[GRASS-SVN] r44954 - grass/trunk/lib/vector/diglib
svn_grass at osgeo.org
Tue Jan 11 13:00:00 EST 2011
Author: mmetz
Date: 2011-01-11 10:00:00 -0800 (Tue, 11 Jan 2011)
New Revision: 44954
grass/trunk/lib/vector/diglib/spindex_rw.c
new fns to dump sidx from file to file
Modified: grass/trunk/lib/vector/diglib/spindex_rw.c
--- grass/trunk/lib/vector/diglib/spindex_rw.c 2011-01-11 17:58:36 UTC (rev 44953)
+++ grass/trunk/lib/vector/diglib/spindex_rw.c 2011-01-11 18:00:00 UTC (rev 44954)
@@ -548,6 +548,78 @@
return 0;
+static int rtree_dump_node_file(FILE *, off_t, int, struct RTree *);
+ \brief Dump R-tree branch from temp file to the file
+ \param fp pointer to FILE
+ \param b pointer to Branch structure
+ \param with_z non-zero value for 3D vector data
+ \param level level value
+ \return 0
+static int rtree_dump_branch_file(FILE * fp, struct Branch *b, int with_z,
+ int level, struct RTree *t)
+ const struct Rect *r;
+ r = &(b->rect);
+ if (level == 0)
+ fprintf(fp, " id = %d ", b->child.id);
+ fprintf(fp, " %f %f %f %f %f %f\n", r->boundary[0], r->boundary[1],
+ r->boundary[2], r->boundary[3], r->boundary[4], r->boundary[5]);
+ if (level > 0) {
+ rtree_dump_node_file(fp, b->child.pos, with_z, t);
+ return 0;
+ \brief Dump R-tree node from temp file to the file
+ \param pos position of Node in temp file
+ \param t RTree to dump
+ \return 0
+int rtree_dump_node_file(FILE * fp, off_t pos, int with_z, struct RTree *t)
+ int i;
+ struct Node n;
+ /* recursive nearly-but-a-bit-messy depth-first pre-order traversal
+ * potentially filling up memory */
+ /* TODO: change to non-recursive depth-first post-order traversal */
+ /* left for comparison with GRASS6.x */
+ RTreeReadNode(&n, pos, t);
+ fprintf(fp, "Node level=%d count=%d\n", n.level, n.count);
+ if (n.level > 0)
+ for (i = 0; i < NODECARD; i++) {
+ if (n.branch[i].child.pos >= 0) {
+ fprintf(fp, " Branch %d", i);
+ rtree_dump_branch_file(fp, &n.branch[i], with_z, n.level, t);
+ else
+ for (i = 0; i < LEAFCARD; i++) {
+ if (n.branch[i].child.id) {
+ return 0;
* all following methods to transfer spatial indices (rtrees) are based
* on the same idea
@@ -1158,16 +1230,40 @@
int dig_dump_spidx(FILE * fp, const struct Plus_head *Plus)
fprintf(fp, "Nodes\n");
- rtree_dump_node(fp, Plus->Node_spidx->root, Plus->with_z);
+ if (Plus->Node_spidx->fd < 0)
+ rtree_dump_node(fp, Plus->Node_spidx->root, Plus->with_z);
+ else {
+ RTreeFlushBuffer(Plus->Node_spidx);
+ rtree_dump_node_file(fp, Plus->Node_spidx->rootpos, Plus->with_z,
+ Plus->Node_spidx);
fprintf(fp, "Lines\n");
- rtree_dump_node(fp, Plus->Line_spidx->root, Plus->with_z);
+ if (Plus->Line_spidx->fd < 0)
+ rtree_dump_node(fp, Plus->Line_spidx->root, Plus->with_z);
+ else {
+ RTreeFlushBuffer(Plus->Line_spidx);
+ rtree_dump_node_file(fp, Plus->Line_spidx->rootpos, Plus->with_z,
+ Plus->Line_spidx);
fprintf(fp, "Areas\n");
- rtree_dump_node(fp, Plus->Area_spidx->root, Plus->with_z);
+ if (Plus->Area_spidx->fd < 0)
+ rtree_dump_node(fp, Plus->Area_spidx->root, Plus->with_z);
+ else {
+ RTreeFlushBuffer(Plus->Area_spidx);
+ rtree_dump_node_file(fp, Plus->Area_spidx->rootpos, Plus->with_z,
+ Plus->Area_spidx);
fprintf(fp, "Isles\n");
- rtree_dump_node(fp, Plus->Isle_spidx->root, Plus->with_z);
+ if (Plus->Isle_spidx->fd < 0)
+ rtree_dump_node(fp, Plus->Isle_spidx->root, Plus->with_z);
+ else {
+ RTreeFlushBuffer(Plus->Isle_spidx);
+ rtree_dump_node_file(fp, Plus->Isle_spidx->rootpos, Plus->with_z,
+ Plus->Isle_spidx);
return 0;
