[GRASS-SVN] r45248 - in grass/branches/develbranch_6/scripts:
d.correlate d.out.gpsdrive d.out.png d.polar d.resize
d.vect.thematic db.dropcol db.droptable db.in.ogr db.out.ogr
g.mremove i.fusion.brovey i.image.mosaic i.in.spotvgt
i.landsat.rgb i.oif r.blend r.fillnulls r.in.aster r.in.srtm
r.in.wms r.out.gdal r.plane r.reclass.area r.shaded.relief
r.univar.sh v.db.addcol v.db.addtable v.db.dropcol
v.db.droptable v.db.join v.db.renamecol v.db.univar
v.db.update v.dissolve v.in.e00 v.in.garmin v.in.geonames
v.in.gns v.in.gpsbabel v.in.mapgen v.in.wfs v.out.gpsbabel
v.rast.stats v.univar.sh
svn_grass at osgeo.org
Sun Jan 30 08:14:10 EST 2011
Author: neteler
Date: 2011-01-30 05:14:09 -0800 (Sun, 30 Jan 2011)
New Revision: 45248
grass/branches/develbranch_6/scripts/d.correlate/d.correlate
grass/branches/develbranch_6/scripts/d.out.gpsdrive/d.out.gpsdrive
grass/branches/develbranch_6/scripts/d.out.png/d.out.png
grass/branches/develbranch_6/scripts/d.polar/d.polar
grass/branches/develbranch_6/scripts/d.resize/d.resize
grass/branches/develbranch_6/scripts/d.vect.thematic/d.vect.thematic
grass/branches/develbranch_6/scripts/db.dropcol/db.dropcol
grass/branches/develbranch_6/scripts/db.droptable/db.droptable
grass/branches/develbranch_6/scripts/db.in.ogr/db.in.ogr
grass/branches/develbranch_6/scripts/db.out.ogr/db.out.ogr
grass/branches/develbranch_6/scripts/g.mremove/g.mremove
grass/branches/develbranch_6/scripts/i.fusion.brovey/i.fusion.brovey
grass/branches/develbranch_6/scripts/i.image.mosaic/i.image.mosaic
grass/branches/develbranch_6/scripts/i.in.spotvgt/i.in.spotvgt
grass/branches/develbranch_6/scripts/i.landsat.rgb/i.landsat.rgb
grass/branches/develbranch_6/scripts/i.oif/i.oifcalc
grass/branches/develbranch_6/scripts/r.blend/r.blend
grass/branches/develbranch_6/scripts/r.fillnulls/r.fillnulls
grass/branches/develbranch_6/scripts/r.in.aster/r.in.aster
grass/branches/develbranch_6/scripts/r.in.srtm/r.in.srtm
grass/branches/develbranch_6/scripts/r.in.wms/r.in.wms
grass/branches/develbranch_6/scripts/r.out.gdal/r.out.gdal.sh
grass/branches/develbranch_6/scripts/r.plane/r.plane
grass/branches/develbranch_6/scripts/r.reclass.area/r.reclass.area
grass/branches/develbranch_6/scripts/r.shaded.relief/r.shaded.relief
grass/branches/develbranch_6/scripts/r.univar.sh/r.univar.sh
grass/branches/develbranch_6/scripts/v.db.addcol/v.db.addcol
grass/branches/develbranch_6/scripts/v.db.addtable/v.db.addtable
grass/branches/develbranch_6/scripts/v.db.dropcol/v.db.dropcol
grass/branches/develbranch_6/scripts/v.db.droptable/v.db.droptable
grass/branches/develbranch_6/scripts/v.db.join/v.db.join
grass/branches/develbranch_6/scripts/v.db.renamecol/v.db.renamecol
grass/branches/develbranch_6/scripts/v.db.univar/v.db.univar
grass/branches/develbranch_6/scripts/v.db.update/v.db.update
grass/branches/develbranch_6/scripts/v.dissolve/v.dissolve
grass/branches/develbranch_6/scripts/v.in.e00/v.in.e00
grass/branches/develbranch_6/scripts/v.in.garmin/v.in.garmin
grass/branches/develbranch_6/scripts/v.in.geonames/v.in.geonames
grass/branches/develbranch_6/scripts/v.in.gns/v.in.gns
grass/branches/develbranch_6/scripts/v.in.gpsbabel/v.in.gpsbabel
grass/branches/develbranch_6/scripts/v.in.mapgen/v.in.mapgen
grass/branches/develbranch_6/scripts/v.in.wfs/v.in.wfs
grass/branches/develbranch_6/scripts/v.out.gpsbabel/v.out.gpsbabel
grass/branches/develbranch_6/scripts/v.rast.stats/v.rast.stats
