[GRASS-SVN] r46901 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Fri Jul 1 04:53:45 EDT 2011
Author: mmetz
Date: 2011-07-01 01:53:45 -0700 (Fri, 01 Jul 2011)
New Revision: 46901
grass/trunk/lib/vector/Vlib/area.c
grass/trunk/lib/vector/Vlib/box.c
grass/trunk/lib/vector/Vlib/break_lines.c
grass/trunk/lib/vector/Vlib/break_polygons.c
grass/trunk/lib/vector/Vlib/build.c
grass/trunk/lib/vector/Vlib/build_nat.c
grass/trunk/lib/vector/Vlib/build_ogr.c
grass/trunk/lib/vector/Vlib/constraint.c
grass/trunk/lib/vector/Vlib/find.c
grass/trunk/lib/vector/Vlib/header.c
grass/trunk/lib/vector/Vlib/init_head.c
grass/trunk/lib/vector/Vlib/intersect.c
grass/trunk/lib/vector/Vlib/legal_vname.c
grass/trunk/lib/vector/Vlib/level_two.c
grass/trunk/lib/vector/Vlib/list.c
grass/trunk/lib/vector/Vlib/merge_lines.c
grass/trunk/lib/vector/Vlib/net.c
grass/trunk/lib/vector/Vlib/open.c
grass/trunk/lib/vector/Vlib/overlap.c
grass/trunk/lib/vector/Vlib/poly.c
grass/trunk/lib/vector/Vlib/read_nat.c
grass/trunk/lib/vector/Vlib/read_ogr.c
grass/trunk/lib/vector/Vlib/remove_duplicates.c
grass/trunk/lib/vector/Vlib/select.c
grass/trunk/lib/vector/Vlib/sindex.c
grass/trunk/lib/vector/Vlib/snap.c
grass/trunk/lib/vector/Vlib/write_nat.c
grass/trunk/lib/vector/Vlib/write_ogr.c
remove bounding boxes from vector topology (Radim's TODO): update Vlib
Modified: grass/trunk/lib/vector/Vlib/area.c
--- grass/trunk/lib/vector/Vlib/area.c 2011-07-01 08:53:19 UTC (rev 46900)
+++ grass/trunk/lib/vector/Vlib/area.c 2011-07-01 08:53:45 UTC (rev 46901)
@@ -345,20 +345,23 @@
const struct Plus_head *Plus;
struct P_area *Area;
int poly;
+ struct bound_box box;
Plus = &(Map->plus);
Area = Plus->Area[area];
if (Area == NULL)
return 0;
- poly = Vect_point_in_area_outer_ring(x, y, Map, area);
+ Vect_get_area_box(Map, area, &box);
+ poly = Vect_point_in_area_outer_ring(x, y, Map, area, box);
if (poly == 0)
return 0; /* includes area boundary (poly == 2), OK? */
/* check if in islands */
for (i = 0; i < Area->n_isles; i++) {
isle = Area->isles[i];
- poly = Vect_point_in_island(x, y, Map, isle);
+ Vect_get_isle_box(Map, isle, &box);
+ poly = Vect_point_in_island(x, y, Map, isle, box);
if (poly >= 1)
return 0; /* excludes island boundary (poly == 2), OK? */
Modified: grass/trunk/lib/vector/Vlib/box.c
--- grass/trunk/lib/vector/Vlib/box.c 2011-07-01 08:53:19 UTC (rev 46900)
+++ grass/trunk/lib/vector/Vlib/box.c 2011-07-01 08:53:45 UTC (rev 46901)
@@ -17,6 +17,7 @@
#include <stdlib.h>
#include <grass/vector.h>
+#include <grass/glocale.h>
\brief Tests for point in box
@@ -206,6 +207,8 @@
struct P_line *Line;
+ static struct line_pnts *Points = NULL;
+ static struct boxlist *list = NULL;
Line = Plus->Line[line];
@@ -220,12 +223,56 @@
return 0;
else {
- Box->N = Line->N;
- Box->S = Line->S;
- Box->E = Line->E;
- Box->W = Line->W;
- Box->T = Line->T;
- Box->B = Line->B;
+ int type = Line->type;
+ /* GV_POINTS: read line */
+ if (type & GV_POINTS) {
+ if (Points == NULL)
+ Points = Vect_new_line_struct();
+ Vect_read_line(Map, Points, NULL, line);
+ dig_line_box(Points, Box);
+ /* all other: retrieve box from spatial index */
+ else {
+ int node = 0;
+ struct bound_box bbox;
+ if (type == GV_LINE) {
+ struct P_topo_l *topo = (struct P_topo_l *)Line->topo;
+ node = topo->N1;
+ else if (type == GV_BOUNDARY) {
+ struct P_topo_b *topo = (struct P_topo_b *)Line->topo;
+ node = topo->N1;
+ if (list == NULL) {
+ list = Vect_new_boxlist();
+ Vect_reset_boxlist(list);
+ bbox.N = Plus->Node[node]->y;
+ bbox.S = Plus->Node[node]->y;
+ bbox.E = Plus->Node[node]->x;
+ bbox.W = Plus->Node[node]->x;
+ bbox.T = Plus->Node[node]->z;
+ bbox.B = Plus->Node[node]->z;
+ dig_boxlist_add(list, line, bbox);
+ if (dig_find_line_box(Plus, list) == 0)
+ G_fatal_error(_("Could not find line box"));
+ Box->N = list->box[0].N;
+ Box->S = list->box[0].S;
+ Box->E = list->box[0].E;
+ Box->W = list->box[0].W;
+ Box->T = list->box[0].T;
+ Box->B = list->box[0].B;
return 1;
@@ -245,6 +292,11 @@
+ struct P_line *Line;
+ struct P_node *Node;
+ struct P_topo_b *topo;
@@ -256,15 +308,38 @@
Box->W = 0;
Box->T = 0;
Box->B = 0;
return 0;
else {
- Box->N = Area->N;
- Box->S = Area->S;
- Box->E = Area->E;
- Box->W = Area->W;
- Box->T = Area->T;
- Box->B = Area->B;
+ Line = Plus->Line[abs(Area->lines[0])];
+ topo = (struct P_topo_b *)Line->topo;
+ Node = Plus->Node[topo->N1];
+ bbox.N = Node->y;
+ bbox.S = Node->y;
+ bbox.E = Node->x;
+ bbox.W = Node->x;
+ bbox.T = Node->z;
+ bbox.B = Node->z;
+ dig_boxlist_add(list, area, bbox);
+ if (dig_find_area_box(Plus, list) == 0)
+ G_fatal_error(_("Could not find area box"));
return 1;
@@ -284,6 +359,11 @@
struct P_isle *Isle;
Isle = Plus->Isle[isle];
@@ -298,12 +378,34 @@
return 0;
else {
- Box->N = Isle->N;
- Box->S = Isle->S;
- Box->E = Isle->E;
- Box->W = Isle->W;
- Box->T = Isle->T;
- Box->B = Isle->B;
+ Line = Plus->Line[abs(Isle->lines[0])];
+ bbox.N = Node->y;
+ bbox.S = Node->y;
+ bbox.E = Node->x;
+ bbox.W = Node->x;
+ bbox.T = Node->z;
+ bbox.B = Node->z;
+ dig_boxlist_add(list, isle, bbox);
+ if (dig_find_isle_box(Plus, list) == 0)
return 1;
Modified: grass/trunk/lib/vector/Vlib/break_lines.c
--- grass/trunk/lib/vector/Vlib/break_lines.c 2011-07-01 08:53:19 UTC (rev 46900)
+++ grass/trunk/lib/vector/Vlib/break_lines.c 2011-07-01 08:53:45 UTC (rev 46901)
@@ -133,7 +133,7 @@
if (!(atype & type))
continue;
- Vect_get_line_box(Map, aline, &ABox);
+ Vect_line_box(APoints, &ABox);
/* Find which sides of the box are touched by intermediate (non-end) points of line */
if (!is3d) {
@@ -175,11 +175,13 @@
G_debug(3, " j = %d bline = %d", j, bline);
+ btype = Vect_read_line(Map, BPoints, BCats, bline);
/* Check if thouch by end node only */
if (!is3d) {
Vect_get_line_nodes(Map, aline, &anode1, &anode2);
Vect_get_line_nodes(Map, bline, &bnode1, &bnode2);
- Vect_get_line_box(Map, bline, &BBox);
+ Vect_line_box(BPoints, &BBox);
if (anode1 == bnode1 || anode1 == bnode2)
node = anode1;
@@ -190,22 +192,23 @@
if (node) {
Vect_get_node_coor(Map, node, &nodex, &nodey, NULL);
- if ((node == anode1 && nodey == ABox.N && !touch1_n &&
- nodey == BBox.S) || (node == anode2 &&
- nodey == ABox.N && !touch2_n &&
- (node == anode1 && nodey == ABox.S && !touch1_s &&
- nodey == BBox.N) || (node == anode2 &&
- nodey == ABox.S && !touch2_s &&
- (node == anode1 && nodex == ABox.E && !touch1_e &&
- nodex == BBox.W) || (node == anode2 &&
- nodex == ABox.E && !touch2_e &&
- (node == anode1 && nodex == ABox.W && !touch1_w &&
- nodex == BBox.E) || (node == anode2 &&
- nodex == ABox.W && !touch2_w &&
- nodex == BBox.E)) {
+ if ((node == anode1 && nodey == ABox.N &&
+ !touch1_n && nodey == BBox.S) ||
+ (node == anode2 && nodey == ABox.N &&
+ !touch2_n && nodey == BBox.S) ||
+ (node == anode1 && nodey == ABox.S &&
+ !touch1_s && nodey == BBox.N) ||
+ (node == anode2 && nodey == ABox.S &&
+ !touch2_s && nodey == BBox.N) ||
+ (node == anode1 && nodex == ABox.E &&
+ !touch1_e && nodex == BBox.W) ||
+ (node == anode2 && nodex == ABox.E &&
+ !touch2_e && nodex == BBox.W) ||
+ (node == anode1 && nodex == ABox.W &&
+ !touch1_w && nodex == BBox.E) ||
+ (node == anode2 && nodex == ABox.W &&
+ !touch2_w && nodex == BBox.E)) {
G_debug(3,
"lines %d and %d touching by end nodes only -> no intersection",
aline, bline);
@@ -214,8 +217,6 @@
