[GRASS-SVN] r46951 - in grass/trunk/raster/r.colors: . tests
Mon Jul 4 05:06:40 EDT 2011
Author: aghisla
Date: 2011-07-04 02:06:40 -0700 (Mon, 04 Jul 2011)
New Revision: 46951
Added:
   grass/trunk/raster/r.colors/tests/
   grass/trunk/raster/r.colors/tests/example1
   grass/trunk/raster/r.colors/tests/example2
   grass/trunk/raster/r.colors/tests/example3
   grass/trunk/raster/r.colors/tests/example4
   grass/trunk/raster/r.colors/tests/test.r.colors.sh
   grass/trunk/raster/r.colors/tests/test_elev_double_default.ref
   grass/trunk/raster/r.colors/tests/test_elev_double_example1.ref
   grass/trunk/raster/r.colors/tests/test_elev_double_example1_hist.ref
   grass/trunk/raster/r.colors/tests/test_elev_double_example2.ref
   grass/trunk/raster/r.colors/tests/test_elev_double_example2_log.ref
   grass/trunk/raster/r.colors/tests/test_elev_double_example3.ref
   grass/trunk/raster/r.colors/tests/test_elev_double_example3_logabs.ref
   grass/trunk/raster/r.colors/tests/test_elev_double_example4.ref
   grass/trunk/raster/r.colors/tests/test_elev_double_example4_inv.ref
   grass/trunk/raster/r.colors/tests/test_elev_float_example1.ref
   grass/trunk/raster/r.colors/tests/test_elev_float_example1_hist.ref
   grass/trunk/raster/r.colors/tests/test_elev_float_example2.ref
   grass/trunk/raster/r.colors/tests/test_elev_float_example2_log.ref
   grass/trunk/raster/r.colors/tests/test_elev_float_example3.ref
   grass/trunk/raster/r.colors/tests/test_elev_float_example3_logabs.ref
   grass/trunk/raster/r.colors/tests/test_elev_float_example4.ref
   grass/trunk/raster/r.colors/tests/test_elev_float_example4_inv.ref
   grass/trunk/raster/r.colors/tests/test_elev_int_example1.ref
   grass/trunk/raster/r.colors/tests/test_elev_int_example1_hist.ref
   grass/trunk/raster/r.colors/tests/test_elev_int_example1_perc.ref
   grass/trunk/raster/r.colors/tests/test_elev_int_example2.ref
   grass/trunk/raster/r.colors/tests/test_elev_int_example2_log.ref
   grass/trunk/raster/r.colors/tests/test_elev_int_example2_perc.ref
   grass/trunk/raster/r.colors/tests/test_elev_int_example3.ref
   grass/trunk/raster/r.colors/tests/test_elev_int_example3_logabs.ref
   grass/trunk/raster/r.colors/tests/test_elev_int_example3_perc.ref
   grass/trunk/raster/r.colors/tests/test_elev_int_example4.ref
   grass/trunk/raster/r.colors/tests/test_elev_int_example4_inv.ref
   grass/trunk/raster/r.colors/tests/test_elev_int_example4_perc.ref
   grass/trunk/raster/r.colors/tests/test_volume_double_default.ref
   grass/trunk/raster/r.colors/tests/test_volume_double_example1.ref
   grass/trunk/raster/r.colors/tests/test_volume_double_example1_hist.ref
   grass/trunk/raster/r.colors/tests/test_volume_double_example2.ref
   grass/trunk/raster/r.colors/tests/test_volume_double_example2_log.ref
   grass/trunk/raster/r.colors/tests/test_volume_double_example3.ref
   grass/trunk/raster/r.colors/tests/test_volume_double_example3_logabs.ref
   grass/trunk/raster/r.colors/tests/test_volume_double_example4.ref
   grass/trunk/raster/r.colors/tests/test_volume_double_example4_inv.ref
   grass/trunk/raster/r.colors/tests/test_volume_double_example5.ref
Removed:
   grass/trunk/raster/r.colors/example1
   grass/trunk/raster/r.colors/example2
   grass/trunk/raster/r.colors/example3
   grass/trunk/raster/r.colors/example4
   grass/trunk/raster/r.colors/test.r.colors.sh
   grass/trunk/raster/r.colors/test_elev_double_default.ref
   grass/trunk/raster/r.colors/test_elev_double_example1.ref
   grass/trunk/raster/r.colors/test_elev_double_example1_hist.ref
   grass/trunk/raster/r.colors/test_elev_double_example2.ref
   grass/trunk/raster/r.colors/test_elev_double_example2_log.ref
   grass/trunk/raster/r.colors/test_elev_double_example3.ref
   grass/trunk/raster/r.colors/test_elev_double_example3_logabs.ref
   grass/trunk/raster/r.colors/test_elev_double_example4.ref
   grass/trunk/raster/r.colors/test_elev_double_example4_inv.ref
   grass/trunk/raster/r.colors/test_elev_float_example1.ref
   grass/trunk/raster/r.colors/test_elev_float_example1_hist.ref
   grass/trunk/raster/r.colors/test_elev_float_example2.ref
   grass/trunk/raster/r.colors/test_elev_float_example2_log.ref
   grass/trunk/raster/r.colors/test_elev_float_example3.ref
   grass/trunk/raster/r.colors/test_elev_float_example3_logabs.ref
   grass/trunk/raster/r.colors/test_elev_float_example4.ref
   grass/trunk/raster/r.colors/test_elev_float_example4_inv.ref
   grass/trunk/raster/r.colors/test_elev_int_example1.ref
   grass/trunk/raster/r.colors/test_elev_int_example1_hist.ref
   grass/trunk/raster/r.colors/test_elev_int_example1_perc.ref
   grass/trunk/raster/r.colors/test_elev_int_example2.ref
   grass/trunk/raster/r.colors/test_elev_int_example2_log.ref
   grass/trunk/raster/r.colors/test_elev_int_example2_perc.ref
   grass/trunk/raster/r.colors/test_elev_int_example3.ref
   grass/trunk/raster/r.colors/test_elev_int_example3_logabs.ref
   grass/trunk/raster/r.colors/test_elev_int_example3_perc.ref
   grass/trunk/raster/r.colors/test_elev_int_example4.ref
   grass/trunk/raster/r.colors/test_elev_int_example4_inv.ref
   grass/trunk/raster/r.colors/test_elev_int_example4_perc.ref
   grass/trunk/raster/r.colors/test_volume_double_default.ref
   grass/trunk/raster/r.colors/test_volume_double_example1.ref
   grass/trunk/raster/r.colors/test_volume_double_example1_hist.ref
   grass/trunk/raster/r.colors/test_volume_double_example2.ref
   grass/trunk/raster/r.colors/test_volume_double_example2_log.ref
   grass/trunk/raster/r.colors/test_volume_double_example3.ref
   grass/trunk/raster/r.colors/test_volume_double_example3_logabs.ref
   grass/trunk/raster/r.colors/test_volume_double_example4.ref
   grass/trunk/raster/r.colors/test_volume_double_example4_inv.ref
   grass/trunk/raster/r.colors/test_volume_double_example5.ref
Moved test files into tests/ subdirectory.
Deleted: grass/trunk/raster/r.colors/example1
--- grass/trunk/raster/r.colors/example1	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/example1	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,7 +0,0 @@
-0%     0 230 0
-20%    0 160 0
-35%   50 130 0
-55% 120 100 30
-75% 120 130 40
-90% 170 160 50
-100% 255 255 150
Deleted: grass/trunk/raster/r.colors/example2
--- grass/trunk/raster/r.colors/example2	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/example2	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,3 +0,0 @@
-0% 128 255 0
-50% 255 0 128
-100% 0 128 255
Deleted: grass/trunk/raster/r.colors/example3
--- grass/trunk/raster/r.colors/example3	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/example3	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,7 +0,0 @@
-0%     0 230 0
-10%    0 160 0
-17%   50 130 0
-27% 120 100 30
-37% 120 130 40
-55% 170 160 50
-70% 255 255 150
Deleted: grass/trunk/raster/r.colors/example4
--- grass/trunk/raster/r.colors/example4	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/example4	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,9 +0,0 @@
-1 black
-2 yellow
-3 orange
-4 red
-5 magenta
-6 indigo
-7 cyan
-8 green
-9 black
Deleted: grass/trunk/raster/r.colors/test.r.colors.sh
--- grass/trunk/raster/r.colors/test.r.colors.sh	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/test.r.colors.sh	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,68 +0,0 @@
-# This script tests r.colors and r.colors.out as well
-# as r3.colors and r3.colors.out which have the same code base
-# Color rules are set with r/r3.colors and exported using r/r3.colors.out
-# We specific a small region in the
-# @preprocess step and generate
-# raster data with r.mapcalc
-# The region setting should work for UTM and LL test locations
-g.region s=0 n=90 w=0 e=100 b=0 t=50 res=10 res3=10 -p3
-# To test r.colors, we need several maps of different types
-r.mapcalc --o expr="test_elev_int = int(if(row() == 2, null(), row()))"
-r.mapcalc --o expr="test_elev_double = double(if(row() == 2, null(), row() + 0.5))"
-r.mapcalc --o expr="test_elev_float = float(if(row() == 2, null(), row() + 0.5))"
-# Create the volumes
-r3.mapcalc --o expr="volume_double = double(col() + row() + depth())"
-r3.mapcalc --o expr="volume_double_null = if(row() == 1 || row() == 5, null(), volume_double)"
-# First we @test the integer maps
-# We use the examples to test the import, export and setting of color tables with differrent options
-# the vaidation is based on raster map colur rules @files reference files created with r.colors.out
-r.colors    map=test_elev_int rules=example1 && r.colors.out --o map=test_elev_int rules=test_elev_int_example1.txt
-r.colors -e map=test_elev_int rules=example1 && r.colors.out --o map=test_elev_int rules=test_elev_int_example1_hist.txt
-r.colors    map=test_elev_int rules=example2 && r.colors.out --o map=test_elev_int rules=test_elev_int_example2.txt
-r.colors -g map=test_elev_int rules=example2 && r.colors.out --o map=test_elev_int rules=test_elev_int_example2_log.txt
-r.colors    map=test_elev_int rules=example3 && r.colors.out --o map=test_elev_int rules=test_elev_int_example3.txt
-r.colors -a map=test_elev_int rules=example3 && r.colors.out --o map=test_elev_int rules=test_elev_int_example3_logabs.txt
-r.colors    map=test_elev_int rules=example4 && r.colors.out --o map=test_elev_int rules=test_elev_int_example4.txt
-r.colors -n map=test_elev_int rast=test_elev_int && r.colors.out --o map=test_elev_int rules=test_elev_int_example4_inv.txt
-# test the percentage output
-r.colors map=test_elev_int rules=example1 && r.colors.out --o -p map=test_elev_int rules=test_elev_int_example1_perc.txt
-r.colors map=test_elev_int rules=example2 && r.colors.out --o -p map=test_elev_int rules=test_elev_int_example2_perc.txt
-r.colors map=test_elev_int rules=example3 && r.colors.out --o -p map=test_elev_int rules=test_elev_int_example3_perc.txt
-r.colors map=test_elev_int rules=example4 && r.colors.out --o -p map=test_elev_int rules=test_elev_int_example4_perc.txt
-# float maps
-r.colors    map=test_elev_float rules=example1 && r.colors.out --o map=test_elev_float rules=test_elev_float_example1.txt
-r.colors -e map=test_elev_float rules=example1 && r.colors.out --o map=test_elev_float rules=test_elev_float_example1_hist.txt
-r.colors    map=test_elev_float rules=example2 && r.colors.out --o map=test_elev_float rules=test_elev_float_example2.txt
-r.colors -g map=test_elev_float rules=example2 && r.colors.out --o map=test_elev_float rules=test_elev_float_example2_log.txt
-r.colors    map=test_elev_float rules=example3 && r.colors.out --o map=test_elev_float rules=test_elev_float_example3.txt
-r.colors -a map=test_elev_float rules=example3 && r.colors.out --o map=test_elev_float rules=test_elev_float_example3_logabs.txt
-r.colors    map=test_elev_float rules=example4 && r.colors.out --o map=test_elev_float rules=test_elev_float_example4.txt
-r.colors -n map=test_elev_float rast=test_elev_float && r.colors.out --o map=test_elev_float rules=test_elev_float_example4_inv.txt
-# double maps
-r.colors    map=test_elev_double rules=example1 && r.colors.out --o map=test_elev_double rules=test_elev_double_example1.txt
-r.colors -e map=test_elev_double rules=example1 && r.colors.out --o map=test_elev_double rules=test_elev_double_example1_hist.txt
-r.colors    map=test_elev_double rules=example2 && r.colors.out --o map=test_elev_double rules=test_elev_double_example2.txt
-r.colors -g map=test_elev_double rules=example2 && r.colors.out --o map=test_elev_double rules=test_elev_double_example2_log.txt
-r.colors    map=test_elev_double rules=example3 && r.colors.out --o map=test_elev_double rules=test_elev_double_example3.txt
-r.colors -a map=test_elev_double rules=example3 && r.colors.out --o map=test_elev_double rules=test_elev_double_example3_logabs.txt
-r.colors    map=test_elev_double rules=example4 && r.colors.out --o map=test_elev_double rules=test_elev_double_example4.txt
-r.colors -n map=test_elev_double rast=test_elev_double && r.colors.out --o map=test_elev_double rules=test_elev_double_example4_inv.txt
-# The volume maps using r3.colors and r3.colors.out
-r3.colors    map=volume_double_null rules=example1 && r3.colors.out --o map=volume_double_null rules=test_volume_double_example1.txt
-r3.colors -e map=volume_double_null rules=example1 && r3.colors.out --o map=volume_double_null rules=test_volume_double_example1_hist.txt
-r3.colors    map=volume_double_null rules=example2 && r3.colors.out --o map=volume_double_null rules=test_volume_double_example2.txt
-r3.colors -g map=volume_double_null rules=example2 && r3.colors.out --o map=volume_double_null rules=test_volume_double_example2_log.txt
-r3.colors    map=volume_double_null rules=example3 && r3.colors.out --o map=volume_double_null rules=test_volume_double_example3.txt
-r3.colors -a map=volume_double_null rules=example3 && r3.colors.out --o map=volume_double_null rules=test_volume_double_example3_logabs.txt
-r3.colors    map=volume_double_null rules=example4 && r3.colors.out --o map=volume_double_null rules=test_volume_double_example4.txt
-r3.colors -n map=volume_double_null volume=volume_double_null && r3.colors.out --o map=volume_double_null rules=test_volume_double_example4_inv.txt
-# Apply a raster color table to the volume map
-r3.colors    map=volume_double_null raster=test_elev_double   && r3.colors.out --o map=volume_double_null rules=test_volume_double_example5.txt
-# Test the removement the raster3d color table, a default color table will be created
-r3.colors -r map=volume_double_null && r3.colors.out --o map=volume_double_null rules=test_volume_double_default.txt
-# Test the removement the raster color table, a default color table will be created
-r.colors -r map=test_elev_double && r.colors.out --o map=test_elev_double rules=test_elev_double_default.txt
Deleted: grass/trunk/raster/r.colors/test_elev_double_default.ref
--- grass/trunk/raster/r.colors/test_elev_double_default.ref	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/test_elev_double_default.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,8 +0,0 @@
-1.5 255:255:0
-3.1 0:255:0
-4.7 0:255:255
-6.3 0:0:255
-7.9 255:0:255
-9.5 255:0:0
-nv 255:255:255
-default 255:255:255
Deleted: grass/trunk/raster/r.colors/test_elev_double_example1.ref
--- grass/trunk/raster/r.colors/test_elev_double_example1.ref	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/test_elev_double_example1.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,9 +0,0 @@
-1.5 0:230:0
-3.1 0:160:0
-4.3 50:130:0
-5.9 120:100:30
-7.5 120:130:40
-8.7 170:160:50
-9.5 255:255:150
-nv 255:255:255
Deleted: grass/trunk/raster/r.colors/test_elev_double_example1_hist.ref
--- grass/trunk/raster/r.colors/test_elev_double_example1_hist.ref	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/test_elev_double_example1_hist.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,11 +0,0 @@
