[GRASS-SVN] r47009 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Tue Jul 5 16:45:52 EDT 2011
Author: annakrat
Date: 2011-07-05 13:45:52 -0700 (Tue, 05 Jul 2011)
New Revision: 47009
grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
grass/trunk/gui/wxpython/gui_modules/wxnviz.py
wxNviz: minor fixes in volume page
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py 2011-07-05 18:40:41 UTC (rev 47008)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py 2011-07-05 20:45:52 UTC (rev 47009)
@@ -1176,7 +1176,7 @@
isosurfId = 0
for isosurf in data['isosurface']:
- for attrb in ('color', 'mask',
+ for attrb in ('topo', 'color', 'mask',
'transp', 'shine'):
if attrb not in isosurf or \
'update' not in isosurf[attrb]:
@@ -1186,7 +1186,9 @@
if map is None: # unset
# only optional attributes
- if attrb == 'mask':
+ if attrb == 'topo' :
+ self._display.SetIsosurfaceTopo(id, isosurfId, map, str(value))
+ elif attrb == 'mask':
# TODO: invert mask
# TODO: broken in NVIZ
self._display.UnsetIsosurfaceMask(id, isosurfId)
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_tools.py 2011-07-05 18:40:41 UTC (rev 47008)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_tools.py 2011-07-05 20:45:52 UTC (rev 47009)
@@ -1453,7 +1453,7 @@
size = (65, -1)
if fs:
value = fs.FloatSpin(parent = panel, id = wx.ID_ANY,
- size = size, increment = 0.5, value = 0)
+ size = size, increment = 1, value = 0)
value.SetFormat("%f")
value.SetDigits(1)
else:
@@ -2332,7 +2332,8 @@
incSel = -1 # decrement selection (no 'unset')
else:
incSel = 0
+ if nvizType == 'volume' and attrb == 'topo':
+ return
if map is True: # map
if attrb != 'topo': # changing map topography not allowed
# not sure why, but here must be disabled both ids, should be fixed!
@@ -2346,10 +2347,11 @@
self.FindWindowById(self.win[nvizType][attrb]['const']).Enable(True)
self.FindWindowById(self.win[nvizType][attrb]['use']).SetSelection(2 + incSel)
else: # unset
+ self.FindWindowById(self.win[nvizType][attrb]['use']).SetSelection(0)
self.FindWindowById(self.win[nvizType][attrb]['map'] + 1).Enable(False)
if self.win[nvizType][attrb]['const']:
self.FindWindowById(self.win[nvizType][attrb]['const']).Enable(False)
- self.FindWindowById(self.win[nvizType][attrb]['use']).SetSelection(0)
def OnSurfaceMap(self, event):
"""!Set surface attribute"""
@@ -2363,31 +2365,33 @@
if not self.mapWindow.init:
return
- attrb = self.__GetWindowName(self.win[nvizType], winId)
+ attrb = self.__GetWindowName(self.win[nvizType], winId)
if not attrb:
return
- if nvizType == 'volume' and attrb == 'topo':
- return
- selection = self.FindWindowById(self.win[nvizType][attrb]['use']).GetSelection()
- if self.win[nvizType][attrb]['required']:
- selection += 1
+ if not (nvizType == 'volume' and attrb == 'topo'):
+ selection = self.FindWindowById(self.win[nvizType][attrb]['use']).GetSelection()
+ if self.win[nvizType][attrb]['required']:
+ selection += 1
- if selection == 0: # unset
+ if selection == 0: # unset
+ useMap = None
+ value = ''
+ elif selection == 1: # map
+ value = self.FindWindowById(self.win[nvizType][attrb]['map']).GetValue()
+ useMap = True
+ else: # constant
+ if attrb == 'color':
+ value = self.FindWindowById(self.win[nvizType][attrb]['const']).GetColour()
+ # tuple to string
+ value = self._getColorString(value)
+ else:
+ value = self.FindWindowById(self.win[nvizType][attrb]['const']).GetValue()