- btype = Vect_read_line(Map, BPoints, BCats, bline);
AXLines = NULL;
BXLines = NULL;
Vect_line_intersection(APoints, BPoints, &AXLines, &BXLines,
@@ -374,6 +375,12 @@
G_verbose_message(_("Intersections: %d"), nbreaks);
+ Vect_destroy_line_struct(APoints);
+ Vect_destroy_line_struct(BPoints);
+ Vect_destroy_line_struct(Points);
+ Vect_destroy_cats_struct(ACats);
+ Vect_destroy_cats_struct(BCats);
+ Vect_destroy_cats_struct(Cats);
Vect_destroy_list(List);
return nbreaks;
Modified: grass/trunk/lib/vector/Vlib/break_polygons.c
--- grass/trunk/lib/vector/Vlib/break_polygons.c 2011-07-01 08:53:19 UTC (rev 46900)
+++ grass/trunk/lib/vector/Vlib/break_polygons.c 2011-07-01 08:53:45 UTC (rev 46901)
@@ -73,7 +73,7 @@
static int fpoint;
/* Function called from RTreeSearch for point found */
-void srch(int id, int *arg)
+void srch(int id, struct Rect rect, int *arg)
fpoint = id;
Modified: grass/trunk/lib/vector/Vlib/build.c
--- grass/trunk/lib/vector/Vlib/build.c 2011-07-01 08:53:19 UTC (rev 46900)
+++ grass/trunk/lib/vector/Vlib/build.c 2011-07-01 08:53:45 UTC (rev 46901)
@@ -180,16 +180,21 @@
if (!Line)
continue;
- if (Line->type == GV_BOUNDARY &&
- (Line->left == 0 || Line->right == 0)) {
- G_debug(3, "line = %d left = %d right = %d", line, Line->left,
- Line->right);
- err_boundaries++;
+ if (Line->type == GV_BOUNDARY) {
+ if (topo->left == 0 || topo->right == 0) {
+ G_debug(3, "line = %d left = %d right = %d", line,
+ topo->left, topo->right);
+ err_boundaries++;
if (Line->type == GV_CENTROID) {
- if (Line->left == 0)
+ struct P_topo_c *topo = (struct P_topo_c *)Line->topo;
+ if (topo->area == 0)
err_centr_out++;
- else if (Line->left < 0)
+ else if (topo->area < 0)
err_centr_dupl++;
@@ -323,12 +328,45 @@
continue;
Line = plus->Line[i];
- fprintf(out, "line = %d, type = %d, offset = %lu n1 = %d, n2 = %d, "
- "left/area = %d, right = %d\n",
- i, Line->type, (unsigned long)Line->offset, Line->N1,
- Line->N2, Line->left, Line->right);
- fprintf(out, "N,S,E,W,T,B: %f, %f, %f, %f, %f, %f\n", Line->N,
- Line->S, Line->E, Line->W, Line->T, Line->B);
+ if (Line->type == GV_POINT) {
+ fprintf(out, "line = %d, type = %d, offset = %lu\n",
+ i, Line->type, (unsigned long)Line->offset);
+ else if (Line->type == GV_CENTROID) {
+ fprintf(out, "line = %d, type = %d, offset = %lu, area = %d\n",
+ i, Line->type, (unsigned long)Line->offset, topo->area);
+ else if (Line->type == GV_LINE) {
+ fprintf(out, "line = %d, type = %d, offset = %lu, n1 = %d, n2 = %d\n",
+ i, Line->type, (unsigned long)Line->offset, topo->N1,
+ topo->N2);
+ else if (Line->type == GV_BOUNDARY) {
+ fprintf(out, "line = %d, type = %d, offset = %lu, n1 = %d, n2 = %d, "
+ "left = %d, right = %d\n",
+ topo->N2, topo->left, topo->right);
+ else if (Line->type == GV_FACE) {
+ struct P_topo_f *topo = (struct P_topo_f *)Line->topo;
+ fprintf(out, "line = %d, type = %d, offset = %lu, e1 = %d, e2 = %d, "
+ "e3 = %d, left = %d, right = %d\n",
+ i, Line->type, (unsigned long)Line->offset, topo->E[0],
+ topo->E[1], topo->E[2], topo->left, topo->right);
+ else if (Line->type == GV_KERNEL) {
+ struct P_topo_k *topo = (struct P_topo_k *)Line->topo;
+ fprintf(out, "line = %d, type = %d, offset = %lu, volume = %d",
+ i, Line->type, (unsigned long)Line->offset, topo->volume);
/* areas */
@@ -342,9 +380,6 @@
fprintf(out, "area = %d, n_lines = %d, n_isles = %d centroid = %d\n",
i, Area->n_lines, Area->n_isles, Area->centroid);
- fprintf(out, "N,S,E,W,T,B: %f, %f, %f, %f, %f, %f\n", Area->N,
- Area->S, Area->E, Area->W, Area->T, Area->B);
for (j = 0; j < Area->n_lines; j++) {
line = Area->lines[j];
Line = plus->Line[abs(line)];
@@ -367,9 +402,6 @@
fprintf(out, "isle = %d, n_lines = %d area = %d\n", i, Isle->n_lines,
Isle->area);
- fprintf(out, "N,S,E,W,T,B: %f, %f, %f, %f, %f, %f\n", Isle->N,
- Isle->S, Isle->E, Isle->W, Isle->T, Isle->B);
for (j = 0; j < Isle->n_lines; j++) {
line = Isle->lines[j];
@@ -413,95 +445,12 @@
int Vect_build_sidx_from_topo(struct Map_info *Map)
- int i, total, done;
- struct Plus_head *plus;
- struct bound_box box;
- struct P_line *Line;
- struct P_node *Node;
- struct P_area *Area;
- struct P_isle *Isle;
G_debug(3, "Vect_build_sidx_from_topo()");
- plus = &(Map->plus);
+ G_warning(_("Vect_build_sidx_from_topo() is no longer supported"));
- Vect_open_sidx(Map, 2);
- total = plus->n_nodes + plus->n_lines + plus->n_areas + plus->n_isles;
- /* Nodes */
- for (i = 1; i <= plus->n_nodes; i++) {
- G_percent(i, total, 3);
- Node = plus->Node[i];
- if (!Node)
- G_fatal_error(_("BUG (Vect_build_sidx_from_topo): node does not exist"));
- dig_spidx_add_node(plus, i, Node->x, Node->y, Node->z);
- /* Lines */
- done = plus->n_nodes;
- for (i = 1; i <= plus->n_lines; i++) {
- G_percent(done + i, total, 3);
- Line = plus->Line[i];
- if (!Line)
- G_fatal_error(_("BUG (Vect_build_sidx_from_topo): line does not exist"));
- box.N = Line->N;
- box.S = Line->S;
- box.E = Line->E;
- box.W = Line->W;
- box.T = Line->T;
- box.B = Line->B;
- dig_spidx_add_line(plus, i, &box);
- /* Areas */
- done += plus->n_lines;
- for (i = 1; i <= plus->n_areas; i++) {
- Area = plus->Area[i];
- if (!Area)
- G_fatal_error(_("BUG (Vect_build_sidx_from_topo): area does not exist"));
- box.N = Area->N;
- box.S = Area->S;
- box.E = Area->E;
- box.W = Area->W;
- box.T = Area->T;
- box.B = Area->B;
- dig_spidx_add_area(plus, i, &box);
- /* Isles */
- done += plus->n_areas;
- for (i = 1; i <= plus->n_isles; i++) {
- Isle = plus->Isle[i];
- if (!Isle)
- G_fatal_error(_("BUG (Vect_build_sidx_from_topo): isle does not exist"));
- box.N = Isle->N;
- box.S = Isle->S;
- box.E = Isle->E;
- box.W = Isle->W;
- box.T = Isle->T;
- box.B = Isle->B;
- dig_spidx_add_isle(plus, i, &box);
- Map->plus.Spidx_built = 1;
- G_debug(3, "Spatial index was built");
- return 0;
+ return 1;
Modified: grass/trunk/lib/vector/Vlib/build_nat.c
--- grass/trunk/lib/vector/Vlib/build_nat.c 2011-07-01 08:53:19 UTC (rev 46900)
+++ grass/trunk/lib/vector/Vlib/build_nat.c 2011-07-01 08:53:45 UTC (rev 46901)
@@ -40,6 +40,7 @@
struct P_line *BLine;
static struct line_pnts *Points, *APoints;
plus_t *lines;
double area_size;
@@ -81,6 +82,7 @@
Vect_append_points(APoints, Points, direction);
APoints->n_points--; /* skip last point, avoids duplicates */
+ dig_line_box(APoints, &box);
APoints->n_points++; /* close polygon */
dig_find_area_poly(APoints, &area_size);
@@ -92,7 +94,7 @@
if (area_size > 0) { /* CW: area */
/* add area structure to plus */
- area = dig_add_area(plus, n_lines, lines);
+ area = dig_add_area(plus, n_lines, lines, &box);
if (area == -1) { /* error */
Vect_close(Map);
G_fatal_error(_("Unable to add area (map closed, topo saved)"));
@@ -101,7 +103,7 @@
return area;
else if (area_size < 0) { /* CCW: island */
- isle = dig_add_isle(plus, n_lines, lines);
+ isle = dig_add_isle(plus, n_lines, lines, &box);
if (isle == -1) { /* error */
Vect_close(Map);
G_fatal_error(_("Unable to add isle (map closed, topo saved)"));
@@ -130,16 +132,17 @@
int Vect_isle_find_area(struct Map_info *Map, int isle)
- int j, line, node, sel_area, first, area, poly;
+ int j, line, sel_area, first, area, poly;
static int first_call = 1;
const struct Plus_head *plus;
double size, cur_size;
struct bound_box box, abox;
- static struct ilist *List;
+ static struct boxlist *List;
static struct line_pnts *APoints;