grass/branches/develbranch_6/scripts/v.univar.sh/v.univar.sh
quoting of variable fixes, esp. for windows
Modified: grass/branches/develbranch_6/scripts/d.correlate/d.correlate
--- grass/branches/develbranch_6/scripts/d.correlate/d.correlate 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/d.correlate/d.correlate 2011-01-30 13:14:09 UTC (rev 45248)
@@ -60,7 +60,7 @@
fi
if [ "$1" != "@ARGS_PARSED@" ] ; then
- CMDLINE="`basename $0`"
+ CMDLINE=`basename "$0"`
for arg in "$@" ; do
CMDLINE="$CMDLINE \"$arg\""
done
@@ -68,7 +68,7 @@
exec g.parser "$0" "$@"
fi
-PROG="`basename $0`"
+PROG=`basename "$0"`
#### check if we have awk
if [ ! -x "`which awk`" ] ; then
Modified: grass/branches/develbranch_6/scripts/d.out.gpsdrive/d.out.gpsdrive
--- grass/branches/develbranch_6/scripts/d.out.gpsdrive/d.out.gpsdrive 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/d.out.gpsdrive/d.out.gpsdrive 2011-01-30 13:14:09 UTC (rev 45248)
@@ -89,7 +89,7 @@
fi
Modified: grass/branches/develbranch_6/scripts/d.out.png/d.out.png
--- grass/branches/develbranch_6/scripts/d.out.png/d.out.png 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/d.out.png/d.out.png 2011-01-30 13:14:09 UTC (rev 45248)
@@ -46,7 +46,7 @@
g.message -w "This module has been superseded. Please use d.out.file instead."
Modified: grass/branches/develbranch_6/scripts/d.polar/d.polar
--- grass/branches/develbranch_6/scripts/d.polar/d.polar 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/d.polar/d.polar 2011-01-30 13:14:09 UTC (rev 45248)
@@ -57,7 +57,7 @@
fi
Modified: grass/branches/develbranch_6/scripts/d.resize/d.resize
--- grass/branches/develbranch_6/scripts/d.resize/d.resize 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/d.resize/d.resize 2011-01-30 13:14:09 UTC (rev 45248)
@@ -42,7 +42,7 @@
fi
Modified: grass/branches/develbranch_6/scripts/d.vect.thematic/d.vect.thematic
--- grass/branches/develbranch_6/scripts/d.vect.thematic/d.vect.thematic 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/d.vect.thematic/d.vect.thematic 2011-01-30 13:14:09 UTC (rev 45248)
@@ -232,7 +232,7 @@
fi
Modified: grass/branches/develbranch_6/scripts/db.dropcol/db.dropcol
--- grass/branches/develbranch_6/scripts/db.dropcol/db.dropcol 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/db.dropcol/db.dropcol 2011-01-30 13:14:09 UTC (rev 45248)
@@ -53,7 +53,7 @@
fi
Modified: grass/branches/develbranch_6/scripts/db.droptable/db.droptable
--- grass/branches/develbranch_6/scripts/db.droptable/db.droptable 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/db.droptable/db.droptable 2011-01-30 13:14:09 UTC (rev 45248)
@@ -42,7 +42,7 @@
fi
# setting environment, so that awk works properly in all languages
unset LC_ALL
Modified: grass/branches/develbranch_6/scripts/db.in.ogr/db.in.ogr
--- grass/branches/develbranch_6/scripts/db.in.ogr/db.in.ogr 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/db.in.ogr/db.in.ogr 2011-01-30 13:14:09 UTC (rev 45248)
@@ -59,7 +59,7 @@
fi
unset LC_ALL
Modified: grass/branches/develbranch_6/scripts/db.out.ogr/db.out.ogr
--- grass/branches/develbranch_6/scripts/db.out.ogr/db.out.ogr 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/db.out.ogr/db.out.ogr 2011-01-30 13:14:09 UTC (rev 45248)
@@ -62,7 +62,7 @@
fi
unset LC_ALL
@@ -88,7 +88,7 @@
fi
if [ "$GIS_OPT_FORMAT" = "CSV" ] ; then
- OLAYER="olayer=`basename $GIS_OPT_DSN .csv`"
+ OLAYER="olayer=`basename "$GIS_OPT_DSN" .csv`"
fi
#is there a simpler way of testing for --overwrite?
