg;
- if(in_accum_opt->answer) {
- seg_create_map(&map_accum,SROWS, SCOLS, number_of_segs, DCELL_TYPE);
- seg_read_map(&map_accum,in_accum_opt->answer,0,-1);
+ if (in_accum_opt->answer) {
+ seg_create_map(&map_accum, SROWS, SCOLS, number_of_segs, DCELL_TYPE);
+ seg_read_map(&map_accum, in_accum_opt->answer, 0, -1);
accum = &map_accum.seg;
- create_distance_mask(radius);
- number_of_points=read_points(in_points_opt->answer, streams, accum);
+ create_distance_mask(radius);
+ number_of_points = read_points(in_points_opt->answer, streams, accum);
- for(i=0;i<number_of_points;++i)
- snap_point(&points[i],radius,streams,accum,accum_treshold);
- write_points(out_points_opt->answer,number_of_points);
+ for (i = 0; i < number_of_points; ++i)
+ snap_point(&points[i], radius, streams, accum, accum_treshold);
+ write_points(out_points_opt->answer, number_of_points);
G_message("AFTER %d %d %d %d",
- points[i].r,points[i].c,points[i].di,points[i].dj);
+ points[i].r, points[i].c, points[i].di, points[i].dj);
- seg_release_map (&map_streams);
- seg_release_map (&map_accum);
+ seg_release_map(&map_streams);
+ seg_release_map(&map_accum);
-exit(EXIT_SUCCESS);
+ exit(EXIT_SUCCESS);
Modified: grass-addons/grass7/raster/r.stream/r.stream.snap/points_io.c
--- grass-addons/grass7/raster/r.stream/r.stream.snap/points_io.c 2011-02-26 07:53:29 UTC (rev 45459)
+++ grass-addons/grass7/raster/r.stream/r.stream.snap/points_io.c 2011-02-26 07:58:05 UTC (rev 45460)
@@ -1,117 +1,120 @@
#include "local_proto.h"
-int read_points(char *in_point, SEGMENT* streams, SEGMENT* accum)
+int read_points(char *in_point, SEGMENT * streams, SEGMENT * accum)
- char *mapset;
- struct Cell_head window;
- struct Map_info Map;
- struct bound_box box;
- int num_point = 0;
- int total_points = 0;
- int type, i,j, cat;
- int r,c;
- struct line_pnts *sites;
- struct line_cats *cats;
- double absaccum;
- sites = Vect_new_line_struct();
- cats = Vect_new_cats_struct();
+ char *mapset;
+ struct Cell_head window;
+ struct Map_info Map;
+ struct bound_box box;
+ int num_point = 0;
+ int total_points = 0;
+ int type, i, j, cat;
+ int r, c;
+ struct line_pnts *sites;
+ struct line_cats *cats;
+ double absaccum;
- mapset = G_find_vector2(in_point, "");
+ sites = Vect_new_line_struct();
+ cats = Vect_new_cats_struct();
+ mapset = G_find_vector2(in_point, "");
G_fatal_error(_("Vector map <%s> not found"), in_point);
- if (Vect_open_old(&Map, in_point, mapset) < 0)
+ if (Vect_open_old(&Map, in_point, mapset) < 0)
G_fatal_error("Cannot open vector map <%s>", in_point);
- G_get_window(&window);
- Vect_region_box(&window, &box);
+ G_get_window(&window);
+ Vect_region_box(&window, &box);
- while ((type = Vect_read_next_line(&Map, sites, cats)) > -1) {
- if (type != GV_POINT)
- continue;
- if (Vect_point_in_box(sites->x[0], sites->y[0], sites->z[0], &box))
- num_point++;
+ while ((type = Vect_read_next_line(&Map, sites, cats)) > -1) {
+ if (type != GV_POINT)
+ continue;
+ if (Vect_point_in_box(sites->x[0], sites->y[0], sites->z[0], &box))
+ num_point++;
- points = (OUTLET *) G_malloc(num_point * sizeof(OUTLET));
- total_points=Vect_get_num_lines(&Map);
- i=0;
+ points = (OUTLET *) G_malloc(num_point * sizeof(OUTLET));
+ total_points = Vect_get_num_lines(&Map);
+ i = 0;
- for (j = 0; j < total_points; ++j) {
+ for (j = 0; j < total_points; ++j) {
- type = Vect_read_line(&Map, sites, cats,j+1);
- continue;
+ type = Vect_read_line(&Map, sites, cats, j + 1);
- if (!Vect_point_in_box(sites->x[0], sites->y[0], sites->z[0], &box))
- continue;
+ continue;
+ if (!Vect_point_in_box(sites->x[0], sites->y[0], sites->z[0], &box))
+ continue;
Vect_cat_get(cats, 1, &cat);
points[i].r = (int)Rast_northing_to_row(sites->y[0], &window);