-1.5 0:230:0
-1.508 0:187:0
-3.508 16:150:0
-4.508 58:127:3
-5.508 102:108:22
-6.508 120:111:33
-7.508 120:129:40
-8.508 161:155:48
-9.5 161:155:48
-nv 255:255:255
Deleted: grass/trunk/raster/r.colors/test_elev_double_example2.ref
--- grass/trunk/raster/r.colors/test_elev_double_example2.ref	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/test_elev_double_example2.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,5 +0,0 @@
-1.5 128:255:0
-5.5 255:0:128
-9.5 0:128:255
-nv 255:255:255
Deleted: grass/trunk/raster/r.colors/test_elev_double_example2_log.ref
--- grass/trunk/raster/r.colors/test_elev_double_example2_log.ref	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/test_elev_double_example2_log.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,103 +0,0 @@
-1.5 128:255:0
-1.52794 130:250:2
-1.55641 133:245:5
-1.58541 135:240:7
-1.61494 138:235:10
-1.64503 140:230:12
-1.67567 143:225:15
-1.70689 145:220:17
-1.73869 148:215:20
-1.77108 150:210:23
-1.80407 153:205:25
-1.83768 155:199:28
-1.87192 158:194:30
-1.90679 161:189:33
-1.94232 163:184:35
-1.9785 166:179:38
-2.01536 168:174:40
-2.0529 171:169:43
-2.09115 173:164:46
-2.13011 176:159:48
-2.16979 178:153:51
-2.21021 181:148:53
-2.25139 183:143:56
-2.29333 186:138:58
-2.33605 188:133:61
-2.37957 191:128:64
-2.42391 194:123:66
-2.46906 196:118:69
-2.51506 199:113:71
-2.56191 201:108:74
-2.60964 204:102:76
-2.65826 206:97:79
-2.70778 209:92:81
-2.75823 211:87:84
-2.80961 214:82:87
-2.86195 216:77:89
-2.91527 219:72:92
-2.96958 221:67:94
-3.0249 224:62:97
-3.08126 227:57:99
-3.13866 229:51:102
-3.19713 232:46:104
-3.25669 234:41:107
-3.31736 237:36:110
-3.37917 239:31:112
-3.44212 242:26:115
-3.50624 244:21:117
-3.57156 247:16:120
-3.6381 249:11:122
-3.70588 252:6:125
-3.77492 255:0:128
-3.84524 250:2:130
-3.91688 245:5:133
-3.98985 240:7:135
-4.06418 235:10:138
-4.13989 230:12:140
-4.21702 225:15:143
-4.29558 220:17:145
-4.3756 215:20:148
-4.45712 210:23:150
-4.54015 205:25:153
-4.62474 199:28:155
-4.71089 194:30:158
-4.79866 189:33:161
-4.88805 184:35:163
-4.97912 179:38:166
-5.07188 174:40:168
-5.16636 169:43:171
-5.26261 164:46:173
-5.36065 159:48:176
-5.46052 154:51:178
-5.56225 148:53:181
-5.66587 143:56:183
-5.77142 138:58:186
-5.87894 133:61:188
-5.98847 128:64:191
-6.10003 123:66:194
-6.21367 118:69:196
-6.32943 113:71:199
-6.44734 108:74:201
-6.56746 102:76:204
-6.68981 97:79:206
-6.81443 92:81:209
-6.94138 87:84:211
-7.0707 82:87:214
-7.20243 77:89:216
-7.3366 72:92:219
-7.47328 67:94:221
-7.61251 62:97:224
-7.75433 57:99:227
-7.89879 52:102:229
-8.04594 46:104:232
-8.19583 41:107:234
-8.34852 36:110:237
-8.50405 31:112:239
-8.66247 26:115:242
-8.82385 21:117:244
-8.98824 16:120:247
-9.15569 11:122:249
-9.32625 6:125:252
-9.5 0:128:255
-nv 255:255:255
Deleted: grass/trunk/raster/r.colors/test_elev_double_example3.ref
--- grass/trunk/raster/r.colors/test_elev_double_example3.ref	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/test_elev_double_example3.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,9 +0,0 @@
-1.5 0:230:0
-2.3 0:160:0
-2.86 50:130:0
-3.66 120:100:30
-4.46 120:130:40
-5.9 170:160:50
-7.1 255:255:150
-nv 255:255:255
Deleted: grass/trunk/raster/r.colors/test_elev_double_example3_logabs.ref
--- grass/trunk/raster/r.colors/test_elev_double_example3_logabs.ref	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/test_elev_double_example3_logabs.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,382 +0,0 @@
-1 0:230:0
-1.02114 0:226:0
--1.02114 0:226:0
--1 0:230:0
-1.02114 0:226:0
-1.04272 0:221:0
--1.04272 0:221:0
--1.02114 0:226:0
-1.04272 0:221:0
-1.06477 0:216:0
--1.06477 0:216:0
--1.04272 0:221:0
-1.06477 0:216:0
-1.08727 0:211:0
--1.08727 0:211:0
--1.06477 0:216:0
-1.08727 0:211:0
-1.11026 0:206:0
--1.11026 0:206:0
--1.08727 0:211:0
-1.11026 0:206:0
-1.13373 0:201:0
--1.13373 0:201:0
--1.11026 0:206:0
-1.13373 0:201:0
-1.15769 0:196:0
--1.15769 0:196:0
--1.13373 0:201:0
-1.15769 0:196:0
-1.18217 0:191:0
--1.18217 0:191:0
--1.15769 0:196:0
-1.18217 0:191:0
-1.20716 0:186:0
--1.20716 0:186:0
--1.18217 0:191:0
-1.20716 0:186:0
-1.23267 0:181:0
--1.23267 0:181:0
--1.20716 0:186:0
-1.23267 0:181:0
-1.25873 0:177:0
--1.25873 0:177:0
--1.23267 0:181:0
-1.25873 0:177:0
-1.28534 0:172:0
--1.28534 0:172:0
--1.25873 0:177:0
-1.28534 0:172:0
-1.31251 0:167:0
--1.31251 0:167:0
--1.28534 0:172:0
-1.31251 0:167:0
-1.34026 0:162:0
--1.34026 0:162:0
--1.31251 0:167:0
-1.34026 0:162:0
-1.36859 3:158:0
--1.36859 3:158:0
--1.34026 0:162:0
-1.36859 3:158:0
-1.39752 8:155:0
--1.39752 8:155:0
--1.36859 3:158:0
-1.39752 8:155:0
-1.42706 13:152:0
--1.42706 13:152:0
--1.39752 8:155:0
-1.42706 13:152:0
-1.45723 18:149:0
--1.45723 18:149:0
--1.42706 13:152:0
-1.45723 18:149:0
-1.48803 23:146:0
--1.48803 23:146:0
--1.45723 18:149:0
-1.48803 23:146:0
-1.51949 28:143:0
--1.51949 28:143:0
--1.48803 23:146:0
-1.51949 28:143:0
-1.55161 33:140:0
--1.55161 33:140:0
--1.51949 28:143:0
-1.55161 33:140:0
-1.58441 38:137:0
--1.58441 38:137:0
--1.55161 33:140:0
-1.58441 38:137:0
-1.6179 43:134:0
--1.6179 43:134:0
--1.58441 38:137:0
-1.6179 43:134:0
-1.6521 48:131:0
--1.6521 48:131:0
--1.6179 43:134:0
-1.6521 48:131:0
-1.68702 53:129:1
--1.68702 53:129:1
--1.6521 48:131:0
-1.68702 53:129:1
-1.72269 58:127:3
--1.72269 58:127:3
--1.68702 53:129:1
-1.72269 58:127:3
-1.7591 63:125:5
--1.7591 63:125:5
--1.72269 58:127:3
-1.7591 63:125:5
-1.79629 68:123:7
--1.79629 68:123:7
--1.7591 63:125:5
-1.79629 68:123:7
-1.83426 73:121:9
--1.83426 73:121:9
--1.79629 68:123:7
-1.83426 73:121:9
-1.87303 77:119:11
--1.87303 77:119:11
--1.83426 73:121:9
-1.87303 77:119:11
-1.91263 82:116:14
--1.91263 82:116:14
--1.87303 77:119:11
-1.91263 82:116:14
-1.95306 87:114:16
--1.95306 87:114:16
--1.91263 82:116:14
-1.95306 87:114:16
-1.99434 92:112:18
--1.99434 92:112:18
--1.95306 87:114:16
-1.99434 92:112:18
-2.0365 97:110:20
--2.0365 97:110:20
--1.99434 92:112:18
-2.0365 97:110:20
-2.07955 102:108:22
--2.07955 102:108:22
--2.0365 97:110:20
-2.07955 102:108:22
-2.12351 107:106:24
--2.12351 107:106:24
-2.12351 107:106:24
-2.1684 112:104:26
--2.1684 112:104:26
-2.1684 112:104:26
-2.21424 117:102:28
--2.21424 117:102:28
--2.1684 112:104:26
-2.21424 117:102:28
-2.26104 120:100:30
--2.26104 120:100:30
-2.26104 120:100:30
-2.30884 120:103:31
--2.30884 120:103:31
-2.30884 120:103:31
-2.35765 120:105:31
--2.35765 120:105:31
-2.35765 120:105:31
-2.40749 120:107:32
--2.40749 120:107:32
-2.40749 120:107:32
-2.45838 120:109:33
--2.45838 120:109:33
-2.45838 120:109:33
-2.51034 120:111:33
--2.51034 120:111:33
-2.51034 120:111:33
-2.56341 120:113:34
--2.56341 120:113:34
-2.56341 120:113:34
-2.6176 120:115:35
--2.6176 120:115:35
-2.6176 120:115:35
-2.67293 120:117:35
--2.67293 120:117:35
--2.6176 120:115:35
-2.67293 120:117:35
-2.72944 120:119:36
--2.72944 120:119:36
-2.72944 120:119:36
-2.78713 120:121:37
--2.78713 120:121:37
-2.78713 120:121:37
-2.84605 120:123:37
--2.84605 120:123:37
-2.84605 120:123:37
-2.90621 120:126:38
--2.90621 120:126:38
-2.90621 120:126:38
-2.96765 120:128:39
--2.96765 120:128:39
-2.96765 120:128:39
-3.03038 120:130:40
--3.03038 120:130:40
-3.03038 120:130:40
-3.09444 122:131:40
--3.09444 122:131:40
-3.09444 122:131:40
-3.15985 124:132:40
--3.15985 124:132:40
-3.15985 124:132:40
-3.22665 126:133:41
--3.22665 126:133:41
-3.22665 126:133:41
-3.29486 128:134:41
--3.29486 128:134:41
-3.29486 128:134:41
-3.36451 129:135:41
--3.36451 129:135:41
-3.36451 129:135:41
-3.43563 131:137:42
--3.43563 131:137:42
-3.43563 131:137:42
-3.50825 133:138:42
--3.50825 133:138:42
-3.50825 133:138:42
-3.58241 135:139:43
--3.58241 135:139:43
-3.58241 135:139:43
-3.65814 137:140:43
--3.65814 137:140:43
-3.65814 137:140:43
-3.73547 139:141:43
--3.73547 139:141:43
-3.73547 139:141:43
-3.81444 141:142:44
--3.81444 141:142:44
-3.81444 141:142:44
-3.89507 143:144:44
--3.89507 143:144:44
-3.89507 143:144:44
-3.97741 145:145:45
--3.97741 145:145:45
-3.97741 145:145:45
-4.06149 147:146:45
--4.06149 147:146:45
-4.06149 147:146:45
-4.14734 149:147:45
--4.14734 149:147:45
-4.14734 149:147:45
-4.23501 151:148:46
--4.23501 151:148:46
-4.23501 151:148:46
-4.32454 153:149:46
--4.32454 153:149:46
-4.32454 153:149:46
-4.41595 155:151:47
--4.41595 155:151:47
-4.41595 155:151:47
-4.5093 157:152:47
--4.5093 157:152:47
-4.5093 157:152:47
-4.60462 159:153:47
--4.60462 159:153:47
--4.5093 157:152:47
-4.60462 159:153:47
-4.70196 161:154:48
--4.70196 161:154:48
-4.70196 161:154:48
-4.80135 163:155:48
--4.80135 163:155:48
-4.80135 163:155:48
-4.90285 164:156:48
--4.90285 164:156:48
-4.90285 164:156:48
-5.00649 166:158:49
--5.00649 166:158:49
-5.00649 166:158:49
-5.11232 168:159:49
--5.11232 168:159:49
-5.11232 168:159:49
-5.22039 171:161:51
--5.22039 171:161:51
-5.22039 171:161:51
-5.33075 175:166:56
--5.33075 175:166:56
-5.33075 175:166:56
-5.44343 179:170:61
--5.44343 179:170:61
-5.44343 179:170:61
-5.5585 183:175:65
--5.5585 183:175:65
-5.5585 183:175:65
-5.676 187:179:70
--5.676 187:179:70
--5.5585 183:175:65
-5.676 187:179:70
-5.79599 191:184:75
--5.79599 191:184:75
--5.676 187:179:70
-5.79599 191:184:75
-5.91851 195:188:79
--5.91851 195:188:79
-5.91851 195:188:79
-6.04362 199:192:84
--6.04362 199:192:84
-6.04362 199:192:84
-6.17138 203:197:89
--6.17138 203:197:89
-6.17138 203:197:89
-6.30183 207:201:93
--6.30183 207:201:93
-6.30183 207:201:93
-6.43505 211:206:98
--6.43505 211:206:98
-6.43505 211:206:98
-6.57108 215:210:103
--6.57108 215:210:103
-6.70998 219:215:108
--6.70998 219:215:108
-6.85182 223:219:112
--6.85182 223:219:112
-6.99666 227:223:117
--6.99666 227:223:117
-7.14457 231:228:121
--7.14457 231:228:121
-7.1 255:255:150
-7.93232 251:250:145
--7.93232 251:250:145
--7.1 255:255:150
-nv 255:255:255
Deleted: grass/trunk/raster/r.colors/test_elev_double_example4.ref
--- grass/trunk/raster/r.colors/test_elev_double_example4.ref	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/test_elev_double_example4.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,11 +0,0 @@
-1 0:0:0
-2 255:255:0
-3 255:127:0
-4 255:0:0
-5 255:0:255
-6 0:127:255
-7 0:255:255
-8 0:255:0
-9 0:0:0
-nv 255:255:255
Deleted: grass/trunk/raster/r.colors/test_elev_double_example4_inv.ref
--- grass/trunk/raster/r.colors/test_elev_double_example4_inv.ref	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/test_elev_double_example4_inv.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,11 +0,0 @@
-1 0:0:0
-2 255:255:0
-3 255:127:0
-4 255:0:0
-5 255:0:255
-6 0:127:255
-7 0:255:255
-8 0:255:0
-9 0:0:0
-nv 255:255:255
Deleted: grass/trunk/raster/r.colors/test_elev_float_example1.ref
--- grass/trunk/raster/r.colors/test_elev_float_example1.ref	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/test_elev_float_example1.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,9 +0,0 @@
-1.5 0:230:0
-3.1 0:160:0
-4.3 50:130:0
-5.9 120:100:30
-7.5 120:130:40
-8.7 170:160:50
-9.5 255:255:150
-nv 255:255:255
Deleted: grass/trunk/raster/r.colors/test_elev_float_example1_hist.ref
--- grass/trunk/raster/r.colors/test_elev_float_example1_hist.ref	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/test_elev_float_example1_hist.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,11 +0,0 @@
-1.5 0:230:0
-1.508 0:187:0
-3.508 16:150:0
-4.508 58:127:3
-5.508 102:108:22
-6.508 120:111:33
-7.508 120:129:40
-8.508 161:155:48
-9.5 161:155:48
-nv 255:255:255
Deleted: grass/trunk/raster/r.colors/test_elev_float_example2.ref
--- grass/trunk/raster/r.colors/test_elev_float_example2.ref	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/test_elev_float_example2.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,5 +0,0 @@
-1.5 128:255:0
-5.5 255:0:128
-9.5 0:128:255
-nv 255:255:255
Deleted: grass/trunk/raster/r.colors/test_elev_float_example2_log.ref
--- grass/trunk/raster/r.colors/test_elev_float_example2_log.ref	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/test_elev_float_example2_log.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,103 +0,0 @@
-1.5 128:255:0
-1.52794 130:250:2
-1.55641 133:245:5
-1.58541 135:240:7
-1.61494 138:235:10
-1.64503 140:230:12
-1.67567 143:225:15
-1.70689 145:220:17
-1.73869 148:215:20
-1.77108 150:210:23
-1.80407 153:205:25
-1.83768 155:199:28
-1.87192 158:194:30
-1.90679 161:189:33
-1.94232 163:184:35
-1.9785 166:179:38
-2.01536 168:174:40
-2.0529 171:169:43
-2.09115 173:164:46
-2.13011 176:159:48
-2.16979 178:153:51
-2.21021 181:148:53
-2.25139 183:143:56
-2.29333 186:138:58
-2.33605 188:133:61
-2.37957 191:128:64
-2.42391 194:123:66
-2.46906 196:118:69
-2.51506 199:113:71
-2.56191 201:108:74
-2.60964 204:102:76
-2.65826 206:97:79
-2.70778 209:92:81
-2.75823 211:87:84
-2.80961 214:82:87
-2.86195 216:77:89
-2.91527 219:72:92
-2.96958 221:67:94
-3.0249 224:62:97
-3.08126 227:57:99
-3.13866 229:51:102
-3.19713 232:46:104
-3.25669 234:41:107
-3.31736 237:36:110
-3.37917 239:31:112
-3.44212 242:26:115
-3.50624 244:21:117
-3.57156 247:16:120
-3.6381 249:11:122
-3.70588 252:6:125
-3.77492 255:0:128
-3.84524 250:2:130
-3.91688 245:5:133
-3.98985 240:7:135
-4.06418 235:10:138
-4.13989 230:12:140
-4.21702 225:15:143
-4.29558 220:17:145
-4.3756 215:20:148
-4.45712 210:23:150
-4.54015 205:25:153
-4.62474 199:28:155
-4.71089 194:30:158
-4.79866 189:33:161
-4.88805 184:35:163
-4.97912 179:38:166
-5.07188 174:40:168
-5.16636 169:43:171
-5.26261 164:46:173
-5.36065 159:48:176
-5.46052 154:51:178
-5.56225 148:53:181
-5.66587 143:56:183
-5.77142 138:58:186
-5.87894 133:61:188
-5.98847 128:64:191
-6.10003 123:66:194
-6.21367 118:69:196
-6.32943 113:71:199
-6.44734 108:74:201
-6.56746 102:76:204
-6.68981 97:79:206
-6.81443 92:81:209
-6.94138 87:84:211
-7.0707 82:87:214
-7.20243 77:89:216
-7.3366 72:92:219
-7.47328 67:94:221
-7.61251 62:97:224
-7.75433 57:99:227
-7.89879 52:102:229
-8.04594 46:104:232
-8.19583 41:107:234
-8.34852 36:110:237
-8.50405 31:112:239
-8.66247 26:115:242
-8.82385 21:117:244
-8.98824 16:120:247
-9.15569 11:122:249
-9.32625 6:125:252
-9.5 0:128:255
-nv 255:255:255
Deleted: grass/trunk/raster/r.colors/test_elev_float_example3.ref
--- grass/trunk/raster/r.colors/test_elev_float_example3.ref	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/test_elev_float_example3.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,9 +0,0 @@
-1.5 0:230:0
-2.3 0:160:0
-2.86 50:130:0
-3.66 120:100:30
-4.46 120:130:40
-5.9 170:160:50
-7.1 255:255:150
-nv 255:255:255
Deleted: grass/trunk/raster/r.colors/test_elev_float_example3_logabs.ref
--- grass/trunk/raster/r.colors/test_elev_float_example3_logabs.ref	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/test_elev_float_example3_logabs.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,382 +0,0 @@
-1 0:230:0
-1.02114 0:226:0
--1.02114 0:226:0
--1 0:230:0
-1.02114 0:226:0