/* Note: We should check all isle points (at least) because if topology is not clean
@@ -155,7 +158,7 @@
if (first_call) {
- List = Vect_new_list();
+ List = Vect_new_boxlist();
APoints = Vect_new_line_struct();
first_call = 0;
@@ -163,8 +166,8 @@
Isle = plus->Isle[isle];
line = abs(Isle->lines[0]);
Line = plus->Line[line];
- node = Line->N1;
- Node = plus->Node[node];
+ Node = plus->Node[topo->N1];
/* select areas by box */
box.E = Node->x;
@@ -173,7 +176,7 @@
box.S = Node->y;
box.T = PORT_DOUBLE_MAX;
box.B = -PORT_DOUBLE_MAX;
- Vect_select_areas_by_box(Map, &box, List);
+ Vect_select_areas_by_box_with_box(Map, &box, List);
G_debug(3, "%d areas overlap island boundary point", List->n_values);
sel_area = 0;
@@ -181,7 +184,7 @@
first = 1;
for (j = 0; j < List->n_values; j++) {
- area = List->value[j];
+ area = List->id[j];
G_debug(3, "area = %d", area);
Area = plus->Area[area];
@@ -198,14 +201,16 @@
* box all overlapping areas selects all areas with box overlapping first node.
* Then reading coordinates for all those areas would take a long time -> check first
* if isle's box is completely within area box */
- Vect_get_area_box(Map, area, &abox);
+ abox = List->box[j];
if (box.E > abox.E || box.W < abox.W || box.N > abox.N ||
box.S < abox.S) {
G_debug(3, " isle not completely inside area box");
continue;
- poly = Vect_point_in_area_outer_ring(Node->x, Node->y, Map, area);
+ poly = Vect_point_in_area_outer_ring(Node->x, Node->y, Map, area, abox);
G_debug(3, " poly = %d", poly);
if (poly == 1) { /* point in area, but node is not part of area inside isle (would be poly == 2) */
@@ -330,7 +335,7 @@
- \brief (Re)Attach centroids to areas in given bouding box
+ \brief (Re)Attach centroids to areas in given bounding box
\param Map_info vector map
\param box bounding box
@@ -342,8 +347,10 @@
int i, sel_area, centr;
static int first = 1;
+ static struct line_pnts *Points;
+ struct P_topo_c *topo;
G_debug(3, "Vect_attach_centroids ()");
@@ -352,6 +359,7 @@
if (first) {
first = 0;
@@ -388,25 +396,27 @@
centr = List->value[i];
Line = plus->Line[centr];
+ topo = (struct P_topo_c *)Line->topo;
/* only attach unregistered and duplicate centroids because
* 1) all properly attached centroids are properly attached, really! Don't touch.
* 2) Vect_find_area() below does not always return the correct area
* 3) it's faster
- if (Line->left > 0)
+ if (topo->area > 0)
continue;
- orig_area = Line->left;
+ orig_area = topo->area;
- sel_area = Vect_find_area(Map, Line->E, Line->N);
+ Vect_read_line(Map, Points, NULL, centr);
+ sel_area = Vect_find_area(Map, Points->x[0], Points->y[0]);
G_debug(3, " centroid %d is in area %d", centr, sel_area);
if (sel_area > 0) {
Area = plus->Area[sel_area];
if (Area->centroid == 0) { /* first centroid */
G_debug(3, " first centroid -> attach to area");
Area->centroid = centr;
- Line->left = sel_area;
+ topo->area = sel_area;
if (sel_area != orig_area && plus->do_uplist)
dig_line_add_updated(plus, centr);
@@ -415,7 +425,7 @@
/* Note: it cannot happen that Area->centroid == centr, because the centroid
* was not registered or a duplicate */
G_debug(3, " duplicate centroid -> do not attach to area");
- Line->left = -sel_area;
+ topo->area = -sel_area;
if (-sel_area != orig_area && plus->do_uplist)
@@ -438,15 +448,16 @@
int Vect_build_nat(struct Map_info *Map, int build)
- int i, s, type, lineid;
+ int i, s, type, line;
off_t offset;
- int side, line, area;
+ int side, area;
struct line_cats *Cats;
struct ilist *List;
+ int print_counter = G_verbose() > G_verbose_min();
G_debug(3, "Vect_build_nat() build = %d", build);
@@ -465,8 +476,10 @@
for (line = 1; line <= nlines; line++) {
- if (Line && Line->type == GV_CENTROID)
- Line->left = 0;
+ if (Line && Line->type == GV_CENTROID) {
+ topo->area = 0;
dig_free_plus_areas(plus);
dig_spidx_free_areas(plus);
@@ -482,8 +495,9 @@
if (Line && Line->type == GV_BOUNDARY) {
- Line->left = 0;
- Line->right = 0;
+ topo->left = 0;
+ topo->right = 0;
@@ -508,7 +522,7 @@
if (plus->built < GV_BUILD_BASE) {
- int npoints, format;
+ register int npoints, format, c;
format = G_info_format();
@@ -521,7 +535,7 @@
/* register lines, create nodes */
Vect_rewind(Map);
G_message(_("Registering primitives..."));
- i = 1;
+ i = 0;
npoints = 0;
while (1) {
/* register line */
@@ -541,36 +555,34 @@
offset = Map->head.last_offset;
G_debug(3, "Register line: offset = %lu", (unsigned long)offset);
- lineid = dig_add_line(plus, type, Points, offset);
dig_line_box(Points, &box);
- if (lineid == 1)
+ line = dig_add_line(plus, type, Points, &box, offset);
+ if (line == 1)
Vect_box_copy(&(plus->box), &box);
else
Vect_box_extend(&(plus->box), &box);
/* Add all categories to category index */
if (build == GV_BUILD_ALL) {
- int c;
for (c = 0; c < Cats->n_cats; c++) {
dig_cidx_add_cat(plus, Cats->field[c], Cats->cat[c],
- lineid, type);
+ line, type);
if (Cats->n_cats == 0) /* add field 0, cat 0 */
- dig_cidx_add_cat(plus, 0, 0, lineid, type);
+ dig_cidx_add_cat(plus, 0, 0, line, type);
- if (G_verbose() > G_verbose_min() && i % 1000 == 0) {
+ i++;
+ if (i == 10000 && print_counter) {
if (format == G_INFO_FORMAT_PLAIN)
- fprintf(stderr, "%d..", i);
+ fprintf(stderr, "%d..", plus->n_lines);
else
- fprintf(stderr, "%10d\b\b\b\b\b\b\b\b\b\b", i);
+ fprintf(stderr, "%10d\b\b\b\b\b\b\b\b\b\b", plus->n_lines);
+ i = 0;
- i++;
- if ((G_verbose() > G_verbose_min()) && format != G_INFO_FORMAT_PLAIN)
+ if ((print_counter) && format != G_INFO_FORMAT_PLAIN)
fprintf(stderr, "\r");
G_message(_("%d primitives registered"), plus->n_lines);
@@ -586,14 +598,14 @@
/* Build areas */
/* Go through all bundaries and try to build area for both sides */
G_important_message(_("Building areas..."));
- G_percent(i, plus->n_lines, 1);
+ for (line = 1; line <= plus->n_lines; line++) {
+ G_percent(line, plus->n_lines, 1);
/* build */
- if (plus->Line[i] == NULL) {
+ if (plus->Line[line] == NULL) {
continue;
} /* dead line */
+ Line = plus->Line[line];
if (Line->type != GV_BOUNDARY) {
continue;
@@ -604,8 +616,8 @@
else
side = GV_RIGHT;
- G_debug(3, "Build area for line = %d, side = %d", i, side);
- Vect_build_line_area(Map, i, side);
+ G_debug(3, "Build area for line = %d, side = %d", line, side);
+ Vect_build_line_area(Map, line, side);
G_message(_("%d areas built"), plus->n_areas);
@@ -632,6 +644,7 @@
/* Attach centroids to areas */
if (plus->built < GV_BUILD_CENTROIDS) {
int nlines;
G_important_message(_("Attaching centroids..."));
@@ -646,19 +659,21 @@
if (Line->type != GV_CENTROID)
continue;
- area = Vect_find_area(Map, Line->E, Line->N);
+ area = Vect_find_area(Map, Points->x[0], Points->y[0]);
if (area > 0) {
G_debug(3, "Centroid (line=%d) in area %d", line, area);
if (Area->centroid == 0) { /* first */
Area->centroid = line;
- Line->left = area;
+ topo->area = area;
else { /* duplicate */
- Line->left = -area;
+ topo->area = -area;
@@ -666,23 +681,23 @@
/* Add areas to category index */
- for (area = 1; area <= plus->n_areas; area++) {
+ for (i = 1; i <= plus->n_areas; i++) {
int c;
- if (plus->Area[area] == NULL)
+ if (plus->Area[i] == NULL)
continue;
- if (plus->Area[area]->centroid > 0) {
- Vect_read_line(Map, NULL, Cats, plus->Area[area]->centroid);
+ if (plus->Area[i]->centroid > 0) {
+ Vect_read_line(Map, NULL, Cats, plus->Area[i]->centroid);