points[i].c = (int)Rast_easting_to_col(sites->x[0], &window);
- points[i].di=0;
- points[i].dj=0;
+ points[i].di = 0;
+ points[i].dj = 0;
points[i].cat = cat;
- if(streams)
- segment_get(streams,&points[i].stream,points[i].r,points[i].c);
- else
- points[i].stream=0;
- if(accum) {
- segment_get(accum,&absaccum,points[i].r,points[i].c);
- points[i].accum=fabs(absaccum);
- } else {
- points[i].accum=0;
- points[i].status = 4; /* default status is 'correct' */
+ if (streams)
+ segment_get(streams, &points[i].stream, points[i].r, points[i].c);
+ else
+ points[i].stream = 0;
+ if (accum) {
+ segment_get(accum, &absaccum, points[i].r, points[i].c);
+ points[i].accum = fabs(absaccum);
+ else {
+ points[i].accum = 0;
+ points[i].status = 4; /* default status is 'correct' */
//dodać skip category
- i++;
- return num_point;
+ i++;
+ return num_point;
-int write_points(char* out_vector, int number_of_points) {
+int write_points(char *out_vector, int number_of_points)
- int i;
- int r,c;
- int cat_layer_1, cat_layer_2;
- float northing, easting;
- struct Map_info Out;
- struct line_pnts *Segments;
- struct line_cats *Cats;
- Segments = Vect_new_line_struct();
- Cats = Vect_new_cats_struct();
- Vect_open_new(&Out, out_vector, 0);
+ int i;
+ int r, c;
+ int cat_layer_1, cat_layer_2;
+ float northing, easting;
+ struct Map_info Out;
+ struct line_pnts *Segments;
+ struct line_cats *Cats;
+ Segments = Vect_new_line_struct();
+ Cats = Vect_new_cats_struct();
+ Vect_open_new(&Out, out_vector, 0);
+ Vect_reset_line(Segments);
+ Vect_reset_cats(Cats);
+ for (i = 0; i < number_of_points; ++i) {
+ r = points[i].r + points[i].di;
+ c = points[i].c + points[i].dj;
+ cat_layer_1 = points[i].cat;
+ cat_layer_2 = points[i].status;
+ Vect_cat_set(Cats, 1, cat_layer_1);
+ Vect_cat_set(Cats, 2, cat_layer_2);
+ easting = window.west + (c + .5) * window.ew_res;
+ northing = window.north - (r + .5) * window.ns_res;
+ Vect_append_point(Segments, easting, northing, 0);
+ Vect_write_line(&Out, GV_POINT, Segments, Cats);
- for (i=0;i<number_of_points;++i) {
- r = points[i].r+points[i].di;
- c = points[i].c+points[i].dj;
+ /* build vector */
+ Vect_hist_command(&Out);
+ Vect_build(&Out);
+ Vect_close(&Out);
- cat_layer_1=points[i].cat;
- cat_layer_2=points[i].status;
- Vect_cat_set(Cats,1,cat_layer_1);
- Vect_cat_set(Cats,2,cat_layer_2);
- easting = window.west + (c + .5) * window.ew_res;
- northing = window.north - (r + .5) * window.ns_res;
- Vect_append_point(Segments, easting,northing, 0);
- Vect_write_line(&Out, GV_POINT, Segments, Cats);
- Vect_reset_line(Segments);
- Vect_reset_cats(Cats);
-/* build vector */
-Vect_hist_command(&Out);
-Vect_build(&Out);
-Vect_close(&Out);
-return 0;
+ return 0;
Modified: grass-addons/grass7/raster/r.stream/r.stream.snap/snap.c
--- grass-addons/grass7/raster/r.stream/r.stream.snap/snap.c 2011-02-26 07:53:29 UTC (rev 45459)
+++ grass-addons/grass7/raster/r.stream/r.stream.snap/snap.c 2011-02-26 07:58:05 UTC (rev 45460)
@@ -2,139 +2,142 @@
#define SQRT(x) ((x) * (x))
static int num;
-int create_distance_mask(int radius) {
+int create_distance_mask(int radius)
- int i, j;
- int window=2*radius+1;
- distance_mask = G_malloc(window * sizeof(float *));
+ int i, j;
+ int window = 2 * radius + 1;
+ distance_mask = G_malloc(window * sizeof(float *));
for (i = 0; i < window; i++)
- distance_mask[i] = G_malloc(window *sizeof(float));
+ distance_mask[i] = G_malloc(window * sizeof(float));
for (j = 0; j < window; j++)
- distance_mask[i][j] =
- (SQR(i - radius) + SQR(j - radius)<= SQR(radius)) ?
- sqrt(SQR(i - radius) + SQR(j - radius)) : 0;
+ distance_mask[i][j] =
+ (SQR(i - radius) + SQR(j - radius) <= SQR(radius)) ?
