[GRASS-SVN] r45130 - grass/branches/develbranch_6/imagery/i.rectify
Fri Jan 21 06:09:13 EST 2011
Author: mmetz
Date: 2011-01-21 03:09:13 -0800 (Fri, 21 Jan 2011)
New Revision: 45130
   grass/branches/develbranch_6/imagery/i.rectify/exec.c
   grass/branches/develbranch_6/imagery/i.rectify/global.h
   grass/branches/develbranch_6/imagery/i.rectify/main.c
   grass/branches/develbranch_6/imagery/i.rectify/rectify.c
   grass/branches/develbranch_6/imagery/i.rectify/report.c
clean up report, check input answers, manually check for overwrite (backport from trunk r45129)
Modified: grass/branches/develbranch_6/imagery/i.rectify/exec.c
--- grass/branches/develbranch_6/imagery/i.rectify/exec.c	2011-01-21 10:42:54 UTC (rev 45129)
+++ grass/branches/develbranch_6/imagery/i.rectify/exec.c	2011-01-21 11:09:13 UTC (rev 45130)
@@ -22,18 +22,19 @@
     char *name;
     char *mapset;
     char *result;
-    char *type;
-    int i, n;
+    char *type = "raster";
+    int n;
     struct Colors colr;
     struct Categories cats;
     struct History hist;
     int colr_ok, cats_ok;
-    long start_time, rectify_time, compress_time;
+    long start_time, rectify_time;
+    G_message("-----------------------------------------------");
     /* rectify each file */
     for (n = 0; n < ref.nfiles; n++) {
-	if ((i = ref_list[n]) < 0) {
-	    /* continue; */
+	if (ref_list[n]) {
 	    name = ref.file[n].name;
 	    mapset = ref.file[n].mapset;
@@ -42,8 +43,6 @@
 		G_malloc(strlen(ref.file[n].name) + strlen(extension) + 1);
 	    strcpy(result, ref.file[n].name);
 	    strcat(result, extension);
-	    G_message(_("Rectified input raster map <%s> will be saved as <%s>"),
-		      name, result);
 	    select_current_env();
@@ -51,7 +50,6 @@
 	    colr_ok = G_read_colors(name, mapset, &colr) > 0;
 	    /* Initialze History */
-	    type = "raster";
 	    G_short_history(name, type, &hist);
 	    time(&start_time);
@@ -59,12 +57,6 @@
 	    if (rectify(name, mapset, result, order, interp_method)) {
 		select_target_env();
-	     * This clobbers (with wrong values) head
-	     * written by gislib.  99% sure it should
-	     * be removed.  EGM 2002/01/03
-            G_put_cellhd (result,&target_window);
 		if (cats_ok) {
 		    G_write_cats(result, &cats);
 		    G_free_cats(&cats);
@@ -84,18 +76,14 @@
 		time(&rectify_time);
-		compress_time = rectify_time;
-		report(name, mapset, result, rectify_time - start_time,
-		       compress_time - rectify_time, 1);
+		report(rectify_time - start_time, 1);
 	    else
-		report(name, mapset, result, (long)0, (long)0, 0);
+		report((long)0, 0);
 	    G_free(result);
-    G_done_msg(" ");
     return 0;
Modified: grass/branches/develbranch_6/imagery/i.rectify/global.h
--- grass/branches/develbranch_6/imagery/i.rectify/global.h	2011-01-21 10:42:54 UTC (rev 45129)
+++ grass/branches/develbranch_6/imagery/i.rectify/global.h	2011-01-21 11:09:13 UTC (rev 45130)
@@ -84,7 +84,7 @@
 #define CPTR(c,y,x) (&(*BLOCK((c),HI((y)),HI((x))))[LO((y))][LO((x))])
 /* report.c */
-int report(char *, char *, char *, long, long, int);
+int report(long, int);
 /* target.c */
 int get_target(char *);
Modified: grass/branches/develbranch_6/imagery/i.rectify/main.c
--- grass/branches/develbranch_6/imagery/i.rectify/main.c	2011-01-21 10:42:54 UTC (rev 45129)
+++ grass/branches/develbranch_6/imagery/i.rectify/main.c	2011-01-21 11:09:13 UTC (rev 45130)
@@ -15,7 +15,7 @@
  * PURPOSE:      calculate a transformation matrix and then convert x,y cell
  *               coordinates to standard map coordinates for each pixel in the
  *               image (control points can come from i.points or i.vpoints)
- * COPYRIGHT:    (C) 2002-2006 by the GRASS Development Team
+ * COPYRIGHT:    (C) 2002-2011 by the GRASS Development Team
  *               This program is free software under the GNU General Public
  *               License (>=v2). Read the file COPYING that comes with GRASS
@@ -75,7 +75,8 @@
     char *ipolname;		/* name of interpolation method */
     int method;
     int n, i, m, k = 0;
-    int got_file = 0;
+    int got_file = 0, target_overwrite = 0;
+    char *overstr;
     struct Cell_head cellhd;
     struct Option *grp,         /* imagery group */
@@ -209,29 +210,43 @@
     if (a->answer) {
-	    ref_list[n] = -1;
+	    ref_list[n] = 1;
     else {
-	char xname[GNAME_MAX], xmapset[GMAPSET_MAX], *name;
+	char xname[GNAME_MAX], xmapset[GMAPSET_MAX], *name, *mapset;
