[GRASS-SVN] r45013 - grass/trunk/gui/wxpython/docs
svn_grass at osgeo.org
Thu Jan 13 10:30:25 EST 2011
Author: martinl
Date: 2011-01-13 07:30:25 -0800 (Thu, 13 Jan 2011)
New Revision: 45013
grass/trunk/gui/wxpython/docs/wxGUI.Modeler.html
grass/trunk/gui/wxpython/docs/wxGUI.Nviz.html
grass/trunk/gui/wxpython/docs/wxGUI.html
fix man compilation error
Modified: grass/trunk/gui/wxpython/docs/wxGUI.Modeler.html
--- grass/trunk/gui/wxpython/docs/wxGUI.Modeler.html 2011-01-13 14:10:54 UTC (rev 45012)
+++ grass/trunk/gui/wxpython/docs/wxGUI.Modeler.html 2011-01-13 15:30:25 UTC (rev 45013)
@@ -35,7 +35,7 @@
<p>
Other wxGUI components:<br>
-<em
+<em>
<a href="wxGUI.Vector_Digitizer.html">Vector Digitizer</a><br>
<a href="wxGUI.Attribute_Table_Manager.html">Attribute Table Manager</a><br>
<a href="wxGUI.Nviz.html">3D Viewer</a><br>
Modified: grass/trunk/gui/wxpython/docs/wxGUI.Nviz.html
--- grass/trunk/gui/wxpython/docs/wxGUI.Nviz.html 2011-01-13 14:10:54 UTC (rev 45012)
+++ grass/trunk/gui/wxpython/docs/wxGUI.Nviz.html 2011-01-13 15:30:25 UTC (rev 45013)
@@ -300,7 +300,7 @@
<p>
-<em
+<em>
<a href="wxGUI.Modeler.html">Graphical Modeler</a><br>
Modified: grass/trunk/gui/wxpython/docs/wxGUI.html
--- grass/trunk/gui/wxpython/docs/wxGUI.html 2011-01-13 14:10:54 UTC (rev 45012)
+++ grass/trunk/gui/wxpython/docs/wxGUI.html 2011-01-13 15:30:25 UTC (rev 45013)
@@ -106,112 +106,114 @@
<dl>
-<dt><img src="icons/grass2/monitor-create.png">
-<em>Start new display / create new workspace</em></dt>
-<dd>Opens a new map display and creates empty layer tree tab in Layer Manager or creates new workspace for the current layer tree.</dd>
-<dl>
- <em>Start new map display</em></dt>
- <dd>Opens a new map display and creates empty layer tree tab in Layer Manager.</dd>
- <dt><img src="icons/grass2/create.png">
- <em>Create new workspace</em></dt>
- <dd>Removes all layers from the layer tree and creates a new, empty tree
- where new layers can be added.</dd>
-</dl>
+ <em>Start new display / create new workspace</em></dt>
+ <dd>Opens a new map display and creates empty layer tree tab in Layer
+ Manager or creates new workspace for the current layer tree.
-<dt><img src="icons/grass2/layer-open.png">
- <em>Load / import map layers into workspace</em></dt>
-<dd>Loads or imports selected raster or vector maps into current layer tree.</dd>
-<dl>
+ <dl>
+ <dt><img src="icons/grass2/monitor-create.png">
+ <em>Start new map display</em></dt>
+ <dd>Opens a new map display and creates empty layer tree tab in Layer Manager.</dd>
+ <dt><img src="icons/grass2/create.png">
+ <em>Create new workspace</em></dt>
+ <dd>Removes all layers from the layer tree and creates a new, empty tree
+ where new layers can be added.</dd>
+ </dl>
+ </dd>
- <em>Load map layers into workspace</em></dt>
- <dd>Loads selected raster or vector maps into current layer tree.</dd>
- <dt><img src="icons/grass2/layer-import.png">
- <em>Import raster data</em></dt>
- <dd>Import selected raster data into GRASS and load them into current layer tree.</dd>
- <em>Import vector data</em></dt>
- <dd>Import selected vector data into GRASS and load them into current layer tree.</dd>
- <em>Link external raster data</em></dt>
- <dd>Link selected external raster data as GRASS raster maps and load them into current layer tree.</dd>
- <em>Link external vector data</em></dt>
- <dd>Link selected external vector data as GRASS vector maps and load them into current layer tree.</dd>
-</dl>
-<dt><img src="icons/grass2/open.png">
- <em>Open existing workspace file</em></dt>
-<dd>Opens an previously saved workspace file, containing a set of display
-layers and their option settings.</dd>
-<dt><img src="icons/grass2/save.png">
- <em>Save current workspace to file</em></dt>
-<dd>Saves current set of layers and their options to a workspace
- file.</dd>
-<dt><img src="icons/grass2/layer-raster-add.png">
- <em>Add raster map layer</em></dt>
-<dd>Adds raster map to layer tree, see <em><a href="d.rast.html">d.rast</a></em>.
