[GRASS-SVN] r45245 - in grass/branches/releasebranch_6_4/scripts:
d.correlate d.out.gpsdrive d.out.png d.polar d.resize
d.vect.thematic db.dropcol db.droptable db.in.ogr db.out.ogr
g.mremove i.image.mosaic i.in.spotvgt i.landsat.rgb i.oif
r.fillnulls r.in.srtm r.out.gdal r.plane r.reclass.area
r.regression.line r.shaded.relief r.univar.sh v.db.addcol
v.db.addtable v.db.dropcol v.db.droptable v.db.join
v.db.renamecol v.db.univar v.db.update v.in.e00 v.in.garmin
v.in.geonames v.in.gns v.in.gpsbabel v.in.mapgen
v.out.gpsbabel v.rast.stats v.univar.sh
svn_grass at osgeo.org
Sat Jan 29 19:27:07 EST 2011
Author: neteler
Date: 2011-01-29 16:27:07 -0800 (Sat, 29 Jan 2011)
New Revision: 45245
grass/branches/releasebranch_6_4/scripts/d.correlate/d.correlate
grass/branches/releasebranch_6_4/scripts/d.out.gpsdrive/d.out.gpsdrive
grass/branches/releasebranch_6_4/scripts/d.out.png/d.out.png
grass/branches/releasebranch_6_4/scripts/d.polar/d.polar
grass/branches/releasebranch_6_4/scripts/d.resize/d.resize
grass/branches/releasebranch_6_4/scripts/d.vect.thematic/d.vect.thematic
grass/branches/releasebranch_6_4/scripts/db.dropcol/db.dropcol
grass/branches/releasebranch_6_4/scripts/db.droptable/db.droptable
grass/branches/releasebranch_6_4/scripts/db.in.ogr/db.in.ogr
grass/branches/releasebranch_6_4/scripts/db.out.ogr/db.out.ogr
grass/branches/releasebranch_6_4/scripts/g.mremove/g.mremove
grass/branches/releasebranch_6_4/scripts/i.image.mosaic/i.image.mosaic
grass/branches/releasebranch_6_4/scripts/i.in.spotvgt/i.in.spotvgt
grass/branches/releasebranch_6_4/scripts/i.landsat.rgb/i.landsat.rgb
grass/branches/releasebranch_6_4/scripts/i.oif/i.oifcalc
grass/branches/releasebranch_6_4/scripts/r.fillnulls/r.fillnulls
grass/branches/releasebranch_6_4/scripts/r.in.srtm/r.in.srtm
grass/branches/releasebranch_6_4/scripts/r.out.gdal/r.out.gdal.sh
grass/branches/releasebranch_6_4/scripts/r.plane/r.plane
grass/branches/releasebranch_6_4/scripts/r.reclass.area/r.reclass.area
grass/branches/releasebranch_6_4/scripts/r.regression.line/r.regression.line
grass/branches/releasebranch_6_4/scripts/r.shaded.relief/r.shaded.relief
grass/branches/releasebranch_6_4/scripts/r.univar.sh/r.univar.sh
grass/branches/releasebranch_6_4/scripts/v.db.addcol/v.db.addcol
grass/branches/releasebranch_6_4/scripts/v.db.addtable/v.db.addtable
grass/branches/releasebranch_6_4/scripts/v.db.dropcol/v.db.dropcol
grass/branches/releasebranch_6_4/scripts/v.db.droptable/v.db.droptable
