[GRASS-SVN] r45471 - grass/branches/develbranch_6
svn_grass at osgeo.org
Sun Feb 27 06:09:51 EST 2011
Author: martinl
Date: 2011-02-27 03:09:51 -0800 (Sun, 27 Feb 2011)
New Revision: 45471
grass/branches/develbranch_6/configure
grass/branches/develbranch_6/configure.in
fix configure script: check geos_c_i instead of geos_c when mingw is used
Modified: grass/branches/develbranch_6/configure
--- grass/branches/develbranch_6/configure 2011-02-27 10:13:50 UTC (rev 45470)
+++ grass/branches/develbranch_6/configure 2011-02-27 11:09:51 UTC (rev 45471)
@@ -8267,7 +8267,113 @@
CPPFLAGS=$ac_save_cppflags
- #LOC_CHECK_LIBS(geos_c,initGEOS,GEOS,$GEOS_LIBS,GEOS_LIBS)
+ if test "$MINGW32" = yes ; then
+ac_save_ldflags="$LDFLAGS"
+LDFLAGS="$GEOS_LIBS $LDFLAGS"
+echo $ac_n "checking for initGEOS in -lgeos_c_i""... $ac_c" 1>&6
+echo "configure:8278: checking for initGEOS in -lgeos_c_i" >&5
+ac_lib_var=`echo geos_c_i'_'initGEOS | sed 'y%./+-%__p_%'`
+ac_save_LIBS="$LIBS"
+LIBS="-lgeos_c_i $LIBS"
+cat > conftest.$ac_ext <<EOF
+#line 8284 "configure"
+#include "confdefs.h"
+/* Override any gcc2 internal prototype to avoid an error. */
+/* We use char because int might match the return type of a gcc2
+ builtin and then its argument prototype would still apply. */
+char initGEOS();
+int main() {
+initGEOS()
+; return 0; }
+EOF
+if { (eval echo configure:8295: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+ rm -rf conftest*
+ eval "ac_cv_lib_$ac_lib_var=yes"
+else
+ echo "configure: failed program was:" >&5
+ cat conftest.$ac_ext >&5
+ rm -rf conftest*
+ eval "ac_cv_lib_$ac_lib_var=no"
+fi
+rm -f conftest*
+LIBS="$ac_save_LIBS"
+if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
+ echo "$ac_t""yes" 1>&6
+ GEOS_LIBS="$GEOS_LIBS -lgeos_c_i "
+else
+ echo "$ac_t""no" 1>&6
+LDFLAGS=${ac_save_ldflags}
+ { echo "configure: error: *** Unable to locate GEOS library." 1>&2; exit 1; }
+fi
+ else
+echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
+echo "configure:8331: checking for initGEOS in -lgeos_c" >&5
+ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
+LIBS="-lgeos_c $LIBS"
+#line 8337 "configure"
+char initGEOS();
+int main() {
+initGEOS()
+; return 0; }
+EOF
+if { (eval echo configure:8348: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+ rm -rf conftest*
+else
+ rm -rf conftest*
+fi
+rm -f conftest*
+ GEOS_LIBS="$GEOS_LIBS -lgeos_c "
+else
+fi
+ fi
cat >> confdefs.h <<\EOF
#define HAVE_GEOS 1
EOF
@@ -8282,7 +8388,7 @@
echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:8286: checking whether to use TIFF" >&5
+echo "configure:8392: checking whether to use TIFF" >&5
echo "$ac_t"""$with_tiff"" 1>&6
case "$with_tiff" in
"no") USE_TIFF= ;;
@@ -8302,7 +8408,7 @@
echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:8306: checking for location of TIFF includes" >&5
+echo "configure:8412: checking for location of TIFF includes" >&5
case "$with_tiff_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -8328,15 +8434,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:8332: checking for $ac_hdr" >&5
+echo "configure:8438: checking for $ac_hdr" >&5
-#line 8335 "configure"
+#line 8441 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:8340: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8446: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -8370,7 +8476,7 @@
echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:8374: checking for location of TIFF library" >&5
+echo "configure:8480: checking for location of TIFF library" >&5
case "$with_tiff_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -8401,13 +8507,13 @@
echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:8405: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8511: checking for TIFFOpen in -ltiff" >&5
ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
LIBS="-ltiff $LIBS"
-#line 8411 "configure"
+#line 8517 "configure"
@@ -8418,7 +8524,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8422: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8528: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8437,13 +8543,13 @@
-echo "configure:8441: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8547: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $MATHLIB $LIBS"
-#line 8447 "configure"
+#line 8553 "configure"
@@ -8454,7 +8560,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8458: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8564: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8473,13 +8579,13 @@
-echo "configure:8477: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8583: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $LIBS"
-#line 8483 "configure"
+#line 8589 "configure"
@@ -8490,7 +8596,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8494: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8600: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8509,13 +8615,13 @@
-echo "configure:8513: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8619: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 8519 "configure"
+#line 8625 "configure"
@@ -8526,7 +8632,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8530: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8636: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8545,13 +8651,13 @@
-echo "configure:8549: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8655: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 8555 "configure"
+#line 8661 "configure"
@@ -8562,7 +8668,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8566: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8672: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8581,13 +8687,13 @@
-echo "configure:8585: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8691: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 8591 "configure"
+#line 8697 "configure"
@@ -8598,7 +8704,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8602: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8708: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8617,13 +8723,13 @@
-echo "configure:8621: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8727: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 8627 "configure"
+#line 8733 "configure"
@@ -8634,7 +8740,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8638: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8744: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8653,13 +8759,13 @@
-echo "configure:8657: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8763: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 8663 "configure"
+#line 8769 "configure"
@@ -8670,7 +8776,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8674: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8780: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8768,7 +8874,7 @@
echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8772: checking whether to use PNG" >&5
+echo "configure:8878: checking whether to use PNG" >&5
echo "$ac_t"""$with_png"" 1>&6
case "$with_png" in
"no") USE_PNG= ;;
@@ -8787,7 +8893,7 @@
echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8791: checking for location of PNG includes" >&5
+echo "configure:8897: checking for location of PNG includes" >&5
case "$with_png_includes" in
{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8813,15 +8919,15 @@
do
-echo "configure:8817: checking for $ac_hdr" >&5
+echo "configure:8923: checking for $ac_hdr" >&5
-#line 8820 "configure"
+#line 8926 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8825: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8931: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8855,7 +8961,7 @@
echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:8859: checking for location of PNG library" >&5
+echo "configure:8965: checking for location of PNG library" >&5
case "$with_png_libs" in
{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -8880,13 +8986,13 @@
echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:8884: checking for png_read_image in -lpng" >&5
+echo "configure:8990: checking for png_read_image in -lpng" >&5
ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 8890 "configure"
+#line 8996 "configure"
