[GRASS-SVN] r45185 - grass/trunk/vector/v.transform
Tue Jan 25 15:21:17 EST 2011
Author: martinl
Date: 2011-01-25 12:21:17 -0800 (Tue, 25 Jan 2011)
New Revision: 45185
   grass/trunk/vector/v.transform/trans_digit.c
v.transform: print info about number of processed features (level 1)
Modified: grass/trunk/vector/v.transform/trans_digit.c
--- grass/trunk/vector/v.transform/trans_digit.c	2011-01-25 19:03:18 UTC (rev 45184)
+++ grass/trunk/vector/v.transform/trans_digit.c	2011-01-25 20:21:17 UTC (rev 45185)
@@ -1,22 +1,3 @@
- * MODULE:       v.transform
- * AUTHOR(S):    See other files as well...
- *               Eric G. Miller <egm2 at jps.net>
- *               Radim Blazek
- *               DB support added by Martin Landa (08/2007)
- * PURPOSE:      To transform a vector layer's coordinates via a set of tie
- *               points.
- * COPYRIGHT:    (C) 2002-2007 by the GRASS Development Team
- *               This program is free software under the GNU General Public
- *              License (>=v2). Read the file COPYING that comes with GRASS
- *              for details.
 #include <math.h>
 #include <grass/libtrans.h>
 #include <grass/vector.h>
@@ -27,12 +8,12 @@
 #define PI M_PI
-int
-transform_digit_file(struct Map_info *Old, struct Map_info *New,
-		     int shift_file, double ztozero, int swap, double *trans_params_def,
-		     char *table, char **columns, int field)
+int transform_digit_file(struct Map_info *Old, struct Map_info *New,
+			 int shift_file, double ztozero, int swap, double *trans_params_def,
+			 char *table, char **columns, int field)
-    int i, type, cat;
+    int i, type, cat, line;
+    int verbose, format;
     unsigned int j;
     double *trans_params;
     double ang, x, y;
@@ -65,7 +46,10 @@
 	ang = PI * trans_params[IDX_ZROT] / 180;
-    while (1) {
+    line = 0;
+    format = G_info_format();
+    verbose = G_verbose() > G_verbose_min();
+    while (TRUE) {
 	type = Vect_read_next_line(Old, Points, Cats);
 	if (type == -1)		/* error */
@@ -77,6 +61,13 @@
 	if (field != -1 && !Vect_cat_get(Cats, field, NULL))
 	    continue;
+	if (verbose && line % 1000 == 0) {
+	    if (format == G_INFO_FORMAT_PLAIN)
+		fprintf(stderr, "%d..", line);
+	    else
+		fprintf(stderr, "%11d\b\b\b\b\b\b\b\b\b\b\b", line);
 	if (swap) {
 	    for (i = 0; i < Points->n_points; i++) {
 		x = Points->x[i];
@@ -165,8 +156,12 @@
 	Vect_write_line(New, type, Points, Cats);
+	line++;
+    if (verbose && format != G_INFO_FORMAT_PLAIN)
+	fprintf(stderr, "\r");
     if (field > 0) {
 	db_close_database_shutdown_driver(driver);
 	G_free((void *)trans_params);
