[GRASS-SVN] r44823 - in grass/trunk: gui/wxpython
gui/wxpython/gui_modules include lib/vector/vedit
svn_grass at osgeo.org
Sat Jan 1 14:26:54 EST 2011
Author: martinl
Date: 2011-01-01 11:26:54 -0800 (Sat, 01 Jan 2011)
New Revision: 44823
Added:
grass/trunk/gui/wxpython/gui_modules/wxvdigit.py
grass/trunk/gui/wxpython/gui_modules/wxvdriver.py
grass/trunk/lib/vector/vedit/render.c
Removed:
grass/trunk/gui/wxpython/vdigit/
grass/trunk/gui/wxpython/Makefile
grass/trunk/gui/wxpython/gui_modules/__init__.py
grass/trunk/gui/wxpython/gui_modules/mapdisp.py
grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
grass/trunk/gui/wxpython/gui_modules/toolbars.py
grass/trunk/gui/wxpython/gui_modules/vdigit.py
grass/trunk/include/vedit.h
grass/trunk/lib/vector/vedit/chtype.c
grass/trunk/lib/vector/vedit/distance.c
grass/trunk/lib/vector/vedit/select.c
wxGUI/vdigit: converted to python & veditlib updated - Vedit_render_map()
very initial version - displays features to PseudoDC
todo1: complete conversion (full functionality)
todo2: improve bulk data processing (replacing PseudoDC)
Modified: grass/trunk/gui/wxpython/Makefile
--- grass/trunk/gui/wxpython/Makefile 2010-12-31 13:44:07 UTC (rev 44822)
+++ grass/trunk/gui/wxpython/Makefile 2011-01-01 19:26:54 UTC (rev 44823)
@@ -1,8 +1,7 @@
MODULE_TOPDIR = ../..
-SUBDIRS = docs vdigit
+SUBDIRS = docs
EXTRA_CLEAN_FILES = menustrings.py build_ext.pyc
-CLEAN_SUBDIRS = vdigit
include $(MODULE_TOPDIR)/include/Make/Dir.make
include $(MODULE_TOPDIR)/include/Make/Doxygen.make
@@ -13,7 +12,7 @@
SRCFILES := $(wildcard scripts/* compat/* gui_modules/* icons/*.* icons/silk/* images/* xml/*) gis_set.py gis_set_error.py wxgui.py README
DSTFILES := $(patsubst %,$(ETCDIR)/%,$(SRCFILES)) $(patsubst %.py,$(ETCDIR)/%.pyc,$(filter %.py,$(SRCFILES)))
-DSTDIRS := $(patsubst %,$(ETCDIR)/%,compat gui_modules icons icons/silk images scripts vdigit xml)
+DSTDIRS := $(patsubst %,$(ETCDIR)/%,compat gui_modules icons icons/silk images scripts xml)
default: $(DSTFILES) menustrings.py
$(MAKE) parsubdirs
Modified: grass/trunk/gui/wxpython/gui_modules/__init__.py
--- grass/trunk/gui/wxpython/gui_modules/__init__.py 2010-12-31 13:44:07 UTC (rev 44822)
+++ grass/trunk/gui/wxpython/gui_modules/__init__.py 2011-01-01 19:26:54 UTC (rev 44823)
@@ -40,4 +40,6 @@
"vdigit.py",
"workspace.py",
"wxnviz.py",
+ "wxvdriver.py",
+ "wxvdigit.py",
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2010-12-31 13:44:07 UTC (rev 44822)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2011-01-01 19:26:54 UTC (rev 44823)
@@ -542,7 +542,7 @@
# deselect features in vdigit
if self.toolbars['vdigit'] and self.digit:
- self.digit.driver.SetSelected([])
+ self.digit.GetDisplay().SetSelected(None)
self.MapWindow.UpdateMap(render = True, renderVector = True)
else:
self.MapWindow.UpdateMap(render = True)
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py 2010-12-31 13:44:07 UTC (rev 44822)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py 2011-01-01 19:26:54 UTC (rev 44823)
@@ -42,7 +42,6 @@
from vdigit import VDigitCategoryDialog
from vdigit import VDigitZBulkDialog
from vdigit import VDigitDuplicatesDialog
-from vdigit import PseudoDC as VDigitPseudoDC
class MapWindow(object):
"""!Abstract map window class
@@ -303,45 +302,18 @@
self.dragid = -1
self.lastpos = (0, 0)
- def DefinePseudoDC(self, vdigit = False):
- """!Define PseudoDC class to use
- @vdigit True to use PseudoDC from vdigit
+ def DefinePseudoDC(self):
+ """!Define PseudoDC objects to use
# create PseudoDC used for background map, map decorations like scales and legends
- self.pdc = self.PseudoDC(vdigit)
+ self.pdc = wx.PseudoDC()
# used for digitization tool
self.pdcVector = None
# decorations (region box, etc.)
- self.pdcDec = self.PseudoDC(vdigit)
+ self.pdcDec = wx.PseudoDC()
# pseudoDC for temporal objects (select box, measurement tool, etc.)
- self.pdcTmp = self.PseudoDC(vdigit)
- def PseudoDC(self, vdigit = False):
- """!Create PseudoDC instance"""
- if vdigit:
- PseudoDC = VDigitPseudoDC
- else:
- PseudoDC = wx.PseudoDC
- return PseudoDC()
+ self.pdcTmp = wx.PseudoDC()
- def CheckPseudoDC(self):
- """!Try to draw background
- @return True on success
- @return False on failure
- try:
- self.pdc.BeginDrawing()
- self.pdc.SetBackground(wx.Brush(self.GetBackgroundColour()))
- except StandardError, e:
- traceback.print_exc(file = sys.stderr)
- return False
- return True
def Draw(self, pdc, img = None, drawid = None, pdctype = 'image', coords = [0, 0, 0, 0]):
"""!Draws map and overlay decorations
@@ -808,9 +780,9 @@
if renderVector and digitToolbar and \
digitToolbar.GetLayer():
# set region
- self.parent.digit.driver.UpdateRegion()
+ self.parent.digit.GetDisplay().UpdateRegion()
# re-calculate threshold for digitization tool
- self.parent.digit.driver.GetThreshold()
+ # self.parent.digit.driver.GetThreshold()
# draw map
if self.pdcVector:
self.pdcVector.Clear()
@@ -821,7 +793,7 @@
item = None
if item and self.tree.IsItemChecked(item):
- self.parent.digit.driver.DrawMap()
+ self.parent.digit.GetDisplay().DrawMap()
# translate tmp objects (pointer position)
if digitToolbar.GetAction() == 'moveLine':
@@ -906,7 +878,7 @@
else:
self.parent.statusbarWin['mask'].SetLabel('')
- Debug.msg (2, "BufferedWindow.UpdateMap(): render=%s, renderVector=%s -> time=%g" % \
+ Debug.msg (1, "BufferedWindow.UpdateMap(): render=%s, renderVector=%s -> time=%g" % \
(render, renderVector, (stop-start)))
return True
@@ -2334,10 +2306,10 @@
event.Skip()
def OnMiddleDown(self, event):
- Middle mouse button pressed
+ """!Middle mouse button pressed
- self.mouse['begin'] = event.GetPositionTuple()[:]
+ if event:
+ self.mouse['begin'] = event.GetPositionTuple()[:]
digitToolbar = self.parent.toolbars['vdigit']
# digitization tool
@@ -2751,7 +2723,7 @@
elif l.type == 'vector':
if digitToolbar and digitToolbar.GetLayer() == l:
- w, s, b, e, n, t = self.parent.digit.driver.GetMapBoundingBox()
+ w, s, b, e, n, t = self.parent.digit.GetDisplay().GetMapBoundingBox()
self.Map.GetRegion(n = n, s = s, w = w, e = e,
update = True)
updated = True
Modified: grass/trunk/gui/wxpython/gui_modules/toolbars.py
--- grass/trunk/gui/wxpython/gui_modules/toolbars.py 2010-12-31 13:44:07 UTC (rev 44822)
+++ grass/trunk/gui/wxpython/gui_modules/toolbars.py 2011-01-01 19:26:54 UTC (rev 44823)
@@ -35,8 +35,7 @@
import globalvar
import gcmd
import gdialogs
-import vdigit
-from vdigit import VDigitSettingsDialog, haveVDigit
+from vdigit import VDigitSettingsDialog, haveVDigit, VDigit
from debug import Debug
from preferences import globalSettings as UserSettings
from nviz import haveNviz
@@ -193,6 +192,7 @@
'In the meantime you can use "NVIZ" from the File menu.'), wrap = 60)
self.toolId['3d'] = -1
if haveVDigit:
choices.append(_('Digitize'))
if self.toolId['3d'] > -1:
@@ -787,7 +787,7 @@
if self.action['id'] != id:
self.parent.MapWindow.ClearLines(pdc = self.parent.MapWindow.pdcTmp)
if self.parent.digit and \
- len(self.parent.digit.driver.GetSelected()) > 0:
+ len(self.parent.digit.GetDisplay().GetSelected()) > 0:
# cancel action
self.parent.MapWindow.OnMiddleDown(None)
@@ -986,10 +986,8 @@
def OnSettings(self, event):
"""!Show settings dialog"""
if self.parent.digit is None:
- reload(vdigit)
- from vdigit import VDigit as VDigit
try:
- self.parent.digit = VDigit(mapwindow=self.parent.MapWindow)
+ self.parent.digit = VDigit(mapwindow = self.parent.MapWindow)
except SystemExit:
self.parent.digit = None
@@ -1268,13 +1266,13 @@
def StartEditing (self, mapLayer):
"""!Start editing selected vector map layer.
- @param mapLayer reference to MapLayer instance
+ @param mapLayer MapLayer to be edited
# deactive layer
self.mapcontent.ChangeLayerActive(mapLayer, False)
# clean map canvas
- ### self.parent.MapWindow.EraseMap()
+ self.parent.MapWindow.EraseMap()
# unset background map if needed
if mapLayer:
@@ -1284,25 +1282,17 @@
subkey = 'value', value = '', internal = True)
self.parent.statusbar.SetStatusText(_("Please wait, "
- "opening vector map <%s> for editing...") % \
- mapLayer.GetName(),
+ "opening vector map <%s> for editing...") % mapLayer.GetName(),
0)
- # reload vdigit module
- reload(vdigit)
- # use vdigit's PseudoDC
- self.parent.MapWindow.DefinePseudoDC(vdigit = True)
+ self.parent.MapWindow.pdcVector = wx.PseudoDC()
self.mapLayer = mapLayer
# open vector map
try:
- if not self.parent.MapWindow.CheckPseudoDC():
- raise gcmd.GException(_("Unable to initialize display driver of vector "
- "digitizer. See 'Command output' for details."))
- self.parent.digit.SetMapName(mapLayer.GetName())
+ self.parent.digit.OpenMap(mapLayer.GetName())
except gcmd.GException, e:
self.mapLayer = None
self.StopEditing()
@@ -1320,10 +1310,6 @@
if self.parent.MapWindow.mouse['use'] == 'pointer':
self.parent.MapWindow.SetCursor(self.parent.cursors["cross"])
- # create pseudoDC for drawing the map
- self.parent.MapWindow.pdcVector = vdigit.PseudoDC()
- self.parent.digit.driver.SetDevice(self.parent.MapWindow.pdcVector)
if not self.parent.MapWindow.resize:
self.parent.MapWindow.UpdateMap(render = True)
@@ -1340,9 +1326,6 @@
- # use wx's PseudoDC
- self.parent.MapWindow.DefinePseudoDC(vdigit = False)
self.combo.SetValue (_('Select vector map'))
# save changes
@@ -1364,9 +1347,9 @@
"closing and rebuilding topology of "
"vector map <%s>...") % self.mapLayer.GetName(),
0)
- self.parent.digit.SetMapName(None) # -> close map
+ self.parent.digit.CloseMap()
# re-active layer
item = self.parent.tree.FindItemByData('maplayer', self.mapLayer)
if item and self.parent.tree.IsItemChecked(item):
@@ -1374,10 +1357,7 @@
# change cursor
self.parent.MapWindow.SetCursor(self.parent.cursors["default"])
- # disable pseudodc for vector map layer
self.parent.MapWindow.pdcVector = None
- self.parent.digit.driver.SetDevice(None)
# close dialogs
for dialog in ('attributes', 'category'):
Modified: grass/trunk/gui/wxpython/gui_modules/vdigit.py
--- grass/trunk/gui/wxpython/gui_modules/vdigit.py 2010-12-31 13:44:07 UTC (rev 44822)
+++ grass/trunk/gui/wxpython/gui_modules/vdigit.py 2011-01-01 19:26:54 UTC (rev 44823)
@@ -1,13 +1,9 @@
@package vdigit
- at brief wxGUI vector digitizer user interface
+ at brief Dialogs for wxGUI vector digitizer
Classes:
- - AbstractDigit
- - VDigit
- - AbstractDisplayDriver
- - CDisplayDriver
- VDigitSettingsDialog
- VDigitCategoryDialog
- CategoryListCtrl
@@ -43,1098 +39,33 @@
from units import Units
try:
- digitPath = os.path.join(globalvar.ETCWXDIR, "vdigit")
- sys.path.append(digitPath)
- import grass7_wxvdigit as wxvdigit
- GV_LINES = wxvdigit.GV_LINES
- PseudoDC = wxvdigit.PseudoDC
+ from wxvdigit import IVDigit
haveVDigit = True
+ GV_LINES = 10
errorMsg = ''
except ImportError, err:
haveVDigit = False
GV_LINES = None
errorMsg = err
-class AbstractDigit:
- """!Abstract digitization class
+class VDigit(IVDigit):
def __init__(self, mapwindow):
- """!Initialization
- @param mapwindow reference to mapwindow (MapFrame) instance
- @param settings initial settings of digitization tool
- self.map = None
- self.mapWindow = mapwindow
+ """!Base class of vector digitizer
- Debug.msg (3, "AbstractDigit.__init__(): map=%s" % \
- self.map)
- #self.SetCategory()
- self.driver = CDisplayDriver(self, mapwindow)
- def __del__(self):
- pass
- def SetCategoryNextToUse(self):
- """!Find maximum category number in the map layer
- and update Digit.settings['category']
- @return 'True' on success, 'False' on failure
- # vector map layer without categories, reset to '1'
- UserSettings.Set(group='vdigit', key='category', subkey='value', value=1)
- if self.map:
- cat = self.digit.GetCategory(UserSettings.Get(group='vdigit', key='layer', subkey='value'))
- cat += 1
- value=cat)
- def SetCategory(self):
- """!Return category number to use (according Settings)"""
- if UserSettings.Get(group='vdigit', key="categoryMode", subkey='selection') == 0:
- self.SetCategoryNextToUse()
- return UserSettings.Get(group='vdigit', key="category", subkey='value')
- def SetMapName(self, map):
- """!Set map name
- @param map map name to be set up or None (will close currently edited map)
- Debug.msg (3, "AbstractDigit.SetMapName map=%s" % map)
- self.map = map
- try:
- ret = self.driver.Reset(self.map)
- "digitizer. See 'Command output' for details.\n\n"
- "Details: ") + e)
- if map and ret == -1:
- raise gcmd.GException(_('Unable to open vector map <%s> for editing.\n\n'
- 'Data are probably corrupted, '
- 'try to run v.build to rebuild '
- 'the topology (Vector->Develop vector map->'
- 'Create/rebuild topology).') % map)
- if not map and ret != 0:
- if self.digit:
- self.digit.InitCats()
- def SelectLinesByQueryThresh(self):
- """!Generic method used for SelectLinesByQuery()
- -- to get threshold value"""
- thresh = 0.0
- if UserSettings.Get(group='vdigit', key='query', subkey='selection') == 0:
- thresh = UserSettings.Get(group='vdigit', key='queryLength', subkey='thresh')
- if UserSettings.Get(group='vdigit', key="queryLength", subkey='than-selection') == 0:
- thresh = -1 * thresh
- else:
- thresh = UserSettings.Get(group='vdigit', key='queryDangle', subkey='thresh')
- if UserSettings.Get(group='vdigit', key="queryDangle", subkey='than-selection') == 0:
- return thresh
- def GetSelectType(self):
- """!Get type(s) to be selected
- Used by SelectLinesByBox() and SelectLinesByPoint()"""
- type = 0
- for feature in (('point', wxvdigit.GV_POINT),
- ('line', wxvdigit.GV_LINE),
- ('centroid', wxvdigit.GV_CENTROID),
- ('boundary', wxvdigit.GV_BOUNDARY)):
- if UserSettings.Get(group='vdigit', key='selectType',
- subkey=[feature[0], 'enabled']) is True:
- type |= feature[1]
- return type
- def SelectLinesFromBackgroundMap(self, pos1, pos2):
- """!Select features from background map
- @param pos1,pos2 bounding box
- bgmap = str(UserSettings.Get(group='vdigit', key='bgmap', subkey='value',
- internal=True))
- if bgmap == '':
- Debug.msg(4, "VEdit.SelectLinesFromBackgroundMap(): []")
- return []
- x1, y1 = pos1
- x2, y2 = pos2
- ret = gcmd.RunCommand('v.edit',
- parent = self,
- quiet = True,
- read = True,
- map = bgmap,
- tool = 'select',
- bbox = '%f,%f,%f,%f' % (x1, y1, x2, y2))
- if not ret:
- x, y = pos1
- parent = self,
- quiet = True,
- read = True,
- map = bgmap,
- tool = 'select',
- coords = '%f,%f' % (x, y),
- thresh = self.driver.GetThreshold(type='selectThresh'))
- if not ret:
- return []
- output = ret.splitlines()[0] # first line
- ids = output.split(',')
- ids = map(int, ids) # str -> int
- Debug.msg(4, "VEdit.SelectLinesFromBackgroundMap(): %s" % \
- ",".join(["%d" % v for v in ids]))
- return ids
-class VDigit(AbstractDigit):
- """!Prototype of digitization class based on v.digit
- reimplementation (wxWidgets C/C++)
- def __init__(self, mapwindow):
- """!VDigit constructor
- AbstractDigit.__init__(self, mapwindow)
+ IVDigit.__init__(self, mapwindow)
- if not mapwindow.parent.IsStandalone():
- self.log = mapwindow.parent.GetLayerManager().goutput.cmd_stderr
- else:
- self.log = sys.stderr
- self.toolbar = mapwindow.parent.toolbars['vdigit']
- try:
- self.digit = wxvdigit.Digit(self.driver.GetDevice(),
- mapwindow)
- except (ImportError, NameError, TypeError), e:
- # print traceback
- traceback.print_exc(file = self.log)
- self.digit = None
- self.UpdateSettings()
- del self.digit
- def AddPoint (self, map, point, x, y, z=None):
- """!Add new point/centroid
- @param map map name (unused, for compatability with VEdit)
- @param point feature type (if true point otherwise centroid)
- @param x,y,z coordinates
+class VDigitSettingsDialog(wx.Dialog):
+ def __init__(self, parent, title, style = wx.DEFAULT_DIALOG_STYLE):
+ """!Standard settings dialog for digitization purposes
- if UserSettings.Get(group='vdigit', key="categoryMode", subkey='selection') == 2:
- layer = -1 # -> no category
- cat = -1
- else:
- layer = UserSettings.Get(group='vdigit', key="layer", subkey='value')
- cat = self.SetCategory()
- if point:
- type = wxvdigit.GV_POINT
- else:
- type = wxvdigit.GV_CENTROID
+ wx.Dialog.__init__(self, parent = parent, id = wx.ID_ANY, title = title, style = style)
- snap, thresh = self.__getSnapThreshold()
- bgmap = str(UserSettings.Get(group='vdigit', key="bgmap",
- subkey='value', internal=True))
- if z:
- ret = self.digit.AddLine(type, [x, y, z], layer, cat,
- bgmap, snap, thresh)
- else:
- ret = self.digit.AddLine(type, [x, y], layer, cat,
- self.toolbar.EnableUndo()
- return ret
- def AddLine (self, map, line, coords):
- """!Add line/boundary
- @param line feature type (if True line, otherwise boundary)
- @param coords list of coordinates
- if len(coords) < 2:
- return
- cat = -1
- else:
- if line:
- type = wxvdigit.GV_LINE
- else:
- type = wxvdigit.GV_BOUNDARY
- listCoords = []
- for c in coords:
- for x in c:
- listCoords.append(x)
- ret = self.digit.AddLine(type, listCoords, layer, cat,
- return ret
- def DeleteSelectedLines(self):
- """!Delete selected features
- @return number of deleted lines
- nlines = self.digit.DeleteLines(UserSettings.Get(group='vdigit', key='delRecord', subkey='enabled'))
- if nlines > 0:
- return nlines
- def MoveSelectedLines(self, move):
- """!Move selected features
- @param move direction (x, y)
- try:
- nlines = self.digit.MoveLines(move[0], move[1], 0.0, # TODO 3D
- except SystemExit:
- pass
- if nlines > 0:
- return nlines
- def MoveSelectedVertex(self, coords, move):
- """!Move selected vertex of the line
- @param coords click coordinates
- @param move X,Y direction
- @return id of new feature
- @return 0 vertex not moved (not found, line is not selected)
- moved = self.digit.MoveVertex(coords[0], coords[1], 0.0, # TODO 3D
- move[0], move[1], 0.0,
- bgmap, snap,
- self.driver.GetThreshold(type='selectThresh'), thresh)
- if moved:
- return moved
- def AddVertex(self, coords):
- """!Add new vertex to the selected line/boundary on position 'coords'
- @param coords coordinates to add vertex
- @return 0 nothing changed
- @return -1 on failure
- added = self.digit.ModifyLineVertex(1, coords[0], coords[1], 0.0, # TODO 3D
- self.driver.GetThreshold(type='selectThresh'))
- if added > 0:
- return added
- def RemoveVertex(self, coords):
- """!Remove vertex from the selected line/boundary on position 'coords'
- @param coords coordinates to remove vertex
- deleted = self.digit.ModifyLineVertex(0, coords[0], coords[1], 0.0, # TODO 3D
- if deleted > 0:
- return deleted
- def SplitLine(self, coords):
- """!Split selected line/boundary on position 'coords'
- @param coords coordinates to split line
- @return 1 line modified
- @return -1 error
- ret = self.digit.SplitLine(coords[0], coords[1], 0.0, # TODO 3D
- self.driver.GetThreshold('selectThresh'))
- if ret > 0:
- return ret
- def EditLine(self, line, coords):
- """!Edit existing line/boundary
- @param line id of line to be modified
- @param coords list of coordinates of modified line
- @return feature id of new line
- @return -1 on error
- try:
- lineid = line[0]
- except:
- lineid = -1
- self.DeleteSelectedLines()
- return 0
- listCoords = []
- for c in coords:
- for x in c:
- try:
- ret = self.digit.RewriteLine(lineid, listCoords,
- pass
- if ret > 0:
- return ret
- def FlipLine(self):
- """!Flip selected lines/boundaries
- @return number of modified lines
- ret = self.digit.FlipLines()
- if ret > 0:
- return ret
- def MergeLine(self):
- """!Merge selected lines/boundaries
- ret = self.digit.MergeLines()
- if ret > 0:
- return ret
- def BreakLine(self):
- """!Break selected lines/boundaries
- ret = self.digit.BreakLines()
- if ret > 0:
- return ret
- def SnapLine(self):
- """!Snap selected lines/boundaries
- @return on success
- ret = self.digit.SnapLines(thresh)
- if ret == 0:
- return ret
- def ConnectLine(self):
- """!Connect selected lines/boundaries
- @return 1 lines connected
- @return 0 lines not connected
- ret = self.digit.ConnectLines(thresh)
- if ret > 0:
- return ret
- def CopyLine(self, ids=[]):
- """!Copy features from (background) vector map
- @param ids list of line ids to be copied
- @return number of copied features
- if len(bgmap) > 0:
- ret = self.digit.CopyLines(ids, bgmap)
- else:
- ret = self.digit.CopyLines(ids, None)
- if ret > 0:
- return ret
- def CopyCats(self, fromId, toId, copyAttrb=False):
- """!Copy given categories to objects with id listed in ids
- @param cats ids of 'from' feature
- @param ids ids of 'to' feature(s)
- @return number of modified features
- if len(fromId) == 0 or len(toId) == 0:
- return 0
- ret = self.digit.CopyCats(fromId, toId, copyAttrb)
- if ret > 0:
- return ret
- def SelectLinesByQuery(self, pos1, pos2):
- """!Select features by query
- @param pos1, pos2 bounding box definition
- thresh = self.SelectLinesByQueryThresh()
- w, n = pos1
- e, s = pos2
- query = wxvdigit.QUERY_UNKNOWN
- query = wxvdigit.QUERY_LENGTH
- else:
- query = wxvdigit.QUERY_DANGLE
- type = wxvdigit.GV_POINTS | wxvdigit.GV_LINES # TODO: 3D
- ids = self.digit.SelectLinesByQuery(w, n, 0.0, e, s, 1000.0,
- UserSettings.Get(group='vdigit', key='query', subkey='box'),
- query, type, thresh)
- Debug.msg(4, "VDigit.SelectLinesByQuery(): %s" % \
- return ids
- def GetLineCats(self, line=-1):
- """!Get layer/category pairs from given (selected) line
- @param line feature id (-1 for first selected line)
- return dict(self.digit.GetLineCats(line))
- def GetLineLength(self, line):
- """!Get line length
- @return line length
- return self.digit.GetLineLength(line)
- def GetAreaSize(self, centroid):
- """!Get area size
- @param centroid centroid id
- @return area size
- return self.digit.GetAreaSize(centroid)
- def GetAreaPerimeter(self, centroid):
- """!Get area perimeter
- @return area size
- return self.digit.GetAreaPerimeter(centroid)
- def SetLineCats(self, line, layer, cats, add=True):
- """!Set categories for given line and layer
- @param layer layer number (-1 for first selected line)
- @param cats list of categories
- @param add if True to add, otherwise do delete categories
- @return new feature id (feature need to be rewritten)
- ret = self.digit.SetLineCats(line, layer, cats, add)
- if ret > 0:
- return ret
- def GetLayers(self):
- """!Get list of layers"""
- return self.digit.GetLayers()
- def TypeConvForSelectedLines(self):
- """!Feature type conversion for selected objects.
- Supported conversions:
- - point <-> centroid
- - line <-> boundary
- ret = self.digit.TypeConvLines()
- if ret > 0:
- return ret
- def Undo(self, level=-1):
- """!Undo action
- @param level levels to undo (0 to revert all)
- @return id of current changeset
- try:
- ret = self.digit.Undo(level)
- ret = -2
- if ret == -2:
- raise gcmd.GException(_("Undo failed, data corrupted."))
- self.mapWindow.UpdateMap(render=False)
- if ret < 0: # disable undo tool
- self.toolbar.EnableUndo(False)
- def GetUndoLevel(self):
- """!Get undo level (number of active changesets)
- Note: Changesets starts wiht 0
- if not self.digit:
- return -1
- return self.digit.GetUndoLevel()
- def UpdateSettings(self):
- """!Update digit settigs"""
- return
- self.digit.UpdateSettings(UserSettings.Get(group='vdigit', key='breakLines',
- subkey='enabled'),
- UserSettings.Get(group='vdigit', key='addCentroid',
- UserSettings.Get(group='vdigit', key='catBoundary',
- subkey='enabled'))
- def ZBulkLines(self, pos1, pos2, start, step):
- """!Z-bulk labeling
- @param pos1 reference line (start point)
- @param pos1 reference line (end point)
- @param start starting value
- @param step step value
- ret = self.digit.ZBulkLabeling(pos1[0], pos1[1], pos2[0], pos2[1],
- start, step)
- if ret > 0:
- return ret
- def __getSnapThreshold(self):
- """!Get snap mode and threshold value
- @return (snap, thresh)
- thresh = self.driver.GetThreshold()
- if thresh > 0.0:
- if UserSettings.Get(group='vdigit', key='snapToVertex', subkey='enabled') is True:
- snap = wxvdigit.SNAPVERTEX
- else:
- else:
- snap = wxvdigit.NO_SNAP
- return (snap, thresh)
-class AbstractDisplayDriver:
- """!Abstract classs for display driver"""
- def __init__(self, parent, mapwindow):
- @param parent
- @param mapwindow reference to mapwindow (MFrame)
- self.parent = parent
- self.mapwindow = mapwindow
- self.ids = {} # dict[g6id] = [pdcId]
- self.selected = [] # list of selected objects (grassId!)
- def GetThreshold(self, type='snapping', value=None, units=None):
- """!Return threshold in map units
- @param value threshold to be set up
- @param units units (map, screen)
- if value is None:
- value = UserSettings.Get(group='vdigit', key=type, subkey='value')
- if units is None:
- units = UserSettings.Get(group='vdigit', key=type, subkey='units')
- reg = self.mapwindow.Map.region
- if value < 0:
- value = (reg['nsres'] + reg['ewres']) / 2.
- if units == "screen pixels":
- # pixel -> cell
- if reg['nsres'] > reg['ewres']:
- res = reg['nsres']
- else:
- res = reg['ewres']
- threshold = value * res
- else:
- threshold = value
- Debug.msg(4, "AbstractDisplayDriver.GetThreshold(): type=%s, thresh=%f" % (type, threshold))
- return threshold
-class CDisplayDriver(AbstractDisplayDriver):
- Display driver using grass7_wxdriver module
- @param parent
- AbstractDisplayDriver.__init__(self, parent, mapwindow)
- if not self.mapwindow.parent.IsStandalone():
- logerr = self.mapwindow.parent.GetLayerManager().goutput.cmd_stderr
- else:
- logerr = None
- # initialize wx display driver
- try:
- self.__display = wxvdigit.DisplayDriver(mapwindow.pdcVector,
- mapwindow.pdcTmp,
- logerr)
- except:
- self.__display = None
- def GetDevice(self):
- """!Get device"""
- return self.__display
- def SetDevice(self, pdc):
- """!Set device for driver
- @param pdc wx.PseudoDC instance
- if self.__display:
- self.__display.SetDevice(pdc)
- def Reset(self, map):
- """!Reset map
- Open or close the vector map by driver.
- @param map map name or None to close the map
- @return 0 on success (close map)
- @return topo level on success (open map)
- @return non-zero (close map)
- @return -1 on error (open map)
- if map:
- name, mapset = map.split('@')
- try:
- ret = self.__display.OpenMap(str(name), str(mapset), True)
- ret = -1
- else:
- ret = self.__display.CloseMap()
- return ret
- def ReloadMap(self):
- """!Reload map (close and re-open).
- Needed for v.edit, TODO: get rid of that..."""
- Debug.msg(4, "CDisplayDriver.ReloadMap():")
- self.__display.ReloadMap()
- def DrawMap(self):
- """!Draw vector map layer content
- @return wx.Image instance
- if not self.__display:
- return 0
- nlines = self.__display.DrawMap(True) # force
- Debug.msg(3, "CDisplayDriver.DrawMap(): nlines=%d" % nlines)
- return nlines
- def SelectLinesByBox(self, begin, end, type=0, drawSeg=False):
- """!Select vector features by given bounding box.
- If type is given, only vector features of given type are selected.
- @param begin,end bounding box definition
- @param type select only objects of given type
- x1, y1 = begin
- x2, y2 = end
- inBox = UserSettings.Get(group='vdigit', key='selectInside', subkey='enabled')
- nselected = self.__display.SelectLinesByBox(x1, y1, -1.0 * wxvdigit.PORT_DOUBLE_MAX,
- x2, y2, wxvdigit.PORT_DOUBLE_MAX,
- type, inBox, drawSeg)
- Debug.msg(4, "CDisplayDriver.SelectLinesByBox(): selected=%d" % \
- nselected)
- return nselected
- def SelectLineByPoint(self, point, type=0):
- """!Select vector feature by coordinates of click point (in given threshold).
- @param point click coordinates (bounding box given by threshold)
- pointOnLine = self.__display.SelectLineByPoint(point[0], point[1], 0.0,
- self.GetThreshold(type='selectThresh'),
- type, 0); # without_z
- if len(pointOnLine) > 0:
- Debug.msg(4, "CDisplayDriver.SelectLineByPoint(): pointOnLine=%f,%f" % \
- (pointOnLine[0], pointOnLine[1]))
- return pointOnLine
- else:
- Debug.msg(4, "CDisplayDriver.SelectLineByPoint(): no line found")
- return None
- def GetSelected(self, grassId=True):
- """!Return ids of selected vector features
- @param grassId if grassId is True returns GRASS ids, otherwise
- internal ids of objects drawn in PseudoDC"""
- return list()
- if grassId:
- selected = self.__display.GetSelected(True)
- else:
- selected = self.__display.GetSelected(False)
- Debug.msg(4, "CDisplayDriver.GetSelected(): grassId=%d, ids=%s" % \
- (grassId, (",".join(["%d" % v for v in selected]))))
- return selected
- def GetSelectedCoord(self):
- """!Return ids of selected vector features and their coordinates"""
- return dict(self.__display.GetSelectedCoord())
- def GetRegionSelected(self):
- """!Get minimal region extent of selected features (ids/cats)"""
- return self.__display.GetRegionSelected()
- def GetDuplicates(self):
- """!Return ids of (selected) duplicated vector features
- # -> id : (list of ids)
- dupl = dict(self.__display.GetDuplicates())
- # -> id : ((id, cat), ...)