-</dd>
-<dt><img src="icons/grass2/layer-raster-more.png">
-<em>Add various raster map layers (RGB, HIS, shaded relief...)</em></dt>
-<dd>Opens a dropdown menu that allows user to select to:<br>
- <dl>
- <dt><img src="icons/grass2/layer-raster3d-add.png">
- <em>Add 3D raster map layer</em></dt>
- <dd>Adds 3D raster map to layer tree.</dd>
- </dd>
+ <em>Load / import map layers into workspace</em></dt>
+ <dd>Loads or imports selected raster or vector maps into current layer tree.
+ <dl>
+ <dt><img src="icons/grass2/layer-open.png">
+ <em>Load map layers into workspace</em></dt>
+ <dd>Loads selected raster or vector maps into current layer tree.</dd>
+ <dt><img src="icons/grass2/layer-import.png">
+ <em>Import raster data</em></dt>
+ <dd>Import selected raster data into GRASS and load them into current layer tree.</dd>
+ <em>Import vector data</em></dt>
+ <dd>Import selected vector data into GRASS and load them into current layer tree.</dd>
+ <em>Link external raster data</em></dt>
+ <dd>Link selected external raster data as GRASS raster maps and load them into current layer tree.</dd>
+ <em>Link external vector data</em></dt>
+ <dd>Link selected external vector data as GRASS vector maps and load them into current layer tree.</dd>
+ </dl>
+ </dd>
+ <dt><img src="icons/grass2/open.png">
+ <em>Open existing workspace file</em></dt>
+ <dd>Opens an previously saved workspace file, containing a set of display
+ layers and their option settings.</dd>
+ <dt><img src="icons/grass2/save.png">
+ <em>Save current workspace to file</em></dt>
+ <dd>Saves current set of layers and their options to a workspace
+ file.</dd>
+ <dt><img src="icons/grass2/layer-raster-add.png">
+ <em>Add raster map layer</em></dt>
+ <dd>Adds raster map to layer tree, see <em><a href="d.rast.html">d.rast</a></em>.