@@ -8897,7 +9003,7 @@
png_read_image()
; return 0; }
EOF
-if { (eval echo configure:8901: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9007: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8939,7 +9045,7 @@
echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:8943: checking whether to use PostgreSQL" >&5
+echo "configure:9049: checking whether to use PostgreSQL" >&5
echo "$ac_t"""$with_postgres"" 1>&6
case "$with_postgres" in
"no") USE_POSTGRES= ;;
@@ -8966,7 +9072,7 @@
echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:8970: checking for location of PostgreSQL includes" >&5
+echo "configure:9076: checking for location of PostgreSQL includes" >&5
case "$with_postgres_includes" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -8992,15 +9098,15 @@
do
-echo "configure:8996: checking for $ac_hdr" >&5
+echo "configure:9102: checking for $ac_hdr" >&5
-#line 8999 "configure"
+#line 9105 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9004: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9110: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9038,7 +9144,7 @@
echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:9042: checking for location of PostgreSQL library" >&5
+echo "configure:9148: checking for location of PostgreSQL library" >&5
case "$with_postgres_libs" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -9067,13 +9173,13 @@
echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:9071: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9177: checking for PQsetdbLogin in -lpq" >&5
ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 9077 "configure"
+#line 9183 "configure"
@@ -9084,7 +9190,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9088: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9194: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9103,13 +9209,13 @@
-echo "configure:9107: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9213: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 9113 "configure"
+#line 9219 "configure"
@@ -9120,7 +9226,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9124: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9230: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9139,13 +9245,13 @@
-echo "configure:9143: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9249: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt $LIBS"
-#line 9149 "configure"
+#line 9255 "configure"
@@ -9156,7 +9262,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9160: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9266: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9175,13 +9281,13 @@
-echo "configure:9179: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9285: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9185 "configure"
+#line 9291 "configure"
@@ -9192,7 +9298,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9196: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9302: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9249,13 +9355,13 @@
LDFLAGS="$LDFLAGS $PQLIBPATH"
echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9253: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9359: checking for PQcmdTuples in -lpq" >&5
ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 9259 "configure"
+#line 9365 "configure"
@@ -9266,7 +9372,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9270: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9376: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9288,13 +9394,13 @@
-echo "configure:9292: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9398: checking for PQcmdTuples in -lpq" >&5
-#line 9298 "configure"
+#line 9404 "configure"
@@ -9305,7 +9411,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9309: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9415: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9348,7 +9454,7 @@
echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9352: checking whether to use MySQL" >&5
+echo "configure:9458: checking whether to use MySQL" >&5
echo "$ac_t"""$with_mysql"" 1>&6
case "$with_mysql" in
"no") USE_MYSQL= ;;
@@ -9368,7 +9474,7 @@
echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9372: checking for location of MySQL includes" >&5
+echo "configure:9478: checking for location of MySQL includes" >&5
case "$with_mysql_includes" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9394,15 +9500,15 @@
do
-echo "configure:9398: checking for $ac_hdr" >&5
+echo "configure:9504: checking for $ac_hdr" >&5
-#line 9401 "configure"
+#line 9507 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9406: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9512: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9439,7 +9545,7 @@
echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9443: checking for location of MySQL library" >&5
+echo "configure:9549: checking for location of MySQL library" >&5
case "$with_mysql_libs" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9470,13 +9576,13 @@
echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9474: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9580: checking for mysql_query in -lmysqlclient" >&5
ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
LIBS="-lmysqlclient $LIBS"
-#line 9480 "configure"
+#line 9586 "configure"
@@ -9487,7 +9593,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9491: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9597: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9506,13 +9612,13 @@
-echo "configure:9510: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9616: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9516 "configure"
+#line 9622 "configure"
@@ -9523,7 +9629,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9527: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9633: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9542,13 +9648,13 @@
-echo "configure:9546: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9652: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9552 "configure"
+#line 9658 "configure"
@@ -9559,7 +9665,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9563: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9669: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9578,13 +9684,13 @@
-echo "configure:9582: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9688: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9588 "configure"
+#line 9694 "configure"
@@ -9595,7 +9701,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9599: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9705: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9614,13 +9720,13 @@
-echo "configure:9618: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9724: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9624 "configure"
+#line 9730 "configure"
@@ -9631,7 +9737,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9635: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9741: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9650,13 +9756,13 @@
-echo "configure:9654: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9760: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 9660 "configure"
+#line 9766 "configure"
@@ -9667,7 +9773,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9671: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9777: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9686,13 +9792,13 @@
-echo "configure:9690: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9796: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 9696 "configure"
+#line 9802 "configure"
@@ -9703,7 +9809,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9707: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9813: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9722,13 +9828,13 @@
-echo "configure:9726: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9832: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 9732 "configure"
+#line 9838 "configure"
@@ -9739,7 +9845,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9743: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9849: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9829,7 +9935,7 @@
