[GRASS-SVN] r45128 - grass/trunk/lib/init
svn_grass at osgeo.org
Fri Jan 21 05:34:33 EST 2011
Author: martinl
Date: 2011-01-21 02:34:33 -0800 (Fri, 21 Jan 2011)
New Revision: 45128
grass/trunk/lib/init/grass.py
fix typo in starting script (create new mapset)
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2011-01-21 10:27:34 UTC (rev 45127)
+++ grass/trunk/lib/init/grass.py 2011-01-21 10:34:33 UTC (rev 45128)
@@ -459,7 +459,7 @@
if not os.access(os.path.join(os.path.join(gisdbase, location_name, "PERMANENT", "DEFAULT_WIND")), os.F_OK):
fatal(_("The location <%s> does not exist. Please create it first.") % location_name)
else:
- os.mkdirs(location)
+ os.mkdir(location)
# copy PERMANENT/DEFAULT_WIND to <mapset>/WIND
s = readfile(os.path.join(gisdbase, location_name, "PERMANENT", "DEFAULT_WIND"))
writefile(os.path.join(location, "WIND"), s)