-1.04272 0:221:0
--1.04272 0:221:0
--1.02114 0:226:0
-1.04272 0:221:0
-1.06477 0:216:0
--1.06477 0:216:0
--1.04272 0:221:0
-1.06477 0:216:0
-1.08727 0:211:0
--1.08727 0:211:0
--1.06477 0:216:0
-1.08727 0:211:0
-1.11026 0:206:0
--1.11026 0:206:0
--1.08727 0:211:0
-1.11026 0:206:0
-1.13373 0:201:0
--1.13373 0:201:0
--1.11026 0:206:0
-1.13373 0:201:0
-1.15769 0:196:0
--1.15769 0:196:0
--1.13373 0:201:0
-1.15769 0:196:0
-1.18217 0:191:0
--1.18217 0:191:0
--1.15769 0:196:0
-1.18217 0:191:0
-1.20716 0:186:0
--1.20716 0:186:0
--1.18217 0:191:0
-1.20716 0:186:0
-1.23267 0:181:0
--1.23267 0:181:0
--1.20716 0:186:0
-1.23267 0:181:0
-1.25873 0:177:0
--1.25873 0:177:0
--1.23267 0:181:0
-1.25873 0:177:0
-1.28534 0:172:0
--1.28534 0:172:0
--1.25873 0:177:0
-1.28534 0:172:0
-1.31251 0:167:0
--1.31251 0:167:0
--1.28534 0:172:0
-1.31251 0:167:0
-1.34026 0:162:0
--1.34026 0:162:0
--1.31251 0:167:0
-1.34026 0:162:0
-1.36859 3:158:0
--1.36859 3:158:0
--1.34026 0:162:0
-1.36859 3:158:0
-1.39752 8:155:0
--1.39752 8:155:0
--1.36859 3:158:0
-1.39752 8:155:0
-1.42706 13:152:0
--1.42706 13:152:0
--1.39752 8:155:0
-1.42706 13:152:0
-1.45723 18:149:0
--1.45723 18:149:0
--1.42706 13:152:0
-1.45723 18:149:0
-1.48803 23:146:0
--1.48803 23:146:0
--1.45723 18:149:0
-1.48803 23:146:0
-1.51949 28:143:0
--1.51949 28:143:0
--1.48803 23:146:0
-1.51949 28:143:0
-1.55161 33:140:0
--1.55161 33:140:0
--1.51949 28:143:0
-1.55161 33:140:0
-1.58441 38:137:0
--1.58441 38:137:0
--1.55161 33:140:0
-1.58441 38:137:0
-1.6179 43:134:0
--1.6179 43:134:0
--1.58441 38:137:0
-1.6179 43:134:0
-1.6521 48:131:0
--1.6521 48:131:0
--1.6179 43:134:0
-1.6521 48:131:0
-1.68702 53:129:1
--1.68702 53:129:1
--1.6521 48:131:0
-1.68702 53:129:1
-1.72269 58:127:3
--1.72269 58:127:3
--1.68702 53:129:1
-1.72269 58:127:3
-1.7591 63:125:5
--1.7591 63:125:5
--1.72269 58:127:3
-1.7591 63:125:5
-1.79629 68:123:7
--1.79629 68:123:7
--1.7591 63:125:5
-1.79629 68:123:7
-1.83426 73:121:9
--1.83426 73:121:9
--1.79629 68:123:7
-1.83426 73:121:9
-1.87303 77:119:11
--1.87303 77:119:11
--1.83426 73:121:9
-1.87303 77:119:11
-1.91263 82:116:14
--1.91263 82:116:14
--1.87303 77:119:11
-1.91263 82:116:14
-1.95306 87:114:16
--1.95306 87:114:16
--1.91263 82:116:14
-1.95306 87:114:16
-1.99434 92:112:18
--1.99434 92:112:18
--1.95306 87:114:16
-1.99434 92:112:18
-2.0365 97:110:20
--2.0365 97:110:20
--1.99434 92:112:18
-2.0365 97:110:20
-2.07955 102:108:22
--2.0365 97:110:20
-2.07955 102:108:22
-2.12351 107:106:24
-2.12351 107:106:24
-2.1684 112:104:26
--2.1684 112:104:26
-2.1684 112:104:26
-2.21424 117:102:28
--2.1684 112:104:26
-2.21424 117:102:28
-2.26104 120:100:30
-2.26104 120:100:30
-2.30884 120:103:31
-2.30884 120:103:31
-2.35765 120:105:31
-2.35765 120:105:31
-2.40749 120:107:32
-2.40749 120:107:32
-2.45838 120:109:33
-2.45838 120:109:33
-2.51034 120:111:33
-2.51034 120:111:33
-2.56341 120:113:34
-2.56341 120:113:34
-2.6176 120:115:35
--2.6176 120:115:35
-2.6176 120:115:35
-2.67293 120:117:35
--2.6176 120:115:35
-2.67293 120:117:35
-2.72944 120:119:36
-2.72944 120:119:36
-2.78713 120:121:37
-2.78713 120:121:37
-2.84605 120:123:37
-2.84605 120:123:37
-2.90621 120:126:38
-2.90621 120:126:38
-2.96765 120:128:39
-2.96765 120:128:39
-3.03038 120:130:40
-3.03038 120:130:40
-3.09444 122:131:40
-3.09444 122:131:40
-3.15985 124:132:40
-3.15985 124:132:40
-3.22665 126:133:41
-3.22665 126:133:41
-3.29486 128:134:41
-3.29486 128:134:41
-3.36451 129:135:41
-3.36451 129:135:41
-3.43563 131:137:42
-3.43563 131:137:42
-3.50825 133:138:42
-3.50825 133:138:42
-3.58241 135:139:43
-3.58241 135:139:43
-3.65814 137:140:43
-3.65814 137:140:43
-3.73547 139:141:43
-3.73547 139:141:43
-3.81444 141:142:44
-3.81444 141:142:44
-3.89507 143:144:44
-3.89507 143:144:44
-3.97741 145:145:45
-3.97741 145:145:45
-4.06149 147:146:45
-4.06149 147:146:45
-4.14734 149:147:45
-4.14734 149:147:45
-4.23501 151:148:46
-4.23501 151:148:46
-4.32454 153:149:46
-4.32454 153:149:46
-4.41595 155:151:47
-4.41595 155:151:47
-4.5093 157:152:47
--4.5093 157:152:47
-4.5093 157:152:47
-4.60462 159:153:47
--4.5093 157:152:47
-4.60462 159:153:47
-4.70196 161:154:48
-4.70196 161:154:48
-4.80135 163:155:48
-4.80135 163:155:48
-4.90285 164:156:48
-4.90285 164:156:48
-5.00649 166:158:49
-5.00649 166:158:49
-5.11232 168:159:49
-5.11232 168:159:49
-5.22039 171:161:51
-5.22039 171:161:51
-5.33075 175:166:56
-5.33075 175:166:56
-5.44343 179:170:61
-5.44343 179:170:61
-5.5585 183:175:65
--5.5585 183:175:65
-5.5585 183:175:65
-5.676 187:179:70
--5.676 187:179:70
--5.5585 183:175:65
-5.676 187:179:70
-5.79599 191:184:75
--5.676 187:179:70
-5.79599 191:184:75
-5.91851 195:188:79
-5.91851 195:188:79
-6.04362 199:192:84
-6.04362 199:192:84
-6.17138 203:197:89
-6.17138 203:197:89
-6.30183 207:201:93
-6.30183 207:201:93
-6.43505 211:206:98
-6.43505 211:206:98
-7.1 255:255:150
--7.1 255:255:150
-nv 255:255:255
Deleted: grass/trunk/raster/r.colors/test_elev_float_example4.ref
--- grass/trunk/raster/r.colors/test_elev_float_example4.ref	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/test_elev_float_example4.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,11 +0,0 @@
-1 0:0:0
-2 255:255:0
-3 255:127:0
-4 255:0:0
-5 255:0:255
-6 0:127:255
-7 0:255:255
-8 0:255:0
-9 0:0:0
-nv 255:255:255
Deleted: grass/trunk/raster/r.colors/test_elev_float_example4_inv.ref
--- grass/trunk/raster/r.colors/test_elev_float_example4_inv.ref	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/test_elev_float_example4_inv.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,11 +0,0 @@
-1 0:0:0
-2 255:255:0
-3 255:127:0
-4 255:0:0
-5 255:0:255
-6 0:127:255
-7 0:255:255
-8 0:255:0
-9 0:0:0
-nv 255:255:255
Deleted: grass/trunk/raster/r.colors/test_elev_int_example1.ref
--- grass/trunk/raster/r.colors/test_elev_int_example1.ref	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/test_elev_int_example1.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,9 +0,0 @@
-1 0:230:0
-2.6 0:160:0
-3.8 50:130:0
-5.4 120:100:30
-7 120:130:40
-8.2 170:160:50
-9 255:255:150
-nv 255:255:255
Deleted: grass/trunk/raster/r.colors/test_elev_int_example1_hist.ref
--- grass/trunk/raster/r.colors/test_elev_int_example1_hist.ref	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/test_elev_int_example1_hist.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,10 +0,0 @@
-1 0:209:0
-3 0:165:0
-4 37:138:0
-5 80:117:13
-6 120:101:30
-7 120:120:36
-8 140:142:44
-9 201:195:87
-nv 255:255:255
Deleted: grass/trunk/raster/r.colors/test_elev_int_example1_perc.ref
--- grass/trunk/raster/r.colors/test_elev_int_example1_perc.ref	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/test_elev_int_example1_perc.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,9 +0,0 @@
-0% 0:230:0
-20% 0:160:0
-35% 50:130:0
-55% 120:100:30
-75% 120:130:40
-90% 170:160:50
-100% 255:255:150
-nv 255:255:255
Deleted: grass/trunk/raster/r.colors/test_elev_int_example2.ref
--- grass/trunk/raster/r.colors/test_elev_int_example2.ref	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/test_elev_int_example2.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,5 +0,0 @@
-1 128:255:0
-5 255:0:128
-9 0:128:255
-nv 255:255:255
Deleted: grass/trunk/raster/r.colors/test_elev_int_example2_log.ref
--- grass/trunk/raster/r.colors/test_elev_int_example2_log.ref	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/test_elev_int_example2_log.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,103 +0,0 @@
-1 128:255:0
-1.02222 130:250:2
-1.04492 133:245:5
-1.06814 135:240:7
-1.09187 138:235:10
-1.11612 140:230:12
-1.14092 143:225:15
-1.16626 145:220:17
-1.19217 148:215:20
-1.21866 150:210:23
-1.24573 153:204:25
-1.27341 155:199:28
-1.30169 158:194:30
-1.33061 161:189:33
-1.36017 163:184:35
-1.39039 166:179:38
-1.42128 168:174:40
-1.45285 171:169:43
-1.48513 173:164:46
-1.51812 176:159:48
-1.55185 178:153:51
-1.58632 181:148:53
-1.62156 183:143:56
-1.65758 186:138:58
-1.69441 188:133:61
-1.73205 191:128:64
-1.77053 194:123:66
-1.80986 196:118:69
-1.85007 199:113:71
-1.89117 201:108:74
-1.93318 204:102:76
-1.97613 206:97:79
-2.02003 209:92:81
-2.0649 211:87:84
-2.11078 214:82:87
-2.15767 216:77:89
-2.2056 219:72:92
-2.2546 221:67:94
-2.30469 224:62:97
-2.35589 227:57:99
-2.40822 229:51:102
-2.46172 232:46:104
-2.51641 234:41:107
-2.57232 237:36:110
-2.62946 239:31:112
-2.68788 242:26:115
-2.74759 244:21:117
-2.80863 247:16:120
-2.87102 249:11:122
-2.9348 252:6:125
-3 255:0:128
-3.06665 250:2:130
-3.13477 245:5:133
-3.20441 240:7:135
-3.2756 235:10:138
-3.34837 230:12:140
-3.42275 225:15:143
-3.49879 220:17:145
-3.57652 215:20:148
-3.65597 210:23:150
-3.73719 205:25:153
-3.82022 199:28:155
-3.90508 194:30:158
-3.99184 189:33:161
-4.08052 184:35:163
-4.17117 179:38:166
-4.26383 174:40:168
-4.35855 169:43:171
-4.45538 164:46:173
-4.55436 159:48:176
-4.65554 154:51:178
-4.75896 148:53:181
-4.86468 143:56:183
-4.97275 138:58:186
-5.08323 133:61:188
-5.19615 128:64:191
-5.31159 123:66:194
-5.42959 118:69:196
-5.55021 113:71:199
-5.67351 108:74:201
-5.79955 102:76:204
-5.92839 97:79:206
-6.06009 92:81:209
-6.19471 87:84:211
-6.33233 82:87:214
-6.47301 77:89:216
-6.61681 72:92:219
-6.7638 67:94:221
-6.91406 62:97:224
-7.06766 57:99:227
-7.22467 52:102:229
-7.38517 46:104:232
-7.54924 41:107:234
-7.71695 36:110:237
-7.88838 31:112:239
-8.06363 26:115:242
-8.24276 21:117:244
-8.42588 16:120:247
-8.61306 11:122:249
-8.80441 6:125:252
-9 0:128:255
-nv 255:255:255
Deleted: grass/trunk/raster/r.colors/test_elev_int_example2_perc.ref
--- grass/trunk/raster/r.colors/test_elev_int_example2_perc.ref	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/test_elev_int_example2_perc.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,5 +0,0 @@
-0% 128:255:0
-50% 255:0:128
-100% 0:128:255
-nv 255:255:255
Deleted: grass/trunk/raster/r.colors/test_elev_int_example3.ref
--- grass/trunk/raster/r.colors/test_elev_int_example3.ref	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/test_elev_int_example3.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,9 +0,0 @@
-1 0:230:0
-1.8 0:160:0
-2.36 50:130:0
-3.16 120:100:30
-3.96 120:130:40
-5.4 170:160:50
-6.6 255:255:150
-nv 255:255:255
Deleted: grass/trunk/raster/r.colors/test_elev_int_example3_logabs.ref
--- grass/trunk/raster/r.colors/test_elev_int_example3_logabs.ref	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/test_elev_int_example3_logabs.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,382 +0,0 @@
-1 0:230:0
-1.02049 0:226:0
--1.02049 0:226:0
--1 0:230:0
-1.02049 0:226:0
-1.0414 0:221:0
--1.0414 0:221:0
--1.02049 0:226:0
-1.0414 0:221:0
-1.06273 0:216:0
--1.06273 0:216:0
--1.0414 0:221:0
-1.06273 0:216:0
-1.08451 0:211:0
--1.08451 0:211:0
--1.06273 0:216:0
-1.08451 0:211:0
-1.10673 0:206:0
--1.10673 0:206:0
--1.08451 0:211:0
-1.10673 0:206:0
-1.1294 0:201:0
--1.1294 0:201:0
--1.10673 0:206:0
-1.1294 0:201:0
-1.15254 0:196:0
--1.15254 0:196:0
--1.1294 0:201:0
-1.15254 0:196:0
-1.17616 0:191:0
--1.17616 0:191:0
--1.15254 0:196:0
-1.17616 0:191:0
-1.20025 0:186:0
--1.20025 0:186:0
--1.17616 0:191:0
-1.20025 0:186:0
-1.22485 0:181:0
--1.22485 0:181:0
--1.20025 0:186:0
-1.22485 0:181:0
-1.24994 0:177:0
--1.24994 0:177:0
--1.22485 0:181:0
-1.24994 0:177:0
-1.27555 0:172:0
--1.27555 0:172:0
--1.24994 0:177:0
-1.27555 0:172:0
-1.30168 0:167:0
--1.30168 0:167:0
--1.27555 0:172:0
-1.30168 0:167:0
-1.32835 0:162:0
--1.32835 0:162:0
--1.30168 0:167:0
-1.32835 0:162:0
-1.35557 3:158:0
--1.35557 3:158:0
--1.32835 0:162:0
-1.35557 3:158:0
-1.38334 8:155:0
--1.38334 8:155:0
--1.35557 3:158:0
-1.38334 8:155:0
-1.41169 13:152:0
--1.41169 13:152:0
--1.38334 8:155:0
-1.41169 13:152:0
-1.44061 18:149:0
--1.44061 18:149:0
--1.41169 13:152:0
-1.44061 18:149:0
-1.47013 23:146:0
--1.47013 23:146:0
--1.44061 18:149:0
-1.47013 23:146:0
-1.50025 28:143:0
--1.50025 28:143:0
--1.47013 23:146:0
-1.50025 28:143:0
-1.53098 33:140:0
--1.53098 33:140:0
--1.50025 28:143:0
-1.53098 33:140:0
-1.56235 38:137:0
--1.56235 38:137:0
--1.53098 33:140:0
-1.56235 38:137:0
-1.59436 43:134:0
--1.59436 43:134:0
--1.56235 38:137:0
-1.59436 43:134:0
-1.62703 48:131:0
--1.62703 48:131:0
--1.59436 43:134:0
-1.62703 48:131:0
-1.66036 53:129:1
--1.66036 53:129:1
--1.62703 48:131:0
-1.66036 53:129:1
-1.69438 58:127:3
--1.69438 58:127:3
--1.66036 53:129:1
-1.69438 58:127:3
-1.7291 63:125:5
--1.7291 63:125:5
--1.69438 58:127:3
-1.7291 63:125:5
-1.76452 68:123:7
--1.76452 68:123:7
--1.7291 63:125:5
-1.76452 68:123:7
-1.80068 73:121:9
--1.80068 73:121:9
--1.76452 68:123:7
-1.80068 73:121:9
-1.83757 77:119:11
--1.83757 77:119:11
--1.80068 73:121:9
-1.83757 77:119:11
-1.87522 82:116:14
--1.87522 82:116:14
--1.83757 77:119:11
-1.87522 82:116:14
-1.91364 87:114:16
--1.91364 87:114:16
--1.87522 82:116:14
-1.91364 87:114:16
-1.95285 92:112:18
--1.95285 92:112:18
--1.91364 87:114:16
-1.95285 92:112:18
-1.99286 97:110:20
--1.99286 97:110:20
--1.95285 92:112:18
-1.99286 97:110:20
-2.03369 102:108:22
--2.03369 102:108:22
--1.99286 97:110:20
-2.03369 102:108:22
-2.07536 107:106:24
--2.07536 107:106:24
-2.07536 107:106:24
-2.11788 112:104:26
--2.11788 112:104:26
-2.11788 112:104:26
-2.16127 117:102:28
--2.16127 117:102:28
-2.16127 117:102:28
-2.20555 120:100:30
--2.20555 120:100:30
-2.20555 120:100:30
-2.25074 120:103:31
--2.25074 120:103:31
-2.25074 120:103:31
-2.29685 120:105:31
--2.29685 120:105:31
-2.29685 120:105:31
-2.34391 120:107:32
--2.34391 120:107:32
-2.34391 120:107:32
-2.39194 120:109:33
--2.39194 120:109:33
-2.39194 120:109:33
-2.44094 120:111:33
--2.44094 120:111:33
-2.44094 120:111:33
-2.49096 120:113:34
--2.49096 120:113:34
-2.49096 120:113:34
-2.54199 120:115:35
--2.54199 120:115:35
-2.54199 120:115:35
-2.59407 120:117:35
--2.59407 120:117:35
-2.59407 120:117:35
-2.64722 120:119:36
--2.64722 120:119:36
-2.64722 120:119:36
-2.70146 120:121:37
--2.70146 120:121:37
-2.70146 120:121:37
-2.75681 120:123:37
--2.75681 120:123:37
-2.75681 120:123:37
-2.81329 120:126:38
--2.81329 120:126:38
-2.81329 120:126:38
-2.87093 120:128:39
--2.87093 120:128:39
-2.87093 120:128:39
-2.92975 120:130:40
--2.92975 120:130:40
-2.92975 120:130:40
-2.98978 122:131:40
--2.98978 122:131:40
-2.98978 122:131:40
-3.05104 124:132:40
--3.05104 124:132:40
-3.05104 124:132:40
-3.11355 126:133:41
--3.11355 126:133:41
-3.11355 126:133:41
-3.17734 128:134:41
--3.17734 128:134:41
-3.17734 128:134:41
-3.24244 129:135:41
--3.24244 129:135:41
-3.24244 129:135:41
-3.30887 131:137:42
--3.30887 131:137:42
-3.30887 131:137:42
-3.37667 133:138:42
--3.37667 133:138:42
-3.37667 133:138:42
-3.44585 135:139:43
--3.44585 135:139:43
-3.44585 135:139:43
-3.51645 137:140:43
--3.51645 137:140:43
-3.51645 137:140:43
-3.5885 139:141:43
--3.5885 139:141:43
-3.5885 139:141:43
-3.66202 141:142:44
--3.66202 141:142:44
--3.5885 139:141:43
-3.66202 141:142:44
-3.73705 143:144:44
