[GRASS-SVN] r44868 - grass/trunk/general/g.gisenv
svn_grass at osgeo.org
Tue Jan 4 15:38:02 EST 2011
Author: martinl
Date: 2011-01-04 12:38:02 -0800 (Tue, 04 Jan 2011)
New Revision: 44868
grass/trunk/general/g.gisenv/g.gisenv.html
grass/trunk/general/g.gisenv/main.c
g.gisenv: clean up manual page + more gui sections
Modified: grass/trunk/general/g.gisenv/g.gisenv.html
--- grass/trunk/general/g.gisenv/g.gisenv.html 2011-01-04 20:06:37 UTC (rev 44867)
+++ grass/trunk/general/g.gisenv/g.gisenv.html 2011-01-04 20:38:02 UTC (rev 44868)
@@ -1,208 +1,173 @@
<h2>DESCRIPTION</h2>
-When a user runs GRASS, certain variables are set
-specifying the GRASS data base, location, mapset,
-peripheral device drivers, etc., being used in the current
-GRASS session. These variable name settings are recognized
-as long as the user is running a GRASS session.
+When a user runs GRASS, certain variables are set specifying the GRASS
+data base, location, mapset, peripheral device drivers, etc., being
+used in the current GRASS session. These variable name settings are
+recognized as long as the user is running a GRASS session.
<h2>OPTIONS</h2>
-No prompts are given to the user when running
-<em>g.gisenv</em>. If run without arguments,
-<em>g.gisenv</em> lists all of the user's current GRASS
-variable settings. Results are sent to standard output,
+No prompts are given to the user when running <em>g.gisenv</em>. If
+run without arguments, <em>g.gisenv</em> lists all of the user's
+current GRASS variable settings. Results are sent to standard output,
and may look like this:
<div class="code"><pre>
-GISDBASE=/usr/grass5/data
+GISDBASE=/opt/grassdata/
LOCATION_NAME=spearfish
MAPSET=PERMANENT
</pre></div>
-In this example, the full path name of the user's current
-location (i.e., <kbd>$LOCATION_NAME</kbd>) is
-<kbd>/usr/grass5/data/spearfish</kbd>, and the full path
-name of the user's current mapset (i.e.,
-<kbd>$MAPSET</kbd>) is
-<kbd>/usr/grass5/data/spearfish/PERMANENT</kbd>.
+In this example, the full path name of the user's current location
+(i.e., <tt>$LOCATION_NAME</tt>) is
+<tt>/opt/grassdata/spearfish</tt>, and the full path name of the
+user's current mapset (i.e., <tt>$MAPSET</tt>)
+is <tt>/opt/grassdata/spearfish/PERMANENT</tt>.
<p>
+If the user specifies a <em>variable_name</em> on the command line
+(e.g., <tt>g.gisenv MAPSET</tt>), only the value for that particular
+GRASS variable is output to standard output. Possible variable names
+depend on the user's system, see <em><a href="variables.html">variables
+list</a></em> for details.
-If the user specifies a <em>variable_name</em> on the
-command line (e.g., <b>g.gisenv MAPSET</b>), only the value
-for that particular GRASS variable is output to standard
-output. Possible variable names depend on the user's
-system, see <a href=variables.html>variables list</a> for details.
<p>
+While other variables may be associated with each GRASS session (e.g.,
+GRASS_GUI, GIS_LOCK, and other variables), those stated below
+are essential.
-While other variables may be associated with each GRASS session
-(e.g., DIGITIZER, PAINTER, DISPLAY, and other variables), those stated
-below are essential.
<dl>
<dt><em>GISDBASE</em>
+<dd>The <tt>$GISDBASE</tt> is a directory in which all users' GRASS
+data are stored. Within the <tt>$GISDBASE</tt>, data are segregated
+into subdirectories (called "locations") based on the map
+coordinate system used and the geographic extent of the data. Each
+"location" directory itself contains subdirectories called
+"mapsets"; each "mapset" stores "data base
+elements" - the directories (e.g.,
+the <tt>cell</tt>, <tt>cellhd</tt>, <tt>vector</tt>, etc., directories)
+in which GRASS data files are actually stored.
