[GRASS-SVN] r45053 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sat Jan 15 19:35:04 EST 2011
Author: martinl
Date: 2011-01-15 16:35:04 -0800 (Sat, 15 Jan 2011)
New Revision: 45053
grass/trunk/gui/wxpython/gui_modules/layertree.py
wxGUI: redesign layer tree popup menu
Modified: grass/trunk/gui/wxpython/gui_modules/layertree.py
--- grass/trunk/gui/wxpython/gui_modules/layertree.py 2011-01-16 00:01:57 UTC (rev 45052)
+++ grass/trunk/gui/wxpython/gui_modules/layertree.py 2011-01-16 00:35:04 UTC (rev 45053)
@@ -255,61 +255,48 @@
Debug.msg (4, "LayerTree.OnContextMenu: layertype=%s" % \
ltype)
- if not hasattr (self, "popupID1"):
- self.popupID1 = wx.NewId()
- self.popupID2 = wx.NewId()
- self.popupID3 = wx.NewId()
- self.popupID4 = wx.NewId()
- self.popupID5 = wx.NewId()
- self.popupID6 = wx.NewId()
- self.popupID7 = wx.NewId()
- self.popupID8 = wx.NewId()
- self.popupID9 = wx.NewId()
- self.popupID10 = wx.NewId()
- self.popupID11 = wx.NewId() # nviz
- self.popupID12 = wx.NewId()
- self.popupID13 = wx.NewId()
- self.popupID14 = wx.NewId()
- self.popupID15 = wx.NewId()
- self.popupID16 = wx.NewId()
- self.popupID17 = wx.NewId()
+ if not hasattr (self, "popupID"):
+ self.popupID = dict()
+ for key in ('remove', 'rename', 'opacity', 'nviz', 'zoom',
+ 'region', 'export', 'attr', 'edit0', 'edit1',
+ 'bgmap', 'topo', 'meta', 'null', 'zoom1', 'region1',
+ 'color', 'hist', 'prof', 'properties'):
+ self.popupID[key] = wx.NewId()
self.popupMenu = wx.Menu()
numSelected = len(self.GetSelections())
- # general item
- self.popupMenu.Append(self.popupID1, text = _("Remove"))
- self.Bind(wx.EVT_MENU, self.lmgr.OnDeleteLayer, id = self.popupID1)
+ self.popupMenu.Append(self.popupID['remove'], text = _("Remove"))
+ self.Bind(wx.EVT_MENU, self.lmgr.OnDeleteLayer, id = self.popupID['remove'])
- if ltype != "command": # rename
- self.popupMenu.Append(self.popupID2, text = _("Rename"))
- self.Bind(wx.EVT_MENU, self.OnRenameLayer, id = self.popupID2)
+ if ltype != "command":
+ self.popupMenu.Append(self.popupID['rename'], text = _("Rename"))
+ self.Bind(wx.EVT_MENU, self.OnRenameLayer, id = self.popupID['rename'])
if numSelected > 1:
- self.popupMenu.Enable(self.popupID2, False)
+ self.popupMenu.Enable(self.popupID['rename'], False)
# map layer items
- if ltype != "group" and \
- ltype != "command":
+ if ltype not in ("group", "command"):
self.popupMenu.AppendSeparator()
- self.popupMenu.Append(self.popupID8, text = _("Change opacity level"))
- self.Bind(wx.EVT_MENU, self.OnPopupOpacityLevel, id = self.popupID8)
- self.popupMenu.Append(self.popupID3, text = _("Properties"))
- self.Bind(wx.EVT_MENU, self.OnPopupProperties, id = self.popupID3)
+ self.popupMenu.Append(self.popupID['opacity'], text = _("Change opacity level"))
+ self.Bind(wx.EVT_MENU, self.OnPopupOpacityLevel, id = self.popupID['opacity'])
+ self.popupMenu.Append(self.popupID['properties'], text = _("Properties"))
+ self.Bind(wx.EVT_MENU, self.OnPopupProperties, id = self.popupID['properties'])
+ if numSelected > 1:
+ self.popupMenu.Enable(self.popupID['opacity'], False)
+ self.popupMenu.Enable(self.popupID['properties'], False)
if ltype in ('raster', 'vector', '3d-raster') and self.mapdisplay.toolbars['nviz']:
- self.popupMenu.Append(self.popupID11, _("3D view properties"))
- self.Bind (wx.EVT_MENU, self.OnNvizProperties, id = self.popupID11)
+ self.popupMenu.Append(self.popupID['nviz'], _("3D view properties"))
+ self.Bind (wx.EVT_MENU, self.OnNvizProperties, id = self.popupID['nviz'])
if ltype in ('raster', 'vector', 'rgb'):
- self.popupMenu.Append(self.popupID9, text = _("Zoom to selected map(s)"))
- self.Bind(wx.EVT_MENU, self.mapdisplay.OnZoomToMap, id = self.popupID9)