- dupl_full = {}
- for key in dupl.keys():
- dupl_full[key] = []
- for id in dupl[key]:
- catStr = ''
- cats = self.parent.GetLineCats(line=id)
- for layer in cats.keys():
- if len(cats[layer]) > 0:
- catStr = "%d: (" % layer
- for cat in cats[layer]:
- catStr += "%d," % cat
- catStr = catStr.rstrip(',')
- catStr += ')'
- dupl_full[key].append([id, catStr])
- return dupl_full
- def GetSelectedVertex(self, coords):
- """!Get PseudoDC id(s) of vertex (of selected line)
- on position 'coords'
- @param coords click position
- x, y = coords
- id = self.__display.GetSelectedVertex(x, y, self.GetThreshold(type='selectThresh'))
- Debug.msg(4, "CDisplayDriver.GetSelectedVertex(): id=%s" % \
- (",".join(["%d" % v for v in id])))
- return id
- def SetSelected(self, id, field=-1):
- """!Set selected vector features
- @param id list of feature ids/categories to be selected
- @param field field(layer) number, -1 for ids instead of cats
- Debug.msg(4, "CDisplayDriver.SetSelected(): id=%s" % \
- id)
- self.__display.SetSelected(id, field)
- def UnSelect(self, id):
- """!Unselect vector features
- @param id list of feature id(s)
- Debug.msg(4, "CDisplayDriver.UnSelect(): id=%s" % \
- ",".join(["%d" % v for v in id]))
- self.__display.UnSelect(id)
- def UpdateRegion(self):
- """!Set geographical region
- Needed for 'cell2pixel' conversion"""
- return
- map = self.mapwindow.Map
- reg = map.region
- self.__display.SetRegion(reg['n'],
- reg['s'],
- reg['e'],
- reg['w'],
- reg['nsres'],
- reg['ewres'],
- reg['center_easting'],
- reg['center_northing'],
- map.width, map.height)
- def GetMapBoundingBox(self):
- """!Return bounding box of given vector map layer
- @return (w,s,b,e,n,t)
- return self.__display.GetMapBoundingBox()
- def Is3D(self):
- """!Check if open vector map is 3D
- @return True if 3D
- @return False if not 3D"""
- return self.__display.Is3D()
- def DrawSelected(self, draw=True):
- """!Show/hide selected features"""
- self.__display.DrawSelected(draw)
- def UpdateSettings(self, alpha=255):
- """!Update display driver settings"""
- # TODO map units
- return
- color = {}
- for symbol in ("highlight",
- "highlightDupl",
- "point",
- "line",
- "boundaryNo",
- "boundaryOne",
- "boundaryTwo",
- "centroidIn",
- "centroidOut",
- "centroidDup",
- "nodeOne",
- "nodeTwo",
- "vertex",
- "area",
- "direction"):
- color[symbol] = wx.Color(UserSettings.Get(group='vdigit', key='symbol',
- subkey=[symbol, 'color'])[0],
- UserSettings.Get(group='vdigit', key='symbol',
- subkey=[symbol, 'color'])[1],
- subkey=[symbol, 'color'])[2]).GetRGB()
- self.__display.UpdateSettings (color['highlight'],
- UserSettings.Get(group='vdigit', key='checkForDupl',
- color['highlightDupl'],
- subkey=['point', 'enabled']),
- color['point'],
- subkey=['line', 'enabled']),
- color['line'],
- subkey=['boundaryNo', 'enabled']),
- color['boundaryNo'],
- subkey=['boundaryOne', 'enabled']),
- color['boundaryOne'],
- subkey=['boundaryTwo', 'enabled']),
- color['boundaryTwo'],
- subkey=['centroidIn', 'enabled']),
- color['centroidIn'],
- subkey=['centroidOut', 'enabled']),
- color['centroidOut'],
- subkey=['centroidDup', 'enabled']),
- color['centroidDup'],
- subkey=['nodeOne', 'enabled']),
- color['nodeOne'],
- subkey=['nodeTwo', 'enabled']),
- color['nodeTwo'],
- subkey=['vertex', 'enabled']),
- color['vertex'],
- subkey=['area', 'enabled']),
- color['area'],
- subkey=['direction', 'enabled']),
- color['direction'],
- UserSettings.Get(group='vdigit', key='lineWidth',
- subkey='value'),
- alpha)
-class VDigitSettingsDialog(wx.Dialog):
- Standard settings dialog for digitization purposes
- def __init__(self, parent, title, style=wx.DEFAULT_DIALOG_STYLE):
- wx.Dialog.__init__(self, parent=parent, id=wx.ID_ANY, title=title, style=style)
self.parent = parent # mapdisplay.BufferedWindow class instance
# notebook
- notebook = wx.Notebook(parent=self, id=wx.ID_ANY, style=wx.BK_DEFAULT)
+ notebook = wx.Notebook(parent = self, id = wx.ID_ANY, style = wx.BK_DEFAULT)
self.__CreateSymbologyPage(notebook)
parent.digit.SetCategory() # update category number (next to use)
self.__CreateGeneralPage(notebook)
@@ -1164,9 +95,9 @@
btnSizer.Realize()
mainSizer = wx.BoxSizer(wx.VERTICAL)
- mainSizer.Add(item=notebook, proportion=1, flag=wx.EXPAND | wx.ALL, border=5)
- mainSizer.Add(item=btnSizer, proportion=0,
- flag=wx.EXPAND | wx.ALL | wx.ALIGN_CENTER, border=5)
+ mainSizer.Add(item = notebook, proportion = 1, flag = wx.EXPAND | wx.ALL, border = 5)
+ mainSizer.Add(item = btnSizer, proportion = 0,
+ flag = wx.EXPAND | wx.ALL | wx.ALIGN_CENTER, border = 5)
self.Bind(wx.EVT_CLOSE, self.OnCancel)
@@ -1176,36 +107,36 @@
def __CreateSymbologyPage(self, notebook):
"""!Create notebook page concerning with symbology settings"""
- panel = wx.Panel(parent=notebook, id=wx.ID_ANY)
- notebook.AddPage(page=panel, text=_("Symbology"))
+ panel = wx.Panel(parent = notebook, id = wx.ID_ANY)
+ notebook.AddPage(page = panel, text = _("Symbology"))
sizer = wx.BoxSizer(wx.VERTICAL)
- flexSizer = wx.FlexGridSizer (cols=3, hgap=5, vgap=5)
+ flexSizer = wx.FlexGridSizer (cols = 3, hgap = 5, vgap = 5)
flexSizer.AddGrowableCol(0)
self.symbology = {}
for label, key in self.__SymbologyData():
textLabel = wx.StaticText(panel, wx.ID_ANY, label)
- color = csel.ColourSelect(panel, id=wx.ID_ANY,
- colour=UserSettings.Get(group='vdigit', key='symbol',
- subkey=[key, 'color']), size=globalvar.DIALOG_COLOR_SIZE)
- isEnabled = UserSettings.Get(group='vdigit', key='symbol',
- subkey=[key, 'enabled'])
+ color = csel.ColourSelect(panel, id = wx.ID_ANY,
+ colour = UserSettings.Get(group = 'vdigit', key = 'symbol',
+ subkey = [key, 'color']), size = globalvar.DIALOG_COLOR_SIZE)
+ isEnabled = UserSettings.Get(group = 'vdigit', key = 'symbol',
+ subkey = [key, 'enabled'])
if isEnabled is not None:
- enabled = wx.CheckBox(panel, id=wx.ID_ANY, label="")
+ enabled = wx.CheckBox(panel, id = wx.ID_ANY, label = "")
enabled.SetValue(isEnabled)
self.symbology[key] = (enabled, color)
else:
enabled = (1, 1)
self.symbology[key] = (None, color)
- flexSizer.Add(textLabel, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
- flexSizer.Add(enabled, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
- flexSizer.Add(color, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
+ flexSizer.Add(textLabel, proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL)
+ flexSizer.Add(enabled, proportion = 0, flag = wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
+ flexSizer.Add(color, proportion = 0, flag = wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
color.SetName("GetColour")
- sizer.Add(item=flexSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=10)
+ sizer.Add(item = flexSizer, proportion = 1, flag = wx.ALL | wx.EXPAND, border = 10)
panel.SetSizer(sizer)
@@ -1214,144 +145,144 @@
def __CreateGeneralPage(self, notebook):
- notebook.AddPage(page=panel, text=_("General"))
+ notebook.AddPage(page = panel, text = _("General"))
border = wx.BoxSizer(wx.VERTICAL)
# display section
- box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Display"))
+ box = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Display"))
sizer = wx.StaticBoxSizer(box, wx.VERTICAL)
# line width
- text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Line width"))
- self.lineWidthValue = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(75, -1),
- initial=UserSettings.Get(group='vdigit', key="lineWidth", subkey='value'),
- min=1, max=1e6)
- units = wx.StaticText(parent=panel, id=wx.ID_ANY, size=(115, -1),
- label=UserSettings.Get(group='vdigit', key="lineWidth", subkey='units'),
- style=wx.ALIGN_LEFT)
- flexSizer.Add(text, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
- flexSizer.Add(self.lineWidthValue, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
- flexSizer.Add(units, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE | wx.ALIGN_CENTER_VERTICAL | wx.LEFT,
- border=10)
+ text = wx.StaticText(parent = panel, id = wx.ID_ANY, label = _("Line width"))
+ self.lineWidthValue = wx.SpinCtrl(parent = panel, id = wx.ID_ANY, size = (75, -1),
+ initial = UserSettings.Get(group = 'vdigit', key = "lineWidth", subkey = 'value'),
+ min = 1, max = 1e6)
+ units = wx.StaticText(parent = panel, id = wx.ID_ANY, size = (115, -1),
+ label = UserSettings.Get(group = 'vdigit', key = "lineWidth", subkey = 'units'),
+ style = wx.ALIGN_LEFT)
+ flexSizer.Add(text, proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL)
+ flexSizer.Add(self.lineWidthValue, proportion = 0, flag = wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
+ flexSizer.Add(units, proportion = 0, flag = wx.ALIGN_RIGHT | wx.FIXED_MINSIZE | wx.ALIGN_CENTER_VERTICAL | wx.LEFT,
+ border = 10)
- sizer.Add(item=flexSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=1)
- border.Add(item=sizer, proportion=0, flag=wx.ALL | wx.EXPAND, border=5)
+ sizer.Add(item = flexSizer, proportion = 1, flag = wx.ALL | wx.EXPAND, border = 1)
+ border.Add(item = sizer, proportion = 0, flag = wx.ALL | wx.EXPAND, border = 5)
# snapping section
- box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Snapping"))
+ box = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Snapping"))
+ flexSizer = wx.FlexGridSizer(cols = 3, hgap = 5, vgap = 5)
# snapping
- text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Snapping threshold"))
- self.snappingValue = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(75, -1),
- initial=UserSettings.Get(group='vdigit', key="snapping", subkey='value'),
- min=-1, max=1e6)
+ text = wx.StaticText(parent = panel, id = wx.ID_ANY, label = _("Snapping threshold"))
+ self.snappingValue = wx.SpinCtrl(parent = panel, id = wx.ID_ANY, size = (75, -1),
+ initial = UserSettings.Get(group = 'vdigit', key = "snapping", subkey = 'value'),
+ min = -1, max = 1e6)
self.snappingValue.Bind(wx.EVT_SPINCTRL, self.OnChangeSnappingValue)
self.snappingValue.Bind(wx.EVT_TEXT, self.OnChangeSnappingValue)
- self.snappingUnit = wx.Choice(parent=panel, id=wx.ID_ANY, size=(125, -1),
- choices=["screen pixels", "map units"])
- self.snappingUnit.SetStringSelection(UserSettings.Get(group='vdigit', key="snapping", subkey='units'))
+ self.snappingUnit = wx.Choice(parent = panel, id = wx.ID_ANY, size = (125, -1),
+ choices = ["screen pixels", "map units"])
+ self.snappingUnit.SetStringSelection(UserSettings.Get(group = 'vdigit', key = "snapping", subkey = 'units'))
self.snappingUnit.Bind(wx.EVT_CHOICE, self.OnChangeSnappingUnits)
- flexSizer.Add(self.snappingValue, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
- flexSizer.Add(self.snappingUnit, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
+ flexSizer.Add(self.snappingValue, proportion = 0, flag = wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
+ flexSizer.Add(self.snappingUnit, proportion = 0, flag = wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
vertexSizer = wx.BoxSizer(wx.VERTICAL)
- self.snapVertex = wx.CheckBox(parent=panel, id=wx.ID_ANY,
- label=_("Snap also to vertex"))
- self.snapVertex.SetValue(UserSettings.Get(group='vdigit', key="snapToVertex", subkey='enabled'))
- vertexSizer.Add(item=self.snapVertex, proportion=0, flag=wx.EXPAND)
+ self.snapVertex = wx.CheckBox(parent = panel, id = wx.ID_ANY,
+ label = _("Snap also to vertex"))
+ self.snapVertex.SetValue(UserSettings.Get(group = 'vdigit', key = "snapToVertex", subkey = 'enabled'))
+ vertexSizer.Add(item = self.snapVertex, proportion = 0, flag = wx.EXPAND)
self.mapUnits = self.parent.MapWindow.Map.GetProjInfo()['units']
- self.snappingInfo = wx.StaticText(parent=panel, id=wx.ID_ANY,
- label=_("Snapping threshold is %(value).1f %(units)s") % \
- {'value' : self.parent.digit.driver.GetThreshold(),
+ self.snappingInfo = wx.StaticText(parent = panel, id = wx.ID_ANY,
+ label = _("Snapping threshold is %(value).1f %(units)s") % \
+ {'value' : self.parent.digit.GetDisplay().GetThreshold(),
'units' : self.mapUnits})
- vertexSizer.Add(item=self.snappingInfo, proportion=0,
- flag=wx.ALL | wx.EXPAND, border=1)
+ vertexSizer.Add(item = self.snappingInfo, proportion = 0,
+ flag = wx.ALL | wx.EXPAND, border = 1)
- sizer.Add(item=flexSizer, proportion=1, flag=wx.EXPAND)
- sizer.Add(item=vertexSizer, proportion=1, flag=wx.EXPAND)
- border.Add(item=sizer, proportion=0, flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border=5)
+ sizer.Add(item = flexSizer, proportion = 1, flag = wx.EXPAND)
+ sizer.Add(item = vertexSizer, proportion = 1, flag = wx.EXPAND)
+ border.Add(item = sizer, proportion = 0, flag = wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border = 5)
# select box
- box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Select vector features"))
+ box = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Select vector features"))
# feature type
inSizer = wx.BoxSizer(wx.HORIZONTAL)
self.selectFeature = {}
for feature in ('point', 'line',
'centroid', 'boundary'):
- chkbox = wx.CheckBox(parent=panel, label=feature)
+ chkbox = wx.CheckBox(parent = panel, label = feature)
self.selectFeature[feature] = chkbox.GetId()
- chkbox.SetValue(UserSettings.Get(group='vdigit', key='selectType',
- subkey=[feature, 'enabled']))
- inSizer.Add(item=chkbox, proportion=0,
- flag=wx.EXPAND | wx.ALL, border=5)
- sizer.Add(item=inSizer, proportion=0, flag=wx.EXPAND)
+ chkbox.SetValue(UserSettings.Get(group = 'vdigit', key = 'selectType',
+ subkey = [feature, 'enabled']))
+ inSizer.Add(item = chkbox, proportion = 0,
+ flag = wx.EXPAND | wx.ALL, border = 5)
+ sizer.Add(item = inSizer, proportion = 0, flag = wx.EXPAND)
# threshold
- text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Select threshold"))
- self.selectThreshValue = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(75, -1),
- initial=UserSettings.Get(group='vdigit', key="selectThresh", subkey='value'),
- min=1, max=1e6)
- flexSizer.Add(self.selectThreshValue, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
- border=10)
+ text = wx.StaticText(parent = panel, id = wx.ID_ANY, label = _("Select threshold"))
+ self.selectThreshValue = wx.SpinCtrl(parent = panel, id = wx.ID_ANY, size = (75, -1),
+ initial = UserSettings.Get(group = 'vdigit', key = "selectThresh", subkey = 'value'),
+ flexSizer.Add(self.selectThreshValue, proportion = 0, flag = wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
+ border = 10)
- self.selectIn = wx.CheckBox(parent=panel, id=wx.ID_ANY,
- label=_("Select only features inside of selection bounding box"))
- self.selectIn.SetValue(UserSettings.Get(group='vdigit', key="selectInside", subkey='enabled'))
+ self.selectIn = wx.CheckBox(parent = panel, id = wx.ID_ANY,
+ label = _("Select only features inside of selection bounding box"))
+ self.selectIn.SetValue(UserSettings.Get(group = 'vdigit', key = "selectInside", subkey = 'enabled'))
self.selectIn.SetToolTipString(_("By default are selected all features overlapping selection bounding box "))
- self.checkForDupl = wx.CheckBox(parent=panel, id=wx.ID_ANY,
- label=_("Check for duplicates"))
- self.checkForDupl.SetValue(UserSettings.Get(group='vdigit', key="checkForDupl", subkey='enabled'))
+ self.checkForDupl = wx.CheckBox(parent = panel, id = wx.ID_ANY,
+ label = _("Check for duplicates"))
+ self.checkForDupl.SetValue(UserSettings.Get(group = 'vdigit', key = "checkForDupl", subkey = 'enabled'))
- sizer.Add(item=flexSizer, proportion=0, flag=wx.EXPAND)
- sizer.Add(item=self.selectIn, proportion=0, flag=wx.EXPAND | wx.ALL, border=1)
- sizer.Add(item=self.checkForDupl, proportion=0, flag=wx.EXPAND | wx.ALL, border=1)
- border.Add(item=sizer, proportion=0, flag=wx.EXPAND | wx.LEFT | wx.RIGHT | wx.BOTTOM, border=5)
+ sizer.Add(item = flexSizer, proportion = 0, flag = wx.EXPAND)
+ sizer.Add(item = self.selectIn, proportion = 0, flag = wx.EXPAND | wx.ALL, border = 1)
+ sizer.Add(item = self.checkForDupl, proportion = 0, flag = wx.EXPAND | wx.ALL, border = 1)
+ border.Add(item = sizer, proportion = 0, flag = wx.EXPAND | wx.LEFT | wx.RIGHT | wx.BOTTOM, border = 5)
# digitize lines box
- box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Digitize line features"))
+ box = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Digitize line features"))
- self.intersect = wx.CheckBox(parent=panel, label=_("Break lines at intersection"))
- self.intersect.SetValue(UserSettings.Get(group='vdigit', key='breakLines', subkey='enabled'))
+ self.intersect = wx.CheckBox(parent = panel, label = _("Break lines at intersection"))
+ self.intersect.SetValue(UserSettings.Get(group = 'vdigit', key = 'breakLines', subkey = 'enabled'))
- sizer.Add(item=self.intersect, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
+ sizer.Add(item = self.intersect, proportion = 0, flag = wx.ALL | wx.EXPAND, border = 1)
# save-on-exit box
- box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Save changes"))
+ box = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Save changes"))