--3.73705 143:144:44
-3.73705 143:144:44
-3.81362 145:145:45
--3.81362 145:145:45
-3.81362 145:145:45
-3.89175 147:146:45
--3.89175 147:146:45
-3.89175 147:146:45
-3.97149 149:147:45
--3.97149 149:147:45
-3.97149 149:147:45
-4.05286 151:148:46
--4.05286 151:148:46
-4.05286 151:148:46
-4.1359 153:149:46
--4.1359 153:149:46
-4.1359 153:149:46
-4.22063 155:151:47
--4.22063 155:151:47
--4.1359 153:149:46
-4.22063 155:151:47
-4.30711 157:152:47
--4.30711 157:152:47
-4.30711 157:152:47
-4.39535 159:153:47
--4.39535 159:153:47
-4.39535 159:153:47
-4.48541 161:154:48
--4.48541 161:154:48
-4.48541 161:154:48
-4.57731 163:155:48
--4.57731 163:155:48
-4.57731 163:155:48
-4.67109 164:156:48
--4.67109 164:156:48
-4.67109 164:156:48
-4.76679 166:158:49
--4.76679 166:158:49
-4.76679 166:158:49
-4.86446 168:159:49
--4.86446 168:159:49
-4.86446 168:159:49
-4.96413 171:161:51
--4.96413 171:161:51
-4.96413 171:161:51
-5.06583 175:166:56
--5.06583 175:166:56
-5.06583 175:166:56
-5.16962 179:170:61
--5.16962 179:170:61
-5.16962 179:170:61
-5.27554 183:175:65
--5.27554 183:175:65
-5.27554 183:175:65
-5.38363 187:179:70
--5.38363 187:179:70
-5.38363 187:179:70
-5.49393 191:184:75
--5.49393 191:184:75
-5.49393 191:184:75
-5.6065 195:188:79
--5.6065 195:188:79
-5.6065 195:188:79
-5.72137 199:192:84
--5.72137 199:192:84
--5.6065 195:188:79
-5.72137 199:192:84
-5.83859 203:197:89
--5.83859 203:197:89
-5.83859 203:197:89
-5.95821 207:201:93
--5.95821 207:201:93
-5.95821 207:201:93
-6.08029 211:206:98
--6.08029 211:206:98
-6.08029 211:206:98
-6.20486 215:210:103
--6.20486 215:210:103
-6.33199 219:215:108
--6.33199 219:215:108
-6.46173 223:219:112
--6.46173 223:219:112
-6.59412 227:223:117
--6.59412 227:223:117
-6.72922 231:228:121
--6.72922 231:228:121
-6.6 255:255:150
-7.44741 251:250:145
--7.44741 251:250:145
--6.6 255:255:150
-nv 255:255:255
Deleted: grass/trunk/raster/r.colors/test_elev_int_example3_perc.ref
--- grass/trunk/raster/r.colors/test_elev_int_example3_perc.ref	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/test_elev_int_example3_perc.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,9 +0,0 @@
-0% 0:230:0
-10% 0:160:0
-17% 50:130:0
-27% 120:100:30
-37% 120:130:40
-55% 170:160:50
-70% 255:255:150
-nv 255:255:255
Deleted: grass/trunk/raster/r.colors/test_elev_int_example4.ref
--- grass/trunk/raster/r.colors/test_elev_int_example4.ref	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/test_elev_int_example4.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,11 +0,0 @@
-1 0:0:0
-2 255:255:0
-3 255:127:0
-4 255:0:0
-5 255:0:255
-6 0:127:255
-7 0:255:255
-8 0:255:0
-9 0:0:0
-nv 255:255:255
Deleted: grass/trunk/raster/r.colors/test_elev_int_example4_inv.ref
--- grass/trunk/raster/r.colors/test_elev_int_example4_inv.ref	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/test_elev_int_example4_inv.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,11 +0,0 @@
-1 0:0:0
-2 255:255:0
-3 255:127:0
-4 255:0:0
-5 255:0:255
-6 0:127:255
-7 0:255:255
-8 0:255:0
-9 0:0:0
-nv 255:255:255
Deleted: grass/trunk/raster/r.colors/test_elev_int_example4_perc.ref
--- grass/trunk/raster/r.colors/test_elev_int_example4_perc.ref	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/test_elev_int_example4_perc.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,11 +0,0 @@
-0% 0:0:0
-12.5% 255:255:0
-25% 255:127:0
-37.5% 255:0:0
-50% 255:0:255
-62.5% 0:127:255
-75% 0:255:255
-87.5% 0:255:0
-100% 0:0:0
-nv 255:255:255
Deleted: grass/trunk/raster/r.colors/test_volume_double_default.ref
--- grass/trunk/raster/r.colors/test_volume_double_default.ref	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/test_volume_double_default.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,8 +0,0 @@
-4 255:255:0
-8 0:255:0
-12 0:255:255
-16 0:0:255
-20 255:0:255
-24 255:0:0
-nv 255:255:255
Deleted: grass/trunk/raster/r.colors/test_volume_double_example1.ref
--- grass/trunk/raster/r.colors/test_volume_double_example1.ref	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/test_volume_double_example1.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,9 +0,0 @@
-4 0:230:0
-8 0:160:0
-11 50:130:0
-15 120:100:30
-19 120:130:40
-22 170:160:50
-24 255:255:150
-nv 255:255:255
Deleted: grass/trunk/raster/r.colors/test_volume_double_example1_hist.ref
--- grass/trunk/raster/r.colors/test_volume_double_example1_hist.ref	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/test_volume_double_example1_hist.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,23 +0,0 @@
-4 0:230:0
-5.02 0:226:0
-6.02 0:221:0
-7.02 0:212:0
-8.02 0:199:0
-9.02 0:182:0
-10.02 0:160:0
-11.02 23:146:0
-12.02 51:130:0
-13.02 83:116:14
-14.02 116:102:28
-15.02 120:112:34
-16.02 120:124:38
-17.02 132:137:42
-18.02 153:150:46
-19.02 172:162:52
-20.02 206:200:92
-21.02 230:227:121
-22.02 245:244:138
-23.02 252:252:147
-24 252:252:147
-nv 255:255:255
Deleted: grass/trunk/raster/r.colors/test_volume_double_example2.ref
--- grass/trunk/raster/r.colors/test_volume_double_example2.ref	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/test_volume_double_example2.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,5 +0,0 @@
-4 128:255:0
-14 255:0:128
-24 0:128:255
-nv 255:255:255
Deleted: grass/trunk/raster/r.colors/test_volume_double_example2_log.ref
--- grass/trunk/raster/r.colors/test_volume_double_example2_log.ref	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/test_volume_double_example2_log.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,103 +0,0 @@
-4 128:255:0
-4.07232 130:250:2
-4.14594 133:245:5
-4.22089 135:240:7
-4.2972 138:235:10
-4.37489 140:230:12
-4.45399 143:225:15
-4.53451 145:220:17
-4.61649 148:215:20
-4.69995 150:210:23
-4.78492 153:204:25
-4.87143 155:199:28
-4.9595 158:194:30
-5.04917 161:189:33
-5.14045 163:184:35
-5.23338 166:179:38
-5.328 168:174:40
-5.42433 171:169:43
-5.52239 173:164:46
-5.62223 176:159:48
-5.72388 178:153:51
-5.82736 181:148:53
-5.93271 183:143:56
-6.03997 186:138:58
-6.14917 188:133:61
-6.26034 191:128:64
-6.37352 194:123:66
-6.48875 196:118:69
-6.60606 199:113:71
-6.72549 201:108:74
-6.84708 204:102:76
-6.97087 206:97:79
-7.0969 209:92:81
-7.2252 211:87:84
-7.35583 214:82:87
-7.48881 216:77:89
-7.6242 219:72:92
-7.76204 221:67:94
-7.90237 224:62:97
-8.04524 227:57:99
-8.19069 229:51:102
-8.33877 232:46:104
-8.48953 234:41:107
-8.64301 237:36:110
-8.79927 239:31:112
-8.95835 242:26:115
-9.12031 244:21:117
-9.2852 247:16:120
-9.45306 249:11:122
-9.62397 252:6:125
-9.79796 255:0:128
-9.9751 250:2:130
-10.1554 245:5:133
-10.339 240:7:135
-10.526 235:10:138
-10.7163 230:12:140
-10.91 225:15:143
-11.1072 220:17:145
-11.308 215:20:148
-11.5125 210:23:150
-11.7206 204:25:153
-11.9325 199:28:155
-12.1483 194:30:158
-12.3679 189:33:161
-12.5915 184:35:163
-12.8191 179:38:166
-13.0509 174:40:168
-13.2868 169:43:171
-13.527 164:46:173
-13.7716 159:48:176
-14.0206 153:51:178
-14.2741 148:53:181
-14.5321 143:56:183
-14.7948 138:58:186
-15.0623 133:61:188
-15.3346 128:64:191
-15.6119 123:66:194
-15.8941 118:69:196
-16.1815 113:71:199
-16.474 108:74:201
-16.7719 102:76:204
-17.0751 97:79:206
-17.3838 92:81:209
-17.6981 87:84:211
-18.018 82:87:214
-18.3438 77:89:216
-18.6754 72:92:219
-19.013 67:94:221
-19.3568 62:97:224
-19.7067 57:99:227
-20.063 51:102:229
-20.4257 46:104:232
-20.795 41:107:234
-21.171 36:110:237
-21.5537 31:112:239
-21.9434 26:115:242
-22.3401 21:117:244
-22.744 16:120:247
-23.1552 11:122:249
-23.5738 6:125:252
-24 0:128:255
-nv 255:255:255
Deleted: grass/trunk/raster/r.colors/test_volume_double_example3.ref
--- grass/trunk/raster/r.colors/test_volume_double_example3.ref	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/test_volume_double_example3.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,9 +0,0 @@
-4 0:230:0
-6 0:160:0
-7.4 50:130:0
-9.4 120:100:30
-11.4 120:130:40
-15 170:160:50
-18 255:255:150
-nv 255:255:255
Deleted: grass/trunk/raster/r.colors/test_volume_double_example3_logabs.ref
--- grass/trunk/raster/r.colors/test_volume_double_example3_logabs.ref	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/test_volume_double_example3_logabs.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,402 +0,0 @@
-1 0:230:0
-1.02988 0:226:0
--1.02988 0:226:0
--1 0:230:0
-1.02988 0:226:0
-1.06066 0:221:0
--1.06066 0:221:0
--1.02988 0:226:0
-1.06066 0:221:0
-1.09235 0:216:0
--1.09235 0:216:0
--1.06066 0:221:0
-1.09235 0:216:0
-1.12499 0:211:0
--1.12499 0:211:0
--1.09235 0:216:0
-1.12499 0:211:0
-1.15861 0:206:0
--1.15861 0:206:0
--1.12499 0:211:0
-1.15861 0:206:0
-1.19323 0:201:0
--1.19323 0:201:0
--1.15861 0:206:0
-1.19323 0:201:0
-1.22889 0:196:0
--1.22889 0:196:0
--1.19323 0:201:0
-1.22889 0:196:0
-1.26561 0:191:0
--1.26561 0:191:0
--1.22889 0:196:0
-1.26561 0:191:0
-1.30343 0:186:0
--1.30343 0:186:0
--1.26561 0:191:0
-1.30343 0:186:0
-1.34238 0:181:0
--1.34238 0:181:0
--1.30343 0:186:0
-1.34238 0:181:0
-1.38249 0:177:0
--1.38249 0:177:0
--1.34238 0:181:0
-1.38249 0:177:0
-1.4238 0:172:0
--1.4238 0:172:0
--1.38249 0:177:0
-1.4238 0:172:0
-1.46635 0:167:0
--1.46635 0:167:0
--1.4238 0:172:0
-1.46635 0:167:0
-1.51017 0:162:0
--1.51017 0:162:0
--1.46635 0:167:0
-1.51017 0:162:0
-1.5553 3:158:0
--1.5553 3:158:0
--1.51017 0:162:0
-1.5553 3:158:0
-1.60177 8:155:0
--1.60177 8:155:0
--1.5553 3:158:0
-1.60177 8:155:0
-1.64964 13:152:0
--1.64964 13:152:0
--1.60177 8:155:0
-1.64964 13:152:0
-1.69893 18:149:0
--1.69893 18:149:0
--1.64964 13:152:0
-1.69893 18:149:0
-1.7497 23:146:0
--1.7497 23:146:0
--1.69893 18:149:0
-1.7497 23:146:0
-1.80198 28:143:0
--1.80198 28:143:0
--1.7497 23:146:0
-1.80198 28:143:0
-1.85583 33:140:0
--1.85583 33:140:0
--1.80198 28:143:0
-1.85583 33:140:0
-1.91129 38:137:0
--1.91129 38:137:0
--1.85583 33:140:0
-1.91129 38:137:0
-1.9684 43:134:0
--1.9684 43:134:0
--1.91129 38:137:0
-1.9684 43:134:0
-2.02722 48:131:0
--2.02722 48:131:0
--1.9684 43:134:0
-2.02722 48:131:0
-2.0878 53:129:1
--2.0878 53:129:1
--2.02722 48:131:0
-2.0878 53:129:1
-2.15019 58:127:3
--2.15019 58:127:3
--2.0878 53:129:1
-2.15019 58:127:3
-2.21444 63:125:5
--2.21444 63:125:5
--2.15019 58:127:3
-2.21444 63:125:5
-2.28061 68:123:7
--2.28061 68:123:7
--2.21444 63:125:5
-2.28061 68:123:7
-2.34876 73:121:9
--2.34876 73:121:9
--2.28061 68:123:7
-2.34876 73:121:9
-2.41895 77:119:11
--2.41895 77:119:11
--2.34876 73:121:9
-2.41895 77:119:11
-2.49123 82:116:14
--2.49123 82:116:14
--2.41895 77:119:11
-2.49123 82:116:14
-2.56567 87:114:16
--2.56567 87:114:16
--2.49123 82:116:14
-2.56567 87:114:16
-2.64234 92:112:18
--2.64234 92:112:18
--2.56567 87:114:16
-2.64234 92:112:18
-2.7213 97:110:20
--2.7213 97:110:20
--2.64234 92:112:18
-2.7213 97:110:20
-2.80262 102:108:22
--2.80262 102:108:22
--2.7213 97:110:20
-2.80262 102:108:22
-2.88637 107:106:24
--2.88637 107:106:24
-2.88637 107:106:24
-2.97262 112:104:26
--2.97262 112:104:26
-2.97262 112:104:26
-3.06144 117:102:28
--3.06144 117:102:28
-3.06144 117:102:28
-3.15293 120:100:30
--3.15293 120:100:30
-3.15293 120:100:30
-3.24714 120:102:30
--3.24714 120:102:30
-3.24714 120:102:30
-3.34417 120:105:31
--3.34417 120:105:31
-3.34417 120:105:31
-3.44411 120:107:32
--3.44411 120:107:32
-3.44411 120:107:32
-3.54702 120:109:33
--3.54702 120:109:33
-3.54702 120:109:33
-3.65302 120:111:33
--3.65302 120:111:33
-3.65302 120:111:33
-3.76218 120:113:34
--3.76218 120:113:34
-3.76218 120:113:34
-3.8746 120:115:35
--3.8746 120:115:35
-3.8746 120:115:35
-3.99038 120:117:35
--3.99038 120:117:35
--3.8746 120:115:35
-3.99038 120:117:35
-4.10962 120:119:36
--4.10962 120:119:36
-4.10962 120:119:36
-4.23242 120:121:37
--4.23242 120:121:37
-4.23242 120:121:37
-4.3589 120:123:37
--4.3589 120:123:37
-4.3589 120:123:37
-4.48915 120:126:38
--4.48915 120:126:38
--4.3589 120:123:37
-4.48915 120:126:38
-4.6233 120:128:39
--4.6233 120:128:39
-4.6233 120:128:39
-4.76145 120:130:40
--4.76145 120:130:40
--4.6233 120:128:39
-4.76145 120:130:40
-4.90373 122:131:40
--4.90373 122:131:40
-4.90373 122:131:40
-5.05027 124:132:40
--5.05027 124:132:40
-5.05027 124:132:40
-5.20118 126:133:41
--5.20118 126:133:41
-5.20118 126:133:41
-5.3566 128:134:41
--5.3566 128:134:41
-5.3566 128:134:41
-5.51667 129:135:41
--5.51667 129:135:41
--5.3566 128:134:41
-5.51667 129:135:41
-5.68152 131:137:42
--5.68152 131:137:42
-5.68152 131:137:42
-5.8513 133:138:42
--5.8513 133:138:42
-5.8513 133:138:42
-6.02615 135:139:43
--6.02615 135:139:43
--5.8513 133:138:42
-6.02615 135:139:43
-6.20622 137:140:43
--6.20622 137:140:43
-6.20622 137:140:43
-6.39168 139:141:43
--6.39168 139:141:43
-6.39168 139:141:43
-6.58267 141:143:44
--6.58267 141:143:44
-6.58267 141:143:44
-6.77938 143:144:44
--6.77938 143:144:44
-6.77938 143:144:44
-6.98196 145:145:45
--6.98196 145:145:45
-6.98196 145:145:45
-7.1906 147:146:45
--7.1906 147:146:45
-7.1906 147:146:45
-7.40547 149:147:45
--7.40547 149:147:45
--7.1906 147:146:45
-7.40547 149:147:45
-7.62676 151:148:46
--7.62676 151:148:46
-7.62676 151:148:46
-7.85466 153:150:46
--7.85466 153:150:46
-7.85466 153:150:46
-8.08938 155:151:47
--8.08938 155:151:47
-8.08938 155:151:47
-8.3311 157:152:47
--8.3311 157:152:47
-8.3311 157:152:47
-8.58006 159:153:47
--8.58006 159:153:47
--8.3311 157:152:47
-8.58006 159:153:47
-8.83645 161:154:48
--8.83645 161:154:48
-8.83645 161:154:48
-9.1005 163:155:48
--9.1005 163:155:48
-9.1005 163:155:48
-9.37244 165:157:49
--9.37244 165:157:49
--9.1005 163:155:48
-9.37244 165:157:49
-9.65251 166:158:49
--9.65251 166:158:49
-9.65251 166:158:49
-9.94095 168:159:49
--9.94095 168:159:49
-9.94095 168:159:49
-10.238 171:161:52
--10.238 171:161:52
-10.238 171:161:52
-10.5439 175:166:56
--10.5439 175:166:56
--10.238 171:161:52
-10.5439 175:166:56
-10.859 179:170:61
--10.859 179:170:61
-10.859 179:170:61
-11.1835 183:175:66
--11.1835 183:175:66
--10.859 179:170:61
-11.1835 183:175:66
-11.5177 187:179:70
--11.5177 187:179:70
-11.5177 187:179:70
-11.8619 191:184:75
--11.8619 191:184:75
-11.8619 191:184:75
-12.2163 195:188:80
--12.2163 195:188:80
-12.2163 195:188:80
-12.5814 199:192:84
--12.5814 199:192:84
-12.5814 199:192:84
-12.9573 203:197:89
--12.9573 203:197:89
-12.9573 203:197:89
-13.3445 207:201:94
--13.3445 207:201:94
-13.3445 207:201:94
-13.7433 211:206:98
--13.7433 211:206:98
-13.7433 211:206:98
-14.154 215:210:103
--14.154 215:210:103
-14.154 215:210:103
-14.5769 219:215:108
--14.5769 219:215:108
-15.0125 223:219:112
--15.0125 223:219:112
-15.4611 227:223:117
--15.4611 227:223:117
-15.9231 231:228:122
--15.9231 231:228:122
-16.3989 235:232:126
--16.3989 235:232:126
-16.889 239:237:131
--16.889 239:237:131
-16.889 239:237:131
-17.3937 243:241:135
--17.3937 243:241:135
-17.9134 247:246:140
--17.9134 247:246:140
-18.4487 251:250:145
--18.4487 251:250:145
-18 255:255:150
--18 255:255:150
-nv 255:255:255
Deleted: grass/trunk/raster/r.colors/test_volume_double_example4.ref
