[GRASS-SVN] r44829 - grass/trunk/vector/v.to.db
Mon Jan 3 09:19:50 EST 2011
Author: neteler
Date: 2011-01-03 06:19:50 -0800 (Mon, 03 Jan 2011)
New Revision: 44829
   grass/trunk/vector/v.to.db/v.to.db.html
typo
Modified: grass/trunk/vector/v.to.db/v.to.db.html
--- grass/trunk/vector/v.to.db/v.to.db.html	2011-01-03 13:54:24 UTC (rev 44828)
+++ grass/trunk/vector/v.to.db/v.to.db.html	2011-01-03 14:19:50 UTC (rev 44829)
@@ -21,7 +21,7 @@
 When using <em>option=coor</em> on a vector area map,
 only coordinates of centroids with unique category will be reported.
 <p>
-Line azimuth is calculaded as angle from the North direction to the line endnode
+Line azimuth is calculated as angle from the North direction to the line endnode
 direction at the line statnode. By default it's reported in decimal degrees (0-360, CW) but
 it also may be repored in radians with <em>unit=radians</em>. Azimuth value
 <b>-1</b> is used to report closed line with it's startnode and endnode being in
