[GRASS-SVN] r45099 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Thu Jan 20 08:42:08 EST 2011
Author: martinl
Date: 2011-01-20 05:42:07 -0800 (Thu, 20 Jan 2011)
New Revision: 45099
grass/trunk/gui/wxpython/gui_modules/render.py
wxGUI/render: comment-out problematic code (crashes wxGUI)
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py 2011-01-20 13:17:22 UTC (rev 45098)
+++ grass/trunk/gui/wxpython/gui_modules/render.py 2011-01-20 13:42:07 UTC (rev 45099)
@@ -121,9 +121,7 @@
Debug.msg (3, "Layer.Render(): type=%s, name=%s" % \
(self.type, self.name))
# prepare command for each layer
layertypes = ('raster', 'rgb', 'his', 'shaded', 'rastarrow', 'rastnum',
'vector','thememap','themechart',
'grid', 'geodesic', 'rhumb', 'labels',
@@ -134,15 +132,11 @@
raise gcmd.GException(_("<%(name)s>: layer type <%(type)s> is not supported") % \
{'type' : self.type, 'name' : self.name})
# start monitor
if self.mapfile:
os.environ["GRASS_PNGFILE"] = self.mapfile
# execute command
try:
if self.type == 'command':
read = False
@@ -162,10 +156,10 @@
getErrorMsg = True,
quiet = True,
**self.cmd[1])
- if len(msg):
- sys.stderr.write(_("Running") + " '" + utils.GetCmdString(self.cmd) + "'")
- sys.stderr.write(msg)
+ # if len(msg):
+ # sys.stderr.write(_("Running") + " '" + utils.GetCmdString(self.cmd) + "'")
+ # sys.stderr.write(msg)
if ret != 0:
# clean up after problem
try:
@@ -178,7 +172,7 @@
self.maskfile = None
except gcmd.GException, e:
- print >> sys.stderr, e
+ sys.stderr.write(e)
# clean up after problems
try:
os.remove(self.mapfile)
@@ -189,9 +183,7 @@
self.mapfile = None
# stop monitor
if os.environ.has_key("GRASS_PNGFILE"):
del os.environ["GRASS_PNGFILE"]
@@ -865,7 +857,7 @@
os.environ["GRASS_PNG_READ"] = "FALSE"
self._renderLayers(force, mapWindow, maps, masks, opacities)
# ugly hack for MSYS
if not subprocess.mswindows:
mapstr = ",".join(maps)
