[GRASS-SVN] r46904 - in grass/trunk/vector: v.net.alloc
v.net.allpairs v.net.centrality v.net.components
v.net.distance v.net.iso v.net.path v.net.salesman v.net.steiner
svn_grass at osgeo.org
Fri Jul 1 04:55:08 EDT 2011
Author: mmetz
Date: 2011-07-01 01:55:08 -0700 (Fri, 01 Jul 2011)
New Revision: 46904
grass/trunk/vector/v.net.alloc/main.c
grass/trunk/vector/v.net.allpairs/main.c
grass/trunk/vector/v.net.centrality/main.c
grass/trunk/vector/v.net.components/main.c
grass/trunk/vector/v.net.distance/main.c
grass/trunk/vector/v.net.iso/main.c
grass/trunk/vector/v.net.path/path.c
grass/trunk/vector/v.net.salesman/main.c
grass/trunk/vector/v.net.steiner/main.c
remove bounding boxes from vector topology (Radim's TODO): update v.net.* modules
Modified: grass/trunk/vector/v.net.alloc/main.c
--- grass/trunk/vector/v.net.alloc/main.c 2011-07-01 08:54:19 UTC (rev 46903)
+++ grass/trunk/vector/v.net.alloc/main.c 2011-07-01 08:55:08 UTC (rev 46904)
@@ -146,8 +146,46 @@
abcol->answer, ncol->answer, geo, 0);
nnodes = Vect_get_num_nodes(&Map);
+ nlines = Vect_get_num_lines(&Map);
/* Create list of centers based on list of categories */
+ for (i = 1; i <= nlines; i++) {
+ int node;
+ ltype = Vect_get_line_type(&Map, i);
+ if (!(ltype & GV_POINT))
+ continue;
+ Vect_read_line(&Map, Points, Cats, i);
+ node = Vect_find_node(&Map, Points->x[0], Points->y[0], Points->z[0], 0, 0);
+ if (!node) {
+ G_warning(_("Point is not connected to the network"));
+ continue;
+ if (!(Vect_cat_get(Cats, nfield, &cat)))
+ continue;
+ if (Vect_cat_in_cat_list(cat, catlist)) {
+ Vect_net_get_node_cost(&Map, node, &n1cost);
+ if (n1cost == -1) { /* closed */
+ G_warning("Centre at closed node (costs = -1) ignored");
+ else {
+ if (acenters == ncenters) {
+ acenters += 1;
+ Centers =
+ (CENTER *) G_realloc(Centers,
+ acenters * sizeof(CENTER));
+ Centers[ncenters].cat = cat;
+ Centers[ncenters].node = node;
+ G_debug(2, "centre = %d node = %d cat = %d", ncenters,
+ node, cat);
+ ncenters++;
+#if 0
for (node = 1; node <= nnodes; node++) {
nlines = Vect_get_node_n_lines(&Map, node);
for (j = 0; j < nlines; j++) {
@@ -178,6 +216,7 @@
+#endif
G_message(_("Number of centers: [%d] (nlayer: [%d])"), ncenters, nfield);
Modified: grass/trunk/vector/v.net.allpairs/main.c
--- grass/trunk/vector/v.net.allpairs/main.c 2011-07-01 08:54:19 UTC (rev 46903)
+++ grass/trunk/vector/v.net.allpairs/main.c 2011-07-01 08:55:08 UTC (rev 46904)
@@ -194,7 +194,8 @@
if (type == GV_POINT) {
int node;
- Vect_get_line_nodes(&In, i, &node, NULL);
+ /* Vect_get_line_nodes(&In, i, &node, NULL); */
+ node = Vect_find_node(&In, Points->x[0], Points->y[0], Points->z[0], 0, 0);
Vect_cat_get(Cats, layer, &cats[node]);
if (cats[node] != -1) {
Vect_write_line(&Out, GV_POINT, Points, Cats);
Modified: grass/trunk/vector/v.net.centrality/main.c
--- grass/trunk/vector/v.net.centrality/main.c 2011-07-01 08:54:19 UTC (rev 46903)
+++ grass/trunk/vector/v.net.centrality/main.c 2011-07-01 08:55:08 UTC (rev 46904)
@@ -322,7 +322,8 @@
if (!Vect_cat_get(Cats, layer, &cat))
continue;
Vect_write_line(&Out, type, Points, Cats);
process_node(node, cat);
covered[node] = 1;
Modified: grass/trunk/vector/v.net.components/main.c
--- grass/trunk/vector/v.net.components/main.c 2011-07-01 08:54:19 UTC (rev 46903)
+++ grass/trunk/vector/v.net.components/main.c 2011-07-01 08:55:08 UTC (rev 46904)