--- grass/trunk/raster/r.colors/test_volume_double_example4.ref	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/test_volume_double_example4.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,11 +0,0 @@
-1 0:0:0
-2 255:255:0
-3 255:127:0
-4 255:0:0
-5 255:0:255
-6 0:127:255
-7 0:255:255
-8 0:255:0
-9 0:0:0
-nv 255:255:255
Deleted: grass/trunk/raster/r.colors/test_volume_double_example4_inv.ref
--- grass/trunk/raster/r.colors/test_volume_double_example4_inv.ref	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/test_volume_double_example4_inv.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,11 +0,0 @@
-1 0:0:0
-2 255:255:0
-3 255:127:0
-4 255:0:0
-5 255:0:255
-6 0:127:255
-7 0:255:255
-8 0:255:0
-9 0:0:0
-nv 255:255:255
Deleted: grass/trunk/raster/r.colors/test_volume_double_example5.ref
--- grass/trunk/raster/r.colors/test_volume_double_example5.ref	2011-07-04 08:17:39 UTC (rev 46950)
+++ grass/trunk/raster/r.colors/test_volume_double_example5.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -1,11 +0,0 @@
-1 0:0:0
-2 255:255:0
-3 255:127:0
-4 255:0:0
-5 255:0:255
-6 0:127:255
-7 0:255:255
-8 0:255:0
-9 0:0:0
-nv 255:255:255
Copied: grass/trunk/raster/r.colors/tests/example1 (from rev 46945, grass/trunk/raster/r.colors/example1)
--- grass/trunk/raster/r.colors/tests/example1	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/example1	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,7 @@
+0%     0 230 0
+20%    0 160 0
+35%   50 130 0
+55% 120 100 30
+75% 120 130 40
+90% 170 160 50
+100% 255 255 150
Copied: grass/trunk/raster/r.colors/tests/example2 (from rev 46945, grass/trunk/raster/r.colors/example2)
--- grass/trunk/raster/r.colors/tests/example2	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/example2	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,3 @@
+0% 128 255 0
+50% 255 0 128
+100% 0 128 255
Copied: grass/trunk/raster/r.colors/tests/example3 (from rev 46945, grass/trunk/raster/r.colors/example3)
--- grass/trunk/raster/r.colors/tests/example3	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/example3	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,7 @@
+0%     0 230 0
+10%    0 160 0
+17%   50 130 0
+27% 120 100 30
+37% 120 130 40
+55% 170 160 50
+70% 255 255 150
Copied: grass/trunk/raster/r.colors/tests/example4 (from rev 46945, grass/trunk/raster/r.colors/example4)
--- grass/trunk/raster/r.colors/tests/example4	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/example4	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,9 @@
+1 black
+2 yellow
+3 orange
+4 red
+5 magenta
+6 indigo
+7 cyan
+8 green
+9 black
Copied: grass/trunk/raster/r.colors/tests/test.r.colors.sh (from rev 46945, grass/trunk/raster/r.colors/test.r.colors.sh)
--- grass/trunk/raster/r.colors/tests/test.r.colors.sh	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/test.r.colors.sh	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,68 @@
+# This script tests r.colors and r.colors.out as well
+# as r3.colors and r3.colors.out which have the same code base
+# Color rules are set with r/r3.colors and exported using r/r3.colors.out
+# We specific a small region in the
+# @preprocess step and generate
+# raster data with r.mapcalc
+# The region setting should work for UTM and LL test locations
+g.region s=0 n=90 w=0 e=100 b=0 t=50 res=10 res3=10 -p3
+# To test r.colors, we need several maps of different types
+r.mapcalc --o expr="test_elev_int = int(if(row() == 2, null(), row()))"
+r.mapcalc --o expr="test_elev_double = double(if(row() == 2, null(), row() + 0.5))"
+r.mapcalc --o expr="test_elev_float = float(if(row() == 2, null(), row() + 0.5))"
+# Create the volumes
+r3.mapcalc --o expr="volume_double = double(col() + row() + depth())"
+r3.mapcalc --o expr="volume_double_null = if(row() == 1 || row() == 5, null(), volume_double)"
+# First we @test the integer maps
+# We use the examples to test the import, export and setting of color tables with differrent options
+# the vaidation is based on raster map colur rules @files reference files created with r.colors.out
+r.colors    map=test_elev_int rules=example1 && r.colors.out --o map=test_elev_int rules=test_elev_int_example1.txt
+r.colors -e map=test_elev_int rules=example1 && r.colors.out --o map=test_elev_int rules=test_elev_int_example1_hist.txt
+r.colors    map=test_elev_int rules=example2 && r.colors.out --o map=test_elev_int rules=test_elev_int_example2.txt
+r.colors -g map=test_elev_int rules=example2 && r.colors.out --o map=test_elev_int rules=test_elev_int_example2_log.txt
+r.colors    map=test_elev_int rules=example3 && r.colors.out --o map=test_elev_int rules=test_elev_int_example3.txt
+r.colors -a map=test_elev_int rules=example3 && r.colors.out --o map=test_elev_int rules=test_elev_int_example3_logabs.txt
+r.colors    map=test_elev_int rules=example4 && r.colors.out --o map=test_elev_int rules=test_elev_int_example4.txt
+r.colors -n map=test_elev_int rast=test_elev_int && r.colors.out --o map=test_elev_int rules=test_elev_int_example4_inv.txt
+# test the percentage output
+r.colors map=test_elev_int rules=example1 && r.colors.out --o -p map=test_elev_int rules=test_elev_int_example1_perc.txt
+r.colors map=test_elev_int rules=example2 && r.colors.out --o -p map=test_elev_int rules=test_elev_int_example2_perc.txt
+r.colors map=test_elev_int rules=example3 && r.colors.out --o -p map=test_elev_int rules=test_elev_int_example3_perc.txt
+r.colors map=test_elev_int rules=example4 && r.colors.out --o -p map=test_elev_int rules=test_elev_int_example4_perc.txt
+# float maps
+r.colors    map=test_elev_float rules=example1 && r.colors.out --o map=test_elev_float rules=test_elev_float_example1.txt
+r.colors -e map=test_elev_float rules=example1 && r.colors.out --o map=test_elev_float rules=test_elev_float_example1_hist.txt
+r.colors    map=test_elev_float rules=example2 && r.colors.out --o map=test_elev_float rules=test_elev_float_example2.txt
+r.colors -g map=test_elev_float rules=example2 && r.colors.out --o map=test_elev_float rules=test_elev_float_example2_log.txt
+r.colors    map=test_elev_float rules=example3 && r.colors.out --o map=test_elev_float rules=test_elev_float_example3.txt
+r.colors -a map=test_elev_float rules=example3 && r.colors.out --o map=test_elev_float rules=test_elev_float_example3_logabs.txt
+r.colors    map=test_elev_float rules=example4 && r.colors.out --o map=test_elev_float rules=test_elev_float_example4.txt
+r.colors -n map=test_elev_float rast=test_elev_float && r.colors.out --o map=test_elev_float rules=test_elev_float_example4_inv.txt
+# double maps
+r.colors    map=test_elev_double rules=example1 && r.colors.out --o map=test_elev_double rules=test_elev_double_example1.txt
+r.colors -e map=test_elev_double rules=example1 && r.colors.out --o map=test_elev_double rules=test_elev_double_example1_hist.txt
+r.colors    map=test_elev_double rules=example2 && r.colors.out --o map=test_elev_double rules=test_elev_double_example2.txt
+r.colors -g map=test_elev_double rules=example2 && r.colors.out --o map=test_elev_double rules=test_elev_double_example2_log.txt
+r.colors    map=test_elev_double rules=example3 && r.colors.out --o map=test_elev_double rules=test_elev_double_example3.txt
+r.colors -a map=test_elev_double rules=example3 && r.colors.out --o map=test_elev_double rules=test_elev_double_example3_logabs.txt
+r.colors    map=test_elev_double rules=example4 && r.colors.out --o map=test_elev_double rules=test_elev_double_example4.txt
+r.colors -n map=test_elev_double rast=test_elev_double && r.colors.out --o map=test_elev_double rules=test_elev_double_example4_inv.txt
+# The volume maps using r3.colors and r3.colors.out
+r3.colors    map=volume_double_null rules=example1 && r3.colors.out --o map=volume_double_null rules=test_volume_double_example1.txt
+r3.colors -e map=volume_double_null rules=example1 && r3.colors.out --o map=volume_double_null rules=test_volume_double_example1_hist.txt
+r3.colors    map=volume_double_null rules=example2 && r3.colors.out --o map=volume_double_null rules=test_volume_double_example2.txt
+r3.colors -g map=volume_double_null rules=example2 && r3.colors.out --o map=volume_double_null rules=test_volume_double_example2_log.txt
+r3.colors    map=volume_double_null rules=example3 && r3.colors.out --o map=volume_double_null rules=test_volume_double_example3.txt
+r3.colors -a map=volume_double_null rules=example3 && r3.colors.out --o map=volume_double_null rules=test_volume_double_example3_logabs.txt
+r3.colors    map=volume_double_null rules=example4 && r3.colors.out --o map=volume_double_null rules=test_volume_double_example4.txt
+r3.colors -n map=volume_double_null volume=volume_double_null && r3.colors.out --o map=volume_double_null rules=test_volume_double_example4_inv.txt
+# Apply a raster color table to the volume map
+r3.colors    map=volume_double_null raster=test_elev_double   && r3.colors.out --o map=volume_double_null rules=test_volume_double_example5.txt
+# Test the removement the raster3d color table, a default color table will be created
+r3.colors -r map=volume_double_null && r3.colors.out --o map=volume_double_null rules=test_volume_double_default.txt
+# Test the removement the raster color table, a default color table will be created
+r.colors -r map=test_elev_double && r.colors.out --o map=test_elev_double rules=test_elev_double_default.txt
Copied: grass/trunk/raster/r.colors/tests/test_elev_double_default.ref (from rev 46945, grass/trunk/raster/r.colors/test_elev_double_default.ref)
--- grass/trunk/raster/r.colors/tests/test_elev_double_default.ref	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/test_elev_double_default.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,8 @@
+1.5 255:255:0
+3.1 0:255:0
+4.7 0:255:255
+6.3 0:0:255
+7.9 255:0:255
+9.5 255:0:0
+nv 255:255:255
+default 255:255:255
Copied: grass/trunk/raster/r.colors/tests/test_elev_double_example1.ref (from rev 46945, grass/trunk/raster/r.colors/test_elev_double_example1.ref)
--- grass/trunk/raster/r.colors/tests/test_elev_double_example1.ref	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/test_elev_double_example1.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,9 @@
+1.5 0:230:0
+3.1 0:160:0
+4.3 50:130:0
+5.9 120:100:30
+7.5 120:130:40
+8.7 170:160:50
+9.5 255:255:150
+nv 255:255:255
Copied: grass/trunk/raster/r.colors/tests/test_elev_double_example1_hist.ref (from rev 46945, grass/trunk/raster/r.colors/test_elev_double_example1_hist.ref)
--- grass/trunk/raster/r.colors/tests/test_elev_double_example1_hist.ref	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/test_elev_double_example1_hist.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,11 @@
+1.5 0:230:0
+1.508 0:187:0
+3.508 16:150:0
+4.508 58:127:3
+5.508 102:108:22
+6.508 120:111:33
+7.508 120:129:40
+8.508 161:155:48
+9.5 161:155:48
+nv 255:255:255
Copied: grass/trunk/raster/r.colors/tests/test_elev_double_example2.ref (from rev 46945, grass/trunk/raster/r.colors/test_elev_double_example2.ref)
--- grass/trunk/raster/r.colors/tests/test_elev_double_example2.ref	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/test_elev_double_example2.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,5 @@
+1.5 128:255:0
+5.5 255:0:128
+9.5 0:128:255
+nv 255:255:255
Copied: grass/trunk/raster/r.colors/tests/test_elev_double_example2_log.ref (from rev 46945, grass/trunk/raster/r.colors/test_elev_double_example2_log.ref)
--- grass/trunk/raster/r.colors/tests/test_elev_double_example2_log.ref	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/test_elev_double_example2_log.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,103 @@
+1.5 128:255:0
+1.52794 130:250:2
+1.55641 133:245:5
+1.58541 135:240:7
+1.61494 138:235:10
+1.64503 140:230:12
+1.67567 143:225:15
+1.70689 145:220:17
+1.73869 148:215:20
+1.77108 150:210:23
+1.80407 153:205:25
+1.83768 155:199:28
+1.87192 158:194:30
+1.90679 161:189:33
+1.94232 163:184:35
+1.9785 166:179:38
+2.01536 168:174:40
+2.0529 171:169:43
+2.09115 173:164:46
+2.13011 176:159:48
+2.16979 178:153:51
+2.21021 181:148:53
+2.25139 183:143:56
+2.29333 186:138:58
+2.33605 188:133:61
+2.37957 191:128:64
+2.42391 194:123:66
+2.46906 196:118:69
+2.51506 199:113:71
+2.56191 201:108:74
+2.60964 204:102:76
+2.65826 206:97:79
+2.70778 209:92:81
+2.75823 211:87:84
+2.80961 214:82:87
+2.86195 216:77:89
+2.91527 219:72:92
+2.96958 221:67:94
+3.0249 224:62:97
+3.08126 227:57:99
+3.13866 229:51:102
+3.19713 232:46:104
+3.25669 234:41:107
+3.31736 237:36:110
+3.37917 239:31:112
+3.44212 242:26:115
+3.50624 244:21:117
+3.57156 247:16:120
+3.6381 249:11:122
+3.70588 252:6:125
+3.77492 255:0:128
+3.84524 250:2:130
+3.91688 245:5:133
+3.98985 240:7:135
+4.06418 235:10:138
+4.13989 230:12:140
+4.21702 225:15:143
+4.29558 220:17:145
+4.3756 215:20:148
+4.45712 210:23:150
+4.54015 205:25:153
+4.62474 199:28:155
+4.71089 194:30:158
+4.79866 189:33:161
+4.88805 184:35:163
+4.97912 179:38:166
+5.07188 174:40:168
+5.16636 169:43:171
+5.26261 164:46:173
+5.36065 159:48:176
+5.46052 154:51:178
+5.56225 148:53:181
+5.66587 143:56:183
+5.77142 138:58:186
+5.87894 133:61:188
+5.98847 128:64:191
+6.10003 123:66:194
+6.21367 118:69:196
+6.32943 113:71:199
+6.44734 108:74:201
+6.56746 102:76:204
+6.68981 97:79:206
+6.81443 92:81:209
+6.94138 87:84:211
+7.0707 82:87:214
+7.20243 77:89:216
+7.3366 72:92:219
+7.47328 67:94:221
+7.61251 62:97:224
+7.75433 57:99:227
+7.89879 52:102:229
+8.04594 46:104:232
+8.19583 41:107:234
+8.34852 36:110:237
+8.50405 31:112:239
+8.66247 26:115:242
+8.82385 21:117:244
+8.98824 16:120:247
+9.15569 11:122:249
+9.32625 6:125:252
+9.5 0:128:255
+nv 255:255:255
Copied: grass/trunk/raster/r.colors/tests/test_elev_double_example3.ref (from rev 46945, grass/trunk/raster/r.colors/test_elev_double_example3.ref)
--- grass/trunk/raster/r.colors/tests/test_elev_double_example3.ref	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/test_elev_double_example3.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,9 @@
+1.5 0:230:0
+2.3 0:160:0
+2.86 50:130:0
+3.66 120:100:30
+4.46 120:130:40
+5.9 170:160:50
+7.1 255:255:150
+nv 255:255:255
Copied: grass/trunk/raster/r.colors/tests/test_elev_double_example3_logabs.ref (from rev 46945, grass/trunk/raster/r.colors/test_elev_double_example3_logabs.ref)
--- grass/trunk/raster/r.colors/tests/test_elev_double_example3_logabs.ref	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/test_elev_double_example3_logabs.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,382 @@
+1 0:230:0
+1.02114 0:226:0
+-1.02114 0:226:0
+-1 0:230:0
+1.02114 0:226:0
+1.04272 0:221:0
+-1.04272 0:221:0
+-1.02114 0:226:0
+1.04272 0:221:0
+1.06477 0:216:0
+-1.06477 0:216:0
+-1.04272 0:221:0
+1.06477 0:216:0
+1.08727 0:211:0
+-1.08727 0:211:0
+-1.06477 0:216:0
+1.08727 0:211:0
