[GRASS-SVN] r46963 - grass/trunk/vector/v.edit
svn_grass at osgeo.org
Mon Jul 4 06:56:43 EDT 2011
Author: mmetz
Date: 2011-07-04 03:56:43 -0700 (Mon, 04 Jul 2011)
New Revision: 46963
grass/trunk/vector/v.edit/select.c
remove redundant code in vector lib: update v.edit
Modified: grass/trunk/vector/v.edit/select.c
--- grass/trunk/vector/v.edit/select.c 2011-07-04 10:52:03 UTC (rev 46962)
+++ grass/trunk/vector/v.edit/select.c 2011-07-04 10:56:43 UTC (rev 46963)
@@ -350,7 +350,7 @@
first_selection = 0;
else {
- List_tmp = Vect_new_boxlist();
+ List_tmp = Vect_new_boxlist(0);
/* bounding box */
@@ -367,7 +367,7 @@
/* merge lists (only duplicate items) */
if (List_tmp != List) {
- merge_lists(List, List_tmp);
+ merge_lists2(List, List_tmp);
Vect_destroy_boxlist(List_tmp);