# save changes on exit?
- self.save = wx.CheckBox(parent=panel, label=_("Save changes on exit"))
- self.save.SetValue(UserSettings.Get(group='vdigit', key='saveOnExit', subkey='enabled'))
- sizer.Add(item=self.save, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
+ self.save = wx.CheckBox(parent = panel, label = _("Save changes on exit"))
+ self.save.SetValue(UserSettings.Get(group = 'vdigit', key = 'saveOnExit', subkey = 'enabled'))
+ sizer.Add(item = self.save, proportion = 0, flag = wx.ALL | wx.EXPAND, border = 1)
panel.SetSizer(border)
@@ -1359,73 +290,72 @@
def __CreateQueryPage(self, notebook):
"""!Create notebook page for query tool"""
+ notebook.AddPage(page = panel, text = _("Query tool"))
- notebook.AddPage(page=panel, text=_("Query tool"))
# query tool box
- box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Choose query tool"))
+ box = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Choose query tool"))
LocUnits = self.parent.MapWindow.Map.GetProjInfo()['units']
- self.queryBox = wx.CheckBox(parent=panel, id=wx.ID_ANY, label=_("Select by box"))
- self.queryBox.SetValue(UserSettings.Get(group='vdigit', key="query", subkey='box'))
+ self.queryBox = wx.CheckBox(parent = panel, id = wx.ID_ANY, label = _("Select by box"))
+ self.queryBox.SetValue(UserSettings.Get(group = 'vdigit', key = "query", subkey = 'box'))
- sizer.Add(item=self.queryBox, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
+ sizer.Add(item = self.queryBox, proportion = 0, flag = wx.ALL | wx.EXPAND, border = 1)
sizer.Add((0, 5))
# length
- self.queryLength = wx.RadioButton(parent=panel, id=wx.ID_ANY, label=_("length"))
+ self.queryLength = wx.RadioButton(parent = panel, id = wx.ID_ANY, label = _("length"))
self.queryLength.Bind(wx.EVT_RADIOBUTTON, self.OnChangeQuery)
- sizer.Add(item=self.queryLength, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
- flexSizer = wx.FlexGridSizer (cols=4, hgap=5, vgap=5)
+ sizer.Add(item = self.queryLength, proportion = 0, flag = wx.ALL | wx.EXPAND, border = 1)
+ flexSizer = wx.FlexGridSizer (cols = 4, hgap = 5, vgap = 5)
- txt = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Select lines"))
- self.queryLengthSL = wx.Choice (parent=panel, id=wx.ID_ANY,
- choices = [_("shorter than"), _("longer than")])
- self.queryLengthSL.SetSelection(UserSettings.Get(group='vdigit', key="queryLength", subkey='than-selection'))
- self.queryLengthValue = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(100, -1),
- initial=1,
- min=0, max=1e6)
- self.queryLengthValue.SetValue(UserSettings.Get(group='vdigit', key="queryLength", subkey='thresh'))
- units = wx.StaticText(parent=panel, id=wx.ID_ANY, label="%s" % LocUnits)
- flexSizer.Add(txt, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
- flexSizer.Add(self.queryLengthSL, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
- flexSizer.Add(self.queryLengthValue, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
- flexSizer.Add(units, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
- sizer.Add(item=flexSizer, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
+ txt = wx.StaticText(parent = panel, id = wx.ID_ANY, label = _("Select lines"))
+ self.queryLengthSL = wx.Choice (parent = panel, id = wx.ID_ANY,
+ choices = [_("shorter than"), _("longer than")])
+ self.queryLengthSL.SetSelection(UserSettings.Get(group = 'vdigit', key = "queryLength", subkey = 'than-selection'))
+ self.queryLengthValue = wx.SpinCtrl(parent = panel, id = wx.ID_ANY, size = (100, -1),
+ initial = 1,
+ min = 0, max = 1e6)
+ self.queryLengthValue.SetValue(UserSettings.Get(group = 'vdigit', key = "queryLength", subkey = 'thresh'))
+ units = wx.StaticText(parent = panel, id = wx.ID_ANY, label = "%s" % LocUnits)
+ flexSizer.Add(txt, proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL)
+ flexSizer.Add(self.queryLengthSL, proportion = 0, flag = wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
+ flexSizer.Add(self.queryLengthValue, proportion = 0, flag = wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
+ flexSizer.Add(units, proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL)
+ sizer.Add(item = flexSizer, proportion = 0, flag = wx.ALL | wx.EXPAND, border = 1)
# dangle
- self.queryDangle = wx.RadioButton(parent=panel, id=wx.ID_ANY, label=_("dangle"))
+ self.queryDangle = wx.RadioButton(parent = panel, id = wx.ID_ANY, label = _("dangle"))
self.queryDangle.Bind(wx.EVT_RADIOBUTTON, self.OnChangeQuery)
- sizer.Add(item=self.queryDangle, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
+ sizer.Add(item = self.queryDangle, proportion = 0, flag = wx.ALL | wx.EXPAND, border = 1)
- txt = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Select dangles"))
- self.queryDangleSL = wx.Choice (parent=panel, id=wx.ID_ANY,
+ txt = wx.StaticText(parent = panel, id = wx.ID_ANY, label = _("Select dangles"))
+ self.queryDangleSL = wx.Choice (parent = panel, id = wx.ID_ANY,
- self.queryDangleSL.SetSelection(UserSettings.Get(group='vdigit', key="queryDangle", subkey='than-selection'))
- self.queryDangleValue = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(100, -1),
- initial=1,
- min=0, max=1e6)
- self.queryDangleValue.SetValue(UserSettings.Get(group='vdigit', key="queryDangle", subkey='thresh'))
- flexSizer.Add(self.queryDangleSL, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
- flexSizer.Add(self.queryDangleValue, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
+ self.queryDangleSL.SetSelection(UserSettings.Get(group = 'vdigit', key = "queryDangle", subkey = 'than-selection'))
+ self.queryDangleValue = wx.SpinCtrl(parent = panel, id = wx.ID_ANY, size = (100, -1),
+ initial = 1,
+ self.queryDangleValue.SetValue(UserSettings.Get(group = 'vdigit', key = "queryDangle", subkey = 'thresh'))
+ flexSizer.Add(self.queryDangleSL, proportion = 0, flag = wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
+ flexSizer.Add(self.queryDangleValue, proportion = 0, flag = wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
- if UserSettings.Get(group='vdigit', key="query", subkey='selection') == 0:
+ if UserSettings.Get(group = 'vdigit', key = "query", subkey = 'selection') == 0:
self.queryLength.SetValue(True)
else:
self.queryDangle.SetValue(True)
@@ -1433,7 +363,7 @@
# enable & disable items
self.OnChangeQuery(None)
@@ -1441,91 +371,90 @@
def __CreateAttributesPage(self, notebook):
+ notebook.AddPage(page = panel, text = _("Attributes"))
- notebook.AddPage(page=panel, text=_("Attributes"))
# add new record
- box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Digitize new feature"))
+ box = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Digitize new feature"))
# checkbox
- self.addRecord = wx.CheckBox(parent=panel, id=wx.ID_ANY,
- label=_("Add new record into table"))
- self.addRecord.SetValue(UserSettings.Get(group='vdigit', key="addRecord", subkey='enabled'))
- sizer.Add(item=self.addRecord, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
+ self.addRecord = wx.CheckBox(parent = panel, id = wx.ID_ANY,
+ label = _("Add new record into table"))
+ self.addRecord.SetValue(UserSettings.Get(group = 'vdigit', key = "addRecord", subkey = 'enabled'))
+ sizer.Add(item = self.addRecord, proportion = 0, flag = wx.ALL | wx.EXPAND, border = 1)
# settings
- flexSizer = wx.FlexGridSizer(cols=2, hgap=3, vgap=3)
+ flexSizer = wx.FlexGridSizer(cols = 2, hgap = 3, vgap = 3)
settings = ((_("Layer"), 1), (_("Category"), 1), (_("Mode"), _("Next to use")))
# layer
- text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Layer"))
- self.layer = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(125, -1),
+ text = wx.StaticText(parent = panel, id = wx.ID_ANY, label = _("Layer"))
+ self.layer = wx.SpinCtrl(parent = panel, id = wx.ID_ANY, size = (125, -1),
min = 1, max = 1e3)
- self.layer.SetValue(int(UserSettings.Get(group='vdigit', key="layer", subkey='value')))
- flexSizer.Add(item=text, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
- flexSizer.Add(item=self.layer, proportion=0,
- flag=wx.FIXED_MINSIZE | wx.ALIGN_CENTER_VERTICAL)
+ self.layer.SetValue(int(UserSettings.Get(group = 'vdigit', key = "layer", subkey = 'value')))
+ flexSizer.Add(item = text, proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL)
+ flexSizer.Add(item = self.layer, proportion = 0,
+ flag = wx.FIXED_MINSIZE | wx.ALIGN_CENTER_VERTICAL)
# category number
- text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Category number"))
- self.category = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(125, -1),
- initial=UserSettings.Get(group='vdigit', key="category", subkey='value'),
- min=-1e9, max=1e9)
- if UserSettings.Get(group='vdigit', key="categoryMode", subkey='selection') != 1:
+ text = wx.StaticText(parent = panel, id = wx.ID_ANY, label = _("Category number"))
+ self.category = wx.SpinCtrl(parent = panel, id = wx.ID_ANY, size = (125, -1),
+ initial = UserSettings.Get(group = 'vdigit', key = "category", subkey = 'value'),
+ min = -1e9, max = 1e9)
+ if UserSettings.Get(group = 'vdigit', key = "categoryMode", subkey = 'selection') != 1:
self.category.Enable(False)
- flexSizer.Add(item=self.category, proportion=0,
+ flexSizer.Add(item = self.category, proportion = 0,
# category mode
- text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Category mode"))
- self.categoryMode = wx.Choice(parent=panel, id=wx.ID_ANY, size=(125, -1),
- choices=[_("Next to use"), _("Manual entry"), _("No category")])
- self.categoryMode.SetSelection(UserSettings.Get(group='vdigit', key="categoryMode", subkey='selection'))
- flexSizer.Add(item=self.categoryMode, proportion=0,
+ text = wx.StaticText(parent = panel, id = wx.ID_ANY, label = _("Category mode"))
+ self.categoryMode = wx.Choice(parent = panel, id = wx.ID_ANY, size = (125, -1),
+ choices = [_("Next to use"), _("Manual entry"), _("No category")])
+ self.categoryMode.SetSelection(UserSettings.Get(group = 'vdigit', key = "categoryMode", subkey = 'selection'))
+ flexSizer.Add(item = self.categoryMode, proportion = 0,
- flag=wx.ALL | wx.EXPAND, border=5)
+ flag = wx.ALL | wx.EXPAND, border = 5)
# digitize new area
- box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Digitize new area"))
+ box = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Digitize new area"))
# add centroid
- self.addCentroid = wx.CheckBox(parent=panel, id=wx.ID_ANY,
- label=_("Add centroid to left/right area"))
- self.addCentroid.SetValue(UserSettings.Get(group='vdigit', key="addCentroid", subkey='enabled'))
- sizer.Add(item=self.addCentroid, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
+ self.addCentroid = wx.CheckBox(parent = panel, id = wx.ID_ANY,
+ label = _("Add centroid to left/right area"))
+ self.addCentroid.SetValue(UserSettings.Get(group = 'vdigit', key = "addCentroid", subkey = 'enabled'))
+ sizer.Add(item = self.addCentroid, proportion = 0, flag = wx.ALL | wx.EXPAND, border = 1)
# attach category to boundary
- self.catBoundary = wx.CheckBox(parent=panel, id=wx.ID_ANY,
- label=_("Do not attach category to boundaries"))
- self.catBoundary.SetValue(UserSettings.Get(group='vdigit', key="catBoundary", subkey='enabled'))
- sizer.Add(item=self.catBoundary, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
- flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border=5)
+ self.catBoundary = wx.CheckBox(parent = panel, id = wx.ID_ANY,
+ label = _("Do not attach category to boundaries"))
+ self.catBoundary.SetValue(UserSettings.Get(group = 'vdigit', key = "catBoundary", subkey = 'enabled'))
+ sizer.Add(item = self.catBoundary, proportion = 0, flag = wx.ALL | wx.EXPAND, border = 1)
+ flag = wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border = 5)
# delete existing record
- box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Delete existing feature(s)"))
+ box = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Delete existing feature(s)"))
# checkbox
- self.deleteRecord = wx.CheckBox(parent=panel, id=wx.ID_ANY,
- label=_("Delete record from table"))
- self.deleteRecord.SetValue(UserSettings.Get(group='vdigit', key="delRecord", subkey='enabled'))
- sizer.Add(item=self.deleteRecord, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
+ self.deleteRecord = wx.CheckBox(parent = panel, id = wx.ID_ANY,
+ label = _("Delete record from table"))
+ self.deleteRecord.SetValue(UserSettings.Get(group = 'vdigit', key = "delRecord", subkey = 'enabled'))
+ sizer.Add(item = self.deleteRecord, proportion = 0, flag = wx.ALL | wx.EXPAND, border = 1)
# geometry attributes (currently only length and area are supported)
@@ -1533,7 +462,7 @@
label = " %s " % _("Geometry attributes"))
- gridSizer = wx.GridBagSizer(hgap=3, vgap=3)
+ gridSizer = wx.GridBagSizer(hgap = 3, vgap = 3)
gridSizer.AddGrowableCol(0)
self.geomAttrb = { 'length' : { 'label' : _('length') },
'area' : { 'label' : _('area') },
@@ -1544,7 +473,7 @@
vectorName = digitToolbar.GetLayer().GetName()
except AttributeError:
vectorName = None # no vector selected for editing
+ layer = UserSettings.Get(group = 'vdigit', key = "layer", subkey = 'value')
mapLayer = self.parent.toolbars['vdigit'].GetLayer()
tree = self.parent.tree
item = tree.FindItemByData('maplayer', mapLayer)
@@ -1556,7 +485,7 @@
### self.deleteRecord.SetValue(UserSettings.Get(group='vdigit', key="delRecord", subkey='enabled'))
check.Bind(wx.EVT_CHECKBOX, self.OnGeomAttrb)
# column (only numeric)
- column = gselect.ColumnSelect(parent = panel, size=(200, -1))
+ column = gselect.ColumnSelect(parent = panel, size = (200, -1))
column.InsertColumns(vector = vectorName,
layer = layer, excludeKey = True,
type = ['integer', 'double precision'])
@@ -1566,7 +495,7 @@
else:
choices = Units.GetUnitsList('length')
win_units = wx.Choice(parent = panel, id = wx.ID_ANY,
- choices = choices, size=(120, -1))
+ choices = choices, size = (120, -1))
# default values
check.SetValue(False)
@@ -1608,12 +537,12 @@
"preferences."), 55))
gridSizer.Add(item = wx.StaticText(parent = panel, id = wx.ID_ANY,
label = note),
- pos = (3, 0), span=(1, 3))
+ pos = (3, 0), span = (1, 3))
- sizer.Add(item=gridSizer, proportion=1,
+ sizer.Add(item = gridSizer, proportion = 1,
# bindings
self.Bind(wx.EVT_CHECKBOX, self.OnChangeAddRecord, self.addRecord)
@@ -1625,8 +554,7 @@
return panel
def __SymbologyData(self):
- Data for __CreateSymbologyPage()
+ """!Data for __CreateSymbologyPage()
label | checkbox | color
@@ -1667,9 +595,8 @@
def OnChangeCategoryMode(self, event):
"""!Change category mode"""
mode = event.GetSelection()
- UserSettings.Set(group='vdigit', key="categoryMode", subkey='selection', value=mode)
+ UserSettings.Set(group = 'vdigit', key = "categoryMode", subkey = 'selection', value = mode)
if mode == 1: # manual entry
self.category.Enable(True)
elif self.category.IsEnabled(): # disable
@@ -1679,15 +606,15 @@
self.addRecord.SetValue(False)
self.parent.digit.SetCategory()
- self.category.SetValue(UserSettings.Get(group='vdigit', key='category', subkey='value'))
+ self.category.SetValue(UserSettings.Get(group = 'vdigit', key = 'category', subkey = 'value'))
def OnChangeLayer(self, event):
"""!Layer changed"""
layer = event.GetInt()
if layer > 0:
- UserSettings.Set(group='vdigit', key='layer', subkey='value', value=layer)
+ UserSettings.Set(group = 'vdigit', key = 'layer', subkey = 'value', value = layer)
event.Skip()
@@ -1702,12 +629,12 @@
if value < 0:
region = self.parent.MapWindow.Map.GetRegion()
res = (region['nsres'] + region['ewres']) / 2.