# Extract the first word of "mysql_config", so it can be a program name with args.
set dummy mysql_config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:9833: checking for $ac_word" >&5
+echo "configure:9939: checking for $ac_word" >&5
case "$MYSQLD_CONFIG" in
@@ -9870,10 +9976,10 @@
LIBS="$MYSQLDLIB $LIBS"
echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:9874: checking for mysql_server_init" >&5
+echo "configure:9980: checking for mysql_server_init" >&5
-#line 9877 "configure"
+#line 9983 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char mysql_server_init(); below. */
@@ -9896,7 +10002,7 @@
; return 0; }
EOF
-if { (eval echo configure:9900: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10006: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_mysql_server_init=yes"
else
@@ -9934,7 +10040,7 @@
echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:9938: checking whether to use SQLite" >&5
+echo "configure:10044: checking whether to use SQLite" >&5
echo "$ac_t"""$with_sqlite"" 1>&6
case "$with_sqlite" in
"no") USE_SQLITE= ;;
@@ -9954,7 +10060,7 @@
echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:9958: checking for location of SQLite includes" >&5
+echo "configure:10064: checking for location of SQLite includes" >&5
case "$with_sqlite_includes" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -9980,15 +10086,15 @@
do
-echo "configure:9984: checking for $ac_hdr" >&5
+echo "configure:10090: checking for $ac_hdr" >&5
-#line 9987 "configure"
+#line 10093 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9992: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10098: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10031,7 +10137,7 @@
echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:10035: checking for location of SQLite library" >&5
+echo "configure:10141: checking for location of SQLite library" >&5
case "$with_sqlite_libs" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -10060,13 +10166,13 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:10064: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10170: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
LIBS="-lsqlite3 $LIBS"
-#line 10070 "configure"
+#line 10176 "configure"
@@ -10077,7 +10183,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10081: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10187: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10096,13 +10202,13 @@
-echo "configure:10100: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10206: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 10106 "configure"
+#line 10212 "configure"
@@ -10113,7 +10219,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10117: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10223: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10132,13 +10238,13 @@
-echo "configure:10136: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10242: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 10142 "configure"
+#line 10248 "configure"
@@ -10149,7 +10255,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10153: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10259: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10168,13 +10274,13 @@
-echo "configure:10172: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10278: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 10178 "configure"
+#line 10284 "configure"
@@ -10185,7 +10291,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10189: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10295: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10254,7 +10360,7 @@
echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10258: checking whether to use FFMPEG" >&5
+echo "configure:10364: checking whether to use FFMPEG" >&5
echo "$ac_t"""$with_ffmpeg"" 1>&6
case "$with_ffmpeg" in
"no") USE_FFMPEG= ;;
@@ -10274,7 +10380,7 @@
echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10278: checking for location of FFMPEG includes" >&5
+echo "configure:10384: checking for location of FFMPEG includes" >&5
case "$with_ffmpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10300,15 +10406,15 @@
do
-echo "configure:10304: checking for $ac_hdr" >&5
+echo "configure:10410: checking for $ac_hdr" >&5
-#line 10307 "configure"
+#line 10413 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10312: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10418: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10344,15 +10450,15 @@
do
-echo "configure:10348: checking for $ac_hdr" >&5
+echo "configure:10454: checking for $ac_hdr" >&5
-#line 10351 "configure"
+#line 10457 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10356: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10462: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10388,15 +10494,15 @@
do
-echo "configure:10392: checking for $ac_hdr" >&5
+echo "configure:10498: checking for $ac_hdr" >&5
-#line 10395 "configure"
+#line 10501 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10400: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10506: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10439,7 +10545,7 @@
echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10443: checking for location of FFMPEG library" >&5
+echo "configure:10549: checking for location of FFMPEG library" >&5
case "$with_ffmpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10466,13 +10572,13 @@
echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10470: checking for av_free in -lavutil" >&5
+echo "configure:10576: checking for av_free in -lavutil" >&5
ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
LIBS="-lavutil $LIBS"
-#line 10476 "configure"
+#line 10582 "configure"
@@ -10483,7 +10589,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:10487: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10593: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10502,13 +10608,13 @@
-echo "configure:10506: checking for av_free in -lavutil" >&5
+echo "configure:10612: checking for av_free in -lavutil" >&5
LIBS="-lavutil $MATHLIB $LIBS"
-#line 10512 "configure"
+#line 10618 "configure"
@@ -10519,7 +10625,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:10523: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10629: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10564,13 +10670,13 @@
echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10568: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10674: checking for avcodec_init in -lavcodec" >&5
ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
LIBS="-lavcodec $FFMPEGLIB $LIBS"
-#line 10574 "configure"
+#line 10680 "configure"
@@ -10581,7 +10687,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:10585: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10691: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10600,13 +10706,13 @@
-echo "configure:10604: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10710: checking for avcodec_init in -lavcodec" >&5
LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 10610 "configure"
+#line 10716 "configure"
@@ -10617,7 +10723,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:10621: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10727: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10662,13 +10768,13 @@
echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:10666: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10772: checking for av_set_parameters in -lavformat" >&5
ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
LIBS="-lavformat $FFMPEGLIB $LIBS"
-#line 10672 "configure"
+#line 10778 "configure"
@@ -10679,7 +10785,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:10683: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10789: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10698,13 +10804,13 @@
-echo "configure:10702: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10808: checking for av_set_parameters in -lavformat" >&5
LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 10708 "configure"
+#line 10814 "configure"
@@ -10715,7 +10821,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:10719: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10825: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10774,7 +10880,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:10778: checking whether to use OpenGL" >&5
+echo "configure:10884: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -10808,7 +10914,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:10812: checking for location of OpenGL includes" >&5
+echo "configure:10918: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -10834,15 +10940,15 @@
do
-echo "configure:10838: checking for $ac_hdr" >&5
+echo "configure:10944: checking for $ac_hdr" >&5
-#line 10841 "configure"
+#line 10947 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10846: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10952: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10876,7 +10982,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:10880: checking for location of OpenGL library" >&5
+echo "configure:10986: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -10905,13 +11011,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:10909: checking for glBegin in -lGL" >&5
+echo "configure:11015: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 10915 "configure"
+#line 11021 "configure"
@@ -10922,7 +11028,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11032: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10941,13 +11047,13 @@
-echo "configure:10945: checking for glBegin in -lGL" >&5
+echo "configure:11051: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 10951 "configure"
+#line 11057 "configure"
