[GRASS-SVN] r44930 - grass/branches/develbranch_6/vector/v.transform
svn_grass at osgeo.org
Mon Jan 10 08:33:09 EST 2011
Author: martinl
Date: 2011-01-10 05:33:09 -0800 (Mon, 10 Jan 2011)
New Revision: 44930
grass/branches/develbranch_6/vector/v.transform/local_proto.h
grass/branches/develbranch_6/vector/v.transform/main.c
grass/branches/develbranch_6/vector/v.transform/trans_digit.c
v.transform: flag to swap coordinates x,y
(merge r44929 from trunk)
Modified: grass/branches/develbranch_6/vector/v.transform/local_proto.h
--- grass/branches/develbranch_6/vector/v.transform/local_proto.h 2011-01-10 13:20:57 UTC (rev 44929)
+++ grass/branches/develbranch_6/vector/v.transform/local_proto.h 2011-01-10 13:33:09 UTC (rev 44930)
@@ -26,4 +26,4 @@
/* trans_digit.c */
int transform_digit_file(struct Map_info *, struct Map_info *, int,
- double, double *, char *, char **, int);
+ double, int, double *, char *, char **, int);
Modified: grass/branches/develbranch_6/vector/v.transform/main.c
--- grass/branches/develbranch_6/vector/v.transform/main.c 2011-01-10 13:20:57 UTC (rev 44929)
+++ grass/branches/develbranch_6/vector/v.transform/main.c 2011-01-10 13:33:09 UTC (rev 44930)
@@ -10,7 +10,7 @@
* PURPOSE: To transform a vector map's coordinates via a set of tie
* points.
-* COPYRIGHT: (C) 2002-2007 by the GRASS Development Team
+* COPYRIGHT: (C) 2002-2007, 2011 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -50,8 +50,8 @@
struct Option *vold, *vnew, *pointsfile, *xshift, *yshift, *zshift,
*xscale, *yscale, *zscale, *zrot, *columns, *table, *field;
- struct Flag *quiet_flag, *tozero_flag, *shift_flag, *print_mat_flag;
+ struct Flag *quiet_flag, *tozero_flag, *shift_flag, *print_mat_flag, *swap_flag;
char *mapset, mon[4], date[40], buf[1000];
struct Map_info Old, New;
int day, yr;
@@ -96,6 +96,11 @@
"(xshift, yshift, zshift, xscale, yscale, zscale, zrot)");
shift_flag->guisection = _("Custom");
+ swap_flag = G_define_flag();
+ swap_flag->key = 'w';
+ swap_flag->description =
+ _("Swap coordinates x, y and then apply other parameters");
vold = G_define_standard_option(G_OPT_V_INPUT);
vnew = G_define_standard_option(G_OPT_V_OUTPUT);
@@ -325,7 +330,7 @@
trans_params[IDX_ZROT] = atof(zrot->answer);
transform_digit_file(&Old, &New, Coord.name[0] ? 1 : 0,
- ztozero, trans_params,
+ ztozero, swap_flag->answer, trans_params,
table->answer, columns_name, atoi(field->answer));
if (Vect_copy_tables(&Old, &New, 0))
Modified: grass/branches/develbranch_6/vector/v.transform/trans_digit.c
--- grass/branches/develbranch_6/vector/v.transform/trans_digit.c 2011-01-10 13:20:57 UTC (rev 44929)
+++ grass/branches/develbranch_6/vector/v.transform/trans_digit.c 2011-01-10 13:33:09 UTC (rev 44930)
@@ -29,7 +29,7 @@
int
transform_digit_file(struct Map_info *Old, struct Map_info *New,
- int shift_file, double ztozero, double *trans_params_def,
+ int shift_file, double ztozero, int swap, double *trans_params_def,
char *table, char **columns, int field)
int i, type, cat;
@@ -74,6 +74,14 @@
if (type == -2) /* EOF */
return 1;
+ if (swap) {
+ for (i = 0; i < Points->n_points; i++) {
+ x = Points->x[i];
+ Points->x[i] = Points->y[i];
+ Points->y[i] = x;
/* get transformation parameters */
if (table) {
Vect_cat_get(Cats, field, &cat); /* get first category */