+ </dd>
+ <dt><img src="icons/grass2/layer-raster-more.png">
+ <em>Add various raster map layers (RGB, HIS, shaded relief...)</em></dt>
+ <dd>Opens a dropdown menu that allows user to select to:
- <dt><img src="icons/grass2/layer-rgb-add.png">
+ <dl>
+ <dt><img src="icons/grass2/layer-raster3d-add.png">
+ <em>Add 3D raster map layer</em></dt>
+ <dd>Adds 3D raster map to layer tree.</dd>
+ <dt><img src="icons/grass2/layer-rgb-add.png">
<em>Add RGB raster layer</em></dt>
<dd>Combines and displays three raster maps defined as red, green,
- and blue channels to create an RGB color map,
- see <em><a href="d.rgb.html">d.rgb</a></em>.</dd>
- <dt><img src="icons/grass2/layer-his-add.png">
+ and blue channels to create an RGB color map,
+ see <em><a href="d.rgb.html">d.rgb</a></em>.</dd>
+ <dt><img src="icons/grass2/layer-his-add.png">
<em>Add HIS raster layer</em></dt>
<dd>Combines and displays two or three raster maps defined as hue,
intensity, and (optionally) saturation channels to create a color map,
see <em><a href="d.his.html">d.his</a></em>.</dd>
- <dt><img src="icons/grass2/layer-shaded-relief-add.png">
+ <dt><img src="icons/grass2/layer-shaded-relief-add.png">
<em>Add shaded relief raster map layer </em></dt>
<dd>Adds shaded relief raster map layer,
see <em><a href="d.shadedmap.html">d.shadedmap</a></em>.</dd>
- <dt><img src="icons/grass2/layer-aspect-arrow-add.png">
+ <dt><img src="icons/grass2/layer-aspect-arrow-add.png">
<em>Add raster arrows layer</em></dt>
<dd>Adds map of raster cells with directional arrows drawn. Arrow
direction and length are determined by separate aspect/directional map
and (optional) slope/intensity map,
see <em><a href="d.rast.arrow.html">d.rast.arrow</a></em>.</dd>
- <dt><img src="icons/grass2/layer-cell-cats-add.png">
+ <dt><img src="icons/grass2/layer-cell-cats-add.png">
<em>Add raster numbers layer</em></dt>
<dd>Adds map of raster cells with numbers representing the cell values,
see <em><a href="d.rast.num.html">d.rast.num</a></em>.</dd>
- </dl>
-<dt><img src="icons/grass2/layer-vector-add.png">
-<em>Add vector map layer</em></dt>
-<dd>Adds a vector map layer, see <em><a href="d.vect.html">d.vect</a></em>.
-</dd>
-<dt><img src="icons/grass2/layer-vector-more.png">
-<em>Add various vector map layers (thematic, chart...)</em></dt>
- <dl>
- <dt><img src="icons/grass2/layer-vector-thematic-add.png">
+ </dl>
+ </dd>
+ <dt><img src="icons/grass2/layer-vector-add.png">
+ <em>Add vector map layer</em></dt>
+ <dd>Adds a vector map layer,
+ see <em><a href="d.vect.html">d.vect</a></em>.</dd>
+ <dt><img src="icons/grass2/layer-vector-more.png">
+ <em>Add various vector map layers (thematic, chart...)</em></dt>
+ <dl>
+ <dt><img src="icons/grass2/layer-vector-thematic-add.png">
<em>Add thematic area (choropleth) map layer
(for all vector types)</em></dt>
<dd>Adds layer for thematic display values from a numeric attribute
@@ -224,7 +226,7 @@
printing,
see <em><a href="d.vect.thematic.html">d.vect.thematic</a></em>.</dd>
- <dt><img src="icons/grass2/layer-vector-chart-add.png">
+ <dt><img src="icons/grass2/layer-vector-chart-add.png">
<em>Add thematic chart layer (for vector points)</em></dt>
<dd>Adds layer in which pie or bar charts can be automatically created
at vector point locations. Charts display values from selected columns
@@ -232,45 +234,44 @@
and attributes to chart, chart colors, and chart size (fixed or based
on attribute column),
see <em><a href="d.vect.chart.html">d.vect.chart</a></em>.</dd>
- </dl>
+ </dl>
+ </dd>
+ <dt><img src="icons/grass2/layer-group-add.png">
+ <em>Add group</em></dt>
+ <dd>Adds an empty group. Layers can then be added to the group.</dd>
+ <dt><img src="icons/grass2/layer-more.png">
+ <em>Add grid or vector labels overlay</em></dt>
+ <dl>
+ <dt><img src="icons/grass2/layer-grid-add.png">
+ <em>Add overlay grids and lines</em></dt>
+ <dd>Adds layer to display regular grid (for all locations)
+ see <em><a href="d.grid.html">d.grid</a></em></dd>
+ <dt><img src="icons/grass2/layer-label-add.png">
+ <em>Add labels layer for vector objects (from existing labels file)</em></dt>
+ <dd>Add a layer of text from a labels file for vector objects
+ created with the <em><a href="v.label.html">v.label</a></em> module.
