[GRASS-SVN] r45198 -
grass/branches/releasebranch_6_4/lib/vector/Vlib
svn_grass at osgeo.org
Wed Jan 26 14:18:03 EST 2011
Author: mmetz
Date: 2011-01-26 11:18:03 -0800 (Wed, 26 Jan 2011)
New Revision: 45198
grass/branches/releasebranch_6_4/lib/vector/Vlib/buffer2.c
grass/branches/releasebranch_6_4/lib/vector/Vlib/snap.c
fix for #994
Modified: grass/branches/releasebranch_6_4/lib/vector/Vlib/buffer2.c
--- grass/branches/releasebranch_6_4/lib/vector/Vlib/buffer2.c 2011-01-26 17:22:48 UTC (rev 45197)
+++ grass/branches/releasebranch_6_4/lib/vector/Vlib/buffer2.c 2011-01-26 19:18:03 UTC (rev 45198)
@@ -57,6 +57,7 @@
l = LENGTH(dx, dy);
*x = dx / l;
*y = dy / l;
return;
@@ -65,6 +66,7 @@
*nx = x * cosa - y * sina;
*ny = x * sina + y * cosa;
return;
@@ -76,7 +78,6 @@
double dalpha, double *nx, double *ny)
double cosa = cos(dalpha);
double sina = sin(dalpha);
/* double cc = cosa*cosa;
@@ -93,6 +94,7 @@
vb = (x * (-sina) + y * cosa) * db;
*nx = va * cosa + vb * (-sina);
*ny = va * sina + vb * cosa;
return;
@@ -106,9 +108,7 @@
double dalpha, double *px, double *py)
double u, v, len;
/* rotate (x,y) -dalpha radians */
@@ -121,6 +121,7 @@
u *= len;
v *= len;
rotate_vector(u, v, cosa, sina, px, py);
return;
@@ -134,6 +135,7 @@
*a = y2 - y1;
*b = x1 - x2;
*c = x2 * y1 - x1 * y2;
return;
@@ -167,6 +169,7 @@
if (tol > a)
tol = a;
return 2 * acos(1 - tol / a);
@@ -187,19 +190,12 @@
double tol, struct line_pnts *nPoints)
int i, j, res, np;
double *x, *y;
double tx, ty, vx, vy, wx, wy, nx, ny, mx, my, rx, ry;
double vx1, vy1, wx1, wy1;
double a0, b0, c0, a1, b1, c1;
double phi1, phi2, delta_phi;
double nsegments, angular_tol, angular_step;
int inner_corner, turns360;
G_debug(3, "parallel_line()");
@@ -348,21 +344,13 @@
int i, j, res, np;
double *x, *y;
double angle0, angle1;
G_debug(3, "convolution_line() side = %d", side);
@@ -510,25 +498,17 @@
int j;
int v; /* current vertex number */
int v0;
int eside; /* side of the current edge */
double eangle; /* current edge angle with Ox (according to the current direction) */
struct pg_vertex *vert; /* current vertex */
struct pg_vertex *vert0; /* last vertex */
struct pg_edge *edge; /* current edge; must be edge of vert */
/* int cs; *//* on which side are we turning along the contour */
/* we will always turn right and dont need that one */
double opt_angle, tangle;
int opt_j, opt_side, opt_flag;
G_debug(3,
@@ -657,15 +637,10 @@
int i;
int flag;
int v;
double min_x, min_angle;
G_debug(3, "extract_outer_contour()");
@@ -713,7 +688,6 @@
int i, w;
G_debug(3, "extract_inner_contour()");
@@ -750,13 +724,9 @@
double db, double dalpha)
int i, np;
double cx, cy;
double delta, delta_k, k;
double vx, vy, wx, wy, mx, my, nx, ny;
double len, tx, ty, d, da2;
G_debug(3, "point_in_buf()");
@@ -817,6 +787,7 @@
return 0;
@@ -825,7 +796,6 @@
static int get_polygon_orientation(const double *x, const double *y, int n)
double x1, y1, x2, y2;
double area;
x2 = x[n - 1];
@@ -841,6 +811,7 @@
area += (y2 + y1) * (x2 - x1);
return (area > 0);
@@ -856,6 +827,7 @@
(*arrPoints)[*count] = Points;
(*count)++;
return;
@@ -878,21 +850,13 @@
int *inner_count)
struct planar_graph *pg2;
struct line_pnts *sPoints, *cPoints;
struct line_pnts **arrPoints;
int i, count = 0;
int res, winding;
int auto_side;
int more = 8;
int allocated = 0;
double px, py;
G_debug(3, "buffer_lines()");
@@ -1002,17 +966,11 @@
struct line_pnts ***iPoints, int *inner_count)
struct planar_graph *pg;
struct line_pnts *tPoints, *outer;
struct line_pnts **isles;
int isles_count = 0;
int res, winding;
int more = 8;
int isles_allocated = 0;
G_debug(2, "Vect_line_buffer()");
@@ -1067,15 +1025,10 @@
int isles_count = 0, n_isles;
int i, isle;
int more = 8;
G_debug(2, "Vect_area_buffer()");
@@ -1089,7 +1042,8 @@
/* outer contour */
outer = Vect_new_line_struct();
Vect_get_area_points(Map, area, outer);
- Vect_append_point(outer, outer->x[0], outer->y[0], outer->z[0]);
+ /* does not work with zero length line segments */
+ Vect_line_prune(outer);
/* inner contours */
for (i = 0; i < n_isles; i++) {
@@ -1101,8 +1055,8 @@
if (Vect_line_length(tPoints) < 2*PI*max)
continue;
- Vect_append_point(tPoints, tPoints->x[0], tPoints->y[0],
- tPoints->z[0]);
+ Vect_line_prune(tPoints);
add_line_to_array(tPoints, &isles, &isles_count, &isles_allocated,
more);
tPoints = Vect_new_line_struct();
@@ -1135,9 +1089,7 @@
struct line_pnts **oPoints)
double tx, ty;
double angular_tol, angular_step, phi1;
int j, nsegments;
G_debug(2, "Vect_point_buffer()");
Modified: grass/branches/releasebranch_6_4/lib/vector/Vlib/snap.c
--- grass/branches/releasebranch_6_4/lib/vector/Vlib/snap.c 2011-01-26 17:22:48 UTC (rev 45197)
+++ grass/branches/releasebranch_6_4/lib/vector/Vlib/snap.c 2011-01-26 19:18:03 UTC (rev 45198)
@@ -205,10 +205,26 @@
dy = XPnts[pointb].y - XPnts[point].y;
dist2 = dx * dx + dy * dy;
- if (dist2 <= thresh2) {
+ if (dist2 > thresh2) /* outside threshold */
+ continue;
+ /* doesn't have an anchor yet */
+ if (XPnts[pointb].anchor == -1) {
XPnts[pointb].anchor = point;
ntosnap++;
+ else if (XPnts[pointb].anchor > 0) { /* check distance to previously assigned anchor */
+ double dist2_a;
+ dx = XPnts[XPnts[pointb].anchor].x - XPnts[pointb].x;
+ dy = XPnts[XPnts[pointb].anchor].y - XPnts[pointb].y;
+ dist2_a = dx * dx + dy * dy;
+ /* replace old anchor */
+ if (dist2 < dist2_a) {
+ XPnts[pointb].anchor = point;
@@ -445,7 +461,8 @@
if (!(ltype & type))
continue;
- Vect_list_append(List, line);
+ /* Vect_list_append(List, line); */
+ dig_list_add(List, line);
Vect_snap_lines_list(Map, List, thresh, Err);
