[GRASS-SVN] r46914 - grass/trunk/lib/init
svn_grass at osgeo.org
Fri Jul 1 06:35:02 EDT 2011
Author: martinl
Date: 2011-07-01 03:35:02 -0700 (Fri, 01 Jul 2011)
New Revision: 46914
grass/trunk/lib/init/grass.py
grass.py: don't delete gislock on concurrent usage
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2011-07-01 10:22:00 UTC (rev 46913)
+++ grass/trunk/lib/init/grass.py 2011-07-01 10:35:02 UTC (rev 46914)
@@ -52,6 +52,7 @@
tmpdir = None
lockfile = None
+remove_lockfile = True
location = None
create_new = None
grass_gui = None
@@ -82,10 +83,10 @@
try_rmdir(os.path.join(root, name))
def cleanup():
- tmpdir, lockfile
+ tmpdir, lockfile, remove_lockfile
# all exits after setting up $tmpdir should also tidy it up
cleanup_dir(tmpdir)
- if lockfile:
+ if lockfile and remove_lockfile:
try_remove(lockfile)
def fatal(msg):
@@ -584,12 +585,15 @@
"Concurrent use not allowed." % \
{ 'user' : user, 'file' : lockfile })
else:
- msg = _("Unable to properly access \"%s\"\nPlease notify system personel.") % lockfile
+ msg = _("Unable to properly access '%s'.\n"
+ "Please notify system personel.") % lockfile
if msg:
if grass_gui == "wxpython":
thetest = call([os.getenv('GRASS_PYTHON'), os.path.join(wxpython_base, "gis_set_error.py"), msg])
else:
+ global remove_lockfile
+ remove_lockfile = False
fatal(msg)
def make_fontcap():
