[GRASS-SVN] r45200 - grass/branches/develbranch_6/lib/vector/Vlib
Wed Jan 26 14:23:35 EST 2011
Author: mmetz
Date: 2011-01-26 11:23:35 -0800 (Wed, 26 Jan 2011)
New Revision: 45200
   grass/branches/develbranch_6/lib/vector/Vlib/buffer2.c
fix for #994
Modified: grass/branches/develbranch_6/lib/vector/Vlib/buffer2.c
--- grass/branches/develbranch_6/lib/vector/Vlib/buffer2.c	2011-01-26 19:22:44 UTC (rev 45199)
+++ grass/branches/develbranch_6/lib/vector/Vlib/buffer2.c	2011-01-26 19:23:35 UTC (rev 45200)
@@ -57,6 +57,7 @@
     l = LENGTH(dx, dy);
     *x = dx / l;
     *y = dy / l;
     return;
@@ -65,6 +66,7 @@
     *nx = x * cosa - y * sina;
     *ny = x * sina + y * cosa;
     return;
@@ -76,7 +78,6 @@
 			       double dalpha, double *nx, double *ny)
     double cosa = cos(dalpha);
     double sina = sin(dalpha);
     /*    double cc = cosa*cosa;
@@ -93,6 +94,7 @@
     vb = (x * (-sina) + y * cosa) * db;
     *nx = va * cosa + vb * (-sina);
     *ny = va * sina + vb * cosa;
     return;
@@ -106,9 +108,7 @@
 			     double dalpha, double *px, double *py)
     double u, v, len;
     /* rotate (x,y) -dalpha radians */
@@ -121,6 +121,7 @@
     u *= len;
     v *= len;
     rotate_vector(u, v, cosa, sina, px, py);
     return;
@@ -134,6 +135,7 @@
     *a = y2 - y1;
     *b = x1 - x2;
     *c = x2 * y1 - x1 * y2;
     return;
@@ -167,6 +169,7 @@
     if (tol > a)
 	tol = a;
     return 2 * acos(1 - tol / a);
@@ -187,19 +190,12 @@
 			  double tol, struct line_pnts *nPoints)
     int i, j, res, np;
     double *x, *y;
     double tx, ty, vx, vy, wx, wy, nx, ny, mx, my, rx, ry;
     double vx1, vy1, wx1, wy1;
     double a0, b0, c0, a1, b1, c1;
     double phi1, phi2, delta_phi;
     double nsegments, angular_tol, angular_step;
     int inner_corner, turns360;
     G_debug(3, "parallel_line()");
@@ -348,21 +344,13 @@
     int i, j, res, np;
     double *x, *y;
     double angle0, angle1;
     G_debug(3, "convolution_line() side = %d", side);
@@ -510,25 +498,17 @@
     int j;
     int v;			/* current vertex number */
     int v0;
     int eside;			/* side of the current edge */
     double eangle;		/* current edge angle with Ox (according to the current direction) */
     struct pg_vertex *vert;	/* current vertex */
     struct pg_vertex *vert0;	/* last vertex */
     struct pg_edge *edge;	/* current edge; must be edge of vert */
     /*    int cs; *//* on which side are we turning along the contour */
     /* we will always turn right and dont need that one */
     double opt_angle, tangle;
     int opt_j, opt_side, opt_flag;
     G_debug(3,
@@ -657,15 +637,10 @@
     int i;
     int flag;
     int v;
     double min_x, min_angle;
     G_debug(3, "extract_outer_contour()");
@@ -713,7 +688,6 @@
     int i, w;
     G_debug(3, "extract_inner_contour()");
@@ -750,13 +724,9 @@
 			double db, double dalpha)
     int i, np;
     double cx, cy;
     double delta, delta_k, k;
     double vx, vy, wx, wy, mx, my, nx, ny;
     double len, tx, ty, d, da2;
     G_debug(3, "point_in_buf()");
@@ -817,6 +787,7 @@
     return 0;
@@ -825,7 +796,6 @@
 static int get_polygon_orientation(const double *x, const double *y, int n)
     double x1, y1, x2, y2;
     double area;
     x2 = x[n - 1];
@@ -841,6 +811,7 @@
 	area += (y2 + y1) * (x2 - x1);
     return (area > 0);
@@ -856,6 +827,7 @@
     (*arrPoints)[*count] = Points;
     (*count)++;
     return;
@@ -878,21 +850,13 @@
 			 int *inner_count)
     struct planar_graph *pg2;
     struct line_pnts *sPoints, *cPoints;
     struct line_pnts **arrPoints;
     int i, count = 0;
     int res, winding;
     int auto_side;
     int more = 8;
     int allocated = 0;
     double px, py;
     G_debug(3, "buffer_lines()");
@@ -1002,17 +966,11 @@
 		       struct line_pnts ***iPoints, int *inner_count)
     struct planar_graph *pg;
     struct line_pnts *tPoints, *outer;
     struct line_pnts **isles;
     int isles_count = 0;
     int res, winding;
     int more = 8;
     int isles_allocated = 0;
     G_debug(2, "Vect_line_buffer()");
@@ -1067,15 +1025,10 @@
     int isles_count = 0, n_isles;
     int i, isle;
     int more = 8;
     G_debug(2, "Vect_area_buffer()");
@@ -1089,7 +1042,8 @@
     /* outer contour */
     outer = Vect_new_line_struct();
     Vect_get_area_points(Map, area, outer);
-    Vect_append_point(outer, outer->x[0], outer->y[0], outer->z[0]);
+    /* does not work with zero length line segments */
+    Vect_line_prune(outer);
     /* inner contours */
     for (i = 0; i < n_isles; i++) {
@@ -1101,8 +1055,8 @@
 	   if (Vect_line_length(tPoints) < 2*PI*max)
 	   continue;
-	Vect_append_point(tPoints, tPoints->x[0], tPoints->y[0],
-			  tPoints->z[0]);
+	Vect_line_prune(tPoints);
 	add_line_to_array(tPoints, &isles, &isles_count, &isles_allocated,
 			  more);
 	tPoints = Vect_new_line_struct();
@@ -1135,9 +1089,7 @@
 			struct line_pnts **oPoints)
     double tx, ty;
     double angular_tol, angular_step, phi1;
     int j, nsegments;
     G_debug(2, "Vect_point_buffer()");