- dig_cidx_add_cat(plus, Cats->field[c], Cats->cat[c], area,
+ dig_cidx_add_cat(plus, Cats->field[c], Cats->cat[c], i,
GV_AREA);
- if (plus->Area[area]->centroid == 0 || Cats->n_cats == 0) /* no centroid or no cats */
- dig_cidx_add_cat(plus, 0, 0, area, GV_AREA);
+ if (plus->Area[i]->centroid == 0 || Cats->n_cats == 0) /* no centroid or no cats */
+ dig_cidx_add_cat(plus, 0, 0, i, GV_AREA);
return 1;
Modified: grass/trunk/lib/vector/Vlib/build_ogr.c
--- grass/trunk/lib/vector/Vlib/build_ogr.c 2011-07-01 08:53:19 UTC (rev 46900)
+++ grass/trunk/lib/vector/Vlib/build_ogr.c 2011-07-01 08:53:45 UTC (rev 46901)
@@ -136,11 +136,11 @@
offset = FID; /* because centroids are read from topology, not from layer */
G_debug(4, "Register line: FID = %d offset = %ld", FID, offset);
- line = dig_add_line(plus, type, Points, offset);
+ dig_line_box(Points, &box);
G_debug(4, "Line registered with line = %d", line);
/* Set box */
- dig_line_box(Points, &box);
if (line == 1)
else
@@ -254,14 +254,12 @@
else
lines[0] = -line;
- area = dig_add_area(plus, 1, lines);
- dig_area_set_box(plus, area, &box);
+ area = dig_add_area(plus, 1, lines, &box);
/* Each area is also isle */
lines[0] = -lines[0]; /* island is counter clockwise */
- isle = dig_add_isle(plus, 1, lines);
- dig_isle_set_box(plus, isle, &box);
+ isle = dig_add_isle(plus, 1, lines, &box);
if (iPart == 0) { /* outer ring */
outer_area = area;
@@ -287,16 +285,16 @@
else {
G_debug(4, " Centroid: %f, %f", x, y);
Vect_reset_line(Points[0]);
Vect_append_point(Points[0], x, y, 0.0);
line = add_line(Map, GV_CENTROID, Points[0], FID, parts);
- dig_line_box(Points[0], &box);
- dig_line_set_box(plus, line, &box);
- Line->left = outer_area;
+ topo->area = outer_area;
/* register centroid to area */
Area = plus->Area[outer_area];
Modified: grass/trunk/lib/vector/Vlib/constraint.c
--- grass/trunk/lib/vector/Vlib/constraint.c 2011-07-01 08:53:19 UTC (rev 46900)
+++ grass/trunk/lib/vector/Vlib/constraint.c 2011-07-01 08:53:45 UTC (rev 46901)
@@ -55,13 +55,13 @@
return -1;
Map->Constraint_region_flag = 1;
- Map->Constraint_N = n;
- Map->Constraint_S = s;
- Map->Constraint_E = e;
- Map->Constraint_W = w;
- Map->Constraint_T = t;
- Map->Constraint_B = b;
- Map->proj = G_projection();
+ Map->Constraint_box.N = n;
+ Map->Constraint_box.S = s;
+ Map->Constraint_box.E = e;
+ Map->Constraint_box.W = w;
+ Map->Constraint_box.T = t;
+ Map->Constraint_box.B = b;
+ Map->head.proj = G_projection();
return 0;
@@ -76,12 +76,12 @@
int Vect_get_constraint_box(const struct Map_info *Map, struct bound_box * Box)
- Box->N = Map->Constraint_N;
- Box->S = Map->Constraint_S;
- Box->E = Map->Constraint_E;
- Box->W = Map->Constraint_W;
- Box->T = Map->Constraint_T;
- Box->B = Map->Constraint_B;
+ Box->N = Map->Constraint_box.N;
+ Box->S = Map->Constraint_box.S;
+ Box->E = Map->Constraint_box.E;
+ Box->W = Map->Constraint_box.W;
+ Box->T = Map->Constraint_box.T;
+ Box->B = Map->Constraint_box.B;
return 0;
Modified: grass/trunk/lib/vector/Vlib/find.c
--- grass/trunk/lib/vector/Vlib/find.c 2011-07-01 08:53:19 UTC (rev 46900)
+++ grass/trunk/lib/vector/Vlib/find.c 2011-07-01 08:53:45 UTC (rev 46901)
@@ -267,14 +267,14 @@
int i, ret, area;
static BOX_SIZE *size_list;
static int alloc_size_list = 0;
G_debug(3, "Vect_find_area() x = %f y = %f", x, y);
if (first) {
first = 0;
alloc_size_list = 10;
size_list = G_malloc(alloc_size_list * sizeof(BOX_SIZE));
@@ -287,7 +287,7 @@
box.S = y;
G_debug(3, " %d areas selected by box", List->n_values);
/* sort areas by size, the smallest is likely to be the nearest */
@@ -297,16 +297,16 @@
for (i = 0; i < List->n_values; i++) {
- size_list[i].i = area = List->value[i];
- Vect_get_area_box(Map, area, &box);
+ size_list[i].i = List->id[i];
+ box = List->box[i];
size_list[i].size = (box.N - box.S) * (box.E - box.W);
if (List->n_values == 2) {
/* simple swap */
if (size_list[1].size < size_list[0].size) {
- size_list[0].i = List->value[1];
- size_list[1].i = List->value[0];
+ size_list[0].i = List->id[1];
+ size_list[1].i = List->id[0];
else if (List->n_values > 2)
@@ -339,13 +339,13 @@
int i, ret, island, current, current_size, size;
G_debug(3, "Vect_find_island() x = %f y = %f", x, y);
if (first) {
first = 0;
@@ -357,14 +357,14 @@
box.S = y;
- Vect_select_isles_by_box(Map, &box, List);
+ Vect_select_isles_by_box_with_box(Map, &box, List);
G_debug(3, " %d islands selected by box", List->n_values);
current_size = -1;
current = 0;
- island = List->value[i];
- ret = Vect_point_in_island(x, y, Map, island);
+ island = List->id[i];
+ ret = Vect_point_in_island(x, y, Map, island, List->box[i]);
if (ret >= 1) { /* inside */
if (current > 0) { /* not first */
Modified: grass/trunk/lib/vector/Vlib/header.c
--- grass/trunk/lib/vector/Vlib/header.c 2011-07-01 08:53:19 UTC (rev 46900)
+++ grass/trunk/lib/vector/Vlib/header.c 2011-07-01 08:53:45 UTC (rev 46901)
@@ -434,8 +434,8 @@
int Vect_set_person(struct Map_info *Map, const char *str)
- G_free(Map->head.your_name);
- Map->head.your_name = G_store(str);
+ G_free(Map->head.user_name);
+ Map->head.user_name = G_store(str);
return 0;
@@ -449,7 +449,7 @@
const char *Vect_get_person(const struct Map_info *Map)
- return Map->head.your_name;
+ return (Map->head.user_name);
@@ -545,8 +545,8 @@
int Vect_set_comment(struct Map_info *Map, const char *str)
- G_free(Map->head.line_3);
- Map->head.line_3 = G_store(str);
+ G_free(Map->head.comment);
+ Map->head.comment = G_store(str);
return 0;
@@ -560,7 +560,7 @@
const char *Vect_get_comment(const struct Map_info *Map)
- return Map->head.line_3;
+ return (Map->head.comment);
@@ -606,7 +606,7 @@
int Vect_set_proj(struct Map_info *Map, int proj)
- Map->proj = proj;
+ Map->head.proj = proj;
return 0;
@@ -623,7 +623,7 @@
int Vect_get_proj(const struct Map_info *Map)
- return Map->proj;
+ return (Map->head.proj);
Modified: grass/trunk/lib/vector/Vlib/init_head.c
--- grass/trunk/lib/vector/Vlib/init_head.c 2011-07-01 08:53:19 UTC (rev 46900)
+++ grass/trunk/lib/vector/Vlib/init_head.c 2011-07-01 08:53:45 UTC (rev 46901)
@@ -39,7 +39,7 @@
Vect_set_date(Map, "");
/* user name */
- Map->head.your_name = NULL;
+ Map->head.user_name = NULL;
sprintf(buf, "%s", G_whoami());
Vect_set_person(Map, buf);
@@ -53,7 +53,7 @@
Vect_set_map_date(Map, buf);
/* comments */
- Map->head.line_3 = NULL;
+ Map->head.comment = NULL;
Vect_set_comment(Map, "");
/* scale, threshold */
Modified: grass/trunk/lib/vector/Vlib/intersect.c
--- grass/trunk/lib/vector/Vlib/intersect.c 2011-07-01 08:53:19 UTC (rev 46900)
+++ grass/trunk/lib/vector/Vlib/intersect.c 2011-07-01 08:53:45 UTC (rev 46901)
@@ -81,8 +81,8 @@
#if 0
static int ident(double x1, double y1, double x2, double y2, double thresh);
#endif
-static int cross_seg(int id, int *arg);
-static int find_cross(int id, int *arg);
+static int cross_seg(int id, struct Rect rect, int *arg);
+static int find_cross(int id, struct Rect rect, int *arg);
#define D ((ax2-ax1)*(by1-by2) - (ay2-ay1)*(bx1-bx2))
#define D1 ((bx1-ax1)*(by1-by2) - (by1-ay1)*(bx1-bx2))
@@ -462,7 +462,7 @@
/* Current line in arrays is for some functions like cmp() set by: */
static int current;
-static int second; /* line whic is not current */
+static int second; /* line which is not current */
static int a_cross = 0;
static int n_cross;
@@ -540,7 +540,7 @@