+ A labels file can also be created with a text editor,
+ see <em><a href="d.labels.html">d.labels</a></em>.</dd>
+ <dt><img src="icons/grass/module-d.geodesic.gif">
+ <em>Add geodesic line layer</em></dt>
+ <dd>Add layer to display geodesic line for latitude/longitude locations only,
+ see <em><a href="d.geodesic.html">d.geodesic</a></em></dd>
+ <em>Add rhumbline layer</em>
+ <dd>Add layer to display rhumblines (for latitude/longitude locations only),
+ see <em><a href="d.rhumbline.html">d.rhumbline</a></em>.</dd>
-<dt><img src="icons/grass2/layer-group-add.png">
-<em>Add group</em></dt>
-<dd>Adds an empty group. Layers can then be added to the group.</dd>
-<dt><img src="icons/grass2/layer-more.png">
- <em>Add grid or vector labels overlay</em></dt>
- <dl>
- <dt><img src="icons/grass2/layer-grid-add.png">
- <em>Add overlay grids and lines</em></dt>
- <dd>Adds layer to display regular grid (for all locations)
- see <em><a href="d.grid.html">d.grid</a></em></dd>
- <dt><img src="icons/grass2/layer-label-add.png">
- <em>Add labels layer for vector objects (from existing labels file)</em></dt>
- <dd>Add a layer of text from a labels file for vector objects
- created with the <em><a href="v.label.html">v.label</a></em> module.
- A labels file can also be created with a text editor,
- see <em><a href="d.labels.html">d.labels</a></em>.</dd>
- <dt><img src="icons/grass/module-d.geodesic.gif">
- <em>Add geodesic line layer</em></dt>
- <dd>Add layer to display geodesic line for latitude/longitude locations only,
- see <em><a href="d.geodesic.html">d.geodesic</a></em></dd>
- <em>Add rhumbline layer</em>
- <dd>Add layer to display rhumblines (for latitude/longitude locations only),
- see <em><a href="d.rhumbline.html">d.rhumbline</a></em>.</dd>
- <dt><img src="icons/grass2/layer-command-add.png">
- <em>Add command layer</em></dt>
- <dd>Adds a layer in which a GRASS GIS command or command list can be entered.
- For a command list use the semi-colon (";") symbol as a separator.
- For example:
+ <dt><img src="icons/grass2/layer-command-add.png">
+ <em>Add command layer</em></dt>
+ <dd>Adds a layer in which a GRASS GIS command or command list can be entered.
+ For a command list use the semi-colon (";") symbol as a separator.
+ For example:
<div class="code"><pre>
d.rast soils;d.rast -o roads;d.vect streams col=blue
</pre></div>
@@ -280,29 +281,28 @@
d.text text=Population\ density
</pre></div>
+ </dl>
</dd>
- </dl>
+ <dt><img src="icons/grass2/layer-remove.png">
+ <em>Delete selected layer</em></dt>
+ <dd>Removes selected map layer or map layer group from layer tree.</dd>
+ <dt><img src="icons/grass2/edit.png">
+ <em>Edit vector maps</em></dt>
+ <dd>Opens <em><a href="wxGUI.Vector_Digitizer.html">vector digitizer</a></em> to allow editing selected vector map.</dd>
+ <dt><img src="icons/grass2/table.png">
+ <em>Show attribute table</em></dt>
+ <dd>Opens <em><a href="wxGUI.Attribute_Table_Manager.html">attribute table manager</a></em> for selected vector map.</dd>
+ <dt><img src="icons/grass2/modeler-main.png">
+ <em>Start Graphical Modeler</em></dt>
+ <dd>Opens <em><a href="wxGUI.Modeler.html">graphical modeler</a></em> to create models and run them.</dd>
+ <dt><img src="icons/grass2/settings.png">
+ <em>Show GUI settings</em></dt>
+ <dd>Opens dialog to change GUI preferences.</dd>
