[GRASS-SVN] r44969 - grass/trunk/imagery/i.eb.netrad
Tue Jan 11 19:45:35 EST 2011
Author: ychemin
Date: 2011-01-11 16:45:35 -0800 (Tue, 11 Jan 2011)
New Revision: 44969
Added:
   grass/trunk/imagery/i.eb.netrad/i.eb.netrad.html
Removed:
   grass/trunk/imagery/i.eb.netrad/description.html
   grass/trunk/imagery/i.eb.netrad/Makefile
   grass/trunk/imagery/i.eb.netrad/main.c
   grass/trunk/imagery/i.eb.netrad/r_net.c
Ported i.eb.netrad to grass 7
Modified: grass/trunk/imagery/i.eb.netrad/Makefile
--- grass/trunk/imagery/i.eb.netrad/Makefile	2011-01-12 00:42:06 UTC (rev 44968)
+++ grass/trunk/imagery/i.eb.netrad/Makefile	2011-01-12 00:45:35 UTC (rev 44969)
@@ -2,8 +2,8 @@
 PGM = i.eb.netrad
-LIBES = $(GISLIB)
-DEPENDENCIES = $(GISDEP)
+LIBES = $(GISLIB) $(RASTERLIB)
+DEPENDENCIES = $(GISDEP) $(RASTERDEP)
 include $(MODULE_TOPDIR)/include/Make/Module.make
Deleted: grass/trunk/imagery/i.eb.netrad/description.html
--- grass/trunk/imagery/i.eb.netrad/description.html	2011-01-12 00:42:06 UTC (rev 44968)
+++ grass/trunk/imagery/i.eb.netrad/description.html	2011-01-12 00:45:35 UTC (rev 44969)
@@ -1,25 +0,0 @@
-<H2>DESCRIPTION</H2>
-<EM>i.eb.netrad</EM> calculates the net radiation at the time of satellite overpass, the way it is in the SEBAL model of bastiaanssen (1995).
-It takes input of Albedo, NDVI, Surface Skin temperature, time of satellite overpass, surface emissivity, difference of temperature from surface skin and about 2 m height (dT), instantaneous satellite overpass single-way atmospheric transmissivity (tsw), Day of Year (DOY), and sun zenith angle.
-<H2>NOTES</H2>
-In the old methods, dT was taken as flat images (dT=5.0), if you don't have a dT map from ground data, you would want to try something in this line, this is to calculate atmospherical energy balance. In the same way, a standard tsw is used in those equations. Refer to r_net.c for that and for other non-used equations, but stored in there for further research convenience.
-<H2>TODO</H2>
-<H2>SEE ALSO</H2>
-<em>
-<A HREF="i.eb.g0.html">i.eb.g0</A><br>
-<A HREF="i.albedo.html">i.albedo</A><br>
-</em>
-<H2>AUTHORS</H2>
-Yann Chemin, International Rice Research Institute, The Philippines<BR>
-<p>
-<i>Last changed: $Date$</i>
Copied: grass/trunk/imagery/i.eb.netrad/i.eb.netrad.html (from rev 44968, grass/trunk/imagery/i.eb.netrad/description.html)
--- grass/trunk/imagery/i.eb.netrad/i.eb.netrad.html	                        (rev 0)
+++ grass/trunk/imagery/i.eb.netrad/i.eb.netrad.html	2011-01-12 00:45:35 UTC (rev 44969)
@@ -0,0 +1,25 @@
+<H2>DESCRIPTION</H2>
+<EM>i.eb.netrad</EM> calculates the net radiation at the time of satellite overpass, the way it is in the SEBAL model of bastiaanssen (1995).
+It takes input of Albedo, NDVI, Surface Skin temperature, time of satellite overpass, surface emissivity, difference of temperature from surface skin and about 2 m height (dT), instantaneous satellite overpass single-way atmospheric transmissivity (tsw), Day of Year (DOY), and sun zenith angle.