- threshold = self.parent.digit.driver.GetThreshold(value=res)
+ threshold = self.parent.digit.driver.GetThreshold(value = res)
else:
if self.snappingUnit.GetStringSelection() == "map units":
threshold = value
else:
- threshold = self.parent.digit.driver.GetThreshold(value=value)
+ threshold = self.parent.digit.driver.GetThreshold(value = value)
if value == 0:
self.snappingInfo.SetLabel(_("Snapping disabled"))
@@ -1727,7 +654,7 @@
"""!Snapping units change -> update static text"""
value = self.snappingValue.GetValue()
units = self.snappingUnit.GetStringSelection()
- threshold = self.parent.digit.driver.GetThreshold(value=value, units=units)
+ threshold = self.parent.digit.driver.GetThreshold(value = value, units = units)
if units == "map units":
self.snappingInfo.SetLabel(_("Snapping threshold is %(value).1f %(units)s") %
@@ -1761,8 +688,8 @@
self.parent.toolbars['vdigit'].settingsDialog = None
fileSettings = {}
- UserSettings.ReadSettingsFile(settings=fileSettings)
- fileSettings['vdigit'] = UserSettings.Get(group='vdigit')
+ UserSettings.ReadSettingsFile(settings = fileSettings)
+ fileSettings['vdigit'] = UserSettings.Get(group = 'vdigit')
file = UserSettings.SaveToFile(fileSettings)
self.parent.GetLayerManager().goutput.WriteLog(_('Vector digitizer settings saved to file <%s>.') % file)
@@ -1784,52 +711,52 @@
event.Skip()
- """!Update UserSettings"""
+ """!Update digitizer settings
# symbology
for key, (enabled, color) in self.symbology.iteritems():
if enabled:
- UserSettings.Set(group='vdigit', key='symbol',
- subkey=[key, 'enabled'],
- value=enabled.IsChecked())
- subkey=[key, 'color'],
- value=tuple(color.GetColour()))
+ UserSettings.Set(group = 'vdigit', key = 'symbol',
+ subkey = [key, 'enabled'],
+ value = enabled.IsChecked())
+ subkey = [key, 'color'],
+ value = tuple(color.GetColour()))
else:
# display
- UserSettings.Set(group='vdigit', key="lineWidth", subkey='value',
- value=int(self.lineWidthValue.GetValue()))
+ UserSettings.Set(group = 'vdigit', key = "lineWidth", subkey = 'value',
+ value = int(self.lineWidthValue.GetValue()))
# snapping
- UserSettings.Set(group='vdigit', key="snapping", subkey='value',
- value=int(self.snappingValue.GetValue()))
- UserSettings.Set(group='vdigit', key="snapping", subkey='units',
- value=self.snappingUnit.GetStringSelection())
- UserSettings.Set(group='vdigit', key="snapToVertex", subkey='enabled',
- value=self.snapVertex.IsChecked())
+ UserSettings.Set(group = 'vdigit', key = "snapping", subkey = 'value',
+ value = int(self.snappingValue.GetValue()))
+ UserSettings.Set(group = 'vdigit', key = "snapping", subkey = 'units',
+ value = self.snappingUnit.GetStringSelection())
+ UserSettings.Set(group = 'vdigit', key = "snapToVertex", subkey = 'enabled',
+ value = self.snapVertex.IsChecked())
# digitize new feature
- UserSettings.Set(group='vdigit', key="addRecord", subkey='enabled',
- value=self.addRecord.IsChecked())
- UserSettings.Set(group='vdigit', key="layer", subkey='value',
- value=int(self.layer.GetValue()))
- UserSettings.Set(group='vdigit', key="category", subkey='value',
- value=int(self.category.GetValue()))
- value=self.categoryMode.GetSelection())
+ UserSettings.Set(group = 'vdigit', key = "addRecord", subkey = 'enabled',
+ value = self.addRecord.IsChecked())
+ UserSettings.Set(group = 'vdigit', key = "layer", subkey = 'value',
+ value = int(self.layer.GetValue()))
+ UserSettings.Set(group = 'vdigit', key = "category", subkey = 'value',
+ value = int(self.category.GetValue()))
+ value = self.categoryMode.GetSelection())
# digitize new area
- UserSettings.Set(group='vdigit', key="addCentroid", subkey='enabled',
- value=self.addCentroid.IsChecked())
- UserSettings.Set(group='vdigit', key="catBoundary", subkey='enabled',
- value=self.catBoundary.IsChecked())
+ UserSettings.Set(group = 'vdigit', key = "addCentroid", subkey = 'enabled',
+ value = self.addCentroid.IsChecked())
+ UserSettings.Set(group = 'vdigit', key = "catBoundary", subkey = 'enabled',
+ value = self.catBoundary.IsChecked())
# delete existing feature
- UserSettings.Set(group='vdigit', key="delRecord", subkey='enabled',
- value=self.deleteRecord.IsChecked())
+ UserSettings.Set(group = 'vdigit', key = "delRecord", subkey = 'enabled',
+ value = self.deleteRecord.IsChecked())
# geometry attributes (workspace)
@@ -1855,74 +782,65 @@
tree.GetPyData(item)[0]['vdigit']['geomAttr'].has_key(key):
del tree.GetPyData(item)[0]['vdigit']['geomAttr'][key]
- # snapping threshold
- self.parent.digit.threshold = self.parent.digit.driver.GetThreshold()
# query tool
if self.queryLength.GetValue():
- UserSettings.Set(group='vdigit', key="query", subkey='selection',
- value=0)
+ UserSettings.Set(group = 'vdigit', key = "query", subkey = 'selection',
+ value = 0)
else:
- UserSettings.Set(group='vdigit', key="query", subkey='type',
- value=1)
- UserSettings.Set(group='vdigit', key="query", subkey='box',
- value=self.queryBox.IsChecked())
- UserSettings.Set(group='vdigit', key="queryLength", subkey='than-selection',
- value=self.queryLengthSL.GetSelection())
- UserSettings.Set(group='vdigit', key="queryLength", subkey='thresh',
- value=int(self.queryLengthValue.GetValue()))
- UserSettings.Set(group='vdigit', key="queryDangle", subkey='than-selection',
- value=self.queryDangleSL.GetSelection())
- UserSettings.Set(group='vdigit', key="queryDangle", subkey='thresh',
- value=int(self.queryDangleValue.GetValue()))
+ UserSettings.Set(group = 'vdigit', key = "query", subkey = 'type',
+ value = 1)
+ UserSettings.Set(group = 'vdigit', key = "query", subkey = 'box',
+ value = self.queryBox.IsChecked())
+ UserSettings.Set(group = 'vdigit', key = "queryLength", subkey = 'than-selection',
+ value = self.queryLengthSL.GetSelection())
+ UserSettings.Set(group = 'vdigit', key = "queryLength", subkey = 'thresh',
+ value = int(self.queryLengthValue.GetValue()))
+ UserSettings.Set(group = 'vdigit', key = "queryDangle", subkey = 'than-selection',
+ value = self.queryDangleSL.GetSelection())
+ UserSettings.Set(group = 'vdigit', key = "queryDangle", subkey = 'thresh',
+ value = int(self.queryDangleValue.GetValue()))
# select features
- UserSettings.Set(group='vdigit', key='selectType',
- subkey=[feature, 'enabled'],
- value=self.FindWindowById(self.selectFeature[feature]).IsChecked())
- UserSettings.Set(group='vdigit', key="selectThresh", subkey='value',
- value=int(self.selectThreshValue.GetValue()))
- UserSettings.Set(group='vdigit', key="checkForDupl", subkey='enabled',
- value=self.checkForDupl.IsChecked())
- UserSettings.Set(group='vdigit', key="selectInside", subkey='enabled',
- value=self.selectIn.IsChecked())
+ UserSettings.Set(group = 'vdigit', key = 'selectType',
+ subkey = [feature, 'enabled'],
+ value = self.FindWindowById(self.selectFeature[feature]).IsChecked())
+ UserSettings.Set(group = 'vdigit', key = "selectThresh", subkey = 'value',
+ value = int(self.selectThreshValue.GetValue()))
+ UserSettings.Set(group = 'vdigit', key = "checkForDupl", subkey = 'enabled',
+ value = self.checkForDupl.IsChecked())
+ UserSettings.Set(group = 'vdigit', key = "selectInside", subkey = 'enabled',
+ value = self.selectIn.IsChecked())
# on-exit
- UserSettings.Set(group='vdigit', key="saveOnExit", subkey='enabled',
- value=self.save.IsChecked())
+ UserSettings.Set(group = 'vdigit', key = "saveOnExit", subkey = 'enabled',
+ value = self.save.IsChecked())
# break lines
- UserSettings.Set(group='vdigit', key="breakLines", subkey='enabled',
- value=self.intersect.IsChecked())
+ UserSettings.Set(group = 'vdigit', key = "breakLines", subkey = 'enabled',
+ value = self.intersect.IsChecked())
- # update driver settings
- self.parent.digit.driver.UpdateSettings()
- # update digit settings
- self.parent.digit.UpdateSettings()
+ self.parent.digit.GetDisplay().UpdateSettings()
# redraw map if auto-rendering is enabled
if self.parent.statusbarWin['render'].GetValue():
self.parent.OnRender(None)
class VDigitCategoryDialog(wx.Dialog, listmix.ColumnSorterMixin):
- Dialog used to display/modify categories of vector objects
- @param parent
- @param title dialog title
- @param query {coordinates, qdist} - used by v.edit/v.what
- @param cats directory of lines (layer/categories) - used by vdigit
- @param pos
- @param style
- map, query=None, cats=None,
- pos=wx.DefaultPosition,
- style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
+ map, query = None, cats = None,
+ pos = wx.DefaultPosition,
+ style = wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
+ """!Dialog used to display/modify categories of vector objects
+ @param parent
+ @param title dialog title
+ @param query {coordinates, qdist} - used by v.edit/v.what
+ @param cats directory of lines (layer/categories) - used by vdigit
+ @param pos
+ @param style
# parent
@@ -1949,15 +867,15 @@
# make copy of cats (used for 'reload')
self.cats_orig = copy.deepcopy(self.cats)
- wx.Dialog.__init__(self, parent=self.parent, id=wx.ID_ANY, title=title,
- style=style, pos=pos)
+ wx.Dialog.__init__(self, parent = self.parent, id = wx.ID_ANY, title = title,
+ style = style, pos = pos)
# list of categories
- box = wx.StaticBox(parent=self, id=wx.ID_ANY,
- label=" %s " % _("List of categories - right-click to delete"))
+ box = wx.StaticBox(parent = self, id = wx.ID_ANY,
+ label = " %s " % _("List of categories - right-click to delete"))
listSizer = wx.StaticBoxSizer(box, wx.VERTICAL)
- self.list = CategoryListCtrl(parent=self, id=wx.ID_ANY,
- style=wx.LC_REPORT |
+ self.list = CategoryListCtrl(parent = self, id = wx.ID_ANY,
+ style = wx.LC_REPORT |
wx.BORDER_NONE |
wx.LC_SORT_ASCENDING |
wx.LC_HRULES |
@@ -1966,10 +884,10 @@
self.fid = self.cats.keys()[0]
self.itemDataMap = self.list.Populate(self.cats[self.fid])
listmix.ColumnSorterMixin.__init__(self, 2)
- self.fidMulti = wx.Choice(parent=self, id=wx.ID_ANY,
- size=(150, -1))
+ self.fidMulti = wx.Choice(parent = self, id = wx.ID_ANY,
+ size = (150, -1))
self.fidMulti.Bind(wx.EVT_CHOICE, self.OnFeature)
- self.fidText = wx.StaticText(parent=self, id=wx.ID_ANY)
+ self.fidText = wx.StaticText(parent = self, id = wx.ID_ANY)
if len(self.cats.keys()) == 1:
self.fidMulti.Show(False)
self.fidText.SetLabel(str(self.fid))
@@ -1981,44 +899,44 @@
self.fidMulti.SetItems(choices)
self.fidMulti.SetSelection(0)
- listSizer.Add(item=self.list, proportion=1, flag=wx.EXPAND)
+ listSizer.Add(item = self.list, proportion = 1, flag = wx.EXPAND)
# add new category
- label=" %s " % _("Add new category"))
+ label = " %s " % _("Add new category"))
addSizer = wx.StaticBoxSizer(box, wx.VERTICAL)
- flexSizer = wx.FlexGridSizer (cols=5, hgap=5, vgap=5)
+ flexSizer = wx.FlexGridSizer (cols = 5, hgap = 5, vgap = 5)
flexSizer.AddGrowableCol(3)
- layerNewTxt = wx.StaticText(parent=self, id=wx.ID_ANY,
- label="%s:" % _("Layer"))
- self.layerNew = wx.Choice(parent=self, id=wx.ID_ANY, size=(75, -1),
- choices=layers)
+ layerNewTxt = wx.StaticText(parent = self, id = wx.ID_ANY,
+ label = "%s:" % _("Layer"))
+ self.layerNew = wx.Choice(parent = self, id = wx.ID_ANY, size = (75, -1),
+ choices = layers)
if len(layers) > 0:
self.layerNew.SetSelection(0)
- catNewTxt = wx.StaticText(parent=self, id=wx.ID_ANY,
- label="%s:" % _("Category"))
+ catNewTxt = wx.StaticText(parent = self, id = wx.ID_ANY,
+ label = "%s:" % _("Category"))
try:
newCat = max(self.cats[self.fid][1]) + 1
except KeyError:
newCat = 1
- self.catNew = wx.SpinCtrl(parent=self, id=wx.ID_ANY, size=(75, -1),
- initial=newCat, min=0, max=1e9)
+ self.catNew = wx.SpinCtrl(parent = self, id = wx.ID_ANY, size = (75, -1),
+ initial = newCat, min = 0, max = 1e9)
btnAddCat = wx.Button(self, wx.ID_ADD)
- flexSizer.Add(item=layerNewTxt, proportion=0,
- flexSizer.Add(item=self.layerNew, proportion=0,
- flexSizer.Add(item=catNewTxt, proportion=0,
- flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT | wx.LEFT,
- border=10)
- flexSizer.Add(item=self.catNew, proportion=0,
- flexSizer.Add(item=btnAddCat, proportion=0,
- flag=wx.EXPAND | wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
- addSizer.Add(item=flexSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=5)
+ flexSizer.Add(item = layerNewTxt, proportion = 0,
+ flexSizer.Add(item = self.layerNew, proportion = 0,
+ flexSizer.Add(item = catNewTxt, proportion = 0,
+ flag = wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT | wx.LEFT,
+ border = 10)
+ flexSizer.Add(item = self.catNew, proportion = 0,
+ flexSizer.Add(item = btnAddCat, proportion = 0,
+ flag = wx.EXPAND | wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
+ addSizer.Add(item = flexSizer, proportion = 1, flag = wx.ALL | wx.EXPAND, border = 5)
# buttons
btnApply = wx.Button(self, wx.ID_APPLY)
@@ -2039,24 +957,24 @@
btnSizer.Realize()
- mainSizer.Add(item=listSizer, proportion=1,
- mainSizer.Add(item=addSizer, proportion=0,
- flag=wx.EXPAND | wx.ALIGN_CENTER |
- wx.LEFT | wx.RIGHT | wx.BOTTOM, border=5)
+ mainSizer.Add(item = listSizer, proportion = 1,
+ mainSizer.Add(item = addSizer, proportion = 0,
+ flag = wx.EXPAND | wx.ALIGN_CENTER |
+ wx.LEFT | wx.RIGHT | wx.BOTTOM, border = 5)
fidSizer = wx.BoxSizer(wx.HORIZONTAL)
- fidSizer.Add(item=wx.StaticText(parent=self, id=wx.ID_ANY,
- label=_("Feature id:")),
- proportion=0, border=5,
- flag=wx.ALIGN_CENTER_VERTICAL)
- fidSizer.Add(item=self.fidMulti, proportion=0,
- fidSizer.Add(item=self.fidText, proportion=0,
- mainSizer.Add(item=fidSizer, proportion=0,
+ fidSizer.Add(item = wx.StaticText(parent = self, id = wx.ID_ANY,
+ label = _("Feature id:")),
+ proportion = 0, border = 5,
+ flag = wx.ALIGN_CENTER_VERTICAL)
+ fidSizer.Add(item = self.fidMulti, proportion = 0,
+ fidSizer.Add(item = self.fidText, proportion = 0,
+ mainSizer.Add(item = fidSizer, proportion = 0,
self.SetSizer(mainSizer)
mainSizer.Fit(self)
@@ -2144,9 +1062,9 @@
self.popupID1 = wx.NewId()
self.popupID2 = wx.NewId()
self.popupID3 = wx.NewId()
- self.Bind(wx.EVT_MENU, self.OnItemDelete, id=self.popupID1)
- self.Bind(wx.EVT_MENU, self.OnItemDeleteAll, id=self.popupID2)
- self.Bind(wx.EVT_MENU, self.OnReload, id=self.popupID3)
+ self.Bind(wx.EVT_MENU, self.OnItemDelete, id = self.popupID1)
+ self.Bind(wx.EVT_MENU, self.OnItemDeleteAll, id = self.popupID2)
+ self.Bind(wx.EVT_MENU, self.OnReload, id = self.popupID3)
# generate popup-menu
menu = wx.Menu()
@@ -2190,7 +1108,7 @@
self.fid = int(event.GetString())
self.itemDataMap = self.list.Populate(self.cats[self.fid],
- update=True)
+ update = True)
try:
@@ -2238,7 +1156,7 @@
# polulate list
- update=True)
+ update = True)
event.Skip()
@@ -2247,7 +1165,7 @@
self.parent.parent.dialogs['category'] = None
if self.parent.parent.digit:
self.parent.parent.digit.driver.SetSelected([])
- self.parent.UpdateMap(render=False)
+ self.parent.UpdateMap(render = False)
else:
self.parent.parent.OnRender(None)
@@ -2299,8 +1217,8 @@
fid = newfid
if self.fid < 0:
- wx.MessageBox(parent=self, message=_("Unable to update vector map."),
- caption=_("Error"), style=wx.OK | wx.ICON_ERROR)
+ wx.MessageBox(parent = self, message = _("Unable to update vector map."),
+ caption = _("Error"), style = wx.OK | wx.ICON_ERROR)
self.cats_orig[fid] = copy.deepcopy(cats)
@@ -2336,7 +1254,7 @@
# reload list
- update=True)
+ update = True)
# update category number for add
self.catNew.SetValue(cat + 1)
@@ -2349,7 +1267,7 @@
"""!Get id of selected line of 'None' if no line is selected"""
return self.cats.keys()
- def UpdateDialog(self, query=None, cats=None):
+ def UpdateDialog(self, query = None, cats = None):
"""!Update dialog
@param query {coordinates, distance} - v.edit/v.what
@@ -2377,7 +1295,7 @@
# polulate list
- update=True)
+ update = True)
try:
@@ -2405,11 +1323,9 @@
class CategoryListCtrl(wx.ListCtrl,
listmix.ListCtrlAutoWidthMixin,
listmix.TextEditMixin):
- """!List of layers/categories"""
- def __init__(self, parent, id, pos=wx.DefaultPosition,
- size=wx.DefaultSize, style=0):
+ def __init__(self, parent, id, pos = wx.DefaultPosition,
+ size = wx.DefaultSize, style = 0):
+ """!List of layers/categories"""
wx.ListCtrl.__init__(self, parent, id, pos, size, style)
@@ -2417,9 +1333,8 @@
listmix.ListCtrlAutoWidthMixin.__init__(self)
listmix.TextEditMixin.__init__(self)
- def Populate(self, cats, update=False):
+ def Populate(self, cats, update = False):
"""!Populate the list"""
itemData = {} # requested by sorter
if not update:
@@ -2448,11 +1363,10 @@
return itemData
class VDigitZBulkDialog(wx.Dialog):
- Dialog used for Z bulk-labeling tool
- def __init__(self, parent, title, nselected, style=wx.DEFAULT_DIALOG_STYLE):
+ def __init__(self, parent, title, nselected, style = wx.DEFAULT_DIALOG_STYLE):
+ """!Dialog used for Z bulk-labeling tool
+ wx.Dialog.__init__(self, parent = parent, id = wx.ID_ANY, title = title, style = style)
@@ -2460,35 +1374,35 @@
- txt = wx.StaticText(parent=self,
- label=_("%d lines selected for z bulk-labeling") % nselected);
- border.Add(item=txt, proportion=0, flag=wx.ALL | wx.EXPAND, border=5)
+ txt = wx.StaticText(parent = self,
+ label = _("%d lines selected for z bulk-labeling") % nselected);
+ border.Add(item = txt, proportion = 0, flag = wx.ALL | wx.EXPAND, border = 5)
- box = wx.StaticBox (parent=self, id=wx.ID_ANY, label=" %s " % _("Set value"))
+ box = wx.StaticBox (parent = self, id = wx.ID_ANY, label = " %s " % _("Set value"))
- flexSizer = wx.FlexGridSizer (cols=2, hgap=5, vgap=5)
+ flexSizer = wx.FlexGridSizer (cols = 2, hgap = 5, vgap = 5)
# starting value
- label=_("Starting value"));
- self.value = wx.SpinCtrl(parent=self, id=wx.ID_ANY, size=(150, -1),
- initial=0,
- min=-1e6, max=1e6)
- flexSizer.Add(self.value, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
+ label = _("Starting value"));
+ self.value = wx.SpinCtrl(parent = self, id = wx.ID_ANY, size = (150, -1),
+ initial = 0,
+ min = -1e6, max = 1e6)
+ flexSizer.Add(self.value, proportion = 0, flag = wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
# step
- label=_("Step"))
- self.step = wx.SpinCtrl(parent=self, id=wx.ID_ANY, size=(150, -1),
- initial=0,
- min=0, max=1e6)
- flexSizer.Add(self.step, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
+ label = _("Step"))
+ self.step = wx.SpinCtrl(parent = self, id = wx.ID_ANY, size = (150, -1),
+ initial = 0,
+ flexSizer.Add(self.step, proportion = 0, flag = wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
- border.Add(item=sizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=0)
+ border.Add(item = sizer, proportion = 1, flag = wx.ALL | wx.EXPAND, border = 0)
# buttons
btnCancel = wx.Button(self, wx.ID_CANCEL)
@@ -2502,23 +1416,21 @@
btnSizer.Realize()
- mainSizer.Add(item=border, proportion=1, flag=wx.EXPAND | wx.ALL, border=5)
+ mainSizer.Add(item = border, proportion = 1, flag = wx.EXPAND | wx.ALL, border = 5)
mainSizer.Fit(self)
class VDigitDuplicatesDialog(wx.Dialog):
- Show duplicated feature ids
- def __init__(self, parent, data, title=_("List of duplicates"),
- style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER,
- pos=wx.DefaultPosition):
- wx.Dialog.__init__(self, parent=parent, id=wx.ID_ANY, title=title, style=style,
- pos=pos)
+ def __init__(self, parent, data, title = _("List of duplicates"),
+ style = wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER,
+ pos = wx.DefaultPosition):
+ """!Show duplicated feature ids
+ wx.Dialog.__init__(self, parent = parent, id = wx.ID_ANY, title = title, style = style,
+ pos = pos)
self.parent = parent # BufferedWindow
self.data = data
@@ -2527,21 +1439,21 @@
# panel = wx.Panel(parent=self, id=wx.ID_ANY)
# notebook
- self.notebook = wx.Notebook(parent=self, id=wx.ID_ANY, style=wx.BK_DEFAULT)
+ self.notebook = wx.Notebook(parent = self, id = wx.ID_ANY, style = wx.BK_DEFAULT)
id = 1
for key in self.data.keys():
- panel = wx.Panel(parent=self.notebook, id=wx.ID_ANY)
- self.notebook.AddPage(page=panel, text=" %d " % (id))
+ panel = wx.Panel(parent = self.notebook, id = wx.ID_ANY)
+ self.notebook.AddPage(page = panel, text = " %d " % (id))
# notebook body
- win = CheckListFeature(parent=panel, data=list(self.data[key]))
+ win = CheckListFeature(parent = panel, data = list(self.data[key]))
self.winList.append(win.GetId())
- border.Add(item=win, proportion=1,
+ border.Add(item = win, proportion = 1,
@@ -2559,9 +1471,9 @@
btnSizer.Realize()
- mainSizer.Add(item=self.notebook, proportion=1, flag=wx.EXPAND | wx.ALL, border=5)
+ mainSizer.Add(item = self.notebook, proportion = 1, flag = wx.EXPAND | wx.ALL, border = 5)
mainSizer.Fit(self)
@@ -2586,14 +1498,14 @@
return ids
class CheckListFeature(wx.ListCtrl, listmix.ListCtrlAutoWidthMixin, listmix.CheckListCtrlMixin):
- """!List of mapset/owner/group"""
- pos=wx.DefaultPosition, log=None):
+ pos = wx.DefaultPosition, log = None):
+ """!List of mapset/owner/group"""
self.data = data
wx.ListCtrl.__init__(self, parent, wx.ID_ANY,
- style=wx.LC_REPORT)
+ style = wx.LC_REPORT)
listmix.CheckListCtrlMixin.__init__(self)
@@ -2617,8 +1529,8 @@
for item in range(self.GetItemCount()):
self.CheckItem(item, True)
- self.SetColumnWidth(col=0, width=wx.LIST_AUTOSIZE_USEHEADER)
- self.SetColumnWidth(col=1, width=wx.LIST_AUTOSIZE_USEHEADER)
+ self.SetColumnWidth(col = 0, width = wx.LIST_AUTOSIZE_USEHEADER)
+ self.SetColumnWidth(col = 1, width = wx.LIST_AUTOSIZE_USEHEADER)
def OnCheckItem(self, index, flag):
"""!Mapset checked/unchecked"""
Added: grass/trunk/gui/wxpython/gui_modules/wxvdigit.py
--- grass/trunk/gui/wxpython/gui_modules/wxvdigit.py (rev 0)
+++ grass/trunk/gui/wxpython/gui_modules/wxvdigit.py 2011-01-01 19:26:54 UTC (rev 44823)
@@ -0,0 +1,798 @@
+ at package wxvdigit.py
+ at brief wxGUI vector digitizer (base class)
+Code based on wxVdigit C++ component from GRASS 6.4.0. Converted to
+Python in 2010/12-2011/01.