- self.popupMenu.Append(self.popupID10, text = _("Set computational region from selected map(s)"))
- self.Bind(wx.EVT_MENU, self.OnSetCompRegFromMap, id = self.popupID10)
- if numSelected > 1:
- self.popupMenu.Enable(self.popupID8, False)
- self.popupMenu.Enable(self.popupID3, False)
+ self.popupMenu.Append(self.popupID['zoom'], text = _("Zoom to selected map(s)"))
+ self.Bind(wx.EVT_MENU, self.mapdisplay.OnZoomToMap, id = self.popupID['zoom'])
+ self.popupMenu.Append(self.popupID['region'], text = _("Set computational region from selected map(s)"))
+ self.Bind(wx.EVT_MENU, self.OnSetCompRegFromMap, id = self.popupID['region'])
# specific items
try:
@@ -320,114 +307,103 @@
# vector layers (specific items)
if mltype and mltype == "vector":
- self.popupMenu.Append(self.popupID17, text = _("Export"))
+ self.popupMenu.Append(self.popupID['export'], text = _("Export"))
self.Bind(wx.EVT_MENU, lambda x: self.lmgr.OnMenuCmd(cmd = ['v.out.ogr',
'input=%s' % mapLayer.GetName()]),
- id = self.popupID17)
+ id = self.popupID['export'])
- self.popupMenu.Append(self.popupID4, text = _("Show attribute data"))
- self.Bind(wx.EVT_MENU, self.lmgr.OnShowAttributeTable, id = self.popupID4)
+ self.popupMenu.Append(self.popupID['attr'], text = _("Show attribute data"))
+ self.Bind(wx.EVT_MENU, self.lmgr.OnShowAttributeTable, id = self.popupID['attr'])
- self.popupMenu.Append(self.popupID5, text = _("Start editing"))
- self.popupMenu.Append(self.popupID6, text = _("Stop editing"))
- self.popupMenu.Enable(self.popupID6, False)
- self.Bind (wx.EVT_MENU, self.OnStartEditing, id = self.popupID5)
- self.Bind (wx.EVT_MENU, self.OnStopEditing, id = self.popupID6)
+ self.popupMenu.Append(self.popupID['edit0'], text = _("Start editing"))
+ self.popupMenu.Append(self.popupID['edit1'], text = _("Stop editing"))
+ self.popupMenu.Enable(self.popupID['edit1'], False)
+ self.Bind (wx.EVT_MENU, self.OnStartEditing, id = self.popupID['edit0'])
+ self.Bind (wx.EVT_MENU, self.OnStopEditing, id = self.popupID['edit1'])
layer = self.GetPyData(self.layer_selected)[0]['maplayer']
# enable editing only for vector map layers available in the current mapset
digitToolbar = self.mapdisplay.toolbars['vdigit']
if digitToolbar:
# background vector map
- self.popupMenu.Append(self.popupID14,
+ self.popupMenu.Append(self.popupID['bgmap'],
text = _("Use as background vector map for digitizer"),
kind = wx.ITEM_CHECK)
- self.Bind(wx.EVT_MENU, self.OnSetBgMap, id = self.popupID14)
+ self.Bind(wx.EVT_MENU, self.OnSetBgMap, id = self.popupID['bgmap'])
if UserSettings.Get(group = 'vdigit', key = 'bgmap', subkey = 'value',
internal = True) == layer.GetName():
- self.popupMenu.Check(self.popupID14, True)
+ self.popupMenu.Check(self.popupID['bgmap'], True)
- self.popupMenu.Append(self.popupID16, text = _("Rebuild topology"))
- self.Bind(wx.EVT_MENU, self.OnTopology, id = self.popupID16)
+ self.popupMenu.Append(self.popupID['topo'], text = _("Rebuild topology"))
+ self.Bind(wx.EVT_MENU, self.OnTopology, id = self.popupID['topo'])
if layer.GetMapset() != grass.gisenv()['MAPSET']:
# only vector map in current mapset can be edited
- self.popupMenu.Enable (self.popupID5, False)
- self.popupMenu.Enable (self.popupID6, False)
- self.popupMenu.Enable (self.popupID16, False)
+ self.popupMenu.Enable (self.popupID['edit0'], False)
+ self.popupMenu.Enable (self.popupID['edit1'], False)
+ self.popupMenu.Enable (self.popupID['topo'], False)
elif digitToolbar and digitToolbar.GetLayer():
# vector map already edited
vdigitLayer = digitToolbar.GetLayer()
if vdigitLayer is layer:
- # disable 'start editing'
- # enable 'stop editing'
- self.popupMenu.Enable(self.popupID6, True)
- # disable 'remove'
- self.popupMenu.Enable(self.popupID1, False)