static struct line_pnts *APnts, *BPnts;
/* break segments (called by rtree search) */
double x1, y1, z1, x2, y2, z2;
int i, j, ret;
@@ -1059,6 +1059,8 @@
*BLines = XLines;
+ /* clean up */
return 1;
@@ -1068,7 +1070,7 @@
static int cross_found; /* set by find_cross() */
int i, j, ret;
Modified: grass/trunk/lib/vector/Vlib/legal_vname.c
--- grass/trunk/lib/vector/Vlib/legal_vname.c 2011-07-01 08:53:19 UTC (rev 46900)
+++ grass/trunk/lib/vector/Vlib/legal_vname.c 2011-07-01 08:53:45 UTC (rev 46901)
@@ -90,6 +90,7 @@
int error)
const char *mapset;
+ char nm[GNAME_MAX], ms[GMAPSET_MAX];
if (Vect_legal_filename(output) == -1) {
if (error == GV_FATAL_EXIT) {
@@ -106,7 +107,14 @@
- mapset = G_find_vector2(input, "");
+ if (G_name_is_fully_qualified(input, nm, ms)) {
+ if (strcasecmp(ms, "ogr") != 0)
+ mapset = G_find_vector2(input, "");
+ else
+ mapset = ms;
+ else
if (mapset == NULL) {
@@ -123,7 +131,6 @@
if (strcmp(mapset, G_mapset()) == 0) {
const char *in;
- char nm[GNAME_MAX], ms[GMAPSET_MAX];
in = nm;
Modified: grass/trunk/lib/vector/Vlib/level_two.c
--- grass/trunk/lib/vector/Vlib/level_two.c 2011-07-01 08:53:19 UTC (rev 46900)
+++ grass/trunk/lib/vector/Vlib/level_two.c 2011-07-01 08:53:45 UTC (rev 46901)
@@ -23,9 +23,9 @@
\return number of nodes
-plus_t Vect_get_num_nodes(const struct Map_info *map)
+plus_t Vect_get_num_nodes(const struct Map_info *Map)
- return (map->plus.n_nodes);
+ return (Map->plus.n_nodes);
@@ -36,22 +36,22 @@
\return number of primitives
-plus_t Vect_get_num_primitives(const struct Map_info *map, int type)
+plus_t Vect_get_num_primitives(const struct Map_info *Map, int type)
plus_t num = 0;
if (type & GV_POINT)
- num += map->plus.n_plines;
+ num += Map->plus.n_plines;
if (type & GV_LINE)
- num += map->plus.n_llines;
+ num += Map->plus.n_llines;
if (type & GV_BOUNDARY)
- num += map->plus.n_blines;
+ num += Map->plus.n_blines;
if (type & GV_CENTROID)
- num += map->plus.n_clines;
+ num += Map->plus.n_clines;
if (type & GV_FACE)
- num += map->plus.n_flines;
+ num += Map->plus.n_flines;
if (type & GV_KERNEL)
- num += map->plus.n_klines;
+ num += Map->plus.n_klines;
return num;
@@ -63,9 +63,9 @@
\return number of features
-plus_t Vect_get_num_lines(const struct Map_info *map)
+plus_t Vect_get_num_lines(const struct Map_info *Map)
- return (map->plus.n_lines);
+ return (Map->plus.n_lines);
@@ -75,9 +75,9 @@
\return number of areas
-plus_t Vect_get_num_areas(const struct Map_info *map)
+plus_t Vect_get_num_areas(const struct Map_info *Map)
- return (map->plus.n_areas);
+ return (Map->plus.n_areas);
@@ -87,9 +87,9 @@
\return number of kernels
-plus_t Vect_get_num_kernels(const struct Map_info *map)
+plus_t Vect_get_num_kernels(const struct Map_info *Map)
- return (map->plus.n_klines);
+ return (Map->plus.n_klines);
@@ -100,9 +100,9 @@
\return number of faces
-plus_t Vect_get_num_faces(const struct Map_info *map)
+plus_t Vect_get_num_faces(const struct Map_info *Map)
- return (map->plus.n_flines);
+ return (Map->plus.n_flines);
@@ -113,9 +113,9 @@
\return number of volumes
-plus_t Vect_get_num_volumes(const struct Map_info *map)
+plus_t Vect_get_num_volumes(const struct Map_info *Map)
- return (map->plus.n_volumes);
+ return (Map->plus.n_volumes);
@@ -126,9 +126,9 @@
\return number of islands
-plus_t Vect_get_num_islands(const struct Map_info *map)
+plus_t Vect_get_num_islands(const struct Map_info *Map)
- return (map->plus.n_isles);
+ return (Map->plus.n_isles);
@@ -139,9 +139,9 @@
\return number of holes
-plus_t Vect_get_num_holes(const struct Map_info *map)
+plus_t Vect_get_num_holes(const struct Map_info *Map)
- return (map->plus.n_holes);
+ return (Map->plus.n_holes);
@@ -152,9 +152,10 @@
\return number of dblinks
-int Vect_get_num_dblinks(const struct Map_info *map)
+int Vect_get_num_dblinks(const struct Map_info *Map)
- return (map->dblnk->n_fields);
+ /* available on level 1 ? */
+ return (Map->dblnk->n_fields);
@@ -164,9 +165,9 @@
\return number of updated features
-int Vect_get_num_updated_lines(const struct Map_info *map)
+int Vect_get_num_updated_lines(const struct Map_info *Map)
- return (map->plus.n_uplines);
+ return (Map->plus.n_uplines);
@@ -177,9 +178,9 @@
\return updated line
-int Vect_get_updated_line(const struct Map_info *map, int idx)
+int Vect_get_updated_line(const struct Map_info *Map, int idx)
- return (map->plus.uplines[idx]);
+ return (Map->plus.uplines[idx]);
@@ -189,9 +190,9 @@
\return number of updated nodes
-int Vect_get_num_updated_nodes(const struct Map_info *map)
+int Vect_get_num_updated_nodes(const struct Map_info *Map)
- return (map->plus.n_upnodes);
+ return (Map->plus.n_upnodes);
@@ -202,12 +203,33 @@
\return updated node
-int Vect_get_updated_node(const struct Map_info *map, int idx)
+int Vect_get_updated_node(const struct Map_info *Map, int idx)
- return (map->plus.upnodes[idx]);
+ return (Map->plus.upnodes[idx]);
+ \brief Get line type
+ \param map vector map
+ \param line line id
+ \return line type
+int
+Vect_get_line_type(const struct Map_info *Map, int line)
+ if (Map->level < 2)
+ G_fatal_error(_("Vector map <%s> is not open on level >= 2"),
+ Vect_get_full_name(Map));
+ if (!Vect_line_alive(Map, line))
+ return 0;
+ return (Map->plus.Line[line]->type);
\brief Get node coordinates
@@ -217,12 +239,12 @@
\return 0
int
-Vect_get_node_coor(const struct Map_info *map, int num, double *x, double *y,
+Vect_get_node_coor(const struct Map_info *Map, int num, double *x, double *y,
double *z)
- Node = map->plus.Node[num];
+ Node = Map->plus.Node[num];
*x = Node->x;
*y = Node->y;
@@ -243,17 +265,34 @@
int Vect_get_line_nodes(const struct Map_info *Map, int line, int *n1, int *n2)
+ char type;
if (Map->level < 2)
- if (n1 != NULL)
- *n1 = Map->plus.Line[line]->N1;
+ type = Vect_get_line_type(Map, line);
- if (n2 != NULL)
- *n2 = Map->plus.Line[line]->N2;
+ if (!(type & GV_LINES))
+ G_fatal_error(_("Nodes not available for line %d"), line);
+ struct P_topo_l *topo = (struct P_topo_l *)Map->plus.Line[line]->topo;
+ if (n1 != NULL)
+ *n1 = topo->N1;
+ if (n2 != NULL)
+ *n2 = topo->N2;
+ struct P_topo_b *topo = (struct P_topo_b *)Map->plus.Line[line]->topo;
+ if (n1 != NULL)
+ *n1 = topo->N1;
+ if (n2 != NULL)
+ *n2 = topo->N2;
return 1;
@@ -268,16 +307,24 @@
int Vect_get_line_areas(const struct Map_info *Map, int line, int *left, int *right)
if (Map->level < 2)
+ if (!Map->plus.Line[line]->topo)
+ G_fatal_error(_("Areas not available for line %d"), line);
+ if (Vect_get_line_type(Map, line) != GV_BOUNDARY)
+ G_fatal_error(_("Line %d is not a boundary"), line);
+ topo = (struct P_topo_b *)Map->plus.Line[line]->topo;
if (left != NULL)
- *left = Map->plus.Line[line]->left;
+ *left = topo->left;
if (right != NULL)
- *right = Map->plus.Line[line]->right;
+ *right = topo->right;
return 1;
@@ -349,9 +396,12 @@
int Vect_get_centroid_area(const struct Map_info *Map, int centroid)
if (Map->level < 2)
- return (Map->plus.Line[centroid]->left);
+ topo = (struct P_topo_c *)Map->plus.Line[centroid]->topo;
+ return (topo->area);
Modified: grass/trunk/lib/vector/Vlib/list.c
--- grass/trunk/lib/vector/Vlib/list.c 2011-07-01 08:53:19 UTC (rev 46900)
+++ grass/trunk/lib/vector/Vlib/list.c 2011-07-01 08:53:45 UTC (rev 46901)
@@ -207,3 +207,203 @@
return 0;
+/* box list routines */
+ * \brief Creates and initializes a struct boxlist.