+<H2>NOTES</H2>
+In the old methods, dT was taken as flat images (dT=5.0), if you don't have a dT map from ground data, you would want to try something in this line, this is to calculate atmospherical energy balance. In the same way, a standard tsw is used in those equations. Refer to r_net.c for that and for other non-used equations, but stored in there for further research convenience.
+<H2>TODO</H2>
+<H2>SEE ALSO</H2>
+<em>
+<A HREF="i.eb.g0.html">i.eb.g0</A><br>
+<A HREF="i.albedo.html">i.albedo</A><br>
+</em>
+<H2>AUTHORS</H2>
+Yann Chemin, International Rice Research Institute, The Philippines<BR>
+<p>
+<i>Last changed: $Date$</i>
Modified: grass/trunk/imagery/i.eb.netrad/main.c
--- grass/trunk/imagery/i.eb.netrad/main.c	2011-01-12 00:42:06 UTC (rev 44968)
+++ grass/trunk/imagery/i.eb.netrad/main.c	2011-01-12 00:45:35 UTC (rev 44969)
@@ -7,7 +7,7 @@
  *               as seen in Bastiaanssen (1995) using time of
  *               satellite overpass.
- * COPYRIGHT:    (C) 2006-2008 by the GRASS Development Team
+ * COPYRIGHT:    (C) 2006-2010 by the GRASS Development Team
  *               This program is free software under the GNU General Public
  *   	    	 License (>=v2). Read the file COPYING that comes with GRASS
@@ -20,6 +20,7 @@
 #include <stdlib.h>
 #include <string.h>
 #include <grass/gis.h>
+#include <grass/raster.h>
 #include <grass/glocale.h>
 double r_net(double bbalb, double ndvi, double tempk, double dtair,
 	      double e0, double tsw, double doy, double utc,
@@ -27,123 +28,96 @@
 int main(int argc, char *argv[])
     struct Cell_head cellhd;	/*region+header info */
     char *mapset;		/*mapset name */
     int nrows, ncols;
     int row, col;
     struct GModule *module;
     struct Option *input1, *input2, *input3, *input4, *input5;
     struct Option *input6, *input7, *input8, *input9, *output1;
     struct Flag *flag1;
     struct History history;	/*metadata */
     struct Colors colors;	/*Color rules */
-	/* FMEO Declarations**************** */
     char *name;			/*input raster name */
     char *result;		/*output raster name */
-	/*File Descriptors */
     int infd_albedo, infd_ndvi, infd_tempk, infd_time, infd_dtair;
     int infd_emissivity, infd_tsw, infd_doy, infd_sunzangle;
     int outfd;
     char *albedo, *ndvi, *tempk, *time, *dtair, *emissivity;
     char *tsw, *doy, *sunzangle;
     int i = 0, j = 0;
     void *inrast_albedo, *inrast_ndvi, *inrast_tempk, *inrast_rnet;
     void *inrast_time, *inrast_dtair, *inrast_emissivity, *inrast_tsw;
     void *inrast_doy, *inrast_sunzangle;
     DCELL * outrast;
-    RASTER_MAP_TYPE data_type_output = DCELL_TYPE;
-    RASTER_MAP_TYPE data_type_albedo;
-    RASTER_MAP_TYPE data_type_ndvi;
-    RASTER_MAP_TYPE data_type_tempk;
-    RASTER_MAP_TYPE data_type_time;
-    RASTER_MAP_TYPE data_type_dtair;
-    RASTER_MAP_TYPE data_type_emissivity;
-    RASTER_MAP_TYPE data_type_tsw;
-    RASTER_MAP_TYPE data_type_doy;
-    RASTER_MAP_TYPE data_type_sunzangle;
-	G_gisinit(argv[0]);
+    CELL val1,val2; /*For color range*/
+    G_gisinit(argv[0]);
     module = G_define_module();
