[GRASS-SVN] r45033 -
grass/branches/releasebranch_6_4/vector/v.out.ogr
svn_grass at osgeo.org
Fri Jan 14 15:24:03 EST 2011
Author: benducke
Date: 2011-01-14 12:24:03 -0800 (Fri, 14 Jan 2011)
New Revision: 45033
grass/branches/releasebranch_6_4/vector/v.out.ogr/main.c
Two simple guard statements added to mk_att() to prevent it from throwing some ugly "index out of range" errors when the 's' flag is given.
Modified: grass/branches/releasebranch_6_4/vector/v.out.ogr/main.c
--- grass/branches/releasebranch_6_4/vector/v.out.ogr/main.c 2011-01-14 20:06:10 UTC (rev 45032)
+++ grass/branches/releasebranch_6_4/vector/v.out.ogr/main.c 2011-01-14 20:24:03 UTC (rev 45033)
@@ -988,10 +988,15 @@
(Column));
/* Reset */
- OGR_F_UnsetField(Ogr_feature, ogrfieldnum);
+ if ( ( ( nocat ) && (strcmp(Fi->key, db_get_column_name(Column)) == 0) ) == 0 ) {
+ /* if this is 'cat', then execute the following only if the '-s' flag was NOT given*/
+ OGR_F_UnsetField(Ogr_feature, ogrfieldnum);
/* prevent writing NULL values */
if (!db_test_value_isnull(Value)) {
+ if ( ( (nocat) && (strcmp(Fi->key, db_get_column_name(Column)) == 0) ) == 0 ) {
switch (colctype) {
case DB_C_TYPE_INT:
OGR_F_SetFieldInteger(Ogr_feature,
@@ -1018,6 +1023,7 @@
break;
db_close_cursor(&cursor);