-<dd>The <kbd>$GISDBASE</kbd> is a directory in which all
-users' GRASS data are stored. Within the
-<kbd>$GISDBASE</kbd>, data are segregated into
-subdirectories (called "locations") based on the map
-coordinate system used and the geographic extent of the
-data. Each "location" directory itself contains
-subdirectories called "mapsets"; each "mapset" stores "data
-base elements" -- the directories (e.g., the
-<kbd>cell</kbd>, <kbd>cellhd</kbd>, <kbd>dig</kbd>, etc.,
-directories) in which GRASS data files are actually
-stored.
<dt><em>LOCATION_NAME</em>
-<dd>The user must choose to work with the data under a single
-GRASS location within any given GRASS session; this
-location is then called the <em>current GRASS
-location</em>, and is specified by the variable
-<kbd>$LOCATION_NAME</kbd>. The <kbd>$LOCATION_NAME</kbd>
+<dd>The user must choose to work with the data under a single GRASS
+location within any given GRASS session; this location is then called
+the <em>current GRASS location</em>, and is specified by the variable
+<tt>$LOCATION_NAME</tt>. The <tt>$LOCATION_NAME</tt> is the GRASS data
+base location whose data will be affected by any GRASS commands issued
+during the user's current GRASS session, and is a subdirectory of the
+current <tt>$GISDBASE</tt>. Each "location" directory can
+contain multiple "mapset" directories (including the special
+mapset <tt>PERMANENT</tt>). Maps stored under the same
+GRASS <tt>$LOCATION_NAME</tt> (and/or within the same <tt>MAPSET</tt>)
+must use the same coordinate system and typically fall within the
+boundaries of the same geographic region (aka, "location").
-is the GRASS data base location whose data will be affected
-by any GRASS commands issued during the user's current
-GRASS session, and is a subdirectory of the current
-<kbd>$GISDBASE</kbd>. Each "location" directory can
-contain multiple "mapset" directories (including the
-special mapset <kbd>PERMANENT</kbd>). Maps stored under
-the same GRASS <kbd>LOCATION_NAME</kbd> (and/or within the
-same <kbd>MAPSET</kbd>) must use the same coordinate system
-and typically fall within the boundaries of the same
-geographic region (aka, "location").
<dt><em>MAPSET</em>
-<dd>Each "mapset" contains a set of maps relevant to the
-<kbd>LOCATION_NAME</kbd> directory in which it appears.
-Each <kbd>LOCATION_NAME</kbd> can contain multiple
-mapsets. (Mapsets which fall under the same
+<dd>Each "mapset" contains a set of maps relevant to the
+<tt>$LOCATION_NAME</tt> directory in which it appears.
+Each <tt>$LOCATION_NAME</tt> can contain multiple mapsets. (Mapsets
+which fall under the same <tt>$LOCATION_NAME</tt> all contain data
+geographically relevant to the <tt>$LOCATION_NAME</tt>, and all store
+data in the same map coordinate system. Frequently, maps are placed
+into different mapsets to distinguish file ownership - e.g., each user
+might have his own mapset, storing any maps that he has created and/or
+are relevant to his work.) During each GRASS session, the user must
+choose one mapset to be the <em>current mapset</em>; the current
+mapset setting is given by <tt>$MAPSET</tt>, and is a subdirectory
+of <tt>$LOCATION_NAME</tt>. During a single GRASS session, the user
+can use available data in any of the mapsets stored under the
+current <tt>$LOCATION_NAME</tt> directory that are in the user's
+mapset search path and accessible by the user. However, within a
+single GRASS session, the user only has <em>write</em> access to data
+stored under the <em>current mapset</em> (specified by the
+variable <tt>$MAPSET</tt>).
