[GRASS-SVN] r47000 - grass/trunk/gui/wxpython/gui_modules
Tue Jul 5 09:11:57 EDT 2011
Author: martinl
Date: 2011-07-05 06:11:57 -0700 (Tue, 05 Jul 2011)
New Revision: 47000
Removed:
   grass/trunk/gui/wxpython/gui_modules/mapdisp_command.py
   grass/trunk/gui/wxpython/gui_modules/__init__.py
   grass/trunk/gui/wxpython/gui_modules/mapdisp.py
wxGUI: remove unused mapdisp_command.py module
Modified: grass/trunk/gui/wxpython/gui_modules/__init__.py
--- grass/trunk/gui/wxpython/gui_modules/__init__.py	2011-07-05 13:10:15 UTC (rev 46999)
+++ grass/trunk/gui/wxpython/gui_modules/__init__.py	2011-07-05 13:11:57 UTC (rev 47000)
@@ -17,7 +17,6 @@
     "histogram.py",
     "layertree.py",
     "location_wizard.py",
-    "mapdisp_command.py",
     "mapdisp_window.py",
     "mapdisp.py",
     "mcalc_builder.py",
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2011-07-05 13:10:15 UTC (rev 46999)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2011-07-05 13:11:57 UTC (rev 47000)
@@ -54,7 +54,6 @@
 from icon        import Icons
 from preferences import globalSettings as UserSettings
-from mapdisp_command import Command
 from mapdisp_window  import BufferedWindow
 from grass.script import core as grass
@@ -2028,8 +2027,6 @@
         self.mapFrm.Show()
         if __name__ == "__main__":
-            #status = Command(self, Map, cmdfile)
-            # status.start()
             self.timer = wx.PyTimer(self.watcher)
             #check each 0.5s
             global mtime
Deleted: grass/trunk/gui/wxpython/gui_modules/mapdisp_command.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp_command.py	2011-07-05 13:10:15 UTC (rev 46999)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp_command.py	2011-07-05 13:11:57 UTC (rev 47000)
@@ -1,75 +0,0 @@
- at package mapdisp.py
- at brief Command line useg of GIS map display canvas.view).
-Classes:
- - Command
-(C) 2006-2009 by the GRASS Development Team
-This program is free software under the GNU General Public
-License (>=v2). Read the file COPYING that comes with GRASS
-for details.
- at author Jachym Cepicky
-import sys
-import time
-from debug import Debug
-from threading import Thread
-class Command(Thread):
-    Creates thread which will observe the command file and see, if
-    there is new command to be executed
-    def __init__ (self, parent, Map, cmdfile):
-        Thread.__init__(self)
-        global cmdfilename
-        self.parent = parent
-        self.map = Map
-        self.cmdfile = open(cmdfile, "r")
-    def run(self):
-        Run this in thread
-        dispcmd = []
-        while 1:
-            self.parent.redraw = False
-            line = self.cmdfile.readline().strip()
-            if line == "quit":
-                break
-            if line:
-                try:
-                    Debug.msg (3, "Command.run(): cmd=%s" % (line))
-                    cmd = line.split(" ")
-                    opacity = 1
-                    if " opacity=" in line:
-                        cmd2 = cmd
-                        cmd = []
-                        for c in cmd2:
-                            if c.find("opacity=") == 0:
-                                opacity = float(c.split("=")[1]) / 100
-                            else:
-                                cmd.append(c)
-                    self.map.AddLayer(type="raster",
-                                      name='',
-                                      command=cmd,
-                                      l_opacity=opacity)
-                    self.parent.redraw =True
-                except Exception, e:
-                    print "Command Thread: ",e
-            time.sleep(0.1)
-        sys.exit()