@@ -107,7 +107,7 @@
if [ "$GIS_OPT_FORMAT" = "ESRI_Shapefile" ] ; then
echo "$GIS_OPT_DSN" | grep '\.dbf$' > /dev/null
if [ $? -eq 0 ] ; then
- OUTNAME="`basename $GIS_OPT_DSN .dbf`"
+ OUTNAME="`basename "$GIS_OPT_DSN" .dbf`"
rm -f "$OUTNAME.shp" "$OUTNAME.shx" "$OUTNAME.prj"
OUTNAME="$OUTNAME.dbf"
else
Modified: grass/branches/develbranch_6/scripts/g.mremove/g.mremove
--- grass/branches/develbranch_6/scripts/g.mremove/g.mremove 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/g.mremove/g.mremove 2011-01-30 13:14:09 UTC (rev 45248)
@@ -101,7 +101,7 @@
: ${GISBASE?} ${GISDBASE?} ${LOCATION_NAME?} ${MAPSET?}
LOCATION=$GISDBASE/$LOCATION_NAME/$MAPSET
g.message "Collecting map names for current mapset <$MAPSET>..."
Modified: grass/branches/develbranch_6/scripts/i.fusion.brovey/i.fusion.brovey
--- grass/branches/develbranch_6/scripts/i.fusion.brovey/i.fusion.brovey 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/i.fusion.brovey/i.fusion.brovey 2011-01-30 13:14:09 UTC (rev 45248)
@@ -89,7 +89,7 @@
# save command line
done
Modified: grass/branches/develbranch_6/scripts/i.image.mosaic/i.image.mosaic
--- grass/branches/develbranch_6/scripts/i.image.mosaic/i.image.mosaic 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/i.image.mosaic/i.image.mosaic 2011-01-30 13:14:09 UTC (rev 45248)
@@ -61,7 +61,7 @@
# save command line
done
@@ -69,7 +69,7 @@
fi
Modified: grass/branches/develbranch_6/scripts/i.in.spotvgt/i.in.spotvgt
--- grass/branches/develbranch_6/scripts/i.in.spotvgt/i.in.spotvgt 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/i.in.spotvgt/i.in.spotvgt 2011-01-30 13:14:09 UTC (rev 45248)
@@ -59,7 +59,7 @@
# save command line
done
Modified: grass/branches/develbranch_6/scripts/i.landsat.rgb/i.landsat.rgb
--- grass/branches/develbranch_6/scripts/i.landsat.rgb/i.landsat.rgb 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/i.landsat.rgb/i.landsat.rgb 2011-01-30 13:14:09 UTC (rev 45248)
@@ -73,7 +73,7 @@
# save command line
done
@@ -92,7 +92,7 @@
LC_NUMERIC=C
export LC_NUMERIC
BLUE="$GIS_OPT_BLUE"
GREEN="$GIS_OPT_GREEN"
Modified: grass/branches/develbranch_6/scripts/i.oif/i.oifcalc
--- grass/branches/develbranch_6/scripts/i.oif/i.oifcalc 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/i.oif/i.oifcalc 2011-01-30 13:14:09 UTC (rev 45248)
@@ -15,7 +15,7 @@
exit 1
fi
Modified: grass/branches/develbranch_6/scripts/r.blend/r.blend
--- grass/branches/develbranch_6/scripts/r.blend/r.blend 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/r.blend/r.blend 2011-01-30 13:14:09 UTC (rev 45248)
@@ -56,7 +56,7 @@
# save command line
done
Modified: grass/branches/develbranch_6/scripts/r.fillnulls/r.fillnulls