@@ -10958,7 +11064,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10962: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11068: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10977,13 +11083,13 @@
-echo "configure:10981: checking for glBegin in -lGL" >&5
+echo "configure:11087: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 10987 "configure"
+#line 11093 "configure"
@@ -10994,7 +11100,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10998: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11104: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11013,13 +11119,13 @@
-echo "configure:11017: checking for glBegin in -lGL" >&5
+echo "configure:11123: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 11023 "configure"
+#line 11129 "configure"
@@ -11030,7 +11136,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11034: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11140: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11092,13 +11198,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:11096: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11202: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 11102 "configure"
+#line 11208 "configure"
@@ -11109,7 +11215,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:11113: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11219: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11128,13 +11234,13 @@
-echo "configure:11132: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11238: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11138 "configure"
+#line 11244 "configure"
@@ -11145,7 +11251,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:11149: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11255: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11189,10 +11295,10 @@
LDFLAGS="$LDFLAGS $OPENGLLIB"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11193: checking for glXCreatePbuffer" >&5
+echo "configure:11299: checking for glXCreatePbuffer" >&5
-#line 11196 "configure"
+#line 11302 "configure"
which can conflict with char glXCreatePbuffer(); below. */
@@ -11215,7 +11321,7 @@
; return 0; }
EOF
-if { (eval echo configure:11219: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11325: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -11237,10 +11343,10 @@
fi
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11241: checking for glXCreateGLXPixmap" >&5
+echo "configure:11347: checking for glXCreateGLXPixmap" >&5
-#line 11244 "configure"
+#line 11350 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -11263,7 +11369,7 @@
; return 0; }
EOF
-if { (eval echo configure:11267: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11373: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -11302,7 +11408,7 @@
-echo "configure:11306: checking for location of OpenGL includes" >&5
+echo "configure:11412: checking for location of OpenGL includes" >&5
@@ -11328,15 +11434,15 @@
do
-echo "configure:11332: checking for $ac_hdr" >&5
+echo "configure:11438: checking for $ac_hdr" >&5
-#line 11335 "configure"
+#line 11441 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11340: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11446: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11371,10 +11477,10 @@
LDFLAGS="$with_opengl_libs $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11375: checking for glBegin" >&5
+echo "configure:11481: checking for glBegin" >&5
-#line 11378 "configure"
+#line 11484 "configure"
which can conflict with char glBegin(); below. */
@@ -11397,7 +11503,7 @@
; return 0; }
EOF
-if { (eval echo configure:11401: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11507: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -11412,10 +11518,10 @@
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11416: checking for gluBeginCurve" >&5
+echo "configure:11522: checking for gluBeginCurve" >&5
-#line 11419 "configure"
+#line 11525 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -11438,7 +11544,7 @@
; return 0; }
EOF
-if { (eval echo configure:11442: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11548: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -11482,7 +11588,7 @@
-echo "configure:11486: checking for location of OpenGL includes" >&5
+echo "configure:11592: checking for location of OpenGL includes" >&5
@@ -11508,15 +11614,15 @@
do
-echo "configure:11512: checking for $ac_hdr" >&5
+echo "configure:11618: checking for $ac_hdr" >&5
-#line 11515 "configure"
+#line 11621 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11520: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11626: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11550,7 +11656,7 @@
-echo "configure:11554: checking for location of OpenGL library" >&5
+echo "configure:11660: checking for location of OpenGL library" >&5
@@ -11575,18 +11681,18 @@
ac_save_libs="$LIBS"
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11579: checking for OpenGL library" >&5
+echo "configure:11685: checking for OpenGL library" >&5
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
LIBS="-lopengl32 "
-#line 11583 "configure"
+#line 11689 "configure"
#include <GL/gl.h>
int main() {
glEnd();
; return 0; }
EOF
-if { (eval echo configure:11590: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11696: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
@@ -11610,18 +11716,18 @@
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11614: checking for GLU library" >&5
+echo "configure:11720: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB "
-#line 11618 "configure"
+#line 11724 "configure"
#include <GL/glu.h>
int main() {
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:11625: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11731: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -11670,7 +11776,7 @@
echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:11674: checking whether to use Tcl/Tk" >&5
+echo "configure:11780: checking whether to use Tcl/Tk" >&5
echo "$ac_t"""$with_tcltk"" 1>&6
case "$with_tcltk" in
"no") USE_TCLTK= ;;
@@ -11690,7 +11796,7 @@
echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:11694: checking for location of Tcl/Tk includes" >&5
+echo "configure:11800: checking for location of Tcl/Tk includes" >&5
case "$with_tcltk_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -11716,15 +11822,15 @@
do
-echo "configure:11720: checking for $ac_hdr" >&5
+echo "configure:11826: checking for $ac_hdr" >&5
-#line 11723 "configure"
+#line 11829 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11728: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11834: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11761,15 +11867,15 @@
do
-echo "configure:11765: checking for $ac_hdr" >&5
+echo "configure:11871: checking for $ac_hdr" >&5
-#line 11768 "configure"
+#line 11874 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11773: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11879: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11802,7 +11908,7 @@
# Tcl/Tk version checks
echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:11806: checking Tcl version" >&5
+echo "configure:11912: checking Tcl version" >&5
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$TCLINCDIR $CPPFLAGS"
if test "$cross_compiling" = yes; then
@@ -11810,7 +11916,7 @@
echo "$ac_t""unknown (cross-compiling)" 1>&6
else
-#line 11814 "configure"
+#line 11920 "configure"
#include <stdio.h>
@@ -11822,7 +11928,7 @@
EOF
-if { (eval echo configure:11826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11932: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tcl_ver=`cat conftestdata`
echo "$ac_t""$tcl_ver" 1>&6
@@ -11840,7 +11946,7 @@
echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:11844: checking Tk version" >&5
+echo "configure:11950: checking Tk version" >&5
CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -11848,7 +11954,7 @@
else
-#line 11852 "configure"
+#line 11958 "configure"
#include <stdio.h>
@@ -11860,7 +11966,7 @@
EOF
-if { (eval echo configure:11864: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tk_ver=`cat conftestdata`
echo "$ac_t""$tk_ver" 1>&6
@@ -11891,7 +11997,7 @@
echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:11895: checking for location of Tcl/Tk library" >&5
+echo "configure:12001: checking for location of Tcl/Tk library" >&5
case "$with_tcltk_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -11931,13 +12037,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:11935: checking for Tcl_Init in -ltcl" >&5
+echo "configure:12041: checking for Tcl_Init in -ltcl" >&5
ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl $MATHLIB $LIBS"
-#line 11941 "configure"
+#line 12047 "configure"
@@ -11948,7 +12054,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11952: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12058: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11967,13 +12073,13 @@
-echo "configure:11971: checking for Tcl_Init in -ltcl" >&5
+echo "configure:12077: checking for Tcl_Init in -ltcl" >&5
LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 11977 "configure"
+#line 12083 "configure"
@@ -11984,7 +12090,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11988: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12094: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12011,13 +12117,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:12015: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:12121: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 12021 "configure"
+#line 12127 "configure"
@@ -12028,7 +12134,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12032: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12138: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12047,13 +12153,13 @@