grass/branches/releasebranch_6_4/scripts/v.db.join/v.db.join
grass/branches/releasebranch_6_4/scripts/v.db.renamecol/v.db.renamecol
grass/branches/releasebranch_6_4/scripts/v.db.univar/v.db.univar
grass/branches/releasebranch_6_4/scripts/v.db.update/v.db.update
grass/branches/releasebranch_6_4/scripts/v.in.e00/v.in.e00
grass/branches/releasebranch_6_4/scripts/v.in.garmin/v.in.garmin
grass/branches/releasebranch_6_4/scripts/v.in.geonames/v.in.geonames
grass/branches/releasebranch_6_4/scripts/v.in.gns/v.in.gns
grass/branches/releasebranch_6_4/scripts/v.in.gpsbabel/v.in.gpsbabel
grass/branches/releasebranch_6_4/scripts/v.in.mapgen/v.in.mapgen
grass/branches/releasebranch_6_4/scripts/v.out.gpsbabel/v.out.gpsbabel
grass/branches/releasebranch_6_4/scripts/v.rast.stats/v.rast.stats
grass/branches/releasebranch_6_4/scripts/v.univar.sh/v.univar.sh
quoting of variable fixes, esp. for windows
Modified: grass/branches/releasebranch_6_4/scripts/d.correlate/d.correlate
--- grass/branches/releasebranch_6_4/scripts/d.correlate/d.correlate 2011-01-30 00:10:58 UTC (rev 45244)
+++ grass/branches/releasebranch_6_4/scripts/d.correlate/d.correlate 2011-01-30 00:27:07 UTC (rev 45245)
@@ -62,7 +62,7 @@
exec g.parser "$0" "$@"
fi
-PROG=`basename $0`
+PROG="`basename $0`"
#### check if we have awk
if [ ! -x "`which awk`" ] ; then
Modified: grass/branches/releasebranch_6_4/scripts/d.out.gpsdrive/d.out.gpsdrive
--- grass/branches/releasebranch_6_4/scripts/d.out.gpsdrive/d.out.gpsdrive 2011-01-30 00:10:58 UTC (rev 45244)
+++ grass/branches/releasebranch_6_4/scripts/d.out.gpsdrive/d.out.gpsdrive 2011-01-30 00:27:07 UTC (rev 45245)
@@ -89,7 +89,7 @@
fi
-PROG=`basename $0`
Modified: grass/branches/releasebranch_6_4/scripts/d.out.png/d.out.png
--- grass/branches/releasebranch_6_4/scripts/d.out.png/d.out.png 2011-01-30 00:10:58 UTC (rev 45244)
+++ grass/branches/releasebranch_6_4/scripts/d.out.png/d.out.png 2011-01-30 00:27:07 UTC (rev 45245)
@@ -46,7 +46,7 @@
g.message -w "This module has been superseded. Please use d.out.file instead."
-PROG=`basename $0`
Modified: grass/branches/releasebranch_6_4/scripts/d.polar/d.polar
--- grass/branches/releasebranch_6_4/scripts/d.polar/d.polar 2011-01-30 00:10:58 UTC (rev 45244)
+++ grass/branches/releasebranch_6_4/scripts/d.polar/d.polar 2011-01-30 00:27:07 UTC (rev 45245)
@@ -57,7 +57,7 @@
fi
-PROG=`basename $0`
Modified: grass/branches/releasebranch_6_4/scripts/d.resize/d.resize