-<dt><img src="icons/grass2/layer-remove.png">
- <em>Delete selected layer</em></dt>
-<dd>Removes selected map layer or map layer group from layer tree.</dd>
-<dt><img src="icons/grass2/edit.png">
- <em>Edit vector maps</em></dt>
-<dd>Opens <em><a href="wxGUI.Vector_Digitizer.html">vector digitizer</a></em> to allow editing selected vector map.</dd>
-<dt><img src="icons/grass2/table.png">
- <em>Show attribute table</em></dt>
-<dd>Opens <em><a href="wxGUI.Attribute_Table_Manager.html">attribute table manager</a></em> for selected vector map.</dd>
-<dt><img src="icons/grass2/modeler-main.png">
- <em>Start Graphical Modeler</em></dt>
-<dd>Opens <em><a href="wxGUI.Modeler.html">graphical modeler</a></em> to create models and run them.</dd>
-<dt><img src="icons/grass2/settings.png">
- <em>Show GUI settings</em></dt>
-<dd>Opens dialog to change GUI preferences.</dd>
</dl>
<h4>Key shortcuts</h4>
@@ -386,175 +386,190 @@
<dl>
-<dt><img src="icons/grass2/show.png">
- <em>Display map</em></dt>
-<dd>Displays all active layers from layer tree and re-renders for display
-any layers that have changed since the last time the display was updated,
-including layers added or removed.</dd>
+ <dt><img src="icons/grass2/show.png">
+ <em>Display map</em></dt>
+ <dd>Displays all active layers from layer tree and re-renders for display
+ any layers that have changed since the last time the display was updated,
+ including layers added or removed.</dd>
+ <dt><img src="icons/grass2/layer-redraw.png">
+ <em>Re-render map</em></dt>
+ <dd>Re-renders all active layers regardless of whether they have changed
+ or not.</dd>
+ <dt><img src="icons/grass2/erase.png">
+ <em>Erase display</em></dt>
+ <dd>Erases the currently selected map display to a white background.
+ see <em><a href="d.erase.html">d.erase</a>, <a href="d.frame.html">d.frame
+ -e</a></em>.</dd>
+ <dt><img src="icons/grass2/pointer.png">
+ <em>Pointer</em></dt>
+ <dd>Select arrow cursor for map display.</dd>
+ <dt><img src="icons/grass2/info.png">
+ <em>Query raster/vector maps</em></dt>
+ <dl>
+ <dt><em>Display mode</em></dt>
+ <dd>Query selected raster, RGB raster (all three map channels will be
+ queried), or vector map(s) using the mouse. Map(s) must be selected
+ before query. Vector charts and thematic vector maps cannot be
+ queried. The results of the query will be displayed in the console window,
+ see <em><a href="r.what.html">r.what</a>, <a href="v.what.html">v.what</a></em>.</dd>
+ <dt><em>Edit mode</em></dt>
+ <dd>Query selected vector map in edit mode. The results of the query
+ will be displayed in a form that permits editing of the queried vector
+ attributes.</dd>
+ </dl>
+ </dd>
+ <dt><img src="icons/grass2/pan.png">
+ <em>Pan</em></dt>
+ <dd>Interactive selection of a new center of view in the active
+ display monitor. Drag the pan cursor while pressing the left mouse
+ button to pan. Panning changes the location of the region displayed
+ but not the size of the area displayed or the resolution. Panning
+ does <em>not</em> affect the computational region for other GIS
+ processes, see <em><a href="g.region.html">g.region</a></em>.</dd>
+ <dt><img src="icons/grass2/zoom-in.png">
+ <em>Zoom in</em></dt>
+ <dd>Interactive zooming with the mouse in the active display monitor.