-<kbd>LOCATION_NAME</kbd> all contain data geographically
-relevant to the <kbd>LOCATION_NAME</kbd>, and all store
-data in the same map coordinate system. Frequently, maps
-are placed into different mapsets to distinguish file
-ownership -- e.g., each user might have his own mapset,
-storing any maps that he has created and/or are relevant to
-his work.) During each GRASS session, the user must choose
-one mapset to be the <em>current mapset</em>; the current
-mapset setting is given by <kbd>$MAPSET</kbd>, and is a
-subdirectory of <kbd>$LOCATION_NAME</kbd>. During a single
-GRASS session, the user can use available data in any of
-the mapsets stored under the current
-<kbd>LOCATION_NAME</kbd> directory that are in the user's
-mapset search path and accessible by the user. However,
-within a single GRASS session, the user only has
-<em>write</em> access to data stored under the <em>current
-mapset</em> (specified by the variable
-<kbd>$MAPSET</kbd>).
<p>
+Each "mapset" stores GRASS data base elements (i.e., the
+directories in which GRASS data files are stored). Any maps created
+or modified by the user in the current GRASS session will be stored
+here. The <tt>$MAPSET</tt> directory <tt>PERMANENT</tt> is generally
+reserved for the set of maps that form the base set for all users
+working under each <tt>$LOCATION_NAME</tt>.
-Each "mapset" stores GRASS data base elements (i.e., the
-directories in which GRASS data files are stored). Any
-maps created or modified by the user in the current GRASS
-session will be stored here. The <kbd>MAPSET</kbd>
-directory <kbd>PERMANENT</kbd> is generally reserved for
-the set of maps that form the base set for all users
-working under each <kbd>LOCATION_NAME</kbd>.
</dl>
-Once within a GRASS session, GRASS users have access only
-to the data under a single GRASS data base directory (the
-<em>current GRASS data base</em>, specified by the variable
-<kbd>$GISDBASE</kbd>), and to a single GRASS location
-directory (the <em>current location</em>, specified by the
-variable <kbd>$LOCATION_NAME</kbd>). Within a single
+Once within a GRASS session, GRASS users have access only to the data
+under a single GRASS data base directory (the <em>current GRASS data
+base</em>, specified by the variable <tt>$GISDBASE</tt>), and to a
+single GRASS location directory (the <em>current location</em>,
+specified by the variable <tt>$LOCATION_NAME</tt>). Within a single
session, the user may only <em>modify</em> the data in the
<em>current mapset</em> (specified by the variable
-<kbd>$MAPSET</kbd>), but may <em>use</em> data available
-under other mapsets under the same
+<tt>$MAPSET</tt>), but may <em>use</em> data available under other
+mapsets under the same <tt>$LOCATION_NAME</tt>.
-<kbd>LOCATION_NAME</kbd>.
<p>
-All of these names must be legal names on the user's
-current system. For UNIX users, names less than 14
-characters and containing no non-printing or space codes
-are permissible. Examples of permissible names include:
-<em>one</em>, <em>mymap</em>, <em>VeGe_map</em>, and
+All of these names must be legal names on the user's current system.
+<!--For UNIX users, names less than 14 characters and containing no
+non-printing or space codes are permissible. Examples of permissible
+names include: <em>one</em>, <em>mymap</em>, <em>VeGe_map</em>, and
<em>1_for_me</em>. The underscore character can safely be
used in place of a blank for multiple-word names.
<h2>NOTES</h2>
The output from
<em>g.gisenv</em>
-when invoked without arguments is directly usable by /bin/sh.
-The following command will cast each variable into the UNIX environment:
-<p>
+when invoked without arguments is directly usable by Bash. The
+following command will cast each variable into the UNIX environment:
-<b>eval `g.gisenv`</b>
+eval `g.gisenv`
</pre></div>
-<p>
-This works only for <em>/bin/sh</em>. The format of the
-output is not compatible with other UNIX shells.