+List of classes:
+ - IVDigit
+(C) 2007-2011 by the GRASS Development Team
+This program is free software under the GNU General Public License
+(>=v2). Read the file COPYING that comes with GRASS for details.
+ at author Martin Landa <landa.martin gmail.com>
+from debug import Debug
+from preferences import globalSettings as UserSettings
+from wxvdriver import DisplayDriver
+from grass.lib.grass import *
+from grass.lib.vector import *
+class IVDigit:
+ def __init__(self, mapwindow):
+ self.map = None
+ self.mapWindow = mapwindow
+ if not mapwindow.parent.IsStandalone():
+ self.log = mapwindow.parent.GetLayerManager().goutput.cmd_stderr
+ else:
+ self.log = sys.stderr
+ self.toolbar = mapwindow.parent.toolbars['vdigit']
+ self._display = DisplayDriver(device = mapwindow.pdcVector,
+ deviceTmp = mapwindow.pdcTmp,
+ mapObj = mapwindow.Map,
+ log = self.log)
+ # self.SetCategory()
+ # layer / max category
+ self.cats = dict()
+ # settings
+ self._settings = {
+ 'breakLines' : None,
+ 'addCentroid' : None,
+ 'catBoundary' : None
+ # undo/redo
+ self.changesets = dict()
+ self.changesetCurrent = None # first changeset to apply
+ self.changesetEnd = None # last changeset to be applied
+ if self._display.mapInfo:
+ self.InitCats()
+ # initial value for undo/redo
+ self.changesetEnd = self.changesetCurrent = -1
+ def __del__(self):
+ pass # free changesets ?
+ def _setCategory(self):
+ pass
+ def _openBackgroundVectorMap(self):
+ pass
+ def _breakLineAtIntersection(self):
+ pass
+ def _addActionsBefore(self):
+ """!Register action before operation
+ @return changeset id
+ pass
+ def _addActionsAfter(self):
+ pass
+ def _addActionToChangeset(self):
+ pass
+ def _applyChangeset(self):
+ pass
+ def _freeChangeset(self):
+ pass
+ def _removeActionFromChangeset(self):
+ pass
+ def AddPoint (self, map, point, x, y, z=None):
+ """!Add new point/centroid
+ @param map map name (unused, for compatability with VEdit)
+ @param point feature type (if true point otherwise centroid)
+ @param x,y,z coordinates
+ if UserSettings.Get(group='vdigit', key="categoryMode", subkey='selection') == 2:
+ layer = -1 # -> no category
+ cat = -1
+ else:
+ layer = UserSettings.Get(group='vdigit', key="layer", subkey='value')
+ cat = self.SetCategory()
+ if point:
+ type = wxvdigit.GV_POINT
+ else:
+ type = wxvdigit.GV_CENTROID
+ snap, thresh = self.__getSnapThreshold()
+ bgmap = str(UserSettings.Get(group='vdigit', key="bgmap",
+ subkey='value', internal=True))
+ if z:
+ ret = self.digit.AddLine(type, [x, y, z], layer, cat,
+ bgmap, snap, thresh)
+ else:
+ ret = self.digit.AddLine(type, [x, y], layer, cat,
+ self.toolbar.EnableUndo()
+ return ret
+ def AddLine (self, map, line, coords):
+ """!Add line/boundary
+ @param line feature type (if True line, otherwise boundary)
+ @param coords list of coordinates
+ if len(coords) < 2:
+ return
+ cat = -1
+ else:
+ if line:
+ type = wxvdigit.GV_LINE
+ else:
+ type = wxvdigit.GV_BOUNDARY
+ listCoords = []
+ for c in coords:
+ for x in c:
+ listCoords.append(x)
+ ret = self.digit.AddLine(type, listCoords, layer, cat,
+ return ret
+ def DeleteSelectedLines(self):
+ """!Delete selected features
+ @return number of deleted lines
+ nlines = self.digit.DeleteLines(UserSettings.Get(group='vdigit', key='delRecord', subkey='enabled'))
+ if nlines > 0:
+ return nlines
+ def MoveSelectedLines(self, move):
+ """!Move selected features
+ @param move direction (x, y)
+ try:
+ nlines = self.digit.MoveLines(move[0], move[1], 0.0, # TODO 3D
+ except SystemExit:
+ pass
+ if nlines > 0:
+ return nlines
+ def MoveSelectedVertex(self, coords, move):
+ """!Move selected vertex of the line
+ @param coords click coordinates
+ @param move X,Y direction
+ @return id of new feature
+ @return 0 vertex not moved (not found, line is not selected)
+ moved = self.digit.MoveVertex(coords[0], coords[1], 0.0, # TODO 3D
+ move[0], move[1], 0.0,
+ bgmap, snap,
+ self.driver.GetThreshold(type='selectThresh'), thresh)
+ if moved:
+ return moved
+ def AddVertex(self, coords):
+ """!Add new vertex to the selected line/boundary on position 'coords'
+ @param coords coordinates to add vertex
+ @return 0 nothing changed
+ @return -1 on failure
+ added = self.digit.ModifyLineVertex(1, coords[0], coords[1], 0.0, # TODO 3D
+ self.driver.GetThreshold(type='selectThresh'))
+ if added > 0:
+ return added
+ def RemoveVertex(self, coords):
+ """!Remove vertex from the selected line/boundary on position 'coords'
+ @param coords coordinates to remove vertex
+ deleted = self.digit.ModifyLineVertex(0, coords[0], coords[1], 0.0, # TODO 3D
+ if deleted > 0:
+ return deleted
+ def SplitLine(self, coords):
+ """!Split selected line/boundary on position 'coords'
+ @param coords coordinates to split line
+ @return 1 line modified
+ @return -1 error
+ ret = self.digit.SplitLine(coords[0], coords[1], 0.0, # TODO 3D
+ self.driver.GetThreshold('selectThresh'))
+ if ret > 0:
+ return ret
+ def EditLine(self, line, coords):
+ """!Edit existing line/boundary
+ @param line id of line to be modified
+ @param coords list of coordinates of modified line
+ @return feature id of new line
+ @return -1 on error
+ try:
+ lineid = line[0]
+ except:
+ lineid = -1
+ self.DeleteSelectedLines()
+ return 0
+ listCoords = []
+ for c in coords:
+ for x in c:
+ try:
+ ret = self.digit.RewriteLine(lineid, listCoords,
+ pass
+ if ret > 0:
+ return ret
+ def FlipLine(self):
+ """!Flip selected lines/boundaries
+ @return number of modified lines
+ ret = self.digit.FlipLines()
+ if ret > 0:
+ return ret
+ def MergeLine(self):
+ """!Merge selected lines/boundaries
+ ret = self.digit.MergeLines()
+ if ret > 0:
+ return ret
+ def BreakLine(self):
+ """!Break selected lines/boundaries
+ ret = self.digit.BreakLines()
+ if ret > 0:
+ return ret
+ def SnapLine(self):
+ """!Snap selected lines/boundaries
+ @return on success
+ ret = self.digit.SnapLines(thresh)
+ if ret == 0:
+ return ret
+ def ConnectLine(self):
+ """!Connect selected lines/boundaries
+ @return 1 lines connected
+ @return 0 lines not connected
+ ret = self.digit.ConnectLines(thresh)
+ if ret > 0:
+ return ret
+ def CopyLine(self, ids=[]):
+ """!Copy features from (background) vector map
+ @param ids list of line ids to be copied
+ @return number of copied features
+ bgmap = str(UserSettings.Get(group='vdigit', key='bgmap',
+ if len(bgmap) > 0:
+ ret = self.digit.CopyLines(ids, bgmap)
+ else:
+ ret = self.digit.CopyLines(ids, None)
+ if ret > 0:
+ return ret
+ def CopyCats(self, fromId, toId, copyAttrb=False):
+ """!Copy given categories to objects with id listed in ids
+ @param cats ids of 'from' feature
+ @param ids ids of 'to' feature(s)
+ @return number of modified features
+ if len(fromId) == 0 or len(toId) == 0:
+ return 0
+ ret = self.digit.CopyCats(fromId, toId, copyAttrb)
+ if ret > 0:
+ return ret
+ def SelectLinesByQuery(self, pos1, pos2):
+ """!Select features by query
+ @param pos1, pos2 bounding box definition
+ thresh = self.SelectLinesByQueryThresh()
+ w, n = pos1
+ e, s = pos2
+ query = wxvdigit.QUERY_UNKNOWN
+ if UserSettings.Get(group='vdigit', key='query', subkey='selection') == 0:
+ query = wxvdigit.QUERY_LENGTH
+ else:
+ query = wxvdigit.QUERY_DANGLE
+ type = wxvdigit.GV_POINTS | wxvdigit.GV_LINES # TODO: 3D
+ ids = self.digit.SelectLinesByQuery(w, n, 0.0, e, s, 1000.0,
+ UserSettings.Get(group='vdigit', key='query', subkey='box'),
+ query, type, thresh)
+ Debug.msg(4, "VDigit.SelectLinesByQuery(): %s" % \
+ ",".join(["%d" % v for v in ids]))
+ return ids
+ def GetLineCats(self, line=-1):
+ """!Get layer/category pairs from given (selected) line
+ @param line feature id (-1 for first selected line)
+ return dict(self.digit.GetLineCats(line))
+ def GetLineLength(self, line):
+ """!Get line length
+ @return line length
+ return self.digit.GetLineLength(line)
+ def GetAreaSize(self, centroid):
+ """!Get area size
+ @param centroid centroid id
+ @return area size
+ return self.digit.GetAreaSize(centroid)
+ def GetAreaPerimeter(self, centroid):
+ """!Get area perimeter
+ @return area size
+ return self.digit.GetAreaPerimeter(centroid)
+ def SetLineCats(self, line, layer, cats, add=True):
+ """!Set categories for given line and layer
+ @param layer layer number (-1 for first selected line)
+ @param cats list of categories
+ @param add if True to add, otherwise do delete categories
+ @return new feature id (feature need to be rewritten)
+ ret = self.digit.SetLineCats(line, layer, cats, add)
+ if ret > 0:
+ return ret
+ def GetLayers(self):
+ """!Get list of layers"""
+ return self.digit.GetLayers()
+ def TypeConvForSelectedLines(self):
+ """!Feature type conversion for selected objects.
+ Supported conversions:
+ - point <-> centroid
+ - line <-> boundary
+ ret = self.digit.TypeConvLines()
+ if ret > 0:
+ return ret
+ def Undo(self, level=-1):
+ """!Undo action
+ @param level levels to undo (0 to revert all)
+ @return id of current changeset
+ try:
+ ret = self.digit.Undo(level)
+ ret = -2
+ if ret == -2:
+ raise gcmd.GException(_("Undo failed, data corrupted."))