-echo "configure:12051: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:12157: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 12057 "configure"
+#line 12163 "configure"
@@ -12064,7 +12170,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12068: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12174: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12091,13 +12197,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:12095: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:12201: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 12101 "configure"
+#line 12207 "configure"
@@ -12108,7 +12214,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12112: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12218: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12127,13 +12233,13 @@
-echo "configure:12131: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:12237: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 12137 "configure"
+#line 12243 "configure"
@@ -12144,7 +12250,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12148: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12254: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12222,13 +12328,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:12226: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:12332: checking for Tk_MainWindow in -ltk" >&5
ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 12232 "configure"
+#line 12338 "configure"
@@ -12239,7 +12345,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12243: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12349: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12258,13 +12364,13 @@
-echo "configure:12262: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:12368: checking for Tk_MainWindow in -ltk" >&5
LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12268 "configure"
+#line 12374 "configure"
@@ -12275,7 +12381,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12279: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12385: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12302,13 +12408,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:12306: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:12412: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 12312 "configure"
+#line 12418 "configure"
@@ -12319,7 +12425,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12323: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12429: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12338,13 +12444,13 @@
-echo "configure:12342: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:12448: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12348 "configure"
+#line 12454 "configure"
@@ -12355,7 +12461,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12359: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12465: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12382,13 +12488,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:12386: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12492: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 12392 "configure"
+#line 12498 "configure"
@@ -12399,7 +12505,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12403: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12509: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12418,13 +12524,13 @@
-echo "configure:12422: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12528: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12428 "configure"
+#line 12534 "configure"
@@ -12435,7 +12541,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12439: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12545: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12525,13 +12631,13 @@
do
# add only if in MACOSX_ARCHS
echo $ac_n "checking for Tcl_Init in -l$tlib""... $ac_c" 1>&6
-echo "configure:12529: checking for Tcl_Init in -l$tlib" >&5
+echo "configure:12635: checking for Tcl_Init in -l$tlib" >&5
ac_lib_var=`echo $tlib'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-l$tlib -arch $a $MACOSX_SDK $TCLTKLIBPATH $LIBS"
-#line 12535 "configure"
+#line 12641 "configure"
@@ -12542,7 +12648,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12546: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12652: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12591,7 +12697,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:12595: checking whether to use ODBC" >&5
+echo "configure:12701: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -12610,7 +12716,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:12614: checking for location of ODBC includes" >&5
+echo "configure:12720: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -12636,15 +12742,15 @@
do
-echo "configure:12640: checking for $ac_hdr" >&5
+echo "configure:12746: checking for $ac_hdr" >&5
-#line 12643 "configure"
+#line 12749 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12648: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12754: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12678,7 +12784,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:12682: checking for location of ODBC library" >&5
+echo "configure:12788: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -12703,13 +12809,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:12707: checking for SQLConnect in -lodbc" >&5
+echo "configure:12813: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 12713 "configure"
+#line 12819 "configure"
@@ -12720,7 +12826,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:12724: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12830: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12745,13 +12851,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12749: checking for SQLConnect in -liodbc" >&5
+echo "configure:12855: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 12755 "configure"
+#line 12861 "configure"
@@ -12762,7 +12868,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:12766: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12872: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12787,11 +12893,11 @@
echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12791: checking for ODBC library" >&5
+echo "configure:12897: checking for ODBC library" >&5
LDFLAGS="$ODBCLIB $LDFLAGS"
LIBS="-lodbc32 "
-#line 12795 "configure"
+#line 12901 "configure"
#include <windows.h>
#include <sql.h>
@@ -12799,7 +12905,7 @@
SQLAllocEnv((SQLHENV *)0);
; return 0; }
EOF
-if { (eval echo configure:12803: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12909: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -12848,7 +12954,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12852: checking whether to use FFTW" >&5
+echo "configure:12958: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -12867,7 +12973,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12871: checking for location of FFTW includes" >&5
+echo "configure:12977: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12893,15 +12999,15 @@
do
-echo "configure:12897: checking for $ac_hdr" >&5
+echo "configure:13003: checking for $ac_hdr" >&5
-#line 12900 "configure"
+#line 13006 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12905: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13011: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12929,15 +13035,15 @@
do
-echo "configure:12933: checking for $ac_hdr" >&5
+echo "configure:13039: checking for $ac_hdr" >&5
-#line 12936 "configure"
+#line 13042 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12941: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13047: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12965,15 +13071,15 @@
do
-echo "configure:12969: checking for $ac_hdr" >&5
+echo "configure:13075: checking for $ac_hdr" >&5
-#line 12972 "configure"
+#line 13078 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12977: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13083: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13019,7 +13125,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:13023: checking for location of FFTW library" >&5
+echo "configure:13129: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -13044,13 +13150,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:13048: checking for fftw_execute in -lfftw3" >&5
+echo "configure:13154: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 13054 "configure"
+#line 13160 "configure"
@@ -13061,7 +13167,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:13065: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13171: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13086,13 +13192,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:13090: checking for fftwnd_one in -lfftw" >&5
+echo "configure:13196: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-lfftw $MATHLIB $LIBS"
-#line 13096 "configure"
+#line 13202 "configure"
@@ -13103,7 +13209,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:13107: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13213: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13128,13 +13234,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:13132: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:13238: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 13138 "configure"
+#line 13244 "configure"
@@ -13145,7 +13251,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:13149: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13255: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13202,7 +13308,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:13206: checking whether to use BLAS" >&5
