[GRASS-SVN] r45227 - grass/branches/releasebranch_6_4/vector/v.digit
svn_grass at osgeo.org
Fri Jan 28 05:38:44 EST 2011
Author: marisn
Date: 2011-01-28 02:38:44 -0800 (Fri, 28 Jan 2011)
New Revision: 45227
grass/branches/releasebranch_6_4/vector/v.digit/line.c
grass/branches/releasebranch_6_4/vector/v.digit/toolbox.tcl
v.digit Fix bind_scroll_list bug (#638), do not create points on mouse scroll. (merge from devel6 r44921 r44928 r44982)
Modified: grass/branches/releasebranch_6_4/vector/v.digit/line.c
--- grass/branches/releasebranch_6_4/vector/v.digit/line.c 2011-01-28 10:18:51 UTC (rev 45226)
+++ grass/branches/releasebranch_6_4/vector/v.digit/line.c 2011-01-28 10:38:44 UTC (rev 45227)
@@ -158,9 +158,11 @@
Tool_next = TOOL_NOTHING;
return 1;
+ if (button > 3) /* Do nothing on mouse scroll */
+ return 0;
- if (nl->type & GV_POINTS) {
- /* We can get here with button = 1 or 2 -> the same write point */
+ if (nl->type & GV_POINTS && (button == 1 || button == 2)) {
snap(&x, &y);
Vect_append_point(nl->Points, x, y, 0);
@@ -221,7 +223,7 @@
set_mode(MOUSE_POINT);
- else { /* button = 3 -> write the line and quit */
+ else if (button == 3) { /* write the line and quit */
if (nl->Points->n_points > 1) {
/* Before the line is written, we must check if connected to existing nodes, if yes,
* such nodes must be add to update list before! the line is written (areas/isles */
Modified: grass/branches/releasebranch_6_4/vector/v.digit/toolbox.tcl
--- grass/branches/releasebranch_6_4/vector/v.digit/toolbox.tcl 2011-01-28 10:18:51 UTC (rev 45226)
+++ grass/branches/releasebranch_6_4/vector/v.digit/toolbox.tcl 2011-01-28 10:38:44 UTC (rev 45227)
@@ -22,6 +22,7 @@
set prompt_middle [G_msg "Middle button"]
set prompt_right [G_msg "Right button"]
set coor ""
+set bind_scroll_list {}
wm title . "v.digit toolbox - $map_name@$map_mapset"