--- grass/branches/develbranch_6/scripts/r.fillnulls/r.fillnulls 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/r.fillnulls/r.fillnulls 2011-01-30 13:14:09 UTC (rev 45248)
@@ -59,7 +59,7 @@
# save command line
done
@@ -67,7 +67,7 @@
fi
Modified: grass/branches/develbranch_6/scripts/r.in.aster/r.in.aster
--- grass/branches/develbranch_6/scripts/r.in.aster/r.in.aster 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/r.in.aster/r.in.aster 2011-01-30 13:14:09 UTC (rev 45248)
@@ -57,7 +57,7 @@
# save command line
done
Modified: grass/branches/develbranch_6/scripts/r.in.srtm/r.in.srtm
--- grass/branches/develbranch_6/scripts/r.in.srtm/r.in.srtm 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/r.in.srtm/r.in.srtm 2011-01-30 13:14:09 UTC (rev 45248)
@@ -81,7 +81,7 @@
# save command line
done
@@ -89,7 +89,7 @@
fi
Modified: grass/branches/develbranch_6/scripts/r.in.wms/r.in.wms
--- grass/branches/develbranch_6/scripts/r.in.wms/r.in.wms 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/r.in.wms/r.in.wms 2011-01-30 13:14:09 UTC (rev 45248)
@@ -190,7 +190,7 @@
# save command line
done
Modified: grass/branches/develbranch_6/scripts/r.out.gdal/r.out.gdal.sh
--- grass/branches/develbranch_6/scripts/r.out.gdal/r.out.gdal.sh 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/r.out.gdal/r.out.gdal.sh 2011-01-30 13:14:09 UTC (rev 45248)
@@ -74,7 +74,7 @@
fi
g.message -w "This module is superseded and will be removed in future \
versions of GRASS. Use the much faster r.out.gdal instead."
Modified: grass/branches/develbranch_6/scripts/r.plane/r.plane
--- grass/branches/develbranch_6/scripts/r.plane/r.plane 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/r.plane/r.plane 2011-01-30 13:14:09 UTC (rev 45248)
@@ -77,7 +77,7 @@
fi
Modified: grass/branches/develbranch_6/scripts/r.reclass.area/r.reclass.area
--- grass/branches/develbranch_6/scripts/r.reclass.area/r.reclass.area 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/r.reclass.area/r.reclass.area 2011-01-30 13:14:09 UTC (rev 45248)
@@ -61,7 +61,7 @@
fi
Modified: grass/branches/develbranch_6/scripts/r.shaded.relief/r.shaded.relief
--- grass/branches/develbranch_6/scripts/r.shaded.relief/r.shaded.relief 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/r.shaded.relief/r.shaded.relief 2011-01-30 13:14:09 UTC (rev 45248)
@@ -110,7 +110,7 @@
# save command line
done
@@ -122,7 +122,7 @@
#nsres=`g.region -g | grep 'nsres=' | sed s/nsres=//`
#ewres=`g.region -g | grep 'ewres=' | sed s/ewres=//`
unset LC_ALL
Modified: grass/branches/develbranch_6/scripts/r.univar.sh/r.univar.sh
--- grass/branches/develbranch_6/scripts/r.univar.sh/r.univar.sh 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/r.univar.sh/r.univar.sh 2011-01-30 13:14:09 UTC (rev 45248)
@@ -49,7 +49,7 @@
versions of GRASS. Use the much faster r.univar instead."