- # disable 'bgmap'
- self.popupMenu.Enable(self.popupID14, False)
- # disable 'topology'
+ self.popupMenu.Enable(self.popupID['edit0'], False)
+ self.popupMenu.Enable(self.popupID['edit1'], True)
+ self.popupMenu.Enable(self.popupID['remove'], False)
+ self.popupMenu.Enable(self.popupID['bgmap'], False)
+ self.popupMenu.Enable(self.popupID['topo'], False)
else:
- self.popupMenu.Enable(self.popupID5, False)
- # disable 'stop editing'
- # enable 'bgmap'
- self.popupMenu.Enable(self.popupID14, True)
+ self.popupMenu.Enable(self.popupID['bgmap'], True)
- self.popupMenu.Append(self.popupID7, _("Metadata"))
- self.Bind (wx.EVT_MENU, self.OnMetadata, id = self.popupID7)
+ self.popupMenu.Append(self.popupID['meta'], _("Metadata"))
+ self.Bind (wx.EVT_MENU, self.OnMetadata, id = self.popupID['meta'])
if numSelected > 1:
- self.popupMenu.Enable(self.popupID4, False)
- self.popupMenu.Enable(self.popupID7, False)
- self.popupMenu.Enable(self.popupID16, False)
- self.popupMenu.Enable(self.popupID17, False)
+ self.popupMenu.Enable(self.popupID['attr'], False)
+ self.popupMenu.Enable(self.popupID['meta'], False)
+ self.popupMenu.Enable(self.popupID['export'], False)
# raster layers (specific items)
elif mltype and mltype == "raster":
- self.popupMenu.Append(self.popupID12, text = _("Zoom to selected map(s) (ignore NULLs)"))
- self.Bind(wx.EVT_MENU, self.mapdisplay.OnZoomToRaster, id = self.popupID12)
- self.popupMenu.Append(self.popupID13, text = _("Set computational region from selected map(s) (ignore NULLs)"))
- self.Bind(wx.EVT_MENU, self.OnSetCompRegFromRaster, id = self.popupID13)
+ self.popupMenu.Append(self.popupID['zoom1'], text = _("Zoom to selected map(s) (ignore NULLs)"))
+ self.Bind(wx.EVT_MENU, self.mapdisplay.OnZoomToRaster, id = self.popupID['zoom1'])
+ self.popupMenu.Append(self.popupID['region1'], text = _("Set computational region from selected map(s) (ignore NULLs)"))
+ self.Bind(wx.EVT_MENU, self.OnSetCompRegFromRaster, id = self.popupID['region1'])
self.Bind(wx.EVT_MENU, lambda x: self.lmgr.OnMenuCmd(cmd = ['r.out.gdal',
- self.popupMenu.Append(self.popupID15, _("Set color table"))
- self.Bind (wx.EVT_MENU, self.OnColorTable, id = self.popupID15)
- self.popupMenu.Append(self.popupID4, _("Histogram"))
- self.Bind (wx.EVT_MENU, self.OnHistogram, id = self.popupID4)
- self.popupMenu.Append(self.popupID5, _("Profile"))
- self.Bind (wx.EVT_MENU, self.OnProfile, id = self.popupID5)
- self.popupMenu.Append(self.popupID6, _("Metadata"))
- self.Bind (wx.EVT_MENU, self.OnMetadata, id = self.popupID6)
+ self.popupMenu.Append(self.popupID['color'], _("Set color table"))
+ self.Bind (wx.EVT_MENU, self.OnColorTable, id = self.popupID['color'])
+ self.popupMenu.Append(self.popupID['hist'], _("Histogram"))
+ self.Bind (wx.EVT_MENU, self.OnHistogram, id = self.popupID['hist'])
+ self.popupMenu.Append(self.popupID['prof'], _("Profile"))
+ self.Bind (wx.EVT_MENU, self.OnProfile, id = self.popupID['prof'])
if numSelected > 1:
- self.popupMenu.Enable(self.popupID12, False)
- self.popupMenu.Enable(self.popupID13, False)
- self.popupMenu.Enable(self.popupID15, False)
- self.popupMenu.Enable(self.popupID11, False)
+ self.popupMenu.Enable(self.popupID['zoom1'], False)
+ self.popupMenu.Enable(self.popupID['region1'], False)
+ self.popupMenu.Enable(self.popupID['color'], False)
+ self.popupMenu.Enable(self.popupID['hist'], False)
+ self.popupMenu.Enable(self.popupID['prof'], False)
+ self.popupMenu.Enable(self.popupID['nviz'], False)
- # self.PopupMenu(self.popupMenu, pos)
self.PopupMenu(self.popupMenu)
self.popupMenu.Destroy()
def OnTopology(self, event):
"""!Rebuild topology of selected vector map"""
mapLayer = self.GetPyData(self.layer_selected)[0]['maplayer']
