[GRASS-SVN] r45102 - grass/branches/develbranch_6/vector/v.transform
Thu Jan 20 11:03:20 EST 2011
Author: martinl
Date: 2011-01-20 08:03:20 -0800 (Thu, 20 Jan 2011)
New Revision: 45102
   grass/branches/develbranch_6/vector/v.transform/main.c
v.transform: fix dim of output vector map
Modified: grass/branches/develbranch_6/vector/v.transform/main.c
--- grass/branches/develbranch_6/vector/v.transform/main.c	2011-01-20 15:56:45 UTC (rev 45101)
+++ grass/branches/develbranch_6/vector/v.transform/main.c	2011-01-20 16:03:20 UTC (rev 45102)
@@ -248,9 +248,11 @@
 	G_fatal_error(_("Vector map <%s> not found"), vold->answer);
     Vect_open_old(&Old, vold->answer, mapset);
-    Vect_open_new(&New, vnew->answer, Vect_is_3d(&Old) || zshift->answer);
+    Vect_open_new(&New, vnew->answer, Vect_is_3d(&Old) || tozero_flag->answer ||
+		  strcmp(zshift->answer, "0.0") || strcmp(zscale->answer, "1.0") ||
+		  strcmp(zrot->answer, "0.0") ? WITH_Z : WITHOUT_Z);
     /* copy and set header */
     Vect_copy_head_data(&Old, &New);