-    module->keywords = _("net radiation, energy balance, SEBAL");
+    G_add_keyword(_("net radiation, energy balance, SEBAL"));
+    G_add_keyword(_("energy balance"));
+    G_add_keyword(_("SEBAL"));
     module->description =
 	_("net radiation approximation (Bastiaanssen, 1995)");
 	/* Define the different options */
-	input1 = G_define_standard_option(G_OPT_R_INPUT);
+    input1 = G_define_standard_option(G_OPT_R_INPUT);
     input1->key = _("albedo");
     input1->description = _("Name of the Albedo map [0.0;1.0]");
     input1->answer = _("albedo");
     input2 = G_define_standard_option(G_OPT_R_INPUT);
     input2->key = _("ndvi");
     input2->description = _("Name of the ndvi map [-1.0;+1.0]");
     input2->answer = _("ndvi");
     input3 = G_define_standard_option(G_OPT_R_INPUT);
     input3->key = _("tempk");
     input3->description =
 	_("Name of the Surface temperature map [degree Kelvin]");
     input3->answer = _("tempk");
     input4 = G_define_standard_option(G_OPT_R_INPUT);
     input4->key = _("time");
     input4->description =
 	_("Name of the map of local UTC time of satellite overpass [hh.hhh]");
     input4->answer = _("time");
     input5 = G_define_standard_option(G_OPT_R_INPUT);
     input5->key = _("dtair");
     input5->description =
 	_("Name of the difference of temperature from surface skin to about 2 m height [K]");
     input5->answer = _("dtair");
     input6 = G_define_standard_option(G_OPT_R_INPUT);
     input6->key = _("emissivity");
     input6->description = _("Name of the emissivity map [-]");
     input6->answer = _("emissivity");
     input7 = G_define_standard_option(G_OPT_R_INPUT);
     input7->key = _("tsw");
     input7->description =
 	_("Name of the single-way atmospheric transmissivitymap [-]");
     input7->answer = _("tsw");
     input8 = G_define_standard_option(G_OPT_R_INPUT);
     input8->key = _("doy");
     input8->description = _("Name of the Day Of Year (DOY) map [-]");
     input8->answer = _("doy");
     input9 = G_define_standard_option(G_OPT_R_INPUT);
     input9->key = _("sunzangle");
     input9->description = _("Name of the sun zenith angle map [degrees]");
     input9->answer = _("sunzangle");
     output1 = G_define_standard_option(G_OPT_R_INPUT);
     output1->key = _("rnet");
     output1->description = _("Name of the output rnet layer");
     output1->answer = _("rnet");
-	if (G_parser(argc, argv))
+    if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
     albedo = input1->answer;
     ndvi = input2->answer;
     tempk = input3->answer;
@@ -155,137 +129,43 @@
     sunzangle = input9->answer;
     result = output1->answer;
-	mapset = G_find_cell2(albedo, "");
-    if (mapset == NULL) {
-	G_fatal_error(_("cell file [%s] not found"), albedo);
-    data_type_albedo = G_raster_map_type(albedo, mapset);
-    if ((infd_albedo = G_open_cell_old(albedo, mapset)) < 0)
-	G_fatal_error(_("Cannot open cell file [%s]"), albedo);
-    if (G_get_cellhd(albedo, mapset, &cellhd) < 0)
-	G_fatal_error(_("Cannot read file header of [%s])"), albedo);
-    inrast_albedo = G_allocate_raster_buf(data_type_albedo);