+ Drawing a box or just click with the mouse (left button) and zoom-in
+ cursor causes the display to zoom in so that the area defined by the
+ box fills the display. The map resolution is not changed. Clicking
+ with the zoom-in cursor causes the display to zoom in by 30%, centered
+ on the point where the mouse is clicked. Zooming resets the display
+ region extents (both size and location of area displayed). It
+ <dt><img src="icons/grass2/zoom-out.png">
+ <em>Zoom out</em></dt>
+ Drawing a box or just click with the mouse (left button) and zoom-out
+ cursor causes the display to zoom in so that the area displayed
+ shrinks to fill the area defined by the box. The map resolution is not
+ changed. Clicking with the zoom-out cursor causes the display to zoom
+ out by 30%, centered on the point where the mouse is clicked. Zooming
+ resets the display region extents (both size and location of area
+ displayed). It does <em>not</em> affect the computational region for
+ other GIS processes,
+ see <em><a href="g.region.html">g.region</a></em>.</dd>
+ <dt><img src="icons/grass2/zoom-extent.png">
+ <em>Zoom to selected map(s)</em></dt>
+ <dd>Set zoom extent based on selected raster or vector maps. Zooming
+ for other GIS processes,
-<dt><img src="icons/grass2/layer-redraw.png">
- <em>Re-render map</em></dt>
-<dd>Re-renders all active layers regardless of whether they have changed
-or not.</dd>
-<dt><img src="icons/grass2/erase.png">
- <em>Erase display</em></dt>
-<dd>Erases the currently selected map display to a white background.
-see <em><a href="d.erase.html">d.erase</a>, <a href="d.frame.html">d.frame
--e</a></em>.</dd>
-<dt><img src="icons/grass2/pointer.png">
- <em>Pointer</em></dt>
-<dd>Select arrow cursor for map display.</dd>
-<dt><img src="icons/grass2/info.png">
- <em>Query raster/vector maps</em></dt>
- <ul>
- <li>Query selected raster, RGB raster (all three map channels will be
-queried), or vector map(s) using the mouse. Map(s) must be selected
-before query. Vector charts and thematic vector maps cannot be
-queried. The results of the query will be displayed in the console window,
-see <em><a href="r.what.html">r.what</a>, <a href="v.what.html">v.what</a></em>.</li>
- <li>Query selected vector map in edit mode. The results of the query
- will be displayed in a form that permits editing of the queried vector
- attributes.</li>
- </ul>
-<dt><img src="icons/grass2/pan.png">
- <em>Pan</em></dt>
-<dd>Interactive selection of a new center of view in the active
-display monitor. Drag the pan cursor while pressing the left mouse
-button to pan. Panning changes the location of the region displayed
-but not the size of the area displayed or the resolution. Panning
-does <em>not</em> affect the computational region for other GIS
-processes, see <em><a href="g.region.html">g.region</a></em>.</dd>
-<dt><img src="icons/grass2/zoom-in.png">
- <em>Zoom in</em></dt>
-<dd>Interactive zooming with the mouse in the active display monitor.
-Drawing a box or just click with the mouse (left button) and zoom-in
-cursor causes the display to zoom in so that the area defined by the
-box fills the display. The map resolution is not changed. Clicking
-with the zoom-in cursor causes the display to zoom in by 30%, centered
-on the point where the mouse is clicked. Zooming resets the display
-region extents (both size and location of area displayed). It
-<dt><img src="icons/grass2/zoom-out.png">
- <em>Zoom out</em></dt>
-Drawing a box or just click with the mouse (left button) and zoom-out
-cursor causes the display to zoom in so that the area displayed
-shrinks to fill the area defined by the box. The map resolution is not
-changed. Clicking with the zoom-out cursor causes the display to zoom
-out by 30%, centered on the point where the mouse is clicked. Zooming
-resets the display region extents (both size and location of area
-displayed). It does <em>not</em> affect the computational region for
-other GIS processes,