+ * This structure is used as container for bounding boxes with id. The
+ * library routines handle all memory allocation.
+ * \return pointer to struct boxlist
+ * \return NULL on error
+struct boxlist *Vect_new_boxlist(void)
+ struct boxlist *p;
+ p = (struct boxlist *)G_malloc(sizeof(struct boxlist));
+ if (p) {
+ p->id = NULL;
+ p->box = NULL;
+ p->n_values = 0;
+ p->alloc_values = 0;
+ return p;
+ * \brief Reset boxlist structure.
+ * To make sure boxlist structure is clean to be re-used. List must have
+ * previously been created with Vect_new_boxlist().
+ * \param[in,out] list pointer to struct boxlist
+ * \return 0
+int Vect_reset_boxlist(struct boxlist *list)
+ list->n_values = 0;
+ return 0;
+ * \brief Frees all memory associated with a struct boxlist, including
+ * the struct itself
+ * \param[in,out] list pointer to ilist structure
+void Vect_destroy_boxlist(struct boxlist *list)
+ if (list) { /* probably a moot test */
+ if (list->alloc_values) {
+ G_free((void *)list->id);
+ G_free((void *)list->box);
+ G_free((void *)list);
+ list = NULL;
+ * \brief Append new item to the end of list if not yet present
+ * \param val new item to append to the end of list
+ * \return 0 on success
+ * \return 1 on error
+int Vect_boxlist_append(struct boxlist *list, int id, struct bound_box box)
+ int i;
+ size_t size;
+ if (list == NULL)
+ return 1;
+ for (i = 0; i < list->n_values; i++) {
+ if (id == list->id[i])
+ return 0;
+ if (list->n_values == list->alloc_values) {
+ size = (list->n_values + 1000) * sizeof(int);
+ list->id = (int *)G_realloc((void *)list->id, size);
+ size = (list->n_values + 1000) * sizeof(struct bound_box);
+ list->box = (struct bound_box *)G_realloc((void *)list->box, size);
+ list->alloc_values = list->n_values + 1000;
+ list->id[list->n_values] = id;
+ list->box[list->n_values] = box;
+ list->n_values++;
+ return 0;
+ * \brief Append new items to the end of list if not yet present
+ * \param[in,out] alist pointer to boxlist structure where items will be appended
+ * \param blist pointer to boxlist structure with new items
+int Vect_boxlist_append_boxlist(struct boxlist *alist, const struct boxlist *blist)
+ int i;
+ if (alist == NULL || blist == NULL)
+ return 1;
+ for (i = 0; i < blist->n_values; i++)
+ Vect_boxlist_append(alist, blist->id[i], blist->box[i]);
+ return 0;
+ * \brief Remove a given value (item) from list
+ * \param[in,out] list pointer to boxlist structure
+ * \param val to remove
+int Vect_boxlist_delete(struct boxlist *list, int id)
+ int i, j;
+ if (list == NULL)
+ return 1;
+ if (id == list->id[i]) {
+ for (j = i + 1; j < list->n_values; j++) {
+ list->id[j - 1] = list->id[j];
+ list->box[j - 1] = list->box[j];
+ list->n_values--;
+ return 0;
+ return 0;
+ * \brief Delete list from existing list
+ * \param[in,out] alist pointer to original boxlist structure,
+ * \param blist pointer to boxlist structure with items to delete
+int Vect_boxlist_delete_boxlist(struct boxlist *alist, const struct boxlist *blist)
+ int i;
+ return 1;
+ Vect_boxlist_delete(alist, blist->id[i]);
+ return 0;
+ * \brief Find a given item in the list
+ * \param list pointer to boxlist structure
+ * \param val value of item
+ * \return 1 if an item is found
+ * \return 0 no found item in the list
+int Vect_val_in_boxlist(const struct boxlist *list, int id)
+ int i;
+ if (list == NULL)
+ return 0;
+ return 1;
+ return 0;
Modified: grass/trunk/lib/vector/Vlib/merge_lines.c
--- grass/trunk/lib/vector/Vlib/merge_lines.c 2011-07-01 08:53:19 UTC (rev 46900)
+++ grass/trunk/lib/vector/Vlib/merge_lines.c 2011-07-01 08:53:45 UTC (rev 46901)
@@ -90,7 +90,15 @@
/* go backward as long as there is only one other line/boundary at the current node */
G_debug(3, "go backward");
- next_node = Line->N1;
+ next_node = 0;
+ next_node = topo->N1;
first = -line;
while (1) {
node_n_lines = Vect_get_node_n_lines(Map, next_node);
@@ -108,10 +116,26 @@
abs(next_line) != line) {
first = next_line;
- if (first < 0)
- next_node = Plus->Line[-first]->N1;
- else
- next_node = Plus->Line[first]->N2;
+ if (first < 0) {
+ struct P_topo_l *topo = (struct P_topo_l *)Plus->Line[-first]->topo;
+ struct P_topo_b *topo = (struct P_topo_b *)Plus->Line[-first]->topo;
+ else {
+ struct P_topo_l *topo = (struct P_topo_l *)Plus->Line[first]->topo;
+ next_node = topo->N2;
+ struct P_topo_b *topo = (struct P_topo_b *)Plus->Line[first]->topo;
else
break;
@@ -123,10 +147,26 @@
/* reverse direction */
last = -first;
- if (last < 0)
- next_node = Plus->Line[-last]->N1;
- else
- next_node = Plus->Line[last]->N2;
+ if (last < 0) {
+ struct P_topo_l *topo = (struct P_topo_l *)Plus->Line[-last]->topo;
+ struct P_topo_b *topo = (struct P_topo_b *)Plus->Line[-last]->topo;
+ else {
+ struct P_topo_l *topo = (struct P_topo_l *)Plus->Line[last]->topo;
+ struct P_topo_b *topo = (struct P_topo_b *)Plus->Line[last]->topo;
Vect_reset_list(List);
while (1) {
@@ -147,10 +187,26 @@
abs(next_line) != abs(first)) {
last = next_line;
- if (last < 0)
- else
+ if (last < 0) {
+ else {
else
break;
Modified: grass/trunk/lib/vector/Vlib/net.c
--- grass/trunk/lib/vector/Vlib/net.c 2011-07-01 08:53:19 UTC (rev 46900)
+++ grass/trunk/lib/vector/Vlib/net.c 2011-07-01 08:53:45 UTC (rev 46901)
@@ -223,11 +223,12 @@
for (i = 1; i <= nlines; i++) {
G_percent(i, nlines, 1); /* must be before any continue */
dofw = dobw = 1;
- Vect_get_line_nodes(Map, i, &from, &to);
type = Vect_read_line(Map, Points, Cats, i);
if (!(type & ltype & (GV_LINE | GV_BOUNDARY)))
continue;
+ Vect_get_line_nodes(Map, i, &from, &to);
if (afcol != NULL) {
if (!(Vect_cat_get(Cats, afield, &cat))) {
G_debug(2,
Modified: grass/trunk/lib/vector/Vlib/open.c
--- grass/trunk/lib/vector/Vlib/open.c 2011-07-01 08:53:19 UTC (rev 46900)
+++ grass/trunk/lib/vector/Vlib/open.c 2011-07-01 08:53:45 UTC (rev 46901)
@@ -275,6 +275,8 @@
G_warning(_("Unable to read header file of vector map <%s>"),
+ /* projection is not written to head but zone ??? */
/* zone not set */
if (Vect_get_zone(Map) == -1)
Modified: grass/trunk/lib/vector/Vlib/overlap.c
--- grass/trunk/lib/vector/Vlib/overlap.c 2011-07-01 08:53:19 UTC (rev 46900)
+++ grass/trunk/lib/vector/Vlib/overlap.c 2011-07-01 08:53:45 UTC (rev 46901)
@@ -31,11 +31,11 @@
struct Cell_head W;
/* updated for Lat lon support 21 Jun 91 */
- W.north = Map->Constraint_N;
- W.south = Map->Constraint_S;
- W.east = Map->Constraint_E;
- W.west = Map->Constraint_W;
- W.proj = Map->proj;
+ W.north = Map->Constraint_box.N;
+ W.south = Map->Constraint_box.S;
+ W.east = Map->Constraint_box.E;
+ W.west = Map->Constraint_box.W;