--- grass/branches/releasebranch_6_4/scripts/d.resize/d.resize 2011-01-30 00:10:58 UTC (rev 45244)
+++ grass/branches/releasebranch_6_4/scripts/d.resize/d.resize 2011-01-30 00:27:07 UTC (rev 45245)
@@ -42,7 +42,7 @@
fi
-PROG=`basename $0`
Modified: grass/branches/releasebranch_6_4/scripts/d.vect.thematic/d.vect.thematic
--- grass/branches/releasebranch_6_4/scripts/d.vect.thematic/d.vect.thematic 2011-01-30 00:10:58 UTC (rev 45244)
+++ grass/branches/releasebranch_6_4/scripts/d.vect.thematic/d.vect.thematic 2011-01-30 00:27:07 UTC (rev 45245)
@@ -232,7 +232,7 @@
fi
-PROG=`basename $0`
Modified: grass/branches/releasebranch_6_4/scripts/db.dropcol/db.dropcol
--- grass/branches/releasebranch_6_4/scripts/db.dropcol/db.dropcol 2011-01-30 00:10:58 UTC (rev 45244)
+++ grass/branches/releasebranch_6_4/scripts/db.dropcol/db.dropcol 2011-01-30 00:27:07 UTC (rev 45245)
@@ -53,7 +53,7 @@
fi
-PROG=`basename $0`
Modified: grass/branches/releasebranch_6_4/scripts/db.droptable/db.droptable
--- grass/branches/releasebranch_6_4/scripts/db.droptable/db.droptable 2011-01-30 00:10:58 UTC (rev 45244)
+++ grass/branches/releasebranch_6_4/scripts/db.droptable/db.droptable 2011-01-30 00:27:07 UTC (rev 45245)
@@ -42,7 +42,7 @@
fi
-PROG=`basename $0`
# setting environment, so that awk works properly in all languages
unset LC_ALL
Modified: grass/branches/releasebranch_6_4/scripts/db.in.ogr/db.in.ogr
--- grass/branches/releasebranch_6_4/scripts/db.in.ogr/db.in.ogr 2011-01-30 00:10:58 UTC (rev 45244)
+++ grass/branches/releasebranch_6_4/scripts/db.in.ogr/db.in.ogr 2011-01-30 00:27:07 UTC (rev 45245)
@@ -59,7 +59,7 @@
fi
-PROG=`basename $0`
unset LC_ALL
Modified: grass/branches/releasebranch_6_4/scripts/db.out.ogr/db.out.ogr
--- grass/branches/releasebranch_6_4/scripts/db.out.ogr/db.out.ogr 2011-01-30 00:10:58 UTC (rev 45244)
+++ grass/branches/releasebranch_6_4/scripts/db.out.ogr/db.out.ogr 2011-01-30 00:27:07 UTC (rev 45245)
@@ -62,7 +62,7 @@
fi
-PROG=`basename $0`
unset LC_ALL
Modified: grass/branches/releasebranch_6_4/scripts/g.mremove/g.mremove
--- grass/branches/releasebranch_6_4/scripts/g.mremove/g.mremove 2011-01-30 00:10:58 UTC (rev 45244)
+++ grass/branches/releasebranch_6_4/scripts/g.mremove/g.mremove 2011-01-30 00:27:07 UTC (rev 45245)
@@ -101,7 +101,7 @@
: ${GISBASE?} ${GISDBASE?} ${LOCATION_NAME?} ${MAPSET?}
LOCATION=$GISDBASE/$LOCATION_NAME/$MAPSET
-program=`basename $0`
g.message "Collecting map names for current mapset <$MAPSET>..."