+ sqrt(SQR(i - radius) + SQR(j - radius)) : 0;
- return 0;
+ return 0;
-int snap_point(OUTLET *point, int radius, SEGMENT* streams, SEGMENT* accum, double accum_treshold) {
- int i,j,di=-1,dj=-1;
- int status=3;
- int number_of_cells=radius*radius;
- int teststream=0;
- float cur_distance=radius;
- float distance=0;
- double absaccum=0;
- double sumaccum=0;
- double maxaccum=0;
- int naccum=-1;
- if(point->stream>0 && point->accum>accum_treshold)
- return 0; /* point lies on line(or skipped) and has proper treshold */
+int snap_point(OUTLET * point, int radius, SEGMENT * streams, SEGMENT * accum,
+ double accum_treshold)
-if(streams) {
+ int i, j, di = -1, dj = -1;
+ int status = 3;
+ int number_of_cells = radius * radius;
+ int teststream = 0;
+ float cur_distance = radius;
+ float distance = 0;
+ double absaccum = 0;
+ double sumaccum = 0;
+ double maxaccum = 0;
+ int naccum = -1;
+ if (point->stream > 0 && point->accum > accum_treshold)
+ return 0; /* point lies on line(or skipped) and has proper treshold */
+ if (streams) {
/* stream version: assume ve have stream network and points
* are snapped to stream points where accum is greater than treshold
* or to nearest stream point in accum is not supplied */
- for(i=-radius; i<=radius; ++i)
- for(j=-radius; j<=radius; ++j) {
- if(point->r+i<0 || point->r+i>=nrows ||
- point->c+j<0 || point->c+j>=ncols)
- continue;
- if(!distance_mask[i+radius][j+radius])
- continue;
- segment_get(streams,&teststream,point->r+i,point->c+j);
- distance=distance_mask[i+radius][j+radius];
- if(teststream) { /* is stream line */
+ for (i = -radius; i <= radius; ++i)
+ for (j = -radius; j <= radius; ++j) {
- if(accum) {
- segment_get(accum,&absaccum,point->r+i,point->c+j);
- absaccum=fabs(absaccum);
+ if (point->r + i < 0 || point->r + i >= nrows ||
+ point->c + j < 0 || point->c + j >= ncols)
+ continue;
- if(absaccum>=accum_treshold) /* if no accum absaccum always =-1 */
- if(cur_distance>distance) {
- cur_distance=distance;
- di=i;
- dj=j;
+ if (!distance_mask[i + radius][j + radius])
+ continue;
+ segment_get(streams, &teststream, point->r + i, point->c + j);
+ distance = distance_mask[i + radius][j + radius];
+ if (teststream) { /* is stream line */
+ if (accum) {
+ segment_get(accum, &absaccum, point->r + i,
+ point->c + j);
+ absaccum = fabs(absaccum);
+ if (absaccum >= accum_treshold) /* if no accum absaccum always =-1 */
+ if (cur_distance > distance) {
+ cur_distance = distance;
+ di = i;
+ dj = j;
-} /* end of streams version */
+ } /* end of streams version */
-if(!streams) {
- /* no stream version: problem for MFD. the snap point is found
- * in different manner. It is not only point where accum exceed the
- * treshold (may be far for potential streamline) but must exceed the
- * mean value of accums in searach area taken in cells where treshold is exceeded */
+ if (!streams) {
+ /* no stream version: problem for MFD. the snap point is found
+ * in different manner. It is not only point where accum exceed the
+ * treshold (may be far for potential streamline) but must exceed the
+ * mean value of accums in searach area taken in cells where treshold is exceeded */
- continue;
- continue;
+ continue;
- if(absaccum>maxaccum)
- maxaccum=absaccum;
- if(absaccum>accum_treshold) {
- sumaccum+=absaccum;
- naccum++;
+ continue;
+ segment_get(accum, &absaccum, point->r + i, point->c + j);
+ if (absaccum > maxaccum)
+ maxaccum = absaccum;
+ if (absaccum > accum_treshold) {
+ sumaccum += absaccum;
+ naccum++;
- if(sumaccum>0)
- /* accum_treshold=(sumaccum/naccum+maxaccum)/2 */;
- accum_treshold=sumaccum/naccum;
+ if (sumaccum > 0)
+ /* accum_treshold=(sumaccum/naccum+maxaccum)/2 */ ;
+ accum_treshold = sumaccum / naccum;
- if(point->r+i<0 || point->r+i>=nrows || point->c+j<0 || point->c+j>=ncols)
- continue;
- continue;
+ continue;
- if(accum_treshold >0 && absaccum>accum_treshold)
- di=i;
- dj=j;
-}/* end of non-streams version */
- if(di==-1&&dj==-1){
+ continue;
+ if (accum_treshold > 0 && absaccum > accum_treshold)
+ di = i;
+ dj = j;
+ } /* end of non-streams version */
+ if (di == -1 && dj == -1) {
G_warning(_("cannot snap point with cat %d, in a given radius. \
- Increase search radius"),point->cat);
- di=0;
- dj=0;
- status=2;
- point->di=di;
- point->dj=dj;
- point->status=status;
- return 0;
+ Increase search radius"), point->cat);
+ di = 0;
+ dj = 0;
+ status = 2;
+ point->di = di;
+ point->dj = dj;
+ point->status = status;
+ return 0;