+ self.mapWindow.UpdateMap(render=False)
+ if ret < 0: # disable undo tool
+ self.toolbar.EnableUndo(False)
+ def ZBulkLines(self, pos1, pos2, start, step):
+ """!Z-bulk labeling
+ @param pos1 reference line (start point)
+ @param pos1 reference line (end point)
+ @param start starting value
+ @param step step value
+ ret = self.digit.ZBulkLabeling(pos1[0], pos1[1], pos2[0], pos2[1],
+ start, step)
+ if ret > 0:
+ return ret
+ def __getSnapThreshold(self):
+ """!Get snap mode and threshold value
+ @return (snap, thresh)
+ thresh = self.driver.GetThreshold()
+ if thresh > 0.0:
+ if UserSettings.Get(group='vdigit', key='snapToVertex', subkey='enabled') is True:
+ snap = wxvdigit.SNAPVERTEX
+ else:
+ else:
+ snap = wxvdigit.NO_SNAP
+ return (snap, thresh)
+ def GetDisplay(self):
+ """!Get display driver instance"""
+ return self._display
+ def OpenMap(self, name):
+ """!Open vector map for editing
+ @param map name of vector map to be set up
+ Debug.msg (3, "AbstractDigit.SetMapName map=%s" % name)
+ self.map = name
+ name, mapset = name.split('@')
+ try:
+ ret = self._display.OpenMap(str(name), str(mapset), True)
+ ret = -1
+ # except StandardError, e:
+ # raise gcmd.GException(_("Unable to initialize display driver of vector "
+ # "digitizer. See 'Command output' for details.\n\n"
+ # "Details: ") + repr(e))
+ # if map and ret == -1:
+ # raise gcmd.GException(_('Unable to open vector map <%s> for editing.\n\n'
+ # 'Data are probably corrupted, '
+ # 'try to run v.build to rebuild '
+ # 'the topology (Vector->Develop vector map->'
+ # 'Create/rebuild topology).') % map)
+ # if not map and ret != 0:
+ self.InitCats()
+ def CloseMap(self):
+ """!Close currently open vector map
+ if not self.map:
+ return
+ self._display.CloseMap()
+ def InitCats(self):
+ """!Initialize categories information
+ @return 0 on success
+ self.cats.clear()
+ mapInfo = self._display.mapInfo
+ if not mapInfo:
+ return -1
+ ndblinks = Vect_get_num_dblinks(byref(mapInfo))
+ for i in range(ndblinks):
+ fi = Vect_get_dblink(byref(mapInfo), i).contents
+ if fi:
+ self.cats[fi.number] = None
+ # find max category
+ nfields = Vect_cidx_get_num_fields(byref(mapInfo))
+ Debug.msg(2, "wxDigit.InitCats(): nfields=%d", nfields)
+ for i in range(nfields):
+ field = Vect_cidx_get_field_number(byref(mapInfo), i)
+ ncats = Vect_cidx_get_num_cats_by_index(byref(mapInfo), i)
+ if field <= 0:
+ continue
+ for j in range(ncats):
+ cat = c_int()
+ type = c_int()
+ id = c_int()
+ Vect_cidx_get_cat_by_index(byref(mapInfo), i, j,
+ byref(cat), byref(type), byref(id))
+ if self.cats.has_key(field):
+ if cat > self.cats[field]:
+ self.cats[field] = cat.value
+ else:
+ Debug.msg(3, "wxDigit.InitCats(): layer=%d, cat=%d", field, self.cats[field])
+ # set default values
+ for field, cat in self.cats.iteritems():
+ if cat == None:
+ self.cats[field] = 0 # first category 1
+ def AddLine(self):
+ pass
+ def RewriteLine(self):
+ pass
+ def SplitLine(self):
+ pass
+ def DeleteLines(self):
+ pass
+ def MoveLines(self):
+ pass
+ def FlipLines(self):
+ pass
+ def MergeLines(self):
+ pass
+ def BreakLines(self):
+ pass
+ def SnapLines(self):
+ pass
+ def ConnectLines(self):
+ pass
+ def TypeConvLines(self):
+ pass
+ def ZBulkLabeling(self):
+ pass
+ def CopyLines(self):
+ pass
+ def MoveVertex(self):
+ pass
+ def ModifyLineVertex(self):
+ pass
+ def SelectLinesByQuery(self):
+ pass
+ def GetLineLength(self):
+ pass
+ def GetAreaSize(self):
+ pass
+ def GetAreaPerimeter(self):
+ pass
+ def CopyCats(self):
+ pass
+ def GetCategory(self, layer):
+ """!Get max category number for layer
+ @return category number (0 if no category found)
+ if cats.find(layer) != cats.end():
+ Debug.msg(3, "vdigit.GetCategory(): layer=%d, cat=%d", layer, cats[layer])
+ return cats[layer]
+ return 0
+ def GetLineCats(self):
+ pass
+ def SetLineCats(self):
+ pass
+ pass
+ def Undo(self):
+ pass
+ def GetUndoLevel(self):
+ pass
+ def UpdateSettings(self, breakLines, addCentroid, catBoundary):
+ """!Update digit settings
+ @param breakLines break lines on intersection
+ @param addCentroid add centroid to left/right area
+ @param catBoundary attach category to boundary
+ self._settings['breakLines'] = breakLines
+ self._settings['addCentroid'] = addCentroid
+ self._settings['catBoundary'] = None # !catBoundary # do not attach
+ def SetCategory(self):
+ """!Return category number to use (according Settings)"""
+ if not UserSettings.Get(group = 'vdigit', key = 'categoryMode', subkey = 'selection'):
+ self.SetCategoryNextToUse()
+ return UserSettings.Get(group = 'vdigit', key = 'category', subkey = 'value')
+ def SetCategoryNextToUse(self):
+ """!Find maximum category number in the map layer
+ and update Digit.settings['category']
+ @return 'True' on success, 'False' on failure
+ # vector map layer without categories, reset to '1'
+ UserSettings.Set(group = 'vdigit', key = 'category', subkey = 'value', value = 1)
+ if self.map:
+ cat = self.GetCategory(UserSettings.Get(group = 'vdigit', key = 'layer', subkey = 'value'))
+ cat += 1
+ value = cat)
Property changes on: grass/trunk/gui/wxpython/gui_modules/wxvdigit.py
___________________________________________________________________
Added: svn:mime-type
+ text/x-python
Added: svn:eol-style
+ native
Added: grass/trunk/gui/wxpython/gui_modules/wxvdriver.py
--- grass/trunk/gui/wxpython/gui_modules/wxvdriver.py (rev 0)
+++ grass/trunk/gui/wxpython/gui_modules/wxvdriver.py 2011-01-01 19:26:54 UTC (rev 44823)
@@ -0,0 +1,567 @@
+ at package wxvdriver.py
+ at brief wxGUI vector digitizer (display driver)
+List of classes:
+ - DisplayDriver
+import math
+import wx
+from debug import Debug as Debug
+from grass.lib.vedit import *
+class DisplayDriver:
+ def __init__(self, device, deviceTmp, mapObj, log = None):
+ """Display driver used by vector digitizer
+ @param device wx.PseudoDC device where to draw vector objects
+ @param deviceTmp wx.PseudoDC device where to draw temporary vector objects
+ G_gisinit("") # initialize GRASS libs
+ self.mapInfo = None # open vector map (Map_Info structure)
+ self.dc = device # PseudoDC devices
+ self.dcTmp = deviceTmp
+ self.mapObj = mapObj
+ self.region = mapObj.GetCurrentRegion()
+ self.log = log # log device
+ # objects used by GRASS vector library
+ self.points = line_pnts()
+ self.pointsScreen = list()
+ self.cats = line_cats()
+ # selected objects
+ self.selected = {
+ 'field' : -1, # field number
+ 'cats' : list(), # list of cats
+ 'ids' : list(), # list of ids
+ 'idsDupl' : list(), # list of duplicated features
+ # digitizer settings
+ self.settings = {
+ 'highlight' : None,
+ 'highlightDupl' : { 'enabled' : False,
+ 'color' : None },
+ 'point' : { 'enabled' : False,
+ 'color' : None },
+ 'line' : { 'enabled' : False,
+ 'color' : None },
+ 'boundaryNo' : { 'enabled' : False,
+ 'color' : None },
+ 'boundaryOne' : { 'enabled' : False,
+ 'color' : None },
+ 'boundaryTwo' : { 'enabled' : False,
+ 'color' : None },
+ 'centroidIn' : { 'enabled' : False,
+ 'color' : None },
+ 'centroidOut' : { 'enabled' : False,
+ 'color' : None },
+ 'centroidDup' : { 'enabled' : False,
+ 'color' : None },
+ 'nodeOne' : { 'enabled' : False,
+ 'color' : None },
+ 'nodeTwo' : { 'enabled' : False,
+ 'color' : None },
+ 'vertex' : { 'enabled' : False,
+ 'color' : None },
+ 'area' : { 'enabled' : False,
+ 'color' : None },
+ 'direction' : { 'enabled' : False,
+ 'color' : None },
+ 'lineWidth' : -1, # screen units
+ # topology
+ self.topology = {
+ 'highlight' : 0,
+ 'point' : 0,
+ 'line' : 0,
+ 'boundaryNo' : 0,
+ 'boundaryOne' : 0,
+ 'boundaryTwo' : 0,
+ 'centroidIn' : 0,
+ 'centroidOut' : 0,
+ 'centroidDup' : 0,
+ 'nodeOne' : 0,
+ 'nodeTwo' : 0,
+ 'vertex' : 0,
+ self.drawSelected = None
+ self.drawSegments = False
+ self.UpdateSettings()
+ # def __del__(self):
+ # """!Close currently open vector map"""
+ # if self.mapInfo:
+ # self.CloseMap()
+ def _cell2Pixel(self, east, north, elev):
+ """!Conversion from geographic coordinates (east, north)
+ to screen (x, y)
+ @todo 3D stuff...
+ @param east, north, elev geographical coordinates
+ @return x, y screen coordinates (integer)
+ map_res = max(self.region['ewres'], self.region['nsres'])
+ w = self.region['center_easting'] - (self.mapObj.width / 2) * map_res
+ n = self.region['center_northing'] + (self.mapObj.height / 2) * map_res
+ return int((east - w) / map_res), int((n - north) / map_res)
+ def _drawCross(self, pdc, point, size = 5):
+ """!Draw cross symbol of given size to device content
+ Used for points, nodes, vertices
+ @param[in,out] PseudoDC where to draw
+ @param point coordinates of center
+ @param size size of the cross symbol
+ if not pdc or not point:
+ return -1;
+ pdc.DrawLine(point.x - size, point.y, point.x + size, point.y)
+ pdc.DrawLine(point.x, point.y - size, point.x, point.y + size)
+ return 0
+ def _drawObject(self, robj):
+ """!Draw given object to the device
+ The object is defined as robject() from vedit.h.
+ @param robj object to be rendered
+ @return 1 on success
+ @return -1 on failure (vector feature marked as dead, etc.)
+ if not self.dc or not self.dcTmp:
+ return -1
+ dcId = 0
+ pdc = self.dc
+ # draw object to the device
+ pdc.SetId(dcId) # 0 | 1 (selected)
+ Debug.msg(3, "_drawObject(): type=%d npoints=%d", robj.type, robj.npoints)
+ points = list()
+ self._setPen(robj.type, pdc)
+ for i in range(robj.npoints):
+ p = robj.point[i]
+ if robj.type & (TYPE_POINT | TYPE_CENTROIDIN | TYPE_CENTROIDOUT | TYPE_CENTROIDDUP |
+ TYPE_NODEONE | TYPE_NODETWO | TYPE_VERTEX): # -> point
+ self._drawCross(pdc, p)
+ else: # -> line
+ # if dcId > 0 and self.drawSegments:
+ # dcId = 2 # first segment
+ # i = 0
+ # while (i < len(self.pointsScreen) - 2):
+ # point_beg = wx.Point(self.pointsScreen[i])
+ # point_end = wx.Point(self.pointsScreen[i + 1])
+ # pdc.SetId(dcId) # set unique id & set bbox for each segment
+ # pdc.SetPen(pen)
+ # rect = wx.Rect(point_beg, point_end)
+ # pdc.SetIdBounds(dcId, rect)
+ # pdc.DrawLine(point_beg.x, point_beg.y,
+ # point_end.x, point_end.y)
+ # i += 2
+ # dcId += 2
+ # else:
+ points.append(wx.Point(p.x, p.y))
+ if points:
+ if robj.type == TYPE_AREA:
+ pdc.DrawPolygon(points)
+ else:
+ pdc.DrawLines(points)
+ def _setPen(self, rtype, pdc):
+ """!Set pen/brush based on rendered object)
+ Updates also self.topology dict
+ if rtype == TYPE_POINT:
+ key = 'point'
+ elif rtype == TYPE_LINE:
+ key = 'line'
+ elif rtype == TYPE_BOUNDARYNO:
+ key = 'boundaryNo'
+ elif rtype == TYPE_BOUNDARYTWO:
+ key = 'boundaryTwo'
+ elif rtype == TYPE_BOUNDARYONE:
+ key = 'boundaryOne'
+ elif rtype == TYPE_CENTROIDIN:
+ key = 'centroidIn'
+ elif rtype == TYPE_CENTROIDOUT:
+ key = 'centroidOut'
+ elif rtype == TYPE_CENTROIDDUP:
+ key = 'centroidDup'
+ elif rtype == TYPE_NODEONE:
+ key = 'nodeOne'
+ elif rtype == TYPE_NODETWO:
+ key = 'nodeTwo'
+ elif rtype == TYPE_VERTEX:
+ key = 'vertex'
+ elif rtype == TYPE_AREA:
+ key = 'area'
+ elif rtype == TYPE_ISLE:
+ key = 'isle'
+ elif rtype == TYPE_DIRECTION:
+ key = 'direction'
+ if key not in ('direction', 'area', 'isle'):
+ self.topology[key] += 1
+ if key in ('area', 'isle'):
+ pen = wx.TRANSPARENT_PEN
+ if key == 'area':
+ pdc.SetBrush(wx.Brush(self.settings[key]['color'], wx.SOLID))
+ else:
+ pdc.SetBrush(wx.TRANSPARENT_BRUSH)
+ else:
+ pdc.SetPen(wx.Pen(self.settings[key]['color'], self.settings['lineWidth'], wx.SOLID))
+ def _getDrawFlag(self):
+ """!Get draw flag from the settings
+ See vedit.h for list of draw flags.
+ @return draw flag (int)
+ ret = 0
+ if self.settings['point']['enabled']:
+ ret |= TYPE_POINT
+ if self.settings['line']['enabled']:
+ ret |= TYPE_LINE
+ if self.settings['boundaryNo']['enabled']:
+ ret |= TYPE_BOUNDARYNO
+ if self.settings['boundaryTwo']['enabled']:
+ ret |= TYPE_BOUNDARYTWO
+ if self.settings['boundaryOne']['enabled']:
+ ret |= TYPE_BOUNDARYONE
+ if self.settings['centroidIn']['enabled']:
+ ret |= TYPE_CENTROIDIN
+ if self.settings['centroidOut']['enabled']:
+ ret |= TYPE_CENTROIDOUT
+ if self.settings['centroidDup']['enabled']:
+ ret |= TYPE_CENTROIDDUP
+ if self.settings['nodeOne']['enabled']:
+ ret |= TYPE_NODEONE
+ if self.settings['nodeTwo']['enabled']:
+ ret |= TYPE_NODETWO
+ if self.settings['vertex']['enabled']:
+ ret |= TYPE_VERTEX
+ if self.settings['area']['enabled']:
+ ret |= TYPE_AREA
+ if self.settings['direction']['enabled']:
+ ret |= TYPE_DIRECTION
+ return ret
+ def _printIds(self):
+ pass
+ def _isSelected(self, featId, foo = False):
+ return False
+ def _isDuplicated(self, featId):
+ return False
+ def _resetTopology(self):
+ pass
+ def _getRegionBox(self):
+ """!Get bound_box() from current region
+ @return bound_box
+ box = bound_box()
+ box.N = self.region['n']
+ box.S = self.region['s']
+ box.E = self.region['e']
+ box.W = self.region['w']
+ box.T = PORT_DOUBLE_MAX
+ box.B = -PORT_DOUBLE_MAX
+ return box
+ def DrawMap(self, force = False):
+ """!Draw content of the vector map to the device
+ @param force force drawing
+ @return number of drawn features
+ Debug.msg(1, "DisplayDriver.DrawMap(): force=%d", force)
+ if not self.mapInfo or not self.dc or not self.dcTmp:
+ return -1
+ rlist = Vedit_render_map(byref(self.mapInfo), byref(self._getRegionBox()), self._getDrawFlag(),
+ self.region['center_easting'], self.region['center_northing'],
+ self.mapObj.width, self.mapObj.height,
+ max(self.region['nsres'], self.region['ewres'])).contents
+ # ResetTopology()
+ self.dc.BeginDrawing()
+ self.dcTmp.BeginDrawing()
+ # draw objects
+ for i in range(rlist.nitems):
+ robj = rlist.item[i].contents
+ self._drawObject(robj)
+ self.dc.EndDrawing()
+ self.dcTmp.EndDrawing()
+ # reset list of selected features by cat
+ # list of ids - see IsSelected()
+ ### selected.field = -1;
+ ### Vect_reset_list(selected.cats);
+ def SelectLinesByBox(self):
+ pass
+ def SelectLineByPoint(self):
+ pass
+ def GetSelected(self, grassId = False):
+ """!Get ids of selected objects
+ @param grassId if true return GRASS line ids, false to return PseudoDC ids
+ @return list of ids of selected vector objects
+ if grassId:
+ # return ListToVector(selected.ids);
+ pass
+ dc_ids = list()
+ if not self.drawSegments:
+ dc_ids.append(1)
+ else:
+ # only first selected feature
+ # Vect_read_line(byref(self.mapInfo), byref(self.points), None,
+ # self.selected.ids->value[0]);
+ npoints = self.points.n_points
+ # node - segment - vertex - segment - node
+ for i in range(1, 2 * self.points.npoints):
+ dc_ids.append(i)
+ return dc_ids
+ def GetSelectedCoord(self):
+ pass
+ def GetDuplicates(self):
+ pass
+ def GetRegionSelected(self):
+ pass
+ def SetSelected(self, ids, layer = -1):
+ """!Set selected vector objects
+ @param ids list of feature ids to be set
+ @param layer field number (-1 for ids instead of cats)
+ if ids:
+ self.drawSelected = True
+ else:
+ self.drawSelected = False
+ return
+ if layer > 0:
+ selected.field = layer
+ # VectorToList(selected.cats, id);
+ else:
+ field = -1
+ # VectorToList(selected.ids, id);
+ return 1
+ def UnSelect(self):
+ pass
+ def GetSelectedVertex(self):
+ pass
+ def DrawSelected(self):
+ pass
+ """!Close vector map
+ @return non-zero on error
+ ret = 0
+ if self.mapInfo:
+ if self.mapInfo.mode == GV_MODE_RW:
+ # rebuild topology
+ Vect_build_partial(byref(self.mapInfo), GV_BUILD_NONE)
+ Vect_build(byref(self.mapInfo))
+ # close map and store topo/cidx
+ ret = Vect_close(byref(self.mapInfo))
+ del self.mapInfo
+ return ret
+ def OpenMap(self, name, mapset, update = True):
+ """!Open vector map by the driver
+ @param name name of vector map to be open
+ @param mapset name of mapset where the vector map lives
+ @return topo level on success
+ Debug.msg("DisplayDriver.OpenMap(): name=%s mapset=%s updated=%d",
+ name, mapset, update)
+ if not self.mapInfo:
+ self.mapInfo = Map_info()
+ # define open level (level 2: topology)
+ Vect_set_open_level(2)
+ # avoid GUI crash when G_fatal_error() is called (opening the vector map)
+ Vect_set_fatal_error(GV_FATAL_PRINT)
+ # open existing map
+ if update:
+ ret = Vect_open_update(byref(self.mapInfo), name, mapset)
+ else:
+ ret = Vect_open_old(byref(self.mapInfo), name, mapset)
+ if ret == -1: # error
+ del self.mapInfo
+ return ret
+ def ReloadMap(self):
+ pass
+ def SetDevice(self):
+ pass
+ def GetMapBoundingBox(self):
+ """!Get bounding box of (opened) vector map layer
+ @return (w,s,b,e,n,t)
+ return None
+ bbox = bound_box()
+ Vect_get_map_box(byref(self.mapInfo), byref(bbox))
+ return bbox.W, bbox.S, bbox.B, \
+ bbox.E, bbox.N, bbox.T
+ def Is3D(self):
+ pass
+ def SetRegion(self):
+ pass
+ def UpdateSettings(self, alpha = 255):
+ """!Update display driver settings
+ @todo map units
+ @alpha color value for aplha channel
+ color = dict()
+ for key in self.settings.keys():
+ if key == 'lineWidth':
+ self.settings[key] = int(UserSettings.Get(group = 'vdigit', key = 'lineWidth',
+ subkey = 'value'))
+ continue
+ color = wx.Color(UserSettings.Get(group = 'vdigit', key = 'symbol',
+ subkey = [key, 'color'])[0],
+ UserSettings.Get(group = 'vdigit', key = 'symbol',
+ subkey = [key, 'color'])[1],
+ subkey = [key, 'color'])[2])
+ if key == 'highlight':
+ self.settings[key] = color
+ continue
+ if key == 'highlightDupl':
+ self.settings[key]['enabled'] = bool(UserSettings.Get(group = 'vdigit', key = 'checkForDupl',
+ subkey = 'enabled'))
+ else:
+ self.settings[key]['enabled'] = bool(UserSettings.Get(group = 'vdigit', key = 'symbol',
+ subkey = [key, 'enabled']))
+ self.settings[key]['color'] = color
+ def UpdateRegion(self):
+ """!Update geographical region used by display driver.