@@ -190,7 +190,8 @@
else if (type == GV_POINT) {
int node;
comp = component[node];
covered[node] = 1;
Modified: grass/trunk/vector/v.net.distance/main.c
--- grass/trunk/vector/v.net.distance/main.c 2011-07-01 08:54:19 UTC (rev 46903)
+++ grass/trunk/vector/v.net.distance/main.c 2011-07-01 08:55:08 UTC (rev 46904)
@@ -64,7 +64,7 @@
"the given sets of features.");
module->description =
_("Finds the shortest paths from a feature 'to' to every feature 'from' "
- "and various information about this realtion are uploaded to the attribute table.");
+ "and various information about this relation are uploaded to the attribute table.");
/* Define the different options as defined in gis.h */
map_in = G_define_standard_option(G_OPT_V_INPUT);
@@ -233,7 +233,15 @@
if (!Vect_cat_get(Cats, flayer, &cat))
continue;
+ if (type & GV_POINTS) {
+ else {
+ Vect_get_line_nodes(&In, i, &node, NULL);
+ if (node < 1)
+ continue;
cost = dst[node] / (double)In.cost_multip;
vertex = dglGetNode(graph, node);
Modified: grass/trunk/vector/v.net.iso/main.c
--- grass/trunk/vector/v.net.iso/main.c 2011-07-01 08:54:19 UTC (rev 46903)
+++ grass/trunk/vector/v.net.iso/main.c 2011-07-01 08:55:08 UTC (rev 46904)
@@ -184,8 +184,44 @@
/* Create list of centres based on list of categories */
+ continue;
+ if (!node) {
+ continue;
+ continue;
+ G_warning(_("Centre at closed node (costs = -1) ignored"));
+ else {
+ if (acentres == ncentres) {
+ acentres += 1;
+ Centers =
+ acentres * sizeof(CENTER));
+ Centers[ncentres].cat = cat;
+ Centers[ncentres].node = node;
+ G_debug(2, "centre = %d node = %d cat = %d", ncentres,
+ node, cat);
+ ncentres++;
+#if 0
@@ -216,6 +252,7 @@
+#endif
G_message(_("Number of centres: %d (nlayer %d)"), ncentres, nfield);
Modified: grass/trunk/vector/v.net.path/path.c
--- grass/trunk/vector/v.net.path/path.c 2011-07-01 08:54:19 UTC (rev 46903)
+++ grass/trunk/vector/v.net.path/path.c 2011-07-01 08:55:08 UTC (rev 46904)
@@ -118,7 +118,7 @@
db_begin_transaction(driver);
- /* Read stdin, find shortest path, and write connectin line and new database record */
+ /* Read stdin, find shortest path, and write connecting line and new database record */
cat = 0;
formaterr = nopoint = unreachable = 0;
while (1) {
@@ -173,7 +173,9 @@
else {
fline = Citem->line;
- Vect_get_line_nodes(In, fline, &fnode, NULL);
+ type = Vect_read_line(&In, Points, NULL, fline);
+ fnode = Vect_find_node(&In, Points->x[0], Points->y[0], Points->z[0], 0, 0);
+ /* Vect_get_line_nodes(In, fline, &fnode, NULL); */
G_debug(3, "from: cat = %5d point(line) = %5d node = %5d", fcat,
fline, fnode);
@@ -191,7 +193,9 @@
else {
tline = Citem->line;
- Vect_get_line_nodes(In, tline, &tnode, NULL);
+ type = Vect_read_line(&In, Points, NULL, tline);
+ tnode = Vect_find_node(&In, Points->x[0], Points->y[0], Points->z[0], 0, 0);
+ /* Vect_get_line_nodes(In, tline, &tnode, NULL); */
G_debug(3, "to : cat = %5d point(line) = %5d node = %5d", tcat,
tline, tnode);
Modified: grass/trunk/vector/v.net.salesman/main.c
--- grass/trunk/vector/v.net.salesman/main.c 2011-07-01 08:54:19 UTC (rev 46903)
+++ grass/trunk/vector/v.net.salesman/main.c 2011-07-01 08:55:08 UTC (rev 46904)
@@ -95,6 +95,7 @@
struct line_cats *Cats;
struct line_pnts *Points;
const char *dstr;
+ char buf[2000], buf2[2000];
/* Initialize the GIS calls */
G_gisinit(argv[0]);
@@ -192,8 +193,31 @@