+1.11026 0:206:0
+-1.11026 0:206:0
+-1.08727 0:211:0
+1.11026 0:206:0
+1.13373 0:201:0
+-1.13373 0:201:0
+-1.11026 0:206:0
+1.13373 0:201:0
+1.15769 0:196:0
+-1.15769 0:196:0
+-1.13373 0:201:0
+1.15769 0:196:0
+1.18217 0:191:0
+-1.18217 0:191:0
+-1.15769 0:196:0
+1.18217 0:191:0
+1.20716 0:186:0
+-1.20716 0:186:0
+-1.18217 0:191:0
+1.20716 0:186:0
+1.23267 0:181:0
+-1.23267 0:181:0
+-1.20716 0:186:0
+1.23267 0:181:0
+1.25873 0:177:0
+-1.25873 0:177:0
+-1.23267 0:181:0
+1.25873 0:177:0
+1.28534 0:172:0
+-1.28534 0:172:0
+-1.25873 0:177:0
+1.28534 0:172:0
+1.31251 0:167:0
+-1.31251 0:167:0
+-1.28534 0:172:0
+1.31251 0:167:0
+1.34026 0:162:0
+-1.34026 0:162:0
+-1.31251 0:167:0
+1.34026 0:162:0
+1.36859 3:158:0
+-1.36859 3:158:0
+-1.34026 0:162:0
+1.36859 3:158:0
+1.39752 8:155:0
+-1.39752 8:155:0
+-1.36859 3:158:0
+1.39752 8:155:0
+1.42706 13:152:0
+-1.42706 13:152:0
+-1.39752 8:155:0
+1.42706 13:152:0
+1.45723 18:149:0
+-1.45723 18:149:0
+-1.42706 13:152:0
+1.45723 18:149:0
+1.48803 23:146:0
+-1.48803 23:146:0
+-1.45723 18:149:0
+1.48803 23:146:0
+1.51949 28:143:0
+-1.51949 28:143:0
+-1.48803 23:146:0
+1.51949 28:143:0
+1.55161 33:140:0
+-1.55161 33:140:0
+-1.51949 28:143:0
+1.55161 33:140:0
+1.58441 38:137:0
+-1.58441 38:137:0
+-1.55161 33:140:0
+1.58441 38:137:0
+1.6179 43:134:0
+-1.6179 43:134:0
+-1.58441 38:137:0
+1.6179 43:134:0
+1.6521 48:131:0
+-1.6521 48:131:0
+-1.6179 43:134:0
+1.6521 48:131:0
+1.68702 53:129:1
+-1.68702 53:129:1
+-1.6521 48:131:0
+1.68702 53:129:1
+1.72269 58:127:3
+-1.72269 58:127:3
+-1.68702 53:129:1
+1.72269 58:127:3
+1.7591 63:125:5
+-1.7591 63:125:5
+-1.72269 58:127:3
+1.7591 63:125:5
+1.79629 68:123:7
+-1.79629 68:123:7
+-1.7591 63:125:5
+1.79629 68:123:7
+1.83426 73:121:9
+-1.83426 73:121:9
+-1.79629 68:123:7
+1.83426 73:121:9
+1.87303 77:119:11
+-1.87303 77:119:11
+-1.83426 73:121:9
+1.87303 77:119:11
+1.91263 82:116:14
+-1.91263 82:116:14
+-1.87303 77:119:11
+1.91263 82:116:14
+1.95306 87:114:16
+-1.95306 87:114:16
+-1.91263 82:116:14
+1.95306 87:114:16
+1.99434 92:112:18
+-1.99434 92:112:18
+-1.95306 87:114:16
+1.99434 92:112:18
+2.0365 97:110:20
+-2.0365 97:110:20
+-1.99434 92:112:18
+2.0365 97:110:20
+2.07955 102:108:22
+-2.07955 102:108:22
+-2.0365 97:110:20
+2.07955 102:108:22
+2.12351 107:106:24
+-2.12351 107:106:24
+2.12351 107:106:24
+2.1684 112:104:26
+-2.1684 112:104:26
+2.1684 112:104:26
+2.21424 117:102:28
+-2.21424 117:102:28
+-2.1684 112:104:26
+2.21424 117:102:28
+2.26104 120:100:30
+-2.26104 120:100:30
+2.26104 120:100:30
+2.30884 120:103:31
+-2.30884 120:103:31
+2.30884 120:103:31
+2.35765 120:105:31
+-2.35765 120:105:31
+2.35765 120:105:31
+2.40749 120:107:32
+-2.40749 120:107:32
+2.40749 120:107:32
+2.45838 120:109:33
+-2.45838 120:109:33
+2.45838 120:109:33
+2.51034 120:111:33
+-2.51034 120:111:33
+2.51034 120:111:33
+2.56341 120:113:34
+-2.56341 120:113:34
+2.56341 120:113:34
+2.6176 120:115:35
+-2.6176 120:115:35
+2.6176 120:115:35
+2.67293 120:117:35
+-2.67293 120:117:35
+-2.6176 120:115:35
+2.67293 120:117:35
+2.72944 120:119:36
+-2.72944 120:119:36
+2.72944 120:119:36
+2.78713 120:121:37
+-2.78713 120:121:37
+2.78713 120:121:37
+2.84605 120:123:37
+-2.84605 120:123:37
+2.84605 120:123:37
+2.90621 120:126:38
+-2.90621 120:126:38
+2.90621 120:126:38
+2.96765 120:128:39
+-2.96765 120:128:39
+2.96765 120:128:39
+3.03038 120:130:40
+-3.03038 120:130:40
+3.03038 120:130:40
+3.09444 122:131:40
+-3.09444 122:131:40
+3.09444 122:131:40
+3.15985 124:132:40
+-3.15985 124:132:40
+3.15985 124:132:40
+3.22665 126:133:41
+-3.22665 126:133:41
+3.22665 126:133:41
+3.29486 128:134:41
+-3.29486 128:134:41
+3.29486 128:134:41
+3.36451 129:135:41
+-3.36451 129:135:41
+3.36451 129:135:41
+3.43563 131:137:42
+-3.43563 131:137:42
+3.43563 131:137:42
+3.50825 133:138:42
+-3.50825 133:138:42
+3.50825 133:138:42
+3.58241 135:139:43
+-3.58241 135:139:43
+3.58241 135:139:43
+3.65814 137:140:43
+-3.65814 137:140:43
+3.65814 137:140:43
+3.73547 139:141:43
+-3.73547 139:141:43
+3.73547 139:141:43
+3.81444 141:142:44
+-3.81444 141:142:44
+3.81444 141:142:44
+3.89507 143:144:44
+-3.89507 143:144:44
+3.89507 143:144:44
+3.97741 145:145:45
+-3.97741 145:145:45
+3.97741 145:145:45
+4.06149 147:146:45
+-4.06149 147:146:45
+4.06149 147:146:45
+4.14734 149:147:45
+-4.14734 149:147:45
+4.14734 149:147:45
+4.23501 151:148:46
+-4.23501 151:148:46
+4.23501 151:148:46
+4.32454 153:149:46
+-4.32454 153:149:46
+4.32454 153:149:46
+4.41595 155:151:47
+-4.41595 155:151:47
+4.41595 155:151:47
+4.5093 157:152:47
+-4.5093 157:152:47
+4.5093 157:152:47
+4.60462 159:153:47
+-4.60462 159:153:47
+-4.5093 157:152:47
+4.60462 159:153:47
+4.70196 161:154:48
+-4.70196 161:154:48
+4.70196 161:154:48
+4.80135 163:155:48
+-4.80135 163:155:48
+4.80135 163:155:48
+4.90285 164:156:48
+-4.90285 164:156:48
+4.90285 164:156:48
+5.00649 166:158:49
+-5.00649 166:158:49
+5.00649 166:158:49
+5.11232 168:159:49
+-5.11232 168:159:49
+5.11232 168:159:49
+5.22039 171:161:51
+-5.22039 171:161:51
+5.22039 171:161:51
+5.33075 175:166:56
+-5.33075 175:166:56
+5.33075 175:166:56
+5.44343 179:170:61
+-5.44343 179:170:61
+5.44343 179:170:61
+5.5585 183:175:65
+-5.5585 183:175:65
+5.5585 183:175:65
+5.676 187:179:70
+-5.676 187:179:70
+-5.5585 183:175:65
+5.676 187:179:70
+5.79599 191:184:75
+-5.79599 191:184:75
+-5.676 187:179:70
+5.79599 191:184:75
+5.91851 195:188:79
+-5.91851 195:188:79
+5.91851 195:188:79
+6.04362 199:192:84
+-6.04362 199:192:84
+6.04362 199:192:84
+6.17138 203:197:89
+-6.17138 203:197:89
+6.17138 203:197:89
+6.30183 207:201:93
+-6.30183 207:201:93
+6.30183 207:201:93
+6.43505 211:206:98
+-6.43505 211:206:98
+6.43505 211:206:98
+6.57108 215:210:103
+-6.57108 215:210:103
+6.70998 219:215:108
+-6.70998 219:215:108
+6.85182 223:219:112
+-6.85182 223:219:112
+6.99666 227:223:117
+-6.99666 227:223:117
+7.14457 231:228:121
+-7.14457 231:228:121
+7.1 255:255:150
+7.93232 251:250:145
+-7.93232 251:250:145
+-7.1 255:255:150
+nv 255:255:255
Copied: grass/trunk/raster/r.colors/tests/test_elev_double_example4.ref (from rev 46945, grass/trunk/raster/r.colors/test_elev_double_example4.ref)
--- grass/trunk/raster/r.colors/tests/test_elev_double_example4.ref	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/test_elev_double_example4.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,11 @@
+1 0:0:0
+2 255:255:0
+3 255:127:0
+4 255:0:0
+5 255:0:255
+6 0:127:255
+7 0:255:255
+8 0:255:0
+9 0:0:0
+nv 255:255:255
Copied: grass/trunk/raster/r.colors/tests/test_elev_double_example4_inv.ref (from rev 46945, grass/trunk/raster/r.colors/test_elev_double_example4_inv.ref)
--- grass/trunk/raster/r.colors/tests/test_elev_double_example4_inv.ref	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/test_elev_double_example4_inv.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,11 @@
+1 0:0:0
+2 255:255:0
+3 255:127:0
+4 255:0:0
+5 255:0:255
+6 0:127:255
+7 0:255:255
+8 0:255:0
+9 0:0:0
+nv 255:255:255
Copied: grass/trunk/raster/r.colors/tests/test_elev_float_example1.ref (from rev 46945, grass/trunk/raster/r.colors/test_elev_float_example1.ref)
--- grass/trunk/raster/r.colors/tests/test_elev_float_example1.ref	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/test_elev_float_example1.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,9 @@
+1.5 0:230:0
+3.1 0:160:0
+4.3 50:130:0
+5.9 120:100:30
+7.5 120:130:40
+8.7 170:160:50
+9.5 255:255:150
+nv 255:255:255
Copied: grass/trunk/raster/r.colors/tests/test_elev_float_example1_hist.ref (from rev 46945, grass/trunk/raster/r.colors/test_elev_float_example1_hist.ref)
--- grass/trunk/raster/r.colors/tests/test_elev_float_example1_hist.ref	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/test_elev_float_example1_hist.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,11 @@
+1.5 0:230:0
+1.508 0:187:0
+3.508 16:150:0
+4.508 58:127:3
+5.508 102:108:22
+6.508 120:111:33
+7.508 120:129:40
+8.508 161:155:48
+9.5 161:155:48
+nv 255:255:255
Copied: grass/trunk/raster/r.colors/tests/test_elev_float_example2.ref (from rev 46945, grass/trunk/raster/r.colors/test_elev_float_example2.ref)
--- grass/trunk/raster/r.colors/tests/test_elev_float_example2.ref	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/test_elev_float_example2.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,5 @@
+1.5 128:255:0
+5.5 255:0:128
+9.5 0:128:255
+nv 255:255:255
Copied: grass/trunk/raster/r.colors/tests/test_elev_float_example2_log.ref (from rev 46945, grass/trunk/raster/r.colors/test_elev_float_example2_log.ref)
--- grass/trunk/raster/r.colors/tests/test_elev_float_example2_log.ref	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/test_elev_float_example2_log.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,103 @@
+1.5 128:255:0
+1.52794 130:250:2
+1.55641 133:245:5
+1.58541 135:240:7
+1.61494 138:235:10
+1.64503 140:230:12
+1.67567 143:225:15
+1.70689 145:220:17
+1.73869 148:215:20
+1.77108 150:210:23
+1.80407 153:205:25
+1.83768 155:199:28
+1.87192 158:194:30
+1.90679 161:189:33
+1.94232 163:184:35
+1.9785 166:179:38
+2.01536 168:174:40
+2.0529 171:169:43
+2.09115 173:164:46
+2.13011 176:159:48
+2.16979 178:153:51
+2.21021 181:148:53
+2.25139 183:143:56
+2.29333 186:138:58
+2.33605 188:133:61
+2.37957 191:128:64
+2.42391 194:123:66
+2.46906 196:118:69
+2.51506 199:113:71
+2.56191 201:108:74
+2.60964 204:102:76
+2.65826 206:97:79
+2.70778 209:92:81
+2.75823 211:87:84
+2.80961 214:82:87
+2.86195 216:77:89
+2.91527 219:72:92
+2.96958 221:67:94
+3.0249 224:62:97
+3.08126 227:57:99
+3.13866 229:51:102
+3.19713 232:46:104
+3.25669 234:41:107
+3.31736 237:36:110
+3.37917 239:31:112
+3.44212 242:26:115
+3.50624 244:21:117
+3.57156 247:16:120
+3.6381 249:11:122
+3.70588 252:6:125
+3.77492 255:0:128
+3.84524 250:2:130
+3.91688 245:5:133
+3.98985 240:7:135
+4.06418 235:10:138
+4.13989 230:12:140
+4.21702 225:15:143
+4.29558 220:17:145
+4.3756 215:20:148
+4.45712 210:23:150
+4.54015 205:25:153
+4.62474 199:28:155
+4.71089 194:30:158
+4.79866 189:33:161
+4.88805 184:35:163
+4.97912 179:38:166
+5.07188 174:40:168
+5.16636 169:43:171
+5.26261 164:46:173
+5.36065 159:48:176
+5.46052 154:51:178
+5.56225 148:53:181
+5.66587 143:56:183
+5.77142 138:58:186
+5.87894 133:61:188
+5.98847 128:64:191
+6.10003 123:66:194
+6.21367 118:69:196
+6.32943 113:71:199
+6.44734 108:74:201
+6.56746 102:76:204
+6.68981 97:79:206
+6.81443 92:81:209
+6.94138 87:84:211
+7.0707 82:87:214
+7.20243 77:89:216
+7.3366 72:92:219
+7.47328 67:94:221
+7.61251 62:97:224
+7.75433 57:99:227
+7.89879 52:102:229
+8.04594 46:104:232
+8.19583 41:107:234
+8.34852 36:110:237
+8.50405 31:112:239
+8.66247 26:115:242
+8.82385 21:117:244
+8.98824 16:120:247
+9.15569 11:122:249
+9.32625 6:125:252
+9.5 0:128:255
+nv 255:255:255
Copied: grass/trunk/raster/r.colors/tests/test_elev_float_example3.ref (from rev 46945, grass/trunk/raster/r.colors/test_elev_float_example3.ref)
--- grass/trunk/raster/r.colors/tests/test_elev_float_example3.ref	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/test_elev_float_example3.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,9 @@
+1.5 0:230:0
+2.3 0:160:0
+2.86 50:130:0
+3.66 120:100:30
+4.46 120:130:40
+5.9 170:160:50
+7.1 255:255:150
+nv 255:255:255
Copied: grass/trunk/raster/r.colors/tests/test_elev_float_example3_logabs.ref (from rev 46945, grass/trunk/raster/r.colors/test_elev_float_example3_logabs.ref)
--- grass/trunk/raster/r.colors/tests/test_elev_float_example3_logabs.ref	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/test_elev_float_example3_logabs.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,382 @@
+1 0:230:0
+1.02114 0:226:0
+-1.02114 0:226:0
+-1 0:230:0
+1.02114 0:226:0
+1.04272 0:221:0
+-1.04272 0:221:0
+-1.02114 0:226:0
+1.04272 0:221:0
+1.06477 0:216:0
+-1.06477 0:216:0
+-1.04272 0:221:0
+1.06477 0:216:0
+1.08727 0:211:0
+-1.08727 0:211:0
+-1.06477 0:216:0
+1.08727 0:211:0
+1.11026 0:206:0
+-1.11026 0:206:0
+-1.08727 0:211:0
+1.11026 0:206:0
+1.13373 0:201:0
+-1.13373 0:201:0
+-1.11026 0:206:0
+1.13373 0:201:0
+1.15769 0:196:0
+-1.15769 0:196:0
+-1.13373 0:201:0
+1.15769 0:196:0
+1.18217 0:191:0
+-1.18217 0:191:0
+-1.15769 0:196:0
+1.18217 0:191:0
+1.20716 0:186:0
+-1.20716 0:186:0
+-1.18217 0:191:0
+1.20716 0:186:0
+1.23267 0:181:0
+-1.23267 0:181:0
+-1.20716 0:186:0
+1.23267 0:181:0
+1.25873 0:177:0
+-1.25873 0:177:0
+-1.23267 0:181:0
+1.25873 0:177:0
+1.28534 0:172:0
+-1.28534 0:172:0
+-1.25873 0:177:0
+1.28534 0:172:0
+1.31251 0:167:0
+-1.31251 0:167:0
+-1.28534 0:172:0
+1.31251 0:167:0
+1.34026 0:162:0
+-1.34026 0:162:0
+-1.31251 0:167:0
+1.34026 0:162:0
+1.36859 3:158:0
+-1.36859 3:158:0
+-1.34026 0:162:0
+1.36859 3:158:0
+1.39752 8:155:0
+-1.39752 8:155:0
+-1.36859 3:158:0
+1.39752 8:155:0
+1.42706 13:152:0
+-1.42706 13:152:0
+-1.39752 8:155:0
+1.42706 13:152:0
+1.45723 18:149:0
+-1.45723 18:149:0
+-1.42706 13:152:0
+1.45723 18:149:0
+1.48803 23:146:0
+-1.48803 23:146:0
+-1.45723 18:149:0
+1.48803 23:146:0
+1.51949 28:143:0
+-1.51949 28:143:0
+-1.48803 23:146:0
+1.51949 28:143:0
+1.55161 33:140:0
+-1.55161 33:140:0
+-1.51949 28:143:0
+1.55161 33:140:0
+1.58441 38:137:0
+-1.58441 38:137:0
+-1.55161 33:140:0
+1.58441 38:137:0
+1.6179 43:134:0
+-1.6179 43:134:0
+-1.58441 38:137:0
+1.6179 43:134:0
+1.6521 48:131:0
+-1.6521 48:131:0
+-1.6179 43:134:0
+1.6521 48:131:0
+1.68702 53:129:1
+-1.68702 53:129:1
+-1.6521 48:131:0
+1.68702 53:129:1
+1.72269 58:127:3
+-1.72269 58:127:3
+-1.68702 53:129:1
+1.72269 58:127:3
+1.7591 63:125:5
+-1.7591 63:125:5
+-1.72269 58:127:3
+1.7591 63:125:5
+1.79629 68:123:7
+-1.79629 68:123:7
+-1.7591 63:125:5
+1.79629 68:123:7
+1.83426 73:121:9
+-1.83426 73:121:9
+-1.79629 68:123:7
+1.83426 73:121:9
+1.87303 77:119:11
+-1.87303 77:119:11
+-1.83426 73:121:9
+1.87303 77:119:11
+1.91263 82:116:14
+-1.91263 82:116:14
+-1.87303 77:119:11
+1.91263 82:116:14
+1.95306 87:114:16
+-1.95306 87:114:16
+-1.91263 82:116:14
+1.95306 87:114:16
+1.99434 92:112:18
+-1.99434 92:112:18
+-1.95306 87:114:16
+1.99434 92:112:18
+2.0365 97:110:20
+-2.0365 97:110:20
+-1.99434 92:112:18
+2.0365 97:110:20
+2.07955 102:108:22
+-2.0365 97:110:20
+2.07955 102:108:22
+2.12351 107:106:24
+2.12351 107:106:24
+2.1684 112:104:26
+-2.1684 112:104:26
+2.1684 112:104:26
+2.21424 117:102:28
+-2.1684 112:104:26
+2.21424 117:102:28
+2.26104 120:100:30
+2.26104 120:100:30
+2.30884 120:103:31
+2.30884 120:103:31
+2.35765 120:105:31
+2.35765 120:105:31
+2.40749 120:107:32
+2.40749 120:107:32
+2.45838 120:109:33
+2.45838 120:109:33
+2.51034 120:111:33
+2.51034 120:111:33
+2.56341 120:113:34
+2.56341 120:113:34
+2.6176 120:115:35
+-2.6176 120:115:35
+2.6176 120:115:35
+2.67293 120:117:35
+-2.6176 120:115:35
+2.67293 120:117:35
+2.72944 120:119:36
+2.72944 120:119:36
+2.78713 120:121:37
+2.78713 120:121:37
+2.84605 120:123:37
+2.84605 120:123:37
+2.90621 120:126:38
