[GRASS-SVN] r44866 - grass/trunk/raster/r.thin
svn_grass at osgeo.org
Tue Jan 4 08:45:49 EST 2011
Author: mmetz
Date: 2011-01-04 05:45:49 -0800 (Tue, 04 Jan 2011)
New Revision: 44866
grass/trunk/raster/r.thin/io.c
grass/trunk/raster/r.thin/thin_lines.c
use NULL instead of zero, zero is a valid number
Modified: grass/trunk/raster/r.thin/io.c
--- grass/trunk/raster/r.thin/io.c 2011-01-04 13:30:40 UTC (rev 44865)
+++ grass/trunk/raster/r.thin/io.c 2011-01-04 13:45:49 UTC (rev 44866)
@@ -85,13 +85,16 @@
int open_file(char *name)
int cell_file, buf_len;
- int i, row, col;
- char cell[100];
+ int i, row;
CELL *buf;
/* open raster map */
- strcpy(cell, name);
- cell_file = Rast_open_old(cell, "");
+ cell_file = Rast_open_old(name, "");
+ if (Rast_get_map_type(cell_file) != CELL_TYPE) {
+ Rast_close(cell_file);
+ G_fatal_error(_("Input raster must be of type CELL."));
n_rows = Rast_window_rows();
n_cols = Rast_window_cols();
@@ -110,8 +113,7 @@
buf_len = n_cols * sizeof(CELL);
buf = (CELL *) G_malloc(buf_len);
- for (col = 0; col < n_cols; col++)
- buf[col] = 0;
+ Rast_set_c_null_value(buf, n_cols);
for (i = 0; i < PAD; i++) {
if (write(work_file, buf, buf_len) != buf_len) {
unlink(work_file_name);
@@ -121,10 +123,6 @@
for (row = 0; row < n_rows; row++) {
Rast_get_c_row(cell_file, buf + PAD, row);
- for (col = 0; col < n_cols; col++) {
- if (Rast_is_c_null_value(&buf[col]))
- buf[col] = 0;
G_fatal_error(_("%s: Error writing temporary file"),
@@ -132,8 +130,7 @@
- buf[col] = 0;
@@ -154,7 +151,7 @@
int close_file(char *name)
int cell_file, row, k;
- int row_count, col_count, col;
+ int row_count, col_count;
CELL *buf;
cell_file = Rast_open_c_new(name);
@@ -167,10 +164,6 @@
for (row = 0, k = PAD; row < row_count; row++, k++) {
buf = get_a_row(k);
- if (buf[col] == 0)
- Rast_set_null_value(&buf[col], 1, CELL_TYPE);
Rast_put_row(cell_file, buf + PAD, CELL_TYPE);
Modified: grass/trunk/raster/r.thin/thin_lines.c
--- grass/trunk/raster/r.thin/thin_lines.c 2011-01-04 13:30:40 UTC (rev 44865)
+++ grass/trunk/raster/r.thin/thin_lines.c 2011-01-04 13:45:49 UTC (rev 44866)
@@ -49,7 +49,8 @@
top = bottom; /* line above the one we're changing */
bottom = get_a_row(row); /* line we're working on now */
for (col = pad_size; col < n_cols - pad_size; col++) {
- if (bottom[col]) { /* not background pixel */
+ /* skip background cells */
+ if (!Rast_is_c_null_value(&(bottom[col]))) {
if (col < box_left) /* find bounding box which will */
box_left = col; /* cover part of raster map which */
if (col > box_right) /* has lines in it */
@@ -107,11 +108,9 @@
N_Templ[7] = /* 00000010 */ 2;
new_med = (CELL *) G_malloc(sizeof(CELL) * (n_cols));
- for (i = 0; i < n_cols; i++)
- new_med[i] = 0;
+ Rast_set_c_null_value(new_med, n_cols);
row_buf = (CELL *) G_malloc(sizeof(CELL) * (n_cols));
- row_buf[i] = 0;
+ Rast_set_c_null_value(row_buf, n_cols);
deleted = 1;
i = 1;
@@ -137,7 +136,7 @@
new_med[col] = med[col];
bottom = get_a_row(row + 1);
for (col = box_left; col <= box_right; col++) {
- if (med[col]) { /* if pixel is not blank */
+ if (!Rast_is_c_null_value(&(med[col]))) { /* if cell is not NULL */
W = encode_neighbours(top, med, bottom, col, 1);
/* current window */
N_W = encode_neighbours(top, med, bottom, col, -1);
@@ -150,7 +149,7 @@
((N_Templ[ind3] & N_W) == N_Templ[ind3]))) {
/* fprintf(stdout, "col: %d, row: %d\n", col, row); */
deleted++;
- new_med[col] = 0;
+ Rast_set_c_null_value(&(new_med[col]), 1);
} /* end blank pixel */
@@ -188,25 +187,23 @@
T = 0;
if (neg > 0)
- T = (((middle[col + 1] != 0) << 5) | ((top[col + 1] !=
- 0) << 6) | ((top[col] !=
- 0) << 7) |
- ((top[col - 1] != 0)) | ((middle[col - 1] !=
- 0) << 1) | ((bottom[col - 1] !=
- 0) << 2) | ((bottom[col]
- 0) << 3) |
- ((bottom[col + 1] != 0) << 4));
+ T = (((!Rast_is_c_null_value(&(middle[col + 1]))) << 5) |
+ ((!Rast_is_c_null_value(&(top[col + 1]))) << 6) |
+ ((!Rast_is_c_null_value(&(top[col]))) << 7) |
+ ((!Rast_is_c_null_value(&(top[col - 1])))) |
+ ((!Rast_is_c_null_value(&(middle[col - 1]))) << 1) |
+ ((!Rast_is_c_null_value(&(bottom[col - 1]))) << 2) |
+ ((!Rast_is_c_null_value(&(bottom[col]))) << 3) |
+ ((!Rast_is_c_null_value(&(bottom[col + 1]))) << 4));
else
- T = (((middle[col + 1] == 0) << 5) | ((top[col + 1] ==
- 0) << 6) | ((top[col] ==
- 0) << 7) |
- ((top[col - 1] == 0)) | ((middle[col - 1] ==
- 0) << 1) | ((bottom[col - 1] ==
- 0) << 3) |
- ((bottom[col + 1] == 0) << 4));
+ T = (((Rast_is_c_null_value(&(middle[col + 1]))) << 5) |
+ ((Rast_is_c_null_value(&(top[col + 1]))) << 6) |
+ ((Rast_is_c_null_value(&(top[col]))) << 7) |
+ ((Rast_is_c_null_value(&(top[col - 1])))) |
+ ((Rast_is_c_null_value(&(middle[col - 1]))) << 1) |
+ ((Rast_is_c_null_value(&(bottom[col - 1]))) << 2) |
+ ((Rast_is_c_null_value(&(bottom[col]))) << 3) |
+ ((Rast_is_c_null_value(&(bottom[col + 1]))) << 4));
return (T);