Modified: grass/branches/releasebranch_6_4/scripts/i.image.mosaic/i.image.mosaic
--- grass/branches/releasebranch_6_4/scripts/i.image.mosaic/i.image.mosaic 2011-01-30 00:10:58 UTC (rev 45244)
+++ grass/branches/releasebranch_6_4/scripts/i.image.mosaic/i.image.mosaic 2011-01-30 00:27:07 UTC (rev 45245)
@@ -69,7 +69,7 @@
fi
-PROG=`basename $0`
Modified: grass/branches/releasebranch_6_4/scripts/i.in.spotvgt/i.in.spotvgt
--- grass/branches/releasebranch_6_4/scripts/i.in.spotvgt/i.in.spotvgt 2011-01-30 00:10:58 UTC (rev 45244)
+++ grass/branches/releasebranch_6_4/scripts/i.in.spotvgt/i.in.spotvgt 2011-01-30 00:27:07 UTC (rev 45245)
@@ -171,7 +171,7 @@
if [ -n "$GIS_OPT_FILE" ] ; then
SPOTDIR="`dirname $GIS_OPT_FILE`"
- SPOTNAME=`basename $GIS_OPT_FILE .HDF`
+ SPOTNAME=`basename "$GIS_OPT_FILE" .HDF`
fi
if [ -n "$GIS_OPT_RAST" ] ; then
Modified: grass/branches/releasebranch_6_4/scripts/i.landsat.rgb/i.landsat.rgb
--- grass/branches/releasebranch_6_4/scripts/i.landsat.rgb/i.landsat.rgb 2011-01-30 00:10:58 UTC (rev 45244)
+++ grass/branches/releasebranch_6_4/scripts/i.landsat.rgb/i.landsat.rgb 2011-01-30 00:27:07 UTC (rev 45245)
@@ -92,7 +92,7 @@
LC_NUMERIC=C
export LC_NUMERIC
-PROG=`basename $0`
BLUE="$GIS_OPT_BLUE"
GREEN="$GIS_OPT_GREEN"
Modified: grass/branches/releasebranch_6_4/scripts/i.oif/i.oifcalc
--- grass/branches/releasebranch_6_4/scripts/i.oif/i.oifcalc 2011-01-30 00:10:58 UTC (rev 45244)
+++ grass/branches/releasebranch_6_4/scripts/i.oif/i.oifcalc 2011-01-30 00:27:07 UTC (rev 45245)
@@ -15,7 +15,7 @@
exit 1
fi
-PROG=`basename $0`
Modified: grass/branches/releasebranch_6_4/scripts/r.fillnulls/r.fillnulls
--- grass/branches/releasebranch_6_4/scripts/r.fillnulls/r.fillnulls 2011-01-30 00:10:58 UTC (rev 45244)
+++ grass/branches/releasebranch_6_4/scripts/r.fillnulls/r.fillnulls 2011-01-30 00:27:07 UTC (rev 45245)
@@ -66,8 +66,9 @@
export CMDLINE
fi
-PROG=`basename $0`
g.message -e "awk required, please install awk or gawk first"
@@ -101,8 +102,6 @@
# shell check for user break (signal list: trap -l)
trap "exitprocedure" 2 3 15
#test:
if [ ! $GIS_OPT_INPUT ]
then
Modified: grass/branches/releasebranch_6_4/scripts/r.in.srtm/r.in.srtm
--- grass/branches/releasebranch_6_4/scripts/r.in.srtm/r.in.srtm 2011-01-30 00:10:58 UTC (rev 45244)
+++ grass/branches/releasebranch_6_4/scripts/r.in.srtm/r.in.srtm 2011-01-30 00:27:07 UTC (rev 45245)
@@ -89,7 +89,7 @@
fi
-PROG=`basename $0`
Modified: grass/branches/releasebranch_6_4/scripts/r.out.gdal/r.out.gdal.sh
--- grass/branches/releasebranch_6_4/scripts/r.out.gdal/r.out.gdal.sh 2011-01-30 00:10:58 UTC (rev 45244)
+++ grass/branches/releasebranch_6_4/scripts/r.out.gdal/r.out.gdal.sh 2011-01-30 00:27:07 UTC (rev 45245)
@@ -74,7 +74,7 @@
fi
-PROG=`basename $0`
g.message -w "This module is superseded and will be removed in future \
versions of GRASS. Use the much faster r.out.gdal instead."
