[GRASS-SVN] r44920 - grass/branches/develbranch_6/vector/v.digit
svn_grass at osgeo.org
Sun Jan 9 16:19:14 EST 2011
Author: marisn
Date: 2011-01-09 13:19:14 -0800 (Sun, 09 Jan 2011)
New Revision: 44920
grass/branches/develbranch_6/vector/v.digit/line.c
v.digit Snap to line startpoint to allow single boundary are creation (fixes #1255)
Modified: grass/branches/develbranch_6/vector/v.digit/line.c
--- grass/branches/develbranch_6/vector/v.digit/line.c 2011-01-09 20:27:12 UTC (rev 44919)
+++ grass/branches/develbranch_6/vector/v.digit/line.c 2011-01-09 21:19:14 UTC (rev 44920)
@@ -153,6 +153,7 @@
struct new_line *nl = closure;
double x = D_d_to_u_col(sxn);
double y = D_d_to_u_row(syn);
+ double dist;
G_debug(3, "button = %d x = %d = %f y = %d = %f", button, sxn, x, syn, y);
@@ -173,8 +174,21 @@
else { /* GV_LINES */
/* Button may be 1,2,3 */
if (button == 1) { /* New point */
- snap(&x, &y);
- Vect_append_point(nl->Points, x, y, 0);
+ if (snap(&x, &y) == 0) {
+ /* If not snapping to other features, try to snap to lines start.
+ * Allows to create area of single boundary. */
+ if (nl->Points->n_points > 2) {
+ dist = Vect_points_distance(nl->Points->x[0], nl->Points->y[0], 0, x, y, 0, WITHOUT_Z);
+ if (dist < get_thresh()) {
+ x = nl->Points->x[0];
+ y = nl->Points->y[0];
+ if (Vect_append_point(nl->Points, x, y, 0) == -1) {
+ G_warning(_("Out of memory! Point not added."));
+ return 0;
if (nl->type == GV_LINE)
symb_set_driver_color(SYMB_LINE);
