[GRASS-SVN] r44910 - grass/trunk/lib/vector/vedit
svn_grass at osgeo.org
Sat Jan 8 21:49:05 EST 2011
Author: martinl
Date: 2011-01-08 18:49:05 -0800 (Sat, 08 Jan 2011)
New Revision: 44910
grass/trunk/lib/vector/vedit/break.c
grass/trunk/lib/vector/vedit/cats.c
grass/trunk/lib/vector/vedit/chtype.c
grass/trunk/lib/vector/vedit/copy.c
grass/trunk/lib/vector/vedit/delete.c
grass/trunk/lib/vector/vedit/distance.c
grass/trunk/lib/vector/vedit/flip.c
grass/trunk/lib/vector/vedit/merge.c
grass/trunk/lib/vector/vedit/move.c
grass/trunk/lib/vector/vedit/render.c
grass/trunk/lib/vector/vedit/select.c
grass/trunk/lib/vector/vedit/snap.c
grass/trunk/lib/vector/vedit/veditlib.dox
grass/trunk/lib/vector/vedit/vertex.c
grass/trunk/lib/vector/vedit/zbulk.c
veditlib: doxygen clean up
Modified: grass/trunk/lib/vector/vedit/break.c
--- grass/trunk/lib/vector/vedit/break.c 2011-01-08 23:35:49 UTC (rev 44909)
+++ grass/trunk/lib/vector/vedit/break.c 2011-01-09 02:49:05 UTC (rev 44910)
@@ -1,16 +1,14 @@
- \file vector/vedit/break.c
+ \file lib/vector/vedit/break.c
- \brief Vedit library - split, break, connect lines
- (C) 2007-2008 by the GRASS Development Team
- This program is free software under the GNU General Public License
- (>=v2). Read the file COPYING that comes with GRASS for details.
- \author Martin Landa <landa.martin gmail.com>
- \date 2007-2008
+ \brief Vedit library - split, break, connect lines
+ (C) 2007-2008 by the GRASS Development Team
+ This program is free software under the GNU General Public License
+ (>=v2). Read the file COPYING that comes with GRASS for details.
+ \author Martin Landa <landa.martin gmail.com>
#include <grass/config.h>
@@ -20,17 +18,17 @@
static int connect_lines(struct Map_info *, int, int, int,
double, struct ilist *);
- \brief Split selected lines on given position
- \param Map vector map
- \param List list of selected lines
- \param coord points location
- \param[out] List_updated list of rewritten features (or NULL)
- \return number of modified lines
- \return -1 on error
+ \brief Split selected lines on given position
+ \param Map pointer to Map_info
+ \param List list of selected lines
+ \param coord points location
+ \param[out] List_updated list of rewritten features (or NULL)
+ \return number of modified lines
+ \return -1 on error
int Vedit_split_lines(struct Map_info *Map, struct ilist *List,
struct line_pnts *coord, double thresh,
struct ilist *List_updated)
@@ -131,20 +129,20 @@
return nlines_modified;
- \brief Connect lines in given threshold
- <pre>
+ \brief Connect lines in given threshold
+ \code
id1 \ -> \
id2 --------- -----+---
- </pre>
+ \endcode
If two lines are selected and <i>thresh</i> is -1, no limit is
applied.
