[GRASS-SVN] r45077 - grass-addons/raster/r.diversity
svn_grass at osgeo.org
Tue Jan 18 07:19:39 EST 2011
Author: lucadelu
Date: 2011-01-18 04:19:39 -0800 (Tue, 18 Jan 2011)
New Revision: 45077
grass-addons/raster/r.diversity/r.diversity.py
solve a small bug in the name variable
Modified: grass-addons/raster/r.diversity/r.diversity.py
--- grass-addons/raster/r.diversity/r.diversity.py 2011-01-18 10:40:02 UTC (rev 45076)
+++ grass-addons/raster/r.diversity/r.diversity.py 2011-01-18 12:19:39 UTC (rev 45077)
@@ -63,7 +63,7 @@
# set the home path
home=os.path.expanduser('~')
# set the name of conf file
- confilename = homePath+'/.r.li/history/conf_diversity'
+ confilename = home+'/.r.li/history/conf_diversity'
# check if GISBASE is set
if "GISBASE" not in os.environ:
# return an error advice
@@ -94,19 +94,19 @@
# check if ~/.r.li/history path exists
if os.path.exists(home+'/.r.li/history'):
# create configuration file
- createConfFile(res,map_in,home)
+ createConfFile(res,map_in,confilename)
else:
# create ~/.r.li/history path
os.path.mkdir(home+'/.r.li/history')
else:
# create ~/.r.li
os.path.mkdir(home+'/.r.li/')
### calculate r.li indices
@@ -123,7 +123,7 @@
print 'All works are terminated'
#create configuration file instead using r.li.setup
-def createConfFile(res,inpumap,homePath):
+def createConfFile(res,inpumap,filename):
# start the text for the conf file
outputLine = ['SAMPLINGFRAME 0|0|1|1\n']
# return r.info about input file
@@ -140,7 +140,7 @@
outputLine.append('SAMPLEAREA -1|-1|'+str(rV)+'|'+str(cV)+'\n')
outputLine.append('MOVINGWINDOW\n')
# open configuration file
- fileConf=open(confilename,'w')
+ fileConf=open(filename,'w')
# write file
fileConf.writelines(outputLine)
# close file