 		ref_list[n] = 0;
 	for (m = 0; m < k; m++) {
 	    got_file = 0;
-	    if (G__name_is_fully_qualified(ifile->answers[m], xname, xmapset))
+	    if (G__name_is_fully_qualified(ifile->answers[m], xname, xmapset)) {
 		name = xname;
-	    else
+		mapset = xmapset;
+	    else {
 		name = ifile->answers[m];
+		mapset = 0;
 	    got_file = 0;
-		if (strcmp(name, ref.file[n].name) == 0) {
-		    got_file = 1;
-		    ref_list[n] = -1;
-		    break;
+		if (mapset) {
+		    if (strcmp(name, ref.file[n].name) == 0 &&
+		        strcmp(mapset, ref.file[n].mapset) == 0) {
+			got_file = 1;
+			ref_list[n] = 1;
+			break;
+		else {
+		    if (strcmp(name, ref.file[n].name) == 0) {
+			got_file = 1;
+			ref_list[n] = 1;
+			break;
 	    if (got_file == 0)
 		err_exit(ifile->answers[m], group);
@@ -244,6 +259,39 @@
     /* get the target */
     get_target(group);
+    /* Check the GRASS_OVERWRITE environment variable */
+    if ((overstr = getenv("GRASS_OVERWRITE")))  /* OK ? */
+	target_overwrite = atoi(overstr);
+    if (!target_overwrite) {
+	/* check if output exists in target location/mapset */
+	char result[GNAME_MAX];
+	select_target_env();
+	for (i = 0; i < ref.nfiles; i++) {
+	    if (!ref_list[i])
+		continue;
+	    strcpy(result, ref.file[i].name);
+	    strcat(result, extension);
+	    if (G_legal_filename(result) < 0)
+		G_fatal_error(_("Extension <%s> is illegal"), extension);
+	    if (G_find_cell(result, G_mapset())) {
+		G_warning(_("The following raster map already exists in"));
+		G_warning(_("target LOCATION %s, MAPSET %s:"),
+			  G_location(), G_mapset());
+		G_warning("<%s>", result);
+		G_fatal_error(_("Orthorectification cancelled."));
+	select_current_env();
+    else
+	G_debug(1, "Overwriting OK");
     /* do not use current region in target location */
     if (!c->answer) {
 	double res = -1;
@@ -273,6 +321,8 @@
     exec_rectify(order, extension, interpol->answer);
+    G_done_msg(" ");
     exit(EXIT_SUCCESS);
Modified: grass/branches/develbranch_6/imagery/i.rectify/rectify.c
--- grass/branches/develbranch_6/imagery/i.rectify/rectify.c	2011-01-21 10:42:54 UTC (rev 45129)
+++ grass/branches/develbranch_6/imagery/i.rectify/rectify.c	2011-01-21 11:09:13 UTC (rev 45130)
@@ -40,8 +40,12 @@
     G_close_cell(infd);		/* (pmx) 17 april 2000 */
+    G_message(_("Rectify <%s@%s> (location <%s>)"),
+	      name, mapset, G_location());
     G_set_window(&target_window);
+    G_message(_("into  <%s@%s> (location <%s>) ..."),
+	      result, G_mapset(), G_location());
     nrows = target_window.rows;
     ncols = target_window.cols;
Modified: grass/branches/develbranch_6/imagery/i.rectify/report.c
--- grass/branches/develbranch_6/imagery/i.rectify/report.c	2011-01-21 10:42:54 UTC (rev 45129)
+++ grass/branches/develbranch_6/imagery/i.rectify/report.c	2011-01-21 11:09:13 UTC (rev 45130)
@@ -1,20 +1,13 @@
 #include <grass/glocale.h>
 #include "global.h"
-int report(char *name, char *mapset, char *result,
-	   long rectify, long compress, int ok)
+int report(long rectify, int ok)
     int minutes, hours;
     long seconds;
     long ncells;
-    select_current_env();
-    G_message(_("Rectify <%s@%s> (location <%s>)"),
-	      name, mapset, G_location());
-    select_target_env();
-    G_message(_("into  <%s@%s> (location <%s>) ... %s"),
-	      result, G_mapset(), G_location(), ok ? _("complete") : _("failed"));
+    G_message("%s", ok ? _("complete") : _("failed"));
     if (!ok)
 	return 1;
@@ -27,30 +20,14 @@
     G_verbose_message(_("%d rows, %d cols (%ld cells) completed in"),
 			target_window.rows, target_window.cols, ncells);
     if (hours)
-	G_verbose_message("%d:%02d:%02ld", hours, minutes, seconds % 60);
+	G_verbose_message(_("%d:%02d:%02ld hours"), hours, minutes, seconds % 60);
     else
-	G_verbose_message("%d:%02ld", minutes, seconds % 60);
+	G_verbose_message(_("%d:%02ld minutes"), minutes, seconds % 60);
     if (seconds)
 	G_verbose_message(_("%.1f cells per minute"),
 			  (60.0 * ncells) / ((double)seconds));
-    seconds = compress;
-    if (seconds <= 0) {
-	G_message("-----------------------------------------------");
-	return 1;
-    minutes = seconds / 60;
-    hours = minutes / 60;
-    minutes -= hours * 60;
-    G_verbose_message(_("data compression required an additional"));
-    if (hours)
-    else
-	G_verbose_message("%d:%02ld\n", minutes, seconds % 60);
-    return 0;
+    return 1;