+    /* Open access to image files and allocate row access memory */
+    infd_albedo = Rast_open_old(albedo, "");
+    inrast_albedo = Rast_allocate_d_buf();
+    infd_ndvi = Rast_open_old(ndvi, "");
+    inrast_ndvi = Rast_allocate_d_buf();
-	mapset = G_find_cell2(ndvi, "");
-	G_fatal_error(_("cell file [%s] not found"), ndvi);
-    data_type_ndvi = G_raster_map_type(ndvi, mapset);
-    if ((infd_ndvi = G_open_cell_old(ndvi, mapset)) < 0)
-	G_fatal_error(_("Cannot open cell file [%s]"), ndvi);
-    if (G_get_cellhd(ndvi, mapset, &cellhd) < 0)
-	G_fatal_error(_("Cannot read file header of [%s]"), ndvi);
-    inrast_ndvi = G_allocate_raster_buf(data_type_ndvi);
+    infd_tempk = Rast_open_old(tempk, "");
+    inrast_tempk = Rast_allocate_d_buf();
-	mapset = G_find_cell2(tempk, "");
-	G_fatal_error(_("Cell file [%s] not found"), tempk);
-    data_type_tempk = G_raster_map_type(tempk, mapset);
-    if ((infd_tempk = G_open_cell_old(tempk, mapset)) < 0)
-	G_fatal_error(_("Cannot open cell file [%s]"), tempk);
-    if (G_get_cellhd(tempk, mapset, &cellhd) < 0)
-	G_fatal_error(_("Cannot read file header of [%s]"), tempk);
-    inrast_tempk = G_allocate_raster_buf(data_type_tempk);
+    infd_dtair = Rast_open_old(dtair, "");
+    inrast_dtair = Rast_allocate_d_buf();
-	mapset = G_find_cell2(dtair, "");
-	G_fatal_error(_("Cell file [%s] not found"), dtair);
-    data_type_dtair = G_raster_map_type(dtair, mapset);
-    if ((infd_dtair = G_open_cell_old(dtair, mapset)) < 0)
-	G_fatal_error(_("Cannot open cell file [%s]"), dtair);
-    if (G_get_cellhd(dtair, mapset, &cellhd) < 0)
-	G_fatal_error(_("Cannot read file header of [%s]"), dtair);
-    inrast_dtair = G_allocate_raster_buf(data_type_dtair);
+    infd_time = Rast_open_old(time, "");
+    inrast_time = Rast_allocate_d_buf();
-	mapset = G_find_cell2(time, "");
-	G_fatal_error(_("Cell file [%s] not found"), time);
-    data_type_time = G_raster_map_type(time, mapset);
-    if ((infd_time = G_open_cell_old(time, mapset)) < 0)
-	G_fatal_error(_("Cannot open cell file [%s]"), time);
-    if (G_get_cellhd(time, mapset, &cellhd) < 0)
-	G_fatal_error(_("Cannot read file header of [%s]"), time);
-    inrast_time = G_allocate_raster_buf(data_type_time);
+    infd_emissivity = Rast_open_old(emissivity, "");
+    inrast_emissivity = Rast_allocate_d_buf();
-	mapset = G_find_cell2(emissivity, "");
-	G_fatal_error(_("Cell file [%s] not found"), emissivity);
-    data_type_emissivity = G_raster_map_type(emissivity, mapset);
-    if ((infd_emissivity = G_open_cell_old(emissivity, mapset)) < 0)
-	G_fatal_error(_("Cannot open cell file [%s]"), emissivity);
-    if (G_get_cellhd(emissivity, mapset, &cellhd) < 0)
-	G_fatal_error(_("Cannot read file header of [%s]"), emissivity);
-    inrast_emissivity = G_allocate_raster_buf(data_type_emissivity);
+    infd_tsw = Rast_open_old(tsw, "");
+    inrast_tsw = Rast_allocate_d_buf();
-	mapset = G_find_cell2(tsw, "");
-	G_fatal_error(_("Cell file [%s] not found"), tsw);
-    data_type_tsw = G_raster_map_type(tsw, mapset);
-    if ((infd_tsw = G_open_cell_old(tsw, mapset)) < 0)
