[GRASS-SVN] r46949 - in grass/trunk/gui/wxpython: . gui_modules
svn_grass at osgeo.org
Mon Jul 4 04:05:40 EDT 2011
Author: martinl
Date: 2011-07-04 01:05:40 -0700 (Mon, 04 Jul 2011)
New Revision: 46949
grass/trunk/gui/wxpython/gis_set.py
grass/trunk/gui/wxpython/gui_modules/utils.py
wxGUI: fix startup dialog when gisdbase is not available
(merge r46947 from relbr64)
Modified: grass/trunk/gui/wxpython/gis_set.py
--- grass/trunk/gui/wxpython/gis_set.py 2011-07-04 08:02:12 UTC (rev 46948)
+++ grass/trunk/gui/wxpython/gis_set.py 2011-07-04 08:05:40 UTC (rev 46949)
@@ -91,7 +91,7 @@
versionFile = open(os.path.join(globalvar.ETCDIR, "VERSIONNUMBER"))
grassVersion = versionFile.readline().split(' ')[0].rstrip('\n')
versionFile.close()
self.select_box = wx.StaticBox (parent = self.panel, id = wx.ID_ANY,
label = " %s " % _("Choose project location and mapset"))
Modified: grass/trunk/gui/wxpython/gui_modules/utils.py
--- grass/trunk/gui/wxpython/gui_modules/utils.py 2011-07-04 08:02:12 UTC (rev 46948)
+++ grass/trunk/gui/wxpython/gui_modules/utils.py 2011-07-04 08:05:40 UTC (rev 46949)
@@ -756,7 +756,14 @@
def GetSettingsPath():
"""!Get full path to the settings directory
- version = int(grass.version()['version'].split('.', 1)[0])
+ try:
+ verFd = open(os.path.join(globalvar.ETCDIR, "VERSIONNUMBER"))
+ version = int(verFd.readlines()[0].split(' ')[0].split('.')[0])
+ except (IOError, ValueError, TypeError, IndexError), e:
+ sys.exit(_("ERROR: Unable to determine GRASS version. Details: %s") % e)
+ verFd.close()
if sys.platform == 'win32':
return os.path.join(os.getenv('APPDATA'), '.grass%d' % version)