+echo "configure:13312: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -13223,7 +13329,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:13227: checking for location of BLAS includes" >&5
+echo "configure:13333: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -13243,7 +13349,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:13247: checking for location of BLAS library" >&5
+echo "configure:13353: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -13269,15 +13375,15 @@
do
-echo "configure:13273: checking for $ac_hdr" >&5
+echo "configure:13379: checking for $ac_hdr" >&5
cat > conftest.$ac_ext <<EOF
-#line 13276 "configure"
+#line 13382 "configure"
#include "confdefs.h"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13281: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13387: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13312,13 +13418,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:13316: checking for dnrm2_ in -lblas" >&5
+echo "configure:13422: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lblas $MATHLIB $LIBS"
-#line 13322 "configure"
+#line 13428 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -13329,7 +13435,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:13333: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13439: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -13348,13 +13454,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:13352: checking for dnrm2_ in -lblas" >&5
+echo "configure:13458: checking for dnrm2_ in -lblas" >&5
LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 13358 "configure"
+#line 13464 "configure"
@@ -13365,7 +13471,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:13369: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13475: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13409,13 +13515,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:13413: checking for ATL_xerbla in -latlas" >&5
+echo "configure:13519: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 13419 "configure"
+#line 13525 "configure"
@@ -13426,7 +13532,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:13430: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13536: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13441,13 +13547,13 @@
if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
echo "$ac_t""yes" 1>&6
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:13445: checking for sgemm_ in -lf77blas" >&5
+echo "configure:13551: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 13451 "configure"
+#line 13557 "configure"
@@ -13458,7 +13564,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13462: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13568: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13473,13 +13579,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:13477: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:13583: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 13483 "configure"
+#line 13589 "configure"
@@ -13490,7 +13596,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:13494: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13600: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13536,16 +13642,16 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:13540: checking for sgemm in $vlib_flags" >&5
+echo "configure:13646: checking for sgemm in $vlib_flags" >&5
-#line 13542 "configure"
+#line 13648 "configure"
int main() {
sgemm
; return 0; }
EOF
-if { (eval echo configure:13549: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13655: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -13563,13 +13669,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:13567: checking for sgemm_ in -lblas" >&5
+echo "configure:13673: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $LIBS"
-#line 13573 "configure"
+#line 13679 "configure"
@@ -13580,7 +13686,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13584: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13690: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13595,13 +13701,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:13599: checking for dgemm_ in -ldgemm" >&5
+echo "configure:13705: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 13605 "configure"
+#line 13711 "configure"
@@ -13612,7 +13718,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:13616: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13722: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13627,13 +13733,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:13631: checking for sgemm_ in -lsgemm" >&5
+echo "configure:13737: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
-#line 13637 "configure"
+#line 13743 "configure"
@@ -13644,7 +13750,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13648: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13754: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13678,13 +13784,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:13682: checking for acosp in -lsunmath" >&5
+echo "configure:13788: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
LIBS="-lsunmath $LIBS"
-#line 13688 "configure"
+#line 13794 "configure"
@@ -13695,7 +13801,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:13699: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13805: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13710,13 +13816,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:13714: checking for sgemm_ in -lsunperf" >&5
+echo "configure:13820: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
-#line 13720 "configure"
+#line 13826 "configure"
@@ -13727,7 +13833,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13731: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13837: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13757,13 +13863,13 @@
# Generic BLAS library
-echo "configure:13761: checking for sgemm_ in -lblas" >&5
+echo "configure:13867: checking for sgemm_ in -lblas" >&5
LIBS="-lblas $LIBS"
-#line 13767 "configure"
+#line 13873 "configure"
@@ -13774,7 +13880,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13778: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13884: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13813,7 +13919,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13817: checking whether to use LAPACK" >&5
+echo "configure:13923: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -13838,7 +13944,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13842: checking for location of LAPACK includes" >&5
+echo "configure:13948: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13858,7 +13964,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13862: checking for location of LAPACK library" >&5
+echo "configure:13968: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13884,15 +13990,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13888: checking for $ac_hdr" >&5
+echo "configure:13994: checking for $ac_hdr" >&5
-#line 13891 "configure"
+#line 13997 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13896: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14002: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -13924,10 +14030,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13928: checking for dsegv_" >&5
+echo "configure:14034: checking for dsegv_" >&5
-#line 13931 "configure"
+#line 14037 "configure"
which can conflict with char dsegv_(); below. */
@@ -13950,7 +14056,7 @@
; return 0; }
EOF
-if { (eval echo configure:13954: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14060: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -13977,13 +14083,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13981: checking for desgv_ in -llapack" >&5
+echo "configure:14087: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $FLIBS $LIBS"
-#line 13987 "configure"
+#line 14093 "configure"
@@ -13994,7 +14100,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:13998: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14104: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14026,13 +14132,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:14030: checking for dgesv_ in -llapack" >&5
+echo "configure:14136: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 14036 "configure"
+#line 14142 "configure"
@@ -14043,7 +14149,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:14047: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14153: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14062,13 +14168,13 @@
-echo "configure:14066: checking for dgesv_ in -llapack" >&5
+echo "configure:14172: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 14072 "configure"
+#line 14178 "configure"
@@ -14079,7 +14185,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:14083: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14189: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14135,7 +14241,7 @@
echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:14139: checking whether to use Motif" >&5
+echo "configure:14245: checking whether to use Motif" >&5
echo "$ac_t"""$with_motif"" 1>&6
case "$with_motif" in
"no") USE_MOTIF= ;;
@@ -14154,7 +14260,7 @@
echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:14158: checking for location of Motif includes" >&5
+echo "configure:14264: checking for location of Motif includes" >&5
case "$with_motif_includes" in
{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -14180,15 +14286,15 @@
do
-echo "configure:14184: checking for $ac_hdr" >&5
+echo "configure:14290: checking for $ac_hdr" >&5
-#line 14187 "configure"
+#line 14293 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14192: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14298: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14222,7 +14328,7 @@
echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:14226: checking for location of Motif library" >&5
+echo "configure:14332: checking for location of Motif library" >&5
case "$with_motif_libs" in
{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -14247,13 +14353,13 @@
echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:14251: checking for XmStringCreate in -lXm" >&5
+echo "configure:14357: checking for XmStringCreate in -lXm" >&5
ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 14257 "configure"
+#line 14363 "configure"
@@ -14264,7 +14370,7 @@
XmStringCreate()
; return 0; }
EOF
-if { (eval echo configure:14268: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14374: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14305,7 +14411,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:14309: checking whether to use Cairo" >&5
+echo "configure:14415: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -14331,7 +14437,7 @@
echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:14335: checking for location of cairo includes" >&5
+echo "configure:14441: checking for location of cairo includes" >&5
case "$with_cairo_includes" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -14357,15 +14463,15 @@
do
-echo "configure:14361: checking for $ac_hdr" >&5
+echo "configure:14467: checking for $ac_hdr" >&5
-#line 14364 "configure"
+#line 14470 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14369: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14475: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14401,7 +14507,7 @@
echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:14405: checking for location of cairo library" >&5
+echo "configure:14511: checking for location of cairo library" >&5
case "$with_cairo_libs" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -14421,7 +14527,7 @@
echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:14425: checking for cairo linking flags" >&5
+echo "configure:14531: checking for cairo linking flags" >&5
case "$with_cairo_ldflags" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -14437,10 +14543,10 @@
LIBS=" $CAIROLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:14441: checking for cairo_create" >&5
+echo "configure:14547: checking for cairo_create" >&5
-#line 14444 "configure"
+#line 14550 "configure"
which can conflict with char cairo_create(); below. */
@@ -14463,7 +14569,7 @@
; return 0; }
EOF
-if { (eval echo configure:14467: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14573: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -14497,10 +14603,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:14501: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:14607: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 14504 "configure"
+#line 14610 "configure"
which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below. */
@@ -14523,7 +14629,7 @@
; return 0; }
EOF
-if { (eval echo configure:14527: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14633: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
else
@@ -14565,7 +14671,7 @@
echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:14569: checking whether to use GLw" >&5
+echo "configure:14675: checking whether to use GLw" >&5
echo "$ac_t"""$with_glw"" 1>&6
case "$with_glw" in
"no") USE_GLW= ;;
@@ -14584,7 +14690,7 @@
echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:14588: checking for location of GLw includes" >&5
+echo "configure:14694: checking for location of GLw includes" >&5
case "$with_glw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -14610,15 +14716,15 @@
do
-echo "configure:14614: checking for $ac_hdr" >&5
+echo "configure:14720: checking for $ac_hdr" >&5
-#line 14617 "configure"
+#line 14723 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14622: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14728: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14646,15 +14752,15 @@
do
-echo "configure:14650: checking for $ac_hdr" >&5
+echo "configure:14756: checking for $ac_hdr" >&5
-#line 14653 "configure"
+#line 14759 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14658: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14764: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14694,7 +14800,7 @@
echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:14698: checking for location of GLw library" >&5
+echo "configure:14804: checking for location of GLw library" >&5
case "$with_glw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -14719,13 +14825,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14723: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:14829: checking for GLwCreateMDrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14729 "configure"
+#line 14835 "configure"
@@ -14736,7 +14842,7 @@
GLwCreateMDrawingArea()
; return 0; }
EOF
-if { (eval echo configure:14740: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14846: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14761,13 +14867,13 @@
echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14765: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:14871: checking for GLwCreateM1DrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14771 "configure"
+#line 14877 "configure"
@@ -14778,7 +14884,7 @@
GLwCreateM1DrawingArea()
; return 0; }
EOF
-if { (eval echo configure:14782: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14888: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14803,13 +14909,13 @@
echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14807: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:14913: checking for GLwCreateM2DrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14813 "configure"
+#line 14919 "configure"
@@ -14820,7 +14926,7 @@
GLwCreateM2DrawingArea()
; return 0; }
EOF
-if { (eval echo configure:14824: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14930: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14845,13 +14951,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14849: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:14955: checking for GLwCreateMDrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14855 "configure"
+#line 14961 "configure"
@@ -14862,7 +14968,7 @@
; return 0; }
EOF
-if { (eval echo configure:14866: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14972: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14887,13 +14993,13 @@
echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14891: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:14997: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14897 "configure"
+#line 15003 "configure"
@@ -14904,7 +15010,7 @@
; return 0; }
EOF
-if { (eval echo configure:14908: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15014: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14929,13 +15035,13 @@
echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14933: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:15039: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14939 "configure"
+#line 15045 "configure"
@@ -14946,7 +15052,7 @@
; return 0; }
EOF
-if { (eval echo configure:14950: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15056: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14973,13 +15079,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:14977: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:15083: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14983 "configure"
+#line 15089 "configure"
@@ -14990,7 +15096,7 @@
; return 0; }
EOF
-if { (eval echo configure:14994: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15100: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15009,13 +15115,13 @@
-echo "configure:15013: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:15119: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 15019 "configure"
+#line 15125 "configure"
@@ -15026,7 +15132,7 @@
; return 0; }
EOF
-if { (eval echo configure:15030: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15136: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15053,13 +15159,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:15057: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:15163: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 15063 "configure"
+#line 15169 "configure"
@@ -15070,7 +15176,7 @@
; return 0; }
EOF
-if { (eval echo configure:15074: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15180: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15089,13 +15195,13 @@
-echo "configure:15093: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:15199: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 15099 "configure"
+#line 15205 "configure"
@@ -15106,7 +15212,7 @@
; return 0; }
EOF
-if { (eval echo configure:15110: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15216: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15219,7 +15325,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:15223: checking whether to use FreeType" >&5
+echo "configure:15329: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -15238,7 +15344,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:15242: checking for location of FreeType includes" >&5
+echo "configure:15348: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -15264,15 +15370,15 @@
do
-echo "configure:15268: checking for $ac_hdr" >&5
+echo "configure:15374: checking for $ac_hdr" >&5
-#line 15271 "configure"
+#line 15377 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15276: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15382: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15306,7 +15412,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:15310: checking for location of FreeType library" >&5