-	G_fatal_error(_("Cannot open cell file [%s]"), tsw);
-    if (G_get_cellhd(tsw, mapset, &cellhd) < 0)
-	G_fatal_error(_("Cannot read file header of [%s]"), tsw);
-    inrast_tsw = G_allocate_raster_buf(data_type_tsw);
+    infd_doy = Rast_open_old(doy, "");
+    inrast_doy = Rast_allocate_d_buf();
-	mapset = G_find_cell2(doy, "");
-	G_fatal_error(_("Cell file [%s] not found"), doy);
-    data_type_doy = G_raster_map_type(doy, mapset);
-    if ((infd_doy = G_open_cell_old(doy, mapset)) < 0)
-	G_fatal_error(_("Cannot open cell file [%s]"), doy);
-    if (G_get_cellhd(doy, mapset, &cellhd) < 0)
-	G_fatal_error(_("Cannot read file header of [%s]"), doy);
-    inrast_doy = G_allocate_raster_buf(data_type_doy);
+    infd_sunzangle = Rast_open_old(sunzangle, "");
+    inrast_sunzangle = Rast_allocate_d_buf();
+    nrows = Rast_window_rows();
+    ncols = Rast_window_cols();
-	mapset = G_find_cell2(sunzangle, "");
-	G_fatal_error(_("Cell file [%s] not found"), sunzangle);
-    data_type_sunzangle = G_raster_map_type(sunzangle, mapset);
-    if ((infd_sunzangle = G_open_cell_old(sunzangle, mapset)) < 0)
-	G_fatal_error(_("Cannot open cell file [%s]"), sunzangle);
-    if (G_get_cellhd(sunzangle, mapset, &cellhd) < 0)
-	G_fatal_error(_("Cannot read file header of [%s]"), sunzangle);
-    inrast_sunzangle = G_allocate_raster_buf(data_type_sunzangle);
+    outfd = Rast_open_new(result, DCELL_TYPE);
+    outrast = Rast_allocate_d_buf();
-	G_debug(3, "number of rows %d", cellhd.rows);
-    nrows = G_window_rows();
-    ncols = G_window_cols();
-    outrast = G_allocate_raster_buf(data_type_output);
-	/* Create New raster files */
-	if ((outfd = G_open_raster_new(result, data_type_output)) < 0)
-	G_fatal_error(_("Could not open <%s>"), result);
-	/* Process pixels */
-	for (row = 0; row < nrows; row++)
+    /* Process pixels */
+    for (row = 0; row < nrows; row++)
 	DCELL d;
 	DCELL d_albedo;
 	DCELL d_ndvi;
@@ -296,160 +176,54 @@
 	DCELL d_tsw;
 	DCELL d_doy;
 	DCELL d_sunzangle;
+	/* Display row process percentage */
 	G_percent(row, nrows, 2);
+	/* Load rows for each input image  */
+	Rast_get_d_row(infd_albedo, inrast_albedo, row);
+	Rast_get_d_row(infd_ndvi, inrast_ndvi, row);
+	Rast_get_d_row(infd_tempk, inrast_tempk, row);
+	Rast_get_d_row(infd_dtair, inrast_dtair, row);
+	Rast_get_d_row(infd_time, inrast_time, row);
+	Rast_get_d_row(infd_emissivity, inrast_emissivity, row);
+	Rast_get_d_row(infd_tsw, inrast_tsw, row);
+	Rast_get_d_row(infd_doy, inrast_doy, row);
+	Rast_get_d_row(infd_sunzangle, inrast_sunzangle, row);
-	    /* read input maps */
-	    if (G_get_raster_row
-		(infd_albedo, inrast_albedo, row, data_type_albedo) < 0)
-	    G_fatal_error(_("Could not read from <%s>"), albedo);
-	if (G_get_raster_row(infd_ndvi, inrast_ndvi, row, data_type_ndvi) <
-	     0)
-	    G_fatal_error(_("Could not read from <%s>"), ndvi);
-	if (G_get_raster_row(infd_tempk, inrast_tempk, row, data_type_tempk)
-	     < 0)
-	    G_fatal_error(_("Could not read from <%s>"), tempk);
-	if (G_get_raster_row(infd_dtair, inrast_dtair, row, data_type_dtair)
-	     < 0)
-	    G_fatal_error(_("Could not read from <%s>"), dtair);
