[GRASS-SVN] r45121 - grass/trunk/lib/init
svn_grass at osgeo.org
Thu Jan 20 17:41:05 EST 2011
Author: martinl
Date: 2011-01-20 14:41:05 -0800 (Thu, 20 Jan 2011)
New Revision: 45121
grass/trunk/lib/init/grass.py
grass/trunk/lib/init/license.txt
there is only wxpython gui, simplify starting script
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2011-01-20 22:36:43 UTC (rev 45120)
+++ grass/trunk/lib/init/grass.py 2011-01-20 22:41:05 UTC (rev 45121)
@@ -118,7 +118,7 @@
help_text = r"""
%s:
$CMD_NAME [-h | -help | --help] [-v | --version] [-c]
- [-text | -gui | -wxpython | -wx]
+ [-text | -gui]
[[[<GISDBASE>/]<LOCATION_NAME>/]<MAPSET>]
%s:
@@ -129,8 +129,6 @@
%s
-gui %s
%s
- -wxpython or -wx %s
- %s
%s:
GISDBASE %s
@@ -153,17 +151,15 @@
_("create given mapset if it doesn't exist"),
_("use text based interface"),
_("and set as default"),
- _("use graphical user interface ($DEFAULT_GUI by default)"),
+ _("use $DEFAULT_GUI graphical user interface"),
- _("use wxPython based graphical user interface"),
- _("and set as default"),
_("Parameters"),
_("initial database (path to GIS data)"),
_("initial location"),
_("initial mapset"),
_("fully qualified initial mapset directory"),
_("Environment variables relevant for startup"),
- _("select GUI (text, gui, wxpython)"),
+ _("select GUI (text, gui)"),
_("set wish shell name to override 'wish'"),
_("set html web browser for help pages"),
_("set additional path(s) to local GRASS modules"),
@@ -244,9 +240,7 @@
if grass_gui == 'gui':
grass_gui = default_gui
- elif grass_gui == 'wx':
- grass_gui = 'wxpython'
# FIXME oldtcltk, gis.m, d.m no longer exist
if grass_gui in ['d.m', 'gis.m', 'oldtcltk', 'tcltk']:
@@ -829,7 +823,7 @@
for i in sys.argv[1:]:
# Check if the user asked for the version
if i in ["-v","--version"]:
- message(readfile(gfile("etc", "license")))
+ message('\n' + readfile(gfile("etc", "license")))
sys.exit()
# Check if the user asked for help
elif i in ["help","-h","-help","--help"]:
Modified: grass/trunk/lib/init/license.txt
--- grass/trunk/lib/init/license.txt 2011-01-20 22:36:43 UTC (rev 45120)
+++ grass/trunk/lib/init/license.txt 2011-01-20 22:41:05 UTC (rev 45121)
@@ -1,9 +1,9 @@
Geographic Resources Analysis Support System (GRASS) is Copyright,
-1999-2008 by the GRASS Development Team, and licensed under terms of the
+1999-GRASS_VERSION_DATE by the GRASS Development Team, and licensed under terms of the
GNU General Public License (GPL) version >=2.
-This GRASS GRASS_VERSION_NUMBER release is coordinated and produced by the
-GRASS Development Team with contributions from all over the world.
+This GRASS GRASS_VERSION_NUMBER release is coordinated and produced by
+the GRASS Development Team with contributions from all over the world.
This program is distributed in the hope that it will be useful, but
WITHOUT ANY WARRANTY; without even the implied warranty of