-see <em><a href="g.region.html">g.region</a></em>.</dd>
-<dt><img src="icons/grass2/zoom-last.png">
- <em>Return to previous zoom</em></dt>
-<dd>Returns to the previous zoom extent. Up to 10 levels of zoom back are
-maintained, see <em><a href="g.region.html">g.region</a></em>.</dd>
-<dt><img src="icons/grass2/zoom-more.png">
- <em>Zoom options</em></dt>
-<dd>Opens a dropdown menu that allows user to:<br>
- <ul>
- <li>Zoom to match the extents of a selected map</li>
- <li>Zoom to match the computational region (set with <em>g.region</em>)</li>
- <li>Zoom to match the extents of the default region</li>
- <li>Zoom to match the extents of a saved region</li>
- <li>Set computational region (the mapset's <tt>WIND</tt> file) to match the
+ <dt><img src="icons/grass2/zoom-last.png">
+ <em>Return to previous zoom</em></dt>
+ <dd>Returns to the previous zoom extent. Up to 10 levels of zoom back are
+ maintained, see <em><a href="g.region.html">g.region</a></em>.</dd>
+ <dt><img src="icons/grass2/zoom-more.png">
+ <em>Zoom options</em></dt>
+ <dd>Opens a dropdown menu that allows user to:
+ <ul>
+ <li>Zoom to match the extents of a selected map</li>
+ <li>Zoom to match the computational region (set with <em>g.region</em>)</li>
+ <li>Zoom to match the extents of the default region</li>
+ <li>Zoom to match the extents of a saved region</li>
+ <li>Set computational region (the mapset's <tt>WIND</tt> file) to match the
current display extents (does not change the resolution),
- <li>Save display geometry (current extents) to a named region file</li>
- </ul>
-<dt><img src="icons/grass2/layer-raster-analyze.png">
- <em>Analyze menu</em></dt>
-<dd>Opens a dropdown menu with:<br>
- <dl>
- <dt><img src="icons/grass2/measure-length.png">
- <em>Distance measurement tool</em></dt>
- <dd>Interactive measurement of lengths defined with the mouse. The
+ <li>Save display geometry (current extents) to a named region file</li>
+ </ul>
+ </dd>
+ <dt><img src="icons/grass2/layer-raster-analyze.png">
+ <em>Analyze menu</em></dt>
+ <dd>Opens a dropdown menu with:
+ <dl>
+ <dt><img src="icons/grass2/measure-length.png">
+ <em>Distance measurement tool</em></dt>
+ <dd>Interactive measurement of lengths defined with the mouse. The
length of each segment and the cumulative length of all segments
measuered is displayed in the command output window frame. Lengths are
measured in the current measurement unit,
see <em><a href="d.measure.html">d.measure</a></em>.</dd>
- <dt><img src="icons/grass2/layer-raster-profile.png">
+ <dt><img src="icons/grass2/layer-raster-profile.png">
<em>Profile tool</em></dt>
<dd>Interactively create profile of a raster map. Profile transect is
- drawn with the mouse in map display. The profile may be of the
- displayed map or a different map. Up to three maps can be profiled
- simultaneously,
- see <em><a href="gm_profile.html">Profile Tool help page</a></em>.</dd>
+ drawn with the mouse in map display. The profile may be of the
+ displayed map or a different map. Up to three maps can be profiled
+ simultaneously,
+ see <em><a href="gm_profile.html">Profile Tool help page</a></em>.</dd>
- <dt><img src="icons/grass2/layer-raster-histogram.png">
+ <dt><img src="icons/grass2/layer-raster-histogram.png">
<em>Histogram tool</em></dt>
- <dd>Displays histogram of selected raster map or image in new window,
+ <dd>Displays histogram of selected raster map or image in new window,
see <em><a href="d.histogram.html">d.histogram</a></em>.</dd>
- </dl>
-<dt><img src="icons/grass2/overlay-add.png">
+ </dl>
+ </dd>
+ <dt><img src="icons/grass2/overlay-add.png">
<em>Add overlay</em></dt>
- <dd>opens a dropdown menu that allows user to:<br>
- <dl>
+ <dd>opens a dropdown menu that allows user to
+ <dl>
<dt><img src="icons/grass2/scalebar-add.png">
- <em>Add scalebar and north arrow</em></dt>
- <dd>Adds layer to display a combined scalebar and north arrow. Options
- include scalebar placement (using screen coordinates or a mouse),