-	if (G_get_raster_row(infd_time, inrast_time, row, data_type_time) <
-	     0)
-	    G_fatal_error(_("Could not read from <%s>"), time);
-	     (infd_emissivity, inrast_emissivity, row,
-	      data_type_emissivity) < 0)
-	    G_fatal_error(_("Could not read from <%s>"), emissivity);
-	if (G_get_raster_row(infd_tsw, inrast_tsw, row, data_type_tsw) < 0)
-	    G_fatal_error(_("Could not read from <%s>"), tsw);
-	if (G_get_raster_row(infd_doy, inrast_doy, row, data_type_doy) < 0)
-	    G_fatal_error(_("Could not read from <%s>"), doy);
-	     (infd_sunzangle, inrast_sunzangle, row, data_type_sunzangle) < 0)
-	    G_fatal_error(_("Could not read from <%s>"), sunzangle);
-	    /*process the data */
-	    for (col = 0; col < ncols; col++)
-	    switch (data_type_albedo) {
-	    case CELL_TYPE:
-		d_albedo = (double)((CELL *) inrast_albedo)[col];
-		break;
-	    case FCELL_TYPE:
-		d_albedo = (double)((FCELL *) inrast_albedo)[col];
-		break;
-	    case DCELL_TYPE:
-		d_albedo = (double)((DCELL *) inrast_albedo)[col];
-		break;
+        /*process the data */
+        for (col = 0; col < ncols; col++)
+            d_albedo = (double)((DCELL *) inrast_albedo)[col];
+            d_ndvi = (double)((DCELL *) inrast_ndvi)[col];
+            d_tempk = (double)((DCELL *) inrast_tempk)[col];
+            d_dtair = (double)((DCELL *) inrast_dtair)[col];
+            d_time = (double)((DCELL *) inrast_time)[col];
+            d_emissivity = (double)((DCELL *) inrast_emissivity)[col];
+            d_tsw = (double)((DCELL *) inrast_tsw)[col];
+            d_doy = (double)((DCELL *) inrast_doy)[col];
+            d_sunzangle = (double)((DCELL *) inrast_sunzangle)[col];
+            /* process NULL Values */
+	    if (Rast_is_d_null_value(&d_albedo) ||
+	         Rast_is_d_null_value(&d_ndvi) ||
+		 Rast_is_d_null_value(&d_tempk) ||
+		 Rast_is_d_null_value(&d_dtair) ||
+		 Rast_is_d_null_value(&d_time) ||
+		 Rast_is_d_null_value(&d_emissivity) ||
+		 Rast_is_d_null_value(&d_tsw) ||
+		 Rast_is_d_null_value(&d_doy) ||
+		 Rast_is_d_null_value(&d_sunzangle)) {
+		Rast_set_d_null_value(&outrast[col], 1);
-	    switch (data_type_ndvi) {
-	    case CELL_TYPE:
-		d_ndvi = (double)((CELL *) inrast_ndvi)[col];
-		break;
-	    case FCELL_TYPE:
-		d_ndvi = (double)((FCELL *) inrast_ndvi)[col];
-		break;
-	    case DCELL_TYPE:
-		d_ndvi = ((DCELL *) inrast_ndvi)[col];
-		break;
-	    switch (data_type_tempk) {
-	    case CELL_TYPE:
-		d_tempk = (double)((CELL *) inrast_tempk)[col];
-		break;
-	    case FCELL_TYPE:
-		d_tempk = (double)((FCELL *) inrast_tempk)[col];
-		break;
-	    case DCELL_TYPE:
-		d_tempk = (double)((DCELL *) inrast_tempk)[col];
-		break;
-	    switch (data_type_dtair) {
-	    case CELL_TYPE:
-		d_dtair = (double)((CELL *) inrast_dtair)[col];
-		break;
-	    case FCELL_TYPE:
-		d_dtair = (double)((FCELL *) inrast_dtair)[col];
-		break;
-	    case DCELL_TYPE:
-		d_dtair = (double)((DCELL *) inrast_dtair)[col];
-		break;
-	    switch (data_type_time) {
-	    case CELL_TYPE:
-		d_time = (double)((CELL *) inrast_time)[col];
-		break;
-	    case FCELL_TYPE:
-		d_time = (double)((FCELL *) inrast_time)[col];
-		break;
-	    case DCELL_TYPE:
-		d_time = (double)((DCELL *) inrast_time)[col];
-		break;
-	    switch (data_type_emissivity) {
-	    case CELL_TYPE:
-		d_emissivity = (double)((CELL *) inrast_emissivity)[col];
-		break;
-	    case FCELL_TYPE:
-		d_emissivity = (double)((FCELL *) inrast_emissivity)[col];
-		break;
-	    case DCELL_TYPE:
-		d_emissivity = (double)((DCELL *) inrast_emissivity)[col];
-		break;
-	    switch (data_type_tsw) {
-	    case CELL_TYPE:
-		d_tsw = (double)((CELL *) inrast_tsw)[col];
-		break;
-	    case FCELL_TYPE:
-		d_tsw = (double)((FCELL *) inrast_tsw)[col];
-		break;
-	    case DCELL_TYPE:
-		d_tsw = (double)((DCELL *) inrast_tsw)[col];
-		break;
-	    switch (data_type_doy) {
-	    case CELL_TYPE:
-		d_doy = (double)((CELL *) inrast_doy)[col];
-		break;
-	    case FCELL_TYPE:
-		d_doy = (double)((FCELL *) inrast_doy)[col];
-		break;
-	    case DCELL_TYPE:
-		d_doy = (double)((DCELL *) inrast_doy)[col];
-		break;
-	    switch (data_type_sunzangle) {
-	    case CELL_TYPE:
-		d_sunzangle = (double)((CELL *) inrast_sunzangle)[col];
-		break;
-	    case FCELL_TYPE:
-		d_sunzangle = (double)((FCELL *) inrast_sunzangle)[col];
-		break;
-	    case DCELL_TYPE:
-		d_sunzangle = (double)((DCELL *) inrast_sunzangle)[col];
-		break;
-	    if (G_is_d_null_value(&d_albedo) || G_is_d_null_value(&d_ndvi)
-		 || G_is_d_null_value(&d_tempk) ||
-		 G_is_d_null_value(&d_dtair) || G_is_d_null_value(&d_time)
-		 || G_is_d_null_value(&d_emissivity) ||
-		 G_is_d_null_value(&d_tsw) || G_is_d_null_value(&d_doy) ||
-		 G_is_d_null_value(&d_sunzangle)) {
-		G_set_d_null_value(&outrast[col], 1);
 	    else {
-		    /* calculate the net radiation      */
-		    d =
-		    r_net(d_albedo, d_ndvi, d_tempk, d_dtair, d_emissivity,
-			  d_tsw, d_doy, d_time, d_sunzangle);
-		outrast[col] = d;
+		 /* calculate the net radiation      */
+		 d = r_net(d_albedo, d_ndvi, d_tempk, d_dtair, d_emissivity, d_tsw, d_doy, d_time, d_sunzangle);
+		 outrast[col] = d;
-	if (G_put_raster_row(outfd, outrast, data_type_output) < 0)
-	    G_fatal_error(_("Cannot write to output raster file"));
+	Rast_put_d_row(outfd, outrast);
     G_free(inrast_albedo);
     G_free(inrast_ndvi);
     G_free(inrast_tempk);
@@ -459,26 +233,28 @@
     G_free(inrast_tsw);
     G_free(inrast_doy);
     G_free(inrast_sunzangle);
-    G_close_cell(infd_albedo);
-    G_close_cell(infd_ndvi);
-    G_close_cell(infd_tempk);
-    G_close_cell(infd_dtair);
-    G_close_cell(infd_time);
-    G_close_cell(infd_emissivity);
-    G_close_cell(infd_tsw);
-    G_close_cell(infd_doy);
-    G_close_cell(infd_sunzangle);
+    Rast_close(infd_albedo);
+    Rast_close(infd_ndvi);
+    Rast_close(infd_tempk);
+    Rast_close(infd_dtair);
+    Rast_close(infd_time);
+    Rast_close(infd_emissivity);
+    Rast_close(infd_tsw);
+    Rast_close(infd_doy);
+    Rast_close(infd_sunzangle);
     G_free(outrast);
-    G_close_cell(outfd);
+    Rast_close(outfd);
-	/* Colors in grey shade */
-	G_init_colors(&colors);
-    G_add_color_rule(0, 0, 0, 0, 900, 255, 255, 255, &colors);