+This works only for <em>Bash</em>. The format of the output is not
+compatible with other UNIX shells.
-<h3>GRASS Debugging:</h3>
+<h3>GRASS Debugging</h3>
-To print debugging messages, the variable DEBUG must be set to level equal or
-greater than 0:
-<P>
+To print debugging messages, the variable DEBUG must be set to level
+equal or greater than 0:
-<TT>g.gisenv set="DEBUG=3"</TT>
+g.gisenv set="DEBUG=3"
</pre></div>
-<P>
Levels: (recommended levels)
<ul>
-<li> 0 - silence
-<li> 1 - message is printed once or few times per module
-<li> 3 - each row (raster) or line (vector)
-<li> 5 - each cell (raster) or point (vector)
+ <li> 0 - silence
+ <li> 1 - message is printed once or few times per module
+ <li> 3 - each row (raster) or line (vector)
+ <li> 5 - each cell (raster) or point (vector)
</ul>
To disable debugging messages, DEBUG must be set back to 0:
-<P>
-<TT>g.gisenv set="DEBUG=0"</TT>
+g.gisenv set="DEBUG=0"
</pre></div>
-<P>
<h2>SEE ALSO</h2>
-<em><a HREF="g.access.html">g.access</a></em><br>
-<em><a HREF="g.ask.html">g.ask</a></em><br>
-<em><a HREF="g.filename.html">g.filename</a></em><br>
-<em><a HREF="g.findfile.html">g.findfile</a></em><br>
-<em><a HREF="g.mapsets.html">g.mapsets</a></em><br>
-<em><a href="variables.html">variables list</a></em>
+<em>
+ <a href="g.access.html">g.access</a>,
+ <a href="g.filename.html">g.filename</a>,
+ <a href="g.findfile.html">g.findfile</a>,
+ <a href="g.mapsets.html">g.mapsets</a>
+</em>
+<br><br>
+<em>
+ See also <a href="variables.html">variables list</a>
+</em>
<h2>AUTHOR</h2>
Michael Shapiro,
U.S.Army Construction Engineering Research Laboratory
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
Modified: grass/trunk/general/g.gisenv/main.c
--- grass/trunk/general/g.gisenv/main.c 2011-01-04 20:06:37 UTC (rev 44867)
+++ grass/trunk/general/g.gisenv/main.c 2011-01-04 20:38:02 UTC (rev 44868)
@@ -8,7 +8,7 @@
* Hamish Bowman <hamish_b yahoo.com>,
* Markus Neteler <neteler itc.it>
* PURPOSE:
- * COPYRIGHT: (C) 2003-2006 by the GRASS Development Team
+ * COPYRIGHT: (C) 2003-2006, 2011 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -36,6 +36,7 @@
module = G_define_module();
G_add_keyword(_("general"));
+ G_add_keyword(_("settings"));
module->description =
_("Outputs and modifies the user's current GRASS variable settings.");
@@ -45,6 +46,7 @@
get->description = _("GRASS variable to get");
get->key_desc = "VARIABLE";
get->required = NO;
+ get->guisection = _("Get");
set = G_define_option();
set->key = "set";
@@ -52,6 +54,7 @@
set->description = _("GRASS variable to set");
set->key_desc = "VARIABLE=value";
set->required = NO;
+ set->guisection = _("Set");
store_opt = G_define_option();
store_opt->key = "store";
@@ -60,14 +63,17 @@
store_opt->answer = "gisrc";
store_opt->description = _("Where GRASS variable is stored");
store_opt->required = NO;
+ store_opt->guisection = _("Set");
flag_s = G_define_flag();
flag_s->key = 's';
flag_s->description = _("Use shell syntax (for \"eval\")");
+ flag_s->guisection = _("Format");
flag_n = G_define_flag();
flag_n->key = 'n';
flag_n->description = _("Don't Use shell syntax");
+ flag_n->guisection = _("Format");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