- scalebar format, and scalebar colors,
- see <em><a href="d.barscale.html">d.barscale</a></em>.</dd>
+ <em>Add scalebar and north arrow</em></dt>
+ <dd>Adds layer to display a combined scalebar and north arrow. Options
+ include scalebar placement (using screen coordinates or a mouse),
+ scalebar format, and scalebar colors,
+ see <em><a href="d.barscale.html">d.barscale</a></em>.</dd>
<dt><img src="icons/grass2/legend-add.png">
- <em>Add raster map legend</em></dt>
- <dd>Adds layer to display with legend of selected raster map,
- see <em><a href="d.legend.html">d.legend</a></em>.</dd>
+ <em>Add raster map legend</em></dt>
+ <dd>Adds layer to display with legend of selected raster map,
+ see <em><a href="d.legend.html">d.legend</a></em>.</dd>
<dt><img src="icons/grass2/text-add.png">
- <em>Add text layer</em></dt>
- <dd>Adds layer to display a line of text using default GRASS font
- (selected with <em><a href="d.font.html">d.font</a></em>). Options
- include: text placement (screen coordinates); and text size, bolding,
- and color, see <em><a href="d.text.html">d.text</a></em>.</dd>
- </dl>
+ <em>Add text layer</em></dt>
+ <dd>Adds layer to display a line of text using default GRASS font
+ (selected with <em><a href="d.font.html">d.font</a></em>). Options
+ include: text placement (screen coordinates); and text size, bolding,
+ and color, see <em><a href="d.text.html">d.text</a></em>.</dd>
+ </dl>
+ </dd>
-<dt><img src="icons/grass2/map-export.png">
- <em>Save display to graphic file</em></dt>
-<dd>Save the visible image in map display to different raster graphic formats.</dd>
+ <dt><img src="icons/grass2/map-export.png">
+ <em>Save display to graphic file</em></dt>
+ <dd>Save the visible image in map display to different raster graphic formats.</dd>
+ <dt><img src="icons/grass2/print.png">
+ <em>Print map</em></dt>
+ <dd>Prints map on system native printer or PostScript device;
+ saves visible map display (including PostScript text and labels) to PDF
+ or EPS file.</dd>
+ <dt><em>Map display mode</em></dt>
+ <dd>Opens a dropdown menu for selecting different display mode
+ <dl>
+ <dt><em>2D view mode</em></dt>
+ <dd>Normal GIS display. All active layers are composited and displayed
+ in 2D mode.</dd>
+ <dt><em>3D view mode</em></dt>
+ <dd>Experimental replacement for NVIZ. Displays all active layers in
+ 3D perspective using OpenGL. A new control panel opens to manage the
+ 3D view. 3D view can be zoomed, panned, rotated, and tilted. The
+ vertical exaggeration of rasters and 3D vectors can be set. Various
+ color and lighten settings are possible. Not yet functional for
+ Windows platforms</dd>
+ <dt><em>Digitize mode</em></dt>
+ <dd>Puts display into vector digitizing mode and opens a new digitizing
+ toolbar. The user can digitize a new map or edit an existing
+ map. Not yet functional for Windows platforms</dd>
+ </dl>
+ </dd>
-<dt><img src="icons/grass2/print.png">
- <em>Print map</em></dt>
-<dd>Prints map on system native printer or PostScript device;
-saves visible map display (including PostScript text and labels) to PDF
-or EPS file.</dd>
-<dt><em>Map display mode</em></dt>
-<dd>Opens a dropdown menu for selecting different display mode<br>
- <dl>
- <dt><em>2D view mode</em></dt>
- <dd>Normal GIS display. All active layers are composited and displayed
- in 2D mode.</dd>
- <dt><em>3D view mode</em></dt>
- <dd>Experimental replacement for NVIZ. Displays all active layers in
- 3D perspective using OpenGL. A new control panel opens to manage the
- 3D view. 3D view can be zoomed, panned, rotated, and tilted. The
- vertical exaggeration of rasters and 3D vectors can be set. Various
- color and lighten settings are possible. Not yet functional for
- Windows platforms</dd>
- <dt><em>Digitize mode</em></dt>
- <dd>Puts display into vector digitizing mode and opens a new digitizing
- toolbar. The user can digitize a new map or edit an existing
- map. Not yet functional for Windows platforms</dd>
- </dl>
</dl>
<h2>SEE ALSO</h2>