+    /* Colors in grey shade */
+    Rast_init_colors(&colors);
+    val1=0;
+    val2=900;
+    Rast_add_c_color_rule(&val1, 0, 0, 0, &val2, 255, 255, 255, &colors);
-	/* Metadata */
-	G_short_history(result, "raster", &history);
-    G_command_history(&history);
-    G_write_history(result, &history);
+    /* Metadata */
+    Rast_short_history(result, "raster", &history);
+    Rast_command_history(&history);
+    Rast_write_history(result, &history);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/imagery/i.eb.netrad/r_net.c
--- grass/trunk/imagery/i.eb.netrad/r_net.c	2011-01-12 00:42:06 UTC (rev 44968)
+++ grass/trunk/imagery/i.eb.netrad/r_net.c	2011-01-12 00:45:35 UTC (rev 44969)
@@ -8,39 +8,37 @@
 	      double sunzangle)
-	/* Tsw =  atmospheric transmissivity single-way (~0.7 -) */
-	/* DOY = Day of Year */
-	/* utc = UTC time of sat overpass */
-	/* sunzangle = sun zenith angle at sat. overpass */
-	/* tair = air temperature (approximative, or met.station) */
+    /* Tsw =  atmospheric transmissivity single-way (~0.7 -) */
+    /* DOY = Day of Year */
+    /* utc = UTC time of sat overpass */
+    /* sunzangle = sun zenith angle at sat. overpass */
+    /* tair = air temperature (approximative, or met.station) */
     double Kin = 0.0, Lin = 0.0, Lout = 0.0, Lcorr = 0.0, result = 0.0;
     double temp = 0.0, ds = 0.0, e_atm = 0.0, delta = 0.0;
     double tsw_for_e_atm = 0.7;	/*Special tsw, consider it a coefficient */
-	/* Atmospheric emissivity (Bastiaanssen, 1995) */
-	e_atm = 1.08 * pow(-log(tsw), 0.265);
+    /* Atmospheric emissivity (Bastiaanssen, 1995) */
+    e_atm = 1.08 * pow(-log(tsw), 0.265);
-	/* Atmospheric emissivity (Pawan, 2004) */
-	/*      e_atm   = 0.85 * pow(-log(tsw),0.09); */
+    /* Atmospheric emissivity (Pawan, 2004) */
+    /*      e_atm   = 0.85 * pow(-log(tsw),0.09); */
-	/*      ds = 1.0 + 0.01672 * sin(2*PI*(doy-93.5)/365); */
-	ds = 1.0 / pow((1 + 0.033 * cos(2 * PI * doy / 365)), 2);
+    /*      ds = 1.0 + 0.01672 * sin(2*PI*(doy-93.5)/365); */
+    ds = 1.0 / pow((1 + 0.033 * cos(2 * PI * doy / 365)), 2);
     delta = 0.4093 * sin((2 * PI * doy / 365) - 1.39);
-	/* Kin is the shortwave incoming radiation */
-	Kin = 1358.0 * (cos(sunzangle * PI / 180) * tsw / (ds * ds));
+    /* Kin is the shortwave incoming radiation */
+    Kin = 1358.0 * (cos(sunzangle * PI / 180) * tsw / (ds * ds));
-	/* Lin is incoming longwave radiation */
-	Lin = (e_atm) * 5.67 * pow(10, -8) * pow((tempk - dtair), 4);
+    /* Lin is incoming longwave radiation */
+    Lin = (e_atm) * 5.67 * pow(10, -8) * pow((tempk - dtair), 4);
-	/* Lout is surface grey body emission in Longwave spectrum */
-	Lout = e0 * 5.67 * pow(10, -8) * pow(tempk, 4);
+    /* Lout is surface grey body emission in Longwave spectrum */
+    Lout = e0 * 5.67 * pow(10, -8) * pow(tempk, 4);
-	/* Lcorr is outgoing longwave radiation "reflected" by the emissivity */
-	Lcorr = (1.0 - e0) * Lin;
+    /* Lcorr is outgoing longwave radiation "reflected" by the emissivity */
+    Lcorr = (1.0 - e0) * Lin;
     result = (1.0 - bbalb) * Kin + Lin - Lout - Lcorr;
     return result;