Modified: grass/branches/develbranch_6/scripts/v.db.addcol/v.db.addcol
--- grass/branches/develbranch_6/scripts/v.db.addcol/v.db.addcol 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/v.db.addcol/v.db.addcol 2011-01-30 13:14:09 UTC (rev 45248)
@@ -55,7 +55,7 @@
# save command line
- CMDLINE="`basename "$0"`"
done
@@ -63,7 +63,7 @@
fi
Modified: grass/branches/develbranch_6/scripts/v.db.addtable/v.db.addtable
--- grass/branches/develbranch_6/scripts/v.db.addtable/v.db.addtable 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/v.db.addtable/v.db.addtable 2011-01-30 13:14:09 UTC (rev 45248)
@@ -56,7 +56,7 @@
# save command line
done
@@ -64,7 +64,7 @@
fi
Modified: grass/branches/develbranch_6/scripts/v.db.dropcol/v.db.dropcol
--- grass/branches/develbranch_6/scripts/v.db.dropcol/v.db.dropcol 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/v.db.dropcol/v.db.dropcol 2011-01-30 13:14:09 UTC (rev 45248)
@@ -56,7 +56,7 @@
# save command line
done
@@ -64,7 +64,7 @@
fi
#### setup temporary file
TEMPFILE="`g.tempfile pid=$$`"
Modified: grass/branches/develbranch_6/scripts/v.db.droptable/v.db.droptable
--- grass/branches/develbranch_6/scripts/v.db.droptable/v.db.droptable 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/v.db.droptable/v.db.droptable 2011-01-30 13:14:09 UTC (rev 45248)
@@ -50,7 +50,7 @@
# save command line
done
@@ -58,7 +58,7 @@
fi
Modified: grass/branches/develbranch_6/scripts/v.db.join/v.db.join
--- grass/branches/develbranch_6/scripts/v.db.join/v.db.join 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/v.db.join/v.db.join 2011-01-30 13:14:09 UTC (rev 45248)
@@ -67,7 +67,7 @@
# save command line
done
@@ -75,7 +75,7 @@
fi
database=`v.db.connect -gl map="$GIS_OPT_MAP" fs="|" layer="$GIS_OPT_LAYER" | cut -d'|' -f4`
driver=`v.db.connect -gl map="$GIS_OPT_MAP" fs="|" layer="$GIS_OPT_LAYER" | cut -d'|' -f5`
Modified: grass/branches/develbranch_6/scripts/v.db.renamecol/v.db.renamecol
--- grass/branches/develbranch_6/scripts/v.db.renamecol/v.db.renamecol 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/v.db.renamecol/v.db.renamecol 2011-01-30 13:14:09 UTC (rev 45248)
@@ -54,7 +54,7 @@
# save command line
done
@@ -62,7 +62,7 @@
fi
# what to do in case of user break:
exitprocedure()
Modified: grass/branches/develbranch_6/scripts/v.db.univar/v.db.univar
--- grass/branches/develbranch_6/scripts/v.db.univar/v.db.univar 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/v.db.univar/v.db.univar 2011-01-30 13:14:09 UTC (rev 45248)
@@ -63,7 +63,7 @@
fi
Modified: grass/branches/develbranch_6/scripts/v.db.update/v.db.update
--- grass/branches/develbranch_6/scripts/v.db.update/v.db.update 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/v.db.update/v.db.update 2011-01-30 13:14:09 UTC (rev 45248)
@@ -67,7 +67,7 @@
# save command line
done
@@ -75,7 +75,7 @@
fi
Modified: grass/branches/develbranch_6/scripts/v.dissolve/v.dissolve
--- grass/branches/develbranch_6/scripts/v.dissolve/v.dissolve 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/v.dissolve/v.dissolve 2011-01-30 13:14:09 UTC (rev 45248)
@@ -58,7 +58,7 @@
# save command line
done
Modified: grass/branches/develbranch_6/scripts/v.in.e00/v.in.e00