+ self.region = self.mapObj.GetCurrentRegion()
+ def GetThreshold(self, type = 'snapping', value = None, units = None):
+ """!Return threshold in map units
+ @param value threshold to be set up
+ @param units units (map, screen)
+ if value is None:
+ value = UserSettings.Get(group = 'vdigit', key = type, subkey =' value')
+ if units is None:
+ units = UserSettings.Get(group = 'vdigit', key = type, subkey = 'units')
+ if value < 0:
+ value = (self.region['nsres'] + self.region['ewres']) / 2.0
+ if units == "screen pixels":
+ # pixel -> cell
+ res = max(self.region['nsres'], self.region['ewres'])
+ threshold = value * res
+ else:
+ threshold = value
+ Debug.msg(4, "DisplayDriver.GetThreshold(): type=%s, thresh=%f" % (type, threshold))
+ return threshold
Property changes on: grass/trunk/gui/wxpython/gui_modules/wxvdriver.py
+ text/x-python
+ native
Modified: grass/trunk/include/vedit.h
--- grass/trunk/include/vedit.h 2010-12-31 13:44:07 UTC (rev 44822)
+++ grass/trunk/include/vedit.h 2011-01-01 19:26:54 UTC (rev 44823)
@@ -12,6 +12,54 @@
#define QUERY_LENGTH 0 /* select by line length */
#define QUERY_DANGLE 1 /* select dangles */
+/* used by Vedit_render_map() */
+#define TYPE_POINT 0x01
+#define TYPE_LINE 0x02
+#define TYPE_BOUNDARYNO 0x04
+#define TYPE_BOUNDARYTWO 0x08
+#define TYPE_BOUNDARYONE 0x10
+#define TYPE_CENTROIDIN 0x20
+#define TYPE_CENTROIDOUT 0x40
+#define TYPE_CENTROIDDUP 0x80
+#define TYPE_NODEONE 0x100
+#define TYPE_NODETWO 0x200
+#define TYPE_VERTEX 0x400
+#define TYPE_AREA 0x800
+#define TYPE_ISLE 0x1000
+#define TYPE_DIRECTION 0x2000
+#define DRAW_POINT 0x01
+#define DRAW_LINE 0x02
+#define DRAW_BOUNDARYNO 0x04
+#define DRAW_BOUNDARYTWO 0x08
+#define DRAW_BOUNDARYONE 0x10
+#define DRAW_CENTROIDIN 0x20
+#define DRAW_CENTROIDOUT 0x40
+#define DRAW_CENTROIDDUP 0x80
+#define DRAW_NODEONE 0x100
+#define DRAW_NODETWO 0x200
+#define DRAW_VERTEX 0x400
+#define DRAW_AREA 0x800
+#define DRAW_DIRECTION 0x1000
+struct rpoint {
+ /* screen coordinates */
+ int x, y;
+struct robject {
+ /* object to be rendered */
+ int type;
+ int npoints;
+ struct rpoint *point; /* list of points */
+struct robject_list {
+ /* list of objects to be rendered */
+ int nitems;
+ struct robject **item;
/* break.c */
int Vedit_split_lines(struct Map_info *, struct ilist *,
struct line_pnts *, double, struct ilist *);
@@ -45,6 +93,10 @@
int Vedit_move_lines(struct Map_info *, struct Map_info **, int,
struct ilist *, double, double, double, int, double);
+/* render.c */
+struct robject_list *Vedit_render_map(struct Map_info *, struct bound_box *, int,
+ double, double, int, int, double);
/* select.c */
int Vedit_select_by_query(struct Map_info *,
int, int, double, int, struct ilist *);
Property changes on: grass/trunk/lib/vector/vedit/chtype.c
+ text/x-csrc
Property changes on: grass/trunk/lib/vector/vedit/distance.c
+ text/x-csrc
Added: grass/trunk/lib/vector/vedit/render.c
--- grass/trunk/lib/vector/vedit/render.c (rev 0)
+++ grass/trunk/lib/vector/vedit/render.c 2011-01-01 19:26:54 UTC (rev 44823)
@@ -0,0 +1,491 @@
+ \file lib/vector/vedit/render.c
+ \brief Vedit library - render vector features (used by wxGUI digitizer)
+ (C) 2010 by the GRASS Development Team
+ This program is free software under the GNU General Public License
+ (>=v2). Read the file COPYING that comes with GRASS for details.
+ \author Martin Landa <landa.martin gmail.com>
+#include <math.h>
+#include <grass/vedit.h>
+struct _region
+ double center_easting;
+ double center_northing;
+ double map_west;
+ double map_north;
+ int map_width;
+ int map_height;
+ double map_res;
+} region;
+struct _state
+ int nitems_alloc;
+ int type;
+ struct line_pnts *Points;
+} state;
+static struct robject *draw_line(struct Map_info *, int, int);
+static struct robject *draw_line_vertices();
+static void draw_line_nodes(struct Map_info *, int, int,
+ struct robject_list *);
+static int draw_line_dir(struct robject_list *);
+static void list_append(struct robject_list *, struct robject *);
+static struct robject *robj_alloc(int, int);
+static void robj_points(struct robject *, const struct line_pnts *);
+static double dist_in_px(double);
+static void en_to_xy(double, double, int *, int *);
+static void draw_arrow(int, int, int, int, double, int,
+static void draw_area(struct Map_info *, int, struct robject_list *);
+ \brief Render vector features into list
+ \param Map pointer to Map_info structure
+ \param box bounding box of region to be rendered
+ \param draw_flag types of objects to be rendered (see vedit.h)
+ \param center_easing, center_northing, map_width, map_height, map_res values used for conversion en->xy
+ \return pointer to robject_list structure
+struct robject_list *Vedit_render_map(struct Map_info *Map,
+ struct bound_box *box, int draw_flag,
+ double center_easting,
+ double center_northing, int map_width,
+ int map_height, double map_res)
+ int i, nfeat, fid;
+ struct ilist *list;
+ struct robject_list *list_obj;
+ struct robject *robj;
+ /* define region */
+ region.center_easting = center_easting;
+ region.center_northing = center_northing;
+ region.map_width = map_width;
+ region.map_height = map_height;
+ region.map_res = map_res;
+ region.map_west = center_easting - (map_width / 2.) * map_res;
+ region.map_north = center_northing + (map_height / 2.) * map_res;
+ list = Vect_new_list();
+ list_obj = NULL;
+ state.nitems_alloc = 1000;
+ list_obj = (struct robject_list *)G_malloc(sizeof(struct robject_list));
+ list_obj->nitems = 0;
+ list_obj->item =
+ (struct robject **)G_malloc(state.nitems_alloc *
+ sizeof(struct robject *));
+ /* area */
+ if (draw_flag & DRAW_AREA) {
+ nfeat = Vect_select_areas_by_box(Map, box, list);
+ for (i = 0; i < nfeat; i++) {
+ fid = list->value[i];
+ draw_area(Map, fid, list_obj);
+ /* draw lines inside of current display region */
+ nfeat = Vect_select_lines_by_box(Map, box, GV_POINTS | GV_LINES, // fixme
+ list);
+ G_debug(1, "Vedit_render_map(): region: w=%f, e=%f, s=%f, n=%f nlines=%d",
+ box->W, box->E, box->S, box->N, nfeat);
+ /* features */
+ for (i = 0; i < list->n_values; i++) {
+ robj = draw_line(Map, fid, draw_flag);
+ if (!robj)
+ continue;
+ list_append(list_obj, robj);
+ if (state.type & GV_LINES) {
+ /* vertices */
+ if (draw_flag & DRAW_VERTEX) {
+ robj = draw_line_vertices();
+ if (robj)
+ /* nodes */
+ if (draw_flag & (DRAW_NODEONE | DRAW_NODETWO)) {
+ draw_line_nodes(Map, fid, draw_flag, list_obj);
+ /* direction */
+ if (draw_flag & DRAW_DIRECTION) {
+ draw_line_dir(list_obj);
+ list_obj->item =
+ (struct robject **)G_realloc(list_obj->item,
+ list_obj->nitems *
+ Vect_destroy_list(list);
+ return list_obj;
+ \brief Draw one feature
+struct robject *draw_line(struct Map_info *Map, int line, int draw_flag)
+ int draw;
+ struct robject *obj;
+ if (!state.Points)
+ state.Points = Vect_new_line_struct();
+ if (!Vect_line_alive(Map, line))
+ return NULL;
+ state.type = Vect_read_line(Map, state.Points, NULL, line);
+ obj = (struct robject *)G_malloc(sizeof(struct robject));
+ draw = FALSE;
+ if (state.type == GV_LINE) {
+ obj->type = TYPE_LINE;
+ draw = draw_flag & DRAW_LINE;
+ else if (state.type == GV_BOUNDARY) {
+ int left, right;
+ Vect_get_line_areas(Map, line, &left, &right);
+ if (left == 0 && right == 0) {
+ obj->type = TYPE_BOUNDARYNO;
+ draw = draw_flag & DRAW_BOUNDARYNO;
+ else if (left > 0 && right > 0) {
+ obj->type = TYPE_BOUNDARYTWO;
+ draw = draw_flag & DRAW_BOUNDARYTWO;
+ else {
+ obj->type = TYPE_BOUNDARYONE;
+ draw = draw_flag & DRAW_BOUNDARYONE;
+ else if (state.type & GV_POINTS) {
+ if (state.type == GV_POINT) {
+ obj->type = TYPE_POINT;
+ draw = draw_flag & DRAW_POINT;
+ else if (state.type == GV_CENTROID) {
+ int cret = Vect_get_centroid_area(Map, line);
+ if (cret > 0) { // -> area
+ obj->type = TYPE_CENTROIDIN;
+ draw = draw_flag & DRAW_CENTROIDIN;
+ else if (cret == 0) {
+ obj->type = TYPE_CENTROIDOUT;
+ draw = draw_flag & DRAW_CENTROIDOUT;
+ else {
+ obj->type = TYPE_CENTROIDDUP;
+ draw = draw_flag & DRAW_CENTROIDDUP;
+ G_debug(3, " draw_line(): type=%d rtype=%d npoints=%d draw=%d",
+ state.type, obj->type, state.Points->n_points, draw);
+ if (!draw)
+ return NULL;
+ obj->npoints = state.Points->n_points;
+ obj->point =
+ (struct rpoint *)G_malloc(obj->npoints * sizeof(struct rpoint));
+ robj_points(obj, state.Points);
+ return obj;
+ \brief Convert geographic coordinates to the screen
+void en_to_xy(double east, double north, int *x, int *y)
+ double n, w;
+ w = region.center_easting - (region.map_width / 2) * region.map_res;
+ n = region.center_northing + (region.map_height / 2) * region.map_res;
+ if (x)
+ *x = (east - w) / region.map_res;
+ if (y)
+ *y = (n - north) / region.map_res;
+ return;
+ \brief Draw line nodes
+void draw_line_nodes(struct Map_info *Map, int line, int draw_flag,
+ struct robject_list *list)
+ unsigned int i;
+ int type, nodes[2];
+ int x, y;
+ double east, north;
+ Vect_get_line_nodes(Map, line, &(nodes[0]), &(nodes[1]));
+ for (i = 0; i < sizeof(nodes) / sizeof(int); i++) {
+ type = 0;
+ if (Vect_get_node_n_lines(Map, nodes[i]) == 1) {
+ if (draw_flag & DRAW_NODEONE) {
+ type = TYPE_NODEONE;
+ else {
+ if (draw_flag & DRAW_NODETWO) {
+ type = TYPE_NODETWO;
+ if (type == 0)
+ continue;
+ Vect_get_node_coor(Map, nodes[i], &east, &north, NULL);
+ robj = robj_alloc(type, 1);
+ en_to_xy(east, north, &x, &y);
+ robj->point->x = x;
+ robj->point->y = y;
+ list_append(list, robj);
+ \brief Append object to the list
+void list_append(struct robject_list *list, struct robject *obj)
+ if (list->nitems >= state.nitems_alloc) {
+ state.nitems_alloc += 1000;
+ list->item =
+ (struct robject **)G_realloc(list->item,
+ state.nitems_alloc *
+ list->item[list->nitems++] = obj;
+ \brief Allocate robject
+struct robject *robj_alloc(int type, int npoints)
+ robj = (struct robject *)G_malloc(sizeof(struct robject));
+ robj->type = type;
+ robj->npoints = npoints;
+ robj->point = (struct rpoint *)G_malloc(npoints * sizeof(struct rpoint));
+ return robj;
+ \brief Draw line vertices
+struct robject *draw_line_vertices()
+ int i;
+ int x, y;
+ robj = robj_alloc(TYPE_VERTEX, state.Points->n_points - 2); /* ignore nodes */
+ for (i = 1; i < state.Points->n_points - 1; i++) {
+ en_to_xy(state.Points->x[i], state.Points->y[i], &x, &y);
+ robj->point[i - 1].x = x;
+ robj->point[i - 1].y = y;
+ return robj;
+ \brief Draw line dirs
+int draw_line_dir(struct robject_list *list)
+ int narrows;
+ int size; /* arrow length in pixels */
+ int limit; /* segment length limit for drawing symbol (in pixels) */
+ double dist, angle, pos;
+ double e, n;
+ int x0, y0, x1, y1;
+ narrows = 0;
+ size = 5;
+ limit = 5; // 5px for line segment
+ dist = Vect_line_length(state.Points);
+ if (dist_in_px(dist) >= limit) {
+ while (1) {
+ pos = (narrows + 1) * 8 * limit * region.map_res;
+ if (Vect_point_on_line(state.Points, pos,
+ &e, &n, NULL, NULL, NULL) < 1) {
+ break;
+ en_to_xy(e, n, &x0, &y0);
+ (state.Points, pos - 3 * size * region.map_res, &e, &n, NULL,
+ &angle, NULL) < 1) {
+ break;
+ en_to_xy(e, n, &x1, &y1);
+ draw_arrow(x0, y0, x1, y1, angle, size, list);
+ if (narrows > 1e2) // low resolution, break
+ break;
+ narrows++;
+ // draw at least one arrow in the middle of line
+ if (narrows < 1) {
+ dist /= 2.;
+ if (Vect_point_on_line(state.Points, dist,
+ &e, &n, NULL, NULL, NULL) > 0) {
+ (state.Points, dist - 3 * size * region.map_res, &e, &n,
+ NULL, &angle, NULL) > 0) {
+ return narrows;
+ \brief Calculate distance in pixels (on screen)
+double dist_in_px(double dist)
+ int x, y;
+ en_to_xy(region.map_west + dist, region.map_north, &x, &y);
+ return sqrt(x * x);
+ \brief Draw arrow
+void draw_arrow(int x0, int y0, int x1, int y1, double angle, int size,
+ double angle_symb;
+ robj = robj_alloc(TYPE_DIRECTION, 3);
+ angle_symb = angle - M_PI / 2.;
+ robj->point[0].x = (int)x1 + size * cos(angle_symb);
+ robj->point[0].y = (int)y1 - size * sin(angle_symb);
+ robj->point[1].x = x0;
+ robj->point[1].y = y0;
+ angle_symb = M_PI / 2. + angle;
+ robj->point[2].x = (int)x1 + size * cos(angle_symb);
+ robj->point[2].y = (int)y1 - size * sin(angle_symb);
+ \brief Draw area
+void draw_area(struct Map_info *Map, int area, struct robject_list *list)
+ int i, centroid, isle;
+ int num_isles;
+ struct line_pnts *ipoints;
+ if (!Vect_area_alive(Map, area))
+ return;
+ /* check for other centroids -- only area with one centroid is valid */
+ centroid = Vect_get_area_centroid(Map, area);
+ if (centroid <= 0)
+ return;
+ ipoints = Vect_new_line_struct();
+ /* get area's boundary */
+ Vect_get_area_points(Map, area, state.Points);
+ robj = robj_alloc(TYPE_AREA, state.Points->n_points);
+ robj_points(robj, state.Points);
+ /* check for isles */
+ num_isles = Vect_get_area_num_isles(Map, area);
+ for (i = 0; i < num_isles; i++) {
+ isle = Vect_get_area_isle(Map, area, i);
+ if (!Vect_isle_alive(Map, isle))
+ continue;
+ Vect_get_isle_points(Map, isle, ipoints);
+ robj = robj_alloc(TYPE_ISLE, ipoints->n_points);
+ robj_points(robj, ipoints);
+ Vect_destroy_line_struct(ipoints);
+ \brief convert EN -> XY
+void robj_points(struct robject *robj, const struct line_pnts *points)
+ int i;
+ int x, y;
+ for (i = 0; i < points->n_points; i++) {
+ en_to_xy(points->x[i], points->y[i], &x, &y);
+ robj->point[i].x = x;
+ robj->point[i].y = y;
Property changes on: grass/trunk/lib/vector/vedit/render.c
+ text/x-csrc
+ native
Property changes on: grass/trunk/lib/vector/vedit/select.c
+ text/x-csrc