+echo "configure:15416: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -15331,13 +15437,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:15335: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:15441: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 15341 "configure"
+#line 15447 "configure"
@@ -15348,7 +15454,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:15352: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15458: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15389,7 +15495,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:15393: checking whether to use NLS" >&5
+echo "configure:15499: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -15409,10 +15515,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:15413: checking for gettext" >&5
+echo "configure:15519: checking for gettext" >&5
-#line 15416 "configure"
+#line 15522 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char gettext(); below. */
@@ -15435,7 +15541,7 @@
; return 0; }
EOF
-if { (eval echo configure:15439: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15545: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -15453,13 +15559,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:15457: checking for gettext in -lintl" >&5
+echo "configure:15563: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 15463 "configure"
+#line 15569 "configure"
@@ -15470,7 +15576,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:15474: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15580: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15505,7 +15611,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:15509: checking whether to use C++" >&5
+echo "configure:15615: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -15521,7 +15627,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:15525: checking for $ac_word" >&5
+echo "configure:15631: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -15550,7 +15656,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:15554: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:15660: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -15561,12 +15667,12 @@
cat > conftest.$ac_ext << EOF
-#line 15565 "configure"
+#line 15671 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:15570: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15676: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -15592,19 +15698,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:15596: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:15702: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:15601: checking whether we are using GNU C++" >&5
+echo "configure:15707: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15608: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15714: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -15622,7 +15728,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:15626: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:15732: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -15663,7 +15769,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:15667: checking whether to use openDWG" >&5
+echo "configure:15773: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -15683,7 +15789,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:15687: checking for location of openDGW includes" >&5
+echo "configure:15793: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -15709,15 +15815,15 @@
do
-echo "configure:15713: checking for $ac_hdr" >&5
+echo "configure:15819: checking for $ac_hdr" >&5
-#line 15716 "configure"
+#line 15822 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15721: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15827: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15751,7 +15857,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:15755: checking for location of openDWG library" >&5
+echo "configure:15861: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -15798,7 +15904,7 @@
if test "$enable_largefile" = yes; then
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:15802: checking for special C compiler options needed for large files" >&5
+echo "configure:15908: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -15806,7 +15912,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 15810 "configure"
+#line 15916 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -15822,7 +15928,7 @@
; return 0; }
EOF
-if { (eval echo configure:15826: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15932: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
echo "configure: failed program was:" >&5
@@ -15831,7 +15937,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 15835 "configure"
+#line 15941 "configure"
@@ -15847,7 +15953,7 @@
; return 0; }
EOF
-if { (eval echo configure:15851: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15957: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -15867,11 +15973,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:15871: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:15977: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 15875 "configure"
+#line 15981 "configure"
@@ -15887,14 +15993,14 @@
; return 0; }
EOF
-if { (eval echo configure:15891: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15997: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
cat conftest.$ac_ext >&5
rm -rf conftest*
-#line 15898 "configure"
+#line 16004 "configure"
#define _FILE_OFFSET_BITS 64
@@ -15912,7 +16018,7 @@
; return 0; }
EOF
-if { (eval echo configure:15916: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16022: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -15931,11 +16037,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:15935: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:16041: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 15939 "configure"
+#line 16045 "configure"
@@ -15951,14 +16057,14 @@
; return 0; }
EOF
-if { (eval echo configure:15955: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16061: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 15962 "configure"
+#line 16068 "configure"
#define _LARGE_FILES 1
@@ -15976,7 +16082,7 @@
; return 0; }
EOF
-if { (eval echo configure:15980: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16086: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -15995,25 +16101,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:15999: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:16105: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 16003 "configure"
+#line 16109 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:16010: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16116: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 16017 "configure"
+#line 16123 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -16022,7 +16128,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:16026: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16132: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -16043,10 +16149,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:16047: checking if system supports Large Files at all" >&5
+echo "configure:16153: checking if system supports Large Files at all" >&5
-#line 16050 "configure"
+#line 16156 "configure"
#include <stdio.h>
@@ -16078,7 +16184,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:16082: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16188: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -16107,7 +16213,7 @@
# Python check
echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:16111: checking whether to use Python" >&5
+echo "configure:16217: checking whether to use Python" >&5
PYTHONINC=
PYTHONCFLAGS=
@@ -16127,7 +16233,7 @@
# Extract the first word of "python-config", so it can be a program name with args.
set dummy python-config; ac_word=$2
-echo "configure:16131: checking for $ac_word" >&5
+echo "configure:16237: checking for $ac_word" >&5
case "$PY_CONFIG" in
@@ -16169,15 +16275,15 @@
do
-echo "configure:16173: checking for $ac_hdr" >&5
+echo "configure:16279: checking for $ac_hdr" >&5
-#line 16176 "configure"
+#line 16282 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:16181: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16287: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -16247,7 +16353,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:16251: checking whether to use wxWidgets" >&5
+echo "configure:16357: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -16268,7 +16374,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
-echo "configure:16272: checking for $ac_word" >&5
+echo "configure:16378: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -16316,7 +16422,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:16320: checking wxWidgets version" >&5
+echo "configure:16426: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -16339,15 +16445,15 @@
do
-echo "configure:16343: checking for $ac_hdr" >&5
+echo "configure:16449: checking for $ac_hdr" >&5
-#line 16346 "configure"
+#line 16452 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:16351: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16457: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
Modified: grass/branches/develbranch_6/configure.in
--- grass/branches/develbranch_6/configure.in 2011-02-27 10:13:50 UTC (rev 45470)
+++ grass/branches/develbranch_6/configure.in 2011-02-27 11:09:51 UTC (rev 45471)
@@ -874,7 +874,11 @@
fi
LOC_CHECK_INCLUDES(geos_c.h,GEOS,$GEOS_CFLAGS)
- #LOC_CHECK_LIBS(geos_c,initGEOS,GEOS,$GEOS_LIBS,GEOS_LIBS)
+ if test "$MINGW32" = yes ; then
+ LOC_CHECK_LIBS(geos_c_i,initGEOS,GEOS,$GEOS_LIBS,GEOS_LIBS)
+ else
+ LOC_CHECK_LIBS(geos_c,initGEOS,GEOS,$GEOS_LIBS,GEOS_LIBS)
+ fi
AC_DEFINE(HAVE_GEOS)
fi