--- grass/branches/develbranch_6/scripts/v.in.e00/v.in.e00 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/v.in.e00/v.in.e00 2011-01-30 13:14:09 UTC (rev 45248)
@@ -57,7 +57,7 @@
# save command line
done
@@ -65,7 +65,7 @@
fi
Modified: grass/branches/develbranch_6/scripts/v.in.garmin/v.in.garmin
--- grass/branches/develbranch_6/scripts/v.in.garmin/v.in.garmin 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/v.in.garmin/v.in.garmin 2011-01-30 13:14:09 UTC (rev 45248)
@@ -91,7 +91,7 @@
# save command line
done
@@ -109,7 +109,7 @@
LOCATION="$GISDBASE"/"$LOCATION_NAME"/"$MAPSET"
if [ $GIS_FLAG_U -eq 0 ] ; then
#### check for gpstrans
Modified: grass/branches/develbranch_6/scripts/v.in.geonames/v.in.geonames
--- grass/branches/develbranch_6/scripts/v.in.geonames/v.in.geonames 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/v.in.geonames/v.in.geonames 2011-01-30 13:14:09 UTC (rev 45248)
@@ -49,7 +49,7 @@
# save command line
done
@@ -57,7 +57,7 @@
fi
Modified: grass/branches/develbranch_6/scripts/v.in.gns/v.in.gns
--- grass/branches/develbranch_6/scripts/v.in.gns/v.in.gns 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/v.in.gns/v.in.gns 2011-01-30 13:14:09 UTC (rev 45248)
@@ -49,7 +49,7 @@
# save command line
done
@@ -57,7 +57,7 @@
fi
Modified: grass/branches/develbranch_6/scripts/v.in.gpsbabel/v.in.gpsbabel
--- grass/branches/develbranch_6/scripts/v.in.gpsbabel/v.in.gpsbabel 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/v.in.gpsbabel/v.in.gpsbabel 2011-01-30 13:14:09 UTC (rev 45248)
@@ -96,7 +96,7 @@
# save command line
done
@@ -113,7 +113,7 @@
#### check for gpsbabel
if [ ! -x "`which gpsbabel`" ] ; then
Modified: grass/branches/develbranch_6/scripts/v.in.mapgen/v.in.mapgen
--- grass/branches/develbranch_6/scripts/v.in.mapgen/v.in.mapgen 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/v.in.mapgen/v.in.mapgen 2011-01-30 13:14:09 UTC (rev 45248)
@@ -59,7 +59,7 @@
fi
Modified: grass/branches/develbranch_6/scripts/v.in.wfs/v.in.wfs
--- grass/branches/develbranch_6/scripts/v.in.wfs/v.in.wfs 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/v.in.wfs/v.in.wfs 2011-01-30 13:14:09 UTC (rev 45248)
@@ -40,7 +40,7 @@
# save command line
done
Modified: grass/branches/develbranch_6/scripts/v.out.gpsbabel/v.out.gpsbabel
--- grass/branches/develbranch_6/scripts/v.out.gpsbabel/v.out.gpsbabel 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/v.out.gpsbabel/v.out.gpsbabel 2011-01-30 13:14:09 UTC (rev 45248)
@@ -107,7 +107,7 @@
# save command line
done
@@ -124,7 +124,7 @@
Modified: grass/branches/develbranch_6/scripts/v.rast.stats/v.rast.stats
--- grass/branches/develbranch_6/scripts/v.rast.stats/v.rast.stats 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/v.rast.stats/v.rast.stats 2011-01-30 13:14:09 UTC (rev 45248)
@@ -75,7 +75,7 @@
fi
Modified: grass/branches/develbranch_6/scripts/v.univar.sh/v.univar.sh
--- grass/branches/develbranch_6/scripts/v.univar.sh/v.univar.sh 2011-01-30 13:03:30 UTC (rev 45247)
+++ grass/branches/develbranch_6/scripts/v.univar.sh/v.univar.sh 2011-01-30 13:14:09 UTC (rev 45248)
@@ -66,7 +66,7 @@
versions of GRASS. Use the v.univar instead."