\param thresh threshold value
Modified: grass/trunk/lib/vector/vedit/cats.c
--- grass/trunk/lib/vector/vedit/cats.c 2011-01-08 23:35:49 UTC (rev 44909)
+++ grass/trunk/lib/vector/vedit/cats.c 2011-01-09 02:49:05 UTC (rev 44910)
@@ -1,35 +1,32 @@
+ \file lib/vector/vedit/cats.c
- \file vector/vedit/cats.c
+ \brief Vedit library - category manipulation
+ (C) 2006-2008 by the GRASS Development Team
- \brief Vedit library - category manipulation
- (C) 2006-2008 by the GRASS Development Team
- \author Jachym Cepicky <jachym.cepicky gmail.com>
- \date 2006-2008
+ \author Jachym Cepicky <jachym.cepicky gmail.com>
#include <grass/glocale.h>
#include <grass/vedit.h>
- \brief Add / remove categories
- \param List list of selected primitives
- \param layer layer number
- \param del action (non-zero for delete otherwise add)
- \param cats_list list of category numbers
- \return number of modified primitives
+ \brief Add / remove categories
+ \param List list of selected primitives
+ \param layer layer number
+ \param del action (non-zero for delete otherwise add)
+ \param cats_list list of category numbers
+ \return number of modified primitives
int Vedit_modify_cats(struct Map_info *Map, struct ilist *List,
int layer, int del, struct cat_list *Clist)
Modified: grass/trunk/lib/vector/vedit/chtype.c
--- grass/trunk/lib/vector/vedit/chtype.c 2011-01-08 23:35:49 UTC (rev 44909)
+++ grass/trunk/lib/vector/vedit/chtype.c 2011-01-09 02:49:05 UTC (rev 44910)
@@ -1,33 +1,30 @@
- \file vector/vedit/chtype.c
- \brief Vedit library - change primitives type
- (C) 2008 by the GRASS Development Team
- \date 2008
+ \file vector/vedit/chtype.c
+ \brief Vedit library - change primitives type
+ (C) 2008 by the GRASS Development Team
- \brief Change primitive type
+ \brief Change primitive type
+ Supported conversions:
+ - point <-> centroid
+ - line <-> boundary
- Supported conversions:
- - point <-> centroid
- - line <-> boundary
int Vedit_chtype_lines(struct Map_info *Map, struct ilist *List)
Modified: grass/trunk/lib/vector/vedit/copy.c
--- grass/trunk/lib/vector/vedit/copy.c 2011-01-08 23:35:49 UTC (rev 44909)
+++ grass/trunk/lib/vector/vedit/copy.c 2011-01-09 02:49:05 UTC (rev 44910)
@@ -1,32 +1,29 @@
+ \file lib/vector/vedit/copy.c
- \file vector/vedit/copy.c
- \brief Vedit library - copy primitives
- \date 2007-2008
+ \brief Vedit library - copy primitives
- \brief Copy selected primitives
- \param Map vector map copy to
- \param FromMap vector map copy from (if not given use Map)
- \param List list of selected primitives (to be copied)
- \return number of copied primitives
+ \brief Copy selected primitives
+ \param Map pointer to Map_info copy to
+ \param FromMap vector map copy from (if not given use Map)
+ \param List list of selected primitives (to be copied)
+ \return number of copied primitives
int Vedit_copy_lines(struct Map_info *Map, struct Map_info *FromMap,
struct ilist *List)
Modified: grass/trunk/lib/vector/vedit/delete.c
--- grass/trunk/lib/vector/vedit/delete.c 2011-01-08 23:35:49 UTC (rev 44909)
+++ grass/trunk/lib/vector/vedit/delete.c 2011-01-09 02:49:05 UTC (rev 44910)
@@ -1,30 +1,27 @@
+ \file lib/vector/vedit/delete.c
- \file vector/vedit/delete.c
+ \brief Vedit library - delete primitives
- \brief Vedit library - delete primitives
- \date 2007-2008
- \brief Delete selected primitives
- \param List list of primitives to be deleted
- \return number of deleted primitives
- \return -1 on on error
+ \brief Delete selected primitives
+ \param List list of primitives to be deleted
+ \return number of deleted primitives
+ \return -1 on on error
int Vedit_delete_lines(struct Map_info *Map, struct ilist *List)
int i, line;
Modified: grass/trunk/lib/vector/vedit/distance.c
--- grass/trunk/lib/vector/vedit/distance.c 2011-01-08 23:35:49 UTC (rev 44909)
+++ grass/trunk/lib/vector/vedit/distance.c 2011-01-09 02:49:05 UTC (rev 44910)
@@ -1,31 +1,28 @@
+ \file lib/vector/vedit/distance.c
- \file vector/vedit/distance.c
+ \brief Vedit library - distance calculation
- \brief Vedit library - distance calculation
- \date 2007-2008
- \brief Calculate distances between two lines
- \todo LL projection
- \param Points1 first line geometry
- \param Points2 second line geometry
- \param[out] index of minimal distance
- \return minimal distance betwen two lines (their nodes)
+ \brief Calculate distances between two lines
+ \todo LL projection
+ \param Points1 first line geometry
+ \param Points2 second line geometry
+ \param[out] index of minimal distance
+ \return minimal distance betwen two lines (their nodes)
double Vedit_get_min_distance(struct line_pnts *Points1,
struct line_pnts *Points2, int with_z,
Modified: grass/trunk/lib/vector/vedit/flip.c
--- grass/trunk/lib/vector/vedit/flip.c 2011-01-08 23:35:49 UTC (rev 44909)
+++ grass/trunk/lib/vector/vedit/flip.c 2011-01-09 02:49:05 UTC (rev 44910)
@@ -1,30 +1,27 @@
- \file vector/vedit/flip.c
- \brief Vedit library - flip lines
- \date 2007-2008
+ \file lib/vector/vedit/flip.c
+ \brief Vedit library - flip lines
- \brief Flip direction of selected lines
