[GRASS-SVN] r45116 - grass/trunk/lib/init
svn_grass at osgeo.org
Thu Jan 20 17:21:01 EST 2011
Author: martinl
Date: 2011-01-20 14:21:01 -0800 (Thu, 20 Jan 2011)
New Revision: 45116
grass/trunk/lib/init/grass.py
check if gisrc is available when starting grass with `-text` switch
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2011-01-20 21:42:58 UTC (rev 45115)
+++ grass/trunk/lib/init/grass.py 2011-01-20 22:21:01 UTC (rev 45116)
@@ -195,7 +195,7 @@
# Set the session grassrc file
gisrc = os.path.join(tmpdir, "gisrc")
os.environ['GISRC'] = gisrc
# remove invalid GISRC file to avoid disturbing error messages:
try:
s = readfile(gisrcrc)
@@ -930,12 +930,18 @@
#predefine monitor size for certain architectures
if os.getenv('HOSTTYPE') == 'arm':
- #small monitor on ARM (iPAQ, zaurus... etc)
+ # small monitor on ARM (iPAQ, zaurus... etc)
os.environ['GRASS_HEIGHT'] = "320"
- os.environ['GRASS_WIDTH'] = "240"
+ os.environ['GRASS_WIDTH'] = "240"
# First time user - GISRC is defined in the GRASS script
if not os.access(gisrc, os.F_OK):
+ if grass_gui == 'text' and len(args) == 0:
+ fatal(_("Unable to start GRASS. You can:\n"
+ " - Launch GRASS with '-gui' switch (`grass70 -gui`)\n"
+ " - Create manually GISRC file (%s)\n"
+ " - Launch GRASS with path to "
+ "the location/mapset as an argument (`grass70 /path/to/location/mapset`)") % gisrcrc)
grass_intro()
else:
clean_temp()
