[GRASS-SVN] r45234 -
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules
svn_grass at osgeo.org
Fri Jan 28 08:21:37 EST 2011
Author: martinl
Date: 2011-01-28 05:21:36 -0800 (Fri, 28 Jan 2011)
New Revision: 45234
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gcpmanager.py
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gdialogs.py
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/goutput.py
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/histogram.py
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/layertree.py
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/mapdisp.py
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/utils.py
wxGUI: fix histogram dialog when raster map is not found
(merge r45230 from trunk)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gcpmanager.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gcpmanager.py 2011-01-28 13:12:49 UTC (rev 45233)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gcpmanager.py 2011-01-28 13:21:36 UTC (rev 45234)
@@ -15,7 +15,7 @@
- EditGCP
- GrSettingsDialog
-(C) 2006-2010 by the GRASS Development Team
+(C) 2006-2011 by the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
@@ -209,9 +209,9 @@
cmdlist = ['d.vect', 'map=%s' % src_map]
self.SwitchEnv('source')
+ name, found = utils.GetLayerNameFromCmd(cmdlist)
self.SrcMap.AddLayer(type=rendertype, command=cmdlist, l_active=True,
- name=utils.GetLayerNameFromCmd(cmdlist),
- l_hidden=False, l_opacity=1.0, l_render=False)
+ name=name, l_hidden=False, l_opacity=1.0, l_render=False)
if tgt_map:
@@ -225,9 +225,9 @@
cmdlist = ['d.vect', 'map=%s' % tgt_map]
self.SwitchEnv('target')
self.TgtMap.AddLayer(type=rendertype, command=cmdlist, l_active=True,
# start GCP Manager
@@ -2717,9 +2717,9 @@
src_map = self.new_src_map
cmdlist = ['d.rast', 'map=%s' % src_map]
self.parent.grwiz.SwitchEnv('source')
+ name, found = utils.GetLayerNameFromCmd(cmdlist),
self.parent.grwiz.SrcMap.AddLayer(type='raster', command=cmdlist, l_active=True,
self.parent.grwiz.SwitchEnv('target')
srcrender = True
@@ -2733,9 +2733,9 @@
if tgt_map != '':
cmdlist = ['d.rast', 'map=%s' % tgt_map]
self.parent.grwiz.TgtMap.AddLayer(type='raster', command=cmdlist, l_active=True,
tgtrender = True
if self.parent.show_target == False:
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gdialogs.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gdialogs.py 2011-01-28 13:12:49 UTC (rev 45233)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gdialogs.py 2011-01-28 13:21:36 UTC (rev 45234)
@@ -462,13 +462,13 @@
self._CreateOverlay()
if len(self.parent.MapWindow.overlays[self.ovlId]['cmd']) > 1:
- mapName = utils.GetLayerNameFromCmd(self.parent.MapWindow.overlays[self.ovlId]['cmd'])
+ mapName, found = utils.GetLayerNameFromCmd(self.parent.MapWindow.overlays[self.ovlId]['cmd'])
if self.parent.MapWindow.overlays[self.ovlId]['propwin'] is None and mapName:
# build properties dialog
menuform.GUI().ParseCommand(cmd=self.cmd,
completed=(self.GetOptData, self.name, ''),
parentframe=self.parent, show=False)
- if mapName:
+ if found:
# enable 'OK' button
self.btnOK.Enable()
if name == 'legend':
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/goutput.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/goutput.py 2011-01-28 13:12:49 UTC (rev 45233)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/goutput.py 2011-01-28 13:21:36 UTC (rev 45234)
@@ -482,11 +482,11 @@
# add layer into layer tree
if command[0] == 'd.rast':
- lname = utils.GetLayerNameFromCmd(command, fullyQualified = True,
- layerType = 'raster')
+ lname, found = utils.GetLayerNameFromCmd(command, fullyQualified = True,
+ layerType = 'raster')
elif command[0] == 'd.vect':
- layerType = 'vector')
+ layerType = 'vector')
else:
lname = None
@@ -790,7 +790,8 @@
if prompt in ('raster', 'vector', '3d-raster') and \
p.get('age', 'old') == 'new' and \
p.get('value', None):
- name = utils.GetLayerNameFromCmd(cmd, fullyQualified=True, param = p.get('name', ''))
+ name, found = utils.GetLayerNameFromCmd(cmd, fullyQualified = True,
+ param = p.get('name', ''))
if mapTree.GetMap().GetListOfLayers(l_name = name):
continue
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/histogram.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/histogram.py 2011-01-28 13:12:49 UTC (rev 45233)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/histogram.py 2011-01-28 13:21:36 UTC (rev 45234)
@@ -7,12 +7,12 @@
- BufferedWindow
- HistFrame
-COPYRIGHT: (C) 2007, 2010 by the GRASS Development Team
+COPYRIGHT: (C) 2007, 2010-2011 by the GRASS Development Team
@author Michael Barton
- at author Various updates by Martin Landa
+ at author Various updates by Martin Landa <landa.martin gmail.com>
import os
@@ -30,6 +30,7 @@
from preferences import DefaultFontDialog
from debug import Debug
from icon import Icons
+from gcmd import GError
class BufferedWindow(wx.Window):
"""!A Buffered window class.