+ \brief Flip direction of selected lines
int Vedit_flip_lines(struct Map_info *Map, struct ilist *List)
struct line_cats *Cats;
Modified: grass/trunk/lib/vector/vedit/merge.c
--- grass/trunk/lib/vector/vedit/merge.c 2011-01-08 23:35:49 UTC (rev 44909)
+++ grass/trunk/lib/vector/vedit/merge.c 2011-01-09 02:49:05 UTC (rev 44910)
@@ -1,49 +1,46 @@
- \file vector/vedit/merge.c
- \brief Vedit library - merge lines
- \date 2006-2008
+ \file lib/vector/vedit/merge.c
+ \brief Vedit library - merge lines
- \brief Merge two given lines a, b
+ \brief Merge two given lines a, b
+ a : Points1/Cats1
+ b : Points2/Cats2
+ merged line : Points/Cats
- a : Points1/Cats1
- b : Points2/Cats2
- merged line : Points/Cats
- \param Points1,Cats1 first line
- \param Points2,Cats2 second line
- \param thresh threshold value
- \param[out] Points result line
- \return 1 on success
- \return 0 on error
+ \param Points1,Cats1 first line
+ \param Points2,Cats2 second line
+ \param thresh threshold value
+ \param[out] Points result line
+ \return 1 on success
+ \return 0 on error
static int merge_lines(struct line_pnts *Points1, struct line_cats *Cats1,
struct line_pnts *Points2, struct line_cats *Cats2,
double thresh, struct line_pnts **Points);
- \brief Merge lines/boundaries
- At least two lines need to be given.
+ \brief Merge lines/boundaries
+ At least two lines need to be given.
\return number of merged lines
\return -1 on error
Modified: grass/trunk/lib/vector/vedit/move.c
--- grass/trunk/lib/vector/vedit/move.c 2011-01-08 23:35:49 UTC (rev 44909)
+++ grass/trunk/lib/vector/vedit/move.c 2011-01-09 02:49:05 UTC (rev 44910)
@@ -1,33 +1,30 @@
- \file vector/vedit/move.c
- \brief Vedit library - move primitives
- \date 2007-2008
+ \file lib/vector/vedit/move.c
+ \brief Vedit library - move primitives
- \brief Move selected primitives
- \param BgMap, nbgmaps list of background vector maps used for snapping
- \param List list of primitives to be moved
- \param move_x,move_y,move_z direction (move_z used only if map is 3D)
- \param snap enable snapping (see globals.h)
+ \brief Move selected primitives
+ \param BgMap, nbgmaps list of background vector maps used for snapping
+ \param List list of primitives to be moved
+ \param move_x,move_y,move_z direction (move_z used only if map is 3D)
+ \param snap enable snapping (see globals.h)
int Vedit_move_lines(struct Map_info *Map, struct Map_info **BgMap,
int nbgmaps, struct ilist *List, double move_x,
Modified: grass/trunk/lib/vector/vedit/render.c
--- grass/trunk/lib/vector/vedit/render.c 2011-01-08 23:35:49 UTC (rev 44909)
+++ grass/trunk/lib/vector/vedit/render.c 2011-01-09 02:49:05 UTC (rev 44910)
@@ -3,7 +3,7 @@
\brief Vedit library - render vector features (used by wxGUI digitizer)
- (C) 2010 by the GRASS Development Team
+ (C) 2010-2011 by the GRASS Development Team
@@ -49,15 +49,15 @@
static void draw_area(struct Map_info *, int, struct robject_list *);
- \brief Render vector features into list
- \param Map pointer to Map_info structure
- \param box bounding box of region to be rendered
- \param draw_flag types of objects to be rendered (see vedit.h)
- \param center_easing, center_northing, map_width, map_height, map_res values used for conversion en->xy
- \return pointer to robject_list structure
+ \brief Render vector features into list
+ \param Map pointer to Map_info structure
+ \param box bounding box of region to be rendered
+ \param draw_flag types of objects to be rendered (see vedit.h)
+ \param center_easing, center_northing, map_width, map_height, map_res values used for conversion en->xy
+ \return pointer to robject_list structure
struct robject_list *Vedit_render_map(struct Map_info *Map,
struct bound_box *box, int draw_flag,
double center_easting,
@@ -125,7 +125,7 @@
/* direction */
if (draw_flag & DRAW_DIRECTION) {
- draw_line_dir(list_obj, fid);
+ draw_line_dir(list_obj, fid);
Modified: grass/trunk/lib/vector/vedit/select.c
--- grass/trunk/lib/vector/vedit/select.c 2011-01-08 23:35:49 UTC (rev 44909)
+++ grass/trunk/lib/vector/vedit/select.c 2011-01-09 02:49:05 UTC (rev 44910)
@@ -1,17 +1,14 @@
+ \file lib/vector/vedit/select.c
- \file vector/vedit/select.c
- \brief Vedit library - select primitives by query
- \date 2007-2008
+ \brief Vedit library - select primitives by query
#include <math.h>
@@ -23,24 +20,24 @@
static int merge_lists(struct ilist *alist, struct ilist *blist);
- \brief Select primitives by query (based on geometry properties)
+ \brief Select primitives by query (based on geometry properties)
+ Currently supported:
+ - QUERY_LENGTH, select all lines longer than threshold (or shorter if threshold is < 0)
+ - QUERY_DANGLE, select all dangles longer than threshold (or shorter if threshold is < 0)
- Currently supported:
- - QUERY_LENGTH, select all lines longer than threshold (or shorter if threshold is < 0)
- - QUERY_DANGLE, select all dangles longer than threshold (or shorter if threshold is < 0)
+ Perform global query if <i>List</i> is empty otherwise query only
+ selected vector objects.