+ W.proj = Map->head.proj;
return G_window_overlap(&W, n, s, e, w);
Modified: grass/trunk/lib/vector/Vlib/poly.c
--- grass/trunk/lib/vector/Vlib/poly.c 2011-07-01 08:53:19 UTC (rev 46900)
+++ grass/trunk/lib/vector/Vlib/poly.c 2011-07-01 08:53:45 UTC (rev 46901)
@@ -681,6 +681,7 @@
\param X,Y point coordinates
\param Map vector map
\param area area id
+ \param box area bounding box
\return 0 - outside
\return 1 - inside
@@ -688,7 +689,7 @@
int
Vect_point_in_area_outer_ring(double X, double Y, const struct Map_info *Map,
- int area)
+ int area, struct bound_box box)
int n_intersects, inter;
@@ -710,7 +711,7 @@
/* First it must be in box */
- if (X < Area->W || X > Area->E || Y > Area->N || Y < Area->S)
+ if (X < box.W || X > box.E || Y > box.N || Y < box.S)
return 0;
n_intersects = 0;
@@ -719,9 +720,11 @@
G_debug(3, " line[%d] = %d", i, line);
+ Vect_get_line_box(Map, line, &box);
/* dont check lines that obviously do not intersect with test ray */
- if ((Line->N < Y) || (Line->S > Y) || (Line->E < X))
+ if ((box.N < Y) || (box.S > Y) || (box.E < X))
continue;
@@ -747,12 +750,14 @@
\param isle isle id
+ \param box isle bounding box
\return 0 - outside
\return 1 - inside
\return 2 - on the boundary (exactly may be said only for vertex of vertical/horizontal line)
-int Vect_point_in_island(double X, double Y, const struct Map_info *Map, int isle)
+int Vect_point_in_island(double X, double Y, const struct Map_info *Map,
+ int isle, struct bound_box box)
@@ -772,7 +777,7 @@
- if (X < Isle->W || X > Isle->E || Y > Isle->N || Y < Isle->S)
return 0;
n_intersects = 0;
@@ -781,8 +786,10 @@
continue;
Modified: grass/trunk/lib/vector/Vlib/read_nat.c
--- grass/trunk/lib/vector/Vlib/read_nat.c 2011-07-01 08:53:19 UTC (rev 46900)
+++ grass/trunk/lib/vector/Vlib/read_nat.c 2011-07-01 08:53:45 UTC (rev 46901)
@@ -150,7 +150,7 @@
V2_read_next_line_nat(struct Map_info *Map,
struct line_pnts *line_p, struct line_cats *line_c)
- register int line;
+ register int line, ret;
register struct P_line *Line;
struct bound_box lbox, mbox;
@@ -177,15 +177,15 @@
continue;
+ ret = V2_read_line_nat(Map, line_p, line_c, Map->next_line++);
if (Map->Constraint_region_flag) {
- Vect_get_line_box(Map, line, &lbox);
+ Vect_line_box(line_p, &lbox);
if (!Vect_box_overlap(&lbox, &mbox)) {
- Map->next_line++;
continue;
- return V2_read_line_nat(Map, line_p, line_c, Map->next_line++);
+ return ret;
/* NOTREACHED */ }
@@ -208,7 +208,7 @@
Vect__Read_line_nat(struct Map_info *Map,
struct line_pnts *p, struct line_cats *c, off_t offset)
- int i, dead = 0;
+ register int i, dead = 0;
int n_points;
off_t size;
int n_cats, do_cats;
Modified: grass/trunk/lib/vector/Vlib/read_ogr.c
--- grass/trunk/lib/vector/Vlib/read_ogr.c 2011-07-01 08:53:19 UTC (rev 46900)
+++ grass/trunk/lib/vector/Vlib/read_ogr.c 2011-07-01 08:53:45 UTC (rev 46901)
@@ -462,15 +462,29 @@
_("Attempt to read dead line"), line);
- plus_t node;
+ G_debug(4, "Centroid");
- G_debug(4, "Centroid");
- node = Line->N1;
- Node = Map->plus.Node[node];
+ if (line_p != NULL) {
+ int i, found;
+ struct boxlist list;
+ /* get area bbox */
+ Vect_get_area_box(Map, topo->area, &box);
+ /* search in spatial index for centroid with area bbox */
+ dig_init_boxlist(&list);
+ Vect_select_lines_by_box_with_box(Map, &box, Line->type, &list);
+ found = 0;
+ for (i = 0; i < list.n_values; i++) {
+ if (list.id[i] == line) {
+ found = i;
+ break;
- if (line_p != NULL) {
- Vect_append_point(line_p, Node->x, Node->y, 0.0);
+ Vect_append_point(line_p, list.box[found].E, list.box[found].N, 0.0);
if (line_c != NULL) {
Modified: grass/trunk/lib/vector/Vlib/remove_duplicates.c
--- grass/trunk/lib/vector/Vlib/remove_duplicates.c 2011-07-01 08:53:19 UTC (rev 46900)
+++ grass/trunk/lib/vector/Vlib/remove_duplicates.c 2011-07-01 08:53:45 UTC (rev 46901)
@@ -23,6 +23,7 @@
Remove duplicate lines of given types from vector map. Duplicate
lines may be optionally written to error map. Input map must be
opened on level 2 for update. Categories are merged.
+ GV_BUILD_BASE is sufficient.
\param[in,out] Map vector map where duplicate lines will be deleted
\param type type of line to be delete
Modified: grass/trunk/lib/vector/Vlib/select.c
--- grass/trunk/lib/vector/Vlib/select.c 2011-07-01 08:53:19 UTC (rev 46900)
+++ grass/trunk/lib/vector/Vlib/select.c 2011-07-01 08:53:45 UTC (rev 46901)
@@ -106,7 +106,7 @@
/************************* SELECT BY BOX *********************************/
/* This function is called by RTreeSearch() to add selected item to the list */
-static int _add_item(int id, struct ilist *list)
+static int _add_item(int id, struct Rect rect, struct ilist *list)
dig_list_add(list, id);
return 1;
Modified: grass/trunk/lib/vector/Vlib/sindex.c
--- grass/trunk/lib/vector/Vlib/sindex.c 2011-07-01 08:53:19 UTC (rev 46900)
+++ grass/trunk/lib/vector/Vlib/sindex.c 2011-07-01 08:53:45 UTC (rev 46901)
@@ -5,12 +5,12 @@
Higher level functions for reading/writing/manipulating vectors.
- (C) 2001-2009 by the GRASS Development Team
+ (C) 2001-2011 by the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
- \author Radim Blazek
+ \author Radim Blazek, Markus Metz
#include <stdlib.h>
@@ -72,6 +72,63 @@
+ \brief Select lines with bounding boxes by box.
+ Select lines whose boxes overlap specified box!!! It means that
+ selected line may or may not overlap the box.
+ \param Map vector map
+ \param Box bounding box
+ \param type line type
+ \param[out] list output list, must be initialized
+ \return number of lines
+int
+Vect_select_lines_by_box_with_box(struct Map_info *Map, const struct bound_box *Box,
+ int type, struct boxlist *list)
+ int i, line, nlines;
+ struct Plus_head *plus;
+ static struct boxlist *LocList = NULL;
+ G_debug(3, "Vect_select_lines_by_box()");
+ G_debug(3, " Box(N,S,E,W,T,B): %e, %e, %e, %e, %e, %e", Box->N, Box->S,
+ Box->E, Box->W, Box->T, Box->B);
+ plus = &(Map->plus);
+ if (!(plus->Spidx_built)) {
+ G_debug(3, "Building spatial index.");
+ Vect_build_sidx_from_topo(Map);
+ if (!LocList) {
+ LocList = (struct boxlist *)G_malloc(sizeof(struct boxlist));
+ dig_init_boxlist(LocList);
+ nlines = dig_select_lines_with_box(plus, Box, LocList);
+ G_debug(3, " %d lines selected (all types)", nlines);
+ /* Remove lines of not requested types */
+ for (i = 0; i < nlines; i++) {
+ line = LocList->id[i];
+ continue; /* Should not happen */
+ if (!(Line->type & type))
+ continue;
+ dig_boxlist_add(list, line, LocList->box[i]);
+ G_debug(3, " %d lines of requested type", list->n_values);
+ return list->n_values;
\brief Select areas by box.