+ useMap = False
+ else:
useMap = None
- value = ''
- elif selection == 1: # map
- value = self.FindWindowById(self.win[nvizType][attrb]['map']).GetValue()
- useMap = True
- else: # constant
- if attrb == 'color':
- value = self.FindWindowById(self.win[nvizType][attrb]['const']).GetColour()
- # tuple to string
- value = self._getColorString(value)
- else:
- value = self.FindWindowById(self.win[nvizType][attrb]['const']).GetValue()
- useMap = False
if not self.pageChanging:
name = self.FindWindowById(self.win[nvizType]['map']).GetValue()
if nvizType == 'surface':
@@ -2403,6 +2407,11 @@
data[nvizType]['isosurface'][id][attrb] = { 'map' : useMap,
'value' : str(value),
'update' : None }
+ if attrb == 'topo':
+ list = self.FindWindowById(self.win['volume']['isosurfs'])
+ sel = list.GetSelection()
+ list.SetString(sel, "%s %s" % (_("Level"), str(value)))
+ list.Check(sel)
# update properties
event = wxUpdateProperties(data = data)
@@ -3362,7 +3371,15 @@
self.FindWindowById(self.win['surface']['shine']['map']).SetValue(value)
else:
self.FindWindowById(self.win['surface']['shine']['const']).SetValue(value)
+ if 'transp' in data['attribute']:
+ value = data['attribute']['transp']['value']
+ if data['attribute']['transp']['map']:
+ self.FindWindowById(self.win['surface']['color']['map']).SetValue(value)
+ else:
+ self.FindWindowById(self.win['surface']['transp']['const']).SetValue(value)
+ self.SetMapObjUseMap(nvizType = 'surface', attrb = 'transp', map = data['attribute']['transp']['map'])
+ else:
+ self.SetMapObjUseMap(nvizType = 'surface', attrb = 'transp', map = None)
# draw
@@ -3581,9 +3598,6 @@
'transp', 'shine'):
# check required first
- if attrb == 'topo':
- self.FindWindowById(self.win['volume'][attrb]['const']).SetValue(0)
- continue
if layer and layer.type == '3d-raster':
self.FindWindowById(self.win['volume'][attrb]['map']).SetValue(layer.name)
@@ -3595,6 +3609,8 @@
# skip empty attributes
if attrb not in data:
+ self.SetMapObjUseMap(nvizType = 'volume',
+ attrb = attrb, map = None)
continue
value = data[attrb]['value']
@@ -3607,9 +3623,10 @@
else:
if data[attrb]['map']:
win = self.FindWindowById(self.win['volume'][attrb]['map'])
+ win.SetValue(value)
else:
win = self.FindWindowById(self.win['volume'][attrb]['const'])
- win.SetValue(value)
+ win.SetValue(float(value))
attrb = attrb, map = data[attrb]['map'])
Modified: grass/trunk/gui/wxpython/gui_modules/wxnviz.py
--- grass/trunk/gui/wxpython/gui_modules/wxnviz.py 2011-07-05 18:40:41 UTC (rev 47008)
+++ grass/trunk/gui/wxpython/gui_modules/wxnviz.py 2011-07-05 20:45:52 UTC (rev 47009)
@@ -1021,6 +1021,21 @@
return 1
+ def SetIsosurfaceTopo(self, id, isosurf_id, map, value):
+ """!Set isosurface level
+ @param id volume id
+ @param isosurf_id isosurface id (0 - MAX_ISOSURFS)
+ @param map if true use map otherwise constant
+ @param value map name of value
+ @return 1 on success
+ @return -1 volume not found
+ @return -2 isosurface not found
+ @return -3 on failure
+ return self.SetIsosurfaceAttr(id, isosurf_id, ATT_TOPO, map, value)
def SetIsosurfaceColor(self, id, isosurf_id, map, value):
"""!Set isosurface color
@@ -1051,7 +1066,7 @@
- return self.SetIsosurfaceAttr(id, isosurf_id, ATT_MASK, true, value)
+ return self.SetIsosurfaceAttr(id, isosurf_id, ATT_MASK, True, value)
def SetIsosurfaceTransp(self, id, isosurf_id, map, value):
"""!Set isosurface transparency