Modified: grass/branches/releasebranch_6_4/scripts/r.plane/r.plane
--- grass/branches/releasebranch_6_4/scripts/r.plane/r.plane 2011-01-30 00:10:58 UTC (rev 45244)
+++ grass/branches/releasebranch_6_4/scripts/r.plane/r.plane 2011-01-30 00:27:07 UTC (rev 45245)
@@ -77,7 +77,7 @@
fi
-PROG=`basename $0`
Modified: grass/branches/releasebranch_6_4/scripts/r.reclass.area/r.reclass.area
--- grass/branches/releasebranch_6_4/scripts/r.reclass.area/r.reclass.area 2011-01-30 00:10:58 UTC (rev 45244)
+++ grass/branches/releasebranch_6_4/scripts/r.reclass.area/r.reclass.area 2011-01-30 00:27:07 UTC (rev 45245)
@@ -61,7 +61,7 @@
fi
-PROG=`basename $0`
Modified: grass/branches/releasebranch_6_4/scripts/r.regression.line/r.regression.line
--- grass/branches/releasebranch_6_4/scripts/r.regression.line/r.regression.line 2011-01-30 00:10:58 UTC (rev 45244)
+++ grass/branches/releasebranch_6_4/scripts/r.regression.line/r.regression.line 2011-01-30 00:27:07 UTC (rev 45245)
@@ -58,7 +58,7 @@
fi
-PROG=`basename $0`
Modified: grass/branches/releasebranch_6_4/scripts/r.shaded.relief/r.shaded.relief
--- grass/branches/releasebranch_6_4/scripts/r.shaded.relief/r.shaded.relief 2011-01-30 00:10:58 UTC (rev 45244)
+++ grass/branches/releasebranch_6_4/scripts/r.shaded.relief/r.shaded.relief 2011-01-30 00:27:07 UTC (rev 45245)
@@ -122,7 +122,7 @@
#nsres=`g.region -g | grep 'nsres=' | sed s/nsres=//`
#ewres=`g.region -g | grep 'ewres=' | sed s/ewres=//`
-PROG=`basename $0`
unset LC_ALL
Modified: grass/branches/releasebranch_6_4/scripts/r.univar.sh/r.univar.sh
--- grass/branches/releasebranch_6_4/scripts/r.univar.sh/r.univar.sh 2011-01-30 00:10:58 UTC (rev 45244)
+++ grass/branches/releasebranch_6_4/scripts/r.univar.sh/r.univar.sh 2011-01-30 00:27:07 UTC (rev 45245)
@@ -49,9 +49,8 @@
versions of GRASS. Use the much faster r.univar instead."
-PROG=`basename $0`
Modified: grass/branches/releasebranch_6_4/scripts/v.db.addcol/v.db.addcol
--- grass/branches/releasebranch_6_4/scripts/v.db.addcol/v.db.addcol 2011-01-30 00:10:58 UTC (rev 45244)
+++ grass/branches/releasebranch_6_4/scripts/v.db.addcol/v.db.addcol 2011-01-30 00:27:07 UTC (rev 45245)
@@ -63,7 +63,7 @@
fi
-PROG=`basename "$0"`
Modified: grass/branches/releasebranch_6_4/scripts/v.db.addtable/v.db.addtable
--- grass/branches/releasebranch_6_4/scripts/v.db.addtable/v.db.addtable 2011-01-30 00:10:58 UTC (rev 45244)
+++ grass/branches/releasebranch_6_4/scripts/v.db.addtable/v.db.addtable 2011-01-30 00:27:07 UTC (rev 45245)
@@ -64,7 +64,7 @@
fi
-PROG=`basename $0`
Modified: grass/branches/releasebranch_6_4/scripts/v.db.dropcol/v.db.dropcol
--- grass/branches/releasebranch_6_4/scripts/v.db.dropcol/v.db.dropcol 2011-01-30 00:10:58 UTC (rev 45244)
