[GRASS-SVN] r46938 - grass/trunk/display/d.vect
svn_grass at osgeo.org
Sun Jul 3 13:00:20 EDT 2011
Author: mmetz
Date: 2011-07-03 10:00:20 -0700 (Sun, 03 Jul 2011)
New Revision: 46938
grass/trunk/display/d.vect/area.c
read areas and their isles only once
Modified: grass/trunk/display/d.vect/area.c
--- grass/trunk/display/d.vect/area.c 2011-07-03 16:52:00 UTC (rev 46937)
+++ grass/trunk/display/d.vect/area.c 2011-07-03 17:00:20 UTC (rev 46938)
@@ -23,8 +23,9 @@
int num, area, isle, n_isles, n_points;
double xl, yl;
- struct line_pnts *Points, *IPoints;
+ struct line_pnts *Points, * APoints, **IPoints;
struct line_cats *Cats;
+ int n_ipoints_alloc;
int cat, centroid = 0;
int red, grn, blu;
@@ -42,7 +43,12 @@
G_debug(1, "display areas:");
Points = Vect_new_line_struct();
- IPoints = Vect_new_line_struct();
+ APoints = Vect_new_line_struct();
+ n_ipoints_alloc = 10;
+ IPoints = (struct line_pnts **)G_malloc(n_ipoints_alloc * sizeof(struct line_pnts *));
+ for (i = 0; i < n_ipoints_alloc; i++) {
+ IPoints[i] = Vect_new_line_struct();
Cats = Vect_new_cats_struct();
open_db = table_colors_flag || width_column;
@@ -189,7 +195,7 @@
G_debug(3, "centroid = %d", centroid);
if (centroid < 1)
continue;
- Vect_read_line(Map, Points, Cats, centroid);
+ Vect_read_line(Map, NULL, Cats, centroid);
for (i = 0; i < Cats->n_cats; i++) {
G_debug(3, " centroid = %d, field = %d, cat = %d", centroid,
@@ -207,17 +213,26 @@
G_debug(3, "display area %d", area);
/* fill */
- Vect_get_area_points(Map, area, Points);
- G_debug(3, "n_points = %d", Points->n_points);
+ Vect_get_area_points(Map, area, APoints);
+ G_debug(3, "n_points = %d", APoints->n_points);
+ Vect_reset_line(Points);
+ Vect_append_points(Points, APoints, GV_FORWARD);
n_points = Points->n_points;
xl = Points->x[n_points - 1];
yl = Points->y[n_points - 1];
n_isles = Vect_get_area_num_isles(Map, area);
+ if (n_isles >= n_ipoints_alloc) {
+ IPoints = (struct line_pnts **)G_realloc(IPoints, (n_isles + 10) * sizeof(struct line_pnts *));
+ for (i = n_ipoints_alloc; i < n_isles + 10; i++) {
+ n_ipoints_alloc = n_isles + 10;
for (i = 0; i < n_isles; i++) {
isle = Vect_get_area_isle(Map, area, i);
- Vect_get_isle_points(Map, isle, IPoints);
- Vect_append_points(Points, IPoints, GV_FORWARD);
+ Vect_get_isle_points(Map, isle, IPoints[i]);
+ Vect_append_points(Points, IPoints[i], GV_FORWARD);
Vect_append_point(Points, xl, yl, 0.0); /* ??? */
@@ -379,7 +394,6 @@
if (bcolor) {
int i;
if (rgb) {
D_RGB_color((unsigned char)red, (unsigned char)grn,
(unsigned char)blu);
@@ -388,18 +402,20 @@
D_RGB_color(bcolor->r, bcolor->g, bcolor->b);
/*use different user defined render methods */
- D_polyline_abs(Points->x, Points->y, Points->n_points);
+ D_polyline_abs(APoints->x, APoints->y, APoints->n_points);
- isle = Vect_get_area_isle(Map, area, i);
- Vect_get_isle_points(Map, isle, Points);
+ D_polyline_abs(IPoints[i]->x, IPoints[i]->y, IPoints[i]->n_points);
} /* end for */
Vect_destroy_line_struct(Points);
- Vect_destroy_line_struct(IPoints);
+ Vect_destroy_line_struct(APoints);
+ Vect_destroy_line_struct(IPoints[i]);
+ G_free(IPoints);
Vect_destroy_cats_struct(Cats);
return 0;