Select areas whose boxes overlap specified box!!!
@@ -124,6 +181,53 @@
+ \brief Select areas with bounding boxes by box.
+ Select areas whose boxes overlap specified box!!!
+ It means that selected area may or may not overlap the box.
+ \param[out] output list, must be initialized
+ \return number of areas
+int
+Vect_select_areas_by_box_with_box(struct Map_info *Map, const struct bound_box * Box,
+ struct boxlist *list)
+ int i;
+ static int debug_level = -1;
+ if (debug_level == -1) {
+ const char *dstr = G__getenv("DEBUG");
+ if (dstr != NULL)
+ debug_level = atoi(dstr);
+ else
+ debug_level = 0;
+ G_debug(3, "Vect_select_areas_by_box()");
+ G_debug(3, "Box(N,S,E,W,T,B): %e, %e, %e, %e, %e, %e", Box->N, Box->S,
+ dig_select_areas_with_box(&(Map->plus), Box, list);
+ G_debug(3, " %d areas selected", list->n_values);
+ /* avoid loop when not debugging */
+ if (debug_level > 2) {
+ G_debug(3, " area = %d pointer to area structure = %lx",
+ list->id[i],
+ (unsigned long)Map->plus.Area[list->id[i]]);
\brief Select isles by box.
Select isles whose boxes overlap specified box!!!
@@ -155,6 +259,32 @@
+ \brief Select isles with bounding boxes by box.
+ Select isles whose boxes overlap specified box!!!
+ It means that selected isle may or may not overlap the box.
+ \return number of isles
+int
+Vect_select_isles_by_box_with_box(struct Map_info *Map, const struct bound_box * Box,
+ G_debug(3, "Vect_select_isles_by_box_with_box()");
+ dig_select_isles_with_box(&(Map->plus), Box, list);
+ G_debug(3, " %d isles selected", list->n_values);
\brief Select nodes by box.
Modified: grass/trunk/lib/vector/Vlib/snap.c
--- grass/trunk/lib/vector/Vlib/snap.c 2011-07-01 08:53:19 UTC (rev 46900)
+++ grass/trunk/lib/vector/Vlib/snap.c 2011-07-01 08:53:45 UTC (rev 46901)
@@ -40,8 +40,8 @@
double along;
} NEW;
-/* This function is called by RTreeSearch() to add selected node/line/area/isle to thelist */
-int add_item(int id, struct ilist *list)
+/* This function is called by RTreeSearch() to add selected node/line/area/isle to the list */
+int add_item(int id, struct Rect rect, struct ilist *list)
return 1;
Modified: grass/trunk/lib/vector/Vlib/write_nat.c
--- grass/trunk/lib/vector/Vlib/write_nat.c 2011-07-01 08:53:19 UTC (rev 46900)
+++ grass/trunk/lib/vector/Vlib/write_nat.c 2011-07-01 08:53:45 UTC (rev 46901)
@@ -152,10 +152,13 @@
if (plus->built >= GV_BUILD_AREAS) {
/* Delete neighbour areas/isles */
first = 1;
for (s = 0; s < 2; s++) { /* for each node */
- node = (s == 0 ? Line->N1 : Line->N2);
+ node = (s == 0 ? topo->N1 : topo->N2);
G_debug(3,
" delete neighbour areas/isles: %s node = %d",
(s == 0 ? "first" : "second"), node);
@@ -182,10 +185,11 @@
if (next_line != 0) { /* there is a boundary to the right */
NLine = plus->Line[abs(next_line)];
+ topo = (struct P_topo_b *)NLine->topo;
if (next_line > 0) /* the boundary is connected by 1. node */
- area = NLine->right; /* we are interested just in this side (close to our line) */
+ area = topo->right; /* we are interested just in this side (close to our line) */
else if (next_line < 0) /* the boundary is connected by 2. node */
- area = NLine->left;
+ area = topo->left;
G_debug(3, " next_line = %d area = %d", next_line,
area);
@@ -265,16 +269,19 @@
/* Attach centroid */
if (plus->built >= GV_BUILD_CENTROIDS) {
if (type == GV_CENTROID) {
sel_area = Vect_find_area(Map, points->x[0], points->y[0]);
G_debug(3, " new centroid %d is in area %d", line, sel_area);
if (sel_area > 0) {
if (plus->update_cidx) {
V2__add_area_cats_to_cidx_nat(Map, sel_area);
@@ -282,7 +289,7 @@
else { /* duplicate centroid */
G_debug(3,
@@ -353,10 +360,9 @@
/* Add line */
if (plus->built >= GV_BUILD_BASE) {
- line = dig_add_line(plus, type, points, offset);
+ dig_line_box(points, &box);
+ line = dig_add_line(plus, type, points, &box, offset);
G_debug(3, " line added to topo with id = %d", line);
- dig_line_box(points, &box);
if (line == 1)
else
@@ -475,10 +481,9 @@
/* Add line */
if (line == 1)
else
@@ -654,6 +659,7 @@
int adjacent[4], n_adjacent;
static struct line_cats *Cats = NULL;
G_debug(3, "V2_delete_line_nat(), line = %lu", (unsigned long) line);
@@ -672,10 +678,14 @@
if (!Cats) {
Cats = Vect_new_cats_struct();
+ if (!Points) {
+ type = V2_read_line_nat(Map, Points, Cats, line);
/* Update category index */
- type = V2_read_line_nat(Map, NULL, Cats, line);
for (i = 0; i < Cats->n_cats; i++) {
dig_cidx_del_cat(plus, Cats->field[i], Cats->cat[i], line, type);
@@ -691,6 +701,8 @@
/* Update topology */
if (plus->built >= GV_BUILD_AREAS && type == GV_BOUNDARY) {
/* Store adjacent boundaries at nodes (will be used to rebuild area/isle) */
/* Adjacent are stored: > 0 - we want right side; < 0 - we want left side */
n_adjacent = 0;
@@ -722,8 +734,8 @@
/* Delete area(s) and islands this line forms */
first = 1;
- if (Line->left > 0) { /* delete area */
- Vect_get_area_box(Map, Line->left, &box);
+ if (topo->left > 0) { /* delete area */
+ Vect_get_area_box(Map, topo->left, &box);
if (first) {
Vect_box_copy(&abox, &box);
first = 0;
@@ -732,15 +744,15 @@
Vect_box_extend(&abox, &box);
- V2__delete_area_cats_from_cidx_nat(Map, Line->left);
+ V2__delete_area_cats_from_cidx_nat(Map, topo->left);
- dig_del_area(plus, Line->left);
+ dig_del_area(plus, topo->left);
- else if (Line->left < 0) { /* delete isle */
- dig_del_isle(plus, -Line->left);
+ else if (topo->left < 0) { /* delete isle */
+ dig_del_isle(plus, -topo->left);
- if (Line->right > 0) { /* delete area */
- Vect_get_area_box(Map, Line->right, &box);
+ if (topo->right > 0) { /* delete area */
+ Vect_get_area_box(Map, topo->right, &box);
if (first) {
first = 0;
@@ -749,29 +761,31 @@
- V2__delete_area_cats_from_cidx_nat(Map, Line->right);
+ V2__delete_area_cats_from_cidx_nat(Map, topo->right);
- dig_del_area(plus, Line->right);
+ dig_del_area(plus, topo->right);
- else if (Line->right < 0) { /* delete isle */
- dig_del_isle(plus, -Line->right);
+ else if (topo->right < 0) { /* delete isle */
+ dig_del_isle(plus, -topo->right);
/* Delete reference from area */
if (plus->built >= GV_BUILD_CENTROIDS && type == GV_CENTROID) {
- G_debug(3, "Remove centroid %d from area %d", (int) line, Line->left);
+ if (topo->area > 0) {
+ G_debug(3, "Remove centroid %d from area %d", (int) line, topo->area);
+ V2__delete_area_cats_from_cidx_nat(Map, topo->area);
- Area = Map->plus.Area[Line->left];
+ Area = Map->plus.Area[topo->area];
Area->centroid = 0;
/* delete the line from topo */
- dig_del_line(plus, line);
+ dig_del_line(plus, line, Points->x[0], Points->y[0], Points->z[0]);
/* Rebuild areas/isles and attach centroids and isles */
@@ -938,10 +952,9 @@
/* restore the line from topo */
- dig_restore_line(plus, line, type, points, offset);
+ dig_restore_line(plus, line, type, points, &box, offset);
G_debug(3, " line restored in topo with id = %d", line);
Modified: grass/trunk/lib/vector/Vlib/write_ogr.c
--- grass/trunk/lib/vector/Vlib/write_ogr.c 2011-07-01 08:53:19 UTC (rev 46900)
+++ grass/trunk/lib/vector/Vlib/write_ogr.c 2011-07-01 08:53:45 UTC (rev 46901)
@@ -174,10 +174,9 @@
/* Add line */
if (line == 1)
else
@@ -288,6 +287,7 @@
G_debug(3, "V2_delete_line_nat(), line = %d", (int) line);
@@ -306,10 +306,14 @@
if (!Cats) {
+ if (!Points) {
- type = V2_read_line_ogr(Map, NULL, Cats, line);
@@ -335,7 +339,7 @@