+2.90621 120:126:38
+2.96765 120:128:39
+2.96765 120:128:39
+3.03038 120:130:40
+3.03038 120:130:40
+3.09444 122:131:40
+3.09444 122:131:40
+3.15985 124:132:40
+3.15985 124:132:40
+3.22665 126:133:41
+3.22665 126:133:41
+3.29486 128:134:41
+3.29486 128:134:41
+3.36451 129:135:41
+3.36451 129:135:41
+3.43563 131:137:42
+3.43563 131:137:42
+3.50825 133:138:42
+3.50825 133:138:42
+3.58241 135:139:43
+3.58241 135:139:43
+3.65814 137:140:43
+3.65814 137:140:43
+3.73547 139:141:43
+3.73547 139:141:43
+3.81444 141:142:44
+3.81444 141:142:44
+3.89507 143:144:44
+3.89507 143:144:44
+3.97741 145:145:45
+3.97741 145:145:45
+4.06149 147:146:45
+4.06149 147:146:45
+4.14734 149:147:45
+4.14734 149:147:45
+4.23501 151:148:46
+4.23501 151:148:46
+4.32454 153:149:46
+4.32454 153:149:46
+4.41595 155:151:47
+4.41595 155:151:47
+4.5093 157:152:47
+-4.5093 157:152:47
+4.5093 157:152:47
+4.60462 159:153:47
+-4.5093 157:152:47
+4.60462 159:153:47
+4.70196 161:154:48
+4.70196 161:154:48
+4.80135 163:155:48
+4.80135 163:155:48
+4.90285 164:156:48
+4.90285 164:156:48
+5.00649 166:158:49
+5.00649 166:158:49
+5.11232 168:159:49
+5.11232 168:159:49
+5.22039 171:161:51
+5.22039 171:161:51
+5.33075 175:166:56
+5.33075 175:166:56
+5.44343 179:170:61
+5.44343 179:170:61
+5.5585 183:175:65
+-5.5585 183:175:65
+5.5585 183:175:65
+5.676 187:179:70
+-5.676 187:179:70
+-5.5585 183:175:65
+5.676 187:179:70
+5.79599 191:184:75
+-5.676 187:179:70
+5.79599 191:184:75
+5.91851 195:188:79
+5.91851 195:188:79
+6.04362 199:192:84
+6.04362 199:192:84
+6.17138 203:197:89
+6.17138 203:197:89
+6.30183 207:201:93
+6.30183 207:201:93
+6.43505 211:206:98
+6.43505 211:206:98
+7.1 255:255:150
+-7.1 255:255:150
+nv 255:255:255
Copied: grass/trunk/raster/r.colors/tests/test_elev_float_example4.ref (from rev 46945, grass/trunk/raster/r.colors/test_elev_float_example4.ref)
--- grass/trunk/raster/r.colors/tests/test_elev_float_example4.ref	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/test_elev_float_example4.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,11 @@
+1 0:0:0
+2 255:255:0
+3 255:127:0
+4 255:0:0
+5 255:0:255
+6 0:127:255
+7 0:255:255
+8 0:255:0
+9 0:0:0
+nv 255:255:255
Copied: grass/trunk/raster/r.colors/tests/test_elev_float_example4_inv.ref (from rev 46945, grass/trunk/raster/r.colors/test_elev_float_example4_inv.ref)
--- grass/trunk/raster/r.colors/tests/test_elev_float_example4_inv.ref	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/test_elev_float_example4_inv.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,11 @@
+1 0:0:0
+2 255:255:0
+3 255:127:0
+4 255:0:0
+5 255:0:255
+6 0:127:255
+7 0:255:255
+8 0:255:0
+9 0:0:0
+nv 255:255:255
Copied: grass/trunk/raster/r.colors/tests/test_elev_int_example1.ref (from rev 46945, grass/trunk/raster/r.colors/test_elev_int_example1.ref)
--- grass/trunk/raster/r.colors/tests/test_elev_int_example1.ref	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/test_elev_int_example1.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,9 @@
+1 0:230:0
+2.6 0:160:0
+3.8 50:130:0
+5.4 120:100:30
+7 120:130:40
+8.2 170:160:50
+9 255:255:150
+nv 255:255:255
Copied: grass/trunk/raster/r.colors/tests/test_elev_int_example1_hist.ref (from rev 46945, grass/trunk/raster/r.colors/test_elev_int_example1_hist.ref)
--- grass/trunk/raster/r.colors/tests/test_elev_int_example1_hist.ref	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/test_elev_int_example1_hist.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,10 @@
+1 0:209:0
+3 0:165:0
+4 37:138:0
+5 80:117:13
+6 120:101:30
+7 120:120:36
+8 140:142:44
+9 201:195:87
+nv 255:255:255
Copied: grass/trunk/raster/r.colors/tests/test_elev_int_example1_perc.ref (from rev 46945, grass/trunk/raster/r.colors/test_elev_int_example1_perc.ref)
--- grass/trunk/raster/r.colors/tests/test_elev_int_example1_perc.ref	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/test_elev_int_example1_perc.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,9 @@
+0% 0:230:0
+20% 0:160:0
+35% 50:130:0
+55% 120:100:30
+75% 120:130:40
+90% 170:160:50
+100% 255:255:150
+nv 255:255:255
Copied: grass/trunk/raster/r.colors/tests/test_elev_int_example2.ref (from rev 46945, grass/trunk/raster/r.colors/test_elev_int_example2.ref)
--- grass/trunk/raster/r.colors/tests/test_elev_int_example2.ref	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/test_elev_int_example2.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,5 @@
+1 128:255:0
+5 255:0:128
+9 0:128:255
+nv 255:255:255
Copied: grass/trunk/raster/r.colors/tests/test_elev_int_example2_log.ref (from rev 46945, grass/trunk/raster/r.colors/test_elev_int_example2_log.ref)
--- grass/trunk/raster/r.colors/tests/test_elev_int_example2_log.ref	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/test_elev_int_example2_log.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,103 @@
+1 128:255:0
+1.02222 130:250:2
+1.04492 133:245:5
+1.06814 135:240:7
+1.09187 138:235:10
+1.11612 140:230:12
+1.14092 143:225:15
+1.16626 145:220:17
+1.19217 148:215:20
+1.21866 150:210:23
+1.24573 153:204:25
+1.27341 155:199:28
+1.30169 158:194:30
+1.33061 161:189:33
+1.36017 163:184:35
+1.39039 166:179:38
+1.42128 168:174:40
+1.45285 171:169:43
+1.48513 173:164:46
+1.51812 176:159:48
+1.55185 178:153:51
+1.58632 181:148:53
+1.62156 183:143:56
+1.65758 186:138:58
+1.69441 188:133:61
+1.73205 191:128:64
+1.77053 194:123:66
+1.80986 196:118:69
+1.85007 199:113:71
+1.89117 201:108:74
+1.93318 204:102:76
+1.97613 206:97:79
+2.02003 209:92:81
+2.0649 211:87:84
+2.11078 214:82:87
+2.15767 216:77:89
+2.2056 219:72:92
+2.2546 221:67:94
+2.30469 224:62:97
+2.35589 227:57:99
+2.40822 229:51:102
+2.46172 232:46:104
+2.51641 234:41:107
+2.57232 237:36:110
+2.62946 239:31:112
+2.68788 242:26:115
+2.74759 244:21:117
+2.80863 247:16:120
+2.87102 249:11:122
+2.9348 252:6:125
+3 255:0:128
+3.06665 250:2:130
+3.13477 245:5:133
+3.20441 240:7:135
+3.2756 235:10:138
+3.34837 230:12:140
+3.42275 225:15:143
+3.49879 220:17:145
+3.57652 215:20:148
+3.65597 210:23:150
+3.73719 205:25:153
+3.82022 199:28:155
+3.90508 194:30:158
+3.99184 189:33:161
+4.08052 184:35:163
+4.17117 179:38:166
+4.26383 174:40:168
+4.35855 169:43:171
+4.45538 164:46:173
+4.55436 159:48:176
+4.65554 154:51:178
+4.75896 148:53:181
+4.86468 143:56:183
+4.97275 138:58:186
+5.08323 133:61:188
+5.19615 128:64:191
+5.31159 123:66:194
+5.42959 118:69:196
+5.55021 113:71:199
+5.67351 108:74:201
+5.79955 102:76:204
+5.92839 97:79:206
+6.06009 92:81:209
+6.19471 87:84:211
+6.33233 82:87:214
+6.47301 77:89:216
+6.61681 72:92:219
+6.7638 67:94:221
+6.91406 62:97:224
+7.06766 57:99:227
+7.22467 52:102:229
+7.38517 46:104:232
+7.54924 41:107:234
+7.71695 36:110:237
+7.88838 31:112:239
+8.06363 26:115:242
+8.24276 21:117:244
+8.42588 16:120:247
+8.61306 11:122:249
+8.80441 6:125:252
+9 0:128:255
+nv 255:255:255
Copied: grass/trunk/raster/r.colors/tests/test_elev_int_example2_perc.ref (from rev 46945, grass/trunk/raster/r.colors/test_elev_int_example2_perc.ref)
--- grass/trunk/raster/r.colors/tests/test_elev_int_example2_perc.ref	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/test_elev_int_example2_perc.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,5 @@
+0% 128:255:0
+50% 255:0:128
+100% 0:128:255
+nv 255:255:255
Copied: grass/trunk/raster/r.colors/tests/test_elev_int_example3.ref (from rev 46945, grass/trunk/raster/r.colors/test_elev_int_example3.ref)
--- grass/trunk/raster/r.colors/tests/test_elev_int_example3.ref	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/test_elev_int_example3.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,9 @@
+1 0:230:0
+1.8 0:160:0
+2.36 50:130:0
+3.16 120:100:30
+3.96 120:130:40
+5.4 170:160:50
+6.6 255:255:150
+nv 255:255:255
Copied: grass/trunk/raster/r.colors/tests/test_elev_int_example3_logabs.ref (from rev 46945, grass/trunk/raster/r.colors/test_elev_int_example3_logabs.ref)
--- grass/trunk/raster/r.colors/tests/test_elev_int_example3_logabs.ref	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/test_elev_int_example3_logabs.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,382 @@
+1 0:230:0
+1.02049 0:226:0
+-1.02049 0:226:0
+-1 0:230:0
+1.02049 0:226:0
+1.0414 0:221:0
+-1.0414 0:221:0
+-1.02049 0:226:0
+1.0414 0:221:0
+1.06273 0:216:0
+-1.06273 0:216:0
+-1.0414 0:221:0
+1.06273 0:216:0
+1.08451 0:211:0
+-1.08451 0:211:0
+-1.06273 0:216:0
+1.08451 0:211:0
+1.10673 0:206:0
+-1.10673 0:206:0
+-1.08451 0:211:0
+1.10673 0:206:0
+1.1294 0:201:0
+-1.1294 0:201:0
+-1.10673 0:206:0
+1.1294 0:201:0
+1.15254 0:196:0
+-1.15254 0:196:0
+-1.1294 0:201:0
+1.15254 0:196:0
+1.17616 0:191:0
+-1.17616 0:191:0
+-1.15254 0:196:0
+1.17616 0:191:0
+1.20025 0:186:0
+-1.20025 0:186:0
+-1.17616 0:191:0
+1.20025 0:186:0
+1.22485 0:181:0
+-1.22485 0:181:0
+-1.20025 0:186:0
+1.22485 0:181:0
+1.24994 0:177:0
+-1.24994 0:177:0
+-1.22485 0:181:0
+1.24994 0:177:0
+1.27555 0:172:0
+-1.27555 0:172:0
+-1.24994 0:177:0
+1.27555 0:172:0
+1.30168 0:167:0
+-1.30168 0:167:0
+-1.27555 0:172:0
+1.30168 0:167:0
+1.32835 0:162:0
+-1.32835 0:162:0
+-1.30168 0:167:0
+1.32835 0:162:0
+1.35557 3:158:0
+-1.35557 3:158:0
+-1.32835 0:162:0
+1.35557 3:158:0
+1.38334 8:155:0
+-1.38334 8:155:0
+-1.35557 3:158:0
+1.38334 8:155:0
+1.41169 13:152:0
+-1.41169 13:152:0
+-1.38334 8:155:0
+1.41169 13:152:0
+1.44061 18:149:0
+-1.44061 18:149:0
+-1.41169 13:152:0
+1.44061 18:149:0
+1.47013 23:146:0
+-1.47013 23:146:0
+-1.44061 18:149:0
+1.47013 23:146:0
+1.50025 28:143:0
+-1.50025 28:143:0
+-1.47013 23:146:0
+1.50025 28:143:0
+1.53098 33:140:0
+-1.53098 33:140:0
+-1.50025 28:143:0
+1.53098 33:140:0
+1.56235 38:137:0
+-1.56235 38:137:0
+-1.53098 33:140:0
+1.56235 38:137:0
+1.59436 43:134:0
+-1.59436 43:134:0
+-1.56235 38:137:0
+1.59436 43:134:0
+1.62703 48:131:0
+-1.62703 48:131:0
+-1.59436 43:134:0
+1.62703 48:131:0
+1.66036 53:129:1
+-1.66036 53:129:1
+-1.62703 48:131:0
+1.66036 53:129:1
+1.69438 58:127:3
+-1.69438 58:127:3
+-1.66036 53:129:1
+1.69438 58:127:3
+1.7291 63:125:5
+-1.7291 63:125:5
+-1.69438 58:127:3
+1.7291 63:125:5
+1.76452 68:123:7
+-1.76452 68:123:7
+-1.7291 63:125:5
+1.76452 68:123:7
+1.80068 73:121:9
+-1.80068 73:121:9
+-1.76452 68:123:7
+1.80068 73:121:9
+1.83757 77:119:11
+-1.83757 77:119:11
+-1.80068 73:121:9
+1.83757 77:119:11
+1.87522 82:116:14
+-1.87522 82:116:14
+-1.83757 77:119:11
+1.87522 82:116:14
+1.91364 87:114:16
+-1.91364 87:114:16
+-1.87522 82:116:14
+1.91364 87:114:16
+1.95285 92:112:18
+-1.95285 92:112:18
+-1.91364 87:114:16
+1.95285 92:112:18
+1.99286 97:110:20
+-1.99286 97:110:20
+-1.95285 92:112:18
+1.99286 97:110:20
+2.03369 102:108:22
+-2.03369 102:108:22
+-1.99286 97:110:20
+2.03369 102:108:22
+2.07536 107:106:24
+-2.07536 107:106:24
+2.07536 107:106:24
+2.11788 112:104:26
+-2.11788 112:104:26
+2.11788 112:104:26
+2.16127 117:102:28
+-2.16127 117:102:28
+2.16127 117:102:28
+2.20555 120:100:30
+-2.20555 120:100:30
+2.20555 120:100:30
+2.25074 120:103:31
+-2.25074 120:103:31
+2.25074 120:103:31
+2.29685 120:105:31
+-2.29685 120:105:31
+2.29685 120:105:31
+2.34391 120:107:32
+-2.34391 120:107:32
+2.34391 120:107:32
+2.39194 120:109:33
+-2.39194 120:109:33
+2.39194 120:109:33
+2.44094 120:111:33
+-2.44094 120:111:33
+2.44094 120:111:33
+2.49096 120:113:34
+-2.49096 120:113:34
+2.49096 120:113:34
+2.54199 120:115:35
+-2.54199 120:115:35
+2.54199 120:115:35
+2.59407 120:117:35
+-2.59407 120:117:35
+2.59407 120:117:35
+2.64722 120:119:36
+-2.64722 120:119:36
+2.64722 120:119:36
+2.70146 120:121:37
+-2.70146 120:121:37
+2.70146 120:121:37
+2.75681 120:123:37
+-2.75681 120:123:37
+2.75681 120:123:37
+2.81329 120:126:38
+-2.81329 120:126:38
+2.81329 120:126:38
+2.87093 120:128:39
+-2.87093 120:128:39
+2.87093 120:128:39
+2.92975 120:130:40
+-2.92975 120:130:40
+2.92975 120:130:40
+2.98978 122:131:40
+-2.98978 122:131:40
+2.98978 122:131:40
+3.05104 124:132:40
+-3.05104 124:132:40
+3.05104 124:132:40
+3.11355 126:133:41
+-3.11355 126:133:41
+3.11355 126:133:41
+3.17734 128:134:41
+-3.17734 128:134:41
+3.17734 128:134:41
+3.24244 129:135:41
+-3.24244 129:135:41
+3.24244 129:135:41
+3.30887 131:137:42
+-3.30887 131:137:42
+3.30887 131:137:42
+3.37667 133:138:42
+-3.37667 133:138:42
+3.37667 133:138:42
+3.44585 135:139:43
+-3.44585 135:139:43
+3.44585 135:139:43
+3.51645 137:140:43
+-3.51645 137:140:43
+3.51645 137:140:43
+3.5885 139:141:43
+-3.5885 139:141:43
+3.5885 139:141:43
+3.66202 141:142:44
+-3.66202 141:142:44
+-3.5885 139:141:43
+3.66202 141:142:44
+3.73705 143:144:44
+-3.73705 143:144:44
+3.73705 143:144:44
+3.81362 145:145:45
+-3.81362 145:145:45
+3.81362 145:145:45
+3.89175 147:146:45
+-3.89175 147:146:45
+3.89175 147:146:45
+3.97149 149:147:45
+-3.97149 149:147:45
+3.97149 149:147:45
+4.05286 151:148:46
+-4.05286 151:148:46
+4.05286 151:148:46
+4.1359 153:149:46
+-4.1359 153:149:46
+4.1359 153:149:46
+4.22063 155:151:47
+-4.22063 155:151:47
+-4.1359 153:149:46
+4.22063 155:151:47
+4.30711 157:152:47
+-4.30711 157:152:47
+4.30711 157:152:47
+4.39535 159:153:47
+-4.39535 159:153:47
+4.39535 159:153:47
+4.48541 161:154:48
+-4.48541 161:154:48
+4.48541 161:154:48
+4.57731 163:155:48
+-4.57731 163:155:48
+4.57731 163:155:48
+4.67109 164:156:48
+-4.67109 164:156:48
+4.67109 164:156:48
+4.76679 166:158:49
+-4.76679 166:158:49
+4.76679 166:158:49
+4.86446 168:159:49
+-4.86446 168:159:49
+4.86446 168:159:49
+4.96413 171:161:51
+-4.96413 171:161:51
+4.96413 171:161:51
+5.06583 175:166:56
+-5.06583 175:166:56
+5.06583 175:166:56
+5.16962 179:170:61
+-5.16962 179:170:61
+5.16962 179:170:61
+5.27554 183:175:65
+-5.27554 183:175:65
+5.27554 183:175:65
+5.38363 187:179:70
+-5.38363 187:179:70
+5.38363 187:179:70
+5.49393 191:184:75
+-5.49393 191:184:75
+5.49393 191:184:75
+5.6065 195:188:79
+-5.6065 195:188:79
+5.6065 195:188:79
+5.72137 199:192:84
+-5.72137 199:192:84
+-5.6065 195:188:79
+5.72137 199:192:84
+5.83859 203:197:89
+-5.83859 203:197:89
+5.83859 203:197:89
+5.95821 207:201:93
+-5.95821 207:201:93
+5.95821 207:201:93
+6.08029 211:206:98
+-6.08029 211:206:98
+6.08029 211:206:98
+6.20486 215:210:103
+-6.20486 215:210:103
+6.33199 219:215:108
+-6.33199 219:215:108
+6.46173 223:219:112
+-6.46173 223:219:112
+6.59412 227:223:117
+-6.59412 227:223:117
+6.72922 231:228:121
+-6.72922 231:228:121
+6.6 255:255:150
+7.44741 251:250:145
+-7.44741 251:250:145
+-6.6 255:255:150
+nv 255:255:255
Copied: grass/trunk/raster/r.colors/tests/test_elev_int_example3_perc.ref (from rev 46945, grass/trunk/raster/r.colors/test_elev_int_example3_perc.ref)
--- grass/trunk/raster/r.colors/tests/test_elev_int_example3_perc.ref	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/test_elev_int_example3_perc.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,9 @@
+0% 0:230:0
+10% 0:160:0
+17% 50:130:0
+27% 120:100:30
+37% 120:130:40
+55% 170:160:50
+70% 255:255:150
+nv 255:255:255