- Perform global query if <i>List</i> is empty otherwise query only
- selected vector objects.
- \param type feature type
- \param thresh threshold value (< 0 for 'shorter', > 0 for 'longer')
- \param query query (length, dangle, ...)
- \param[in,out] List list of selected features
- \return number of selected primitives
+ \param type feature type
+ \param thresh threshold value (< 0 for 'shorter', > 0 for 'longer')
+ \param query query (length, dangle, ...)
+ \param[in,out] List list of selected features
+ \return number of selected primitives
int Vedit_select_by_query(struct Map_info *Map,
int type, int layer, double thresh, int query,
@@ -126,7 +123,7 @@
return List->n_values;
\brief Query selected primitive
\return 1 line test positive
@@ -237,7 +234,7 @@
return 0;
\brief Merge two lists, i.e. store only duplicate items
\param[in,out] alist list to be merged
Modified: grass/trunk/lib/vector/vedit/snap.c
--- grass/trunk/lib/vector/vedit/snap.c 2011-01-08 23:35:49 UTC (rev 44909)
+++ grass/trunk/lib/vector/vedit/snap.c 2011-01-09 02:49:05 UTC (rev 44910)
@@ -1,32 +1,29 @@
+ \file lib/vector/vedit/snap.c
- \file vector/vedit/snap.c
- \brief Vedit library - snapping
- \date 2007-2008
+ \brief Vedit library - snapping
- \brief Snap given point to the nearest primitive
- \param line line to be excluded (point on line)
- \param x,y,z point on line to be snapped
- \param thresh snapping threshold (>0)
- \param vertex snap also to vertex (non-zero)
- \return 1 snapped
- \return 0 not snapped
+ \brief Snap given point to the nearest primitive
+ \param line line to be excluded (point on line)
+ \param x,y,z point on line to be snapped
+ \param thresh snapping threshold (>0)
+ \param vertex snap also to vertex (non-zero)
+ \return 1 snapped
+ \return 0 not snapped
int Vedit_snap_point(struct Map_info *Map,
int line, double *x, double *y, double *z, double thresh,
@@ -84,20 +81,20 @@
return snapped;
- \brief Snap selected primitive to its nearest primitive
- \param BgMap,nbgmaps list of background maps used for snapping
- \param line line id to be snapped (if already written, otherwise -1)
- \param Points line geometry
- \param thresh threshold value used for snapping (>0)
- \param to_vertex allow snapping also to vertex
- \return 1 line snapped
- \return 0 line not snapped
- \return -1 line is dead (if 'line' is > 0)
+ \brief Snap selected primitive to its nearest primitive
+ \param BgMap,nbgmaps list of background maps used for snapping
+ \param line line id to be snapped (if already written, otherwise -1)
+ \param Points line geometry
+ \param thresh threshold value used for snapping (>0)
+ \param to_vertex allow snapping also to vertex
+ \return 1 line snapped
+ \return 0 line not snapped
+ \return -1 line is dead (if 'line' is > 0)
int Vedit_snap_line(struct Map_info *Map, struct Map_info **BgMap,
int nbgmaps, int line, struct line_pnts *Points,
@@ -162,18 +159,18 @@
return rewrite;
- \brief Snap lines/boundaries
- \param List list of lines to be snapped
- \return number of snapped lines
+ \brief Snap lines/boundaries
+ \param List list of lines to be snapped
+ \return number of snapped lines
int Vedit_snap_lines(struct Map_info *Map, struct Map_info **BgMap,
int nbgmaps, struct ilist *List, double thresh,
Modified: grass/trunk/lib/vector/vedit/veditlib.dox
--- grass/trunk/lib/vector/vedit/veditlib.dox 2011-01-08 23:35:49 UTC (rev 44909)
+++ grass/trunk/lib/vector/vedit/veditlib.dox 2011-01-09 02:49:05 UTC (rev 44910)
@@ -62,15 +62,16 @@
- Vedit_bulk_labeling()
-\section authors Authors