+++ grass/branches/releasebranch_6_4/scripts/v.db.dropcol/v.db.dropcol 2011-01-30 00:27:07 UTC (rev 45245)
@@ -62,7 +62,7 @@
fi
-PROG=`basename $0`
#### setup temporary file
TEMPFILE="`g.tempfile pid=$$`"
Modified: grass/branches/releasebranch_6_4/scripts/v.db.droptable/v.db.droptable
--- grass/branches/releasebranch_6_4/scripts/v.db.droptable/v.db.droptable 2011-01-30 00:10:58 UTC (rev 45244)
+++ grass/branches/releasebranch_6_4/scripts/v.db.droptable/v.db.droptable 2011-01-30 00:27:07 UTC (rev 45245)
@@ -58,7 +58,7 @@
fi
-PROG=`basename $0`
Modified: grass/branches/releasebranch_6_4/scripts/v.db.join/v.db.join
--- grass/branches/releasebranch_6_4/scripts/v.db.join/v.db.join 2011-01-30 00:10:58 UTC (rev 45244)
+++ grass/branches/releasebranch_6_4/scripts/v.db.join/v.db.join 2011-01-30 00:27:07 UTC (rev 45245)
@@ -75,7 +75,7 @@
fi
-PROG=`basename $0`
driver=`v.db.connect -g map="$GIS_OPT_MAP" fs=";" | grep "^$GIS_OPT_LAYER" | cut -d';' -f5`
database=`v.db.connect -g map="$GIS_OPT_MAP" fs=";" | grep "^$GIS_OPT_LAYER" | cut -d';' -f4`
Modified: grass/branches/releasebranch_6_4/scripts/v.db.renamecol/v.db.renamecol
--- grass/branches/releasebranch_6_4/scripts/v.db.renamecol/v.db.renamecol 2011-01-30 00:10:58 UTC (rev 45244)
+++ grass/branches/releasebranch_6_4/scripts/v.db.renamecol/v.db.renamecol 2011-01-30 00:27:07 UTC (rev 45245)
@@ -62,9 +62,8 @@
fi
-PROG=`basename $0`
# what to do in case of user break:
exitprocedure()
Modified: grass/branches/releasebranch_6_4/scripts/v.db.univar/v.db.univar
--- grass/branches/releasebranch_6_4/scripts/v.db.univar/v.db.univar 2011-01-30 00:10:58 UTC (rev 45244)
+++ grass/branches/releasebranch_6_4/scripts/v.db.univar/v.db.univar 2011-01-30 00:27:07 UTC (rev 45245)
@@ -63,7 +63,7 @@
fi
-PROG=`basename $0`
Modified: grass/branches/releasebranch_6_4/scripts/v.db.update/v.db.update
--- grass/branches/releasebranch_6_4/scripts/v.db.update/v.db.update 2011-01-30 00:10:58 UTC (rev 45244)
+++ grass/branches/releasebranch_6_4/scripts/v.db.update/v.db.update 2011-01-30 00:27:07 UTC (rev 45245)
@@ -75,7 +75,7 @@
fi
-PROG=`basename $0`
Modified: grass/branches/releasebranch_6_4/scripts/v.in.e00/v.in.e00
--- grass/branches/releasebranch_6_4/scripts/v.in.e00/v.in.e00 2011-01-30 00:10:58 UTC (rev 45244)
+++ grass/branches/releasebranch_6_4/scripts/v.in.e00/v.in.e00 2011-01-30 00:27:07 UTC (rev 45245)
@@ -65,7 +65,7 @@
fi
-PROG=`basename $0`
Modified: grass/branches/releasebranch_6_4/scripts/v.in.garmin/v.in.garmin
--- grass/branches/releasebranch_6_4/scripts/v.in.garmin/v.in.garmin 2011-01-30 00:10:58 UTC (rev 45244)
+++ grass/branches/releasebranch_6_4/scripts/v.in.garmin/v.in.garmin 2011-01-30 00:27:07 UTC (rev 45245)
@@ -109,7 +109,7 @@
LOCATION="$GISDBASE"/"$LOCATION_NAME"/"$MAPSET"