Copied: grass/trunk/raster/r.colors/tests/test_elev_int_example4.ref (from rev 46945, grass/trunk/raster/r.colors/test_elev_int_example4.ref)
--- grass/trunk/raster/r.colors/tests/test_elev_int_example4.ref	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/test_elev_int_example4.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,11 @@
+1 0:0:0
+2 255:255:0
+3 255:127:0
+4 255:0:0
+5 255:0:255
+6 0:127:255
+7 0:255:255
+8 0:255:0
+9 0:0:0
+nv 255:255:255
Copied: grass/trunk/raster/r.colors/tests/test_elev_int_example4_inv.ref (from rev 46945, grass/trunk/raster/r.colors/test_elev_int_example4_inv.ref)
--- grass/trunk/raster/r.colors/tests/test_elev_int_example4_inv.ref	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/test_elev_int_example4_inv.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,11 @@
+1 0:0:0
+2 255:255:0
+3 255:127:0
+4 255:0:0
+5 255:0:255
+6 0:127:255
+7 0:255:255
+8 0:255:0
+9 0:0:0
+nv 255:255:255
Copied: grass/trunk/raster/r.colors/tests/test_elev_int_example4_perc.ref (from rev 46945, grass/trunk/raster/r.colors/test_elev_int_example4_perc.ref)
--- grass/trunk/raster/r.colors/tests/test_elev_int_example4_perc.ref	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/test_elev_int_example4_perc.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,11 @@
+0% 0:0:0
+12.5% 255:255:0
+25% 255:127:0
+37.5% 255:0:0
+50% 255:0:255
+62.5% 0:127:255
+75% 0:255:255
+87.5% 0:255:0
+100% 0:0:0
+nv 255:255:255
Copied: grass/trunk/raster/r.colors/tests/test_volume_double_default.ref (from rev 46945, grass/trunk/raster/r.colors/test_volume_double_default.ref)
--- grass/trunk/raster/r.colors/tests/test_volume_double_default.ref	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/test_volume_double_default.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,8 @@
+4 255:255:0
+8 0:255:0
+12 0:255:255
+16 0:0:255
+20 255:0:255
+24 255:0:0
+nv 255:255:255
Copied: grass/trunk/raster/r.colors/tests/test_volume_double_example1.ref (from rev 46945, grass/trunk/raster/r.colors/test_volume_double_example1.ref)
--- grass/trunk/raster/r.colors/tests/test_volume_double_example1.ref	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/test_volume_double_example1.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,9 @@
+4 0:230:0
+8 0:160:0
+11 50:130:0
+15 120:100:30
+19 120:130:40
+22 170:160:50
+24 255:255:150
+nv 255:255:255
Copied: grass/trunk/raster/r.colors/tests/test_volume_double_example1_hist.ref (from rev 46945, grass/trunk/raster/r.colors/test_volume_double_example1_hist.ref)
--- grass/trunk/raster/r.colors/tests/test_volume_double_example1_hist.ref	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/test_volume_double_example1_hist.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,23 @@
+4 0:230:0
+5.02 0:226:0
+6.02 0:221:0
+7.02 0:212:0
+8.02 0:199:0
+9.02 0:182:0
+10.02 0:160:0
+11.02 23:146:0
+12.02 51:130:0
+13.02 83:116:14
+14.02 116:102:28
+15.02 120:112:34
+16.02 120:124:38
+17.02 132:137:42
+18.02 153:150:46
+19.02 172:162:52
+20.02 206:200:92
+21.02 230:227:121
+22.02 245:244:138
+23.02 252:252:147
+24 252:252:147
+nv 255:255:255
Copied: grass/trunk/raster/r.colors/tests/test_volume_double_example2.ref (from rev 46945, grass/trunk/raster/r.colors/test_volume_double_example2.ref)
--- grass/trunk/raster/r.colors/tests/test_volume_double_example2.ref	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/test_volume_double_example2.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,5 @@
+4 128:255:0
+14 255:0:128
+24 0:128:255
+nv 255:255:255
Copied: grass/trunk/raster/r.colors/tests/test_volume_double_example2_log.ref (from rev 46945, grass/trunk/raster/r.colors/test_volume_double_example2_log.ref)
--- grass/trunk/raster/r.colors/tests/test_volume_double_example2_log.ref	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/test_volume_double_example2_log.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,103 @@
+4 128:255:0
+4.07232 130:250:2
+4.14594 133:245:5
+4.22089 135:240:7
+4.2972 138:235:10
+4.37489 140:230:12
+4.45399 143:225:15
+4.53451 145:220:17
+4.61649 148:215:20
+4.69995 150:210:23
+4.78492 153:204:25
+4.87143 155:199:28
+4.9595 158:194:30
+5.04917 161:189:33
+5.14045 163:184:35
+5.23338 166:179:38
+5.328 168:174:40
+5.42433 171:169:43
+5.52239 173:164:46
+5.62223 176:159:48
+5.72388 178:153:51
+5.82736 181:148:53
+5.93271 183:143:56
+6.03997 186:138:58
+6.14917 188:133:61
+6.26034 191:128:64
+6.37352 194:123:66
+6.48875 196:118:69
+6.60606 199:113:71
+6.72549 201:108:74
+6.84708 204:102:76
+6.97087 206:97:79
+7.0969 209:92:81
+7.2252 211:87:84
+7.35583 214:82:87
+7.48881 216:77:89
+7.6242 219:72:92
+7.76204 221:67:94
+7.90237 224:62:97
+8.04524 227:57:99
+8.19069 229:51:102
+8.33877 232:46:104
+8.48953 234:41:107
+8.64301 237:36:110
+8.79927 239:31:112
+8.95835 242:26:115
+9.12031 244:21:117
+9.2852 247:16:120
+9.45306 249:11:122
+9.62397 252:6:125
+9.79796 255:0:128
+9.9751 250:2:130
+10.1554 245:5:133
+10.339 240:7:135
+10.526 235:10:138
+10.7163 230:12:140
+10.91 225:15:143
+11.1072 220:17:145
+11.308 215:20:148
+11.5125 210:23:150
+11.7206 204:25:153
+11.9325 199:28:155
+12.1483 194:30:158
+12.3679 189:33:161
+12.5915 184:35:163
+12.8191 179:38:166
+13.0509 174:40:168
+13.2868 169:43:171
+13.527 164:46:173
+13.7716 159:48:176
+14.0206 153:51:178
+14.2741 148:53:181
+14.5321 143:56:183
+14.7948 138:58:186
+15.0623 133:61:188
+15.3346 128:64:191
+15.6119 123:66:194
+15.8941 118:69:196
+16.1815 113:71:199
+16.474 108:74:201
+16.7719 102:76:204
+17.0751 97:79:206
+17.3838 92:81:209
+17.6981 87:84:211
+18.018 82:87:214
+18.3438 77:89:216
+18.6754 72:92:219
+19.013 67:94:221
+19.3568 62:97:224
+19.7067 57:99:227
+20.063 51:102:229
+20.4257 46:104:232
+20.795 41:107:234
+21.171 36:110:237
+21.5537 31:112:239
+21.9434 26:115:242
+22.3401 21:117:244
+22.744 16:120:247
+23.1552 11:122:249
+23.5738 6:125:252
+24 0:128:255
+nv 255:255:255
Copied: grass/trunk/raster/r.colors/tests/test_volume_double_example3.ref (from rev 46945, grass/trunk/raster/r.colors/test_volume_double_example3.ref)
--- grass/trunk/raster/r.colors/tests/test_volume_double_example3.ref	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/test_volume_double_example3.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,9 @@
+4 0:230:0
+6 0:160:0
+7.4 50:130:0
+9.4 120:100:30
+11.4 120:130:40
+15 170:160:50
+18 255:255:150
+nv 255:255:255
Copied: grass/trunk/raster/r.colors/tests/test_volume_double_example3_logabs.ref (from rev 46945, grass/trunk/raster/r.colors/test_volume_double_example3_logabs.ref)
--- grass/trunk/raster/r.colors/tests/test_volume_double_example3_logabs.ref	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/test_volume_double_example3_logabs.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,402 @@
+1 0:230:0
+1.02988 0:226:0
+-1.02988 0:226:0
+-1 0:230:0
+1.02988 0:226:0
+1.06066 0:221:0
+-1.06066 0:221:0
+-1.02988 0:226:0
+1.06066 0:221:0
+1.09235 0:216:0
+-1.09235 0:216:0
+-1.06066 0:221:0
+1.09235 0:216:0
+1.12499 0:211:0
+-1.12499 0:211:0
+-1.09235 0:216:0
+1.12499 0:211:0
+1.15861 0:206:0
+-1.15861 0:206:0
+-1.12499 0:211:0
+1.15861 0:206:0
+1.19323 0:201:0
+-1.19323 0:201:0
+-1.15861 0:206:0
+1.19323 0:201:0
+1.22889 0:196:0
+-1.22889 0:196:0
+-1.19323 0:201:0
+1.22889 0:196:0
+1.26561 0:191:0
+-1.26561 0:191:0
+-1.22889 0:196:0
+1.26561 0:191:0
+1.30343 0:186:0
+-1.30343 0:186:0
+-1.26561 0:191:0
+1.30343 0:186:0
+1.34238 0:181:0
+-1.34238 0:181:0
+-1.30343 0:186:0
+1.34238 0:181:0
+1.38249 0:177:0
+-1.38249 0:177:0
+-1.34238 0:181:0
+1.38249 0:177:0
+1.4238 0:172:0
+-1.4238 0:172:0
+-1.38249 0:177:0
+1.4238 0:172:0
+1.46635 0:167:0
+-1.46635 0:167:0
+-1.4238 0:172:0
+1.46635 0:167:0
+1.51017 0:162:0
+-1.51017 0:162:0
+-1.46635 0:167:0
+1.51017 0:162:0
+1.5553 3:158:0
+-1.5553 3:158:0
+-1.51017 0:162:0
+1.5553 3:158:0
+1.60177 8:155:0
+-1.60177 8:155:0
+-1.5553 3:158:0
+1.60177 8:155:0
+1.64964 13:152:0
+-1.64964 13:152:0
+-1.60177 8:155:0
+1.64964 13:152:0
+1.69893 18:149:0
+-1.69893 18:149:0
+-1.64964 13:152:0
+1.69893 18:149:0
+1.7497 23:146:0
+-1.7497 23:146:0
+-1.69893 18:149:0
+1.7497 23:146:0
+1.80198 28:143:0
+-1.80198 28:143:0
+-1.7497 23:146:0
+1.80198 28:143:0
+1.85583 33:140:0
+-1.85583 33:140:0
+-1.80198 28:143:0
+1.85583 33:140:0
+1.91129 38:137:0
+-1.91129 38:137:0
+-1.85583 33:140:0
+1.91129 38:137:0
+1.9684 43:134:0
+-1.9684 43:134:0
+-1.91129 38:137:0
+1.9684 43:134:0
+2.02722 48:131:0
+-2.02722 48:131:0
+-1.9684 43:134:0
+2.02722 48:131:0
+2.0878 53:129:1
+-2.0878 53:129:1
+-2.02722 48:131:0
+2.0878 53:129:1
+2.15019 58:127:3
+-2.15019 58:127:3
+-2.0878 53:129:1
+2.15019 58:127:3
+2.21444 63:125:5
+-2.21444 63:125:5
+-2.15019 58:127:3
+2.21444 63:125:5
+2.28061 68:123:7
+-2.28061 68:123:7
+-2.21444 63:125:5
+2.28061 68:123:7
+2.34876 73:121:9
+-2.34876 73:121:9
+-2.28061 68:123:7
+2.34876 73:121:9
+2.41895 77:119:11
+-2.41895 77:119:11
+-2.34876 73:121:9
+2.41895 77:119:11
+2.49123 82:116:14
+-2.49123 82:116:14
+-2.41895 77:119:11
+2.49123 82:116:14
+2.56567 87:114:16
+-2.56567 87:114:16
+-2.49123 82:116:14
+2.56567 87:114:16
+2.64234 92:112:18
+-2.64234 92:112:18
+-2.56567 87:114:16
+2.64234 92:112:18
+2.7213 97:110:20
+-2.7213 97:110:20
+-2.64234 92:112:18
+2.7213 97:110:20
+2.80262 102:108:22
+-2.80262 102:108:22
+-2.7213 97:110:20
+2.80262 102:108:22
+2.88637 107:106:24
+-2.88637 107:106:24
+2.88637 107:106:24
+2.97262 112:104:26
+-2.97262 112:104:26
+2.97262 112:104:26
+3.06144 117:102:28
+-3.06144 117:102:28
+3.06144 117:102:28
+3.15293 120:100:30
+-3.15293 120:100:30
+3.15293 120:100:30
+3.24714 120:102:30
+-3.24714 120:102:30
+3.24714 120:102:30
+3.34417 120:105:31
+-3.34417 120:105:31
+3.34417 120:105:31
+3.44411 120:107:32
+-3.44411 120:107:32
+3.44411 120:107:32
+3.54702 120:109:33
+-3.54702 120:109:33
+3.54702 120:109:33
+3.65302 120:111:33
+-3.65302 120:111:33
+3.65302 120:111:33
+3.76218 120:113:34
+-3.76218 120:113:34
+3.76218 120:113:34
+3.8746 120:115:35
+-3.8746 120:115:35
+3.8746 120:115:35
+3.99038 120:117:35
+-3.99038 120:117:35
+-3.8746 120:115:35
+3.99038 120:117:35
+4.10962 120:119:36
+-4.10962 120:119:36
+4.10962 120:119:36
+4.23242 120:121:37
+-4.23242 120:121:37
+4.23242 120:121:37
+4.3589 120:123:37
+-4.3589 120:123:37
+4.3589 120:123:37
+4.48915 120:126:38
+-4.48915 120:126:38
+-4.3589 120:123:37
+4.48915 120:126:38
+4.6233 120:128:39
+-4.6233 120:128:39
+4.6233 120:128:39
+4.76145 120:130:40
+-4.76145 120:130:40
+-4.6233 120:128:39
+4.76145 120:130:40
+4.90373 122:131:40
+-4.90373 122:131:40
+4.90373 122:131:40
+5.05027 124:132:40
+-5.05027 124:132:40
+5.05027 124:132:40
+5.20118 126:133:41
+-5.20118 126:133:41
+5.20118 126:133:41
+5.3566 128:134:41
+-5.3566 128:134:41
+5.3566 128:134:41
+5.51667 129:135:41
+-5.51667 129:135:41
+-5.3566 128:134:41
+5.51667 129:135:41
+5.68152 131:137:42
+-5.68152 131:137:42
+5.68152 131:137:42
+5.8513 133:138:42
+-5.8513 133:138:42
+5.8513 133:138:42
+6.02615 135:139:43
+-6.02615 135:139:43
+-5.8513 133:138:42
+6.02615 135:139:43
+6.20622 137:140:43
+-6.20622 137:140:43
+6.20622 137:140:43
+6.39168 139:141:43
+-6.39168 139:141:43
+6.39168 139:141:43
+6.58267 141:143:44
+-6.58267 141:143:44
+6.58267 141:143:44
+6.77938 143:144:44
+-6.77938 143:144:44
+6.77938 143:144:44
+6.98196 145:145:45
+-6.98196 145:145:45
+6.98196 145:145:45
+7.1906 147:146:45
+-7.1906 147:146:45
+7.1906 147:146:45
+7.40547 149:147:45
+-7.40547 149:147:45
+-7.1906 147:146:45
+7.40547 149:147:45
+7.62676 151:148:46
+-7.62676 151:148:46
+7.62676 151:148:46
+7.85466 153:150:46
+-7.85466 153:150:46
+7.85466 153:150:46
+8.08938 155:151:47
+-8.08938 155:151:47
+8.08938 155:151:47
+8.3311 157:152:47
+-8.3311 157:152:47
+8.3311 157:152:47
+8.58006 159:153:47
+-8.58006 159:153:47
+-8.3311 157:152:47
+8.58006 159:153:47
+8.83645 161:154:48
+-8.83645 161:154:48
+8.83645 161:154:48
+9.1005 163:155:48
+-9.1005 163:155:48
+9.1005 163:155:48
+9.37244 165:157:49
+-9.37244 165:157:49
+-9.1005 163:155:48
+9.37244 165:157:49
+9.65251 166:158:49
+-9.65251 166:158:49
+9.65251 166:158:49
+9.94095 168:159:49
+-9.94095 168:159:49
+9.94095 168:159:49
+10.238 171:161:52
+-10.238 171:161:52
+10.238 171:161:52
+10.5439 175:166:56
+-10.5439 175:166:56
+-10.238 171:161:52
+10.5439 175:166:56
+10.859 179:170:61
+-10.859 179:170:61
+10.859 179:170:61
+11.1835 183:175:66
+-11.1835 183:175:66
+-10.859 179:170:61
+11.1835 183:175:66
+11.5177 187:179:70
+-11.5177 187:179:70
+11.5177 187:179:70
+11.8619 191:184:75
+-11.8619 191:184:75
+11.8619 191:184:75
+12.2163 195:188:80
+-12.2163 195:188:80
+12.2163 195:188:80
+12.5814 199:192:84
+-12.5814 199:192:84
+12.5814 199:192:84
+12.9573 203:197:89
+-12.9573 203:197:89
+12.9573 203:197:89
+13.3445 207:201:94
+-13.3445 207:201:94
+13.3445 207:201:94
+13.7433 211:206:98
+-13.7433 211:206:98
+13.7433 211:206:98
+14.154 215:210:103
+-14.154 215:210:103
+14.154 215:210:103
+14.5769 219:215:108
+-14.5769 219:215:108
+15.0125 223:219:112
+-15.0125 223:219:112
+15.4611 227:223:117
+-15.4611 227:223:117
+15.9231 231:228:122
+-15.9231 231:228:122
+16.3989 235:232:126
+-16.3989 235:232:126
+16.889 239:237:131
+-16.889 239:237:131
+16.889 239:237:131
+17.3937 243:241:135
+-17.3937 243:241:135
+17.9134 247:246:140
+-17.9134 247:246:140
+18.4487 251:250:145
+-18.4487 251:250:145
+18 255:255:150
+-18 255:255:150
+nv 255:255:255
Copied: grass/trunk/raster/r.colors/tests/test_volume_double_example4.ref (from rev 46945, grass/trunk/raster/r.colors/test_volume_double_example4.ref)
--- grass/trunk/raster/r.colors/tests/test_volume_double_example4.ref	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/test_volume_double_example4.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,11 @@
+1 0:0:0
+2 255:255:0
+3 255:127:0
+4 255:0:0
+5 255:0:255
+6 0:127:255
+7 0:255:255
+8 0:255:0
+9 0:0:0
+nv 255:255:255
Copied: grass/trunk/raster/r.colors/tests/test_volume_double_example4_inv.ref (from rev 46945, grass/trunk/raster/r.colors/test_volume_double_example4_inv.ref)
--- grass/trunk/raster/r.colors/tests/test_volume_double_example4_inv.ref	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/test_volume_double_example4_inv.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,11 @@
+1 0:0:0
+2 255:255:0
+3 255:127:0
+4 255:0:0
+5 255:0:255
+6 0:127:255
+7 0:255:255
+8 0:255:0
+9 0:0:0
+nv 255:255:255
Copied: grass/trunk/raster/r.colors/tests/test_volume_double_example5.ref (from rev 46945, grass/trunk/raster/r.colors/test_volume_double_example5.ref)
--- grass/trunk/raster/r.colors/tests/test_volume_double_example5.ref	                        (rev 0)
+++ grass/trunk/raster/r.colors/tests/test_volume_double_example5.ref	2011-07-04 09:06:40 UTC (rev 46951)
@@ -0,0 +1,11 @@
+1 0:0:0
+2 255:255:0
+3 255:127:0
+4 255:0:0
+5 255:0:255
+6 0:127:255
+7 0:255:255
+8 0:255:0
+9 0:0:0
+nv 255:255:255