+ - Vedit_render_map()
- Martin Landa <landa.martin gmail.com>
\section seealso See Also
- \ref vectorlib
- \ref dbmilib
-Last change: $Date$
+\section authors Authors
+ Martin Landa <landa.martin gmail.com>
Modified: grass/trunk/lib/vector/vedit/vertex.c
--- grass/trunk/lib/vector/vedit/vertex.c 2011-01-08 23:35:49 UTC (rev 44909)
+++ grass/trunk/lib/vector/vedit/vertex.c 2011-01-09 02:49:05 UTC (rev 44910)
@@ -1,38 +1,35 @@
- \file vector/vedit/vertex.c
- \brief Vedit library - vertex manipulation
- \date 2006-2008
+ \file lib/vector/vedit/vertex.c
+ \brief Vedit library - vertex manipulation
- \brief Move all vertices in bounding box(es)
- \param BgMap, nbgmaps list of background vector maps for snapping
- \param thresh_coords threshold value for selecting lines
- \param thresh_snap threshold value used for snapping
- \param move_x,move_y,move_z direction (move_z is used when map is 3D)
- \param move_first move only first vertex found in the bounding box
- \param snap snapping mode (see vedit.h)
- \return number of moved verteces
+ \brief Move all vertices in bounding box(es)
+ \param BgMap, nbgmaps list of background vector maps for snapping
+ \param thresh_coords threshold value for selecting lines
+ \param thresh_snap threshold value used for snapping
+ \param move_x,move_y,move_z direction (move_z is used when map is 3D)
+ \param move_first move only first vertex found in the bounding box
+ \param snap snapping mode (see vedit.h)
+ \return number of moved verteces
int Vedit_move_vertex(struct Map_info *Map, struct Map_info **BgMap,
struct line_pnts *coord, double thresh_coords,
@@ -179,20 +176,20 @@
return nvertices_moved;
- \brief Add new vertex to line
- Shape of line is not changed.
- \todo 3D
- \param thresh find line in given threshold
- \return number of add verteces
+ \brief Add new vertex to line
+ Shape of line is not changed.
+ \todo 3D
+ \param thresh find line in given threshold
+ \return number of add verteces
int Vedit_add_vertex(struct Map_info *Map, struct ilist *List,
struct line_pnts *coord, double thresh)
@@ -269,18 +266,18 @@
return nvertices_added;
- \brief Remove vertex from line
- \todo 3D
- \param thresh threshold value to find a line
- \return number of removed vertices
+ \brief Remove vertex from line
+ \todo 3D
+ \param thresh threshold value to find a line
+ \return number of removed vertices
int Vedit_remove_vertex(struct Map_info *Map, struct ilist *List,
Modified: grass/trunk/lib/vector/vedit/zbulk.c
--- grass/trunk/lib/vector/vedit/zbulk.c 2011-01-08 23:35:49 UTC (rev 44909)
+++ grass/trunk/lib/vector/vedit/zbulk.c 2011-01-09 02:49:05 UTC (rev 44910)
@@ -1,37 +1,34 @@
+ \file lib/vector/vedit/zbulk.c
- \file vector/vedit/zbulk.c
- \brief Vedit library - Bulk labeling (automated labeling of vector
- features)
- \date 2007-2008
+ \brief Vedit library - Bulk labeling (automated labeling of vector
+ features)
#include <grass/dbmi.h>
- \brief Lines z-bulk labeling
- Automated labeling (z coordinate assignment) of vector lines (iso-lines).
- \param point_start_end staring and ending point
- \param start starting value
- \param step step value
- \return number of modified features
+ \brief Lines z-bulk labeling
+ Automated labeling (z coordinate assignment) of vector lines (iso-lines).
+ \param point_start_end staring and ending point
+ \param start starting value
+ \param step step value
+ \return number of modified features
int Vedit_bulk_labeling(struct Map_info *Map, struct ilist *List,
double x1, double y1, double x2, double y2,