-PROG=`basename $0`
if [ $GIS_FLAG_U -eq 0 ] ; then
#### check for gpstrans
Modified: grass/branches/releasebranch_6_4/scripts/v.in.geonames/v.in.geonames
--- grass/branches/releasebranch_6_4/scripts/v.in.geonames/v.in.geonames 2011-01-30 00:10:58 UTC (rev 45244)
+++ grass/branches/releasebranch_6_4/scripts/v.in.geonames/v.in.geonames 2011-01-30 00:27:07 UTC (rev 45245)
@@ -57,7 +57,7 @@
fi
-PROG=`basename $0`
@@ -80,8 +80,8 @@
if [ -n "$GIS_OPT_VECT" ] ; then
FILE="$GIS_OPT_VECT"
else
- FILE=`basename $FILEORIG .txt`
- FILE=`basename $FILE .csv`
+ FILE=`basename "$FILEORIG" .txt`
+ FILE=`basename "$FILE" .csv`
fi
fi
Modified: grass/branches/releasebranch_6_4/scripts/v.in.gns/v.in.gns
--- grass/branches/releasebranch_6_4/scripts/v.in.gns/v.in.gns 2011-01-30 00:10:58 UTC (rev 45244)
+++ grass/branches/releasebranch_6_4/scripts/v.in.gns/v.in.gns 2011-01-30 00:27:07 UTC (rev 45245)
@@ -57,7 +57,7 @@
fi
-PROG=`basename $0`
@@ -80,7 +80,7 @@
else
fi
fi
Modified: grass/branches/releasebranch_6_4/scripts/v.in.gpsbabel/v.in.gpsbabel
--- grass/branches/releasebranch_6_4/scripts/v.in.gpsbabel/v.in.gpsbabel 2011-01-30 00:10:58 UTC (rev 45244)
+++ grass/branches/releasebranch_6_4/scripts/v.in.gpsbabel/v.in.gpsbabel 2011-01-30 00:27:07 UTC (rev 45245)
@@ -113,7 +113,7 @@
-PROG=`basename $0`
#### check for gpsbabel
if [ ! -x "`which gpsbabel`" ] ; then
Modified: grass/branches/releasebranch_6_4/scripts/v.in.mapgen/v.in.mapgen
--- grass/branches/releasebranch_6_4/scripts/v.in.mapgen/v.in.mapgen 2011-01-30 00:10:58 UTC (rev 45244)
+++ grass/branches/releasebranch_6_4/scripts/v.in.mapgen/v.in.mapgen 2011-01-30 00:27:07 UTC (rev 45245)
@@ -59,7 +59,7 @@
fi
-PROG=`basename $0`
Modified: grass/branches/releasebranch_6_4/scripts/v.out.gpsbabel/v.out.gpsbabel
--- grass/branches/releasebranch_6_4/scripts/v.out.gpsbabel/v.out.gpsbabel 2011-01-30 00:10:58 UTC (rev 45244)
+++ grass/branches/releasebranch_6_4/scripts/v.out.gpsbabel/v.out.gpsbabel 2011-01-30 00:27:07 UTC (rev 45245)
@@ -124,7 +124,7 @@
-PROG=`basename $0`
Modified: grass/branches/releasebranch_6_4/scripts/v.rast.stats/v.rast.stats
--- grass/branches/releasebranch_6_4/scripts/v.rast.stats/v.rast.stats 2011-01-30 00:10:58 UTC (rev 45244)
+++ grass/branches/releasebranch_6_4/scripts/v.rast.stats/v.rast.stats 2011-01-30 00:27:07 UTC (rev 45245)
@@ -75,7 +75,7 @@
fi
-PROG=`basename $0`
Modified: grass/branches/releasebranch_6_4/scripts/v.univar.sh/v.univar.sh
--- grass/branches/releasebranch_6_4/scripts/v.univar.sh/v.univar.sh 2011-01-30 00:10:58 UTC (rev 45244)
+++ grass/branches/releasebranch_6_4/scripts/v.univar.sh/v.univar.sh 2011-01-30 00:27:07 UTC (rev 45245)
@@ -66,7 +66,7 @@
versions of GRASS. Use the v.univar instead."
-PROG=`basename $0`