@@ -244,7 +245,7 @@
# update statusbar
# Debug.msg (3, "BufferedWindow.UpdateHist(%s): region=%s" % self.Map.region)
self.Map.SetRegion()
- self.parent.statusbar.SetStatusText("Raster/Image map layer <%s>" % self.parent.mapname)
+ self.parent.statusbar.SetStatusText("Image/Raster map <%s>" % self.parent.mapname)
# set default font and encoding environmental variables
if oldfont != "":
@@ -325,7 +326,13 @@
created in menuform.py
if dcmd:
- name = utils.GetLayerNameFromCmd(dcmd, fullyQualified = True)
+ name, found = utils.GetLayerNameFromCmd(dcmd, fullyQualified = True,
+ if not found:
+ GError(parent = propwin,
+ message = _("Raster map <%s> not found") % name)
+ return
self.SetHistLayer(name)
self.params = params
self.propwin = propwin
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/layertree.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/layertree.py 2011-01-28 13:12:49 UTC (rev 45233)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/layertree.py 2011-01-28 13:21:36 UTC (rev 45234)
@@ -791,7 +791,7 @@
if lcmd and len(lcmd) > 1:
cmd = lcmd
render = False
- name = utils.GetLayerNameFromCmd(lcmd)
+ name, found = utils.GetLayerNameFromCmd(lcmd)
else:
cmd = []
if ltype == 'command' and lname:
@@ -1316,9 +1316,9 @@
opacity = int(mapLayer.GetOpacity(float = True) * 100)
if not mapname:
dcmd = self.GetPyData(item)[0]['cmd']
- mapname = utils.GetLayerNameFromCmd(dcmd, layerType = mapLayer.GetType(),
- fullyQualified = True)
- if not mapname:
+ mapname, found = utils.GetLayerNameFromCmd(dcmd, layerType = mapLayer.GetType(),
+ fullyQualified = True)
+ if not found:
return None
return mapname + ' (%s %d' % (_('opacity:'), opacity) + '%)'
@@ -1330,16 +1330,10 @@
if dcmd:
self.GetPyData(layer)[0]['cmd'] = dcmd
mapText = self._getLayerName(layer)
- mapName = utils.GetLayerNameFromCmd(dcmd)
+ mapName, found = utils.GetLayerNameFromCmd(dcmd)
mapLayer = self.GetPyData(layer)[0]['maplayer']
self.SetItemText(layer, mapName)
- found = True
- if mapLayer and \
- mapLayer.GetType() in ('raster', '3d-raster', 'vector') and \
- not grass.find_file(name = mapName, element = mapLayer.GetElement())['fullname']:
- found = False
if not mapText or not found:
propwin.Hide()
GWarning(parent = self,
@@ -1447,8 +1441,8 @@
chk = self.IsItemChecked(item)
hidden = not self.IsVisible(item)
# determine layer name
- layerName = utils.GetLayerNameFromCmd(cmdlist, fullyQualified=True)
- if not layerName:
+ layerName, found = utils.GetLayerNameFromCmd(cmdlist, fullyQualified = True)
+ if not found:
layerName = self.GetItemText(item)
maplayer = self.Map.ChangeLayer(layer=self.GetPyData(item)[0]['maplayer'], type=type,
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/mapdisp.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/mapdisp.py 2011-01-28 13:12:49 UTC (rev 45233)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/mapdisp.py 2011-01-28 13:21:36 UTC (rev 45234)
@@ -1284,8 +1284,8 @@
for layer in self.tree.GetSelections():
type = self.tree.GetPyData(layer)[0]['maplayer'].GetType()
dcmd = self.tree.GetPyData(layer)[0]['cmd']
- name = utils.GetLayerNameFromCmd(dcmd)
- if name == '':
+ name, found = utils.GetLayerNameFromCmd(dcmd)
+ if not found:
continue
if type in ('raster', 'rgb', 'his'):
raststr += "%s," % name
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/utils.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/utils.py 2011-01-28 13:12:49 UTC (rev 45233)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/utils.py 2011-01-28 13:21:36 UTC (rev 45234)
@@ -42,8 +42,7 @@
return shlex.split(s)
def GetTempfile(pref=None):
- Creates GRASS temporary file using defined prefix.
+ """!Creates GRASS temporary file using defined prefix.
@todo Fix path on MS Windows/MSYS
@@ -78,17 +77,16 @@
@param dcmd GRASS command (given as list)
@param fullyQualified change map name to be fully qualified
- @param force parameter otherwise 'input'/'map'
- @param update change map name in command
+ @param param params directory
@param layerType check also layer type ('raster', 'vector', '3d-raster', ...)
- @return map name
- @return '' if no map name found in command
+ @return tuple (name, found)
mapname = ''
+ found = True
if len(dcmd) < 1:
- return mapname
+ return mapname, False
if 'd.grid' == dcmd[0]:
mapname = 'grid'
@@ -120,7 +118,7 @@
if len(dcmd) > 1 and '=' not in dcmd[1]:
params.append((1, None, dcmd[1]))
else:
- return mapname
mapname = params[0][2]
mapset = ''
@@ -131,20 +129,22 @@
findType = 'cell'
else:
findType = layerType
- mapset = grass.find_file(mapname, element=findType)['mapset']
+ mapset = grass.find_file(mapname, element = findType)['mapset']
except AttributeError, e: # not found
- return ''
+ return '', False
if not mapset:
- mapset = grass.gisenv()['MAPSET']
+ found = False
else:
# update dcmd
for i, p, v in params:
if p:
- dcmd[i] = p + '=' + v + '@' + mapset
+ dcmd[i] = p + '=' + v
else:
- dcmd[i] = v + '@' + mapset
+ dcmd[i] = v
+ if mapset:
+ dcmd[i] += '@' + mapset
maps = list()
@@ -154,7 +154,7 @@
maps.append(dcmd[i].split('=', 1)[1])
mapname = '\n'.join(maps)
- return mapname
+ return mapname, found
def GetValidLayerName(name):
"""!Make layer name SQL compliant, based on G_str_to_sql()