Vect_set_open_level(2);
Vect_open_old(&Map, map->answer, "");
/* Create list of terminals based on list of categories */
+ continue;
+ if (!node) {
+ continue;
+ if (!(Vect_cat_get(Cats, tfield, &cat)))
+ continue;
+ if (Vect_cat_in_cat_list(cat, Clist)) {
+ Vect_list_append(TList, node);
+#if 0
for (i = 1; i <= nnodes; i++) {
nlines = Vect_get_node_n_lines(&Map, i);
@@ -208,6 +232,8 @@
+#endif
ncities = TList->n_values;
G_message(_("Number of cities: [%d]"), ncities);
if (ncities < 2)
@@ -419,41 +445,51 @@
Vect_open_new(&Out, output->answer, Vect_is_3d(&Map));
Vect_hist_command(&Out);
- fprintf(stdout, "\nCycle:\n");
- fprintf(stdout, "Arcs' categories (layer %d, %d arcs):\n", afield,
+ G_verbose_message(_("Cycle:"));
+ G_verbose_message(_("Arcs' categories (layer %d, %d arcs):"), afield,
StArcs->n_values);
for (i = 0; i < StArcs->n_values; i++) {
line = StArcs->value[i];
ltype = Vect_read_line(&Map, Points, Cats, line);
Vect_write_line(&Out, ltype, Points, Cats);
Vect_cat_get(Cats, afield, &cat);
- if (i > 0)
- printf(",");
- fprintf(stdout, "%d", cat);
+ if (i > 0) {
+ sprintf(buf2, ", %d", cat);
+ strcat(buf, buf2);
+ else
+ sprintf(buf, "%d", cat);
- fprintf(stdout, "\n\n");
+ G_verbose_message("%s\n\n", buf);
- fprintf(stdout, "Nodes' categories (layer %d, %d nodes):\n", tfield,
+ G_verbose_message(_("Nodes' categories (layer %d, %d nodes):"), tfield,
StNodes->n_values);
k = 0;
- for (i = 0; i < StNodes->n_values; i++) {
- node = StNodes->value[i];
- nlines = Vect_get_node_n_lines(&Map, node);
- for (j = 0; j < nlines; j++) {
- line = abs(Vect_get_node_line(&Map, node, j));
- ltype = Vect_read_line(&Map, Points, Cats, line);
- if (!(ltype & GV_POINT))
- continue;
- if (!(Vect_cat_get(Cats, tfield, &cat)))
- continue;
- Vect_write_line(&Out, ltype, Points, Cats);
- if (k > 0)
- fprintf(stdout, ",");
- k++;
+ for (i = 0; i < TList->n_values; i++) {
+ double coor_x, coor_y, coor_z;
+ node = TList->value[i];
+ Vect_get_node_coor(&Map, node, &coor_x, &coor_y, &coor_z);
+ line = Vect_find_line(&Map, coor_x, coor_y, coor_z, GV_POINT, 0, 0, 0);
+ if (!line)
+ continue;
+ ltype = Vect_read_line(&Map, Points, Cats, line);
+ continue;
+ continue;
+ Vect_write_line(&Out, ltype, Points, Cats);
+ if (k > 0) {
+ else
+ k++;
Vect_build(&Out);
Modified: grass/trunk/vector/v.net.steiner/main.c
--- grass/trunk/vector/v.net.steiner/main.c 2011-07-01 08:54:19 UTC (rev 46903)
+++ grass/trunk/vector/v.net.steiner/main.c 2011-07-01 08:55:08 UTC (rev 46904)
@@ -332,6 +332,7 @@
struct ilist *TList; /* list of terminal nodes */
struct ilist *StArcs; /* list of arcs on Steiner tree */
struct ilist *StNodes; /* list of nodes on Steiner tree */
+ struct ilist *pointlist;
double cost, tmpcost;
struct cat_list *Clist;
@@ -426,8 +427,28 @@
+ continue;
+ if (!node) {
+ continue;
+ continue;
+ Vect_list_append(TList, i);
+#if 0
@@ -442,6 +463,7 @@
+#endif
nterms = TList->n_values;
fprintf(stdout, "Number of terminals: %d\n", nterms);
@@ -611,11 +633,22 @@
StNodes->n_values);
k = 0;
+ pointlist = Vect_new_list();
+ double x, y, z;
+ struct bound_box box;
+ Vect_get_node_coor(&Map, node, &x, &y, &z);
+ box.E = box.W = x;
+ box.N = box.S = y;
+ box.T = box.B = z;
+ Vect_select_lines_by_box(&Map, &box, GV_POINT, pointlist);
+ for (j = 0; j < pointlist->n_values; j++) {
+ line = pointlist->value[j];
continue;
